[PATCH v3 31/42] validation: Test rtems_interrupt_get_attributes()
Fri Jul 23 13:56:39 UTC 2021
Update #3269.
 .../testsuites/validation/validation-0.yml    |   1 +
 .../validation/tc-intr-get-attributes.c       | 440 ++++++++++++++++++
 2 files changed, 441 insertions(+)
 create mode 100644 testsuites/validation/tc-intr-get-attributes.c
diff --git a/spec/build/testsuites/validation/validation-0.yml b/spec/build/testsuites/validation/validation-0.yml
index 653872320c..4e8ecfe1a0 100644
--- a/spec/build/testsuites/validation/validation-0.yml
+++ b/spec/build/testsuites/validation/validation-0.yml
@@ -15,6 +15,7 @@ source:
 - testsuites/validation/tc-barrier-delete.c
 - testsuites/validation/tc-barrier-release.c
 - testsuites/validation/tc-barrier-wait.c
+- testsuites/validation/tc-intr-get-attributes.c
 - testsuites/validation/tc-message-construct-errors.c
 - testsuites/validation/tc-object.c
 - testsuites/validation/tc-signal-catch.c
diff --git a/testsuites/validation/tc-intr-get-attributes.c b/testsuites/validation/tc-intr-get-attributes.c
new file mode 100644
index 0000000000..16860a08cd
--- /dev/null
+++ b/testsuites/validation/tc-intr-get-attributes.c
@@ -0,0 +1,440 @@
+ * @file
+ * @ingroup RTEMSTestCaseRtemsIntrReqGetAttributes
+ * Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * This file is part of the RTEMS quality process and was automatically
+ * generated.  If you find something that needs to be fixed or
+ * worded better please post a report or patch to an RTEMS mailing list
+ * or raise a bug report:
+ * https://www.rtems.org/bugs.html
+ * For information on updating and regenerating please refer to the How-To
+ * section in the Software Requirements Engineering chapter of the
+ * RTEMS Software Engineering manual.  The manual is provided as a part of
+ * a release.  For development sources please refer to the online
+ * documentation at:
+ * https://docs.rtems.org
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <string.h>
+#include <bsp/irq-generic.h>
+#include <rtems/irq-extension.h>
+#include <rtems/test.h>
+ * @defgroup RTEMSTestCaseRtemsIntrReqGetAttributes \
+ *   spec:/rtems/intr/req/get-attributes
+ * @ingroup RTEMSTestSuiteTestsuitesValidation0
+typedef enum {
+  RtemsIntrReqGetAttributes_Pre_Vector_Valid,
+  RtemsIntrReqGetAttributes_Pre_Vector_Invalid,
+  RtemsIntrReqGetAttributes_Pre_Vector_NA
+} RtemsIntrReqGetAttributes_Pre_Vector;
+typedef enum {
+  RtemsIntrReqGetAttributes_Pre_Attributes_Obj,
+  RtemsIntrReqGetAttributes_Pre_Attributes_Null,
+  RtemsIntrReqGetAttributes_Pre_Attributes_NA
+} RtemsIntrReqGetAttributes_Pre_Attributes;
+typedef enum {
+  RtemsIntrReqGetAttributes_Post_Status_Ok,
+  RtemsIntrReqGetAttributes_Post_Status_InvAddr,
+  RtemsIntrReqGetAttributes_Post_Status_InvId,
+  RtemsIntrReqGetAttributes_Post_Status_NA
+} RtemsIntrReqGetAttributes_Post_Status;
+typedef enum {
+  RtemsIntrReqGetAttributes_Post_Attributes_Nop,
+  RtemsIntrReqGetAttributes_Post_Attributes_Zero,
+  RtemsIntrReqGetAttributes_Post_Attributes_Set,
+  RtemsIntrReqGetAttributes_Post_Attributes_NA
+} RtemsIntrReqGetAttributes_Post_Attributes;
+ * @brief Test context for spec:/rtems/intr/req/get-attributes test case.
+typedef struct {
+   * @brief This member provides the rtems_interrupt_attributes object.
+  rtems_interrupt_attributes attributes_obj;
+   * @brief If this member is true, then the ``vector`` parameter shall be
+   *   valid.
+  bool valid_vector;
+   * @brief This member specifies if the ``attributes`` parameter value.
+  rtems_interrupt_attributes *attributes;;
+   * @brief This member contains the return value of the
+   *   rtems_interrupt_get_attributes() call.
+  rtems_status_code status;
+   * @brief This member defines the pre-condition states for the next action.
+  size_t pcs[ 2 ];
+   * @brief This member indicates if the test action loop is currently
+   *   executed.
+  bool in_action_loop;
+} RtemsIntrReqGetAttributes_Context;
+static RtemsIntrReqGetAttributes_Context
+  RtemsIntrReqGetAttributes_Instance;
+static const char * const RtemsIntrReqGetAttributes_PreDesc_Vector[] = {
+  "Valid",
+  "Invalid",
+  "NA"
+static const char * const RtemsIntrReqGetAttributes_PreDesc_Attributes[] = {
+  "Obj",
+  "Null",
+  "NA"
+static const char * const * const RtemsIntrReqGetAttributes_PreDesc[] = {
+  RtemsIntrReqGetAttributes_PreDesc_Vector,
+  RtemsIntrReqGetAttributes_PreDesc_Attributes,
+  NULL
+static void RtemsIntrReqGetAttributes_Pre_Vector_Prepare(
+  RtemsIntrReqGetAttributes_Context   *ctx,
+  RtemsIntrReqGetAttributes_Pre_Vector state
+  switch ( state ) {
+    case RtemsIntrReqGetAttributes_Pre_Vector_Valid: {
+       * While the ``vector`` parameter is associated with an interrupt vector.
+      ctx->valid_vector = true;
+      break;
+    case RtemsIntrReqGetAttributes_Pre_Vector_Invalid: {
+       * While the ``vector`` parameter is not associated with an interrupt
+       * vector.
+      ctx->valid_vector = false;
+      break;
+    case RtemsIntrReqGetAttributes_Pre_Vector_NA:
+      break;
+static void RtemsIntrReqGetAttributes_Pre_Attributes_Prepare(
+  RtemsIntrReqGetAttributes_Pre_Attributes state
+    case RtemsIntrReqGetAttributes_Pre_Attributes_Obj: {
+       * While the ``attributes`` parameter references an object of type
+       * rtems_interrupt_attributes.
+      ctx->attributes = &ctx->attributes_obj;
+      break;
+    case RtemsIntrReqGetAttributes_Pre_Attributes_Null: {
+       * While the ``attributes`` parameter is equal to NULL.
+      ctx->attributes = NULL;
+      break;
+    case RtemsIntrReqGetAttributes_Pre_Attributes_NA:
+      break;
+static void RtemsIntrReqGetAttributes_Post_Status_Check(
+  RtemsIntrReqGetAttributes_Post_Status state
+    case RtemsIntrReqGetAttributes_Post_Status_Ok: {
+       * The return status of rtems_interrupt_get_attributes() shall be
+       * RTEMS_SUCCESSFUL.
+      T_rsc_success( ctx->status );
+      break;
+    case RtemsIntrReqGetAttributes_Post_Status_InvAddr: {
+       * RTEMS_INVALID_ADDRESS.
+      T_rsc( ctx->status, RTEMS_INVALID_ADDRESS );
+      break;
+    case RtemsIntrReqGetAttributes_Post_Status_InvId: {
+       * RTEMS_INVALID_ID.
+      T_rsc( ctx->status, RTEMS_INVALID_ID );
+      break;
+    case RtemsIntrReqGetAttributes_Post_Status_NA:
+      break;
+static void RtemsIntrReqGetAttributes_Post_Attributes_Check(
+  RtemsIntrReqGetAttributes_Post_Attributes state
+  rtems_interrupt_attributes attr;
+    case RtemsIntrReqGetAttributes_Post_Attributes_Nop: {
+       * Objects referenced by the ``attributes`` parameter in past calls to
+       * rtems_interrupt_get_attributes() shall not be accessed by the
+      memset( &attr, 0xa5, sizeof( attr ) );
+      T_eq_mem( &ctx->attributes_obj, &attr, sizeof( attr ) );
+      break;
+    case RtemsIntrReqGetAttributes_Post_Attributes_Zero: {
+       * The object referenced by the ``attributes`` parameter shall cleared to
+       * zero.
+      memset( &attr, 0, sizeof( attr ) );
+      break;
+    case RtemsIntrReqGetAttributes_Post_Attributes_Set: {
+       * The members of the object referenced by the ``attributes`` parameter
+       * shall be set to the attributes of the interrupt vector specified by
+       * ``vector``.
+      T_ne_mem( &ctx->attributes_obj, &attr, sizeof( attr ) );
+      break;
+    case RtemsIntrReqGetAttributes_Post_Attributes_NA:
+      break;
+static void RtemsIntrReqGetAttributes_Prepare(
+  memset( &ctx->attributes_obj, 0xa5, sizeof( ctx->attributes_obj ) );
+static void RtemsIntrReqGetAttributes_Action(
+  rtems_vector_number vector;
+  if ( ctx->valid_vector && ctx->attributes != NULL ) {
+    ctx->status = RTEMS_INTERNAL_ERROR;
+    for ( vector = 0; vector < BSP_INTERRUPT_VECTOR_COUNT; ++vector ) {
+      rtems_status_code sc;
+      memset( &ctx->attributes_obj, 0xff, sizeof( ctx->attributes_obj ) );
+      sc = rtems_interrupt_get_attributes( vector, ctx->attributes );
+      if ( sc == RTEMS_INVALID_ID ) {
+        continue;
+      T_rsc_success( sc );
+      ctx->status = sc;
+      if ( ctx->attributes_obj.can_enable ) {
+        T_true( ctx->attributes_obj.maybe_enable );
+      if ( ctx->attributes_obj.can_disable ) {
+        T_true( ctx->attributes_obj.maybe_disable );
+        T_true(
+          ctx->attributes_obj.can_enable || ctx->attributes_obj.maybe_enable
+  } else {
+    if ( ctx->valid_vector ) {
+      vector = 0;
+    } else {
+      vector = BSP_INTERRUPT_VECTOR_COUNT;
+    ctx->status = rtems_interrupt_get_attributes( vector, ctx->attributes );
+typedef struct {
+  uint8_t Skip : 1;
+  uint8_t Pre_Vector_NA : 1;
+  uint8_t Pre_Attributes_NA : 1;
+  uint8_t Post_Status : 2;
+  uint8_t Post_Attributes : 2;
+} RtemsIntrReqGetAttributes_Entry;
+static const RtemsIntrReqGetAttributes_Entry
+RtemsIntrReqGetAttributes_Entries[] = {
+  { 0, 0, 0, RtemsIntrReqGetAttributes_Post_Status_InvAddr,
+    RtemsIntrReqGetAttributes_Post_Attributes_Nop },
+  { 0, 0, 0, RtemsIntrReqGetAttributes_Post_Status_Ok,
+    RtemsIntrReqGetAttributes_Post_Attributes_Set },
+  { 0, 0, 0, RtemsIntrReqGetAttributes_Post_Status_InvId,
+    RtemsIntrReqGetAttributes_Post_Attributes_Zero }
+static const uint8_t
+RtemsIntrReqGetAttributes_Map[] = {
+  1, 0, 2, 0
+static size_t RtemsIntrReqGetAttributes_Scope( void *arg, char *buf, size_t n )
+  RtemsIntrReqGetAttributes_Context *ctx;
+  ctx = arg;
+  if ( ctx->in_action_loop ) {
+    return T_get_scope( RtemsIntrReqGetAttributes_PreDesc, buf, n, ctx->pcs );
+  return 0;
+static T_fixture RtemsIntrReqGetAttributes_Fixture = {
+  .setup = NULL,
+  .stop = NULL,
+  .teardown = NULL,
+  .scope = RtemsIntrReqGetAttributes_Scope,
+  .initial_context = &RtemsIntrReqGetAttributes_Instance
+static inline RtemsIntrReqGetAttributes_Entry
+RtemsIntrReqGetAttributes_GetEntry( size_t index )
+  return RtemsIntrReqGetAttributes_Entries[
+    RtemsIntrReqGetAttributes_Map[ index ]
+ * @fn void T_case_body_RtemsIntrReqGetAttributes( void )
+T_TEST_CASE_FIXTURE(
+  RtemsIntrReqGetAttributes,
+  &RtemsIntrReqGetAttributes_Fixture
+  size_t index;
+  ctx = T_fixture_context();
+  ctx->in_action_loop = true;
+  index = 0;
+  for (
+    ctx->pcs[ 0 ] = RtemsIntrReqGetAttributes_Pre_Vector_Valid;
+    ctx->pcs[ 0 ] < RtemsIntrReqGetAttributes_Pre_Vector_NA;
+    ++ctx->pcs[ 0 ]
+    for (
+      ctx->pcs[ 1 ] = RtemsIntrReqGetAttributes_Pre_Attributes_Obj;
+      ctx->pcs[ 1 ] < RtemsIntrReqGetAttributes_Pre_Attributes_NA;
+      ++ctx->pcs[ 1 ]
+      RtemsIntrReqGetAttributes_Entry entry;
+      entry = RtemsIntrReqGetAttributes_GetEntry( index );
+      ++index;
+      RtemsIntrReqGetAttributes_Prepare( ctx );
+      RtemsIntrReqGetAttributes_Pre_Vector_Prepare( ctx, ctx->pcs[ 0 ] );
+      RtemsIntrReqGetAttributes_Pre_Attributes_Prepare( ctx, ctx->pcs[ 1 ] );
+      RtemsIntrReqGetAttributes_Action( ctx );
+      RtemsIntrReqGetAttributes_Post_Status_Check( ctx, entry.Post_Status );
+      RtemsIntrReqGetAttributes_Post_Attributes_Check(
+        ctx,
+        entry.Post_Attributes
2.26.2
