[PATCH v3 36/42] validation: Test rtems_interrupt_entry_remove()
Sebastian Huber
Fri Jul 23 13:56:44 UTC 2021
Update #3269.
.../testsuites/validation/validation-0.yml | 1 +
testsuites/validation/tc-intr-entry-remove.c | 1432 +++++++++++++++++
2 files changed, 1433 insertions(+)
create mode 100644 testsuites/validation/tc-intr-entry-remove.c
diff --git a/spec/build/testsuites/validation/validation-0.yml b/spec/build/testsuites/validation/validation-0.yml
index c536779f2d..08ef145c82 100644
--- a/spec/build/testsuites/validation/validation-0.yml
+++ b/spec/build/testsuites/validation/validation-0.yml
@@ -16,6 +16,7 @@ source:
- testsuites/validation/tc-barrier-release.c
- testsuites/validation/tc-barrier-wait.c
- testsuites/validation/tc-intr-entry-install.c
+- testsuites/validation/tc-intr-entry-remove.c
- testsuites/validation/tc-intr-get-attributes.c
- testsuites/validation/tc-intr-vector-disable.c
- testsuites/validation/tc-intr-vector-enable.c
diff --git a/testsuites/validation/tc-intr-entry-remove.c b/testsuites/validation/tc-intr-entry-remove.c
new file mode 100644
index 0000000000..64f6e46de7
--- /dev/null
+++ b/testsuites/validation/tc-intr-entry-remove.c
@@ -0,0 +1,1432 @@
+ * @file
+ * @ingroup RTEMSTestCaseRtemsIntrReqEntryRemove
+ * Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * This file is part of the RTEMS quality process and was automatically
+ * generated. If you find something that needs to be fixed or
+ * worded better please post a report or patch to an RTEMS mailing list
+ * or raise a bug report:
+ * https://www.rtems.org/bugs.html
+ * For information on updating and regenerating please refer to the How-To
+ * section in the Software Requirements Engineering chapter of the
+ * RTEMS Software Engineering manual. The manual is provided as a part of
+ * a release. For development sources please refer to the online
+ * documentation at:
+ * https://docs.rtems.org
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <bsp/irq-generic.h>
+#include <rtems/irq-extension.h>
+#include "tx-support.h"
+#include <rtems/test.h>
+ * @defgroup RTEMSTestCaseRtemsIntrReqEntryRemove \
+ * spec:/rtems/intr/req/entry-remove
+ * @ingroup RTEMSTestSuiteTestsuitesValidation0
+typedef enum {
+ RtemsIntrReqEntryRemove_Pre_Vector_Valid,
+ RtemsIntrReqEntryRemove_Pre_Vector_Invalid,
+ RtemsIntrReqEntryRemove_Pre_Vector_NA
+} RtemsIntrReqEntryRemove_Pre_Vector;
+typedef enum {
+ RtemsIntrReqEntryRemove_Pre_Entry_Obj,
+ RtemsIntrReqEntryRemove_Pre_Entry_Null,
+ RtemsIntrReqEntryRemove_Pre_Entry_NA
+} RtemsIntrReqEntryRemove_Pre_Entry;
+typedef enum {
+ RtemsIntrReqEntryRemove_Pre_Routine_Valid,
+ RtemsIntrReqEntryRemove_Pre_Routine_Null,
+ RtemsIntrReqEntryRemove_Pre_Routine_NA
+} RtemsIntrReqEntryRemove_Pre_Routine;
+typedef enum {
+ RtemsIntrReqEntryRemove_Pre_EntryObj_Installed,
+ RtemsIntrReqEntryRemove_Pre_EntryObj_Match,
+ RtemsIntrReqEntryRemove_Pre_EntryObj_NoMatch,
+ RtemsIntrReqEntryRemove_Pre_EntryObj_NA
+} RtemsIntrReqEntryRemove_Pre_EntryObj;
+typedef enum {
+ RtemsIntrReqEntryRemove_Pre_Init_Yes,
+ RtemsIntrReqEntryRemove_Pre_Init_No,
+ RtemsIntrReqEntryRemove_Pre_Init_NA
+} RtemsIntrReqEntryRemove_Pre_Init;
+typedef enum {
+ RtemsIntrReqEntryRemove_Pre_ISR_Yes,
+ RtemsIntrReqEntryRemove_Pre_ISR_No,
+ RtemsIntrReqEntryRemove_Pre_ISR_NA
+} RtemsIntrReqEntryRemove_Pre_ISR;
+typedef enum {
+ RtemsIntrReqEntryRemove_Pre_CanDisable_Yes,
+ RtemsIntrReqEntryRemove_Pre_CanDisable_Maybe,
+ RtemsIntrReqEntryRemove_Pre_CanDisable_No,
+ RtemsIntrReqEntryRemove_Pre_CanDisable_NA
+} RtemsIntrReqEntryRemove_Pre_CanDisable;
+typedef enum {
+ RtemsIntrReqEntryRemove_Pre_First_Yes,
+ RtemsIntrReqEntryRemove_Pre_First_No,
+ RtemsIntrReqEntryRemove_Pre_First_NA
+} RtemsIntrReqEntryRemove_Pre_First;
+typedef enum {
+ RtemsIntrReqEntryRemove_Pre_Last_Yes,
+ RtemsIntrReqEntryRemove_Pre_Last_No,
+ RtemsIntrReqEntryRemove_Pre_Last_NA
+} RtemsIntrReqEntryRemove_Pre_Last;
+typedef enum {
+ RtemsIntrReqEntryRemove_Post_Status_Ok,
+ RtemsIntrReqEntryRemove_Post_Status_InvAddr,
+ RtemsIntrReqEntryRemove_Post_Status_IncStat,
+ RtemsIntrReqEntryRemove_Post_Status_InvId,
+ RtemsIntrReqEntryRemove_Post_Status_CalledFromISR,
+ RtemsIntrReqEntryRemove_Post_Status_Unsat,
+ RtemsIntrReqEntryRemove_Post_Status_NA
+} RtemsIntrReqEntryRemove_Post_Status;
+typedef enum {
+ RtemsIntrReqEntryRemove_Post_Disabled_Nop,
+ RtemsIntrReqEntryRemove_Post_Disabled_Yes,
+ RtemsIntrReqEntryRemove_Post_Disabled_Maybe,
+ RtemsIntrReqEntryRemove_Post_Disabled_No,
+ RtemsIntrReqEntryRemove_Post_Disabled_NA
+} RtemsIntrReqEntryRemove_Post_Disabled;
+typedef enum {
+ RtemsIntrReqEntryRemove_Post_Installed_No,
+ RtemsIntrReqEntryRemove_Post_Installed_Nop,
+ RtemsIntrReqEntryRemove_Post_Installed_NA
+} RtemsIntrReqEntryRemove_Post_Installed;
+ * @brief Test context for spec:/rtems/intr/req/entry-remove test case.
+typedef struct {
+ * @brief If this member is true, then the service was initialized during
+ * setup.
+ bool initialized_during_setup;
+ * @brief If this member is true, then an interrupt occurred.
+ bool interrupt_occurred;
+ * @brief This member provides a counter incremented by EntryRoutine().
+ uint32_t entry_counter;;
+ * @brief This member provides another rtems_interrupt_entry object.
+ rtems_interrupt_entry other_entry;
+ * @brief If this member is true, then another entry was installed.
+ bool other_installed;
+ * @brief This member provides a third rtems_interrupt_entry object.
+ rtems_interrupt_entry third_entry;
+ * @brief If this member is true, then a third entry was installed.
+ bool third_installed;
+ * @brief If this member is true, then the entry is installed.
+ bool installed;
+ * @brief If this member is true, then the entry is installed as the first
+ * entry.
+ bool first;
+ * @brief If this member is true, then the entry is installed as the last
+ * entry.
+ bool last;
+ * @brief If this member is true, then the entry matches with another
+ * installed entry.
+ bool match;
+ * @brief This member provides the vector number of a testable interrupt
+ * vector.
+ rtems_vector_number test_vector;
+ * @brief This member provides the attributes of the testable interrupt
+ * vector.
+ rtems_interrupt_attributes attributes;
+ * @brief If this member is true, then the service shall be initialized.
+ bool initialized;
+ * @brief If this member is true, then rtems_interrupt_entry_remove() shall
+ * be called from within interrupt context.
+ bool isr;
+ * @brief This member contains the enabled status before the
+ * rtems_interrupt_entry_remove() call.
+ bool enabled_before;
+ * @brief This member contains the enabled status after the
+ bool enabled_after;
+ * @brief This member provides the count of visited entries.
+ uint32_t visited_entries;
+ * @brief This member provides the rtems_interrupt_entry object.
+ rtems_interrupt_entry entry_obj;
+ * @brief This member specifies if the ``vector`` parameter value.
+ rtems_vector_number vector;
+ * @brief This member specifies if the ``entry`` parameter value.
+ rtems_interrupt_entry *entry;;
+ * @brief This member contains the return value of the
+ rtems_status_code status;
+ * @brief This member defines the pre-condition states for the next action.
+ size_t pcs[ 9 ];
+ * @brief This member indicates if the test action loop is currently
+ * executed.
+ bool in_action_loop;
+} RtemsIntrReqEntryRemove_Context;
+static RtemsIntrReqEntryRemove_Context
+ RtemsIntrReqEntryRemove_Instance;
+static const char * const RtemsIntrReqEntryRemove_PreDesc_Vector[] = {
+ "Valid",
+ "Invalid",
+ "NA"
+static const char * const RtemsIntrReqEntryRemove_PreDesc_Entry[] = {
+ "Obj",
+ "Null",
+ "NA"
+static const char * const RtemsIntrReqEntryRemove_PreDesc_Routine[] = {
+ "Valid",
+ "Null",
+ "NA"
+static const char * const RtemsIntrReqEntryRemove_PreDesc_EntryObj[] = {
+ "Installed",
+ "Match",
+ "NoMatch",
+ "NA"
+static const char * const RtemsIntrReqEntryRemove_PreDesc_Init[] = {
+ "Yes",
+ "No",
+ "NA"
+static const char * const RtemsIntrReqEntryRemove_PreDesc_ISR[] = {
+ "Yes",
+ "No",
+ "NA"
+static const char * const RtemsIntrReqEntryRemove_PreDesc_CanDisable[] = {
+ "Yes",
+ "Maybe",
+ "No",
+ "NA"
+static const char * const RtemsIntrReqEntryRemove_PreDesc_First[] = {
+ "Yes",
+ "No",
+ "NA"
+static const char * const RtemsIntrReqEntryRemove_PreDesc_Last[] = {
+ "Yes",
+ "No",
+ "NA"
+static const char * const * const RtemsIntrReqEntryRemove_PreDesc[] = {
+ RtemsIntrReqEntryRemove_PreDesc_Vector,
+ RtemsIntrReqEntryRemove_PreDesc_Entry,
+ RtemsIntrReqEntryRemove_PreDesc_Routine,
+ RtemsIntrReqEntryRemove_PreDesc_EntryObj,
+ RtemsIntrReqEntryRemove_PreDesc_Init,
+ RtemsIntrReqEntryRemove_PreDesc_ISR,
+ RtemsIntrReqEntryRemove_PreDesc_CanDisable,
+ RtemsIntrReqEntryRemove_PreDesc_First,
+ RtemsIntrReqEntryRemove_PreDesc_Last,
+ NULL
+typedef RtemsIntrReqEntryRemove_Context Context;
+static char entry_arg;
+static char other_arg;
+static char third_arg;
+static const char info[] = "Info";
+static void Install(
+ Context *ctx,
+ rtems_interrupt_entry *entry,
+ rtems_interrupt_handler routine,
+ void *arg
+ rtems_status_code sc;
+ rtems_interrupt_entry_initialize(
+ entry,
+ routine,
+ arg,
+ info
+ sc = rtems_interrupt_entry_install(
+ ctx->test_vector,
+ RTEMS_INTERRUPT_SHARED,
+ entry
+ T_rsc_success( sc );
+static void OtherRoutine( void *arg )
+ Context *ctx;
+ (void) arg;
+ ctx = T_fixture_context();
+ sc = rtems_interrupt_vector_disable( ctx->test_vector );
+ ctx->interrupt_occurred = true;
+static void ThirdRoutine( void *arg )
+ T_eq_ptr( arg, &third_arg );
+ OtherRoutine( NULL );
+static void EntryRoutine( void *arg )
+ Context *ctx;
+ ++ctx->entry_counter;
+ T_eq_ptr( arg, &entry_arg );
+static void Action( void *arg )
+ Context *ctx;
+ ctx = arg;
+ sc = rtems_interrupt_vector_is_enabled(
+ ctx->test_vector,
+ &ctx->enabled_before
+ bsp_interrupt_set_handler_unique(
+ BSP_INTERRUPT_HANDLER_TABLE_SIZE,
+ ctx->initialized
+ ctx->status = rtems_interrupt_entry_remove( ctx->vector, ctx->entry );
+ ctx->initialized_during_setup
+ ctx->test_vector,
+ &ctx->enabled_after
+static void VisitInstalledNo(
+ void *arg,
+ const char *entry_info,
+ rtems_option options,
+ rtems_interrupt_handler handler_routine,
+ void *handler_arg
+ Context *ctx;
+ ctx = arg;
+ visited_entries = ctx->visited_entries;
+ T_eq_u32( options, RTEMS_INTERRUPT_SHARED );
+ T_eq_ptr( entry_info, info );
+ if ( visited_entries == 0 ) {
+ T_eq_ptr( handler_routine, ctx->other_entry.handler );
+ T_eq_ptr( handler_arg, ctx->other_entry.arg );
+ } else if ( visited_entries == 1 ) {
+ T_eq_ptr( handler_routine, ctx->third_entry.handler );
+ T_eq_ptr( handler_arg, ctx->third_entry.arg );
+ ctx->visited_entries = visited_entries + 1;
+static void VisitInstalledNop(
+ void *arg,
+ void *handler_arg
+ Context *ctx;
+ ctx = arg;
+ if ( ctx->installed && ctx->first ) {
+ T_eq_ptr( handler_routine, ctx->entry_obj.handler );
+ T_eq_ptr( handler_arg, ctx->entry_obj.arg );
+ } else {
+ T_eq_ptr( info, ctx->other_entry.info );
+ if (
+ ctx->installed && ( ( !ctx->first && ctx->last ) ||
+ ( !ctx->first && !ctx->last ) )
+ } else {
+ } else if ( visited_entries == 2 ) {
+ if ( ctx->installed && !ctx->first && ctx->last ) {
+ } else {
+static void RtemsIntrReqEntryRemove_Pre_Vector_Prepare(
+ RtemsIntrReqEntryRemove_Context *ctx,
+ RtemsIntrReqEntryRemove_Pre_Vector state
+ switch ( state ) {
+ case RtemsIntrReqEntryRemove_Pre_Vector_Valid: {
+ * While the ``vector`` parameter is associated with an interrupt vector.
+ ctx->vector = ctx->test_vector;
+ break;
+ case RtemsIntrReqEntryRemove_Pre_Vector_Invalid: {
+ * While the ``vector`` parameter is not associated with an interrupt
+ * vector.
+ ctx->vector = BSP_INTERRUPT_VECTOR_COUNT;
+ break;
+ case RtemsIntrReqEntryRemove_Pre_Vector_NA:
+ break;
+static void RtemsIntrReqEntryRemove_Pre_Entry_Prepare(
+ RtemsIntrReqEntryRemove_Pre_Entry state
+ case RtemsIntrReqEntryRemove_Pre_Entry_Obj: {
+ * While the ``entry`` parameter references an object of type
+ * rtems_interrupt_entry.
+ ctx->entry = &ctx->entry_obj;
+ break;
+ case RtemsIntrReqEntryRemove_Pre_Entry_Null: {
+ * While the ``entry`` parameter is equal to NULL.
+ ctx->entry = NULL;
+ break;
+ case RtemsIntrReqEntryRemove_Pre_Entry_NA:
+ break;
+static void RtemsIntrReqEntryRemove_Pre_Routine_Prepare(
+ RtemsIntrReqEntryRemove_Pre_Routine state
+ case RtemsIntrReqEntryRemove_Pre_Routine_Valid: {
+ * While the handler routine of the entry referenced by the ``options``
+ * parameter is valid.
+ &ctx->entry_obj,
+ EntryRoutine,
+ &entry_arg,
+ info
+ break;
+ case RtemsIntrReqEntryRemove_Pre_Routine_Null: {
+ * parameter is equal to NULL.
+ &ctx->entry_obj,
+ NULL,
+ &entry_arg,
+ info
+ break;
+ case RtemsIntrReqEntryRemove_Pre_Routine_NA:
+ break;
+static void RtemsIntrReqEntryRemove_Pre_EntryObj_Prepare(
+ RtemsIntrReqEntryRemove_Pre_EntryObj state
+ case RtemsIntrReqEntryRemove_Pre_EntryObj_Installed: {
+ * While the entry referenced by the ``options`` parameter is installed
+ * at the interrupt vector specified by the ``vector`` parameter.
+ ctx->installed = true;
+ break;
+ case RtemsIntrReqEntryRemove_Pre_EntryObj_Match: {
+ * While the entry referenced by the ``options`` parameter not installed
+ * at the interrupt vector specified by the ``vector`` parameter, while
+ * the entry referenced by the ``options`` has a handler routine and
+ * argument pair which is equal to the handler routine and argument pair
+ * of an entry installed at the interrupt vector specified by the
+ * ``vector`` parameter.
+ ctx->installed = false;
+ ctx->other_installed = true;
+ ctx->match = true;
+ break;
+ case RtemsIntrReqEntryRemove_Pre_EntryObj_NoMatch: {
+ * argument pair which is not equal to the handler routine and argument
+ * pairs of all entries installed at the interrupt vector specified by
+ * the ``vector`` parameter.
+ ctx->match = false;
+ break;
+ case RtemsIntrReqEntryRemove_Pre_EntryObj_NA:
+ break;
+static void RtemsIntrReqEntryRemove_Pre_Init_Prepare(
+ RtemsIntrReqEntryRemove_Pre_Init state
+ case RtemsIntrReqEntryRemove_Pre_Init_Yes: {
+ * While the service is initialized.
+ ctx->initialized = true;
+ break;
+ case RtemsIntrReqEntryRemove_Pre_Init_No: {
+ * While the service is not initialized.
+ ctx->initialized = false;
+ break;
+ case RtemsIntrReqEntryRemove_Pre_Init_NA:
+ break;
+static void RtemsIntrReqEntryRemove_Pre_ISR_Prepare(
+ RtemsIntrReqEntryRemove_Pre_ISR state
+ case RtemsIntrReqEntryRemove_Pre_ISR_Yes: {
+ * While rtems_interrupt_entry_remove() is called from within interrupt
+ * context.
+ ctx->isr = true;
+ break;
+ case RtemsIntrReqEntryRemove_Pre_ISR_No: {
+ * While rtems_interrupt_entry_remove() is not called from within
+ * interrupt context.
+ ctx->isr = false;
+ break;
+ case RtemsIntrReqEntryRemove_Pre_ISR_NA:
+ break;
+static void RtemsIntrReqEntryRemove_Pre_CanDisable_Prepare(
+ RtemsIntrReqEntryRemove_Pre_CanDisable state
+ case RtemsIntrReqEntryRemove_Pre_CanDisable_Yes: {
+ * While the interrupt vector associated with the ``vector`` parameter
+ * can be disabled.
+ * This pre-condition depends on the attributes of an interrupt vector.
+ * For the validation test of rtems_interrupt_entry_remove() a testable
+ * interrupt vector is determined by GetTestableInterruptVector(). The
+ * implementation of rtems_interrupt_entry_remove() uses
+ * rtems_interrupt_vector_disable() which is validated separately in detail.
+ break;
+ case RtemsIntrReqEntryRemove_Pre_CanDisable_Maybe: {
+ * may be disabled.
+ /* See comment for ``Yes`` state */
+ break;
+ case RtemsIntrReqEntryRemove_Pre_CanDisable_No: {
+ * cannot be disabled.
+ break;
+ case RtemsIntrReqEntryRemove_Pre_CanDisable_NA:
+ break;
+static void RtemsIntrReqEntryRemove_Pre_First_Prepare(
+ RtemsIntrReqEntryRemove_Pre_First state
+ case RtemsIntrReqEntryRemove_Pre_First_Yes: {
+ * While the entry referenced by the ``entry`` parameter is installed as
+ * the first entry at the interrupt vector specified by the ``vector``
+ * parameter.
+ ctx->first = true;
+ break;
+ case RtemsIntrReqEntryRemove_Pre_First_No: {
+ * not the first entry at the interrupt vector specified by the
+ ctx->first = false;
+ break;
+ case RtemsIntrReqEntryRemove_Pre_First_NA:
+ break;
+static void RtemsIntrReqEntryRemove_Pre_Last_Prepare(
+ RtemsIntrReqEntryRemove_Pre_Last state
+ case RtemsIntrReqEntryRemove_Pre_Last_Yes: {
+ * the last entry at the interrupt vector specified by the ``vector``
+ * parameter.
+ ctx->last = true;
+ break;
+ case RtemsIntrReqEntryRemove_Pre_Last_No: {
+ * not the last entry at the interrupt vector specified by the ``vector``
+ * parameter.
+ ctx->last = false;
+ break;
+ case RtemsIntrReqEntryRemove_Pre_Last_NA:
+ break;
+static void RtemsIntrReqEntryRemove_Post_Status_Check(
+ RtemsIntrReqEntryRemove_Post_Status state
+ case RtemsIntrReqEntryRemove_Post_Status_Ok: {
+ * The return status of rtems_interrupt_entry_remove() shall be
+ * RTEMS_SUCCESSFUL.
+ T_rsc_success( ctx->status );
+ break;
+ case RtemsIntrReqEntryRemove_Post_Status_InvAddr: {
+ * RTEMS_INVALID_ADDRESS.
+ T_rsc( ctx->status, RTEMS_INVALID_ADDRESS );
+ break;
+ case RtemsIntrReqEntryRemove_Post_Status_IncStat: {
+ * RTEMS_INCORRECT_STATE.
+ T_rsc( ctx->status, RTEMS_INCORRECT_STATE );
+ break;
+ case RtemsIntrReqEntryRemove_Post_Status_InvId: {
+ * RTEMS_INVALID_ID.
+ T_rsc( ctx->status, RTEMS_INVALID_ID );
+ break;
+ case RtemsIntrReqEntryRemove_Post_Status_CalledFromISR: {
+ * RTEMS_CALLED_FROM_ISR.
+ T_rsc( ctx->status, RTEMS_CALLED_FROM_ISR );
+ break;
+ case RtemsIntrReqEntryRemove_Post_Status_Unsat: {
+ * RTEMS_UNSATISFIED.
+ T_rsc( ctx->status, RTEMS_UNSATISFIED );
+ break;
+ case RtemsIntrReqEntryRemove_Post_Status_NA:
+ break;
+static void RtemsIntrReqEntryRemove_Post_Disabled_Check(
+ RtemsIntrReqEntryRemove_Post_Disabled state
+ case RtemsIntrReqEntryRemove_Post_Disabled_Nop: {
+ * The enabled status of the interrupt vector specified by ``vector``
+ * shall not be modified by the rtems_interrupt_entry_remove() call.
+ if ( !ctx->interrupt_occurred ) {
+ T_eq( ctx->enabled_before, ctx->enabled_after );
+ break;
+ case RtemsIntrReqEntryRemove_Post_Disabled_Yes: {
+ * The interrupt vector specified by ``vector`` shall be disabled.
+ if ( ctx->attributes.can_disable ) {
+ T_false( ctx->enabled_after );
+ break;
+ case RtemsIntrReqEntryRemove_Post_Disabled_Maybe: {
+ * The interrupt vector specified by ``vector`` may be disabled.
+ /* The comment of pre-condition ``CanDisable`` for the ``Yes`` state. */
+ break;
+ case RtemsIntrReqEntryRemove_Post_Disabled_No: {
+ * The interrupt vector specified by ``vector`` shall not be disabled.
+ break;
+ case RtemsIntrReqEntryRemove_Post_Disabled_NA:
+ break;
+static void RtemsIntrReqEntryRemove_Post_Installed_Check(
+ RtemsIntrReqEntryRemove_Post_Installed state
+ uint32_t expected_entries;
+ case RtemsIntrReqEntryRemove_Post_Installed_No: {
+ * The entry referenced by ``entry`` shall not be installed at the
+ * interrupt vector specified by ``vector``.
+ ctx->visited_entries = 0;
+ sc = rtems_interrupt_handler_iterate(
+ ctx->test_vector,
+ VisitInstalledNo,
+ ctx
+ if ( ctx->other_installed && ctx->third_installed ) {
+ expected_entries = 2;
+ } else if ( ctx->other_installed ) {
+ expected_entries = 1;
+ } else {
+ expected_entries = 0;
+ T_eq_u32( ctx->visited_entries, expected_entries );
+ if ( expected_entries > 0 ) {
+ ctx->entry_counter = 0;
+ bsp_interrupt_handler_dispatch( ctx->test_vector );
+ T_eq_u32( ctx->entry_counter, 0 );
+ } else {
+ rtems_interrupt_entry *first;
+ first = bsp_interrupt_handler_table[
+ bsp_interrupt_handler_index( ctx->test_vector )
+ T_null( first );
+ break;
+ case RtemsIntrReqEntryRemove_Post_Installed_Nop: {
+ * The entries installed at the interrupt vector specified by ``vector``
+ ctx->test_vector,
+ VisitInstalledNop,
+ ctx
+ if ( ctx->installed && ctx->other_installed && ctx->third_installed ) {
+ expected_entries = 3;
+ } else if ( ctx->installed && ctx->other_installed ) {
+ } else if ( ctx->installed || ctx->other_installed ) {
+ } else {
+ if ( ctx->installed ) {
+ T_eq_u32( ctx->entry_counter, 1 );
+ break;
+ case RtemsIntrReqEntryRemove_Post_Installed_NA:
+ break;
+static void RtemsIntrReqEntryRemove_Setup(
+ ctx->initialized_during_setup = bsp_interrupt_is_initialized();
+ ctx->test_vector = GetTestableInterruptVector();
+ sc = rtems_interrupt_get_attributes( ctx->test_vector, &ctx->attributes );
+static void RtemsIntrReqEntryRemove_Setup_Wrap( void *arg )
+ RtemsIntrReqEntryRemove_Context *ctx;
+ ctx = arg;
+ ctx->in_action_loop = false;
+ RtemsIntrReqEntryRemove_Setup( ctx );
+static void RtemsIntrReqEntryRemove_Prepare(
+ ctx->interrupt_occurred = false;
+ ctx->other_installed = false;
+ ctx->third_installed = false;
+static void RtemsIntrReqEntryRemove_Action(
+ if ( ctx->first && ctx->last ) {
+ Install( ctx, &ctx->entry_obj, EntryRoutine, &entry_arg );
+ } else if ( ctx->first ) {
+ Install( ctx, &ctx->other_entry, OtherRoutine, &other_arg );
+ } else if ( ctx->last ) {
+ } else {
+ ctx->third_installed = true;
+ Install( ctx, &ctx->third_entry, ThirdRoutine, &third_arg );
+ if ( ctx->match ) {
+ Install( ctx, &ctx->other_entry, EntryRoutine, &entry_arg );
+ } else {
+ if ( ctx->isr ) {
+ CallWithinISR( Action, ctx );
+ } else {
+ Action( ctx );
+static void RtemsIntrReqEntryRemove_Cleanup(
+ if ( ctx->third_installed ) {
+ sc = rtems_interrupt_entry_remove( ctx->test_vector, &ctx->third_entry );
+ if ( ctx->other_installed ) {
+ sc = rtems_interrupt_entry_remove( ctx->test_vector, &ctx->other_entry );
+ if ( ctx->installed && ctx->status != RTEMS_SUCCESSFUL ) {
+ sc = rtems_interrupt_entry_remove( ctx->test_vector, ctx->entry );
+typedef struct {
+ uint32_t Skip : 1;
+ uint32_t Pre_Vector_NA : 1;
+ uint32_t Pre_Entry_NA : 1;
+ uint32_t Pre_Routine_NA : 1;
+ uint32_t Pre_EntryObj_NA : 1;
+ uint32_t Pre_Init_NA : 1;
+ uint32_t Pre_ISR_NA : 1;
+ uint32_t Pre_CanDisable_NA : 1;
+ uint32_t Pre_First_NA : 1;
+ uint32_t Pre_Last_NA : 1;
+ uint32_t Post_Status : 3;
+ uint32_t Post_Disabled : 3;
+ uint32_t Post_Installed : 2;
+} RtemsIntrReqEntryRemove_Entry;
+static const RtemsIntrReqEntryRemove_Entry
+RtemsIntrReqEntryRemove_Entries[] = {
+ { 0, 0, 0, 1, 1, 0, 0, 0, 1, 1, RtemsIntrReqEntryRemove_Post_Status_InvAddr,
+ RtemsIntrReqEntryRemove_Post_Installed_NA },
+ { 0, 0, 0, 1, 1, 0, 0, 1, 1, 1, RtemsIntrReqEntryRemove_Post_Status_InvAddr,
+ RtemsIntrReqEntryRemove_Post_Disabled_NA,
+ { 0, 0, 0, 0, 1, 0, 0, 0, 1, 1, RtemsIntrReqEntryRemove_Post_Status_IncStat,
+ { 0, 0, 0, 0, 1, 0, 0, 1, 1, 1, RtemsIntrReqEntryRemove_Post_Status_IncStat,
+ { 0, 0, 0, 0, 1, 0, 0, 0, 1, 1, RtemsIntrReqEntryRemove_Post_Status_InvAddr,
+ { 0, 0, 0, 0, 1, 0, 0, 1, 1, 1, RtemsIntrReqEntryRemove_Post_Status_InvId,
+ { 0, 0, 0, 0, 1, 0, 0, 1, 1, 1, RtemsIntrReqEntryRemove_Post_Status_InvAddr,
+ { 0, 0, 0, 0, 0, 0, 0, 0, 1, 1,
+ { 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, RtemsIntrReqEntryRemove_Post_Status_Unsat,
+ { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ RtemsIntrReqEntryRemove_Post_Installed_Nop },
+ { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, RtemsIntrReqEntryRemove_Post_Status_Ok,
+ RtemsIntrReqEntryRemove_Post_Installed_No },
+static const uint8_t
+RtemsIntrReqEntryRemove_Map[] = {
+ 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 11, 10, 10, 10, 12, 10, 10, 10, 13, 10,
+ 10, 10, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2,
+ 2, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 2,
+ 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 7, 7, 7,
+ 7, 7, 7, 7, 7, 7, 7, 7, 7, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 2, 2, 2, 2, 2,
+ 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 4, 4, 4, 4, 4, 4, 4,
+ 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 2, 2, 2, 2, 2, 2, 2, 2, 2,
+ 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4,
+ 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2,
+ 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4,
+ 4, 4, 4, 4, 4, 4, 4, 4, 4, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2,
+ 2, 2, 2, 2, 2, 2, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+ 0, 0, 0, 0, 0, 0, 0, 0, 0, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5,
+ 5, 5, 5, 5, 5, 5, 5, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3,
+ 3, 3, 3, 3, 3, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5,
+ 5, 5, 5, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3,
+ 3, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 3,
+ 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 6, 6, 6,
+ 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 3, 3, 3, 3, 3,
+ 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 6, 6, 6, 6, 6, 6, 6,
+ 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 3, 3, 3, 3, 3, 3, 3, 3, 3,
+ 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6,
+ 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3,
+ 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1,
+ 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1,
+static size_t RtemsIntrReqEntryRemove_Scope( void *arg, char *buf, size_t n )
+ ctx = arg;
+ if ( ctx->in_action_loop ) {
+ return T_get_scope( RtemsIntrReqEntryRemove_PreDesc, buf, n, ctx->pcs );
+ return 0;
+static T_fixture RtemsIntrReqEntryRemove_Fixture = {
+ .setup = RtemsIntrReqEntryRemove_Setup_Wrap,
+ .stop = NULL,
+ .teardown = NULL,
+ .scope = RtemsIntrReqEntryRemove_Scope,
+ .initial_context = &RtemsIntrReqEntryRemove_Instance
+static inline RtemsIntrReqEntryRemove_Entry RtemsIntrReqEntryRemove_GetEntry(
+ size_t index
+ return RtemsIntrReqEntryRemove_Entries[
+ RtemsIntrReqEntryRemove_Map[ index ]
+ * @fn void T_case_body_RtemsIntrReqEntryRemove( void )
+T_TEST_CASE_FIXTURE(
+ RtemsIntrReqEntryRemove,
+ &RtemsIntrReqEntryRemove_Fixture
+ size_t index;
+ ctx->in_action_loop = true;
+ index = 0;
+ for (
+ ctx->pcs[ 0 ] = RtemsIntrReqEntryRemove_Pre_Vector_Valid;
+ ctx->pcs[ 0 ] < RtemsIntrReqEntryRemove_Pre_Vector_NA;
+ ++ctx->pcs[ 0 ]
+ for (
+ ctx->pcs[ 1 ] = RtemsIntrReqEntryRemove_Pre_Entry_Obj;
+ ctx->pcs[ 1 ] < RtemsIntrReqEntryRemove_Pre_Entry_NA;
+ ++ctx->pcs[ 1 ]
+ for (
+ ctx->pcs[ 2 ] = RtemsIntrReqEntryRemove_Pre_Routine_Valid;
+ ctx->pcs[ 2 ] < RtemsIntrReqEntryRemove_Pre_Routine_NA;
+ ++ctx->pcs[ 2 ]
+ for (
+ ctx->pcs[ 3 ] = RtemsIntrReqEntryRemove_Pre_EntryObj_Installed;
+ ctx->pcs[ 3 ] < RtemsIntrReqEntryRemove_Pre_EntryObj_NA;
+ ++ctx->pcs[ 3 ]
+ for (
+ ctx->pcs[ 4 ] = RtemsIntrReqEntryRemove_Pre_Init_Yes;
+ ctx->pcs[ 4 ] < RtemsIntrReqEntryRemove_Pre_Init_NA;
+ ++ctx->pcs[ 4 ]
+ for (
+ ctx->pcs[ 5 ] = RtemsIntrReqEntryRemove_Pre_ISR_Yes;
+ ctx->pcs[ 5 ] < RtemsIntrReqEntryRemove_Pre_ISR_NA;
+ ++ctx->pcs[ 5 ]
+ for (
+ ctx->pcs[ 6 ] = RtemsIntrReqEntryRemove_Pre_CanDisable_Yes;
+ ctx->pcs[ 6 ] < RtemsIntrReqEntryRemove_Pre_CanDisable_NA;
+ ++ctx->pcs[ 6 ]
+ for (
+ ctx->pcs[ 7 ] = RtemsIntrReqEntryRemove_Pre_First_Yes;
+ ctx->pcs[ 7 ] < RtemsIntrReqEntryRemove_Pre_First_NA;
+ ++ctx->pcs[ 7 ]
+ for (
+ ctx->pcs[ 8 ] = RtemsIntrReqEntryRemove_Pre_Last_Yes;
+ ctx->pcs[ 8 ] < RtemsIntrReqEntryRemove_Pre_Last_NA;
+ ++ctx->pcs[ 8 ]
+ RtemsIntrReqEntryRemove_Entry entry;
+ size_t pcs[ 9 ];
+ entry = RtemsIntrReqEntryRemove_GetEntry( index );
+ ++index;
+ memcpy( pcs, ctx->pcs, sizeof( pcs ) );
+ if ( entry.Pre_Routine_NA ) {
+ ctx->pcs[ 2 ] = RtemsIntrReqEntryRemove_Pre_Routine_NA;
+ if ( entry.Pre_EntryObj_NA ) {
+ ctx->pcs[ 3 ] = RtemsIntrReqEntryRemove_Pre_EntryObj_NA;
+ if ( entry.Pre_CanDisable_NA ) {
+ ctx->pcs[ 6 ] = RtemsIntrReqEntryRemove_Pre_CanDisable_NA;
+ if ( entry.Pre_First_NA ) {
+ ctx->pcs[ 7 ] = RtemsIntrReqEntryRemove_Pre_First_NA;
+ if ( entry.Pre_Last_NA ) {
+ ctx->pcs[ 8 ] = RtemsIntrReqEntryRemove_Pre_Last_NA;
+ RtemsIntrReqEntryRemove_Prepare( ctx );
+ RtemsIntrReqEntryRemove_Pre_Vector_Prepare(
+ ctx,
+ ctx->pcs[ 0 ]
+ RtemsIntrReqEntryRemove_Pre_Entry_Prepare(
+ ctx,
+ ctx->pcs[ 1 ]
+ RtemsIntrReqEntryRemove_Pre_Routine_Prepare(
+ ctx,
+ ctx->pcs[ 2 ]
+ RtemsIntrReqEntryRemove_Pre_EntryObj_Prepare(
+ ctx,
+ ctx->pcs[ 3 ]
+ RtemsIntrReqEntryRemove_Pre_Init_Prepare(
+ ctx,
+ ctx->pcs[ 4 ]
+ RtemsIntrReqEntryRemove_Pre_ISR_Prepare(
+ ctx,
+ ctx->pcs[ 5 ]
+ RtemsIntrReqEntryRemove_Pre_CanDisable_Prepare(
+ ctx,
+ ctx->pcs[ 6 ]
+ RtemsIntrReqEntryRemove_Pre_First_Prepare(
+ ctx,
+ ctx->pcs[ 7 ]
+ RtemsIntrReqEntryRemove_Pre_Last_Prepare(
+ ctx,
+ ctx->pcs[ 8 ]
+ RtemsIntrReqEntryRemove_Action( ctx );
+ RtemsIntrReqEntryRemove_Post_Status_Check(
+ ctx,
+ entry.Post_Status
+ RtemsIntrReqEntryRemove_Post_Disabled_Check(
+ ctx,
+ entry.Post_Disabled
+ RtemsIntrReqEntryRemove_Post_Installed_Check(
+ ctx,
+ entry.Post_Installed
+ RtemsIntrReqEntryRemove_Cleanup( ctx );
+ memcpy( ctx->pcs, pcs, sizeof( ctx->pcs ) );
2.26.2
