[PATCH rtems-libbsd 0/4] Beagle BSP: USB Template Driver for CDC Ethernet
Christian Mauderer
oss at c-mauderer.de
Thu Jul 15 19:54:32 UTC 2021
Hello Husni,
On 14/07/2021 20:18, Ahamed Husni wrote:
> Hi,
> Ping :)
Sorry for the late reply. I hoped that someone else would review the
patches. I already had a look at them before you sent them.
I only found two small points. Otherwise the patches look fine. Can you
fix the two points and then send a v2? I think you also mentioned having
the patches ported to the 6-freebsd-12 branch? If you post v2: Can you
just add a link to a branch with these in your [Patch 0/x] mail?
Best regards
Christian
> On Tue, Jul 6, 2021 at 10:30 PM Husni Faiz <ahamedhusni73 at gmail.com
> <mailto:ahamedhusni73 at gmail.com>> wrote:
> This set of patches import the drivers from freebsd and
> configures it for the beagle bsp.
> Github Branch for the commits
> https://github.com/drac98/rtems-libbsd/commits/usb-cdce
> <https://github.com/drac98/rtems-libbsd/commits/usb-cdce>
> Husni Faiz (4):
> usb_template:Import CDC Ethernet
> usb_template: Configure template driver only for CDC Ethernet
> nexus-devices: Include CDC Ethernet for Beagle
> libbsd.py: add usb template files
> buildset/default.ini | 1 +
> buildset/minimal.ini | 3 +-
> freebsd/sys/dev/usb/template/usb_template.c | 1493 +++++++++++++++++
> freebsd/sys/dev/usb/template/usb_template.h | 130 ++
> .../sys/dev/usb/template/usb_template_cdce.c | 355 ++++
> freebsd/sys/dev/usb/usb_device.c | 4 +-
> libbsd.py | 25 +
> rtemsbsd/include/bsp/nexus-devices.h | 5 +
> .../include/machine/rtems-bsd-nexus-bus.h | 17 +
> 9 files changed, 2030 insertions(+), 3 deletions(-)
> create mode 100644 freebsd/sys/dev/usb/template/usb_template.c
> create mode 100644 freebsd/sys/dev/usb/template/usb_template.h
> create mode 100644 freebsd/sys/dev/usb/template/usb_template_cdce.c
> 2.25.1
> devel mailing list
> devel at rtems.org
