[PATCH] bsp: Remove fatal from exit(0). Add extended heap error output
chrisj at rtems.org
chrisj at rtems.org
Wed Jul 21 05:17:41 UTC 2021
bsps/shared/start/bspfatal-default.c | 53 +++++++++++++++++++++++++---
1 file changed, 49 insertions(+), 4 deletions(-)
diff --git a/bsps/shared/start/bspfatal-default.c b/bsps/shared/start/bspfatal-default.c
index 0289dbda63..5e93b21b04 100644
--- a/bsps/shared/start/bspfatal-default.c
+++ b/bsps/shared/start/bspfatal-default.c
@@ -22,15 +22,24 @@ void bsp_fatal_extension(
#if BSP_VERBOSE_FATAL_EXTENSION
Thread_Control *executing;
+ const char* TYPE = "*** FATAL ***\n";
+ const char* type = "fatal";
+ if ( source == RTEMS_FATAL_SOURCE_EXIT ) {
+ TYPE = "";
+ type = "exit";
printk(
"\n"
- "*** FATAL ***\n"
- "fatal source: %i (%s)\n"
+ "%s"
+ "%s source: %i (%s)\n"
#ifdef RTEMS_SMP
"CPU: %" PRIu32 "\n"
#endif
+ TYPE,
+ type,
source,
rtems_fatal_source_text( source )
#ifdef RTEMS_SMP
@@ -48,13 +57,49 @@ void bsp_fatal_extension(
else if ( source == INTERNAL_ERROR_CORE ) {
printk(
- "fatal code: %ju (%s)\n",
+ "%s code: %ju (%s)\n",
+ type,
(uintmax_t) code,
rtems_internal_error_text( code )
+ } else if ( source == RTEMS_FATAL_SOURCE_HEAP ) {
+ Heap_Error_context *error_context = (Heap_Error_context*) code;
+ const char* reasons[] = {
+ "HEAP_ERROR_BROKEN_PROTECTOR",
+ "HEAP_ERROR_FREE_PATTERN",
+ "HEAP_ERROR_DOUBLE_FREE",
+ "HEAP_ERROR_BAD_USED_BLOCK",
+ "HEAP_ERROR_BAD_FREE_BLOCK"
+ const char* reason = "invalid reason";
+ if ( error_context->reason <= (int) HEAP_ERROR_BAD_FREE_BLOCK ) {
+ reason = reasons[(int) error_context->reason];
+ printk(
+ "heap error: heap=%p block=%p reason=%s(%d)",
+ error_context->heap,
+ error_context->block,
+ reason,
+ error_context->reason
+ if ( error_context->reason == HEAP_ERROR_BROKEN_PROTECTOR ) {
+ uintptr_t *pb0 = &error_context->block->Protection_begin.protector [0];
+ uintptr_t *pb1 = &error_context->block->Protection_begin.protector [1];
+ uintptr_t *pe0 = &error_context->block->Protection_end.protector [0];
+ uintptr_t *pe1 = &error_context->block->Protection_end.protector [1];
+ printk(
+ "=[%p,%p,%p,%p]",
+ *pb0 != HEAP_BEGIN_PROTECTOR_0 ? pb0 : NULL,
+ *pb1 != HEAP_BEGIN_PROTECTOR_1 ? pb1 : NULL,
+ *pe0 != HEAP_END_PROTECTOR_0 ? pe0 : NULL,
+ *pe1 != HEAP_END_PROTECTOR_1 ? pe1 : NULL
+ printk( "\n" );
} else {
printk(
- "fatal code: %ju (0x%08jx)\n",
+ "%s code: %ju (0x%08jx)\n",
+ type,
(uintmax_t) code,
(uintmax_t) code
2.24.1
