[PATCH] closes #3889
zack leung zakthertemsdev at gmail.com
Sun Jul 25 00:10:20 UTC 2021
> -      remaining = 0;
> +      result->tv_nsec=0;
> +      result->tv_sec=0;
This isn't correct. result is an uninitialized pointer.
So then how do  I set the timespec's value to 0? I have changed the
timespec variables i have declared from pointers to regular variables.
in the original code the result ( used to be the remaining time) should be
0.
> +    _TOD_Get(now);
>This isn't correct. now is an uninitialized pointer.  How do you
>compile and run this code? I'm surprised it passes tests with this
>kind of bug.
Since the now timespec is defined as
struct timesepc now
TOD_GET used like this :
_TOD_GET(now)
I think the code will now work as intended as it now has a reference.
> -  ptimer = _POSIX_Timer_Get( timerid, &lock_context );
> -  if ( ptimer != NULL ) {
> -    Per_CPU_Control *cpu;
> +  ptimer = _POSIX_Timer_Get(timerid, &lock_context);
avoid whitespace changes. This change is inconsistent with our coding
conventions.
Can  you explain where the whilespace is?  Sometimes i have issues with
trailing whitespace as sometimes when i run format patch it's different
from the file that I'm working on.
Don't add extra whitespaces. We don't use more than one blank line in
a row in RTEMS C
 Again  I may have to change it manually within the patch file.  I may talk
with people on discord for help to avoid flooding the mailing list.
Also how i solved the  nesting was the completely delete the repository and
then i would rebuilt rtems.  After making a emailed patch how do i do
another one without running into the same problem?
On Fri, 23 Jul 2021 at 22:15, Joel Sherrill <joel at rtems.org> wrote:
> I concur with Gedare's comments.
> I would think your commit message would be similar to the subject of the
> ticket.
> This looks like a decent example:
> https://git.rtems.org/rtems/commit/?id=6c23252cdd8ea63d0fe13d9f99b7befbf070fe80
> Please update and submit. Pay attention to compiler warnings.
> On Fri, Jul 23, 2021 at 12:02 PM Gedare Bloom <gedare at rtems.org> wrote:
> > Hi Zak,
> > Please provide a useful first commit line. I think I've mentioned this
> > before, but the current guidance is found at
> > https://devel.rtems.org/wiki/Developer/Git#GitCommits
> > Put the ticket closing line within the commit message, usually on its
> > own line at the end of your  commit message
> > On Thu, Jul 22, 2021 at 6:29 PM Zacchaeus Leung
> > <zakthertemsdev at gmail.com> wrote:
> > >  cpukit/include/rtems/posix/timer.h |  1 +
> > >  cpukit/posix/src/psxtimercreate.c  |  1 +
> > >  cpukit/posix/src/timergettime.c    | 61 +++++++++++++++++++-----------
> > >  3 files changed, 41 insertions(+), 22 deletions(-)
> > > diff --git a/cpukit/include/rtems/posix/timer.h
> b/cpukit/include/rtems/posix/timer.h
> > > index bcbf07a65a..7ae089173a 100644
> > > --- a/cpukit/include/rtems/posix/timer.h
> > > +++ b/cpukit/include/rtems/posix/timer.h
> > > @@ -48,6 +48,7 @@ typedef struct {
> > >    uint32_t          ticks;      /* Number of ticks of the
> initialization */
> > >    uint32_t          overrun;    /* Number of expirations of the
> timer    */
> > >    struct timespec   time;       /* Time at which the timer was
> started   */
> > > +  clockid_t         clock_type; /* The type of timer */
> > >  } POSIX_Timer_Control;
> > > diff --git a/cpukit/posix/src/psxtimercreate.c
> b/cpukit/posix/src/psxtimercreate.c
> > > index a63cf1d100..804c7a41e7 100644
> > > --- a/cpukit/posix/src/psxtimercreate.c
> > > +++ b/cpukit/posix/src/psxtimercreate.c
> > > @@ -91,6 +91,7 @@ int timer_create(
> > >    ptimer->timer_data.it_value.tv_nsec    = 0;
> > >    ptimer->timer_data.it_interval.tv_sec  = 0;
> > >    ptimer->timer_data.it_interval.tv_nsec = 0;
> > > +  ptimer->clock_type = clock_id;
> > >    _Watchdog_Preinitialize( &ptimer->Timer, _Per_CPU_Get_snapshot() );
> > >    _Watchdog_Initialize( &ptimer->Timer, _POSIX_Timer_TSR );
> > > diff --git a/cpukit/posix/src/timergettime.c
> b/cpukit/posix/src/timergettime.c
> > > index ee2a566f0e..ff2176ac60 100644
> > > --- a/cpukit/posix/src/timergettime.c
> > > +++ b/cpukit/posix/src/timergettime.c
> > > @@ -28,6 +28,7 @@
> > >  #include <rtems/score/todimpl.h>
> > >  #include <rtems/score/watchdogimpl.h>
> > >  #include <rtems/seterr.h>
> > > +#include <rtems/timespec.h>
> > >   *          - When a timer is initialized, the value of the time in
> > > @@ -35,39 +36,55 @@
> > >   *          - When this function is called, it returns the difference
> > >   *            between the current time and the initialization time.
> > avoid random whitespace changes.
> > >  int timer_gettime(
> > >    timer_t            timerid,
> > >    struct itimerspec *value
> > avoid random whitespace changes. I can't even tell what this one changes.
> > >    POSIX_Timer_Control *ptimer;
> > > -  ISR_lock_Context     lock_context;
> > > -  uint64_t             now;
> > > -  uint32_t             remaining;
> > > +  ISR_lock_Context lock_context;
> > > +  uint32_t remaining;
> > > +  Per_CPU_Control *cpu;
> > > +  struct timespec *now;
> > > +  struct timespec *expire;
> > > +  struct timespec *result;
> > > -  if ( !value )
> > > -    rtems_set_errno_and_return_minus_one( EINVAL );
> > > +  if (!value)
> > > +    rtems_set_errno_and_return_minus_one(EINVAL);
> > conventions.
> > conventions.
> > > +  if (ptimer == NULL) {
> > add spaces after ( and before ), e.g.,
> > if ( ptimer == NULL ) {
> > Add spaces around EINVAL
> > > -    cpu = _POSIX_Timer_Acquire_critical( ptimer, &lock_context );
> > > -    now = cpu->Watchdog.ticks;
> > > +  cpu = _POSIX_Timer_Acquire_critical(ptimer, &lock_context);
> > conventions.
> > > +  rtems_timespec_from_ticks(ptimer->Timer.expire, expire);
> > This isn't correct. expire is an uninitialized pointer.  How do you
> > kind of bug.
> > What you should do instead is declare your struct timespec variable
> > and pass a pointer to it, e.g.,
> > struct timespec expire;   <-- put that above
> > rtems_timespec_from_ticks( ptimer->Timer.expire, &expire );
> > don't forget to add spaces after ( and before ). Use & to pass the
> > pointer to the local stack-allocated expire struct.
> > > -    if ( now < ptimer->Timer.expire ) {
> > > -      remaining = (uint32_t) ( ptimer->Timer.expire - now );
> > > +  if (ptimer->clock_type == CLOCK_MONOTONIC) {
> > > +  _Timecounter_Nanouptime(now);
> > kind of bug.
> > Declare now like expire, and pass a pointer to the stack-local variable.
> > > +  if (ptimer-
> > >clock_type == CLOCK_REALTIME) {
> > > +    _TOD_Get(now);
> > kind of bug.
> > > + if( rtems_timespec_less_than( now, expire )) {
> > add space after if and before ) at the end.
> > > +      rtems_timespec_subtract(now, expire, result);
> > This isn't correct. now, expire, and result are uninitialized pointers.
> > Declare result like now and expire, and pass a reference to the
> > >      } else {
> > > -      remaining = 0;
> > > +      result->tv_sec=0;
> > Add spaces around =.
> > > +  (*value).it_value=*result;
> > why using *. instead of -> notation?
> > > +  value->it_interval = ptimer->timer_data.it_interval;
> > > +  _POSIX_Timer_Release(cpu, &lock_context);
> > > +  return 0;
> > a row in RTEMS C Code.
> > > -    _Timespec_From_ticks( remaining, &value->it_value );
> > > -    value->it_interval = ptimer->timer_data.it_interval;
> > > -    _POSIX_Timer_Release( cpu, &lock_context );
> > > -    return 0;
> > > 2.32.0
> > > _______________________________________________
> > > devel mailing list
> > > devel at rtems.org
> > > http://lists.rtems.org/mailman/listinfo/devel
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210725/d223c28b/attachment.html>
