[PATCH] AddressToLineMapper.h: Remove pointer to temporary string
Alex White
alex.white at oarcorp.com
Fri Jul 16 18:03:56 UTC 2021
CID 1505281: Pointer to local outside scope
Closes #4473
tester/covoar/AddressToLineMapper.cc | 11 ++++++++---
tester/covoar/AddressToLineMapper.h | 21 ++++++++++++++++-----
2 files changed, 24 insertions(+), 8 deletions(-)
diff --git a/tester/covoar/AddressToLineMapper.cc b/tester/covoar/AddressToLineMapper.cc
index c305e3b..838b156 100644
--- a/tester/covoar/AddressToLineMapper.cc
+++ b/tester/covoar/AddressToLineMapper.cc
@@ -19,9 +19,13 @@ namespace Coverage {
return is_end_sequence;
- const std::string& SourceLine::path() const
+ const std::string SourceLine::path() const
- return path_;
+ if (!path_) {
+ return "unknown";
+ } else {
+ return *path_;
int SourceLine::line() const
@@ -31,7 +35,8 @@ namespace Coverage {
void AddressLineRange::addSourceLine(const rld::dwarf::address& address)
- auto insertResult = sourcePaths.insert(address.path());
+ auto insertResult = sourcePaths.insert(
+ std::make_shared<std::string>(address.path()));
sourceLines.emplace_back(
SourceLine (
diff --git a/tester/covoar/AddressToLineMapper.h b/tester/covoar/AddressToLineMapper.h
index 88bf475..308925a 100644
--- a/tester/covoar/AddressToLineMapper.h
+++ b/tester/covoar/AddressToLineMapper.h
@@ -8,6 +8,7 @@
#define __ADDRESS_TO_LINE_MAPPER_H__
#include <cstdint>
+#include <memory>
#include <set>
#include <string>
#include <vector>
@@ -26,7 +27,7 @@ namespace Coverage {
SourceLine()
: address(0),
- path_("unknown"),
+ path_(nullptr),
line_num(-1),
is_end_sequence(true)
@@ -34,7 +35,7 @@ namespace Coverage {
SourceLine(
uint64_t addr,
- const std::string& src,
+ const std::shared_ptr<std::string>& src,
int line,
bool end_sequence
) : address(addr),
@@ -64,7 +65,7 @@ namespace Coverage {
* @return Returns the source file path of this address
- const std::string& path() const;
+ const std::string path() const;
* This method gets the source line number of this address.
@@ -84,7 +85,7 @@ namespace Coverage {
* An iterator pointing to the location in the set that contains the
* source file path of the address.
- const std::string& path_;
+ const std::shared_ptr<std::string> path_;
* The source line number of the address.
@@ -100,7 +101,17 @@ namespace Coverage {
typedef std::vector<SourceLine> SourceLines;
- typedef std::set<std::string> SourcePaths;
+ /* This allows comparison of strings owned by shared_ptrs. */
+ struct SharedStringCmp {
+ bool operator()(
+ const std::shared_ptr<std::string>& lhs,
+ const std::shared_ptr<std::string>& rhs
+ ) const {
+ return *lhs < *rhs;
+ typedef std::set<std::shared_ptr<std::string>, SharedStringCmp> SourcePaths;
/*! @class AddressLineRange
2.27.0
