[PATCH 15/41] bsps/irq: bsp_interrupt_vector_enable()
Wed Jul 21 18:17:55 UTC 2021
On Mon, Jul 12, 2021 at 6:50 AM Sebastian Huber
> Return a status code for bsp_interrupt_vector_enable().
> Update #3269.
>  bsps/arm/beagle/irq/irq.c                 |  3 ++-
>  bsps/arm/csb336/irq/irq.c                 |  4 +++-
>  bsps/arm/csb337/irq/irq.c                 |  3 ++-
>  bsps/arm/edb7312/irq/irq.c                |  4 +++-
>  bsps/arm/gumstix/irq/irq.c                |  3 ++-
>  bsps/arm/lpc24xx/irq/irq.c                |  3 ++-
>  bsps/arm/lpc32xx/irq/irq.c                |  4 +++-
>  bsps/arm/raspberrypi/irq/irq.c            |  3 ++-
>  bsps/arm/rtl22xx/irq/irq.c                |  3 ++-
>  bsps/arm/shared/irq/irq-armv7m.c          |  3 ++-
>  bsps/arm/smdk2410/irq/irq.c               |  3 ++-
>  bsps/arm/tms570/irq/irq.c                 |  3 ++-
>  bsps/i386/shared/irq/irq.c                |  3 ++-
>  bsps/include/bsp/irq-generic.h            | 16 ++++++++++------
>  bsps/lm32/shared/irq/irq.c                |  3 ++-
>  bsps/m68k/genmcf548x/irq/irq.c            |  4 +++-
>  bsps/mips/shared/irq/irq.c                |  3 ++-
>  bsps/powerpc/gen5200/irq/irq.c            |  4 +++-
>  bsps/powerpc/gen83xx/irq/irq.c            |  4 +++-
>  bsps/powerpc/mpc55xxevb/start/irq.c       |  3 ++-
>  bsps/powerpc/mpc8260ads/irq/irq.c         |  4 +++-
>  bsps/powerpc/psim/irq/irq_init.c          |  3 ++-
>  bsps/powerpc/qemuppc/irq/irq_init.c       |  3 ++-
>  bsps/powerpc/qoriq/irq/irq.c              |  5 +++--
>  bsps/powerpc/shared/irq/ppc-irq-generic.c |  3 ++-
>  bsps/powerpc/t32mppc/irq/irq.c            |  3 ++-
>  bsps/powerpc/tqm8xx/irq/irq.c             |  4 +++-
>  bsps/powerpc/virtex/irq/irq_init.c        |  4 +++-
>  bsps/riscv/griscv/irq/irq.c               |  3 ++-
>  bsps/riscv/riscv/irq/irq.c                |  4 +++-
>  bsps/shared/dev/irq/arm-gicv2.c           |  3 ++-
>  bsps/shared/dev/irq/arm-gicv3.c           |  4 +++-
>  bsps/shared/irq/irq-default.c             |  3 ++-
>  bsps/shared/irq/irq-enable-disable.c      |  4 +---
>  bsps/sparc/leon3/start/eirq.c             |  3 ++-
>  bsps/sparc/shared/irq/irq-shared.c        |  3 ++-
>  bsps/x86_64/amd64/interrupts/idt.c        |  3 ++-
>  37 files changed, 93 insertions(+), 45 deletions(-)
> diff --git a/bsps/arm/beagle/irq/irq.c b/bsps/arm/beagle/irq/irq.c
> index e34a89afff..7953a2fe1f 100644
> --- a/bsps/arm/beagle/irq/irq.c
> +++ b/bsps/arm/beagle/irq/irq.c
> @@ -137,7 +137,7 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
>    return RTEMS_UNSATISFIED;
> -void bsp_interrupt_vector_enable(rtems_vector_number vector)
> +rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
>    uint32_t mask, cur;
>    uint32_t mir_reg = omap_get_mir_reg(vector, &mask);
> @@ -147,6 +147,7 @@ void bsp_interrupt_vector_enable(rtems_vector_number vector)
>    cur = mmio_read(omap_intr.base + mir_reg);
>    mmio_write(omap_intr.base + mir_reg, cur & ~mask);
>    flush_data_cache();
> +  return RTEMS_SUCCESSFUL;
>  void bsp_interrupt_vector_disable(rtems_vector_number vector)
> diff --git a/bsps/arm/csb336/irq/irq.c b/bsps/arm/csb336/irq/irq.c
> index 13f094e1fb..d47f0362e8 100644
> --- a/bsps/arm/csb336/irq/irq.c
> +++ b/bsps/arm/csb336/irq/irq.c
> @@ -68,12 +68,14 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
>    bsp_interrupt_assert(bsp_interrupt_is_valid_vector(vector));
>    if (vector < MC9328MXL_NUM_INTS)
>      MC9328MXL_AITC_INTENNUM = vector;
> diff --git a/bsps/arm/csb337/irq/irq.c b/bsps/arm/csb337/irq/irq.c
> index 1b13f0b461..a4bfb1f83b 100644
> --- a/bsps/arm/csb337/irq/irq.c
> +++ b/bsps/arm/csb337/irq/irq.c
> @@ -69,10 +69,11 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
>    AIC_CTL_REG(AIC_IECR) = 1 << vector;
> diff --git a/bsps/arm/edb7312/irq/irq.c b/bsps/arm/edb7312/irq/irq.c
> index 75dffdec9f..3cff5bfff2 100644
> --- a/bsps/arm/edb7312/irq/irq.c
> +++ b/bsps/arm/edb7312/irq/irq.c
> @@ -69,7 +69,7 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
> @@ -93,6 +93,8 @@ void bsp_interrupt_vector_enable(rtems_vector_number vector)
>          /* interrupt managed by INTMR3 and INTSR3 */
>          *EP7312_INTMR3 |= (1 << (vector - 21));
> diff --git a/bsps/arm/gumstix/irq/irq.c b/bsps/arm/gumstix/irq/irq.c
> index d28e4c051f..bba91f1d08 100644
> --- a/bsps/arm/gumstix/irq/irq.c
> +++ b/bsps/arm/gumstix/irq/irq.c
> @@ -66,10 +66,11 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
>    XSCALE_INT_ICMR |= 1 << vector;
> diff --git a/bsps/arm/lpc24xx/irq/irq.c b/bsps/arm/lpc24xx/irq/irq.c
> index 0514099c6f..2b266a0822 100644
> --- a/bsps/arm/lpc24xx/irq/irq.c
> +++ b/bsps/arm/lpc24xx/irq/irq.c
> @@ -106,10 +106,11 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
>    VICIntEnable = 1U << vector;
> diff --git a/bsps/arm/lpc32xx/irq/irq.c b/bsps/arm/lpc32xx/irq/irq.c
> index b81920f7e9..5e8c93909f 100644
> --- a/bsps/arm/lpc32xx/irq/irq.c
> +++ b/bsps/arm/lpc32xx/irq/irq.c
> @@ -302,7 +302,7 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
>    rtems_interrupt_level level;
> @@ -312,6 +312,8 @@ void bsp_interrupt_vector_enable(rtems_vector_number vector)
>    lpc32xx_irq_set_bit_in_register(vector, LPC32XX_IRQ_OFFSET_ER);
>    lpc32xx_irq_set_bit_in_field(vector, &lpc32xx_irq_enable);
>    rtems_interrupt_enable(level);
> diff --git a/bsps/arm/raspberrypi/irq/irq.c b/bsps/arm/raspberrypi/irq/irq.c
> index 0d82e12640..763ad30692 100644
> --- a/bsps/arm/raspberrypi/irq/irq.c
> +++ b/bsps/arm/raspberrypi/irq/irq.c
> @@ -196,11 +196,12 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
>    BCM2835_REG(bsp_vector_to_reg(vector)->enable_reg_addr) =
>                bsp_vector_to_mask(vector);
> diff --git a/bsps/arm/rtl22xx/irq/irq.c b/bsps/arm/rtl22xx/irq/irq.c
> index 56b1b4c4f1..9fc8f1b3e8 100644
> --- a/bsps/arm/rtl22xx/irq/irq.c
> +++ b/bsps/arm/rtl22xx/irq/irq.c
> @@ -68,10 +68,11 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
>    VICIntEnable |= 1 << vector;
> diff --git a/bsps/arm/shared/irq/irq-armv7m.c b/bsps/arm/shared/irq/irq-armv7m.c
> index 2ce08a9fc8..a242071be5 100644
> --- a/bsps/arm/shared/irq/irq-armv7m.c
> +++ b/bsps/arm/shared/irq/irq-armv7m.c
> @@ -80,10 +80,11 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
>    _ARMV7M_NVIC_Set_enable((int) vector);
> diff --git a/bsps/arm/smdk2410/irq/irq.c b/bsps/arm/smdk2410/irq/irq.c
> index 47f951cb19..95be366525 100644
> --- a/bsps/arm/smdk2410/irq/irq.c
> +++ b/bsps/arm/smdk2410/irq/irq.c
> @@ -69,9 +69,10 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
> diff --git a/bsps/arm/tms570/irq/irq.c b/bsps/arm/tms570/irq/irq.c
> index a7e1465822..ef38ac32db 100644
> --- a/bsps/arm/tms570/irq/irq.c
> +++ b/bsps/arm/tms570/irq/irq.c
> @@ -138,12 +138,13 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
>    TMS570_VIM.REQENASET[vector >> 5] = 1 << (vector & 0x1f);
> diff --git a/bsps/i386/shared/irq/irq.c b/bsps/i386/shared/irq/irq.c
> index bb7debf89a..ad278e6224 100644
> --- a/bsps/i386/shared/irq/irq.c
> +++ b/bsps/i386/shared/irq/irq.c
> @@ -312,10 +312,11 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
>    BSP_irq_enable_at_i8259a(vector);
> diff --git a/bsps/include/bsp/irq-generic.h b/bsps/include/bsp/irq-generic.h
> index bb3c98bdd3..54b8501f96 100644
> --- a/bsps/include/bsp/irq-generic.h
> +++ b/bsps/include/bsp/irq-generic.h
> @@ -258,20 +258,24 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
> - * @brief Enables the interrupt vector with number @a vector.
> + * @brief Enables the interrupt vector.
>   * This function shall enable the vector at the corresponding facility (in most
>   * cases the interrupt controller).  It will be called then the first handler
>   * is installed for the vector in bsp_interrupt_handler_install() for example.
>   * @note The implementation should use
> - * bsp_interrupt_assert(bsp_interrupt_is_valid_vector(vector)) to valdiate the
> - * vector number.
> + * bsp_interrupt_assert( bsp_interrupt_is_valid_vector( vector ) ) to valdiate
validate
This typo already existed
> + * the vector number in ::RTEMS_DEBUG configurations.
> - * @note You must not install or remove an interrupt handler in this function.
> - * This may result in a deadlock.
> + * @param vector is the interrupt vector number.
> + * @retval ::RTEMS_SUCCESSFUL The requested operation was successful.
> + * @retval ::RTEMS_UNSATISFIED The request to enable the interrupt vector has
> + *   not been satisfied.
> -void bsp_interrupt_vector_enable(rtems_vector_number vector);
> +rtems_status_code bsp_interrupt_vector_enable( rtems_vector_number vector );
>   * @brief Disables the interrupt vector with number @a vector.
> diff --git a/bsps/lm32/shared/irq/irq.c b/bsps/lm32/shared/irq/irq.c
> index c539220912..6ba09e9e27 100644
> --- a/bsps/lm32/shared/irq/irq.c
> +++ b/bsps/lm32/shared/irq/irq.c
> @@ -59,10 +59,11 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
>    lm32_interrupt_unmask(1 << vector);
> diff --git a/bsps/m68k/genmcf548x/irq/irq.c b/bsps/m68k/genmcf548x/irq/irq.c
> index 7261da0344..372208e6ca 100644
> --- a/bsps/m68k/genmcf548x/irq/irq.c
> +++ b/bsps/m68k/genmcf548x/irq/irq.c
> @@ -101,7 +101,7 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
>    volatile uint32_t *imr = vector_to_imr(vector);
>    uint32_t bit = vector_to_bit(vector);
> @@ -112,6 +112,8 @@ void bsp_interrupt_vector_enable(rtems_vector_number vector)
>    rtems_interrupt_disable(level);
>    *imr &= ~bit;
> diff --git a/bsps/mips/shared/irq/irq.c b/bsps/mips/shared/irq/irq.c
> index 5b0aa60af1..3e144d876b 100644
> --- a/bsps/mips/shared/irq/irq.c
> +++ b/bsps/mips/shared/irq/irq.c
> @@ -109,9 +109,10 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
> diff --git a/bsps/powerpc/gen5200/irq/irq.c b/bsps/powerpc/gen5200/irq/irq.c
> index 48b6ea7e29..e79067da6d 100644
> --- a/bsps/powerpc/gen5200/irq/irq.c
> +++ b/bsps/powerpc/gen5200/irq/irq.c
> @@ -401,7 +401,7 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
> -void bsp_interrupt_vector_enable( rtems_vector_number vector)
> +rtems_status_code bsp_interrupt_vector_enable( rtems_vector_number vector)
>    int base_index = get_siu_irq_base_index( vector);
> @@ -429,6 +429,8 @@ void bsp_interrupt_vector_enable( rtems_vector_number vector)
>      rtems_interrupt_enable( level);
> diff --git a/bsps/powerpc/gen83xx/irq/irq.c b/bsps/powerpc/gen83xx/irq/irq.c
> index e3d5f42d8d..ec035e14c3 100644
> --- a/bsps/powerpc/gen83xx/irq/irq.c
> +++ b/bsps/powerpc/gen83xx/irq/irq.c
> @@ -418,7 +418,7 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
>    rtems_vector_number vecnum = vector - BSP_IPIC_IRQ_LOWEST_OFFSET;
>    const BSP_isrc_rsc_t *rsc_ptr;
> @@ -436,6 +436,8 @@ void bsp_interrupt_vector_enable( rtems_vector_number vector)
>  void bsp_interrupt_vector_disable( rtems_vector_number vector)
> diff --git a/bsps/powerpc/mpc55xxevb/start/irq.c b/bsps/powerpc/mpc55xxevb/start/irq.c
> index 2a37787166..f0a04c0398 100644
> --- a/bsps/powerpc/mpc55xxevb/start/irq.c
> +++ b/bsps/powerpc/mpc55xxevb/start/irq.c
> @@ -194,10 +194,11 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
>         mpc55xx_intc_set_priority( vector, MPC55XX_INTC_DEFAULT_PRIORITY);
> diff --git a/bsps/powerpc/mpc8260ads/irq/irq.c b/bsps/powerpc/mpc8260ads/irq/irq.c
> index 6bad2a9514..6fdf83e3b6 100644
> --- a/bsps/powerpc/mpc8260ads/irq/irq.c
> +++ b/bsps/powerpc/mpc8260ads/irq/irq.c
> @@ -370,7 +370,7 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
> -void bsp_interrupt_vector_enable( rtems_vector_number irqnum)
> +rtems_status_code bsp_interrupt_vector_enable( rtems_vector_number irqnum)
>    bsp_interrupt_assert(bsp_interrupt_is_valid_vector(irqnum));
> @@ -380,6 +380,8 @@ void bsp_interrupt_vector_enable( rtems_vector_number irqnum)
>      BSP_irq_enable_at_cpm (irqnum);
>  void bsp_interrupt_vector_disable( rtems_vector_number irqnum)
> diff --git a/bsps/powerpc/psim/irq/irq_init.c b/bsps/powerpc/psim/irq/irq_init.c
> index bfd373a502..48783a6056 100644
> --- a/bsps/powerpc/psim/irq/irq_init.c
> +++ b/bsps/powerpc/psim/irq/irq_init.c
> @@ -144,10 +144,11 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
>    /* FIXME: do something */
> diff --git a/bsps/powerpc/qemuppc/irq/irq_init.c b/bsps/powerpc/qemuppc/irq/irq_init.c
> index e9af3d747f..419fc66ce1 100644
> --- a/bsps/powerpc/qemuppc/irq/irq_init.c
> +++ b/bsps/powerpc/qemuppc/irq/irq_init.c
>   * functions to enable/disable a source at the ipic
> diff --git a/bsps/powerpc/qoriq/irq/irq.c b/bsps/powerpc/qoriq/irq/irq.c
> index e6a9f09ea1..98d4ef1a42 100644
> --- a/bsps/powerpc/qoriq/irq/irq.c
> +++ b/bsps/powerpc/qoriq/irq/irq.c
> @@ -130,10 +130,11 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
>         ev_int_set_mask(vector, 0);
> @@ -396,7 +397,7 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
>         pic_vector_enable(vector, 0);
> diff --git a/bsps/powerpc/shared/irq/ppc-irq-generic.c b/bsps/powerpc/shared/irq/ppc-irq-generic.c
> index 4e746ba78e..14c1f7c8c7 100644
> --- a/bsps/powerpc/shared/irq/ppc-irq-generic.c
> +++ b/bsps/powerpc/shared/irq/ppc-irq-generic.c
> @@ -137,10 +137,11 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
>    BSP_enable_irq_at_pic(vector);
> diff --git a/bsps/powerpc/t32mppc/irq/irq.c b/bsps/powerpc/t32mppc/irq/irq.c
> index 56cb2dbb7f..0c0bb8f1e8 100644
> --- a/bsps/powerpc/t32mppc/irq/irq.c
> +++ b/bsps/powerpc/t32mppc/irq/irq.c
> @@ -58,9 +58,10 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
>  void bsp_interrupt_dispatch(uintptr_t exception_number)
> diff --git a/bsps/powerpc/tqm8xx/irq/irq.c b/bsps/powerpc/tqm8xx/irq/irq.c
> index 103af361b7..4903ef7696 100644
> --- a/bsps/powerpc/tqm8xx/irq/irq.c
> +++ b/bsps/powerpc/tqm8xx/irq/irq.c
> @@ -105,7 +105,7 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
> @@ -114,6 +114,8 @@ void bsp_interrupt_vector_enable(rtems_vector_number vector)
>    } else if (BSP_IS_SIU_IRQ(vector)) {
>      bsp_irq_enable_at_SIU(vector);
> diff --git a/bsps/powerpc/virtex/irq/irq_init.c b/bsps/powerpc/virtex/irq/irq_init.c
> index 6436ee3feb..9a9f4eacb4 100644
> --- a/bsps/powerpc/virtex/irq/irq_init.c
> +++ b/bsps/powerpc/virtex/irq/irq_init.c
> @@ -174,13 +174,15 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
>    if (BSP_IS_OPBINTC_IRQ(vector)) {
>      BSP_irq_enable_at_opbintc(vector);
> diff --git a/bsps/riscv/griscv/irq/irq.c b/bsps/riscv/griscv/irq/irq.c
> index 58ac1e9ba5..1b58f86fc4 100644
> --- a/bsps/riscv/griscv/irq/irq.c
> +++ b/bsps/riscv/griscv/irq/irq.c
> @@ -140,11 +140,12 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
>    int irq = (int)vector;
>    GRLIB_Cpu_Unmask_interrupt(irq, bsp_irq_cpu(irq));
> diff --git a/bsps/riscv/riscv/irq/irq.c b/bsps/riscv/riscv/irq/irq.c
> index d53124864a..e651c828d5 100644
> --- a/bsps/riscv/riscv/irq/irq.c
> +++ b/bsps/riscv/riscv/irq/irq.c
> @@ -279,7 +279,7 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
> @@ -319,6 +319,8 @@ void bsp_interrupt_vector_enable(rtems_vector_number vector)
>      rtems_interrupt_lock_release(&riscv_plic_lock, &lock_context);
> diff --git a/bsps/shared/dev/irq/arm-gicv2.c b/bsps/shared/dev/irq/arm-gicv2.c
> index deaae253a2..85cb543945 100644
> --- a/bsps/shared/dev/irq/arm-gicv2.c
> +++ b/bsps/shared/dev/irq/arm-gicv2.c
> @@ -117,13 +117,14 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
>    volatile gic_dist *dist = ARM_GIC_DIST;
>    gic_id_enable(dist, vector);
> diff --git a/bsps/shared/dev/irq/arm-gicv3.c b/bsps/shared/dev/irq/arm-gicv3.c
> index f4ac4b212e..89cac60901 100644
> --- a/bsps/shared/dev/irq/arm-gicv3.c
> +++ b/bsps/shared/dev/irq/arm-gicv3.c
> @@ -217,7 +217,7 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
> @@ -239,6 +239,8 @@ void bsp_interrupt_vector_enable(rtems_vector_number vector)
>      /* Set enable */
>      sgi_ppi->icspiser[0] = 1 << (vector % 32);
> diff --git a/bsps/shared/irq/irq-default.c b/bsps/shared/irq/irq-default.c
> index de8e7c3b6b..a8f6de21d9 100644
> --- a/bsps/shared/irq/irq-default.c
> +++ b/bsps/shared/irq/irq-default.c
> @@ -79,10 +79,11 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
>    (void)vector;
> +  return RTEMS_UNSATISFIED;
> diff --git a/bsps/shared/irq/irq-enable-disable.c b/bsps/shared/irq/irq-enable-disable.c
> index 84c576084b..6f2793c3e1 100644
> --- a/bsps/shared/irq/irq-enable-disable.c
> +++ b/bsps/shared/irq/irq-enable-disable.c
> @@ -88,9 +88,7 @@ rtems_status_code rtems_interrupt_vector_enable( rtems_vector_number vector )
>      return RTEMS_INVALID_ID;
> -  bsp_interrupt_vector_enable( vector );
> -  return RTEMS_SUCCESSFUL;
> +  return bsp_interrupt_vector_enable( vector );
>  rtems_status_code rtems_interrupt_vector_disable( rtems_vector_number vector )
> diff --git a/bsps/sparc/leon3/start/eirq.c b/bsps/sparc/leon3/start/eirq.c
> index d9bf9d4073..a9abaa3304 100644
> --- a/bsps/sparc/leon3/start/eirq.c
> +++ b/bsps/sparc/leon3/start/eirq.c
> @@ -151,7 +151,7 @@ static void leon3_interrupt_vector_enable(rtems_vector_number vector)
>  #endif
>  #if defined(RTEMS_SMP)
>    rtems_interrupt_lock_context lock_context;
> @@ -164,6 +164,7 @@ void bsp_interrupt_vector_enable(rtems_vector_number vector)
>    BSP_Cpu_Unmask_interrupt(vector, _LEON3_Get_current_processor());
>  #endif
> diff --git a/bsps/sparc/shared/irq/irq-shared.c b/bsps/sparc/shared/irq/irq-shared.c
> index 669a7be345..9315d6dadf 100644
> --- a/bsps/sparc/shared/irq/irq-shared.c
> +++ b/bsps/sparc/shared/irq/irq-shared.c
> @@ -85,10 +85,11 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
>    BSP_Cpu_Unmask_interrupt(vector, 0);
> diff --git a/bsps/x86_64/amd64/interrupts/idt.c b/bsps/x86_64/amd64/interrupts/idt.c
> index 15081e9292..39c941b3e1 100644
> --- a/bsps/x86_64/amd64/interrupts/idt.c
> +++ b/bsps/x86_64/amd64/interrupts/idt.c
> @@ -188,7 +188,8 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
>    /* XXX */
> 2.26.2
> devel mailing list
> devel at rtems.org
