[PATCH rtems-libbsd 4/7] kern: Import kern_prot.c fnd kern_resource.c for proc0
chrisj at rtems.org
chrisj at rtems.org
Tue Jul 27 08:58:48 UTC 2021
Update #4475
freebsd/sys/kern/kern_prot.c | 2247 ++++++++++++++++++++++++++++++
freebsd/sys/kern/kern_resource.c | 1539 ++++++++++++++++++++
2 files changed, 3786 insertions(+)
create mode 100644 freebsd/sys/kern/kern_prot.c
create mode 100644 freebsd/sys/kern/kern_resource.c
diff --git a/freebsd/sys/kern/kern_prot.c b/freebsd/sys/kern/kern_prot.c
new file mode 100644
index 00000000..a62b6f76
--- /dev/null
+++ b/freebsd/sys/kern/kern_prot.c
@@ -0,0 +1,2247 @@
+ * SPDX-License-Identifier: BSD-3-Clause
+ * Copyright (c) 1982, 1986, 1989, 1990, 1991, 1993
+ * The Regents of the University of California.
+ * (c) UNIX System Laboratories, Inc.
+ * Copyright (c) 2000-2001 Robert N. M. Watson.
+ * All rights reserved.
+ * All or some portions of this file are derived from material licensed
+ * to the University of California by American Telephone and Telegraph
+ * Co. or Unix System Laboratories, Inc. and are reproduced herein with
+ * the permission of UNIX System Laboratories, Inc.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * 3. Neither the name of the University nor the names of its contributors
+ * may be used to endorse or promote products derived from this software
+ * without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * @(#)kern_prot.c 8.6 (Berkeley) 1/21/94
+ * System calls related to processes and protection
+#include <sys/cdefs.h>
+__FBSDID("$FreeBSD$");
+#include "opt_inet.h"
+#include "opt_inet6.h"
+#include <sys/param.h>
+#include <sys/systm.h>
+#include <sys/acct.h>
+#include <sys/kdb.h>
+#include <sys/kernel.h>
+#include <sys/lock.h>
+#include <sys/loginclass.h>
+#include <sys/malloc.h>
+#include <sys/mutex.h>
+#include <sys/refcount.h>
+#include <sys/sx.h>
+#include <sys/priv.h>
+#include <sys/proc.h>
+#include <sys/sysent.h>
+#include <sys/sysproto.h>
+#include <sys/jail.h>
+#include <sys/pioctl.h>
+#include <sys/racct.h>
+#include <sys/rctl.h>
+#include <sys/resourcevar.h>
+#include <sys/socket.h>
+#include <sys/socketvar.h>
+#include <sys/syscallsubr.h>
+#include <sys/sysctl.h>
+#ifdef REGRESSION
+FEATURE(regression,
+ "Kernel support for interfaces necessary for regression testing (SECURITY RISK!)");
+#endif
+#include <security/audit/audit.h>
+#include <security/mac/mac_framework.h>
+static MALLOC_DEFINE(M_CRED, "cred", "credentials");
+SYSCTL_NODE(_security, OID_AUTO, bsd, CTLFLAG_RW, 0, "BSD security policy");
+static void crsetgroups_locked(struct ucred *cr, int ngrp,
+ gid_t *groups);
+#ifndef _SYS_SYSPROTO_H_
+struct getpid_args {
+ int dummy;
+#endif
+/* ARGSUSED */
+int
+sys_getpid(struct thread *td, struct getpid_args *uap)
+ struct proc *p = td->td_proc;
+ td->td_retval[0] = p->p_pid;
+#if defined(COMPAT_43)
+ if (SV_PROC_FLAG(p, SV_AOUT))
+ td->td_retval[1] = kern_getppid(td);
+#endif
+ return (0);
+struct getppid_args {
+ int dummy;
+#endif
+/* ARGSUSED */
+int
+sys_getppid(struct thread *td, struct getppid_args *uap)
+ td->td_retval[0] = kern_getppid(td);
+ return (0);
+int
+kern_getppid(struct thread *td)
+ return (p->p_oppid);
+ * Get process group ID; note that POSIX getpgrp takes no parameter.
+struct getpgrp_args {
+ int dummy;
+#endif
+int
+sys_getpgrp(struct thread *td, struct getpgrp_args *uap)
+ PROC_LOCK(p);
+ td->td_retval[0] = p->p_pgrp->pg_id;
+ PROC_UNLOCK(p);
+ return (0);
+/* Get an arbitrary pid's process group id */
+struct getpgid_args {
+ pid_t pid;
+#endif
+int
+sys_getpgid(struct thread *td, struct getpgid_args *uap)
+ struct proc *p;
+ int error;
+ if (uap->pid == 0) {
+ p = td->td_proc;
+ PROC_LOCK(p);
+ } else {
+ p = pfind(uap->pid);
+ if (p == NULL)
+ return (ESRCH);
+ error = p_cansee(td, p);
+ if (error) {
+ PROC_UNLOCK(p);
+ return (error);
+ PROC_UNLOCK(p);
+ return (0);
+ * Get an arbitrary pid's session id.
+struct getsid_args {
+ pid_t pid;
+#endif
+int
+sys_getsid(struct thread *td, struct getsid_args *uap)
+ struct proc *p;
+ int error;
+ p = td->td_proc;
+ PROC_LOCK(p);
+ } else {
+ if (p == NULL)
+ return (ESRCH);
+ if (error) {
+ PROC_UNLOCK(p);
+ return (error);
+ td->td_retval[0] = p->p_session->s_sid;
+ PROC_UNLOCK(p);
+ return (0);
+struct getuid_args {
+ int dummy;
+#endif
+/* ARGSUSED */
+int
+sys_getuid(struct thread *td, struct getuid_args *uap)
+ td->td_retval[0] = td->td_ucred->cr_ruid;
+ td->td_retval[1] = td->td_ucred->cr_uid;
+#endif
+ return (0);
+struct geteuid_args {
+ int dummy;
+#endif
+/* ARGSUSED */
+int
+sys_geteuid(struct thread *td, struct geteuid_args *uap)
+ td->td_retval[0] = td->td_ucred->cr_uid;
+ return (0);
+struct getgid_args {
+ int dummy;
+#endif
+/* ARGSUSED */
+int
+sys_getgid(struct thread *td, struct getgid_args *uap)
+ td->td_retval[0] = td->td_ucred->cr_rgid;
+ td->td_retval[1] = td->td_ucred->cr_groups[0];
+#endif
+ return (0);
+ * Get effective group ID. The "egid" is groups[0], and could be obtained
+ * via getgroups. This syscall exists because it is somewhat painful to do
+ * correctly in a library function.
+struct getegid_args {
+ int dummy;
+#endif
+/* ARGSUSED */
+int
+sys_getegid(struct thread *td, struct getegid_args *uap)
+ td->td_retval[0] = td->td_ucred->cr_groups[0];
+ return (0);
+struct getgroups_args {
+ u_int gidsetsize;
+ gid_t *gidset;
+#endif
+int
+sys_getgroups(struct thread *td, struct getgroups_args *uap)
+ struct ucred *cred;
+ u_int ngrp;
+ int error;
+ cred = td->td_ucred;
+ ngrp = cred->cr_ngroups;
+ if (uap->gidsetsize == 0) {
+ error = 0;
+ goto out;
+ if (uap->gidsetsize < ngrp)
+ return (EINVAL);
+ error = copyout(cred->cr_groups, uap->gidset, ngrp * sizeof(gid_t));
+out:
+ td->td_retval[0] = ngrp;
+ return (error);
+struct setsid_args {
+ int dummy;
+#endif
+/* ARGSUSED */
+int
+sys_setsid(struct thread *td, struct setsid_args *uap)
+ struct pgrp *pgrp;
+ int error;
+ struct pgrp *newpgrp;
+ struct session *newsess;
+ error = 0;
+ pgrp = NULL;
+ newpgrp = malloc(sizeof(struct pgrp), M_PGRP, M_WAITOK | M_ZERO);
+ newsess = malloc(sizeof(struct session), M_SESSION, M_WAITOK | M_ZERO);
+ sx_xlock(&proctree_lock);
+ if (p->p_pgid == p->p_pid || (pgrp = pgfind(p->p_pid)) != NULL) {
+ if (pgrp != NULL)
+ PGRP_UNLOCK(pgrp);
+ error = EPERM;
+ } else {
+ (void)enterpgrp(p, p->p_pid, newpgrp, newsess);
+ newpgrp = NULL;
+ newsess = NULL;
+ sx_xunlock(&proctree_lock);
+ if (newpgrp != NULL)
+ free(newpgrp, M_PGRP);
+ if (newsess != NULL)
+ free(newsess, M_SESSION);
+ return (error);
+ * set process group (setpgid/old setpgrp)
+ * caller does setpgid(targpid, targpgid)
+ * pid must be caller or child of caller (ESRCH)
+ * if a child
+ * pid must be in same session (EPERM)
+ * pid can't have done an exec (EACCES)
+ * if pgid != pid
+ * there must exist some pid in same session having pgid (EPERM)
+ * pid must not be session leader (EPERM)
+struct setpgid_args {
+ int pid; /* target process id */
+ int pgid; /* target pgrp id */
+#endif
+/* ARGSUSED */
+int
+sys_setpgid(struct thread *td, struct setpgid_args *uap)
+ struct proc *curp = td->td_proc;
+ struct proc *targp; /* target process */
+ struct pgrp *pgrp; /* target pgrp */
+ int error;
+ if (uap->pgid < 0)
+ return (EINVAL);
+ error = 0;
+ if (uap->pid != 0 && uap->pid != curp->p_pid) {
+ if ((targp = pfind(uap->pid)) == NULL) {
+ error = ESRCH;
+ goto done;
+ if (!inferior(targp)) {
+ PROC_UNLOCK(targp);
+ error = ESRCH;
+ goto done;
+ if ((error = p_cansee(td, targp))) {
+ goto done;
+ if (targp->p_pgrp == NULL ||
+ targp->p_session != curp->p_session) {
+ error = EPERM;
+ goto done;
+ if (targp->p_flag & P_EXEC) {
+ error = EACCES;
+ goto done;
+ } else
+ targp = curp;
+ if (SESS_LEADER(targp)) {
+ error = EPERM;
+ goto done;
+ if (uap->pgid == 0)
+ uap->pgid = targp->p_pid;
+ if ((pgrp = pgfind(uap->pgid)) == NULL) {
+ if (uap->pgid == targp->p_pid) {
+ error = enterpgrp(targp, uap->pgid, newpgrp,
+ NULL);
+ if (error == 0)
+ newpgrp = NULL;
+ } else
+ error = EPERM;
+ } else {
+ if (pgrp == targp->p_pgrp) {
+ goto done;
+ if (pgrp->pg_id != targp->p_pid &&
+ pgrp->pg_session != curp->p_session) {
+ error = EPERM;
+ goto done;
+ error = enterthispgrp(targp, pgrp);
+done:
+ KASSERT((error == 0) || (newpgrp != NULL),
+ ("setpgid failed and newpgrp is NULL"));
+ return (error);
+ * Use the clause in B.4.2.2 that allows setuid/setgid to be 4.2/4.3BSD
+ * compatible. It says that setting the uid/gid to euid/egid is a special
+ * case of "appropriate privilege". Once the rules are expanded out, this
+ * basically means that setuid(nnn) sets all three id's, in all permitted
+ * cases unless _POSIX_SAVED_IDS is enabled. In that case, setuid(getuid())
+ * does not set the saved id - this is dangerous for traditional BSD
+ * programs. For this reason, we *really* do not want to set
+ * _POSIX_SAVED_IDS and do not want to clear POSIX_APPENDIX_B_4_2_2.
+#define POSIX_APPENDIX_B_4_2_2
+struct setuid_args {
+ uid_t uid;
+#endif
+/* ARGSUSED */
+int
+sys_setuid(struct thread *td, struct setuid_args *uap)
+ struct ucred *newcred, *oldcred;
+ uid_t uid;
+ struct uidinfo *uip;
+ int error;
+ uid = uap->uid;
+ AUDIT_ARG_UID(uid);
+ newcred = crget();
+ uip = uifind(uid);
+ PROC_LOCK(p);
+ * Copy credentials so other references do not see our changes.
+ oldcred = crcopysafe(p, newcred);
+#ifdef MAC
+ error = mac_cred_check_setuid(oldcred, uid);
+ if (error)
+ goto fail;
+#endif
+ * See if we have "permission" by POSIX 1003.1 rules.
+ * Note that setuid(geteuid()) is a special case of
+ * "appropriate privileges" in appendix B.4.2.2. We need
+ * to use this clause to be compatible with traditional BSD
+ * semantics. Basically, it means that "setuid(xx)" sets all
+ * three id's (assuming you have privs).
+ * Notes on the logic. We do things in three steps.
+ * 1: We determine if the euid is going to change, and do EPERM
+ * right away. We unconditionally change the euid later if this
+ * test is satisfied, simplifying that part of the logic.
+ * 2: We determine if the real and/or saved uids are going to
+ * change. Determined by compile options.
+ * 3: Change euid last. (after tests in #2 for "appropriate privs")
+ if (uid != oldcred->cr_ruid && /* allow setuid(getuid()) */
+#ifdef _POSIX_SAVED_IDS
+ uid != oldcred->cr_svuid && /* allow setuid(saved gid) */
+#endif
+#ifdef POSIX_APPENDIX_B_4_2_2 /* Use BSD-compat clause from B.4.2.2 */
+ uid != oldcred->cr_uid && /* allow setuid(geteuid()) */
+#endif
+ (error = priv_check_cred(oldcred, PRIV_CRED_SETUID, 0)) != 0)
+ goto fail;
+ * Do we have "appropriate privileges" (are we root or uid == euid)
+ * If so, we are changing the real uid and/or saved uid.
+ if (
+#ifdef POSIX_APPENDIX_B_4_2_2 /* Use the clause from B.4.2.2 */
+ uid == oldcred->cr_uid ||
+#endif
+ /* We are using privs. */
+ priv_check_cred(oldcred, PRIV_CRED_SETUID, 0) == 0)
+#endif
+ * Set the real uid and transfer proc count to new user.
+ if (uid != oldcred->cr_ruid) {
+ change_ruid(newcred, uip);
+ setsugid(p);
+ * Set saved uid
+ * XXX always set saved uid even if not _POSIX_SAVED_IDS, as
+ * the security of seteuid() depends on it. B.4.2.2 says it
+ * is important that we should do this.
+ if (uid != oldcred->cr_svuid) {
+ change_svuid(newcred, uid);
+ setsugid(p);
+ * In all permitted cases, we are changing the euid.
+ if (uid != oldcred->cr_uid) {
+ change_euid(newcred, uip);
+ setsugid(p);
+ proc_set_cred(p, newcred);
+#ifdef RACCT
+ racct_proc_ucred_changed(p, oldcred, newcred);
+ crhold(newcred);
+#endif
+ PROC_UNLOCK(p);
+#ifdef RCTL
+ rctl_proc_ucred_changed(p, newcred);
+ crfree(newcred);
+#endif
+ uifree(uip);
+ crfree(oldcred);
+ return (0);
+fail:
+ PROC_UNLOCK(p);
+ uifree(uip);
+ crfree(newcred);
+ return (error);
+struct seteuid_args {
+ uid_t euid;
+#endif
+/* ARGSUSED */
+int
+sys_seteuid(struct thread *td, struct seteuid_args *uap)
+ uid_t euid;
+ struct uidinfo *euip;
+ int error;
+ euid = uap->euid;
+ AUDIT_ARG_EUID(euid);
+ euip = uifind(euid);
+ PROC_LOCK(p);
+#ifdef MAC
+ error = mac_cred_check_seteuid(oldcred, euid);
+ if (error)
+ goto fail;
+#endif
+ if (euid != oldcred->cr_ruid && /* allow seteuid(getuid()) */
+ euid != oldcred->cr_svuid && /* allow seteuid(saved uid) */
+ (error = priv_check_cred(oldcred, PRIV_CRED_SETEUID, 0)) != 0)
+ goto fail;
+ * Everything's okay, do it.
+ if (oldcred->cr_uid != euid) {
+ change_euid(newcred, euip);
+ setsugid(p);
+ PROC_UNLOCK(p);
+ uifree(euip);
+ crfree(oldcred);
+ return (0);
+fail:
+ PROC_UNLOCK(p);
+ uifree(euip);
+ crfree(newcred);
+ return (error);
+struct setgid_args {
+ gid_t gid;
+#endif
+/* ARGSUSED */
+int
+sys_setgid(struct thread *td, struct setgid_args *uap)
+ gid_t gid;
+ int error;
+ gid = uap->gid;
+ AUDIT_ARG_GID(gid);
+ PROC_LOCK(p);
+#ifdef MAC
+ error = mac_cred_check_setgid(oldcred, gid);
+ if (error)
+ goto fail;
+#endif
+ * Note that setgid(getegid()) is a special case of
+ * semantics. Basically, it means that "setgid(xx)" sets all
+ * For notes on the logic here, see setuid() above.
+ if (gid != oldcred->cr_rgid && /* allow setgid(getgid()) */
+ gid != oldcred->cr_svgid && /* allow setgid(saved gid) */
+#endif
+ gid != oldcred->cr_groups[0] && /* allow setgid(getegid()) */
+#endif
+ (error = priv_check_cred(oldcred, PRIV_CRED_SETGID, 0)) != 0)
+ goto fail;
+ * Do we have "appropriate privileges" (are we root or gid == egid)
+ * If so, we are changing the real uid and saved gid.
+ if (
+#ifdef POSIX_APPENDIX_B_4_2_2 /* use the clause from B.4.2.2 */
+ gid == oldcred->cr_groups[0] ||
+#endif
+ priv_check_cred(oldcred, PRIV_CRED_SETGID, 0) == 0)
+#endif
+ * Set real gid
+ if (oldcred->cr_rgid != gid) {
+ change_rgid(newcred, gid);
+ setsugid(p);
+ * Set saved gid
+ * XXX always set saved gid even if not _POSIX_SAVED_IDS, as
+ * the security of setegid() depends on it. B.4.2.2 says it
+ if (oldcred->cr_svgid != gid) {
+ change_svgid(newcred, gid);
+ setsugid(p);
+ * In all cases permitted cases, we are changing the egid.
+ if (oldcred->cr_groups[0] != gid) {
+ change_egid(newcred, gid);
+ setsugid(p);
+ PROC_UNLOCK(p);
+ crfree(oldcred);
+ return (0);
+fail:
+ PROC_UNLOCK(p);
+ crfree(newcred);
+ return (error);
+struct setegid_args {
+ gid_t egid;
+#endif
+/* ARGSUSED */
+int
+sys_setegid(struct thread *td, struct setegid_args *uap)
+ gid_t egid;
+ int error;
+ egid = uap->egid;
+ AUDIT_ARG_EGID(egid);
+ PROC_LOCK(p);
+#ifdef MAC
+ error = mac_cred_check_setegid(oldcred, egid);
+ if (error)
+ goto fail;
+#endif
+ if (egid != oldcred->cr_rgid && /* allow setegid(getgid()) */
+ egid != oldcred->cr_svgid && /* allow setegid(saved gid) */
+ (error = priv_check_cred(oldcred, PRIV_CRED_SETEGID, 0)) != 0)
+ goto fail;
+ if (oldcred->cr_groups[0] != egid) {
+ change_egid(newcred, egid);
+ setsugid(p);
+ PROC_UNLOCK(p);
+ crfree(oldcred);
+ return (0);
+fail:
+ PROC_UNLOCK(p);
+ crfree(newcred);
+ return (error);
+struct setgroups_args {
+ u_int gidsetsize;
+ gid_t *gidset;
+#endif
+/* ARGSUSED */
+int
+sys_setgroups(struct thread *td, struct setgroups_args *uap)
+ gid_t smallgroups[XU_NGROUPS];
+ gid_t *groups;
+ u_int gidsetsize;
+ int error;
+ gidsetsize = uap->gidsetsize;
+ if (gidsetsize > ngroups_max + 1)
+ return (EINVAL);
+ if (gidsetsize > XU_NGROUPS)
+ groups = malloc(gidsetsize * sizeof(gid_t), M_TEMP, M_WAITOK);
+ else
+ groups = smallgroups;
+ error = copyin(uap->gidset, groups, gidsetsize * sizeof(gid_t));
+ if (error == 0)
+ error = kern_setgroups(td, gidsetsize, groups);
+ free(groups, M_TEMP);
+ return (error);
+int
+kern_setgroups(struct thread *td, u_int ngrp, gid_t *groups)
+ int error;
+ MPASS(ngrp <= ngroups_max + 1);
+ AUDIT_ARG_GROUPSET(groups, ngrp);
+ crextend(newcred, ngrp);
+ PROC_LOCK(p);
+#ifdef MAC
+ error = mac_cred_check_setgroups(oldcred, ngrp, groups);
+ if (error)
+ goto fail;
+#endif
+ error = priv_check_cred(oldcred, PRIV_CRED_SETGROUPS, 0);
+ if (error)
+ goto fail;
+ if (ngrp == 0) {
+ * setgroups(0, NULL) is a legitimate way of clearing the
+ * groups vector on non-BSD systems (which generally do not
+ * have the egid in the groups[0]). We risk security holes
+ * when running non-BSD software if we do not do the same.
+ newcred->cr_ngroups = 1;
+ } else {
+ crsetgroups_locked(newcred, ngrp, groups);
+ setsugid(p);
+ PROC_UNLOCK(p);
+ crfree(oldcred);
+ return (0);
+fail:
+ PROC_UNLOCK(p);
+ crfree(newcred);
+ return (error);
+struct setreuid_args {
+ uid_t ruid;
+ uid_t euid;
+#endif
+/* ARGSUSED */
+int
+sys_setreuid(struct thread *td, struct setreuid_args *uap)
+ uid_t euid, ruid;
+ struct uidinfo *euip, *ruip;
+ int error;
+ euid = uap->euid;
+ ruid = uap->ruid;
+ AUDIT_ARG_RUID(ruid);
+ ruip = uifind(ruid);
+ PROC_LOCK(p);
+#ifdef MAC
+ error = mac_cred_check_setreuid(oldcred, ruid, euid);
+ if (error)
+ goto fail;
+#endif
+ if (((ruid != (uid_t)-1 && ruid != oldcred->cr_ruid &&
+ ruid != oldcred->cr_svuid) ||
+ (euid != (uid_t)-1 && euid != oldcred->cr_uid &&
+ euid != oldcred->cr_ruid && euid != oldcred->cr_svuid)) &&
+ (error = priv_check_cred(oldcred, PRIV_CRED_SETREUID, 0)) != 0)
+ goto fail;
+ if (euid != (uid_t)-1 && oldcred->cr_uid != euid) {
+ setsugid(p);
+ if (ruid != (uid_t)-1 && oldcred->cr_ruid != ruid) {
+ change_ruid(newcred, ruip);
+ setsugid(p);
+ if ((ruid != (uid_t)-1 || newcred->cr_uid != newcred->cr_ruid) &&
+ newcred->cr_svuid != newcred->cr_uid) {
+ change_svuid(newcred, newcred->cr_uid);
+ setsugid(p);
+#ifdef RACCT
+ crhold(newcred);
+#endif
+ PROC_UNLOCK(p);
+#ifdef RCTL
+ crfree(newcred);
+#endif
+ uifree(ruip);
+ uifree(euip);
+ crfree(oldcred);
+ return (0);
+fail:
+ PROC_UNLOCK(p);
+ uifree(ruip);
+ uifree(euip);
+ crfree(newcred);
+ return (error);
+struct setregid_args {
+ gid_t rgid;
+ gid_t egid;
+#endif
+/* ARGSUSED */
+int
+sys_setregid(struct thread *td, struct setregid_args *uap)
+ gid_t egid, rgid;
+ int error;
+ egid = uap->egid;
+ rgid = uap->rgid;
+ AUDIT_ARG_RGID(rgid);
+ PROC_LOCK(p);
+#ifdef MAC
+ error = mac_cred_check_setregid(oldcred, rgid, egid);
+ if (error)
+ goto fail;
+#endif
+ if (((rgid != (gid_t)-1 && rgid != oldcred->cr_rgid &&
+ rgid != oldcred->cr_svgid) ||
+ (egid != (gid_t)-1 && egid != oldcred->cr_groups[0] &&
+ egid != oldcred->cr_rgid && egid != oldcred->cr_svgid)) &&
+ (error = priv_check_cred(oldcred, PRIV_CRED_SETREGID, 0)) != 0)
+ goto fail;
+ if (egid != (gid_t)-1 && oldcred->cr_groups[0] != egid) {
+ setsugid(p);
+ if (rgid != (gid_t)-1 && oldcred->cr_rgid != rgid) {
+ change_rgid(newcred, rgid);
+ setsugid(p);
+ if ((rgid != (gid_t)-1 || newcred->cr_groups[0] != newcred->cr_rgid) &&
+ newcred->cr_svgid != newcred->cr_groups[0]) {
+ change_svgid(newcred, newcred->cr_groups[0]);
+ setsugid(p);
+ PROC_UNLOCK(p);
+ crfree(oldcred);
+ return (0);
+fail:
+ PROC_UNLOCK(p);
+ crfree(newcred);
+ return (error);
+ * setresuid(ruid, euid, suid) is like setreuid except control over the saved
+ * uid is explicit.
+struct setresuid_args {
+ uid_t ruid;
+ uid_t euid;
+ uid_t suid;
+#endif
+/* ARGSUSED */
+int
+sys_setresuid(struct thread *td, struct setresuid_args *uap)
+ uid_t euid, ruid, suid;
+ int error;
+ euid = uap->euid;
+ ruid = uap->ruid;
+ suid = uap->suid;
+ AUDIT_ARG_SUID(suid);
+ PROC_LOCK(p);
+#ifdef MAC
+ error = mac_cred_check_setresuid(oldcred, ruid, euid, suid);
+ if (error)
+ goto fail;
+#endif
+ ruid != oldcred->cr_svuid &&
+ ruid != oldcred->cr_uid) ||
+ (euid != (uid_t)-1 && euid != oldcred->cr_ruid &&
+ euid != oldcred->cr_uid) ||
+ (suid != (uid_t)-1 && suid != oldcred->cr_ruid &&
+ suid != oldcred->cr_svuid &&
+ suid != oldcred->cr_uid)) &&
+ (error = priv_check_cred(oldcred, PRIV_CRED_SETRESUID, 0)) != 0)
+ goto fail;
+ setsugid(p);
+ setsugid(p);
+ if (suid != (uid_t)-1 && oldcred->cr_svuid != suid) {
+ change_svuid(newcred, suid);
+ setsugid(p);
+#ifdef RACCT
+ crhold(newcred);
+#endif
+ PROC_UNLOCK(p);
+#ifdef RCTL
+ crfree(newcred);
+#endif
+ uifree(ruip);
+ uifree(euip);
+ crfree(oldcred);
+ return (0);
+fail:
+ PROC_UNLOCK(p);
+ uifree(ruip);
+ uifree(euip);
+ crfree(newcred);
+ return (error);
+ * setresgid(rgid, egid, sgid) is like setregid except control over the saved
+ * gid is explicit.
+struct setresgid_args {
+ gid_t rgid;
+ gid_t egid;
+ gid_t sgid;
+#endif
+/* ARGSUSED */
+int
+sys_setresgid(struct thread *td, struct setresgid_args *uap)
+ gid_t egid, rgid, sgid;
+ int error;
+ egid = uap->egid;
+ rgid = uap->rgid;
+ sgid = uap->sgid;
+ AUDIT_ARG_SGID(sgid);
+ PROC_LOCK(p);
+#ifdef MAC
+ error = mac_cred_check_setresgid(oldcred, rgid, egid, sgid);
+ if (error)
+ goto fail;
+#endif
+ rgid != oldcred->cr_svgid &&
+ rgid != oldcred->cr_groups[0]) ||
+ (egid != (gid_t)-1 && egid != oldcred->cr_rgid &&
+ egid != oldcred->cr_groups[0]) ||
+ (sgid != (gid_t)-1 && sgid != oldcred->cr_rgid &&
+ sgid != oldcred->cr_svgid &&
+ sgid != oldcred->cr_groups[0])) &&
+ (error = priv_check_cred(oldcred, PRIV_CRED_SETRESGID, 0)) != 0)
+ goto fail;
+ setsugid(p);
+ setsugid(p);
+ if (sgid != (gid_t)-1 && oldcred->cr_svgid != sgid) {
+ change_svgid(newcred, sgid);
+ setsugid(p);
+ PROC_UNLOCK(p);
+ crfree(oldcred);
+ return (0);
+fail:
+ PROC_UNLOCK(p);
+ crfree(newcred);
+ return (error);
+struct getresuid_args {
+ uid_t *ruid;
+ uid_t *euid;
+ uid_t *suid;
+#endif
+/* ARGSUSED */
+int
+sys_getresuid(struct thread *td, struct getresuid_args *uap)
+ int error1 = 0, error2 = 0, error3 = 0;
+ if (uap->ruid)
+ error1 = copyout(&cred->cr_ruid,
+ uap->ruid, sizeof(cred->cr_ruid));
+ if (uap->euid)
+ error2 = copyout(&cred->cr_uid,
+ uap->euid, sizeof(cred->cr_uid));
+ if (uap->suid)
+ error3 = copyout(&cred->cr_svuid,
+ uap->suid, sizeof(cred->cr_svuid));
+ return (error1 ? error1 : error2 ? error2 : error3);
+struct getresgid_args {
+ gid_t *rgid;
+ gid_t *egid;
+ gid_t *sgid;
+#endif
+/* ARGSUSED */
+int
+sys_getresgid(struct thread *td, struct getresgid_args *uap)
+ if (uap->rgid)
+ error1 = copyout(&cred->cr_rgid,
+ uap->rgid, sizeof(cred->cr_rgid));
+ if (uap->egid)
+ error2 = copyout(&cred->cr_groups[0],
+ uap->egid, sizeof(cred->cr_groups[0]));
+ if (uap->sgid)
+ error3 = copyout(&cred->cr_svgid,
+ uap->sgid, sizeof(cred->cr_svgid));
+struct issetugid_args {
+ int dummy;
+#endif
+/* ARGSUSED */
+int
+sys_issetugid(struct thread *td, struct issetugid_args *uap)
+ * Note: OpenBSD sets a P_SUGIDEXEC flag set at execve() time,
+ * we use P_SUGID because we consider changing the owners as
+ * "tainting" as well.
+ * This is significant for procs that start as root and "become"
+ * a user without an exec - programs cannot know *everything*
+ * that libc *might* have put in their data segment.
+ td->td_retval[0] = (p->p_flag & P_SUGID) ? 1 : 0;
+ return (0);
+int
+sys___setugid(struct thread *td, struct __setugid_args *uap)
+#ifdef REGRESSION
+ struct proc *p;
+ p = td->td_proc;
+ switch (uap->flag) {
+ case 0:
+ PROC_LOCK(p);
+ p->p_flag &= ~P_SUGID;
+ PROC_UNLOCK(p);
+ return (0);
+ case 1:
+ PROC_LOCK(p);
+ p->p_flag |= P_SUGID;
+ PROC_UNLOCK(p);
+ return (0);
+ default:
+ return (EINVAL);
+#else /* !REGRESSION */
+ return (ENOSYS);
+#endif /* REGRESSION */
+ * Check if gid is a member of the group set.
+int
+groupmember(gid_t gid, struct ucred *cred)
+ int l;
+ int h;
+ int m;
+ if (cred->cr_groups[0] == gid)
+ return(1);
+ * If gid was not our primary group, perform a binary search
+ * of the supplemental groups. This is possible because we
+ * sort the groups in crsetgroups().
+ l = 1;
+ h = cred->cr_ngroups;
+ while (l < h) {
+ m = l + ((h - l) / 2);
+ if (cred->cr_groups[m] < gid)
+ l = m + 1;
+ else
+ h = m;
+ if ((l < cred->cr_ngroups) && (cred->cr_groups[l] == gid))
+ return (1);
+ return (0);
+ * Test the active securelevel against a given level. securelevel_gt()
+ * implements (securelevel > level). securelevel_ge() implements
+ * (securelevel >= level). Note that the logic is inverted -- these
+ * functions return EPERM on "success" and 0 on "failure".
+ * Due to care taken when setting the securelevel, we know that no jail will
+ * be less secure that its parent (or the physical system), so it is sufficient
+ * to test the current jail only.
+ * XXXRW: Possibly since this has to do with privilege, it should move to
+ * kern_priv.c.
+int
+securelevel_gt(struct ucred *cr, int level)
+ return (cr->cr_prison->pr_securelevel > level ? EPERM : 0);
+int
+securelevel_ge(struct ucred *cr, int level)
+ return (cr->cr_prison->pr_securelevel >= level ? EPERM : 0);
+ * 'see_other_uids' determines whether or not visibility of processes
+ * and sockets with credentials holding different real uids is possible
+ * using a variety of system MIBs.
+ * XXX: data declarations should be together near the beginning of the file.
+static int see_other_uids = 1;
+SYSCTL_INT(_security_bsd, OID_AUTO, see_other_uids, CTLFLAG_RW,
+ &see_other_uids, 0,
+ "Unprivileged processes may see subjects/objects with different real uid");
+ * Determine if u1 "can see" the subject specified by u2, according to the
+ * 'see_other_uids' policy.
+ * Returns: 0 for permitted, ESRCH otherwise
+ * Locks: none
+ * References: *u1 and *u2 must not change during the call
+ * u1 may equal u2, in which case only one reference is required
+int
+cr_canseeotheruids(struct ucred *u1, struct ucred *u2)
+ if (!see_other_uids && u1->cr_ruid != u2->cr_ruid) {
+ if (priv_check_cred(u1, PRIV_SEEOTHERUIDS, 0) != 0)
+ return (ESRCH);
+ return (0);
+ * 'see_other_gids' determines whether or not visibility of processes
+ * and sockets with credentials holding different real gids is possible
+static int see_other_gids = 1;
+SYSCTL_INT(_security_bsd, OID_AUTO, see_other_gids, CTLFLAG_RW,
+ &see_other_gids, 0,
+ "Unprivileged processes may see subjects/objects with different real gid");
+ * Determine if u1 can "see" the subject specified by u2, according to the
+ * 'see_other_gids' policy.
+ * Locks: none
+int
+cr_canseeothergids(struct ucred *u1, struct ucred *u2)
+ int i, match;
+ if (!see_other_gids) {
+ match = 0;
+ for (i = 0; i < u1->cr_ngroups; i++) {
+ if (groupmember(u1->cr_groups[i], u2))
+ match = 1;
+ if (match)
+ break;
+ if (!match) {
+ if (priv_check_cred(u1, PRIV_SEEOTHERGIDS, 0) != 0)
+ return (ESRCH);
+ return (0);
+ * 'see_jail_proc' determines whether or not visibility of processes and
+ * sockets with credentials holding different jail ids is possible using a
+ * variety of system MIBs.
+static int see_jail_proc = 1;
+SYSCTL_INT(_security_bsd, OID_AUTO, see_jail_proc, CTLFLAG_RW,
+ &see_jail_proc, 0,
+ "Unprivileged processes may see subjects/objects with different jail ids");
+ * 'see_jail_proc' policy.
+ * Locks: none
+int
+cr_canseejailproc(struct ucred *u1, struct ucred *u2)
+ if (u1->cr_uid == 0)
+ return (0);
+ return (!see_jail_proc && u1->cr_prison != u2->cr_prison ? ESRCH : 0);
+ * Determine if u1 "can see" the subject specified by u2.
+ * Returns: 0 for permitted, an errno value otherwise
+ * Locks: none
+int
+cr_cansee(struct ucred *u1, struct ucred *u2)
+ int error;
+ if ((error = prison_check(u1, u2)))
+ return (error);
+#ifdef MAC
+ if ((error = mac_cred_check_visible(u1, u2)))
+ return (error);
+#endif
+ if ((error = cr_canseeotheruids(u1, u2)))
+ return (error);
+ if ((error = cr_canseeothergids(u1, u2)))
+ return (error);
+ if ((error = cr_canseejailproc(u1, u2)))
+ return (error);
+ return (0);
+ * Determine if td "can see" the subject specified by p.
+ * Locks: Sufficient locks to protect p->p_ucred must be held. td really
+ * should be curthread.
+ * References: td and p must be valid for the lifetime of the call
+int
+p_cansee(struct thread *td, struct proc *p)
+ /* Wrap cr_cansee() for all functionality. */
+ KASSERT(td == curthread, ("%s: td not curthread", __func__));
+ PROC_LOCK_ASSERT(p, MA_OWNED);
+ return (cr_cansee(td->td_ucred, p->p_ucred));
+ * 'conservative_signals' prevents the delivery of a broad class of
+ * signals by unprivileged processes to processes that have changed their
+ * credentials since the last invocation of execve(). This can prevent
+ * the leakage of cached information or retained privileges as a result
+ * of a common class of signal-related vulnerabilities. However, this
+ * may interfere with some applications that expect to be able to
+ * deliver these signals to peer processes after having given up
+ * privilege.
+static int conservative_signals = 1;
+SYSCTL_INT(_security_bsd, OID_AUTO, conservative_signals, CTLFLAG_RW,
+ &conservative_signals, 0, "Unprivileged processes prevented from "
+ "sending certain signals to processes whose credentials have changed");
+ * Determine whether cred may deliver the specified signal to proc.
+ * Returns: 0 for permitted, an errno value otherwise.
+ * Locks: A lock must be held for proc.
+ * References: cred and proc must be valid for the lifetime of the call.
+int
+cr_cansignal(struct ucred *cred, struct proc *proc, int signum)
+ int error;
+ PROC_LOCK_ASSERT(proc, MA_OWNED);
+ * Jail semantics limit the scope of signalling to proc in the
+ * same jail as cred, if cred is in jail.
+ error = prison_check(cred, proc->p_ucred);
+ if (error)
+ return (error);
+#ifdef MAC
+ if ((error = mac_proc_check_signal(cred, proc, signum)))
+ return (error);
+#endif
+ if ((error = cr_canseeotheruids(cred, proc->p_ucred)))
+ return (error);
+ if ((error = cr_canseeothergids(cred, proc->p_ucred)))
+ return (error);
+ * UNIX signal semantics depend on the status of the P_SUGID
+ * bit on the target process. If the bit is set, then additional
+ * restrictions are placed on the set of available signals.
+ if (conservative_signals && (proc->p_flag & P_SUGID)) {
+ switch (signum) {
+ case 0:
+ case SIGKILL:
+ case SIGINT:
+ case SIGTERM:
+ case SIGALRM:
+ case SIGSTOP:
+ case SIGTTIN:
+ case SIGTTOU:
+ case SIGTSTP:
+ case SIGHUP:
+ case SIGUSR1:
+ case SIGUSR2:
+ * Generally, permit job and terminal control
+ * signals.
+ break;
+ default:
+ /* Not permitted without privilege. */
+ error = priv_check_cred(cred, PRIV_SIGNAL_SUGID, 0);
+ if (error)
+ return (error);
+ * Generally, the target credential's ruid or svuid must match the
+ * subject credential's ruid or euid.
+ if (cred->cr_ruid != proc->p_ucred->cr_ruid &&
+ cred->cr_ruid != proc->p_ucred->cr_svuid &&
+ cred->cr_uid != proc->p_ucred->cr_ruid &&
+ cred->cr_uid != proc->p_ucred->cr_svuid) {
+ error = priv_check_cred(cred, PRIV_SIGNAL_DIFFCRED, 0);
+ if (error)
+ return (error);
+ return (0);
+ * Determine whether td may deliver the specified signal to p.
+ * Locks: Sufficient locks to protect various components of td and p
+ * must be held. td must be curthread, and a lock must be
+ * held for p.
+int
+p_cansignal(struct thread *td, struct proc *p, int signum)
+ if (td->td_proc == p)
+ return (0);
+ * UNIX signalling semantics require that processes in the same
+ * session always be able to deliver SIGCONT to one another,
+ * overriding the remaining protections.
+ /* XXX: This will require an additional lock of some sort. */
+ if (signum == SIGCONT && td->td_proc->p_session == p->p_session)
+ return (0);
+ * Some compat layers use SIGTHR and higher signals for
+ * communication between different kernel threads of the same
+ * process, so that they expect that it's always possible to
+ * deliver them, even for suid applications where cr_cansignal() can
+ * deny such ability for security consideration. It should be
+ * pretty safe to do since the only way to create two processes
+ * with the same p_leader is via rfork(2).
+ if (td->td_proc->p_leader != NULL && signum >= SIGTHR &&
+ signum < SIGTHR + 4 && td->td_proc->p_leader == p->p_leader)
+ return (0);
+ return (cr_cansignal(td->td_ucred, p, signum));
+ * Determine whether td may reschedule p.
+ * be held for p.
+int
+p_cansched(struct thread *td, struct proc *p)
+ int error;
+ return (0);
+ if ((error = prison_check(td->td_ucred, p->p_ucred)))
+ return (error);
+#ifdef MAC
+ if ((error = mac_proc_check_sched(td->td_ucred, p)))
+ return (error);
+#endif
+ if ((error = cr_canseeotheruids(td->td_ucred, p->p_ucred)))
+ return (error);
+ if ((error = cr_canseeothergids(td->td_ucred, p->p_ucred)))
+ return (error);
+ if (td->td_ucred->cr_ruid != p->p_ucred->cr_ruid &&
+ td->td_ucred->cr_uid != p->p_ucred->cr_ruid) {
+ error = priv_check(td, PRIV_SCHED_DIFFCRED);
+ if (error)
+ return (error);
+ return (0);
+ * The 'unprivileged_proc_debug' flag may be used to disable a variety of
+ * unprivileged inter-process debugging services, including some procfs
+ * functionality, ptrace(), and ktrace(). In the past, inter-process
+ * debugging has been involved in a variety of security problems, and sites
+ * not requiring the service might choose to disable it when hardening
+ * systems.
+ * XXX: Should modifying and reading this variable require locking?
+static int unprivileged_proc_debug = 1;
+SYSCTL_INT(_security_bsd, OID_AUTO, unprivileged_proc_debug, CTLFLAG_RW,
+ &unprivileged_proc_debug, 0,
+ "Unprivileged processes may use process debugging facilities");
+ * Determine whether td may debug p.
+ * be held for p.
+int
+p_candebug(struct thread *td, struct proc *p)
+ int credentialchanged, error, grpsubset, i, uidsubset;
+ if (!unprivileged_proc_debug) {
+ error = priv_check(td, PRIV_DEBUG_UNPRIV);
+ if (error)
+ return (error);
+ return (0);
+ return (error);
+#ifdef MAC
+ if ((error = mac_proc_check_debug(td->td_ucred, p)))
+ return (error);
+#endif
+ return (error);
+ return (error);
+ * Is p's group set a subset of td's effective group set? This
+ * includes p's egid, group access list, rgid, and svgid.
+ grpsubset = 1;
+ for (i = 0; i < p->p_ucred->cr_ngroups; i++) {
+ if (!groupmember(p->p_ucred->cr_groups[i], td->td_ucred)) {
+ grpsubset = 0;
+ break;
+ grpsubset = grpsubset &&
+ groupmember(p->p_ucred->cr_rgid, td->td_ucred) &&
+ groupmember(p->p_ucred->cr_svgid, td->td_ucred);
+ * Are the uids present in p's credential equal to td's
+ * effective uid? This includes p's euid, svuid, and ruid.
+ uidsubset = (td->td_ucred->cr_uid == p->p_ucred->cr_uid &&
+ td->td_ucred->cr_uid == p->p_ucred->cr_svuid &&
+ td->td_ucred->cr_uid == p->p_ucred->cr_ruid);
+ * Has the credential of the process changed since the last exec()?
+ credentialchanged = (p->p_flag & P_SUGID);
+ * If p's gids aren't a subset, or the uids aren't a subset,
+ * or the credential has changed, require appropriate privilege
+ * for td to debug p.
+ if (!grpsubset || !uidsubset) {
+ error = priv_check(td, PRIV_DEBUG_DIFFCRED);
+ if (error)
+ return (error);
+ if (credentialchanged) {
+ error = priv_check(td, PRIV_DEBUG_SUGID);
+ if (error)
+ return (error);
+ /* Can't trace init when securelevel > 0. */
+ if (p == initproc) {
+ error = securelevel_gt(td->td_ucred, 0);
+ if (error)
+ return (error);
+ * Can't trace a process that's currently exec'ing.
+ * XXX: Note, this is not a security policy decision, it's a
+ * basic correctness/functionality decision. Therefore, this check
+ * should be moved to the caller's of p_candebug().
+ if ((p->p_flag & P_INEXEC) != 0)
+ return (EBUSY);
+ /* Denied explicitely */
+ if ((p->p_flag2 & P2_NOTRACE) != 0) {
+ error = priv_check(td, PRIV_DEBUG_DENIED);
+ if (error != 0)
+ return (error);
+ return (0);
+ * Determine whether the subject represented by cred can "see" a socket.
+ * Returns: 0 for permitted, ENOENT otherwise.
+int
+cr_canseesocket(struct ucred *cred, struct socket *so)
+ int error;
+ error = prison_check(cred, so->so_cred);
+ if (error)
+ return (ENOENT);
+#ifdef MAC
+ error = mac_socket_check_visible(cred, so);
+ if (error)
+ return (error);
+#endif
+ if (cr_canseeotheruids(cred, so->so_cred))
+ return (ENOENT);
+ if (cr_canseeothergids(cred, so->so_cred))
+ return (ENOENT);
+ return (0);
+ * Determine whether td can wait for the exit of p.
+ * be held for p.
+int
+p_canwait(struct thread *td, struct proc *p)
+ int error;
+ return (error);
+#ifdef MAC
+ if ((error = mac_proc_check_wait(td->td_ucred, p)))
+ return (error);
+#endif
+#if 0
+ /* XXXMAC: This could have odd effects on some shells. */
+ return (error);
+#endif
+ return (0);
+ * Allocate a zeroed cred structure.
+struct ucred *
+crget(void)
+ struct ucred *cr;
+ cr = malloc(sizeof(*cr), M_CRED, M_WAITOK | M_ZERO);
+ refcount_init(&cr->cr_ref, 1);
+#ifdef AUDIT
+ audit_cred_init(cr);
+#endif
+#ifdef MAC
+ mac_cred_init(cr);
+#endif
+ cr->cr_groups = cr->cr_smallgroups;
+ cr->cr_agroups =
+ sizeof(cr->cr_smallgroups) / sizeof(cr->cr_smallgroups[0]);
+ return (cr);
+ * Claim another reference to a ucred structure.
+struct ucred *
+crhold(struct ucred *cr)
+ refcount_acquire(&cr->cr_ref);
+ return (cr);
+ * Free a cred structure. Throws away space when ref count gets to 0.
+void
+crfree(struct ucred *cr)
+ KASSERT(cr->cr_ref > 0, ("bad ucred refcount: %d", cr->cr_ref));
+ KASSERT(cr->cr_ref != 0xdeadc0de, ("dangling reference to ucred"));
+ if (refcount_release(&cr->cr_ref)) {
+ * Some callers of crget(), such as nfs_statfs(),
+ * allocate a temporary credential, but don't
+ * allocate a uidinfo structure.
+ if (cr->cr_uidinfo != NULL)
+ uifree(cr->cr_uidinfo);
+ if (cr->cr_ruidinfo != NULL)
+ uifree(cr->cr_ruidinfo);
+ * Free a prison, if any.
+ if (cr->cr_prison != NULL)
+ prison_free(cr->cr_prison);
+ if (cr->cr_loginclass != NULL)
+ loginclass_free(cr->cr_loginclass);
+#ifdef AUDIT
+ audit_cred_destroy(cr);
+#endif
+#ifdef MAC
+ mac_cred_destroy(cr);
+#endif
+ if (cr->cr_groups != cr->cr_smallgroups)
+ free(cr->cr_groups, M_CRED);
+ free(cr, M_CRED);
+ * Copy a ucred's contents from a template. Does not block.
+void
+crcopy(struct ucred *dest, struct ucred *src)
+ KASSERT(dest->cr_ref == 1, ("crcopy of shared ucred"));
+ bcopy(&src->cr_startcopy, &dest->cr_startcopy,
+ (unsigned)((caddr_t)&src->cr_endcopy -
+ (caddr_t)&src->cr_startcopy));
+ crsetgroups(dest, src->cr_ngroups, src->cr_groups);
+ uihold(dest->cr_uidinfo);
+ uihold(dest->cr_ruidinfo);
+ prison_hold(dest->cr_prison);
+ loginclass_hold(dest->cr_loginclass);
+#ifdef AUDIT
+ audit_cred_copy(src, dest);
+#endif
+#ifdef MAC
+ mac_cred_copy(src, dest);
+#endif
+ * Dup cred struct to a new held one.
+struct ucred *
+crdup(struct ucred *cr)
+ struct ucred *newcr;
+ newcr = crget();
+ crcopy(newcr, cr);
+ return (newcr);
+ * Fill in a struct xucred based on a struct ucred.
+void
+cru2x(struct ucred *cr, struct xucred *xcr)
+ int ngroups;
+ bzero(xcr, sizeof(*xcr));
+ xcr->cr_version = XUCRED_VERSION;
+ xcr->cr_uid = cr->cr_uid;
+ ngroups = MIN(cr->cr_ngroups, XU_NGROUPS);
+ xcr->cr_ngroups = ngroups;
+ bcopy(cr->cr_groups, xcr->cr_groups,
+ ngroups * sizeof(*cr->cr_groups));
+ * Set initial process credentials.
+ * Callers are responsible for providing the reference for provided credentials.
+void
+proc_set_cred_init(struct proc *p, struct ucred *newcred)
+ p->p_ucred = newcred;
+ * Change process credentials.
+ * Callers are responsible for providing the reference for passed credentials
+ * and for freeing old ones.
+ * Process has to be locked except when it does not have credentials (as it
+ * should not be visible just yet) or when newcred is NULL (as this can be
+ * only used when the process is about to be freed, at which point it should
+ * not be visible anymore).
+struct ucred *
+proc_set_cred(struct proc *p, struct ucred *newcred)
+ struct ucred *oldcred;
+ MPASS(p->p_ucred != NULL);
+ if (newcred == NULL)
+ MPASS(p->p_state == PRS_ZOMBIE);
+ else
+ oldcred = p->p_ucred;
+ if (newcred != NULL)
+ PROC_UPDATE_COW(p);
+ return (oldcred);
+struct ucred *
+crcopysafe(struct proc *p, struct ucred *cr)
+ int groups;
+ while (cr->cr_agroups < oldcred->cr_agroups) {
+ groups = oldcred->cr_agroups;
+ PROC_UNLOCK(p);
+ crextend(cr, groups);
+ PROC_LOCK(p);
+ crcopy(cr, oldcred);
+ return (oldcred);
+ * Extend the passed in credential to hold n items.
+void
+crextend(struct ucred *cr, int n)
+ int cnt;
+ /* Truncate? */
+ if (n <= cr->cr_agroups)
+ return;
+ * We extend by 2 each time since we're using a power of two
+ * allocator until we need enough groups to fill a page.
+ * Once we're allocating multiple pages, only allocate as many
+ * as we actually need. The case of processes needing a
+ * non-power of two number of pages seems more likely than
+ * a real world process that adds thousands of groups one at a
+ * time.
+ if ( n < PAGE_SIZE / sizeof(gid_t) ) {
+ if (cr->cr_agroups == 0)
+ cnt = MINALLOCSIZE / sizeof(gid_t);
+ else
+ cnt = cr->cr_agroups * 2;
+ while (cnt < n)
+ cnt *= 2;
+ } else
+ cnt = roundup2(n, PAGE_SIZE / sizeof(gid_t));
+ /* Free the old array. */
+ cr->cr_groups = malloc(cnt * sizeof(gid_t), M_CRED, M_WAITOK | M_ZERO);
+ cr->cr_agroups = cnt;
+ * Copy groups in to a credential, preserving any necessary invariants.
+ * Currently this includes the sorting of all supplemental gids.
+ * crextend() must have been called before hand to ensure sufficient
+ * space is available.
+static void
+crsetgroups_locked(struct ucred *cr, int ngrp, gid_t *groups)
+ int i;
+ int j;
+ gid_t g;
+ KASSERT(cr->cr_agroups >= ngrp, ("cr_ngroups is too small"));
+ bcopy(groups, cr->cr_groups, ngrp * sizeof(gid_t));
+ cr->cr_ngroups = ngrp;
+ * Sort all groups except cr_groups[0] to allow groupmember to
+ * perform a binary search.
+ * XXX: If large numbers of groups become common this should
+ * be replaced with shell sort like linux uses or possibly
+ * heap sort.
+ for (i = 2; i < ngrp; i++) {
+ g = cr->cr_groups[i];
+ for (j = i-1; j >= 1 && g < cr->cr_groups[j]; j--)
+ cr->cr_groups[j + 1] = cr->cr_groups[j];
+ cr->cr_groups[j + 1] = g;
+ * Copy groups in to a credential after expanding it if required.
+ * Truncate the list to (ngroups_max + 1) if it is too large.
+void
+crsetgroups(struct ucred *cr, int ngrp, gid_t *groups)
+ if (ngrp > ngroups_max + 1)
+ ngrp = ngroups_max + 1;
+ crextend(cr, ngrp);
+ crsetgroups_locked(cr, ngrp, groups);
+ * Get login name, if available.
+struct getlogin_args {
+ char *namebuf;
+ u_int namelen;
+#endif
+/* ARGSUSED */
+int
+sys_getlogin(struct thread *td, struct getlogin_args *uap)
+ char login[MAXLOGNAME];
+ size_t len;
+ if (uap->namelen > MAXLOGNAME)
+ uap->namelen = MAXLOGNAME;
+ PROC_LOCK(p);
+ SESS_LOCK(p->p_session);
+ len = strlcpy(login, p->p_session->s_login, uap->namelen) + 1;
+ SESS_UNLOCK(p->p_session);
+ PROC_UNLOCK(p);
+ if (len > uap->namelen)
+ return (ERANGE);
+ return (copyout(login, uap->namebuf, len));
+ * Set login name.
+struct setlogin_args {
+ char *namebuf;
+#endif
+/* ARGSUSED */
+int
+sys_setlogin(struct thread *td, struct setlogin_args *uap)
+ int error;
+ char logintmp[MAXLOGNAME];
+ CTASSERT(sizeof(p->p_session->s_login) >= sizeof(logintmp));
+ error = priv_check(td, PRIV_PROC_SETLOGIN);
+ if (error)
+ return (error);
+ error = copyinstr(uap->namebuf, logintmp, sizeof(logintmp), NULL);
+ if (error != 0) {
+ if (error == ENAMETOOLONG)
+ error = EINVAL;
+ return (error);
+ AUDIT_ARG_LOGIN(logintmp);
+ PROC_LOCK(p);
+ strcpy(p->p_session->s_login, logintmp);
+ PROC_UNLOCK(p);
+ return (0);
+void
+setsugid(struct proc *p)
+ if (!(p->p_pfsflags & PF_ISUGID))
+ p->p_stops = 0;
+ * Change a process's effective uid.
+ * Side effects: newcred->cr_uid and newcred->cr_uidinfo will be modified.
+ * References: newcred must be an exclusive credential reference for the
+ * duration of the call.
+void
+change_euid(struct ucred *newcred, struct uidinfo *euip)
+ newcred->cr_uid = euip->ui_uid;
+ uihold(euip);
+ uifree(newcred->cr_uidinfo);
+ newcred->cr_uidinfo = euip;
+ * Change a process's effective gid.
+ * Side effects: newcred->cr_gid will be modified.
+void
+change_egid(struct ucred *newcred, gid_t egid)
+ newcred->cr_groups[0] = egid;
+ * Change a process's real uid.
+ * Side effects: newcred->cr_ruid will be updated, newcred->cr_ruidinfo
+ * will be updated, and the old and new cr_ruidinfo proc
+ * counts will be updated.
+void
+change_ruid(struct ucred *newcred, struct uidinfo *ruip)
+ (void)chgproccnt(newcred->cr_ruidinfo, -1, 0);
+ newcred->cr_ruid = ruip->ui_uid;
+ uihold(ruip);
+ uifree(newcred->cr_ruidinfo);
+ newcred->cr_ruidinfo = ruip;
+ (void)chgproccnt(newcred->cr_ruidinfo, 1, 0);
+ * Change a process's real gid.
+ * Side effects: newcred->cr_rgid will be updated.
+void
+change_rgid(struct ucred *newcred, gid_t rgid)
+ newcred->cr_rgid = rgid;
+ * Change a process's saved uid.
+ * Side effects: newcred->cr_svuid will be updated.
+void
+change_svuid(struct ucred *newcred, uid_t svuid)
+ newcred->cr_svuid = svuid;
+ * Change a process's saved gid.
+ * Side effects: newcred->cr_svgid will be updated.
+void
+change_svgid(struct ucred *newcred, gid_t svgid)
+ newcred->cr_svgid = svgid;
diff --git a/freebsd/sys/kern/kern_resource.c b/freebsd/sys/kern/kern_resource.c
index 00000000..49b1e0fe
--- /dev/null
+++ b/freebsd/sys/kern/kern_resource.c
@@ -0,0 +1,1539 @@
+ * Copyright (c) 1982, 1986, 1991, 1993
+ * The Regents of the University of California. All rights reserved.
+ * are met:
+ * SUCH DAMAGE.
+ * @(#)kern_resource.c 8.5 (Berkeley) 1/21/94
+#include <sys/file.h>
+#include <sys/rwlock.h>
+#include <sys/sched.h>
+#include <sys/time.h>
+#include <sys/umtx.h>
+#include <vm/vm.h>
+#include <vm/vm_param.h>
+#include <vm/pmap.h>
+#include <vm/vm_map.h>
+static MALLOC_DEFINE(M_PLIMIT, "plimit", "plimit structures");
+static MALLOC_DEFINE(M_UIDINFO, "uidinfo", "uidinfo structures");
+#define UIHASH(uid) (&uihashtbl[(uid) & uihash])
+static struct rwlock uihashtbl_lock;
+static LIST_HEAD(uihashhead, uidinfo) *uihashtbl;
+static u_long uihash; /* size of hash table - 1 */
+static void calcru1(struct proc *p, struct rusage_ext *ruxp,
+ struct timeval *up, struct timeval *sp);
+static int donice(struct thread *td, struct proc *chgp, int n);
+static struct uidinfo *uilookup(uid_t uid);
+static void ruxagg_locked(struct rusage_ext *rux, struct thread *td);
+ * Resource controls and accounting.
+struct getpriority_args {
+ int which;
+ int who;
+#endif
+int
+sys_getpriority(struct thread *td, struct getpriority_args *uap)
+ struct proc *p;
+ struct pgrp *pg;
+ int error, low;
+ error = 0;
+ low = PRIO_MAX + 1;
+ switch (uap->which) {
+ case PRIO_PROCESS:
+ if (uap->who == 0)
+ low = td->td_proc->p_nice;
+ else {
+ p = pfind(uap->who);
+ if (p == NULL)
+ break;
+ if (p_cansee(td, p) == 0)
+ low = p->p_nice;
+ PROC_UNLOCK(p);
+ break;
+ case PRIO_PGRP:
+ sx_slock(&proctree_lock);
+ if (uap->who == 0) {
+ pg = td->td_proc->p_pgrp;
+ PGRP_LOCK(pg);
+ } else {
+ pg = pgfind(uap->who);
+ if (pg == NULL) {
+ sx_sunlock(&proctree_lock);
+ break;
+ LIST_FOREACH(p, &pg->pg_members, p_pglist) {
+ PROC_LOCK(p);
+ if (p->p_state == PRS_NORMAL &&
+ p_cansee(td, p) == 0) {
+ if (p->p_nice < low)
+ low = p->p_nice;
+ PROC_UNLOCK(p);
+ PGRP_UNLOCK(pg);
+ break;
+ case PRIO_USER:
+ uap->who = td->td_ucred->cr_uid;
+ sx_slock(&allproc_lock);
+ FOREACH_PROC_IN_SYSTEM(p) {
+ PROC_LOCK(p);
+ p_cansee(td, p) == 0 &&
+ p->p_ucred->cr_uid == uap->who) {
+ low = p->p_nice;
+ PROC_UNLOCK(p);
+ sx_sunlock(&allproc_lock);
+ break;
+ default:
+ error = EINVAL;
+ break;
+ if (low == PRIO_MAX + 1 && error == 0)
+ error = ESRCH;
+ td->td_retval[0] = low;
+ return (error);
+struct setpriority_args {
+ int which;
+ int who;
+ int prio;
+#endif
+int
+sys_setpriority(struct thread *td, struct setpriority_args *uap)
+ struct proc *curp, *p;
+ struct pgrp *pg;
+ int found = 0, error = 0;
+ curp = td->td_proc;
+ PROC_LOCK(curp);
+ error = donice(td, curp, uap->prio);
+ PROC_UNLOCK(curp);
+ } else {
+ if (p == NULL)
+ break;
+ if (error == 0)
+ error = donice(td, p, uap->prio);
+ PROC_UNLOCK(p);
+ found++;
+ break;
+ case PRIO_PGRP:
+ pg = curp->p_pgrp;
+ PGRP_LOCK(pg);
+ } else {
+ if (pg == NULL) {
+ break;
+ PROC_LOCK(p);
+ found++;
+ PROC_UNLOCK(p);
+ PGRP_UNLOCK(pg);
+ break;
+ case PRIO_USER:
+ PROC_LOCK(p);
+ p->p_ucred->cr_uid == uap->who &&
+ found++;
+ PROC_UNLOCK(p);
+ break;
+ default:
+ error = EINVAL;
+ break;
+ if (found == 0 && error == 0)
+ error = ESRCH;
+ return (error);
+ * Set "nice" for a (whole) process.
+static int
+donice(struct thread *td, struct proc *p, int n)
+ int error;
+ if ((error = p_cansched(td, p)))
+ return (error);
+ if (n > PRIO_MAX)
+ n = PRIO_MAX;
+ if (n < PRIO_MIN)
+ n = PRIO_MIN;
+ if (n < p->p_nice && priv_check(td, PRIV_SCHED_SETPRIORITY) != 0)
+ return (EACCES);
+ sched_nice(p, n);
+ return (0);
+static int unprivileged_idprio;
+SYSCTL_INT(_security_bsd, OID_AUTO, unprivileged_idprio, CTLFLAG_RW,
+ &unprivileged_idprio, 0, "Allow non-root users to set an idle priority");
+ * Set realtime priority for LWP.
+struct rtprio_thread_args {
+ int function;
+ lwpid_t lwpid;
+ struct rtprio *rtp;
+#endif
+int
+sys_rtprio_thread(struct thread *td, struct rtprio_thread_args *uap)
+ struct proc *p;
+ struct rtprio rtp;
+ struct thread *td1;
+ int cierror, error;
+ /* Perform copyin before acquiring locks if needed. */
+ if (uap->function == RTP_SET)
+ cierror = copyin(uap->rtp, &rtp, sizeof(struct rtprio));
+ else
+ cierror = 0;
+ if (uap->lwpid == 0 || uap->lwpid == td->td_tid) {
+ p = td->td_proc;
+ td1 = td;
+ PROC_LOCK(p);
+ } else {
+ /* Only look up thread in current process */
+ td1 = tdfind(uap->lwpid, curproc->p_pid);
+ if (td1 == NULL)
+ return (ESRCH);
+ p = td1->td_proc;
+ switch (uap->function) {
+ case RTP_LOOKUP:
+ if ((error = p_cansee(td, p)))
+ break;
+ pri_to_rtp(td1, &rtp);
+ PROC_UNLOCK(p);
+ return (copyout(&rtp, uap->rtp, sizeof(struct rtprio)));
+ case RTP_SET:
+ if ((error = p_cansched(td, p)) || (error = cierror))
+ break;
+ /* Disallow setting rtprio in most cases if not superuser. */
+ * Realtime priority has to be restricted for reasons which
+ * should be obvious. However, for idleprio processes, there is
+ * a potential for system deadlock if an idleprio process gains
+ * a lock on a resource that other processes need (and the
+ * idleprio process can't run due to a CPU-bound normal
+ * process). Fix me! XXX
+ * This problem is not only related to idleprio process.
+ * A user level program can obtain a file lock and hold it
+ * indefinitely. Additionally, without idleprio processes it is
+ * still conceivable that a program with low priority will never
+ * get to run. In short, allowing this feature might make it
+ * easier to lock a resource indefinitely, but it is not the
+ * only thing that makes it possible.
+ if (RTP_PRIO_BASE(rtp.type) == RTP_PRIO_REALTIME ||
+ (RTP_PRIO_BASE(rtp.type) == RTP_PRIO_IDLE &&
+ unprivileged_idprio == 0)) {
+ error = priv_check(td, PRIV_SCHED_RTPRIO);
+ if (error)
+ break;
+ error = rtp_to_pri(&rtp, td1);
+ break;
+ default:
+ error = EINVAL;
+ break;
+ PROC_UNLOCK(p);
+ return (error);
+ * Set realtime priority.
+struct rtprio_args {
+ int function;
+ pid_t pid;
+#endif
+int
+sys_rtprio(struct thread *td, struct rtprio_args *uap)
+ struct proc *p;
+ struct thread *tdp;
+ else
+ cierror = 0;
+ p = td->td_proc;
+ PROC_LOCK(p);
+ } else {
+ if (p == NULL)
+ return (ESRCH);
+ case RTP_LOOKUP:
+ break;
+ * Return OUR priority if no pid specified,
+ * or if one is, report the highest priority
+ * in the process. There isn't much more you can do as
+ * there is only room to return a single priority.
+ * Note: specifying our own pid is not the same
+ * as leaving it zero.
+ pri_to_rtp(td, &rtp);
+ } else {
+ struct rtprio rtp2;
+ rtp.type = RTP_PRIO_IDLE;
+ rtp.prio = RTP_PRIO_MAX;
+ FOREACH_THREAD_IN_PROC(p, tdp) {
+ pri_to_rtp(tdp, &rtp2);
+ if (rtp2.type < rtp.type ||
+ (rtp2.type == rtp.type &&
+ rtp2.prio < rtp.prio)) {
+ rtp.type = rtp2.type;
+ rtp.prio = rtp2.prio;
+ PROC_UNLOCK(p);
+ case RTP_SET:
+ break;
+ * Disallow setting rtprio in most cases if not superuser.
+ * See the comment in sys_rtprio_thread about idprio
+ * threads holding a lock.
+ !unprivileged_idprio)) {
+ if (error)
+ break;
+ * If we are setting our own priority, set just our
+ * thread but if we are doing another process,
+ * do all the threads on that process. If we
+ * specify our own pid we do the latter.
+ error = rtp_to_pri(&rtp, td);
+ } else {
+ FOREACH_THREAD_IN_PROC(p, td) {
+ if ((error = rtp_to_pri(&rtp, td)) != 0)
+ break;
+ break;
+ default:
+ error = EINVAL;
+ break;
+ PROC_UNLOCK(p);
+ return (error);
+int
+rtp_to_pri(struct rtprio *rtp, struct thread *td)
+ u_char newpri, oldclass, oldpri;
+ switch (RTP_PRIO_BASE(rtp->type)) {
+ case RTP_PRIO_REALTIME:
+ if (rtp->prio > RTP_PRIO_MAX)
+ return (EINVAL);
+ newpri = PRI_MIN_REALTIME + rtp->prio;
+ break;
+ case RTP_PRIO_NORMAL:
+ if (rtp->prio > (PRI_MAX_TIMESHARE - PRI_MIN_TIMESHARE))
+ return (EINVAL);
+ newpri = PRI_MIN_TIMESHARE + rtp->prio;
+ break;
+ case RTP_PRIO_IDLE:
+ return (EINVAL);
+ newpri = PRI_MIN_IDLE + rtp->prio;
+ break;
+ default:
+ return (EINVAL);
+ thread_lock(td);
+ oldclass = td->td_pri_class;
+ sched_class(td, rtp->type); /* XXX fix */
+ oldpri = td->td_user_pri;
+ sched_user_prio(td, newpri);
+ if (td->td_user_pri != oldpri && (oldclass != RTP_PRIO_NORMAL ||
+ td->td_pri_class != RTP_PRIO_NORMAL))
+ sched_prio(td, td->td_user_pri);
+ if (TD_ON_UPILOCK(td) && oldpri != newpri) {
+ critical_enter();
+ thread_unlock(td);
+ umtx_pi_adjust(td, oldpri);
+ critical_exit();
+ } else
+ return (0);
+void
+pri_to_rtp(struct thread *td, struct rtprio *rtp)
+ thread_lock(td);
+ switch (PRI_BASE(td->td_pri_class)) {
+ case PRI_REALTIME:
+ rtp->prio = td->td_base_user_pri - PRI_MIN_REALTIME;
+ break;
+ case PRI_TIMESHARE:
+ rtp->prio = td->td_base_user_pri - PRI_MIN_TIMESHARE;
+ break;
+ case PRI_IDLE:
+ rtp->prio = td->td_base_user_pri - PRI_MIN_IDLE;
+ break;
+ default:
+ break;
+ rtp->type = td->td_pri_class;
+struct osetrlimit_args {
+ u_int which;
+ struct orlimit *rlp;
+#endif
+int
+osetrlimit(struct thread *td, struct osetrlimit_args *uap)
+ struct orlimit olim;
+ struct rlimit lim;
+ int error;
+ if ((error = copyin(uap->rlp, &olim, sizeof(struct orlimit))))
+ return (error);
+ lim.rlim_cur = olim.rlim_cur;
+ lim.rlim_max = olim.rlim_max;
+ error = kern_setrlimit(td, uap->which, &lim);
+ return (error);
+struct ogetrlimit_args {
+ u_int which;
+#endif
+int
+ogetrlimit(struct thread *td, struct ogetrlimit_args *uap)
+ struct rlimit rl;
+ int error;
+ if (uap->which >= RLIM_NLIMITS)
+ return (EINVAL);
+ lim_rlimit(td, uap->which, &rl);
+ * XXX would be more correct to convert only RLIM_INFINITY to the
+ * old RLIM_INFINITY and fail with EOVERFLOW for other larger
+ * values. Most 64->32 and 32->16 conversions, including not
+ * unimportant ones of uids are even more broken than what we
+ * do here (they blindly truncate). We don't do this correctly
+ * here since we have little experience with EOVERFLOW yet.
+ * Elsewhere, getuid() can't fail...
+ olim.rlim_cur = rl.rlim_cur > 0x7fffffff ? 0x7fffffff : rl.rlim_cur;
+ olim.rlim_max = rl.rlim_max > 0x7fffffff ? 0x7fffffff : rl.rlim_max;
+ error = copyout(&olim, uap->rlp, sizeof(olim));
+ return (error);
+#endif /* COMPAT_43 */
+struct __setrlimit_args {
+ u_int which;
+ struct rlimit *rlp;
+#endif
+int
+sys_setrlimit(struct thread *td, struct __setrlimit_args *uap)
+ struct rlimit alim;
+ int error;
+ if ((error = copyin(uap->rlp, &alim, sizeof(struct rlimit))))
+ return (error);
+ error = kern_setrlimit(td, uap->which, &alim);
+ return (error);
+static void
+lim_cb(void *arg)
+ struct rlimit rlim;
+ struct thread *td;
+ struct proc *p;
+ p = arg;
+ * Check if the process exceeds its cpu resource allocation. If
+ * it reaches the max, arrange to kill the process in ast().
+ if (p->p_cpulimit == RLIM_INFINITY)
+ return;
+ PROC_STATLOCK(p);
+ ruxagg(p, td);
+ PROC_STATUNLOCK(p);
+ if (p->p_rux.rux_runtime > p->p_cpulimit * cpu_tickrate()) {
+ lim_rlimit_proc(p, RLIMIT_CPU, &rlim);
+ if (p->p_rux.rux_runtime >= rlim.rlim_max * cpu_tickrate()) {
+ killproc(p, "exceeded maximum CPU limit");
+ } else {
+ if (p->p_cpulimit < rlim.rlim_max)
+ p->p_cpulimit += 5;
+ kern_psignal(p, SIGXCPU);
+ if ((p->p_flag & P_WEXIT) == 0)
+ callout_reset_sbt(&p->p_limco, SBT_1S, 0,
+ lim_cb, p, C_PREL(1));
+int
+kern_setrlimit(struct thread *td, u_int which, struct rlimit *limp)
+ return (kern_proc_setrlimit(td, td->td_proc, which, limp));
+int
+kern_proc_setrlimit(struct thread *td, struct proc *p, u_int which,
+ struct rlimit *limp)
+ struct plimit *newlim, *oldlim;
+ struct rlimit *alimp;
+ struct rlimit oldssiz;
+ int error;
+ if (which >= RLIM_NLIMITS)
+ return (EINVAL);
+ * Preserve historical bugs by treating negative limits as unsigned.
+ if (limp->rlim_cur < 0)
+ limp->rlim_cur = RLIM_INFINITY;
+ if (limp->rlim_max < 0)
+ limp->rlim_max = RLIM_INFINITY;
+ oldssiz.rlim_cur = 0;
+ newlim = lim_alloc();
+ PROC_LOCK(p);
+ oldlim = p->p_limit;
+ alimp = &oldlim->pl_rlimit[which];
+ if (limp->rlim_cur > alimp->rlim_max ||
+ limp->rlim_max > alimp->rlim_max)
+ if ((error = priv_check(td, PRIV_PROC_SETRLIMIT))) {
+ PROC_UNLOCK(p);
+ lim_free(newlim);
+ return (error);
+ if (limp->rlim_cur > limp->rlim_max)
+ limp->rlim_cur = limp->rlim_max;
+ lim_copy(newlim, oldlim);
+ alimp = &newlim->pl_rlimit[which];
+ switch (which) {
+ case RLIMIT_CPU:
+ if (limp->rlim_cur != RLIM_INFINITY &&
+ p->p_cpulimit == RLIM_INFINITY)
+ p->p_cpulimit = limp->rlim_cur;
+ break;
+ case RLIMIT_DATA:
+ if (limp->rlim_cur > maxdsiz)
+ limp->rlim_cur = maxdsiz;
+ if (limp->rlim_max > maxdsiz)
+ limp->rlim_max = maxdsiz;
+ break;
+ case RLIMIT_STACK:
+ if (limp->rlim_cur > maxssiz)
+ limp->rlim_cur = maxssiz;
+ if (limp->rlim_max > maxssiz)
+ limp->rlim_max = maxssiz;
+ oldssiz = *alimp;
+ if (p->p_sysent->sv_fixlimit != NULL)
+ p->p_sysent->sv_fixlimit(&oldssiz,
+ RLIMIT_STACK);
+ break;
+ case RLIMIT_NOFILE:
+ if (limp->rlim_cur > maxfilesperproc)
+ limp->rlim_cur = maxfilesperproc;
+ if (limp->rlim_max > maxfilesperproc)
+ limp->rlim_max = maxfilesperproc;
+ break;
+ case RLIMIT_NPROC:
+ if (limp->rlim_cur > maxprocperuid)
+ limp->rlim_cur = maxprocperuid;
+ if (limp->rlim_max > maxprocperuid)
+ limp->rlim_max = maxprocperuid;
+ if (limp->rlim_cur < 1)
+ limp->rlim_cur = 1;
+ if (limp->rlim_max < 1)
+ limp->rlim_max = 1;
+ break;
+ p->p_sysent->sv_fixlimit(limp, which);
+ *alimp = *limp;
+ p->p_limit = newlim;
+ PROC_UNLOCK(p);
+ lim_free(oldlim);
+ if (which == RLIMIT_STACK &&
+ * Skip calls from exec_new_vmspace(), done when stack is
+ * not mapped yet.
+ (td != curthread || (p->p_flag & P_INEXEC) == 0)) {
+ * Stack is allocated to the max at exec time with only
+ * "rlim_cur" bytes accessible. If stack limit is going
+ * up make more accessible, if going down make inaccessible.
+ if (limp->rlim_cur != oldssiz.rlim_cur) {
+ vm_offset_t addr;
+ vm_size_t size;
+ vm_prot_t prot;
+ if (limp->rlim_cur > oldssiz.rlim_cur) {
+ prot = p->p_sysent->sv_stackprot;
+ size = limp->rlim_cur - oldssiz.rlim_cur;
+ addr = p->p_sysent->sv_usrstack -
+ limp->rlim_cur;
+ } else {
+ prot = VM_PROT_NONE;
+ size = oldssiz.rlim_cur - limp->rlim_cur;
+ oldssiz.rlim_cur;
+ addr = trunc_page(addr);
+ size = round_page(size);
+ (void)vm_map_protect(&p->p_vmspace->vm_map,
+ addr, addr + size, prot, FALSE);
+ return (0);
+struct __getrlimit_args {
+ u_int which;
+#endif
+/* ARGSUSED */
+int
+sys_getrlimit(struct thread *td, struct __getrlimit_args *uap)
+ int error;
+ return (EINVAL);
+ lim_rlimit(td, uap->which, &rlim);
+ error = copyout(&rlim, uap->rlp, sizeof(struct rlimit));
+ return (error);
+ * Transform the running time and tick information for children of proc p
+ * into user and system time usage.
+void
+calccru(struct proc *p, struct timeval *up, struct timeval *sp)
+ calcru1(p, &p->p_crux, up, sp);
+ * Transform the running time and tick information in proc p into user
+ * and system time usage. If appropriate, include the current time slice
+ * on this CPU.
+void
+calcru(struct proc *p, struct timeval *up, struct timeval *sp)
+ uint64_t runtime, u;
+ PROC_STATLOCK_ASSERT(p, MA_OWNED);
+ * If we are getting stats for the current process, then add in the
+ * stats that this thread has accumulated in its current time slice.
+ * We reset the thread and CPU state as if we had performed a context
+ * switch right here.
+ td = curthread;
+ if (td->td_proc == p) {
+ u = cpu_ticks();
+ runtime = u - PCPU_GET(switchtime);
+ td->td_runtime += runtime;
+ td->td_incruntime += runtime;
+ PCPU_SET(switchtime, u);
+ /* Make sure the per-thread stats are current. */
+ if (td->td_incruntime == 0)
+ continue;
+ ruxagg(p, td);
+ calcru1(p, &p->p_rux, up, sp);
+/* Collect resource usage for a single thread. */
+void
+rufetchtd(struct thread *td, struct rusage *ru)
+ struct proc *p;
+ p = td->td_proc;
+ THREAD_LOCK_ASSERT(td, MA_OWNED);
+ * If we are getting stats for the current thread, then add in the
+ if (td == curthread) {
+ u = cpu_ticks();
+ ruxagg(p, td);
+ *ru = td->td_ru;
+ calcru1(p, &td->td_rux, &ru->ru_utime, &ru->ru_stime);
+/* XXX: the MI version is too slow to use: */
+#ifndef __HAVE_INLINE_FLSLL
+#define flsll(x) (fls((x) >> 32) != 0 ? fls((x) >> 32) + 32 : fls(x))
+#endif
+static uint64_t
+mul64_by_fraction(uint64_t a, uint64_t b, uint64_t c)
+ uint64_t acc, bh, bl;
+ int i, s, sa, sb;
+ * Calculate (a * b) / c accurately enough without overflowing. c
+ * must be nonzero, and its top bit must be 0. a or b must be
+ * <= c, and the implementation is tuned for b <= c.
+ * The comments about times are for use in calcru1() with units of
+ * microseconds for 'a' and stathz ticks at 128 Hz for b and c.
+ * Let n be the number of top zero bits in c. Each iteration
+ * either returns, or reduces b by right shifting it by at least n.
+ * The number of iterations is at most 1 + 64 / n, and the error is
+ * at most the number of iterations.
+ * It is very unusual to need even 2 iterations. Previous
+ * implementations overflowed essentially by returning early in the
+ * first iteration, with n = 38 giving overflow at 105+ hours and
+ * n = 32 giving overlow at at 388+ days despite a more careful
+ * calculation. 388 days is a reasonable uptime, and the calculation
+ * needs to work for the uptime times the number of CPUs since 'a'
+ * is per-process.
+ if (a >= (uint64_t)1 << 63)
+ return (0); /* Unsupported arg -- can't happen. */
+ acc = 0;
+ for (i = 0; i < 128; i++) {
+ sa = flsll(a);
+ sb = flsll(b);
+ if (sa + sb <= 64)
+ /* Up to 105 hours on first iteration. */
+ return (acc + (a * b) / c);
+ if (a >= c) {
+ * This reduction is based on a = q * c + r, with the
+ * remainder r < c. 'a' may be large to start, and
+ * moving bits from b into 'a' at the end of the loop
+ * sets the top bit of 'a', so the reduction makes
+ * significant progress.
+ acc += (a / c) * b;
+ a %= c;
+ sa = flsll(a);
+ /* Up to 388 days on first iteration. */
+ * This step writes a * b as a * ((bh << s) + bl) =
+ * a * (bh << s) + a * bl = (a << s) * bh + a * bl. The 2
+ * additive terms are handled separately. Splitting in
+ * this way is linear except for rounding errors.
+ * s = 64 - sa is the maximum such that a << s fits in 64
+ * bits. Since a < c and c has at least 1 zero top bit,
+ * sa < 64 and s > 0. Thus this step makes progress by
+ * reducing b (it increases 'a', but taking remainders on
+ * the next iteration completes the reduction).
+ * Finally, the choice for s is just what is needed to keep
+ * a * bl from overflowing, so we don't need complications
+ * like a recursive call mul64_by_fraction(a, bl, c) to
+ * handle the second additive term.
+ s = 64 - sa;
+ bh = b >> s;
+ bl = b - (bh << s);
+ acc += (a * bl) / c;
+ a <<= s;
+ b = bh;
+ return (0); /* Algorithm failure -- can't happen. */
+static void
+calcru1(struct proc *p, struct rusage_ext *ruxp, struct timeval *up,
+ struct timeval *sp)
+ /* {user, system, interrupt, total} {ticks, usec}: */
+ uint64_t ut, uu, st, su, it, tt, tu;
+ ut = ruxp->rux_uticks;
+ st = ruxp->rux_sticks;
+ it = ruxp->rux_iticks;
+ tt = ut + st + it;
+ if (tt == 0) {
+ /* Avoid divide by zero */
+ st = 1;
+ tt = 1;
+ tu = cputick2usec(ruxp->rux_runtime);
+ if ((int64_t)tu < 0) {
+ /* XXX: this should be an assert /phk */
+ printf("calcru: negative runtime of %jd usec for pid %d (%s)\n",
+ (intmax_t)tu, p->p_pid, p->p_comm);
+ tu = ruxp->rux_tu;
+ /* Subdivide tu. Avoid overflow in the multiplications. */
+ if (__predict_true(tu <= ((uint64_t)1 << 38) && tt <= (1 << 26))) {
+ /* Up to 76 hours when stathz is 128. */
+ uu = (tu * ut) / tt;
+ su = (tu * st) / tt;
+ } else {
+ uu = mul64_by_fraction(tu, ut, tt);
+ su = mul64_by_fraction(tu, st, tt);
+ if (tu >= ruxp->rux_tu) {
+ * The normal case, time increased.
+ * Enforce monotonicity of bucketed numbers.
+ if (uu < ruxp->rux_uu)
+ uu = ruxp->rux_uu;
+ if (su < ruxp->rux_su)
+ su = ruxp->rux_su;
+ } else if (tu + 3 > ruxp->rux_tu || 101 * tu > 100 * ruxp->rux_tu) {
+ * When we calibrate the cputicker, it is not uncommon to
+ * see the presumably fixed frequency increase slightly over
+ * time as a result of thermal stabilization and NTP
+ * discipline (of the reference clock). We therefore ignore
+ * a bit of backwards slop because we expect to catch up
+ * shortly. We use a 3 microsecond limit to catch low
+ * counts and a 1% limit for high counts.
+ } else { /* tu < ruxp->rux_tu */
+ * What happened here was likely that a laptop, which ran at
+ * a reduced clock frequency at boot, kicked into high gear.
+ * The wisdom of spamming this message in that case is
+ * dubious, but it might also be indicative of something
+ * serious, so lets keep it and hope laptops can be made
+ * more truthful about their CPU speed via ACPI.
+ printf("calcru: runtime went backwards from %ju usec "
+ "to %ju usec for pid %d (%s)\n",
+ (uintmax_t)ruxp->rux_tu, (uintmax_t)tu,
+ p->p_pid, p->p_comm);
+ ruxp->rux_uu = uu;
+ ruxp->rux_su = su;
+ ruxp->rux_tu = tu;
+ up->tv_sec = uu / 1000000;
+ up->tv_usec = uu % 1000000;
+ sp->tv_sec = su / 1000000;
+ sp->tv_usec = su % 1000000;
+#ifndef _SYS_SYSPROTO_H_
+struct getrusage_args {
+ int who;
+ struct rusage *rusage;
+#endif
+int
+sys_getrusage(struct thread *td, struct getrusage_args *uap)
+ struct rusage ru;
+ int error;
+ error = kern_getrusage(td, uap->who, &ru);
+ if (error == 0)
+ error = copyout(&ru, uap->rusage, sizeof(struct rusage));
+ return (error);
+int
+kern_getrusage(struct thread *td, int who, struct rusage *rup)
+ struct proc *p;
+ int error;
+ error = 0;
+ p = td->td_proc;
+ PROC_LOCK(p);
+ switch (who) {
+ case RUSAGE_SELF:
+ rufetchcalc(p, rup, &rup->ru_utime,
+ &rup->ru_stime);
+ break;
+ case RUSAGE_CHILDREN:
+ *rup = p->p_stats->p_cru;
+ calccru(p, &rup->ru_utime, &rup->ru_stime);
+ break;
+ case RUSAGE_THREAD:
+ PROC_STATLOCK(p);
+ thread_lock(td);
+ rufetchtd(td, rup);
+ break;
+ default:
+ error = EINVAL;
+ PROC_UNLOCK(p);
+ return (error);
+void
+rucollect(struct rusage *ru, struct rusage *ru2)
+ long *ip, *ip2;
+ int i;
+ if (ru->ru_maxrss < ru2->ru_maxrss)
+ ru->ru_maxrss = ru2->ru_maxrss;
+ ip = &ru->ru_first;
+ ip2 = &ru2->ru_first;
+ for (i = &ru->ru_last - &ru->ru_first; i >= 0; i--)
+ *ip++ += *ip2++;
+void
+ruadd(struct rusage *ru, struct rusage_ext *rux, struct rusage *ru2,
+ struct rusage_ext *rux2)
+ rux->rux_runtime += rux2->rux_runtime;
+ rux->rux_uticks += rux2->rux_uticks;
+ rux->rux_sticks += rux2->rux_sticks;
+ rux->rux_iticks += rux2->rux_iticks;
+ rux->rux_uu += rux2->rux_uu;
+ rux->rux_su += rux2->rux_su;
+ rux->rux_tu += rux2->rux_tu;
+ rucollect(ru, ru2);
+ * Aggregate tick counts into the proc's rusage_ext.
+static void
+ruxagg_locked(struct rusage_ext *rux, struct thread *td)
+ PROC_STATLOCK_ASSERT(td->td_proc, MA_OWNED);
+ rux->rux_runtime += td->td_incruntime;
+ rux->rux_uticks += td->td_uticks;
+ rux->rux_sticks += td->td_sticks;
+ rux->rux_iticks += td->td_iticks;
+void
+ruxagg(struct proc *p, struct thread *td)
+ thread_lock(td);
+ ruxagg_locked(&p->p_rux, td);
+ ruxagg_locked(&td->td_rux, td);
+ td->td_incruntime = 0;
+ td->td_uticks = 0;
+ td->td_iticks = 0;
+ td->td_sticks = 0;
+ * Update the rusage_ext structure and fetch a valid aggregate rusage
+ * for proc p if storage for one is supplied.
+void
+rufetch(struct proc *p, struct rusage *ru)
+ *ru = p->p_ru;
+ if (p->p_numthreads > 0) {
+ ruxagg(p, td);
+ rucollect(ru, &td->td_ru);
+ * Atomically perform a rufetch and a calcru together.
+ * Consumers, can safely assume the calcru is executed only once
+ * rufetch is completed.
+void
+rufetchcalc(struct proc *p, struct rusage *ru, struct timeval *up,
+ PROC_STATLOCK(p);
+ rufetch(p, ru);
+ calcru(p, up, sp);
+ * Allocate a new resource limits structure and initialize its
+ * reference count and mutex pointer.
+struct plimit *
+lim_alloc()
+ struct plimit *limp;
+ limp = malloc(sizeof(struct plimit), M_PLIMIT, M_WAITOK);
+ refcount_init(&limp->pl_refcnt, 1);
+ return (limp);
+struct plimit *
+lim_hold(struct plimit *limp)
+ refcount_acquire(&limp->pl_refcnt);
+ return (limp);
+void
+lim_fork(struct proc *p1, struct proc *p2)
+ PROC_LOCK_ASSERT(p1, MA_OWNED);
+ PROC_LOCK_ASSERT(p2, MA_OWNED);
+ p2->p_limit = lim_hold(p1->p_limit);
+ callout_init_mtx(&p2->p_limco, &p2->p_mtx, 0);
+ if (p1->p_cpulimit != RLIM_INFINITY)
+ callout_reset_sbt(&p2->p_limco, SBT_1S, 0,
+ lim_cb, p2, C_PREL(1));
+void
+lim_free(struct plimit *limp)
+ if (refcount_release(&limp->pl_refcnt))
+ free((void *)limp, M_PLIMIT);
+ * Make a copy of the plimit structure.
+ * We share these structures copy-on-write after fork.
+void
+lim_copy(struct plimit *dst, struct plimit *src)
+ KASSERT(dst->pl_refcnt <= 1, ("lim_copy to shared limit"));
+ bcopy(src->pl_rlimit, dst->pl_rlimit, sizeof(src->pl_rlimit));
+ * Return the hard limit for a particular system resource. The
+ * which parameter specifies the index into the rlimit array.
+rlim_t
+lim_max(struct thread *td, int which)
+ struct rlimit rl;
+ lim_rlimit(td, which, &rl);
+ return (rl.rlim_max);
+rlim_t
+lim_max_proc(struct proc *p, int which)
+ struct rlimit rl;
+ lim_rlimit_proc(p, which, &rl);
+ * Return the current (soft) limit for a particular system resource.
+ * The which parameter which specifies the index into the rlimit array
+rlim_t
+lim_cur(struct thread *td, int which)
+ struct rlimit rl;
+ return (rl.rlim_cur);
+rlim_t
+lim_cur_proc(struct proc *p, int which)
+ struct rlimit rl;
+ * Return a copy of the entire rlimit structure for the system limit
+ * specified by 'which' in the rlimit structure pointed to by 'rlp'.
+void
+lim_rlimit(struct thread *td, int which, struct rlimit *rlp)
+ struct proc *p = td->td_proc;
+ MPASS(td == curthread);
+ KASSERT(which >= 0 && which < RLIM_NLIMITS,
+ ("request for invalid resource limit"));
+ *rlp = td->td_limit->pl_rlimit[which];
+ p->p_sysent->sv_fixlimit(rlp, which);
+void
+lim_rlimit_proc(struct proc *p, int which, struct rlimit *rlp)
+ *rlp = p->p_limit->pl_rlimit[which];
+void
+uihashinit()
+ uihashtbl = hashinit(maxproc / 16, M_UIDINFO, &uihash);
+ rw_init(&uihashtbl_lock, "uidinfo hash");
+ * Look up a uidinfo struct for the parameter uid.
+ * uihashtbl_lock must be locked.
+ * Increase refcount on uidinfo struct returned.
+uilookup(uid_t uid)
+ struct uihashhead *uipp;
+ struct uidinfo *uip;
+ rw_assert(&uihashtbl_lock, RA_LOCKED);
+ uipp = UIHASH(uid);
+ LIST_FOREACH(uip, uipp, ui_hash)
+ if (uip->ui_uid == uid) {
+ uihold(uip);
+ break;
+ return (uip);
+ * Find or allocate a struct uidinfo for a particular uid.
+ * Returns with uidinfo struct referenced.
+ * uifree() should be called on a struct uidinfo when released.
+struct uidinfo *
+uifind(uid_t uid)
+ struct uidinfo *new_uip, *uip;
+ struct ucred *cred;
+ cred = curthread->td_ucred;
+ if (cred->cr_uidinfo->ui_uid == uid) {
+ uip = cred->cr_uidinfo;
+ uihold(uip);
+ return (uip);
+ } else if (cred->cr_ruidinfo->ui_uid == uid) {
+ uip = cred->cr_ruidinfo;
+ uihold(uip);
+ return (uip);
+ rw_rlock(&uihashtbl_lock);
+ uip = uilookup(uid);
+ rw_runlock(&uihashtbl_lock);
+ if (uip != NULL)
+ return (uip);
+ new_uip = malloc(sizeof(*new_uip), M_UIDINFO, M_WAITOK | M_ZERO);
+ racct_create(&new_uip->ui_racct);
+ refcount_init(&new_uip->ui_ref, 1);
+ new_uip->ui_uid = uid;
+ rw_wlock(&uihashtbl_lock);
+ * There's a chance someone created our uidinfo while we
+ * were in malloc and not holding the lock, so we have to
+ * make sure we don't insert a duplicate uidinfo.
+ if ((uip = uilookup(uid)) == NULL) {
+ LIST_INSERT_HEAD(UIHASH(uid), new_uip, ui_hash);
+ rw_wunlock(&uihashtbl_lock);
+ uip = new_uip;
+ } else {
+ racct_destroy(&new_uip->ui_racct);
+ free(new_uip, M_UIDINFO);
+ return (uip);
+ * Place another refcount on a uidinfo struct.
+void
+uihold(struct uidinfo *uip)
+ refcount_acquire(&uip->ui_ref);
+ * Since uidinfo structs have a long lifetime, we use an
+ * opportunistic refcounting scheme to avoid locking the lookup hash
+ * for each release.
+ * If the refcount hits 0, we need to free the structure,
+ * which means we need to lock the hash.
+ * Optimal case:
+ * After locking the struct and lowering the refcount, if we find
+ * that we don't need to free, simply unlock and return.
+ * Suboptimal case:
+ * If refcount lowering results in need to free, bump the count
+ * back up, lose the lock and acquire the locks in the proper
+ * order to try again.
+void
+uifree(struct uidinfo *uip)
+ int old;
+ /* Prepare for optimal case. */
+ old = uip->ui_ref;
+ if (old > 1 && atomic_cmpset_int(&uip->ui_ref, old, old - 1))
+ return;
+ /* Prepare for suboptimal case. */
+ if (refcount_release(&uip->ui_ref) == 0) {
+ return;
+ racct_destroy(&uip->ui_racct);
+ LIST_REMOVE(uip, ui_hash);
+ if (uip->ui_sbsize != 0)
+ printf("freeing uidinfo: uid = %d, sbsize = %ld\n",
+ uip->ui_uid, uip->ui_sbsize);
+ if (uip->ui_proccnt != 0)
+ printf("freeing uidinfo: uid = %d, proccnt = %ld\n",
+ uip->ui_uid, uip->ui_proccnt);
+ if (uip->ui_vmsize != 0)
+ printf("freeing uidinfo: uid = %d, swapuse = %lld\n",
+ uip->ui_uid, (unsigned long long)uip->ui_vmsize);
+ free(uip, M_UIDINFO);
+#ifdef RACCT
+void
+ui_racct_foreach(void (*callback)(struct racct *racct,
+ void *arg2, void *arg3), void (*pre)(void), void (*post)(void),
+ struct uihashhead *uih;
+ if (pre != NULL)
+ (pre)();
+ for (uih = &uihashtbl[uihash]; uih >= uihashtbl; uih--) {
+ LIST_FOREACH(uip, uih, ui_hash) {
+ (callback)(uip->ui_racct, arg2, arg3);
+ if (post != NULL)
+ (post)();
+#endif
+static inline int
+chglimit(struct uidinfo *uip, long *limit, int diff, rlim_t max, const char *name)
+ long new;
+ /* Don't allow them to exceed max, but allow subtraction. */
+ new = atomic_fetchadd_long(limit, (long)diff) + diff;
+ if (diff > 0 && max != 0) {
+ if (new < 0 || new > max) {
+ atomic_subtract_long(limit, (long)diff);
+ return (0);
+ } else if (new < 0)
+ printf("negative %s for uid = %d\n", name, uip->ui_uid);
+ return (1);
+ * Change the count associated with number of processes
+ * a given user is using. When 'max' is 0, don't enforce a limit
+int
+chgproccnt(struct uidinfo *uip, int diff, rlim_t max)
+ return (chglimit(uip, &uip->ui_proccnt, diff, max, "proccnt"));
+ * Change the total socket buffer size a user has used.
+int
+chgsbsize(struct uidinfo *uip, u_int *hiwat, u_int to, rlim_t max)
+ int diff, rv;
+ diff = to - *hiwat;
+ if (diff > 0 && max == 0) {
+ rv = 0;
+ } else {
+ rv = chglimit(uip, &uip->ui_sbsize, diff, max, "sbsize");
+ if (rv != 0)
+ *hiwat = to;
+ return (rv);
+ * Change the count associated with number of pseudo-terminals
+int
+chgptscnt(struct uidinfo *uip, int diff, rlim_t max)
+ return (chglimit(uip, &uip->ui_ptscnt, diff, max, "ptscnt"));
+int
+chgkqcnt(struct uidinfo *uip, int diff, rlim_t max)
+ return (chglimit(uip, &uip->ui_kqcnt, diff, max, "kqcnt"));
+int
+chgumtxcnt(struct uidinfo *uip, int diff, rlim_t max)
+ return (chglimit(uip, &uip->ui_umtxcnt, diff, max, "umtxcnt"));
2.24.1
