[PATCH 41/41] validation: Test rtems_interrupt_set_affinity()
Gedare Bloom
gedare at rtems.org
Wed Jul 21 18:54:58 UTC 2021
I did not check the validation patches, everything else looks good to me.
On Mon, Jul 12, 2021 at 6:51 AM Sebastian Huber
> Update #3269.
> .../testsuites/validation/validation-0.yml | 1 +
> testsuites/validation/tc-intr-set-affinity.c | 670 ++++++++++++++++++
> 2 files changed, 671 insertions(+)
> create mode 100644 testsuites/validation/tc-intr-set-affinity.c
> diff --git a/spec/build/testsuites/validation/validation-0.yml b/spec/build/testsuites/validation/validation-0.yml
> index 89c0f408d6..6778a5ec25 100644
> --- a/spec/build/testsuites/validation/validation-0.yml
> +++ b/spec/build/testsuites/validation/validation-0.yml
> @@ -23,6 +23,7 @@ source:
> - testsuites/validation/tc-intr-get-affinity.c
> - testsuites/validation/tc-intr-get-attributes.c
> - testsuites/validation/tc-intr-is-pending.c
> +- testsuites/validation/tc-intr-set-affinity.c
> - testsuites/validation/tc-intr-vector-disable.c
> - testsuites/validation/tc-intr-vector-enable.c
> - testsuites/validation/tc-intr-vector-is-enabled.c
> diff --git a/testsuites/validation/tc-intr-set-affinity.c b/testsuites/validation/tc-intr-set-affinity.c
> new file mode 100644
> index 0000000000..b2b47baea8
> --- /dev/null
> +++ b/testsuites/validation/tc-intr-set-affinity.c
> @@ -0,0 +1,670 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * @file
> + * @ingroup RTEMSTestCaseRtemsIntrReqSetAffinity
> + * Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + * notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + * notice, this list of conditions and the following disclaimer in the
> + * documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> + * This file is part of the RTEMS quality process and was automatically
> + * generated. If you find something that needs to be fixed or
> + * worded better please post a report or patch to an RTEMS mailing list
> + * or raise a bug report:
> + * https://www.rtems.org/bugs.html
> + * For information on updating and regenerating please refer to the How-To
> + * section in the Software Requirements Engineering chapter of the
> + * RTEMS Software Engineering manual. The manual is provided as a part of
> + * a release. For development sources please refer to the online
> + * documentation at:
> + * https://docs.rtems.org
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <bsp/irq-generic.h>
> +#include <rtems/irq-extension.h>
> +#include "tx-support.h"
> +#include <rtems/test.h>
> + * @defgroup RTEMSTestCaseRtemsIntrReqSetAffinity \
> + * spec:/rtems/intr/req/set-affinity
> + * @ingroup RTEMSTestSuiteTestsuitesValidation0
> +typedef enum {
> + RtemsIntrReqSetAffinity_Pre_Vector_Valid,
> + RtemsIntrReqSetAffinity_Pre_Vector_Invalid,
> + RtemsIntrReqSetAffinity_Pre_Vector_NA
> +} RtemsIntrReqSetAffinity_Pre_Vector;
> +typedef enum {
> + RtemsIntrReqSetAffinity_Pre_CPUSetKind_Valid,
> + RtemsIntrReqSetAffinity_Pre_CPUSetKind_Huge,
> + RtemsIntrReqSetAffinity_Pre_CPUSetKind_Askew,
> + RtemsIntrReqSetAffinity_Pre_CPUSetKind_NA
> +} RtemsIntrReqSetAffinity_Pre_CPUSetKind;
> +typedef enum {
> + RtemsIntrReqSetAffinity_Pre_CPUSet_Valid,
> + RtemsIntrReqSetAffinity_Pre_CPUSet_Null,
> + RtemsIntrReqSetAffinity_Pre_CPUSet_NA
> +} RtemsIntrReqSetAffinity_Pre_CPUSet;
> +typedef enum {
> + RtemsIntrReqSetAffinity_Pre_CanSetAffinity_Yes,
> + RtemsIntrReqSetAffinity_Pre_CanSetAffinity_No,
> + RtemsIntrReqSetAffinity_Pre_CanSetAffinity_NA
> +} RtemsIntrReqSetAffinity_Pre_CanSetAffinity;
> +typedef enum {
> + RtemsIntrReqSetAffinity_Post_Status_Ok,
> + RtemsIntrReqSetAffinity_Post_Status_InvAddr,
> + RtemsIntrReqSetAffinity_Post_Status_InvId,
> + RtemsIntrReqSetAffinity_Post_Status_InvNum,
> + RtemsIntrReqSetAffinity_Post_Status_Unsat,
> + RtemsIntrReqSetAffinity_Post_Status_NA
> +} RtemsIntrReqSetAffinity_Post_Status;
> +typedef enum {
> + RtemsIntrReqSetAffinity_Post_SetAffinity_Yes,
> + RtemsIntrReqSetAffinity_Post_SetAffinity_Nop,
> + RtemsIntrReqSetAffinity_Post_SetAffinity_NA
> +} RtemsIntrReqSetAffinity_Post_SetAffinity;
> + * @brief Test context for spec:/rtems/intr/req/set-affinity test case.
> +typedef struct {
> + * @brief This member contains the current vector number.
> + rtems_vector_number vector;
> + * @brief This member contains some valid vector number.
> + rtems_vector_number some_vector;
> + * @brief This member provides the object referenced by the ``affinity``
> + * parameter.
> + cpu_set_t cpuset_obj[ 2 ];
> + * @brief This member contains the return value of the
> + * rtems_interrupt_set_affinity() call.
> + rtems_status_code status;
> + * @brief If this member is true, then the ``vector`` parameter shall be
> + * valid.
> + bool valid_vector;
> + * @brief This member specifies if the ``affinity_size`` parameter value.
> + size_t cpusetsize;
> + * @brief This member specifies if the ``affinity`` parameter value.
> + cpu_set_t *cpuset;
> + * @brief This member defines the pre-condition states for the next action.
> + size_t pcs[ 4 ];
> + * @brief This member indicates if the test action loop is currently
> + * executed.
> + bool in_action_loop;
> +} RtemsIntrReqSetAffinity_Context;
> +static RtemsIntrReqSetAffinity_Context
> + RtemsIntrReqSetAffinity_Instance;
> +static const char * const RtemsIntrReqSetAffinity_PreDesc_Vector[] = {
> + "Valid",
> + "Invalid",
> + "NA"
> +static const char * const RtemsIntrReqSetAffinity_PreDesc_CPUSetKind[] = {
> + "Valid",
> + "Huge",
> + "Askew",
> + "NA"
> +static const char * const RtemsIntrReqSetAffinity_PreDesc_CPUSet[] = {
> + "Valid",
> + "Null",
> + "NA"
> +static const char * const RtemsIntrReqSetAffinity_PreDesc_CanSetAffinity[] = {
> + "Yes",
> + "No",
> + "NA"
> +static const char * const * const RtemsIntrReqSetAffinity_PreDesc[] = {
> + RtemsIntrReqSetAffinity_PreDesc_Vector,
> + RtemsIntrReqSetAffinity_PreDesc_CPUSetKind,
> + RtemsIntrReqSetAffinity_PreDesc_CPUSet,
> + RtemsIntrReqSetAffinity_PreDesc_CanSetAffinity,
> + NULL
> +typedef RtemsIntrReqSetAffinity_Context Context;
> +static void CheckSetAffinity(
> + Context *ctx,
> + const rtems_interrupt_attributes *attr
> + rtems_status_code sc;
> + cpu_set_t set;
> + cpu_set_t set2;
> + CPU_ZERO( &set );
> + if ( attr->can_get_affinity ) {
> + sc = rtems_interrupt_get_affinity( ctx->vector, sizeof( set ), &set );
> + T_rsc_success( sc );
> + } else {
> + CPU_SET( 0, &set );
> + CPU_COPY( &set, &ctx->cpuset_obj[ 0 ] );
> + sc = rtems_interrupt_set_affinity(
> + ctx->vector,
> + ctx->cpusetsize,
> + ctx->cpuset
> + if ( attr->can_set_affinity ) {
> + } else {
> + T_rsc( sc, RTEMS_UNSATISFIED );
> + CPU_FILL( &set2 );
> + sc = rtems_interrupt_get_affinity( ctx->vector, sizeof( set2 ), &set2 );
> + T_eq_int( CPU_CMP( &set, &set2 ), 0 );
> +static void RtemsIntrReqSetAffinity_Pre_Vector_Prepare(
> + RtemsIntrReqSetAffinity_Context *ctx,
> + RtemsIntrReqSetAffinity_Pre_Vector state
> + switch ( state ) {
> + case RtemsIntrReqSetAffinity_Pre_Vector_Valid: {
> + * While the ``vector`` parameter is associated with an interrupt vector.
> + ctx->valid_vector = true;
> + break;
> + case RtemsIntrReqSetAffinity_Pre_Vector_Invalid: {
> + * While the ``vector`` parameter is not associated with an interrupt
> + * vector.
> + ctx->valid_vector = false;
> + break;
> + case RtemsIntrReqSetAffinity_Pre_Vector_NA:
> + break;
> +static void RtemsIntrReqSetAffinity_Pre_CPUSetKind_Prepare(
> + RtemsIntrReqSetAffinity_Pre_CPUSetKind state
> + case RtemsIntrReqSetAffinity_Pre_CPUSetKind_Valid: {
> + * While the ``affinity_size`` parameter is an integral multiple of the
> + * size of long, while the ``affinity_size`` and ``affinity`` parameter
> + * specify a processor set which is within the implementation limits.
> + ctx->cpusetsize = sizeof( ctx->cpuset_obj[ 0 ] );
> + break;
> + case RtemsIntrReqSetAffinity_Pre_CPUSetKind_Huge: {
> + * specify a processor set which exceeds the implementation limits.
> + ctx->cpusetsize = sizeof( ctx->cpuset_obj );
> + CPU_ZERO( &ctx->cpuset_obj[ 0 ] );
> + break;
> + case RtemsIntrReqSetAffinity_Pre_CPUSetKind_Askew: {
> + * While the ``affinity_size`` parameter is not an integral multiple of
> + * the size of long.
> + ctx->cpusetsize = SIZE_MAX;
> + break;
> + case RtemsIntrReqSetAffinity_Pre_CPUSetKind_NA:
> + break;
> +static void RtemsIntrReqSetAffinity_Pre_CPUSet_Prepare(
> + RtemsIntrReqSetAffinity_Pre_CPUSet state
> + case RtemsIntrReqSetAffinity_Pre_CPUSet_Valid: {
> + * While the ``affinity`` parameter references an object of type
> + * cpu_set_t.
> + ctx->cpuset = &ctx->cpuset_obj[ 0 ];
> + break;
> + case RtemsIntrReqSetAffinity_Pre_CPUSet_Null: {
> + * While the ``affinity`` parameter is equal to NULL.
> + ctx->cpuset = NULL;
> + break;
> + case RtemsIntrReqSetAffinity_Pre_CPUSet_NA:
> + break;
> +static void RtemsIntrReqSetAffinity_Pre_CanSetAffinity_Prepare(
> + RtemsIntrReqSetAffinity_Pre_CanSetAffinity state
> + case RtemsIntrReqSetAffinity_Pre_CanSetAffinity_Yes: {
> + * While setting the affinity for the interrupt vector specified by
> + * ``vector`` parameter is supported.
> + /* Validation done by CheckSetAffinity() for each interrupt vector */
> + break;
> + case RtemsIntrReqSetAffinity_Pre_CanSetAffinity_No: {
> + * ``vector`` parameter is not supported.
> + break;
> + case RtemsIntrReqSetAffinity_Pre_CanSetAffinity_NA:
> + break;
> +static void RtemsIntrReqSetAffinity_Post_Status_Check(
> + RtemsIntrReqSetAffinity_Post_Status state
> + case RtemsIntrReqSetAffinity_Post_Status_Ok: {
> + * The return status of rtems_interrupt_set_affinity() shall be
> + * RTEMS_SUCCESSFUL.
> + break;
> + case RtemsIntrReqSetAffinity_Post_Status_InvAddr: {
> + * RTEMS_INVALID_ADDRESS.
> + T_rsc( ctx->status, RTEMS_INVALID_ADDRESS );
> + break;
> + case RtemsIntrReqSetAffinity_Post_Status_InvId: {
> + * RTEMS_INVALID_ID.
> + T_rsc( ctx->status, RTEMS_INVALID_ID );
> + break;
> + case RtemsIntrReqSetAffinity_Post_Status_InvNum: {
> + * RTEMS_INVALID_NUMBER.
> + T_rsc( ctx->status, RTEMS_INVALID_NUMBER );
> + break;
> + case RtemsIntrReqSetAffinity_Post_Status_Unsat: {
> + * RTEMS_UNSATISFIED.
> + break;
> + case RtemsIntrReqSetAffinity_Post_Status_NA:
> + break;
> +static void RtemsIntrReqSetAffinity_Post_SetAffinity_Check(
> + RtemsIntrReqSetAffinity_Post_SetAffinity state
> + case RtemsIntrReqSetAffinity_Post_SetAffinity_Yes: {
> + * The affinity set of the interrupt specified by ``vector`` shall be set
> + * to the processor set specified by ``affinity_size`` and ``affinity``
> + * at some point during the rtems_interrupt_set_affinity() call.
> + break;
> + case RtemsIntrReqSetAffinity_Post_SetAffinity_Nop: {
> + * The affinity set of the interrupt specified by ``vector`` shall not be
> + * modified by the rtems_interrupt_set_affinity() call.
> + * Validation done by CheckSetAffinity() for each interrupt vector and in
> + * the action code.
> + break;
> + case RtemsIntrReqSetAffinity_Post_SetAffinity_NA:
> + break;
> +static void RtemsIntrReqSetAffinity_Setup(
> + ctx->some_vector = GetValidInterruptVectorNumber( NULL );
> +static void RtemsIntrReqSetAffinity_Setup_Wrap( void *arg )
> + RtemsIntrReqSetAffinity_Context *ctx;
> + ctx = arg;
> + ctx->in_action_loop = false;
> + RtemsIntrReqSetAffinity_Setup( ctx );
> +static void RtemsIntrReqSetAffinity_Prepare(
> + CPU_FILL_S( sizeof( ctx->cpuset_obj ), &ctx->cpuset_obj[ 0 ] );
> +static void RtemsIntrReqSetAffinity_Action(
> + if (
> + ctx->valid_vector && ctx->cpusetsize == sizeof( ctx->cpuset_obj[ 0 ] ) &&
> + ctx->cpuset == &ctx->cpuset_obj[ 0 ]
> + for (
> + ctx->vector = 0;
> + ctx->vector < BSP_INTERRUPT_VECTOR_COUNT;
> + ++ctx->vector
> + rtems_interrupt_attributes attr;
> + memset( &attr, 0, sizeof( attr ) );
> + sc = rtems_interrupt_get_attributes( ctx->vector, &attr );
> + if ( sc == RTEMS_INVALID_ID ) {
> + continue;
> + CheckSetAffinity( ctx, &attr );
> + } else {
> + cpu_set_t set;
> + cpu_set_t set2;
> + CPU_ZERO( &set );
> + CPU_ZERO( &set2 );
> + if ( ctx->valid_vector ) {
> + ctx->vector = ctx->some_vector;
> + T_true( sc == RTEMS_SUCCESSFUL || sc == RTEMS_UNSATISFIED );
> + } else {
> + ctx->vector = BSP_INTERRUPT_VECTOR_COUNT;
> + ctx->status = rtems_interrupt_set_affinity(
> + ctx->vector,
> + ctx->cpusetsize,
> + ctx->cpuset
> +typedef struct {
> + uint16_t Skip : 1;
> + uint16_t Pre_Vector_NA : 1;
> + uint16_t Pre_CPUSetKind_NA : 1;
> + uint16_t Pre_CPUSet_NA : 1;
> + uint16_t Pre_CanSetAffinity_NA : 1;
> + uint16_t Post_Status : 3;
> + uint16_t Post_SetAffinity : 2;
> +} RtemsIntrReqSetAffinity_Entry;
> +static const RtemsIntrReqSetAffinity_Entry
> +RtemsIntrReqSetAffinity_Entries[] = {
> + { 0, 0, 0, 0, 0, RtemsIntrReqSetAffinity_Post_Status_InvAddr,
> + RtemsIntrReqSetAffinity_Post_SetAffinity_Nop },
> + { 0, 0, 0, 0, 1, RtemsIntrReqSetAffinity_Post_Status_InvId,
> + RtemsIntrReqSetAffinity_Post_SetAffinity_NA },
> + { 0, 0, 0, 0, 1, RtemsIntrReqSetAffinity_Post_Status_InvAddr,
> + { 0, 0, 0, 0, 0, RtemsIntrReqSetAffinity_Post_Status_InvNum,
> + { 0, 0, 0, 0, 0, RtemsIntrReqSetAffinity_Post_Status_Ok,
> + RtemsIntrReqSetAffinity_Post_SetAffinity_Yes },
> + { 0, 0, 0, 0, 0, RtemsIntrReqSetAffinity_Post_Status_Unsat,
> +static const uint8_t
> +RtemsIntrReqSetAffinity_Map[] = {
> + 4, 5, 0, 0, 3, 3, 0, 0, 3, 3, 0, 0, 1, 1, 2, 2, 1, 1, 2, 2, 1, 1, 2, 2
> +static size_t RtemsIntrReqSetAffinity_Scope( void *arg, char *buf, size_t n )
> + ctx = arg;
> + if ( ctx->in_action_loop ) {
> + return T_get_scope( RtemsIntrReqSetAffinity_PreDesc, buf, n, ctx->pcs );
> + return 0;
> +static T_fixture RtemsIntrReqSetAffinity_Fixture = {
> + .setup = RtemsIntrReqSetAffinity_Setup_Wrap,
> + .stop = NULL,
> + .teardown = NULL,
> + .scope = RtemsIntrReqSetAffinity_Scope,
> + .initial_context = &RtemsIntrReqSetAffinity_Instance
> +static inline RtemsIntrReqSetAffinity_Entry RtemsIntrReqSetAffinity_GetEntry(
> + size_t index
> + return RtemsIntrReqSetAffinity_Entries[
> + RtemsIntrReqSetAffinity_Map[ index ]
> + * @fn void T_case_body_RtemsIntrReqSetAffinity( void )
> +T_TEST_CASE_FIXTURE(
> + RtemsIntrReqSetAffinity,
> + &RtemsIntrReqSetAffinity_Fixture
> + size_t index;
> + ctx = T_fixture_context();
> + ctx->in_action_loop = true;
> + index = 0;
> + for (
> + ctx->pcs[ 0 ] = RtemsIntrReqSetAffinity_Pre_Vector_Valid;
> + ctx->pcs[ 0 ] < RtemsIntrReqSetAffinity_Pre_Vector_NA;
> + ++ctx->pcs[ 0 ]
> + for (
> + ctx->pcs[ 1 ] = RtemsIntrReqSetAffinity_Pre_CPUSetKind_Valid;
> + ctx->pcs[ 1 ] < RtemsIntrReqSetAffinity_Pre_CPUSetKind_NA;
> + ++ctx->pcs[ 1 ]
> + for (
> + ctx->pcs[ 2 ] = RtemsIntrReqSetAffinity_Pre_CPUSet_Valid;
> + ctx->pcs[ 2 ] < RtemsIntrReqSetAffinity_Pre_CPUSet_NA;
> + ++ctx->pcs[ 2 ]
> + for (
> + ctx->pcs[ 3 ] = RtemsIntrReqSetAffinity_Pre_CanSetAffinity_Yes;
> + ctx->pcs[ 3 ] < RtemsIntrReqSetAffinity_Pre_CanSetAffinity_NA;
> + ++ctx->pcs[ 3 ]
> + RtemsIntrReqSetAffinity_Entry entry;
> + size_t pcs[ 4 ];
> + entry = RtemsIntrReqSetAffinity_GetEntry( index );
> + ++index;
> + memcpy( pcs, ctx->pcs, sizeof( pcs ) );
> + if ( entry.Pre_CanSetAffinity_NA ) {
> + ctx->pcs[ 3 ] = RtemsIntrReqSetAffinity_Pre_CanSetAffinity_NA;
> + RtemsIntrReqSetAffinity_Prepare( ctx );
> + RtemsIntrReqSetAffinity_Pre_Vector_Prepare( ctx, ctx->pcs[ 0 ] );
> + RtemsIntrReqSetAffinity_Pre_CPUSetKind_Prepare( ctx, ctx->pcs[ 1 ] );
> + RtemsIntrReqSetAffinity_Pre_CPUSet_Prepare( ctx, ctx->pcs[ 2 ] );
> + RtemsIntrReqSetAffinity_Pre_CanSetAffinity_Prepare(
> + ctx,
> + ctx->pcs[ 3 ]
> + RtemsIntrReqSetAffinity_Action( ctx );
> + RtemsIntrReqSetAffinity_Post_Status_Check( ctx, entry.Post_Status );
> + RtemsIntrReqSetAffinity_Post_SetAffinity_Check(
> + ctx,
> + entry.Post_SetAffinity
> + memcpy( ctx->pcs, pcs, sizeof( ctx->pcs ) );
> 2.26.2
> devel mailing list
> devel at rtems.org
