[PATCH rtems-libbsd 3/7] sys/kern: Add lockmgr support
chrisj at rtems.org
chrisj at rtems.org
Tue Jul 27 08:58:47 UTC 2021
- See `man lockmgr`
- Implement the lock_object and move the RTEMS mutex to that object
- Add debug support to track the locks with gdb
Update #4475
freebsd/sys/sys/_lock.h | 10 +-
freebsd/sys/sys/_lockmgr.h | 6 +
freebsd/sys/sys/_mutex.h | 5 -
freebsd/sys/sys/_rwlock.h | 5 -
freebsd/sys/sys/_sx.h | 5 -
rtemsbsd/include/machine/_kernel_lock.h | 2 +-
rtemsbsd/include/machine/rtems-bsd-mutex.h | 8 +-
.../include/machine/rtems-bsd-muteximpl.h | 87 ++-
rtemsbsd/include/machine/rtems-bsd-thread.h | 1 +
rtemsbsd/rtems/rtems-kernel-epoch.c | 2 +-
rtemsbsd/rtems/rtems-kernel-jail.c | 10 +-
rtemsbsd/rtems/rtems-kernel-lockmgr.c | 578 ++++++++++++++++++
rtemsbsd/rtems/rtems-kernel-mutex.c | 21 +-
rtemsbsd/rtems/rtems-kernel-muteximpl.c | 5 +-
rtemsbsd/rtems/rtems-kernel-rwlock.c | 28 +-
rtemsbsd/rtems/rtems-kernel-sx.c | 34 +-
16 files changed, 724 insertions(+), 83 deletions(-)
create mode 100644 rtemsbsd/rtems/rtems-kernel-lockmgr.c
diff --git a/freebsd/sys/sys/_lock.h b/freebsd/sys/sys/_lock.h
index ae10254c..9e3388d5 100644
--- a/freebsd/sys/sys/_lock.h
+++ b/freebsd/sys/sys/_lock.h
@@ -32,15 +32,19 @@
#ifndef _SYS__LOCK_H_
#define _SYS__LOCK_H_
+#ifdef __rtems__
+#include <machine/rtems-bsd-mutex.h>
+#endif /* __rtems__ */
struct lock_object {
-#ifndef __rtems__
const char *lo_name; /* Individual lock name. */
u_int lo_flags;
u_int lo_data; /* General class specific data. */
+#ifndef __rtems__
struct witness *lo_witness; /* Data for witness. */
-#else /* __rtems__ */
- unsigned int lo_flags;
+#ifdef __rtems__
+ rtems_bsd_mutex lo_mtx;
diff --git a/freebsd/sys/sys/_lockmgr.h b/freebsd/sys/sys/_lockmgr.h
index 62e50df1..8e9ac276 100644
--- a/freebsd/sys/sys/_lockmgr.h
+++ b/freebsd/sys/sys/_lockmgr.h
@@ -34,7 +34,9 @@
#define _SYS__LOCKMGR_H_
#ifdef DEBUG_LOCKS
+#ifndef __rtems__
#include <sys/_stack.h>
#endif
struct lock {
@@ -44,7 +46,11 @@ struct lock {
int lk_timo;
int lk_pri;
#ifdef DEBUG_LOCKS
+#ifndef __rtems__
struct stack lk_stack;
+#else /* __rtems__ */
+ void* lk_stack;
#endif
diff --git a/freebsd/sys/sys/_mutex.h b/freebsd/sys/sys/_mutex.h
index 5252aee1..418b62b4 100644
--- a/freebsd/sys/sys/_mutex.h
+++ b/freebsd/sys/sys/_mutex.h
@@ -32,9 +32,6 @@
#ifndef _SYS__MUTEX_H_
#define _SYS__MUTEX_H_
-#ifdef __rtems__
-#include <machine/rtems-bsd-mutex.h>
-#endif /* __rtems__ */
#include <machine/param.h>
@@ -51,8 +48,6 @@ struct mtx {
struct lock_object lock_object; /* Common lock properties. */
#ifndef __rtems__
volatile uintptr_t mtx_lock; /* Owner and flags. */
- rtems_bsd_mutex mutex;
diff --git a/freebsd/sys/sys/_rwlock.h b/freebsd/sys/sys/_rwlock.h
index 318592d5..6110a494 100644
--- a/freebsd/sys/sys/_rwlock.h
+++ b/freebsd/sys/sys/_rwlock.h
@@ -30,9 +30,6 @@
#ifndef _SYS__RWLOCK_H_
#define _SYS__RWLOCK_H_
-#ifdef __rtems__
@@ -49,8 +46,6 @@ struct rwlock {
#ifndef __rtems__
volatile uintptr_t rw_lock;
diff --git a/freebsd/sys/sys/_sx.h b/freebsd/sys/sys/_sx.h
index 328a43a4..d8f86296 100644
--- a/freebsd/sys/sys/_sx.h
+++ b/freebsd/sys/sys/_sx.h
@@ -32,9 +32,6 @@
#ifndef _SYS__SX_H_
#define _SYS__SX_H_
-#ifdef __rtems__
* Shared/exclusive lock main structure definition.
@@ -43,8 +40,6 @@ struct sx {
#ifndef __rtems__
volatile uintptr_t sx_lock;
diff --git a/rtemsbsd/include/machine/_kernel_lock.h b/rtemsbsd/include/machine/_kernel_lock.h
index dc4f8255..32a41cb8 100644
--- a/rtemsbsd/include/machine/_kernel_lock.h
+++ b/rtemsbsd/include/machine/_kernel_lock.h
@@ -35,9 +35,9 @@
#define _MACHINE__KERNEL_LOCK_H_
#include <sys/queue.h>
-#include <sys/_lock.h>
#include <sys/ktr_class.h>
+struct lock_object;
struct lock_list_entry;
struct thread;
diff --git a/rtemsbsd/include/machine/rtems-bsd-mutex.h b/rtemsbsd/include/machine/rtems-bsd-mutex.h
index dd728cdc..54873dc3 100644
--- a/rtemsbsd/include/machine/rtems-bsd-mutex.h
+++ b/rtemsbsd/include/machine/rtems-bsd-mutex.h
@@ -40,16 +40,20 @@
#ifndef _RTEMS_BSD_MACHINE_RTEMS_BSD_MUTEX_H_
#define _RTEMS_BSD_MACHINE_RTEMS_BSD_MUTEX_H_
-#include <rtems/score/thread.h>
+#include <sys/queue.h>
#include <rtems/score/threadq.h>
#ifdef __cplusplus
extern "C" {
#endif /* __cplusplus */
-typedef struct {
+typedef struct rtems_bsd_mutex {
Thread_queue_Control queue;
int nest_level;
+#if RTEMS_DEBUG
+ TAILQ_ENTRY(rtems_bsd_mutex) mutex_list;
+#endif /* RTEMS_DEBUG */
} rtems_bsd_mutex;
#ifdef __cplusplus
diff --git a/rtemsbsd/include/machine/rtems-bsd-muteximpl.h b/rtemsbsd/include/machine/rtems-bsd-muteximpl.h
index b362e524..2e180b97 100644
--- a/rtemsbsd/include/machine/rtems-bsd-muteximpl.h
+++ b/rtemsbsd/include/machine/rtems-bsd-muteximpl.h
@@ -50,6 +50,8 @@
#include <inttypes.h>
+#include <rtems/thread.h>
+#include <rtems/score/thread.h>
@@ -60,17 +62,48 @@ extern "C" {
#define RTEMS_BSD_MUTEX_TQ_OPERATIONS \
&_Thread_queue_Operations_priority_inherit
+#if RTEMS_DEBUG
+ * Resource tracking. In GDB you can:
+ * define mutex-owned
+ * set $m = $arg0
+ * set $c = 0
+ * while $m != 0
+ * set $c = $c + 1
+ * if $m->queue.Queue.owner != 0
+ * printf "%08x %-40s\n", $m->queue.Queue.owner, $m->queue.Queue.name
+ * end
+ * set $m = $m->mutex_list.tqe_next
+ * end
+ * printf "Total: %d\n", $c
+ * end
+ * (gdb) mutex-owned _bsd_bsd_mutexlist->tqh_first
+extern TAILQ_HEAD(bsd_mutex_list, rtems_bsd_mutex) bsd_mutexlist;
+extern rtems_mutex bsd_mutexlist_lock;
static inline void
-rtems_bsd_mutex_init(struct lock_object *lock, rtems_bsd_mutex *m,
- struct lock_class *class, const char *name, const char *type, int flags)
+rtems_bsd_mutex_init(struct lock_object *lk, struct lock_class *class,
+ const char *name, const char *type, int flags)
+ rtems_bsd_mutex *m = &lk->lo_mtx;
_Thread_queue_Initialize(&m->queue, name);
m->nest_level = 0;
- lock_init(lock, class, name, type, flags);
+ lock_init(lk, class, name, type, flags);
+#if RTEMS_DEBUG
+ rtems_mutex_lock(&bsd_mutexlist_lock);
+ TAILQ_INSERT_TAIL(&bsd_mutexlist, m, mutex_list);
+ rtems_mutex_unlock(&bsd_mutexlist_lock);
-void rtems_bsd_mutex_lock_more(struct lock_object *lock, rtems_bsd_mutex *m,
+void rtems_bsd_mutex_lock_more(struct lock_object *lk,
Thread_Control *owner, Thread_Control *executing,
Thread_queue_Context *queue_context);
@@ -117,12 +150,13 @@ rtems_bsd_mutex_set_isr_level(Thread_queue_Context *queue_context,
static inline void
-rtems_bsd_mutex_lock(struct lock_object *lock, rtems_bsd_mutex *m)
+rtems_bsd_mutex_lock(struct lock_object *lk)
ISR_Level isr_level;
Thread_queue_Context queue_context;
Thread_Control *executing;
Thread_Control *owner;
_Thread_queue_Context_initialize(&queue_context);
rtems_bsd_mutex_isr_disable(isr_level, &queue_context);
@@ -137,19 +171,20 @@ rtems_bsd_mutex_lock(struct lock_object *lock, rtems_bsd_mutex *m)
rtems_bsd_mutex_release(m, isr_level, &queue_context);
} else {
rtems_bsd_mutex_set_isr_level(&queue_context, isr_level);
- rtems_bsd_mutex_lock_more(lock, m, owner, executing,
+ rtems_bsd_mutex_lock_more(lk, owner, executing,
&queue_context);
static inline int
-rtems_bsd_mutex_trylock(struct lock_object *lock, rtems_bsd_mutex *m)
+rtems_bsd_mutex_trylock(struct lock_object *lk)
int success;
@@ -163,7 +198,7 @@ rtems_bsd_mutex_trylock(struct lock_object *lock, rtems_bsd_mutex *m)
_Thread_Resource_count_increment(executing);
success = 1;
} else if (owner == executing) {
- if ((lock->lo_flags & LO_RECURSABLE) == 0) {
+ if ((lk->lo_flags & LO_RECURSABLE) == 0) {
panic("mutex trylock: %s: not LO_RECURSABLE\n",
m->queue.Queue.name);
@@ -181,13 +216,14 @@ rtems_bsd_mutex_trylock(struct lock_object *lock, rtems_bsd_mutex *m)
static inline void
-rtems_bsd_mutex_unlock(rtems_bsd_mutex *m)
+rtems_bsd_mutex_unlock(struct lock_object *lk)
int nest_level;
@@ -226,45 +262,52 @@ rtems_bsd_mutex_unlock(rtems_bsd_mutex *m)
static inline Thread_Control *
-rtems_bsd_mutex_owner(const rtems_bsd_mutex *m)
+rtems_bsd_mutex_owner(struct lock_object *lk)
return (m->queue.Queue.owner);
static inline int
-rtems_bsd_mutex_owned(const rtems_bsd_mutex *m)
+rtems_bsd_mutex_owned(struct lock_object *lk)
- return (rtems_bsd_mutex_owner(m) == _Thread_Get_executing());
+ return (rtems_bsd_mutex_owner(lk) == _Thread_Get_executing());
static inline int
-rtems_bsd_mutex_recursed(const rtems_bsd_mutex *m)
+rtems_bsd_mutex_recursed(struct lock_object *lk)
return (m->nest_level != 0);
static inline const char *
-rtems_bsd_mutex_name(const rtems_bsd_mutex *m)
+rtems_bsd_mutex_name(struct lock_object *lk)
return (m->queue.Queue.name);
static inline void
-rtems_bsd_mutex_destroy(struct lock_object *lock, rtems_bsd_mutex *m)
+rtems_bsd_mutex_destroy(struct lock_object *lk)
BSD_ASSERT(m->queue.Queue.heads == NULL);
- if (rtems_bsd_mutex_owned(m)) {
+ if (rtems_bsd_mutex_owned(lk)) {
m->nest_level = 0;
- rtems_bsd_mutex_unlock(m);
+ rtems_bsd_mutex_unlock(lk);
+#if RTEMS_DEBUG
+ TAILQ_REMOVE(&bsd_mutexlist, m, mutex_list);
_Thread_queue_Destroy(&m->queue);
- lock_destroy(lock);
+ lock_destroy(lk);
#ifdef __cplusplus
diff --git a/rtemsbsd/include/machine/rtems-bsd-thread.h b/rtemsbsd/include/machine/rtems-bsd-thread.h
index 28286b8e..6b9259c4 100644
--- a/rtemsbsd/include/machine/rtems-bsd-thread.h
+++ b/rtemsbsd/include/machine/rtems-bsd-thread.h
@@ -45,6 +45,7 @@
#include <sys/proc.h>
extern sbintime_t rtems_bsd_sbt_per_watchdog_tick;
diff --git a/rtemsbsd/rtems/rtems-kernel-epoch.c b/rtemsbsd/rtems/rtems-kernel-epoch.c
index 642b5854..858aa4ba 100644
--- a/rtemsbsd/rtems/rtems-kernel-epoch.c
+++ b/rtemsbsd/rtems/rtems-kernel-epoch.c
@@ -32,8 +32,8 @@
#include <sys/types.h>
#include <sys/kernel.h>
-#include <sys/epoch.h>
#include <sys/mutex.h>
+#include <sys/epoch.h>
#include <sys/sx.h>
#include <sys/systm.h>
diff --git a/rtemsbsd/rtems/rtems-kernel-jail.c b/rtemsbsd/rtems/rtems-kernel-jail.c
index e53e4cc2..da538856 100644
--- a/rtemsbsd/rtems/rtems-kernel-jail.c
+++ b/rtemsbsd/rtems/rtems-kernel-jail.c
@@ -97,10 +97,12 @@ struct prison prison0 = {
* structure.
.pr_mtx = {
- .lock_object = { .lo_flags = LO_INITIALIZED },
- .mutex = {
- .queue = THREAD_QUEUE_INITIALIZER("jail mutex"),
- .nest_level = 0
+ .lock_object = {
+ .lo_flags = LO_INITIALIZED,
+ .lo_mtx = {
+ .queue = THREAD_QUEUE_INITIALIZER("jail mutex"),
+ .nest_level = 0
diff --git a/rtemsbsd/rtems/rtems-kernel-lockmgr.c b/rtemsbsd/rtems/rtems-kernel-lockmgr.c
new file mode 100644
index 00000000..36e7a82f
--- /dev/null
+++ b/rtemsbsd/rtems/rtems-kernel-lockmgr.c
@@ -0,0 +1,578 @@
+ * @file
+ * @ingroup rtems_bsd_rtems
+ * @brief TODO.
+ * Copyright (c) 2020 Chris Johns. All rights reserved.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#include <machine/rtems-bsd-kernel-space.h>
+#include <machine/rtems-bsd-muteximpl.h>
+#include <machine/rtems-bsd-thread.h>
+#include <sys/param.h>
+#include <sys/types.h>
+#include <sys/systm.h>
+#include <sys/lock.h>
+#include <sys/lockmgr.h>
+#include <sys/mutex.h>
+#include <sys/proc.h>
+#include <sys/conf.h>
+#ifdef DEBUG_LOCKS
+#define STACK_PRINT(lk) printf("caller: %p\n", (lk)->lk_stack)
+#define STACK_SAVE(lk) (lk)->lk_stack = __builtin_return_address(0)
+#define STACK_ZERO(lk) (lk)->lk_stack = NULL
+#else
+#endif
+static void assert_lockmgr(const struct lock_object *lock, int how);
+static void lock_lockmgr(struct lock_object *lock, uintptr_t how);
+static uintptr_t unlock_lockmgr(struct lock_object *lock);
+#define lockmgr_xlocked(lk) \
+ rtems_bsd_mutex_owned(RTEMS_DECONST(struct lock_object*, &lk->lock_object))
+#define lockmgr_disowned(lk) \
+ !rtems_bsd_mutex_owned(RTEMS_DECONST(struct lock_object*, &lk->lock_object))
+struct lock_class lock_class_lockmgr = {
+ .lc_name = "lockmgr",
+ .lc_flags = LC_RECURSABLE | LC_SLEEPABLE | LC_SLEEPLOCK | LC_UPGRADABLE,
+ .lc_assert = assert_lockmgr,
+#ifdef DDB
+ .lc_ddb_show = db_show_lockmgr,
+#endif
+ .lc_lock = lock_lockmgr,
+ .lc_unlock = unlock_lockmgr,
+#ifdef KDTRACE_HOOKS
+ .lc_owner = owner_lockmgr,
+#endif
+static void
+assert_lockmgr(const struct lock_object *lock, int what)
+ panic("lockmgr locks do not support assertions");
+static void
+lock_lockmgr(struct lock_object *lock, uintptr_t how)
+ panic("lockmgr locks do not support sleep interlocking");
+static uintptr_t
+unlock_lockmgr(struct lock_object *lock)
+static struct thread *
+lockmgr_xholder(const struct lock *lk)
+ uintptr_t x;
+ x = lk->lk_lock;
+ if ((x & LK_SHARE))
+ return NULL;
+ return rtems_bsd_get_thread(lk->lock_object.lo_mtx.queue.Queue.owner);
+static void
+lockmgr_exit(u_int flags, struct lock_object *ilk, int wakeup_swapper)
+ if (flags & LK_INTERLOCK) {
+ struct lock_class *class = LOCK_CLASS(ilk);
+ class->lc_unlock(ilk);
+#ifdef RTEMS_BSD_LOCKMGR_TRACE
+static void
+lockmgr_trace(const char* label, const char dir, const struct lock *lk)
+ printf("bsd: lck: %s %c lk=%p (%s) lk_lock=%08x rec=%d mtx=%c/%d\n",
+ label, dir, lk, lk->lock_object.lo_mtx.queue.Queue.name,
+ lk->lk_lock, lk->lk_recurse,
+ lk->lock_object.lo_mtx.queue.Queue.owner != NULL ? 'L' : 'U',
+ lk->lock_object.lo_mtx.nest_level);
+#else
+#define lockmgr_trace(lm, d, lk)
+#endif
+static int
+lockmgr_slock_hard(struct lock *lk, u_int flags, struct lock_object *ilk,
+ const char *file, int line)
+ uintptr_t x;
+ int error = 0;
+ lockmgr_trace("slock", 'I', lk);
+ rtems_bsd_mutex_lock(&lk->lock_object);
+ x = lk->lk_lock;
+ atomic_store_rel_ptr(&lk->lk_lock, x + LK_ONE_SHARER);
+ if (rtems_bsd_mutex_recursed(&lk->lock_object))
+ lk->lk_recurse++;
+ else
+ lk->lk_recurse = 0;
+ lockmgr_trace("slock", 'O', lk);
+ LOCK_LOG_LOCK("SLOCK", &lk->lock_object, 0, lk->lk_recurse, file, line);
+ lockmgr_exit(flags, ilk, 0);
+ return error;
+static int
+lockmgr_xlock_hard(struct lock *lk, u_int flags, struct lock_object *ilk,
+ int error = 0;
+ lockmgr_trace("xlock", 'I', lk);
+ if ((flags & LK_NOWAIT) != 0) {
+ if (!rtems_bsd_mutex_trylock(&lk->lock_object))
+ error = EBUSY;
+ } else {
+ if (error == 0) {
+ atomic_store_rel_ptr(&lk->lk_lock, 0);
+ lk->lk_recurse++;
+ else
+ lockmgr_trace("xlock", 'O', lk);
+ return error;
+static int
+lockmgr_upgrade(struct lock *lk, u_int flags, struct lock_object *ilk,
+ uintptr_t x, v;
+ int error = 0;
+ LOCK_LOG_LOCK("XUPGRADE", &lk->lock_object, 0, 0, file, line);
+ lockmgr_trace("xupgrade", 'I', lk);
+ v = lk->lk_lock;
+ x = v & ~LK_SHARE;
+ atomic_store_rel_ptr(&lk->lk_lock, x);
+ lockmgr_trace("xupgrade", 'O', lk);
+ return error;
+static int
+lockmgr_downgrade(struct lock *lk, u_int flags, struct lock_object *ilk,
+ uintptr_t x;
+ LOCK_LOG_LOCK("XDOWNGRADE", &lk->lock_object, 0, 0, file, line);
+ lockmgr_trace("xdowngrade", 'I', lk);
+ x = lk->lk_lock;
+ x &= LK_ALL_WAITERS;
+ lockmgr_trace("xdowngrade", 'O', lk);
+ return 0;
+int
+lockmgr_lock_fast_path(struct lock *lk, u_int flags,
+ struct lock_object *ilk, const char *file, int line)
+ uintptr_t x, tid;
+ u_int op;
+ bool locked;
+ if (__predict_false(panicstr != NULL))
+ return (0);
+ op = flags & LK_TYPE_MASK;
+ locked = false;
+ switch (op) {
+ case LK_SHARED:
+ if (!__predict_false(lk->lock_object.lo_flags & LK_NOSHARE))
+ return (lockmgr_slock_hard(lk, flags, ilk, file, line));
+ /* fall through */
+ case LK_EXCLUSIVE:
+ return (lockmgr_xlock_hard(lk, flags, ilk, file, line));
+ break;
+ case LK_UPGRADE:
+ case LK_TRYUPGRADE:
+ return (lockmgr_upgrade(lk, flags, ilk, file, line));
+ break;
+ case LK_DOWNGRADE:
+ return (lockmgr_downgrade(lk, flags, ilk, file, line));
+ break;
+ default:
+ break;
+ panic("unsupported lockmgr op: %d\n", op);
+static int
+lockmgr_sunlock_hard(struct lock *lk, uintptr_t x, u_int flags, struct lock_object *ilk,
+ uintptr_t v;
+ int error = 0;
+ LOCK_LOG_LOCK("SUNLOCK", &lk->lock_object, 0, lk->lk_recurse, file, line);
+ lockmgr_trace("sunlock", 'I', lk);
+ x = lk->lk_lock;
+ if (x == LK_UNLOCKED)
+ panic("sunlock not locked");
+ lk->lk_recurse--;
+ atomic_store_rel_ptr(&lk->lk_lock, x - LK_ONE_SHARER);
+ rtems_bsd_mutex_unlock(&lk->lock_object);
+ lockmgr_trace("sunlock", 'O', lk);
+ return error;
+static int
+lockmgr_xunlock_hard(struct lock *lk, uintptr_t x, u_int flags, struct lock_object *ilk,
+ int error = 0;
+ LOCK_LOG_LOCK("XUNLOCK", &lk->lock_object, 0, lk->lk_recurse, file, line);
+ lockmgr_trace("xunlock", 'I', lk);
+ lk->lk_recurse--;
+ if (lk->lk_recurse == 0) {
+ uintptr_t v, x;
+ x = lk->lk_lock;
+ if (x != 0)
+ x -= LK_ONE_SHARER;
+ v = x | LK_SHARE;
+ atomic_store_rel_ptr(&lk->lk_lock, v);
+ lockmgr_trace("xunlock", 'O', lk);
+ return error;
+int
+lockmgr_unlock_fast_path(struct lock *lk, u_int flags, struct lock_object *ilk)
+ struct lock_class *class;
+ uintptr_t x, tid;
+ const char *file;
+ int line;
+ return (0);
+ file = __FILE__;
+ line = __LINE__;
+ x = lk->lk_lock;
+ if (__predict_true(x & LK_SHARE) != 0) {
+ return (lockmgr_sunlock_hard(lk, x, flags, ilk, file, line));
+ } else {
+ return (lockmgr_xunlock_hard(lk, x, flags, ilk, file, line));
+int
+lockstatus(const struct lock *lk)
+ uintptr_t v, x;
+ int ret;
+ ret = LK_SHARED;
+ x = lk->lk_lock;
+ if ((x & LK_SHARE) == 0) {
+ v = rtems_bsd_mutex_owned(RTEMS_DECONST(struct lock_object*, &lk->lock_object));
+ if (v)
+ ret = LK_EXCLUSIVE;
+ else
+ ret = LK_EXCLOTHER;
+ } else if (x == LK_UNLOCKED) {
+ ret = 0;
+ lockmgr_trace("status", 'O', lk);
+ return (ret);
+void
+lockallowrecurse(struct lock *lk)
+ lk->lock_object.lo_flags |= LO_RECURSABLE;
+void
+lockallowshare(struct lock *lk)
+ lk->lock_object.lo_flags &= ~LK_NOSHARE;
+void
+lockdisablerecurse(struct lock *lk)
+ lk->lock_object.lo_flags &= ~LO_RECURSABLE;
+void
+lockdisableshare(struct lock *lk)
+ lk->lock_object.lo_flags |= LK_NOSHARE;
+void
+lockinit(struct lock *lk, int pri, const char *wmesg, int timo, int flags)
+ int iflags;
+ MPASS((flags & ~LK_INIT_MASK) == 0);
+ ASSERT_ATOMIC_LOAD_PTR(lk->lk_lock,
+ ("%s: lockmgr not aligned for %s: %p", __func__, wmesg,
+ &lk->lk_lock));
+ iflags = LO_SLEEPABLE | LO_UPGRADABLE;
+ if (flags & LK_CANRECURSE)
+ iflags |= LO_RECURSABLE;
+ if ((flags & LK_NODUP) == 0)
+ iflags |= LO_DUPOK;
+ if (flags & LK_NOPROFILE)
+ iflags |= LO_NOPROFILE;
+ if ((flags & LK_NOWITNESS) == 0)
+ iflags |= LO_WITNESS;
+ if (flags & LK_QUIET)
+ iflags |= LO_QUIET;
+ if (flags & LK_IS_VNODE)
+ iflags |= LO_IS_VNODE;
+ iflags |= flags & (LK_ADAPTIVE | LK_NOSHARE);
+ rtems_bsd_mutex_init(&lk->lock_object, &lock_class_lockmgr, wmesg, NULL, iflags);
+ lk->lk_lock = LK_UNLOCKED;
+ lk->lk_exslpfail = 0;
+ lk->lk_timo = timo;
+ lk->lk_pri = pri;
+ STACK_ZERO(lk);
+void
+lockdestroy(struct lock *lk)
+ KASSERT(lk->lk_lock == LK_UNLOCKED, ("lockmgr still held"));
+ KASSERT(lk->lk_recurse == 0, ("lockmgr still recursed"));
+ KASSERT(lk->lk_exslpfail == 0, ("lockmgr still exclusive waiters"));
+ rtems_bsd_mutex_destroy(&lk->lock_object);
+void
+lockmgr_printinfo(const struct lock *lk)
+ struct thread *td;
+ uintptr_t x;
+ if (lk->lk_lock == LK_UNLOCKED)
+ printf("lock type %s: UNLOCKED\n", lk->lock_object.lo_name);
+ else if (lk->lk_lock & LK_SHARE)
+ printf("lock type %s: SHARED (count %ju)\n",
+ lk->lock_object.lo_name,
+ (uintmax_t)LK_SHARERS(lk->lk_lock));
+ else {
+ td = lockmgr_xholder(lk);
+ if (td == NULL)
+ printf("lock type %s: not owned\n",
+ lk->lock_object.lo_name);
+ else
+ printf("lock type %s: EXCL by thread %p "
+ "(pid %d, rtems, tid %d)\n", lk->lock_object.lo_name,
+ td, td->td_proc->p_pid,
+ td->td_tid);
+ x = lk->lk_lock;
+ if (x & LK_EXCLUSIVE_WAITERS)
+ printf(" with exclusive waiters pending\n");
+ if (x & LK_SHARED_WAITERS)
+ printf(" with shared waiters pending\n");
+ if (x & LK_EXCLUSIVE_SPINNERS)
+ printf(" with exclusive spinners pending\n");
+ STACK_PRINT(lk);
+int
+__lockmgr_args(struct lock *lk, u_int flags, struct lock_object *ilk,
+ const char *wmesg, int prio, int timo, const char *file, int line)
+ uintptr_t x;
+ u_int op = (flags & LK_TYPE_MASK);
+ int error = 0;
+ if (panicstr != NULL)
+ return (0);
+ class = (flags & LK_INTERLOCK) ? LOCK_CLASS(ilk) : NULL;
+ if (lk->lock_object.lo_flags & LK_NOSHARE) {
+ switch (op) {
+ case LK_SHARED:
+ op = LK_EXCLUSIVE;
+ break;
+ case LK_UPGRADE:
+ return (0);
+ switch (op) {
+ case LK_SHARED:
+ break;
+ case LK_UPGRADE:
+ break;
+ break;
+ error = lockmgr_downgrade(lk, flags, ilk, file, line);
+ break;
+ case LK_RELEASE:
+ lockmgr_trace("release", '-', lk);
+ x = lk->lk_lock;
+ } else {
+ break;
+ case LK_DRAIN:
+ break;
+ default:
+ panic("%s: unknown lockmgr request 0x%x\n", __func__, op);
+ return (error);
+void
+_lockmgr_disown(struct lock *lk, const char *file, int line)
+#ifdef INVARIANT_SUPPORT
+#ifndef INVARIANTS
+#undef _lockmgr_assert
+#endif
+void
+_lockmgr_assert(const struct lock *lk, int what, const char *file, int line)
+ int slocked = 0;
+ return;
+ switch (what) {
+ case KA_SLOCKED:
+ case KA_SLOCKED | KA_NOTRECURSED:
+ case KA_SLOCKED | KA_RECURSED:
+ slocked = 1;
+ case KA_LOCKED:
+ case KA_LOCKED | KA_NOTRECURSED:
+ case KA_LOCKED | KA_RECURSED:
+#ifdef WITNESS
+ * We cannot trust WITNESS if the lock is held in exclusive
+ * mode and a call to lockmgr_disown() happened.
+ * Workaround this skipping the check if the lock is held in
+ * exclusive mode even for the KA_LOCKED case.
+ if (slocked || (lk->lk_lock & LK_SHARE)) {
+ witness_assert(&lk->lock_object, what, file, line);
+ break;
+#endif
+ if (lk->lk_lock == LK_UNLOCKED ||
+ ((lk->lk_lock & LK_SHARE) == 0 && (slocked ||
+ (!lockmgr_xlocked(lk) && !lockmgr_disowned(lk)))))
+ panic("Lock %s not %slocked @ %s:%d\n",
+ lk->lock_object.lo_name, slocked ? "share" : "",
+ file, line);
+ if ((lk->lk_lock & LK_SHARE) == 0) {
+ if (lockmgr_recursed(lk)) {
+ if (what & KA_NOTRECURSED)
+ panic("Lock %s recursed @ %s:%d\n",
+ lk->lock_object.lo_name, file,
+ line);
+ } else if (what & KA_RECURSED)
+ panic("Lock %s not recursed @ %s:%d\n",
+ lk->lock_object.lo_name, file, line);
+ break;
+ case KA_XLOCKED:
+ case KA_XLOCKED | KA_NOTRECURSED:
+ case KA_XLOCKED | KA_RECURSED:
+ if (!lockmgr_xlocked(lk) && !lockmgr_disowned(lk))
+ panic("Lock %s not exclusively locked @ %s:%d\n",
+ break;
+ case KA_UNLOCKED:
+ if (lockmgr_xlocked(lk) || lockmgr_disowned(lk))
+ panic("Lock %s exclusively locked @ %s:%d\n",
+ break;
+ default:
+ panic("Unknown lockmgr assertion: %d @ %s:%d\n", what, file,
+ line);
+#endif
diff --git a/rtemsbsd/rtems/rtems-kernel-mutex.c b/rtemsbsd/rtems/rtems-kernel-mutex.c
index 47f36832..ef73c3dd 100644
--- a/rtemsbsd/rtems/rtems-kernel-mutex.c
+++ b/rtemsbsd/rtems/rtems-kernel-mutex.c
@@ -48,6 +48,11 @@
+#if RTEMS_DEBUG
+struct bsd_mutex_list bsd_mutexlist = TAILQ_HEAD_INITIALIZER(bsd_mutexlist);
+rtems_mutex bsd_mutexlist_lock = RTEMS_MUTEX_INITIALIZER("mmutexlist");
static void assert_mtx(const struct lock_object *lock, int what);
static void lock_mtx(struct lock_object *lock, uintptr_t how);
static uintptr_t unlock_mtx(struct lock_object *lock);
@@ -110,26 +115,26 @@ mtx_init(struct mtx *m, const char *name, const char *type, int opts)
if (opts & MTX_RECURSE)
- rtems_bsd_mutex_init(&m->lock_object, &m->mutex, class, name, type,
+ rtems_bsd_mutex_init(&m->lock_object, class, name, type,
flags);
void
_mtx_lock_flags(struct mtx *m, int opts, const char *file, int line)
- rtems_bsd_mutex_lock(&m->lock_object, &m->mutex);
+ rtems_bsd_mutex_lock(&m->lock_object);
int
mtx_trylock_flags_(struct mtx *m, int opts, const char *file, int line)
- return (rtems_bsd_mutex_trylock(&m->lock_object, &m->mutex));
+ return (rtems_bsd_mutex_trylock(&m->lock_object));
void
_mtx_unlock_flags(struct mtx *m, int opts, const char *file, int line)
- rtems_bsd_mutex_unlock(&m->mutex);
+ rtems_bsd_mutex_unlock(&m->lock_object);
@@ -139,7 +144,7 @@ _mtx_unlock_flags(struct mtx *m, int opts, const char *file, int line)
void
_mtx_assert(struct mtx *m, int what, const char *file, int line)
- const char *name = rtems_bsd_mutex_name(&m->mutex);
+ const char *name = rtems_bsd_mutex_name(&m->lock_object);
switch (what) {
case MA_OWNED:
@@ -168,12 +173,12 @@ _mtx_assert(struct mtx *m, int what, const char *file, int line)
int mtx_owned(struct mtx *m)
- return (rtems_bsd_mutex_owned(&m->mutex));
+ return (rtems_bsd_mutex_owned(&m->lock_object));
int mtx_recursed(struct mtx *m)
- return (rtems_bsd_mutex_recursed(&m->mutex));
+ return (rtems_bsd_mutex_recursed(&m->lock_object));
void
@@ -188,7 +193,7 @@ void
mtx_destroy(struct mtx *m)
- rtems_bsd_mutex_destroy(&m->lock_object, &m->mutex);
+ rtems_bsd_mutex_destroy(&m->lock_object);
void
diff --git a/rtemsbsd/rtems/rtems-kernel-muteximpl.c b/rtemsbsd/rtems/rtems-kernel-muteximpl.c
index 8a832b4e..a57d1bc8 100644
--- a/rtemsbsd/rtems/rtems-kernel-muteximpl.c
+++ b/rtemsbsd/rtems/rtems-kernel-muteximpl.c
@@ -43,12 +43,13 @@
void
-rtems_bsd_mutex_lock_more(struct lock_object *lock, rtems_bsd_mutex *m,
+rtems_bsd_mutex_lock_more(struct lock_object *lk,
_Thread_queue_Release(&m->queue, queue_context);
panic("mutex lock: %s: not LO_RECURSABLE\n",
diff --git a/rtemsbsd/rtems/rtems-kernel-rwlock.c b/rtemsbsd/rtems/rtems-kernel-rwlock.c
index c204c04f..a4e98edd 100644
--- a/rtemsbsd/rtems/rtems-kernel-rwlock.c
+++ b/rtemsbsd/rtems/rtems-kernel-rwlock.c
@@ -70,9 +70,9 @@ struct lock_class lock_class_rw = {
.lc_unlock = unlock_rw,
-#define rw_wowner(rw) rtems_bsd_mutex_owner(&(rw)->mutex)
+#define rw_wowner(rw) rtems_bsd_mutex_owner(&(rw)->lock_object)
-#define rw_recursed(rw) rtems_bsd_mutex_recursed(&(rw)->mutex)
+#define rw_recursed(rw) rtems_bsd_mutex_recursed(&(rw)->lock_object)
void
assert_rw(const struct lock_object *lock, int what)
@@ -101,11 +101,9 @@ rw_init_flags(struct rwlock *rw, const char *name, int opts)
int flags;
- flags = LO_UPGRADABLE;
- if (opts & RW_RECURSE)
- flags |= LO_RECURSABLE;
+ flags = LO_UPGRADABLE | LO_RECURSABLE;
- rtems_bsd_mutex_init(&rw->lock_object, &rw->mutex, &lock_class_rw,
+ rtems_bsd_mutex_init(&rw->lock_object, &lock_class_rw,
name, NULL, flags);
@@ -113,7 +111,7 @@ void
rw_destroy(struct rwlock *rw)
- rtems_bsd_mutex_destroy(&rw->lock_object, &rw->mutex);
+ rtems_bsd_mutex_destroy(&rw->lock_object);
void
@@ -128,43 +126,43 @@ rw_sysinit(void *arg)
int
rw_wowned(struct rwlock *rw)
- return (rtems_bsd_mutex_owned(&rw->mutex));
+ return (rtems_bsd_mutex_owned(&rw->lock_object));
void
_rw_wlock(struct rwlock *rw, const char *file, int line)
- rtems_bsd_mutex_lock(&rw->lock_object, &rw->mutex);
+ rtems_bsd_mutex_lock(&rw->lock_object);
int
_rw_try_wlock(struct rwlock *rw, const char *file, int line)
- return (rtems_bsd_mutex_trylock(&rw->lock_object, &rw->mutex));
+ return (rtems_bsd_mutex_trylock(&rw->lock_object));
void
_rw_wunlock(struct rwlock *rw, const char *file, int line)
- rtems_bsd_mutex_unlock(&rw->mutex);
+ rtems_bsd_mutex_unlock(&rw->lock_object);
void
_rw_rlock(struct rwlock *rw, const char *file, int line)
int
_rw_try_rlock(struct rwlock *rw, const char *file, int line)
void
_rw_runlock(struct rwlock *rw, const char *file, int line)
int
@@ -188,7 +186,7 @@ _rw_downgrade(struct rwlock *rw, const char *file, int line)
void
_rw_assert(const struct rwlock *rw, int what, const char *file, int line)
- const char *name = rtems_bsd_mutex_name(&rw->mutex);
+ const char *name = rtems_bsd_mutex_name(&rw->lock_object);
switch (what) {
case RA_LOCKED:
diff --git a/rtemsbsd/rtems/rtems-kernel-sx.c b/rtemsbsd/rtems/rtems-kernel-sx.c
index 4f8bea4d..827b3397 100644
--- a/rtemsbsd/rtems/rtems-kernel-sx.c
+++ b/rtemsbsd/rtems/rtems-kernel-sx.c
@@ -59,9 +59,9 @@ struct lock_class lock_class_sx = {
.lc_unlock = unlock_sx,
-#define sx_xholder(sx) rtems_bsd_mutex_owner(&(sx)->mutex)
+#define sx_xholder(sx) rtems_bsd_mutex_owner(&(sx)->lock_object)
-#define sx_recursed(sx) rtems_bsd_mutex_recursed(&(sx)->mutex)
+#define sx_recursed(sx) rtems_bsd_mutex_recursed(&(sx)->lock_object)
void
assert_sx(const struct lock_object *lock, int what)
@@ -90,7 +90,7 @@ sx_sysinit(void *arg)
struct sx_args *sargs = arg;
- sx_init(sargs->sa_sx, sargs->sa_desc);
+ sx_init_flags(sargs->sa_sx, sargs->sa_desc, sargs->sa_flags);
void
@@ -102,7 +102,7 @@ sx_init_flags(struct sx *sx, const char *description, int opts)
if (opts & SX_RECURSE)
- rtems_bsd_mutex_init(&sx->lock_object, &sx->mutex, &lock_class_sx,
+ rtems_bsd_mutex_init(&sx->lock_object, &lock_class_sx,
description, NULL, flags);
@@ -110,14 +110,14 @@ void
sx_destroy(struct sx *sx)
- rtems_bsd_mutex_destroy(&sx->lock_object, &sx->mutex);
+ rtems_bsd_mutex_destroy(&sx->lock_object);
int
_sx_slock_int(struct sx *sx, int opts LOCK_FILE_LINE_ARG_DEF)
- rtems_bsd_mutex_lock(&sx->lock_object, &sx->mutex);
+ rtems_bsd_mutex_lock(&sx->lock_object);
return (0);
@@ -125,14 +125,14 @@ int
sx_try_slock_int(struct sx *sx LOCK_FILE_LINE_ARG_DEF)
- return (rtems_bsd_mutex_trylock(&sx->lock_object, &sx->mutex));
+ return (rtems_bsd_mutex_trylock(&sx->lock_object));
void
_sx_sunlock_int(struct sx *sx LOCK_FILE_LINE_ARG_DEF)
- rtems_bsd_mutex_unlock(&sx->mutex);
+ rtems_bsd_mutex_unlock(&sx->lock_object);
int
@@ -142,6 +142,13 @@ sx_try_upgrade_int(struct sx *sx LOCK_FILE_LINE_ARG_DEF)
return (1);
+int
+sx_try_upgrade_(struct sx *sx, const char *file, int line)
+ return (1);
void
sx_downgrade_int(struct sx *sx LOCK_FILE_LINE_ARG_DEF)
@@ -149,6 +156,13 @@ sx_downgrade_int(struct sx *sx LOCK_FILE_LINE_ARG_DEF)
/* Do nothing */
+int
+sx_try_downgrade_(struct sx *sx, const char *file, int line)
+ return (1);
* In the non-WITNESS case, sx_assert() can only detect that at least
@@ -158,7 +172,7 @@ sx_downgrade_int(struct sx *sx LOCK_FILE_LINE_ARG_DEF)
void
_sx_assert(const struct sx *sx, int what, const char *file, int line)
- const char *name = rtems_bsd_mutex_name(&sx->mutex);
+ const char *name = rtems_bsd_mutex_name(&sx->lock_object);
switch (what) {
case SA_SLOCKED:
@@ -205,5 +219,5 @@ _sx_assert(const struct sx *sx, int what, const char *file, int line)
int
sx_xlocked(struct sx *sx)
- return (rtems_bsd_mutex_owned(&sx->mutex));
+ return (rtems_bsd_mutex_owned(&sx->lock_object));
2.24.1
