[PATCH 20/41] sparc/irq: Implement new interrupt directives
Thu Jul 22 06:46:06 UTC 2021
On 22/07/2021 08:43, Chris Johns wrote:
> On 22/7/21 5:08 am, Sebastian Huber wrote:
>> On 21/07/2021 21:04, Gedare Bloom wrote:
>>> On Wed, Jul 21, 2021 at 12:31 PM Sebastian Huber
>>> <sebastian.huber at embedded-brains.de>   wrote:
>>>> On 21/07/2021 20:28, Gedare Bloom wrote:
>>>>> Why not throw an error here instead? In production, you wouldn't want
>>>>> this code...
>>>> The main issue is the bad chip design. If we don't have this code, we
>>>> can't test the extended interrupts. In production, you want tested code.
>>> ok, thanks. My comments are all pretty minor, except for the
>>> terminology issues of "cause" but that wording already exists. post
>>> the v2 series, but I probably won't review it and you can check it in
>>> if no one complains. It's up to you if you want to work a different
>>> wording than "cause" -- I prefer "raise"
>> Thanks a lot for the review.
>> Joel, what is your opinion with respect to "cause" vs. "raise"?
> I think `raise`.
Ok, great. I will replace "cause" with "raise" and send a v3 version of
the patch set.
I think we should remove the unimplemented rtems_interrupt_cause().
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
