[PATCH] build: Add the BSP family to the enable set
Sebastian Huber
Tue Jul 20 10:25:20 UTC 2021
On 15/07/2021 08:19, Sebastian Huber wrote:
> This makes it possible to use the BSP family in expressions of the enabled-by
> attribute.
> wscript | 7 ++++++-
> 1 file changed, 6 insertions(+), 1 deletion(-)
> diff --git a/wscript b/wscript
> index 487951fdba..1331ae149e 100755
> --- a/wscript
> +++ b/wscript
> @@ -1387,7 +1387,12 @@ def configure_variant(conf, cp, bsp_map, path_list, top_group, variant):
> # For the enabled-by evaluation we have to use the base BSP defined by the
> # build specification and not the BSP name provided by the user.
> - conf.env["ENABLE"] = [get_compiler(conf, cp, variant), arch, arch_bsp]
> + conf.env["ENABLE"] = [
> + get_compiler(conf, cp, variant),
> + arch,
> + arch_family,
> + arch_bsp,
> conf.env["TOP"] = conf.path.abspath()
> conf.env["TOPGROUP"] = top_group
This actually broke some riscv BSPs which do not support SMP. We have
cat spec/build/cpukit/optsmp.yml
SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
actions:
- get-boolean: null
- env-enable: null
- define-condition: null
build-type: option
copyrights:
- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
default: false
default-by-family: []
default-by-variant: []
description: |
Enable the Symmetric Multiprocessing (SMP) support
enabled-by:
- arm/altcycv_devkit
- arm/fvp_cortex_r52
- arm/imx7
- arm/raspberrypi2
- arm/realview_pbx_a9_qemu
- arm/xilinx_zynq_a9_qemu
- arm/xilinx_zynqmp_ultra96
- arm/xilinx_zynq_zc702
- arm/xilinx_zynq_zc706
- arm/xilinx_zynq_zedboard
- powerpc/qoriq_e500
- powerpc/qoriq_e6500_32
- powerpc/qoriq_e6500_64
- riscv/griscv
- riscv/grv32imac
- riscv/grv32imafdc
- riscv/rv32iac
- riscv/rv32imac
- riscv/rv32imafc
- riscv/rv32imafd
- riscv/rv32imafdc
- riscv/rv64imac
- riscv/rv64imac_medany
- riscv/rv64imafd
- riscv/rv64imafdc
- riscv/rv64imafdc_medany
- riscv/rv64imafd_medany
- sparc/erc32
- sparc/gr712rc
- sparc/gr740
- sparc/leon3
links: []
type: build
The problem is that one BSP which supports SMP "riscv/griscv" is
identical to the family "riscv/griscv" which contains BSPs which do not
support SMP ("riscv/grv32i" and riscv/grv32im").
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
