[PATCH v3 23/42] bsps/irq: Add bsp_interrupt_check_and_lock()
Sebastian Huber
Fri Jul 23 13:56:31 UTC 2021
Return RTEMS_INCORRECT_STATE instead of RTEMS_INTERNAL_ERROR in case the
interrupt support is not initialized. This is similar to
rtems_timer_server_fire_after() for example.
Update #3269.
bsps/include/bsp/irq-generic.h | 38 ++++++++++++++++-
bsps/shared/irq/irq-generic.c | 60 ++++++++++++++++-----------
bsps/shared/irq/irq-handler-iterate.c | 51 +++++++----------------
3 files changed, 86 insertions(+), 63 deletions(-)
diff --git a/bsps/include/bsp/irq-generic.h b/bsps/include/bsp/irq-generic.h
index 0f9bd5765b..e9cb0b4bb9 100644
--- a/bsps/include/bsp/irq-generic.h
+++ b/bsps/include/bsp/irq-generic.h
@@ -428,12 +428,46 @@ bool bsp_interrupt_handler_is_empty(rtems_vector_number vector);
-/* For internal use only */
+ * @brief Acquires the interrupt support lock.
+ * The interrupt support lock is a mutex. The mutex is only acquired if the
+ * system is the ::SYSTEM_STATE_UP state.
void bsp_interrupt_lock(void);
+ * @brief Releases the interrupt support lock.
+ * The mutex is only released if the system is the ::SYSTEM_STATE_UP state.
void bsp_interrupt_unlock(void);
+ * @brief Checks the vector and routine. When the checks were successful, the
+ * interrupt support lock will be obtained.
+ * @param vector is the interrupt vector number to check.
+ * @param routine is the routine to check.
+ * @retval ::RTEMS_SUCCESSFUL The requested operation was successful.
+ * @retval ::RTEMS_INCORRECT_STATE The interrupt support was not initialized.
+ * @retval ::RTEMS_CALLED_FROM_ISR The function was called from within
+ * interrupt context.
+ * @retval ::RTEMS_INVALID_ADDRESS The ``routine`` parameter was NULL.
+ * @retval ::RTEMS_INVALID_ID There was no interrupt vector associated with the
+ * number specified by ``vector``.
+rtems_status_code bsp_interrupt_check_and_lock(
+ rtems_vector_number vector,
+ rtems_interrupt_handler handler
* @brief This table contains a bit map which indicates if an entry is unique
* or shared.
diff --git a/bsps/shared/irq/irq-generic.c b/bsps/shared/irq/irq-generic.c
index a7e8c1163f..59963182ab 100644
--- a/bsps/shared/irq/irq-generic.c
+++ b/bsps/shared/irq/irq-generic.c
@@ -122,6 +122,32 @@ static inline bool bsp_interrupt_allocate_handler_index(
#endif
+ if ( !bsp_interrupt_is_initialized() ) {
+ return RTEMS_INCORRECT_STATE;
+ if ( handler == NULL ) {
+ return RTEMS_INVALID_ADDRESS;
+ if ( !bsp_interrupt_is_valid_vector( vector ) ) {
+ return RTEMS_INVALID_ID;
+ if ( rtems_interrupt_is_in_progress() ) {
+ return RTEMS_CALLED_FROM_ISR;
+ bsp_interrupt_lock();
+ return RTEMS_SUCCESSFUL;
void bsp_interrupt_initialize(void)
rtems_status_code sc = RTEMS_SUCCESSFUL;
@@ -162,25 +188,18 @@ static rtems_status_code bsp_interrupt_handler_install(
void *arg
+ rtems_status_code sc;
rtems_interrupt_level level;
rtems_vector_number index = 0;
rtems_interrupt_entry *head = NULL;
bool enable_vector = false;
bool replace = RTEMS_INTERRUPT_IS_REPLACE(options);
- /* Check parameters and system state */
- if (!bsp_interrupt_is_initialized()) {
- return RTEMS_INTERNAL_ERROR;
- } else if (!bsp_interrupt_is_valid_vector(vector)) {
- return RTEMS_INVALID_ID;
- } else if (handler == NULL) {
- return RTEMS_INVALID_ADDRESS;
- } else if (rtems_interrupt_is_in_progress()) {
- return RTEMS_CALLED_FROM_ISR;
+ sc = bsp_interrupt_check_and_lock( vector, handler );
- /* Lock */
- bsp_interrupt_lock();
+ if ( sc != RTEMS_SUCCESSFUL ) {
+ return sc;
/* Get handler table index */
index = bsp_interrupt_handler_index(vector);
@@ -325,6 +344,7 @@ static rtems_status_code bsp_interrupt_handler_remove(
void *arg
@@ -332,19 +352,11 @@ static rtems_status_code bsp_interrupt_handler_remove(
rtems_interrupt_entry *previous = NULL;
rtems_interrupt_entry *match = NULL;
- /* Lock */
+ return sc;
diff --git a/bsps/shared/irq/irq-handler-iterate.c b/bsps/shared/irq/irq-handler-iterate.c
index 3c642b075e..385cb8db2d 100644
--- a/bsps/shared/irq/irq-handler-iterate.c
+++ b/bsps/shared/irq/irq-handler-iterate.c
@@ -36,39 +36,26 @@
#include <bsp/irq-generic.h>
- * @brief Iterates over all installed interrupt handler of a vector.
- * @ingroup bsp_interrupt
- * @return In addition to the standard status codes this function returns
- * RTEMS_INTERNAL_ERROR if the BSP interrupt support is not initialized.
- * @see rtems_interrupt_handler_iterate().
-static rtems_status_code bsp_interrupt_handler_iterate(
- rtems_vector_number vector,
+rtems_status_code rtems_interrupt_handler_iterate(
rtems_interrupt_per_handler_routine routine,
- void *arg
+ void *arg
- rtems_interrupt_entry *current = NULL;
- rtems_option options = 0;
- rtems_vector_number index = 0;
+ rtems_vector_number index;
+ rtems_option options;
+ rtems_interrupt_entry *current;
+ vector,
+ (rtems_interrupt_handler) routine
- /* Lock */
+ return sc;
- /* Interate */
current = &bsp_interrupt_handler_table [index];
if (!bsp_interrupt_is_empty_handler_entry(current)) {
@@ -80,17 +67,7 @@ static rtems_status_code bsp_interrupt_handler_iterate(
} while (current != NULL);
- /* Unlock */
bsp_interrupt_unlock();
-rtems_status_code rtems_interrupt_handler_iterate(
- rtems_interrupt_per_handler_routine routine,
- void *arg
- return bsp_interrupt_handler_iterate(vector, routine, arg);
2.26.2
