[PATCH v3 33/42] validation: Test rtems_interrupt_vector_enable()
Fri Jul 23 13:56:41 UTC 2021
Update #3269.
 .../testsuites/validation/validation-0.yml    |   1 +
 testsuites/validation/tc-intr-vector-enable.c | 638 ++++++++++++++++++
 2 files changed, 639 insertions(+)
 create mode 100644 testsuites/validation/tc-intr-vector-enable.c
diff --git a/spec/build/testsuites/validation/validation-0.yml b/spec/build/testsuites/validation/validation-0.yml
index 0fbd4d808f..36d2a0f388 100644
--- a/spec/build/testsuites/validation/validation-0.yml
+++ b/spec/build/testsuites/validation/validation-0.yml
@@ -16,6 +16,7 @@ source:
 - testsuites/validation/tc-barrier-release.c
 - testsuites/validation/tc-barrier-wait.c
 - testsuites/validation/tc-intr-get-attributes.c
+- testsuites/validation/tc-intr-vector-enable.c
 - testsuites/validation/tc-intr-vector-is-enabled.c
 - testsuites/validation/tc-message-construct-errors.c
 - testsuites/validation/tc-object.c
diff --git a/testsuites/validation/tc-intr-vector-enable.c b/testsuites/validation/tc-intr-vector-enable.c
new file mode 100644
index 0000000000..76e1bd0191
--- /dev/null
+++ b/testsuites/validation/tc-intr-vector-enable.c
@@ -0,0 +1,638 @@
+ * @file
+ * @ingroup RTEMSTestCaseRtemsIntrReqVectorEnable
+ * Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * This file is part of the RTEMS quality process and was automatically
+ * generated.  If you find something that needs to be fixed or
+ * worded better please post a report or patch to an RTEMS mailing list
+ * or raise a bug report:
+ * https://www.rtems.org/bugs.html
+ * For information on updating and regenerating please refer to the How-To
+ * section in the Software Requirements Engineering chapter of the
+ * RTEMS Software Engineering manual.  The manual is provided as a part of
+ * a release.  For development sources please refer to the online
+ * documentation at:
+ * https://docs.rtems.org
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <string.h>
+#include <bsp/irq-generic.h>
+#include <rtems/irq-extension.h>
+#include "tx-support.h"
+#include <rtems/test.h>
+ * @defgroup RTEMSTestCaseRtemsIntrReqVectorEnable \
+ *   spec:/rtems/intr/req/vector-enable
+ * @ingroup RTEMSTestSuiteTestsuitesValidation0
+typedef enum {
+  RtemsIntrReqVectorEnable_Pre_Vector_Valid,
+  RtemsIntrReqVectorEnable_Pre_Vector_Invalid,
+  RtemsIntrReqVectorEnable_Pre_Vector_NA
+} RtemsIntrReqVectorEnable_Pre_Vector;
+typedef enum {
+  RtemsIntrReqVectorEnable_Pre_IsEnabled_Yes,
+  RtemsIntrReqVectorEnable_Pre_IsEnabled_No,
+  RtemsIntrReqVectorEnable_Pre_IsEnabled_NA
+} RtemsIntrReqVectorEnable_Pre_IsEnabled;
+typedef enum {
+  RtemsIntrReqVectorEnable_Pre_CanEnable_Yes,
+  RtemsIntrReqVectorEnable_Pre_CanEnable_Maybe,
+  RtemsIntrReqVectorEnable_Pre_CanEnable_No,
+  RtemsIntrReqVectorEnable_Pre_CanEnable_NA
+} RtemsIntrReqVectorEnable_Pre_CanEnable;
+typedef enum {
+  RtemsIntrReqVectorEnable_Post_Status_Ok,
+  RtemsIntrReqVectorEnable_Post_Status_InvId,
+  RtemsIntrReqVectorEnable_Post_Status_Unsat,
+  RtemsIntrReqVectorEnable_Post_Status_NA
+} RtemsIntrReqVectorEnable_Post_Status;
+typedef enum {
+  RtemsIntrReqVectorEnable_Post_IsEnabled_Nop,
+  RtemsIntrReqVectorEnable_Post_IsEnabled_Yes,
+  RtemsIntrReqVectorEnable_Post_IsEnabled_Maybe,
+  RtemsIntrReqVectorEnable_Post_IsEnabled_NA
+} RtemsIntrReqVectorEnable_Post_IsEnabled;
+ * @brief Test context for spec:/rtems/intr/req/vector-enable test case.
+typedef struct {
+   * @brief If this member is true, then an interrupt occurred.
+  bool interrupt_occurred;
+   * @brief This member contains the current vector number.
+  rtems_vector_number vector;
+   * @brief If this member is true, then the ``vector`` parameter shall be
+   *   valid.
+  bool valid_vector;
+   * @brief This member may contain the return value of the
+   *   rtems_interrupt_vector_enable() call.
+  rtems_status_code status;
+   * @brief This member defines the pre-condition states for the next action.
+  size_t pcs[ 3 ];
+   * @brief This member indicates if the test action loop is currently
+   *   executed.
+  bool in_action_loop;
+} RtemsIntrReqVectorEnable_Context;
+static RtemsIntrReqVectorEnable_Context
+  RtemsIntrReqVectorEnable_Instance;
+static const char * const RtemsIntrReqVectorEnable_PreDesc_Vector[] = {
+  "Valid",
+  "Invalid",
+  "NA"
+static const char * const RtemsIntrReqVectorEnable_PreDesc_IsEnabled[] = {
+  "Yes",
+  "No",
+  "NA"
+static const char * const RtemsIntrReqVectorEnable_PreDesc_CanEnable[] = {
+  "Yes",
+  "Maybe",
+  "No",
+  "NA"
+static const char * const * const RtemsIntrReqVectorEnable_PreDesc[] = {
+  RtemsIntrReqVectorEnable_PreDesc_Vector,
+  RtemsIntrReqVectorEnable_PreDesc_IsEnabled,
+  RtemsIntrReqVectorEnable_PreDesc_CanEnable,
+  NULL
+typedef RtemsIntrReqVectorEnable_Context Context;
+static bool IsEnabled( const Context *ctx )
+  rtems_status_code sc;
+  bool              enabled;
+  enabled = false;
+  sc = rtems_interrupt_vector_is_enabled( ctx->vector, &enabled );
+  T_rsc_success( sc );
+  return enabled;
+static void Enable( const Context *ctx )
+  sc = rtems_interrupt_vector_enable( ctx->vector );
+static void Disable( const Context *ctx )
+  sc = rtems_interrupt_vector_disable( ctx->vector );
+static void EntryRoutine( void *arg )
+  Context *ctx;
+  (void) arg;
+  ctx = T_fixture_context();
+  T_true( IsEnabled( ctx ) );
+  Enable( ctx );
+  Disable( ctx );
+  T_false( IsEnabled( ctx ) );
+  ctx->interrupt_occurred = true;
+static void CheckUnsatisfied( const Context *ctx )
+  bool              enabled_before;
+  bool              enabled_after;
+  enabled_before = true;
+  sc = rtems_interrupt_vector_is_enabled( ctx->vector, &enabled_before );
+  T_rsc( sc, RTEMS_UNSATISFIED );
+  enabled_after = !enabled_before;
+  sc = rtems_interrupt_vector_is_enabled( ctx->vector, &enabled_after );
+  T_eq( enabled_before, enabled_after );
+static void CheckVectorEnable(
+  Context                          *ctx,
+  const rtems_interrupt_attributes *attr,
+  bool                              has_installed_entries
+  if ( !attr->maybe_enable ) {
+    CheckUnsatisfied( ctx );
+  } else if ( has_installed_entries ) {
+    if ( attr->can_disable ) {
+      Disable( ctx );
+    Enable( ctx );
+  } else if ( attr->is_maskable && attr->can_disable ) {
+    rtems_interrupt_entry entry;
+    bool                  enabled;
+    ctx->interrupt_occurred = false;
+    rtems_interrupt_entry_initialize( &entry, EntryRoutine, ctx, "Info" );
+    sc = rtems_interrupt_entry_install(
+      ctx->vector,
+      RTEMS_INTERRUPT_UNIQUE,
+      &entry
+      Disable( ctx );
+    Enable( ctx );
+    Enable( ctx );
+    enabled = false;
+    T_true( enabled || ctx->interrupt_occurred || attr->maybe_enable );
+    sc = rtems_interrupt_entry_remove( ctx->vector, &entry );
+    T_true( !attr->can_disable || !IsEnabled( ctx ) );
+static void RtemsIntrReqVectorEnable_Pre_Vector_Prepare(
+  RtemsIntrReqVectorEnable_Context   *ctx,
+  RtemsIntrReqVectorEnable_Pre_Vector state
+  switch ( state ) {
+    case RtemsIntrReqVectorEnable_Pre_Vector_Valid: {
+       * While the ``vector`` parameter is associated with an interrupt vector.
+      ctx->valid_vector = true;
+      break;
+    case RtemsIntrReqVectorEnable_Pre_Vector_Invalid: {
+       * While the ``vector`` parameter is not associated with an interrupt
+       * vector.
+      ctx->valid_vector = false;
+      break;
+    case RtemsIntrReqVectorEnable_Pre_Vector_NA:
+      break;
+static void RtemsIntrReqVectorEnable_Pre_IsEnabled_Prepare(
+  RtemsIntrReqVectorEnable_Pre_IsEnabled state
+    case RtemsIntrReqVectorEnable_Pre_IsEnabled_Yes: {
+       * While the interrupt vector associated with the ``vector`` parameter is
+       * enabled.
+       * This pre-condition depends on the attributes of an interrupt vector,
+       * see CheckVectorEnable().
+      break;
+    case RtemsIntrReqVectorEnable_Pre_IsEnabled_No: {
+       * enabled.
+      break;
+    case RtemsIntrReqVectorEnable_Pre_IsEnabled_NA:
+      break;
+static void RtemsIntrReqVectorEnable_Pre_CanEnable_Prepare(
+  RtemsIntrReqVectorEnable_Pre_CanEnable state
+    case RtemsIntrReqVectorEnable_Pre_CanEnable_Yes: {
+       * can be enabled.
+      break;
+    case RtemsIntrReqVectorEnable_Pre_CanEnable_Maybe: {
+       * may be enabled.
+      break;
+    case RtemsIntrReqVectorEnable_Pre_CanEnable_No: {
+       * cannot be enabled.
+      break;
+    case RtemsIntrReqVectorEnable_Pre_CanEnable_NA:
+      break;
+static void RtemsIntrReqVectorEnable_Post_Status_Check(
+  RtemsIntrReqVectorEnable_Post_Status state
+    case RtemsIntrReqVectorEnable_Post_Status_Ok: {
+       * The return status of rtems_interrupt_vector_enable() shall be
+       * RTEMS_SUCCESSFUL.
+       * Validation is done by CheckVectorEnable() for each interrupt
+       * vector.
+      break;
+    case RtemsIntrReqVectorEnable_Post_Status_InvId: {
+       * RTEMS_INVALID_ID.
+      T_rsc( ctx->status, RTEMS_INVALID_ID );
+      break;
+    case RtemsIntrReqVectorEnable_Post_Status_Unsat: {
+       * RTEMS_UNSATISFIED.
+       * vector.
+      break;
+    case RtemsIntrReqVectorEnable_Post_Status_NA:
+      break;
+static void RtemsIntrReqVectorEnable_Post_IsEnabled_Check(
+  RtemsIntrReqVectorEnable_Post_IsEnabled state
+    case RtemsIntrReqVectorEnable_Post_IsEnabled_Nop: {
+       * The enabled status of the interrupt vector specified by ``vector``
+       * shall not be modified by the rtems_interrupt_vector_enable() call.
+       * Validation is done by CheckUnsatisfied() for each interrupt
+       * vector which cannot be enabled.
+      break;
+    case RtemsIntrReqVectorEnable_Post_IsEnabled_Yes: {
+       * The interrupt vector specified by ``vector`` shall be enabled.
+       * vector.
+      break;
+    case RtemsIntrReqVectorEnable_Post_IsEnabled_Maybe: {
+       * The interrupt vector specified by ``vector`` may be enabled.
+       * vector.
+      break;
+    case RtemsIntrReqVectorEnable_Post_IsEnabled_NA:
+      break;
+static void RtemsIntrReqVectorEnable_Action(
+  if ( ctx->valid_vector ) {
+    for (
+      ctx->vector = 0;
+      ctx->vector < BSP_INTERRUPT_VECTOR_COUNT;
+      ++ctx->vector
+      rtems_interrupt_attributes attr;
+      bool                       has_installed_entries;
+      memset( &attr, 0, sizeof( attr ) );
+      sc = rtems_interrupt_get_attributes( ctx->vector, &attr );
+      if ( sc == RTEMS_INVALID_ID ) {
+        continue;
+      has_installed_entries = HasInterruptVectorEntriesInstalled( ctx->vector );
+      CheckVectorEnable( ctx, &attr, has_installed_entries );
+  } else {
+    ctx->vector = BSP_INTERRUPT_VECTOR_COUNT;
+    ctx->status = rtems_interrupt_vector_enable( ctx->vector );
+typedef struct {
+  uint8_t Skip : 1;
+  uint8_t Pre_Vector_NA : 1;
+  uint8_t Pre_IsEnabled_NA : 1;
+  uint8_t Pre_CanEnable_NA : 1;
+  uint8_t Post_Status : 2;
+  uint8_t Post_IsEnabled : 2;
+} RtemsIntrReqVectorEnable_Entry;
+static const RtemsIntrReqVectorEnable_Entry
+RtemsIntrReqVectorEnable_Entries[] = {
+  { 0, 0, 1, 1, RtemsIntrReqVectorEnable_Post_Status_InvId,
+    RtemsIntrReqVectorEnable_Post_IsEnabled_NA },
+  { 0, 0, 0, 0, RtemsIntrReqVectorEnable_Post_Status_Ok,
+    RtemsIntrReqVectorEnable_Post_IsEnabled_Yes },
+    RtemsIntrReqVectorEnable_Post_IsEnabled_Maybe },
+  { 0, 0, 0, 0, RtemsIntrReqVectorEnable_Post_Status_Unsat,
+    RtemsIntrReqVectorEnable_Post_IsEnabled_Nop }
+static const uint8_t
+RtemsIntrReqVectorEnable_Map[] = {
+  1, 2, 3, 1, 2, 3, 0, 0, 0, 0, 0, 0
+static size_t RtemsIntrReqVectorEnable_Scope( void *arg, char *buf, size_t n )
+  RtemsIntrReqVectorEnable_Context *ctx;
+  ctx = arg;
+  if ( ctx->in_action_loop ) {
+    return T_get_scope( RtemsIntrReqVectorEnable_PreDesc, buf, n, ctx->pcs );
+  return 0;
+static T_fixture RtemsIntrReqVectorEnable_Fixture = {
+  .setup = NULL,
+  .stop = NULL,
+  .teardown = NULL,
+  .scope = RtemsIntrReqVectorEnable_Scope,
+  .initial_context = &RtemsIntrReqVectorEnable_Instance
+static inline RtemsIntrReqVectorEnable_Entry RtemsIntrReqVectorEnable_GetEntry(
+  size_t index
+  return RtemsIntrReqVectorEnable_Entries[
+    RtemsIntrReqVectorEnable_Map[ index ]
+ * @fn void T_case_body_RtemsIntrReqVectorEnable( void )
+T_TEST_CASE_FIXTURE(
+  RtemsIntrReqVectorEnable,
+  &RtemsIntrReqVectorEnable_Fixture
+  size_t index;
+  ctx->in_action_loop = true;
+  index = 0;
+  for (
+    ctx->pcs[ 0 ] = RtemsIntrReqVectorEnable_Pre_Vector_Valid;
+    ctx->pcs[ 0 ] < RtemsIntrReqVectorEnable_Pre_Vector_NA;
+    ++ctx->pcs[ 0 ]
+    for (
+      ctx->pcs[ 1 ] = RtemsIntrReqVectorEnable_Pre_IsEnabled_Yes;
+      ctx->pcs[ 1 ] < RtemsIntrReqVectorEnable_Pre_IsEnabled_NA;
+      ++ctx->pcs[ 1 ]
+      for (
+        ctx->pcs[ 2 ] = RtemsIntrReqVectorEnable_Pre_CanEnable_Yes;
+        ctx->pcs[ 2 ] < RtemsIntrReqVectorEnable_Pre_CanEnable_NA;
+        ++ctx->pcs[ 2 ]
+        RtemsIntrReqVectorEnable_Entry entry;
+        size_t pcs[ 3 ];
+        entry = RtemsIntrReqVectorEnable_GetEntry( index );
+        ++index;
+        memcpy( pcs, ctx->pcs, sizeof( pcs ) );
+        if ( entry.Pre_IsEnabled_NA ) {
+          ctx->pcs[ 1 ] = RtemsIntrReqVectorEnable_Pre_IsEnabled_NA;
+        if ( entry.Pre_CanEnable_NA ) {
+          ctx->pcs[ 2 ] = RtemsIntrReqVectorEnable_Pre_CanEnable_NA;
+        RtemsIntrReqVectorEnable_Pre_Vector_Prepare( ctx, ctx->pcs[ 0 ] );
+        RtemsIntrReqVectorEnable_Pre_IsEnabled_Prepare( ctx, ctx->pcs[ 1 ] );
+        RtemsIntrReqVectorEnable_Pre_CanEnable_Prepare( ctx, ctx->pcs[ 2 ] );
+        RtemsIntrReqVectorEnable_Action( ctx );
+        RtemsIntrReqVectorEnable_Post_Status_Check( ctx, entry.Post_Status );
+        RtemsIntrReqVectorEnable_Post_IsEnabled_Check(
+          ctx,
+          entry.Post_IsEnabled
+        memcpy( ctx->pcs, pcs, sizeof( ctx->pcs ) );
2.26.2
