[PATCH v3 09/42] rtems: Add rtems_interrupt_is_pending()
Sebastian Huber
Fri Jul 23 13:56:17 UTC 2021
Update #3269.
cpukit/include/rtems/irq-extension.h | 54 ++++++++++++++++++++++++++++
1 file changed, 54 insertions(+)
diff --git a/cpukit/include/rtems/irq-extension.h b/cpukit/include/rtems/irq-extension.h
index f538297b3c..0a26ef959c 100644
--- a/cpukit/include/rtems/irq-extension.h
+++ b/cpukit/include/rtems/irq-extension.h
@@ -453,6 +453,60 @@ rtems_status_code rtems_interrupt_vector_enable( rtems_vector_number vector );
rtems_status_code rtems_interrupt_vector_disable( rtems_vector_number vector );
+/* Generated from spec:/rtems/intr/if/is-pending */
+ * @ingroup RTEMSAPIClassicIntr
+ * @brief Checks if the interrupt is pending.
+ * @param vector is the interrupt vector number.
+ * @param[out] pending is the pointer to a ``bool`` object. When the directive
+ * call is successful, the pending status of the interrupt associated with
+ * the interrupt vector specified by ``vector`` will be stored in this
+ * object. When the interrupt was pending for the processor executing the
+ * directive call at some time point during the call, the object value will
+ * be set to true, otherwise to false.
+ * The directive checks if the interrupt associated with the interrupt vector
+ * specified by ``vector`` was pending for the processor executing the
+ * directive call at some time point during the call.
+ * @retval ::RTEMS_SUCCESSFUL The requested operation was successful.
+ * @retval ::RTEMS_INVALID_ADDRESS The ``pending`` parameter was NULL.
+ * @retval ::RTEMS_INVALID_ID There was no interrupt vector associated with the
+ * number specified by ``vector``.
+ * @retval ::RTEMS_UNSATISFIED The request to get the pending status has not
+ * been satisfied.
+ * @par Notes
+ * Interrupts may be made pending by calling the rtems_interrupt_raise() or
+ * rtems_interrupt_raise_on() directives or due to external signals or
+ * messages. The pending state may be cleared by rtems_interrupt_clear().
+ * @par Constraints
+ * @parblock
+ * The following constraints apply to this directive:
+ * * The directive may be called from within interrupt context.
+ * * The directive may be called from within device driver initialization
+ * context.
+ * * The directive may be called from within task context.
+ * * The directive will not cause the calling task to be preempted.
+ * @endparblock
+rtems_status_code rtems_interrupt_is_pending(
+ rtems_vector_number vector,
+ bool *pending
/* Generated from spec:/rtems/intr/if/get-affinity */
2.26.2
