[PATCH v3 19/42] bsps/irq: Implement new directives for GICv2/3
Gedare Bloom
gedare at rtems.org
Fri Jul 23 15:03:43 UTC 2021
On Fri, Jul 23, 2021 at 7:58 AM Sebastian Huber
> Update #3269.
> bsps/aarch64/a53/include/bsp/irq.h | 2 +-
> bsps/include/dev/irq/arm-gic-irq.h | 3 +
> bsps/shared/dev/irq/arm-gicv2.c | 87 +++++++++++++++----
> bsps/shared/dev/irq/arm-gicv3.c | 129 +++++++++++++++++++++++++----
> 4 files changed, 189 insertions(+), 32 deletions(-)
> diff --git a/bsps/aarch64/a53/include/bsp/irq.h b/bsps/aarch64/a53/include/bsp/irq.h
> index b797408ca5..e0cc6a6026 100644
> --- a/bsps/aarch64/a53/include/bsp/irq.h
> +++ b/bsps/aarch64/a53/include/bsp/irq.h
> @@ -48,7 +48,7 @@
> extern "C" {
> #endif /* __cplusplus */
> -#define BSP_INTERRUPT_VECTOR_COUNT 1024
> +#define BSP_INTERRUPT_VECTOR_COUNT 256
> /* Interrupts vectors */
> #define BSP_TIMER_VIRT_PPI 27
> diff --git a/bsps/include/dev/irq/arm-gic-irq.h b/bsps/include/dev/irq/arm-gic-irq.h
> index 68e0247fd8..398fd8bceb 100644
> --- a/bsps/include/dev/irq/arm-gic-irq.h
> +++ b/bsps/include/dev/irq/arm-gic-irq.h
> @@ -46,6 +46,9 @@ extern "C" {
> #define ARM_GIC_IRQ_SGI_13 13
> #define ARM_GIC_IRQ_SGI_14 14
> #define ARM_GIC_IRQ_SGI_15 15
> +#define ARM_GIC_IRQ_SGI_LAST 15
> +#define ARM_GIC_IRQ_PPI_LAST 31
> #define ARM_GIC_DIST ((volatile gic_dist *) BSP_ARM_GIC_DIST_BASE)
> diff --git a/bsps/shared/dev/irq/arm-gicv2.c b/bsps/shared/dev/irq/arm-gicv2.c
> index 8372d0f191..eaae6124e8 100644
> --- a/bsps/shared/dev/irq/arm-gicv2.c
> +++ b/bsps/shared/dev/irq/arm-gicv2.c
> @@ -1,5 +1,5 @@
> - * Copyright (c) 2013, 2019 embedded brains GmbH. All rights reserved.
> + * Copyright (c) 2013, 2021 embedded brains GmbH. All rights reserved.
> * embedded brains GmbH
> * Dornierstr. 4
> @@ -69,6 +69,32 @@ rtems_status_code bsp_interrupt_get_attributes(
> rtems_interrupt_attributes *attributes
> + attributes->is_maskable = true;
> + attributes->maybe_enable = true;
> + attributes->maybe_disable = true;
> + attributes->can_raise = true;
> + if ( vector <= ARM_GIC_IRQ_SGI_LAST ) {
> + * It is implementation-defined whether implemented SGIs are permanently
> + * enabled, or can be enabled and disabled by writes to GICD_ISENABLER0 and
> + * GICD_ICENABLER0.
> + attributes->can_raise_on = true;
> + attributes->cleared_by_acknowledge = true;
> + attributes->trigger_signal = RTEMS_INTERRUPT_NO_SIGNAL;
> + } else {
> + attributes->can_disable = true;
> + attributes->can_clear = true;
> + attributes->trigger_signal = RTEMS_INTERRUPT_UNSPECIFIED_SIGNAL;
> + if ( vector > ARM_GIC_IRQ_PPI_LAST ) {
> + /* SPI */
> + attributes->can_get_affinity = true;
> + attributes->can_set_affinity = true;
> return RTEMS_SUCCESSFUL;
> @@ -77,16 +103,25 @@ rtems_status_code bsp_interrupt_is_pending(
> bool *pending
> - bsp_interrupt_assert(bsp_interrupt_is_valid_vector(vector));
> - bsp_interrupt_assert(pending != NULL);
> - *pending = false;
> - return RTEMS_UNSATISFIED;
> + volatile gic_dist *dist = ARM_GIC_DIST;
> + *pending = gic_id_is_pending(dist, vector);
> + return RTEMS_SUCCESSFUL;
> rtems_status_code bsp_interrupt_raise(rtems_vector_number vector)
> + if (vector <= ARM_GIC_IRQ_SGI_LAST) {
> + arm_gic_trigger_sgi(vector, 1U << _SMP_Get_current_processor());
> + } else {
> + gic_id_set_pending(dist, vector);
> #if defined(RTEMS_SMP)
> @@ -95,15 +130,27 @@ rtems_status_code bsp_interrupt_raise_on(
> uint32_t cpu_index
> + if (vector >= 16) {
> + return RTEMS_UNSATISFIED;
> + arm_gic_trigger_sgi(vector, 1U << cpu_index);
> #endif
> rtems_status_code bsp_interrupt_clear(rtems_vector_number vector)
> + gic_id_clear_pending(dist, vector);
> rtems_status_code bsp_interrupt_vector_is_enabled(
> @@ -111,10 +158,13 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
> bool *enabled
> bsp_interrupt_assert(enabled != NULL);
> - *enabled = false;
> + *enabled = gic_id_is_enabled(dist, vector);
> rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
> @@ -207,8 +257,8 @@ BSP_START_TEXT_SECTION void arm_gic_irq_initialize_secondary_cpu(void)
> dist->icdigr[0] = 0xffffffff;
> #endif
> - /* Initialize Peripheral Private Interrupts (PPIs) */
> - for (id = 0; id < 32; ++id) {
> + /* Initialize priority of SGIs and PPIs */
> + for (id = 0; id <= ARM_GIC_IRQ_PPI_LAST; ++id) {
> gic_id_set_priority(dist, id, PRIORITY_DEFAULT);
> @@ -300,6 +350,10 @@ rtems_status_code bsp_interrupt_set_affinity(
> uint8_t targets = (uint8_t) _Processor_mask_To_uint32_t(affinity, 0);
> + if ( vector <= ARM_GIC_IRQ_PPI_LAST ) {
> gic_id_set_targets(dist, vector, targets);
> @@ -310,8 +364,13 @@ rtems_status_code bsp_interrupt_get_affinity(
> - uint8_t targets = gic_id_get_targets(dist, vector);
> + uint8_t targets;
> + targets = gic_id_get_targets(dist, vector);
> _Processor_mask_From_uint32_t(affinity, targets, 0);
> diff --git a/bsps/shared/dev/irq/arm-gicv3.c b/bsps/shared/dev/irq/arm-gicv3.c
> index 3c1e2f8731..ca282a378d 100644
> --- a/bsps/shared/dev/irq/arm-gicv3.c
> +++ b/bsps/shared/dev/irq/arm-gicv3.c
> @@ -169,6 +169,32 @@ rtems_status_code bsp_interrupt_get_attributes(
> + } else {
> + /* SPI */
> @@ -179,14 +205,39 @@ rtems_status_code bsp_interrupt_is_pending(
> - *pending = false;
> + if (vector <= ARM_GIC_IRQ_PPI_LAST) {
> + volatile gic_sgi_ppi *sgi_ppi =
> + gicv3_get_sgi_ppi(_SMP_Get_current_processor());
> + *pending = (sgi_ppi->icspispendr[0] & (1U << vector)) != 0;
> + } else {
> + } else if (vector <= ARM_GIC_IRQ_PPI_LAST) {
> + sgi_ppi->icspispendr[0] = 1U << vector;
> + } else {
> @@ -195,15 +246,35 @@ rtems_status_code bsp_interrupt_raise_on(
> uint32_t cpu_index
Use (vector > ARM_GIC_IRQ_SGI_LAST) for clarity?
no need to repost for this change.
Should we assert cpu_index <
rtems_configuration_get_maximum_processors()? That would be consistent
with using assert that the vector is valid, since both are handled
when coming in through the rtems_interrupt_*() interface.
> #endif
> + sgi_ppi->icspicpendr[0] = 1U << vector;
> + } else {
> @@ -213,8 +284,19 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
> - *enabled = false;
> + *enabled = (sgi_ppi->icspiser[0] & (1U << vector)) != 0;
> + } else {
> @@ -222,22 +304,24 @@ rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
> - if (vector >= 32) {
> + if (vector > ARM_GIC_IRQ_PPI_LAST) {
> gic_id_enable(dist, vector);
> } else {
> /* Set interrupt group to 1 in the current security mode */
> #if defined(ARM_MULTILIB_ARCH_V4) || defined(AARCH64_IS_NONSECURE)
> - sgi_ppi->icspigrpr[0] |= 1 << (vector % 32);
> - sgi_ppi->icspigrpmodr[0] &= ~(1 << (vector % 32));
> + sgi_ppi->icspigrpr[0] |= 1U << vector;
> + sgi_ppi->icspigrpmodr[0] &= ~(1U << vector);
> #else
> - sgi_ppi->icspigrpr[0] &= ~(1 << (vector % 32));
> - sgi_ppi->icspigrpmodr[0] |= 1 << (vector % 32);
> + sgi_ppi->icspigrpr[0] &= ~(1U << vector);
> + sgi_ppi->icspigrpmodr[0] |= 1U << vector;
> #endif
> /* Set enable */
> - sgi_ppi->icspiser[0] = 1 << (vector % 32);
> + sgi_ppi->icspiser[0] = 1U << vector;
> @@ -247,13 +331,15 @@ rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
> gic_id_disable(dist, vector);
> } else {
> - sgi_ppi->icspicer[0] = 1 << (vector % 32);
> + sgi_ppi->icspicer[0] = 1U << vector;
> @@ -407,6 +493,10 @@ rtems_status_code bsp_interrupt_set_affinity(
> @@ -417,8 +507,13 @@ rtems_status_code bsp_interrupt_get_affinity(
> + uint8_t targets;
> 2.26.2
> devel mailing list
> devel at rtems.org
