[PATCH] closes #3889
Zacchaeus Leung zakthertemsdev at gmail.com
Tue Jul 27 20:49:25 UTC 2021
adds
 cpukit/include/rtems/posix/timer.h        |  1 +
 cpukit/posix/src/psxtimercreate.c         |  5 +-
 cpukit/posix/src/timergettime.c           | 59 +++++++++++++----------
 testsuites/psxtests/psxtimer02/psxtimer.c | 26 ++++++++++
 4 files changed, 63 insertions(+), 28 deletions(-)
diff --git a/cpukit/include/rtems/posix/timer.h b/cpukit/include/rtems/posix/timer.h
index bcbf07a65a..7ae089173a 100644
--- a/cpukit/include/rtems/posix/timer.h
+++ b/cpukit/include/rtems/posix/timer.h
@@ -48,6 +48,7 @@ typedef struct {
   uint32_t          ticks;      /* Number of ticks of the initialization */
   uint32_t          overrun;    /* Number of expirations of the timer    */
   struct timespec   time;       /* Time at which the timer was started   */
+  clockid_t         clock_type; /* The type of timer */
 } POSIX_Timer_Control;
diff --git a/cpukit/posix/src/psxtimercreate.c b/cpukit/posix/src/psxtimercreate.c
index a63cf1d100..5ffdf429b4 100644
--- a/cpukit/posix/src/psxtimercreate.c
+++ b/cpukit/posix/src/psxtimercreate.c
@@ -40,7 +40,7 @@ int timer_create(
   POSIX_Timer_Control *ptimer;
-  if ( clock_id != CLOCK_REALTIME )
+  if ( clock_id != CLOCK_REALTIME && clock_id != CLOCK_MONOTONIC )
     rtems_set_errno_and_return_minus_one( EINVAL );
   if ( !timerid )
@@ -91,7 +91,8 @@ int timer_create(
   ptimer->timer_data.it_value.tv_nsec    = 0;
   ptimer->timer_data.it_interval.tv_sec  = 0;
   ptimer->timer_data.it_interval.tv_nsec = 0;
+  ptimer->clock_type = clock_id;
   _Watchdog_Preinitialize( &ptimer->Timer, _Per_CPU_Get_snapshot() );
   _Watchdog_Initialize( &ptimer->Timer, _POSIX_Timer_TSR );
   _Objects_Open_u32(&_POSIX_Timer_Information, &ptimer->Object, 0);
diff --git a/cpukit/posix/src/timergettime.c b/cpukit/posix/src/timergettime.c
index ee2a566f0e..2576d7ba95 100644
--- a/cpukit/posix/src/timergettime.c
+++ b/cpukit/posix/src/timergettime.c
@@ -13,8 +13,6 @@
  *  On-Line Applications Research Corporation (OAR).
  *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
 #ifdef HAVE_CONFIG_H
@@ -28,6 +26,7 @@
 #include <rtems/seterr.h>
+#include <rtems/timespec.h>
  *          - When a timer is initialized, the value of the time in
@@ -35,39 +34,47 @@
  *          - When this function is called, it returns the difference
  *            between the current time and the initialization time.
 int timer_gettime(
   timer_t            timerid,
   struct itimerspec *value
-  ISR_lock_Context     lock_context;
-  uint64_t             now;
-  uint32_t             remaining;
+  ISR_lock_Context lock_context;
+  Per_CPU_Control *cpu;
+  struct timespec now;
+  struct timespec expire;
+  struct timespec result;
-  if ( !value )
+  if ( !value )
-  ptimer = _POSIX_Timer_Get( timerid, &lock_context );
-  if ( ptimer != NULL ) {
-    Per_CPU_Control *cpu;
-    cpu = _POSIX_Timer_Acquire_critical( ptimer, &lock_context );
-    now = cpu->Watchdog.ticks;
-    if ( now < ptimer->Timer.expire ) {
-      remaining = (uint32_t) ( ptimer->Timer.expire - now );
-    } else {
-      remaining = 0;
+  ptimer = _POSIX_Timer_Get(timerid, &lock_context);
+  if ( ptimer == NULL ) {
+    rtems_set_errno_and_return_minus_one( EINVAL );
-    _Timespec_From_ticks( remaining, &value->it_value );
-    value->it_interval = ptimer->timer_data.it_interval;
+  cpu = _POSIX_Timer_Acquire_critical( ptimer, &lock_context ) ;
+  rtems_timespec_from_ticks( ptimer->Timer.expire, &expire) ;
-    _POSIX_Timer_Release( cpu, &lock_context );
-    return 0;
+  if (ptimer->clock_type == CLOCK_MONOTONIC) {
+  _Timecounter_Nanouptime( &now );
+  if (ptimer->clock_type == CLOCK_REALTIME) {
+    _TOD_Get( &now );
-  rtems_set_errno_and_return_minus_one( EINVAL );
+ if( rtems_timespec_less_than( &now, &expire ) ) {
+      rtems_timespec_subtract(&now, &expire, &result);
+    } else {
+      result.tv_nsec = 0;
+      result.tv_sec  = 0;
+  value->it_value=result;
+  value->it_interval = ptimer->timer_data.it_interval;
+  _POSIX_Timer_Release(cpu, &lock_context);
+  return 0;
\ No newline at end of file
diff --git a/testsuites/psxtests/psxtimer02/psxtimer.c b/testsuites/psxtests/psxtimer02/psxtimer.c
index 9f79d33c42..c07f5422e0 100644
--- a/testsuites/psxtests/psxtimer02/psxtimer.c
+++ b/testsuites/psxtests/psxtimer02/psxtimer.c
@@ -127,6 +127,32 @@ void *POSIX_Init (
   status = timer_delete( timer );
   fatal_posix_service_status_errno( status, EINVAL, "bad id" );
+  puts( "timer_create (montonic) - bad timer id pointer - EINVAL" );
+  status = timer_create( CLOCK_MONOTONIC, &event, NULL );
+  fatal_posix_service_status_errno( status, EINVAL, "bad timer id" );
+  puts( "timer_create (montonic) - OK" );
+  status = timer_create( CLOCK_MONOTONIC, NULL, &timer );
+  posix_service_failed( status, "timer_create OK" );
+  puts( "timer_create (montonic)  - too many - EAGAIN" );
+  status = timer_create( CLOCK_MONOTONIC, NULL, &timer1 );
+  fatal_posix_service_status_errno( status, EAGAIN, "too many" );
+  clock_gettime( CLOCK_MONOTONIC, &now );
+  itimer.it_value = now;
+  itimer.it_value.tv_sec = itimer.it_value.tv_sec - 1;
+  puts( "timer_settime  (montonic) - bad itimer value - previous time - EINVAL" );
+  status = timer_settime( timer, TIMER_ABSTIME, &itimer, NULL );
+  fatal_posix_service_status_errno( status, EINVAL, "bad itimer value #3" );
+  itimer.it_value.tv_sec = itimer.it_value.tv_sec + 1;
+  puts( "timer_settime (montonic)  - bad id - EINVAL" );
+  status = timer_settime( timer1, TIMER_ABSTIME, &itimer, NULL );
+  fatal_posix_service_status_errno( status, EINVAL, "bad id" );
   TEST_END();
   rtems_test_exit (0);
2.32.0
