[PATCH] build: Merge default-by-family into by-variant
Fri Jul 23 06:49:40 UTC 2021
Prefix the BSP family name with "bsps/" to make it distinct to the BSP
variant names.
 spec/build/bsps/optconsolebaud.yml |  5 +----
 wscript                            | 10 ++++++----
 2 files changed, 7 insertions(+), 8 deletions(-)
diff --git a/spec/build/bsps/optconsolebaud.yml b/spec/build/bsps/optconsolebaud.yml
index 4b0869beca..0233fdd61b 100644
--- a/spec/build/bsps/optconsolebaud.yml
+++ b/spec/build/bsps/optconsolebaud.yml
@@ -6,13 +6,10 @@ build-type: option
 copyrights:
 - Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
 default: 115200
-default-by-family:
-- value: 9600
-  families:
-  - powerpc/motorola_powerpc
 default-by-variant:
 - value: 9600
   variants:
+  - bsps/powerpc/motorola_powerpc
   - m68k/m5484FireEngine
   - powerpc/hsc_cm01
   - powerpc/beatnik
diff --git a/wscript b/wscript
index fb8ce9292d..bd75de9807 100755
--- a/wscript
+++ b/wscript
@@ -698,10 +698,12 @@ class OptionItem(Item):
             if OptionItem._is_variant(default["variants"], variant):
                 value = default["value"]
                 break
-        for default in self.data["default-by-family"]:
-            if OptionItem._is_variant(default["families"], family):
-                value = default["value"]
-                break
+        else:
+            family = "bsps/" + family
+            for default in self.data["default-by-variant"]:
+                if OptionItem._is_variant(default["variants"], family):
+                    value = default["value"]
+                    break
         if value is None:
             return value
         if isinstance(value, list):
2.26.2
