[PATCH v3 01/42] bsps/irq: Move get/set affinity to separate file
Sebastian Huber
Fri Jul 23 13:56:09 UTC 2021
Update #3269.
bsps/shared/irq-default-sources.am | 1 +
bsps/shared/irq-sources.am | 1 +
bsps/shared/irq/irq-affinity.c | 90 ++++++++++++++++++++
bsps/shared/irq/irq-generic.c | 52 -----------
c/src/lib/libbsp/m68k/genmcf548x/Makefile.am | 1 +
c/src/lib/libbsp/powerpc/ss555/Makefile.am | 1 +
spec/build/bsps/m68k/genmcf548x/obj.yml | 1 +
spec/build/bsps/objirq.yml | 1 +
spec/build/bsps/powerpc/ss555/bspss555.yml | 1 +
9 files changed, 97 insertions(+), 52 deletions(-)
create mode 100644 bsps/shared/irq/irq-affinity.c
diff --git a/bsps/shared/irq-default-sources.am b/bsps/shared/irq-default-sources.am
index 1163f77bd8..6b4696dd26 100644
--- a/bsps/shared/irq-default-sources.am
+++ b/bsps/shared/irq-default-sources.am
@@ -1,3 +1,4 @@
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-affinity.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-default.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-default-handler.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-generic.c
diff --git a/bsps/shared/irq-sources.am b/bsps/shared/irq-sources.am
index a5e8e6ffdf..65c380a2da 100644
--- a/bsps/shared/irq-sources.am
+++ b/bsps/shared/irq-sources.am
@@ -1,3 +1,4 @@
librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-info.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-legacy.c
diff --git a/bsps/shared/irq/irq-affinity.c b/bsps/shared/irq/irq-affinity.c
new file mode 100644
index 0000000000..f750d6b174
--- /dev/null
+++ b/bsps/shared/irq/irq-affinity.c
@@ -0,0 +1,90 @@
+ * @file
+ * @ingroup bsp_interrupt
+ * @brief This source file contains the implementation of
+ * rtems_interrupt_get_affinity() and rtems_interrupt_set_affinity().
+ * Copyright (C) 2017 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#include <bsp/irq-generic.h>
+#include <rtems/score/processormask.h>
+rtems_status_code rtems_interrupt_set_affinity(
+ rtems_vector_number vector,
+ size_t affinity_size,
+ const cpu_set_t *affinity
+ Processor_mask set;
+ Processor_mask_Copy_status status;
+ if (!bsp_interrupt_is_valid_vector(vector)) {
+ return RTEMS_INVALID_ID;
+ status = _Processor_mask_From_cpu_set_t(&set, affinity_size, affinity);
+ if (status != PROCESSOR_MASK_COPY_LOSSLESS) {
+ return RTEMS_INVALID_SIZE;
+#if defined(RTEMS_SMP)
+ bsp_interrupt_set_affinity(vector, &set);
+#endif
+ return RTEMS_SUCCESSFUL;
+rtems_status_code rtems_interrupt_get_affinity(
+ cpu_set_t *affinity
+ bsp_interrupt_get_affinity(vector, &set);
+#else
+ _Processor_mask_From_index(&set, 0);
+#endif
+ status = _Processor_mask_To_cpu_set_t(&set, affinity_size, affinity);
diff --git a/bsps/shared/irq/irq-generic.c b/bsps/shared/irq/irq-generic.c
index 65971fb1b3..bea6612136 100644
--- a/bsps/shared/irq/irq-generic.c
+++ b/bsps/shared/irq/irq-generic.c
@@ -39,7 +39,6 @@
-#include <rtems/score/processormask.h>
#include <rtems/malloc.h>
#ifdef BSP_INTERRUPT_USE_INDEX_TABLE
@@ -548,54 +547,3 @@ bool bsp_interrupt_handler_is_empty(rtems_vector_number vector)
return empty;
-rtems_status_code rtems_interrupt_set_affinity(
- rtems_vector_number vector,
- size_t affinity_size,
- const cpu_set_t *affinity
- Processor_mask set;
- Processor_mask_Copy_status status;
- if (!bsp_interrupt_is_valid_vector(vector)) {
- return RTEMS_INVALID_ID;
- status = _Processor_mask_From_cpu_set_t(&set, affinity_size, affinity);
- if (status != PROCESSOR_MASK_COPY_LOSSLESS) {
- return RTEMS_INVALID_SIZE;
-#if defined(RTEMS_SMP)
- bsp_interrupt_set_affinity(vector, &set);
-#endif
- return RTEMS_SUCCESSFUL;
-rtems_status_code rtems_interrupt_get_affinity(
- cpu_set_t *affinity
- bsp_interrupt_get_affinity(vector, &set);
-#else
- _Processor_mask_From_index(&set, 0);
-#endif
- status = _Processor_mask_To_cpu_set_t(&set, affinity_size, affinity);
diff --git a/c/src/lib/libbsp/m68k/genmcf548x/Makefile.am b/c/src/lib/libbsp/m68k/genmcf548x/Makefile.am
index a7dc71edd8..0ae30ca93a 100644
--- a/c/src/lib/libbsp/m68k/genmcf548x/Makefile.am
+++ b/c/src/lib/libbsp/m68k/genmcf548x/Makefile.am
@@ -38,6 +38,7 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/m68k/genmcf548x/console/console.
librtemsbsp_a_SOURCES += ../../../../../../bsps/m68k/genmcf548x/btimer/btimer.c
# IRQ
diff --git a/c/src/lib/libbsp/powerpc/ss555/Makefile.am b/c/src/lib/libbsp/powerpc/ss555/Makefile.am
index d5da8fb303..43fed4fcbd 100644
--- a/c/src/lib/libbsp/powerpc/ss555/Makefile.am
+++ b/c/src/lib/libbsp/powerpc/ss555/Makefile.am
@@ -46,6 +46,7 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/powerpc/ss555/start/raw_exceptio
librtemsbsp_a_SOURCES += ../../../../../../bsps/powerpc/ss555/start/vectors_init.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/powerpc/ss555/start/vectors.S
diff --git a/spec/build/bsps/m68k/genmcf548x/obj.yml b/spec/build/bsps/m68k/genmcf548x/obj.yml
index d01149ce38..a318da5e93 100644
--- a/spec/build/bsps/m68k/genmcf548x/obj.yml
+++ b/spec/build/bsps/m68k/genmcf548x/obj.yml
@@ -38,6 +38,7 @@ source:
- bsps/m68k/shared/m68kidle.c
- bsps/m68k/shared/memProbe.c
- bsps/shared/dev/getentropy/getentropy-cpucounter.c
+- bsps/shared/irq/irq-affinity.c
- bsps/shared/irq/irq-default-handler.c
- bsps/shared/irq/irq-info.c
- bsps/shared/irq/irq-legacy.c
diff --git a/spec/build/bsps/objirq.yml b/spec/build/bsps/objirq.yml
index aa3da23aa7..cb4eeb8fd4 100644
--- a/spec/build/bsps/objirq.yml
+++ b/spec/build/bsps/objirq.yml
@@ -10,6 +10,7 @@ includes: []
install: []
links: []
source:
- bsps/shared/irq/irq-generic.c
diff --git a/spec/build/bsps/powerpc/ss555/bspss555.yml b/spec/build/bsps/powerpc/ss555/bspss555.yml
index c76dae2a4a..89c0ff7774 100644
--- a/spec/build/bsps/powerpc/ss555/bspss555.yml
+++ b/spec/build/bsps/powerpc/ss555/bspss555.yml
@@ -67,6 +67,7 @@ source:
- bsps/powerpc/ss555/start/vectors.S
- bsps/powerpc/ss555/start/vectors_init.c
- bsps/shared/irq/irq-default.c
2.26.2
