[PATCH v3 27/42] validation: Add CallWithinISR()
    Sebastian Huber
    Fri Jul 23 13:56:35 UTC 2021
Update #3269.
 .../testsuites/validation/libvalidation.yml   |   1 +
 testsuites/validation/tx-call-within-isr.c    | 134 ++++++++++++++++++
 testsuites/validation/tx-support.h            |  14 ++
 3 files changed, 149 insertions(+)
 create mode 100644 testsuites/validation/tx-call-within-isr.c
diff --git a/spec/build/testsuites/validation/libvalidation.yml b/spec/build/testsuites/validation/libvalidation.yml
index d55d4b9e41..54c7ae0ac0 100644
--- a/spec/build/testsuites/validation/libvalidation.yml
+++ b/spec/build/testsuites/validation/libvalidation.yml
@@ -11,6 +11,7 @@ install: []
 install-path: null
 links: []
 source:
+- testsuites/validation/tx-call-within-isr.c
 - testsuites/validation/tx-support.c
 target: validation
 type: build
diff --git a/testsuites/validation/tx-call-within-isr.c b/testsuites/validation/tx-call-within-isr.c
new file mode 100644
index 0000000000..226647c0bc
--- /dev/null
+++ b/testsuites/validation/tx-call-within-isr.c
@@ -0,0 +1,134 @@
+ * @file
+ * @ingroup RTEMSTestSuites
+ * @brief This source file contains the implementation of CallWithinISR(),
+ *   CallWithinISRSubmit(), and CallWithinISRWait().
+ * Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include "tx-support.h"
+#include <rtems/sysinit.h>
+#include <rtems/score/chainimpl.h>
+#include <bsp.h>
+/* Some target architectures need this variable for <tm27.h> */
+uint32_t Interrupt_nest;
+#define _RTEMS_TMTEST27
+#include <tm27.h>
+typedef struct {
+  Chain_Control pending;
+  RTEMS_INTERRUPT_LOCK_MEMBER( lock )
+} CallWithinISRContext;
+static CallWithinISRContext CallWithinISRInstance = {
+#if defined( RTEMS_SMP )
+  .lock = RTEMS_INTERRUPT_LOCK_INITIALIZER( "CallWithinISR" ),
+#endif
+  .pending = CHAIN_INITIALIZER_EMPTY( CallWithinISRInstance.pending )
+static void CallWithinISRHandler( rtems_vector_number vector )
+  CallWithinISRContext *ctx;
+  (void) vector;
+  ctx = &CallWithinISRInstance;
+  while ( true ) {
+    rtems_interrupt_lock_context lock_context;
+    CallWithinISRRequest        *request;
+    rtems_interrupt_lock_acquire( &ctx->lock, &lock_context );
+    request = (CallWithinISRRequest *)
+      _Chain_Get_unprotected( &ctx->pending );
+    rtems_interrupt_lock_release( &ctx->lock, &lock_context );
+    if ( request == NULL ) {
+      break;
+    ( *request->handler )( request->arg );
+    _Atomic_Store_uint( &request->done, 1, ATOMIC_ORDER_RELEASE );
+void CallWithinISR( void ( *handler )( void * ), void *arg )
+  CallWithinISRRequest request;
+  request.handler = handler;
+  request.arg = arg;
+  CallWithinISRSubmit( &request );
+  CallWithinISRWait( &request );
+void CallWithinISRSubmit( CallWithinISRRequest *request )
+  _Atomic_Store_uint( &request->done, 0, ATOMIC_ORDER_RELAXED );
+  _Chain_Initialize_node( &request->node );
+  _Chain_Append_unprotected( &ctx->pending, &request->node );
+  Cause_tm27_intr();
+void CallWithinISRWait( const CallWithinISRRequest *request )
+  while ( _Atomic_Load_uint( &request->done, ATOMIC_ORDER_ACQUIRE ) == 0 ) {
+    /* Wait */
+static void CallWithinISRInitialize( void )
+  Install_tm27_vector( CallWithinISRHandler );
+RTEMS_SYSINIT_ITEM(
+  CallWithinISRInitialize,
+  RTEMS_SYSINIT_DEVICE_DRIVERS,
+  RTEMS_SYSINIT_ORDER_MIDDLE
diff --git a/testsuites/validation/tx-support.h b/testsuites/validation/tx-support.h
index 932584b168..9d5a51e461 100644
--- a/testsuites/validation/tx-support.h
+++ b/testsuites/validation/tx-support.h
@@ -38,6 +38,7 @@
 #define _TX_SUPPORT_H
+#include <rtems/score/atomic.h>
 #ifdef __cplusplus
 extern "C" {
@@ -99,6 +100,19 @@ void RestoreRunnerMode( void );
 void RestoreRunnerPriority( void );
+typedef struct {
+  Chain_Node node;
+  void ( *handler )( void * );
+  void *arg;
+  Atomic_Uint done;
+} CallWithinISRRequest;
+void CallWithinISR( void ( *handler )( void * ), void *arg );
+void CallWithinISRSubmit( CallWithinISRRequest *request );
+void CallWithinISRWait( const CallWithinISRRequest *request );
 #ifdef __cplusplus
2.26.2
