[PATCH rtems-libbsd 2/4] usb_template: Configure template driver only for CDC Ethernet
Christian Mauderer oss at c-mauderer.de
Thu Jul 15 19:47:59 UTC 2021
Hello Husni,
On 06/07/2021 19:00, Husni Faiz wrote:
> Add the conditional macro to prevent the driver from referencing
> the templates which are not imported yet.
> Include functions which adds the hw.usb.template sysctl variable.
> Signed-off-by: Husni Faiz <ahamedhusni73 at gmail.com>
>   freebsd/sys/dev/usb/template/usb_template.c | 4 ++++
>   freebsd/sys/dev/usb/usb_device.c            | 4 ++--
>   2 files changed, 6 insertions(+), 2 deletions(-)
> diff --git a/freebsd/sys/dev/usb/template/usb_template.c b/freebsd/sys/dev/usb/template/usb_template.c
> index 0650da15..fe90d5b7 100644
> --- a/freebsd/sys/dev/usb/template/usb_template.c
> +++ b/freebsd/sys/dev/usb/template/usb_template.c
> @@ -1433,12 +1433,15 @@ usb_temp_setup_by_index(struct usb_device *udev, uint16_t index)
>   	usb_error_t err;
>   	switch (index) {
> +#ifndef __rtems__
>   	case USB_TEMP_MSC:
>   		err = usb_temp_setup(udev, &usb_template_msc);
>   		break;
> +#endif
>   	case USB_TEMP_CDCE:
>   		err = usb_temp_setup(udev, &usb_template_cdce);
>   		break;
> +#ifndef __rtems__
>   	case USB_TEMP_MTP:
>   		err = usb_temp_setup(udev, &usb_template_mtp);
>   		break;
> @@ -1469,6 +1472,7 @@ usb_temp_setup_by_index(struct usb_device *udev, uint16_t index)
>   	case USB_TEMP_CDCEEM:
>   		err = usb_temp_setup(udev, &usb_template_cdceem);
>   		break;
> +#endif
>   	default:
>   		return (USB_ERR_INVAL);
> diff --git a/freebsd/sys/dev/usb/usb_device.c b/freebsd/sys/dev/usb/usb_device.c
> index ee240949..28ef1b74 100644
> --- a/freebsd/sys/dev/usb/usb_device.c
> +++ b/freebsd/sys/dev/usb/usb_device.c
> @@ -123,7 +123,7 @@ int	usb_template = USB_TEMPLATE;
>   int	usb_template = -1;
>   #endif
> -#ifndef __rtems__
> +#if !defined(__rtems__) || defined(RTEMS_BSD_MODULE_DEV_USB_TEMPLATE)
Shouldn't there be an include for the rtems/bsd/modules.h somewhere if
you use the RTEMS_BSD_MODULE_DEV_USB_TEMPLATE define?
>   SYSCTL_PROC(_hw_usb, OID_AUTO, template,
>       CTLTYPE_INT | CTLFLAG_RWTUN | CTLFLAG_MPSAFE,
>       NULL, 0, sysctl_hw_usb_template,
> @@ -255,7 +255,7 @@ sysctl_hw_usb_template(SYSCTL_HANDLER_ARGS)
>   	return (0);
> -#endif /* __rtems__ */
> +#endif /* !__rtmes__ || RTEMS_BSD_MODULE_DEV_USB_TEMPLATE */
>   /* English is default language */
