[PATCH rtems-libbsd 1/7] rtemsbsd: Catch timeout overflows
Tue Jul 27 21:38:56 UTC 2021
On Tue, Jul 27, 2021 at 2:59 AM <chrisj at rtems.org> wrote:
> From: Chris Johns <chrisj at rtems.org>
> Update #4475
This change could probably use its own ticket.
>  rtemsbsd/rtems/rtems-kernel-timesupport.c | 8 +++++++-
>  1 file changed, 7 insertions(+), 1 deletion(-)
> diff --git a/rtemsbsd/rtems/rtems-kernel-timesupport.c b/rtemsbsd/rtems/rtems-kernel-timesupport.c
> index ef14d1fa..5d290d66 100644
> --- a/rtemsbsd/rtems/rtems-kernel-timesupport.c
> +++ b/rtemsbsd/rtems/rtems-kernel-timesupport.c
> @@ -35,6 +35,7 @@
>  #include <machine/rtems-bsd-kernel-space.h>
> +#include <limits.h>
>  #include <sys/time.h>
>  #include <rtems/score/timespec.h>
> @@ -46,9 +47,14 @@ int
>  tvtohz(struct timeval *tv)
>    struct timespec ts;
> +  uint32_t ticks;
>    ts.tv_sec = tv->tv_sec;
>    ts.tv_nsec = tv->tv_usec * 1000;
> -  return (int) _Timespec_To_ticks( &ts );
> +  ticks = _Timespec_To_ticks( &ts );
> +  if (ticks > INT_MAX)
> +    ticks = INT_MAX;
This changes the behavior to saturating in the overflow case, which is
at least well-defined, but is it the best thing to do?  (I have no
idea.)
> +  return ticks;
> 2.24.1
> devel mailing list
> devel at rtems.org
