[PATCH rtems-libbsd v3 1/4] Implement portable kernel symbol namespace tool
chrisj at rtems.org chrisj at rtems.org
Wed Jul 28 02:53:15 UTC 2021
- The script's use of sort proved to not be portable
- No need to check the commits as symbols are only added
- Regenerated kernel header to reset the sort order
Update #4475
 CONTRIBUTING.md                               |    78 +-
 create-kernel-namespace.sh                    |   133 -
 rtems-kern-symbols                            |   502 +
 .../machine/rtems-bsd-kernel-namespace.h      | 11418 ++++++++--------
 4 files changed, 6289 insertions(+), 5842 deletions(-)
 delete mode 100755 create-kernel-namespace.sh
 create mode 100755 rtems-kern-symbols
diff --git a/CONTRIBUTING.md b/CONTRIBUTING.md
index 20dc938b..5336b22e 100644
--- a/CONTRIBUTING.md
+++ b/CONTRIBUTING.md
@@ -121,6 +121,82 @@ $ git log freebsd-org
 to figure out the current FreeBSD baseline.
+Updates to FreeBSD or RTEMS Kernel Support
+If you update code or change any defines that effect the generated
+code in the following paths:
+* `freebsd/sys/*.[ch]`
+* `rtemsbsd/rtems/rtems-kernel-*.c`
+you need to see if any new kernel symbols have been generated or
+exposed. The tool `rtems-kern-symbols` command supports checking and
+updating the kernel symbol namespace.
+The public (global) kernel symbosl need to reside in a private
+namespace to avoid clashing with symbols in the user space code or
+applications. The FreeBSD kernel names functions and variables
+assuming a private kernel only symbols space. RTEMS builds FreeBSD
+kernel and user space code in the same symbols space so there can be
+clashes. We manage this by maintaining a header file that maps the
+global kernel symbols to a private namespace. For example `malloc` is
+mapped to `_bsd_malloc`.
+The set of symbols to map is not easy to obtain because symbols may be
+the result of complex preprocessing of the source, the code is
+specific to a BSP or the code is controlled by a buildset.
+The approach we use is to not remove symbols unless you are certain
+the symbols have been removed from the FreeBSD kernel source. This is
+a manual operation.
+You are required to check symbols with a 32bit and 64bit
+architecture.
+If you are working on a specific BSP and related drivers please make
+sure the kernel symbols are checked. It is too much to ask every
+developer to build all BSPs and check.
+RTEMS Kernel Symbols Tool
+The python tool `rtems-kern-symbols` can read a kernel header loading
+a previously generated version. This maintains the current symbol set
+without you needing to build the object files previously scanned.
+The kernel namespace header can be regenerated from the original
+header. This checks the kernel header is already sorted. If you think
+there is a sorting issue in the existing header please regenerate
+without adding new symbols.
+$ ./rtems-kern-symbols --regenerate --output=tmp.h
+This command needs access to your built RTEMS tools. You can set your
+environment `PATH` variable or you can specify the top level path as an argument:
+$ ./rtems-kern-symbols --rtems-tools=/opt/work/rtems/6
+Options:
+* You can provide a different kernel header using the `--kern-header`
+argument. The default is the LibbSD header.
+* The `--report` option provides a report.
+* The `--diff` option provides a unified diff of any changes.
+* The `--write` option is needed to write any changes
+* The `--output` option lets you control the output kernel header file
+  change are written too
+The tool manages a number of exlcuded symbols. These are symbols in
+the kernel space that are not mapped to the RTEMS kernel namespace.
 How to Import Code from FreeBSD
@@ -134,7 +210,7 @@ How to Import Code from FreeBSD
 * Immediately check in the imported files without the changes to `libbsd.py` and the buildsets.  Do not touch the imported files yourself at this point.
 * Port the imported files to RTEMS.  See 'Rules for Modifying FreeBSD Source'.
 * Add a test to the testsuite if possible.
-* Run `./create-kernel-namespace.sh` if you imported kernel space headers.  Add only your new defines via `git add -p rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h`.
+* Run `./rtems-kern-symbols` as discussed above
 * Create one commit from this.
 The -S or --stats option generates reports the changes we have made to
diff --git a/create-kernel-namespace.sh b/create-kernel-namespace.sh
deleted file mode 100755
index ed4efa10..00000000
--- a/create-kernel-namespace.sh
+++ /dev/null
@@ -1,133 +0,0 @@
-#!/bin/sh -x
-# Copyright (c) 2016 embedded brains GmbH.  All rights reserved.
-#  embedded brains GmbH
-#  Dornierstr. 4
-#  82178 Puchheim
-#  Germany
-#  <rtems at embedded-brains.de>
-# Redistribution and use in source and binary forms, with or without
-# modification, are permitted provided that the following conditions
-# are met:
-# 1. Redistributions of source code must retain the above copyright
-#    notice, this list of conditions and the following disclaimer.
-# 2. Redistributions in binary form must reproduce the above copyright
-#    notice, this list of conditions and the following disclaimer in the
-#    documentation and/or other materials provided with the distribution.
-# THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
-# ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
-# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
-# ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
-# FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
-# DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
-# OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
-# HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
-# LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
-# OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
-# SUCH DAMAGE.
-# This script generates the kernel namespace header file
-# <machine/rtems-bsd-kernel-namespace.h>.
-objdump --syms `for i in build/*rtems* ; do \
-	find $i/freebsd/sys/ -name '*.o' ; \
-	echo $i/rtemsbsd/rtems/rtems-kernel-*.o ; \
-	done` \
-	| awk '/^[0-9a-f]+[[:blank:]]+g/ {print $6}' \
-	| sed 's/^_bsd_//' \
-	| sed '/^accept$/d' \
-	| sed '/^arc4random$/d' \
-	| sed '/^bind$/d' \
-	| sed '/^blackhole$/d' \
-	| sed '/^bpf_filter$/d' \
-	| sed '/^bpf_jitter$/d' \
-	| sed '/^bpf_jitter_enable$/d' \
-	| sed '/^bpf_validate$/d' \
-	| sed '/^connect$/d' \
-	| sed '/^drop_redirect$/d' \
-	| sed '/^drop_synfin$/d' \
-	| sed '/^free$/d' \
-	| sed '/^getentropy$/d' \
-	| sed '/^getpeername$/d' \
-	| sed '/^getsockname$/d' \
-	| sed '/^getsockopt$/d' \
-	| sed '/^ifqmaxlen$/d' \
-	| sed '/^in6addr_any$/d' \
-	| sed '/^in6addr_loopback$/d' \
-	| sed '/^in6addr_nodelocal_allnodes$/d' \
-	| sed '/^in6addr_linklocal_allnodes$/d' \
-	| sed '/^kevent$/d' \
-	| sed '/^kqueue$/d' \
-	| sed '/^listen$/d' \
-	| sed '/^malloc$/d' \
-	| sed '/^max_datalen$/d' \
-	| sed '/^max_hdr$/d' \
-	| sed '/^max_linkhdr$/d' \
-	| sed '/^max_protohdr$/d' \
-	| sed '/^maxsockets$/d' \
-	| sed '/^nd6_debug$/d' \
-	| sed '/^nd6_delay$/d' \
-	| sed '/^nd6_gctimer$/d' \
-	| sed '/^nd6_maxnudhint$/d' \
-	| sed '/^nd6_mmaxtries$/d' \
-	| sed '/^nd6_onlink_ns_rfc4861$/d' \
-	| sed '/^nd6_prune$/d' \
-	| sed '/^nd6_umaxtries$/d' \
-	| sed '/^nd6_useloopback$/d' \
-	| sed '/^nmbclusters$/d' \
-	| sed '/^nmbjumbo16$/d' \
-	| sed '/^nmbjumbo9$/d' \
-	| sed '/^nmbjumbop$/d' \
-	| sed '/^nmbufs$/d' \
-	| sed '/^nolocaltimewait$/d' \
-	| sed '/^path_mtu_discovery$/d' \
-	| sed '/^pause$/d' \
-	| sed '/^pf_osfp_entry_pl$/d' \
-	| sed '/^pf_osfp_pl$/d' \
-	| sed '/^pipe$/d' \
-	| sed '/^poll$/d' \
-	| sed '/^random$/d' \
-	| sed '/^realloc$/d' \
-	| sed '/^reallocf$/d' \
-	| sed '/^recvfrom$/d' \
-	| sed '/^recvmsg$/d' \
-	| sed '/^rtems/d' \
-	| sed '/^select$/d' \
-	| sed '/^sendmsg$/d' \
-	| sed '/^sendto$/d' \
-	| sed '/^setfib$/d' \
-	| sed '/^setsockopt$/d' \
-	| sed '/^shutdown$/d' \
-	| sed '/^socket$/d' \
-	| sed '/^socketpair$/d' \
-	| sed '/^soreceive_stream$/d' \
-	| sed '/^srandom$/d' \
-	| sed '/^strdup$/d' \
-	| sed '/^sysctlbyname$/d' \
-	| sed '/^sysctl$/d' \
-	| sed '/^sysctlnametomib$/d' \
-	| sed '/sys_init/d' \
-	| sed '/^taskqueue_/d' \
-	| sed '/^tcp_offload_listen_start$/d' \
-	| sed '/^tcp_offload_listen_stop$/d' \
-	| sed '/^ticks$/d' \
-	| sed '/^useloopback$/d' \
-	| sed '/^_Watchdog_Ticks_since_boot$/d' \
-	| sort -u > symbols.txt
-cat << eof > rtems-bsd-kernel-namespace.h
-#ifndef _RTEMS_BSD_MACHINE_RTEMS_BSD_KERNEL_SPACE_H_
-#error "the header file <machine/rtems-bsd-kernel-space.h> must be included first"
-#endif
-eof
-sed 's/^\(.*\)/#define	\1 _bsd_\1/' < symbols.txt >> rtems-bsd-kernel-namespace.h
-rm symbols.txt
-mv rtems-bsd-kernel-namespace.h rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
diff --git a/rtems-kern-symbols b/rtems-kern-symbols
new file mode 100755
index 00000000..c67f1c47
--- /dev/null
+++ b/rtems-kern-symbols
@@ -0,0 +1,502 @@
+#! /usr/bin/env python
+# SPDX-License-Identifier: BSD-2-Clause
+"""RTEMS LibBBSD Kernel Symbols
+Generate the symbols for the kernel headers and merge in any new ones
+# Copyright (C) 2021 Chris Johns <chrisj at rtems.org>, All rights reserved.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions
+# are met:
+# 1. Redistributions of source code must retain the above copyright
+#    notice, this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright
+#    notice, this list of conditions and the following disclaimer in the
+#    documentation and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
+from __future__ import print_function
+import argparse
+import os
+import re
+import sys
+version = "1.0"
+kern_objects = [
+    ( 'freebsd/sys', '.*\.o' ),
+    ( 'rtemsbsd/rtems', 'rtems-kernel-.*\.o' )
+] # yapf: disable
+kern_excludes = [
+    '^_bsd_' ,
+    '^rtems_',
+    '^accept$',
+    '^arc4random$',
+    '^bind$',
+    '^blackhole$',
+    '^bootverbose$',
+    '^bpf_filter$',
+    '^bpf_jitter$',
+    '^bpf_jitter_enable$',
+    '^bpf_validate$',
+    '^cache_enter$',
+    '^connect$',
+    '^drop_redirect$',
+    '^drop_synfin$',
+    '^free$',
+    '^getentropy$',
+    '^getpeername$',
+    '^getsockname$',
+    '^getsockopt$',
+    '^global_epoch$',
+    '^global_epoch_preempt$',
+    '^ifqmaxlen$',
+    '^in6addr_any$',
+    '^in6addr_linklocal_allnodes$',
+    '^in6addr_loopback$',
+    '^in6addr_nodelocal_allnodes$',
+    '^in_epoch$',
+    '^kevent$',
+    '^kqueue$',
+    '^listen$',
+    '^malloc$',
+    '^max_datalen$',
+    '^max_hdr$',
+    '^max_linkhdr$',
+    '^max_protohdr$',
+    '^maxsockets$',
+    '^nd6_debug$',
+    '^nd6_delay$',
+    '^nd6_gctimer$',
+    '^nd6_maxnudhint$',
+    '^nd6_mmaxtries$',
+    '^nd6_onlink_ns_rfc4861$',
+    '^nd6_prune$',
+    '^nd6_umaxtries$',
+    '^nd6_useloopback$',
+    '^net_epoch$',
+    '^net_epoch_preempt$',
+    '^nmbclusters$',
+    '^nmbjumbo16$',
+    '^nmbjumbo9$',
+    '^nmbjumbop$',
+    '^nmbufs$',
+    '^nolocaltimewait$',
+    '^path_mtu_discovery$',
+    '^pause$',
+    '^pf_osfp_entry_pl$',
+    '^pf_osfp_pl$',
+    '^pipe$',
+    '^poll$',
+    '^pselect$',
+    '^random$',
+    '^realloc$',
+    '^reallocf$',
+    '^recvfrom$',
+    '^recvmsg$',
+    '^rtems',
+    '^select$',
+    '^sendmsg$',
+    '^sendto$',
+    '^setfib$',
+    '^setsockopt$',
+    '^shutdown$',
+    '^socket$',
+    '^socketpair$',
+    '^soreceive_stream$',
+    '^srandom$',
+    '^strdup$',
+    '^sysctlbyname$',
+    '^sysctl$',
+    '^sysctlnametomib$',
+    'sys_init',
+    '^taskqueue_',
+    '^tcp_offload_listen_start$',
+    '^tcp_offload_listen_stop$',
+    '^ticks$',
+    '^useloopback$',
+    '^_Watchdog_Ticks_since_boot$'
+] # yapf: disable
+kern_header = 'rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h'
+class exit(Exception):
+    """Base class for exceptions."""
+    def __init__(self, code):
+        self.code = code
+class error(Exception):
+    def set_output(self, msg):
+        self.msg = msg
+    def __str__(self):
+        return self.msg
+class general_error(error):
+    """Raise for a general error."""
+    def __init__(self, what):
+        self.set_output('error: ' + str(what))
+class command:
+    def __init__(self, cmd, cwd='.'):
+        self.exit_code = 0
+        self.output = None
+        self.cmd = cmd
+        self.cwd = cwd
+        self.result = None
+    def run(self):
+        import subprocess
+        # Support Python 2.6
+        if "check_output" not in dir(subprocess):
+            def f(*popenargs, **kwargs):
+                if 'stdout' in kwargs:
+                    raise ValueError(
+                        'stdout argument not allowed, it will be overridden.')
+                process = subprocess.Popen(stdout=subprocess.PIPE,
+                                           *popenargs,
+                                           **kwargs)
+                output, unused_err = process.communicate()
+                retcode = process.poll()
+                if retcode:
+                    cmd = kwargs.get("args")
+                    if cmd is None:
+                        cmd = popenargs[0]
+                    raise subprocess.CalledProcessError(retcode, cmd)
+                return output
+            subprocess.check_output = f
+        try:
+            if os.name == 'nt':
+                cmd = ['sh', '-c'] + self.cmd
+            else:
+                cmd = self.cmd
+                output = subprocess.check_output(cmd,
+                                                 cwd=self.cwd).decode("utf-8")
+                self.output = output.split(os.linesep)
+        except subprocess.CalledProcessError as cpe:
+            self.exit_code = cpe.returncode
+            output = cpe.output.decode("utf-8")
+        except OSError as ose:
+            cs = ' '.join(cmd)
+            if len(cs) > 80:
+                cs = cs[:80] + '...'
+            raise general_error('bootstrap failed: %s in %s: %s' % \
+                                (cs, self.cwd, (str(ose))))
+        except KeyboardInterrupt:
+            pass
+        except:
+            raise
+class kernel_symbols:
+    def __init__(self, excludes):
+        self.excludes = [re.compile(exc) for exc in excludes]
+        self.bsps = {}
+        self.header = {'source': [], 'symbols': []}
+        self.output = {'source': [], 'symbols': []}
+        self.analysis = {'unmapped': [], 'new': []}
+    @staticmethod
+    def _find(base, spec):
+        found = []
+        filter = re.compile(spec[1])
+        for root, dirs, files in os.walk(os.path.join(base, spec[0]),
+                                         topdown=True):
+            for f in files:
+                if filter.match(f):
+                    found += [os.path.join(root, f)]
+        return found
+    @staticmethod
+    def _find_bsps(build):
+        bsps = []
+        filter = re.compile('^.*-rtems[0-9].*-.*')
+        with os.scandir(build) as sdir:
+            for entry in sdir:
+                if entry.is_dir() and filter.match(entry.name) != None:
+                    bsps += [entry.name]
+        return bsps
+    @staticmethod
+    def bsp_arch(bsp):
+        bs = bsp.split('-')
+        return bs[0] + '-' + bs[1]
+    def _clean(self, symbols):
+        syms = []
+        for sym in symbols:
+            add = True
+            for exclude in self.excludes:
+                if exclude.match(sym) is not None:
+                    add = False
+                    break
+            if add:
+                syms += [sym]
+        return sorted(list(set(syms)))
+    def load_header(self, header):
+        with open(header, 'r') as h:
+            self.header['source'] = h.read().splitlines()
+        filter = re.compile('^#define\s')
+        for line in self.header['source']:
+            if filter.match(line) != None:
+                ls = line.split()
+                if len(ls) == 3:
+                    self.header['symbols'] += [ls[1]]
+    def load_symbols(self, specs, excludes, build, tools):
+        bsps = self._find_bsps(build)
+        for bsp in bsps:
+            self.bsps[bsp] = {'output': [], 'objects': [], 'symbols': []}
+            for spec in specs:
+                self.bsps[bsp]['objects'] += self._find(
+                    os.path.join(build, bsp), spec)
+            arch = self.bsp_arch(bsp)
+            if tools is not None:
+                cmd = os.path.join(tools, 'bin', arch + '-nm')
+            else:
+                cmd = arch + '-nm'
+            nm = command([cmd] + self.bsps[bsp]['objects'])
+            nm.run()
+            self.bsps[bsp]['output'] = nm.output
+            object = '-'
+            syms = []
+            for line in nm.output:
+                if len(line) == 0:
+                    continue
+                if line[-1] == ':':
+                    object = os.path.basename(line[:-1])
+                    continue
+                ls = line.split()
+                if len(ls) == 3:
+                    ls = ls[1:]
+                if ls[0] in ['A', 'B', 'C', 'D', 'R', 'T', 'W']:
+                    if ls[1] in syms:
+                        print('warning: duplicate symbol: %s:%s: %s' %
+                              (bsp, object, ls[1]))
+                    syms += [ls[1]]
+            self.bsps[bsp]['symbols'] += syms
+    def generate_header(self):
+        out = [
+            '/*', '* RTEMS Libbsd, this file is generated. Do not edit.', '*/',
+            '#ifndef _RTEMS_BSD_MACHINE_RTEMS_BSD_KERNEL_SPACE_H_',
+            '#error "the header file <machine/rtems-bsd-kernel-space.h> must be included first"',
+            '#endif', ''
+        for sym in self.output['symbols']:
+            out += ['#define %s _bsd_%s' % (sym, sym)]
+        self.output['source'] = out
+    def write_header(self, header):
+        with open(header, 'wb') as o:
+            o.write(
+                os.linesep.join(self.output['source'] + ['']).encode("utf-8"))
+    def write_sym_data(self):
+        for bsp in self.bsps:
+            with open('sym-data-' + arch + '.txt', 'w') as o:
+                o.writelines(os.linesep.join(self.bsps[bsp]['output']))
+    def merge(self, symbols):
+        self.output['symbols'] = \
+            self._clean(self.output['symbols'] + symbols)
+    def merge_bsp(self):
+            self.merge(self.bsps[bsp]['symbols'])
+    def analyse(self):
+            for sym in self.bsps[bsp]['symbols']:
+                if sym in self.header['symbols']:
+                    key = 'unmapped'
+                else:
+                    key = 'new'
+                self.analysis[key] += [sym]
+        for key in self.analysis:
+            self.analysis[key] = self._clean(self.analysis[key])
+    def diff(self):
+        import difflib
+        return list(
+            difflib.unified_diff(self.header['source'], self.output['source']))
+    def report(self):
+        out = [
+            'Symbols:',
+            ' mapped   : %d' % (len(self.header['symbols'])),
+            ' unmapped : %d' % (len(self.analysis['unmapped'])),
+            ' new      : %d' % (len(self.analysis['new']))
+        max_len = 0
+            if max_len < len(bsp):
+                max_len = len(bsp)
+        out += ['BSPs: %*s Unmapped Total' % (max_len - 4, ' ')]
+            unmapped = len(self._clean(self.bsps[bsp]['symbols']))
+            total = len(self.bsps[bsp]['symbols'])
+            out += [' %-*s: %-8d %d' % (max_len, bsp, unmapped, total)]
+        out += ['Unmapped:'] + [' ' + sym for sym in self.analysis['unmapped']]
+        out += ['New:'] + [' ' + sym for sym in self.analysis['new']]
+        return out
+def run(args):
+    try:
+        argsp = argparse.ArgumentParser(
+            prog='rtems-kern-symbols',
+            description="RTEMS LibBSD Kernel Symbols")
+        argsp.add_argument('-t',
+                           '--rtems-tools',
+                           help='RTEMS Tools (default: %(default)s).',
+                           type=str,
+                           default=None)
+            '-w',
+            '--write',
+            action='store_true',
+            help=
+            'Write the header to the output file name (default: %(default)s).')
+            '-d',
+            '--diff',
+            help='Show a diff if the header has changed (default: %(default)s).'
+            '-o',
+            '--output',
+            type=str,
+            default=kern_header,
+            help='output path to the write the header (default: %(default)s).')
+            '-b',
+            '--build',
+            type=str,
+            default='build',
+            help='path to the rtems libbsd build output (default: %(default)s).'
+            '-K',
+            '--kern-header',
+            type=str,
+            help=
+            'kernel header to load existing symbols from(default: %(default)s).'
+            '-S',
+            '--sym-data',
+            action="store_true",
+            help=
+            'Write the BSP symbol data that is parsed (default: %(default)s).')
+            '-r',
+            '--regenerate',
+            help=
+            'Regenerate the header file from the symbols in it, write option ignored (default: %(default)s).'
+        argsp.add_argument('-R',
+                           '--report',
+                           help='Generate a report (default: %(default)s).')
+        argopts = argsp.parse_args(args[1:])
+        print('RTEMS LibBSD Kernel Symbols, %s' % (version))
+        if not os.path.exists(argopts.build):
+            raise general_error('path does not exist: %s' % (argopts.build))
+        ks = kernel_symbols(kern_excludes)
+        ks.load_header(argopts.kern_header)
+        if argopts.regenerate:
+            ks.merge(ks.header['symbols'])
+            print('Regenerating: symbols: %d: %s' %
+                  (len(ks.output['symbols']), argopts.output))
+            ks.generate_header()
+            diff = ks.diff()
+            if len(diff) == 0:
+                print('info: no changes; header not updated')
+            else:
+                print('info: writing: %s' % (argopts.output))
+                ks.write_header(argopts.output)
+            raise exit(0)
+        ks.load_symbols(kern_objects, kern_excludes, argopts.build,
+                        argopts.tools)
+        if argopts.sym_data:
+            ks.write_sym_data()
+        ks.analyse()
+        ks.merge_bsp()
+        diff = ks.diff()
+        if argopts.write:
+            else:
+        if argopts.report:
+            print(os.linesep.join(ks.report()))
+        if argopts.diff:
+            print('Diff: %d' % (len(diff)))
+            print(os.linesep.join(diff))
+    except general_error as gerr:
+        print(gerr)
+        print('RTEMS Kernel Symbols FAILED', file=sys.stderr)
+        sys.exit(1)
+        log.notice('abort: user terminated')
+        sys.exit(1)
+    except exit as ec:
+        sys.exit(ec.code)
+    sys.exit(0)
+if __name__ == "__main__":
+    run(sys.argv)
diff --git a/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h b/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
index 3300b3fd..108709ce 100644
--- a/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
+++ b/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
@@ -1,5712 +1,5714 @@
+* RTEMS Libbsd, this file is generated. Do not edit.
 #endif
-#define	accept_filt_add _bsd_accept_filt_add
-#define	accept_filt_del _bsd_accept_filt_del
-#define	accept_filt_generic_mod_event _bsd_accept_filt_generic_mod_event
-#define	accept_filt_get _bsd_accept_filt_get
-#define	accept_filt_getopt _bsd_accept_filt_getopt
-#define	accept_filt_setopt _bsd_accept_filt_setopt
-#define	accept_mtx _bsd_accept_mtx
-#define	AddFragmentPtrLink _bsd_AddFragmentPtrLink
-#define	AddLink _bsd_AddLink
-#define	AddPptp _bsd_AddPptp
-#define	addrsel_policy_init _bsd_addrsel_policy_init
-#define	AddSeq _bsd_AddSeq
-#define	AES_CBC_MAC_Final _bsd_AES_CBC_MAC_Final
-#define	AES_CBC_MAC_Init _bsd_AES_CBC_MAC_Init
-#define	AES_CBC_MAC_Reinit _bsd_AES_CBC_MAC_Reinit
-#define	AES_CBC_MAC_Setkey _bsd_AES_CBC_MAC_Setkey
-#define	AES_CBC_MAC_Update _bsd_AES_CBC_MAC_Update
-#define	AES_GMAC_Final _bsd_AES_GMAC_Final
-#define	AES_GMAC_Init _bsd_AES_GMAC_Init
-#define	AES_GMAC_Reinit _bsd_AES_GMAC_Reinit
-#define	AES_GMAC_Setkey _bsd_AES_GMAC_Setkey
-#define	AES_GMAC_Update _bsd_AES_GMAC_Update
-#define	ah_cleartos _bsd_ah_cleartos
-#define	ah_enable _bsd_ah_enable
-#define	ah_hdrsiz _bsd_ah_hdrsiz
-#define	ah_init0 _bsd_ah_init0
-#define	ahstat _bsd_ahstat
-#define	ah_zeroize _bsd_ah_zeroize
-#define	aio_swake _bsd_aio_swake
-#define	AliasSctpInit _bsd_AliasSctpInit
-#define	AliasSctpTerm _bsd_AliasSctpTerm
-#define	alloc_unr _bsd_alloc_unr
-#define	alloc_unr64 _bsd_alloc_unr64
-#define	alloc_unrl _bsd_alloc_unrl
-#define	alloc_unr_specific _bsd_alloc_unr_specific
-#define	altq_add _bsd_altq_add
-#define	altq_add_queue _bsd_altq_add_queue
-#define	altq_attach _bsd_altq_attach
-#define	altq_detach _bsd_altq_detach
-#define	altq_disable _bsd_altq_disable
-#define	altq_enable _bsd_altq_enable
-#define	altq_getqstats _bsd_altq_getqstats
-#define	altq_input _bsd_altq_input
-#define	altq_lookup _bsd_altq_lookup
-#define	altq_pfattach _bsd_altq_pfattach
-#define	altq_pfdetach _bsd_altq_pfdetach
-#define	altq_remove _bsd_altq_remove
-#define	altq_remove_queue _bsd_altq_remove_queue
-#define	altqs_inactive_open _bsd_altqs_inactive_open
-#define	am335x_pwm_config_ecap _bsd_am335x_pwm_config_ecap
-#define	am335x_pwmss_driver _bsd_am335x_pwmss_driver
-#define	arp_announce_ifaddr _bsd_arp_announce_ifaddr
-#define	arp_ifinit _bsd_arp_ifinit
-#define	arprequest _bsd_arprequest
-#define	arpresolve _bsd_arpresolve
-#define	arpresolve_addr _bsd_arpresolve_addr
-#define	arpstat _bsd_arpstat
-#define	async_crypto _bsd_async_crypto
-#define	auth_algorithm_lookup _bsd_auth_algorithm_lookup
-#define	auth_hash_blake2b _bsd_auth_hash_blake2b
-#define	auth_hash_blake2s _bsd_auth_hash_blake2s
-#define	auth_hash_ccm_cbc_mac_128 _bsd_auth_hash_ccm_cbc_mac_128
-#define	auth_hash_ccm_cbc_mac_192 _bsd_auth_hash_ccm_cbc_mac_192
-#define	auth_hash_ccm_cbc_mac_256 _bsd_auth_hash_ccm_cbc_mac_256
-#define	auth_hash_hmac_md5 _bsd_auth_hash_hmac_md5
-#define	auth_hash_hmac_ripemd_160 _bsd_auth_hash_hmac_ripemd_160
-#define	auth_hash_hmac_sha1 _bsd_auth_hash_hmac_sha1
-#define	auth_hash_hmac_sha2_224 _bsd_auth_hash_hmac_sha2_224
-#define	auth_hash_hmac_sha2_256 _bsd_auth_hash_hmac_sha2_256
-#define	auth_hash_hmac_sha2_384 _bsd_auth_hash_hmac_sha2_384
-#define	auth_hash_hmac_sha2_512 _bsd_auth_hash_hmac_sha2_512
-#define	auth_hash_key_md5 _bsd_auth_hash_key_md5
-#define	auth_hash_key_sha1 _bsd_auth_hash_key_sha1
-#define	auth_hash_nist_gmac_aes_128 _bsd_auth_hash_nist_gmac_aes_128
-#define	auth_hash_nist_gmac_aes_192 _bsd_auth_hash_nist_gmac_aes_192
-#define	auth_hash_nist_gmac_aes_256 _bsd_auth_hash_nist_gmac_aes_256
-#define	auth_hash_null _bsd_auth_hash_null
-#define	auth_hash_poly1305 _bsd_auth_hash_poly1305
-#define	auth_hash_sha1 _bsd_auth_hash_sha1
-#define	auth_hash_sha2_224 _bsd_auth_hash_sha2_224
-#define	auth_hash_sha2_256 _bsd_auth_hash_sha2_256
-#define	auth_hash_sha2_384 _bsd_auth_hash_sha2_384
-#define	auth_hash_sha2_512 _bsd_auth_hash_sha2_512
-#define	badport_bandlim _bsd_badport_bandlim
-#define	bcd2bin_data _bsd_bcd2bin_data
-#define	bce_COM_b06FwBss _bsd_bce_COM_b06FwBss
-#define	bce_COM_b06FwBssAddr _bsd_bce_COM_b06FwBssAddr
-#define	bce_COM_b06FwBssLen _bsd_bce_COM_b06FwBssLen
-#define	bce_COM_b06FwData _bsd_bce_COM_b06FwData
-#define	bce_COM_b06FwDataAddr _bsd_bce_COM_b06FwDataAddr
-#define	bce_COM_b06FwDataLen _bsd_bce_COM_b06FwDataLen
-#define	bce_COM_b06FwReleaseFix _bsd_bce_COM_b06FwReleaseFix
-#define	bce_COM_b06FwReleaseMajor _bsd_bce_COM_b06FwReleaseMajor
-#define	bce_COM_b06FwReleaseMinor _bsd_bce_COM_b06FwReleaseMinor
-#define	bce_COM_b06FwRodata _bsd_bce_COM_b06FwRodata
-#define	bce_COM_b06FwRodataAddr _bsd_bce_COM_b06FwRodataAddr
-#define	bce_COM_b06FwRodataLen _bsd_bce_COM_b06FwRodataLen
-#define	bce_COM_b06FwSbss _bsd_bce_COM_b06FwSbss
-#define	bce_COM_b06FwSbssAddr _bsd_bce_COM_b06FwSbssAddr
-#define	bce_COM_b06FwSbssLen _bsd_bce_COM_b06FwSbssLen
-#define	bce_COM_b06FwSdata _bsd_bce_COM_b06FwSdata
-#define	bce_COM_b06FwSDataAddr _bsd_bce_COM_b06FwSDataAddr
-#define	bce_COM_b06FwSDataLen _bsd_bce_COM_b06FwSDataLen
-#define	bce_COM_b06FwStartAddr _bsd_bce_COM_b06FwStartAddr
-#define	bce_COM_b06FwText _bsd_bce_COM_b06FwText
-#define	bce_COM_b06FwTextAddr _bsd_bce_COM_b06FwTextAddr
-#define	bce_COM_b06FwTextLen _bsd_bce_COM_b06FwTextLen
-#define	bce_COM_b09FwBss _bsd_bce_COM_b09FwBss
-#define	bce_COM_b09FwBssAddr _bsd_bce_COM_b09FwBssAddr
-#define	bce_COM_b09FwBssLen _bsd_bce_COM_b09FwBssLen
-#define	bce_COM_b09FwData _bsd_bce_COM_b09FwData
-#define	bce_COM_b09FwDataAddr _bsd_bce_COM_b09FwDataAddr
-#define	bce_COM_b09FwDataLen _bsd_bce_COM_b09FwDataLen
-#define	bce_COM_b09FwReleaseFix _bsd_bce_COM_b09FwReleaseFix
-#define	bce_COM_b09FwReleaseMajor _bsd_bce_COM_b09FwReleaseMajor
-#define	bce_COM_b09FwReleaseMinor _bsd_bce_COM_b09FwReleaseMinor
-#define	bce_COM_b09FwRodata _bsd_bce_COM_b09FwRodata
-#define	bce_COM_b09FwRodataAddr _bsd_bce_COM_b09FwRodataAddr
-#define	bce_COM_b09FwRodataLen _bsd_bce_COM_b09FwRodataLen
-#define	bce_COM_b09FwSbss _bsd_bce_COM_b09FwSbss
-#define	bce_COM_b09FwSbssAddr _bsd_bce_COM_b09FwSbssAddr
-#define	bce_COM_b09FwSbssLen _bsd_bce_COM_b09FwSbssLen
-#define	bce_COM_b09FwSdata _bsd_bce_COM_b09FwSdata
-#define	bce_COM_b09FwSDataAddr _bsd_bce_COM_b09FwSDataAddr
-#define	bce_COM_b09FwSDataLen _bsd_bce_COM_b09FwSDataLen
-#define	bce_COM_b09FwStartAddr _bsd_bce_COM_b09FwStartAddr
-#define	bce_COM_b09FwText _bsd_bce_COM_b09FwText
-#define	bce_COM_b09FwTextAddr _bsd_bce_COM_b09FwTextAddr
-#define	bce_COM_b09FwTextLen _bsd_bce_COM_b09FwTextLen
-#define	bce_CP_b06FwBss _bsd_bce_CP_b06FwBss
-#define	bce_CP_b06FwBssAddr _bsd_bce_CP_b06FwBssAddr
-#define	bce_CP_b06FwBssLen _bsd_bce_CP_b06FwBssLen
-#define	bce_CP_b06FwData _bsd_bce_CP_b06FwData
-#define	bce_CP_b06FwDataAddr _bsd_bce_CP_b06FwDataAddr
-#define	bce_CP_b06FwDataLen _bsd_bce_CP_b06FwDataLen
-#define	bce_CP_b06FwReleaseFix _bsd_bce_CP_b06FwReleaseFix
-#define	bce_CP_b06FwReleaseMajor _bsd_bce_CP_b06FwReleaseMajor
-#define	bce_CP_b06FwReleaseMinor _bsd_bce_CP_b06FwReleaseMinor
-#define	bce_CP_b06FwRodata _bsd_bce_CP_b06FwRodata
-#define	bce_CP_b06FwRodataAddr _bsd_bce_CP_b06FwRodataAddr
-#define	bce_CP_b06FwRodataLen _bsd_bce_CP_b06FwRodataLen
-#define	bce_CP_b06FwSbss _bsd_bce_CP_b06FwSbss
-#define	bce_CP_b06FwSbssAddr _bsd_bce_CP_b06FwSbssAddr
-#define	bce_CP_b06FwSbssLen _bsd_bce_CP_b06FwSbssLen
-#define	bce_CP_b06FwSdata _bsd_bce_CP_b06FwSdata
-#define	bce_CP_b06FwSDataAddr _bsd_bce_CP_b06FwSDataAddr
-#define	bce_CP_b06FwSDataLen _bsd_bce_CP_b06FwSDataLen
-#define	bce_CP_b06FwStartAddr _bsd_bce_CP_b06FwStartAddr
-#define	bce_CP_b06FwText _bsd_bce_CP_b06FwText
-#define	bce_CP_b06FwTextAddr _bsd_bce_CP_b06FwTextAddr
-#define	bce_CP_b06FwTextLen _bsd_bce_CP_b06FwTextLen
-#define	bce_CP_b09FwBss _bsd_bce_CP_b09FwBss
-#define	bce_CP_b09FwBssAddr _bsd_bce_CP_b09FwBssAddr
-#define	bce_CP_b09FwBssLen _bsd_bce_CP_b09FwBssLen
-#define	bce_CP_b09FwData _bsd_bce_CP_b09FwData
-#define	bce_CP_b09FwDataAddr _bsd_bce_CP_b09FwDataAddr
-#define	bce_CP_b09FwDataLen _bsd_bce_CP_b09FwDataLen
-#define	bce_CP_b09FwReleaseFix _bsd_bce_CP_b09FwReleaseFix
-#define	bce_CP_b09FwReleaseMajor _bsd_bce_CP_b09FwReleaseMajor
-#define	bce_CP_b09FwReleaseMinor _bsd_bce_CP_b09FwReleaseMinor
-#define	bce_CP_b09FwRodata _bsd_bce_CP_b09FwRodata
-#define	bce_CP_b09FwRodataAddr _bsd_bce_CP_b09FwRodataAddr
-#define	bce_CP_b09FwRodataLen _bsd_bce_CP_b09FwRodataLen
-#define	bce_CP_b09FwSbss _bsd_bce_CP_b09FwSbss
-#define	bce_CP_b09FwSbssAddr _bsd_bce_CP_b09FwSbssAddr
-#define	bce_CP_b09FwSbssLen _bsd_bce_CP_b09FwSbssLen
-#define	bce_CP_b09FwSdata _bsd_bce_CP_b09FwSdata
-#define	bce_CP_b09FwSDataAddr _bsd_bce_CP_b09FwSDataAddr
-#define	bce_CP_b09FwSDataLen _bsd_bce_CP_b09FwSDataLen
-#define	bce_CP_b09FwStartAddr _bsd_bce_CP_b09FwStartAddr
-#define	bce_CP_b09FwText _bsd_bce_CP_b09FwText
-#define	bce_CP_b09FwTextAddr _bsd_bce_CP_b09FwTextAddr
-#define	bce_CP_b09FwTextLen _bsd_bce_CP_b09FwTextLen
-#define	bce_rv2p_proc1 _bsd_bce_rv2p_proc1
-#define	bce_rv2p_proc2 _bsd_bce_rv2p_proc2
-#define	bce_RXP_b06FwBss _bsd_bce_RXP_b06FwBss
-#define	bce_RXP_b06FwBssAddr _bsd_bce_RXP_b06FwBssAddr
-#define	bce_RXP_b06FwBssLen _bsd_bce_RXP_b06FwBssLen
-#define	bce_RXP_b06FwData _bsd_bce_RXP_b06FwData
-#define	bce_RXP_b06FwDataAddr _bsd_bce_RXP_b06FwDataAddr
-#define	bce_RXP_b06FwDataLen _bsd_bce_RXP_b06FwDataLen
-#define	bce_RXP_b06FwReleaseFix _bsd_bce_RXP_b06FwReleaseFix
-#define	bce_RXP_b06FwReleaseMajor _bsd_bce_RXP_b06FwReleaseMajor
-#define	bce_RXP_b06FwReleaseMinor _bsd_bce_RXP_b06FwReleaseMinor
-#define	bce_RXP_b06FwRodata _bsd_bce_RXP_b06FwRodata
-#define	bce_RXP_b06FwRodataAddr _bsd_bce_RXP_b06FwRodataAddr
-#define	bce_RXP_b06FwRodataLen _bsd_bce_RXP_b06FwRodataLen
-#define	bce_RXP_b06FwSbss _bsd_bce_RXP_b06FwSbss
-#define	bce_RXP_b06FwSbssAddr _bsd_bce_RXP_b06FwSbssAddr
-#define	bce_RXP_b06FwSbssLen _bsd_bce_RXP_b06FwSbssLen
-#define	bce_RXP_b06FwSdata _bsd_bce_RXP_b06FwSdata
-#define	bce_RXP_b06FwSDataAddr _bsd_bce_RXP_b06FwSDataAddr
-#define	bce_RXP_b06FwSDataLen _bsd_bce_RXP_b06FwSDataLen
-#define	bce_RXP_b06FwStartAddr _bsd_bce_RXP_b06FwStartAddr
-#define	bce_RXP_b06FwText _bsd_bce_RXP_b06FwText
-#define	bce_RXP_b06FwTextAddr _bsd_bce_RXP_b06FwTextAddr
-#define	bce_RXP_b06FwTextLen _bsd_bce_RXP_b06FwTextLen
-#define	bce_RXP_b09FwBss _bsd_bce_RXP_b09FwBss
-#define	bce_RXP_b09FwBssAddr _bsd_bce_RXP_b09FwBssAddr
-#define	bce_RXP_b09FwBssLen _bsd_bce_RXP_b09FwBssLen
-#define	bce_RXP_b09FwData _bsd_bce_RXP_b09FwData
-#define	bce_RXP_b09FwDataAddr _bsd_bce_RXP_b09FwDataAddr
-#define	bce_RXP_b09FwDataLen _bsd_bce_RXP_b09FwDataLen
-#define	bce_RXP_b09FwReleaseFix _bsd_bce_RXP_b09FwReleaseFix
-#define	bce_RXP_b09FwReleaseMajor _bsd_bce_RXP_b09FwReleaseMajor
-#define	bce_RXP_b09FwReleaseMinor _bsd_bce_RXP_b09FwReleaseMinor
-#define	bce_RXP_b09FwRodata _bsd_bce_RXP_b09FwRodata
-#define	bce_RXP_b09FwRodataAddr _bsd_bce_RXP_b09FwRodataAddr
-#define	bce_RXP_b09FwRodataLen _bsd_bce_RXP_b09FwRodataLen
-#define	bce_RXP_b09FwSbss _bsd_bce_RXP_b09FwSbss
-#define	bce_RXP_b09FwSbssAddr _bsd_bce_RXP_b09FwSbssAddr
-#define	bce_RXP_b09FwSbssLen _bsd_bce_RXP_b09FwSbssLen
-#define	bce_RXP_b09FwSdata _bsd_bce_RXP_b09FwSdata
-#define	bce_RXP_b09FwSDataAddr _bsd_bce_RXP_b09FwSDataAddr
-#define	bce_RXP_b09FwSDataLen _bsd_bce_RXP_b09FwSDataLen
-#define	bce_RXP_b09FwStartAddr _bsd_bce_RXP_b09FwStartAddr
-#define	bce_RXP_b09FwText _bsd_bce_RXP_b09FwText
-#define	bce_RXP_b09FwTextAddr _bsd_bce_RXP_b09FwTextAddr
-#define	bce_RXP_b09FwTextLen _bsd_bce_RXP_b09FwTextLen
-#define	bce_TPAT_b06FwBss _bsd_bce_TPAT_b06FwBss
-#define	bce_TPAT_b06FwBssAddr _bsd_bce_TPAT_b06FwBssAddr
-#define	bce_TPAT_b06FwBssLen _bsd_bce_TPAT_b06FwBssLen
-#define	bce_TPAT_b06FwData _bsd_bce_TPAT_b06FwData
-#define	bce_TPAT_b06FwDataAddr _bsd_bce_TPAT_b06FwDataAddr
-#define	bce_TPAT_b06FwDataLen _bsd_bce_TPAT_b06FwDataLen
-#define	bce_TPAT_b06FwReleaseFix _bsd_bce_TPAT_b06FwReleaseFix
-#define	bce_TPAT_b06FwReleaseMajor _bsd_bce_TPAT_b06FwReleaseMajor
-#define	bce_TPAT_b06FwReleaseMinor _bsd_bce_TPAT_b06FwReleaseMinor
-#define	bce_TPAT_b06FwRodata _bsd_bce_TPAT_b06FwRodata
-#define	bce_TPAT_b06FwRodataAddr _bsd_bce_TPAT_b06FwRodataAddr
-#define	bce_TPAT_b06FwRodataLen _bsd_bce_TPAT_b06FwRodataLen
-#define	bce_TPAT_b06FwSbss _bsd_bce_TPAT_b06FwSbss
-#define	bce_TPAT_b06FwSbssAddr _bsd_bce_TPAT_b06FwSbssAddr
-#define	bce_TPAT_b06FwSbssLen _bsd_bce_TPAT_b06FwSbssLen
-#define	bce_TPAT_b06FwSdata _bsd_bce_TPAT_b06FwSdata
-#define	bce_TPAT_b06FwSDataAddr _bsd_bce_TPAT_b06FwSDataAddr
-#define	bce_TPAT_b06FwSDataLen _bsd_bce_TPAT_b06FwSDataLen
-#define	bce_TPAT_b06FwStartAddr _bsd_bce_TPAT_b06FwStartAddr
-#define	bce_TPAT_b06FwText _bsd_bce_TPAT_b06FwText
-#define	bce_TPAT_b06FwTextAddr _bsd_bce_TPAT_b06FwTextAddr
-#define	bce_TPAT_b06FwTextLen _bsd_bce_TPAT_b06FwTextLen
-#define	bce_TPAT_b09FwBss _bsd_bce_TPAT_b09FwBss
-#define	bce_TPAT_b09FwBssAddr _bsd_bce_TPAT_b09FwBssAddr
-#define	bce_TPAT_b09FwBssLen _bsd_bce_TPAT_b09FwBssLen
-#define	bce_TPAT_b09FwData _bsd_bce_TPAT_b09FwData
-#define	bce_TPAT_b09FwDataAddr _bsd_bce_TPAT_b09FwDataAddr
-#define	bce_TPAT_b09FwDataLen _bsd_bce_TPAT_b09FwDataLen
-#define	bce_TPAT_b09FwReleaseFix _bsd_bce_TPAT_b09FwReleaseFix
-#define	bce_TPAT_b09FwReleaseMajor _bsd_bce_TPAT_b09FwReleaseMajor
-#define	bce_TPAT_b09FwReleaseMinor _bsd_bce_TPAT_b09FwReleaseMinor
-#define	bce_TPAT_b09FwRodata _bsd_bce_TPAT_b09FwRodata
-#define	bce_TPAT_b09FwRodataAddr _bsd_bce_TPAT_b09FwRodataAddr
-#define	bce_TPAT_b09FwRodataLen _bsd_bce_TPAT_b09FwRodataLen
-#define	bce_TPAT_b09FwSbss _bsd_bce_TPAT_b09FwSbss
-#define	bce_TPAT_b09FwSbssAddr _bsd_bce_TPAT_b09FwSbssAddr
-#define	bce_TPAT_b09FwSbssLen _bsd_bce_TPAT_b09FwSbssLen
-#define	bce_TPAT_b09FwSdata _bsd_bce_TPAT_b09FwSdata
-#define	bce_TPAT_b09FwSDataAddr _bsd_bce_TPAT_b09FwSDataAddr
-#define	bce_TPAT_b09FwSDataLen _bsd_bce_TPAT_b09FwSDataLen
-#define	bce_TPAT_b09FwStartAddr _bsd_bce_TPAT_b09FwStartAddr
-#define	bce_TPAT_b09FwText _bsd_bce_TPAT_b09FwText
-#define	bce_TPAT_b09FwTextAddr _bsd_bce_TPAT_b09FwTextAddr
-#define	bce_TPAT_b09FwTextLen _bsd_bce_TPAT_b09FwTextLen
-#define	bce_TXP_b06FwBss _bsd_bce_TXP_b06FwBss
-#define	bce_TXP_b06FwBssAddr _bsd_bce_TXP_b06FwBssAddr
-#define	bce_TXP_b06FwBssLen _bsd_bce_TXP_b06FwBssLen
-#define	bce_TXP_b06FwData _bsd_bce_TXP_b06FwData
-#define	bce_TXP_b06FwDataAddr _bsd_bce_TXP_b06FwDataAddr
-#define	bce_TXP_b06FwDataLen _bsd_bce_TXP_b06FwDataLen
-#define	bce_TXP_b06FwReleaseFix _bsd_bce_TXP_b06FwReleaseFix
-#define	bce_TXP_b06FwReleaseMajor _bsd_bce_TXP_b06FwReleaseMajor
-#define	bce_TXP_b06FwReleaseMinor _bsd_bce_TXP_b06FwReleaseMinor
-#define	bce_TXP_b06FwRodata _bsd_bce_TXP_b06FwRodata
-#define	bce_TXP_b06FwRodataAddr _bsd_bce_TXP_b06FwRodataAddr
-#define	bce_TXP_b06FwRodataLen _bsd_bce_TXP_b06FwRodataLen
-#define	bce_TXP_b06FwSbss _bsd_bce_TXP_b06FwSbss
-#define	bce_TXP_b06FwSbssAddr _bsd_bce_TXP_b06FwSbssAddr
-#define	bce_TXP_b06FwSbssLen _bsd_bce_TXP_b06FwSbssLen
-#define	bce_TXP_b06FwSdata _bsd_bce_TXP_b06FwSdata
-#define	bce_TXP_b06FwSDataAddr _bsd_bce_TXP_b06FwSDataAddr
-#define	bce_TXP_b06FwSDataLen _bsd_bce_TXP_b06FwSDataLen
-#define	bce_TXP_b06FwStartAddr _bsd_bce_TXP_b06FwStartAddr
-#define	bce_TXP_b06FwText _bsd_bce_TXP_b06FwText
-#define	bce_TXP_b06FwTextAddr _bsd_bce_TXP_b06FwTextAddr
-#define	bce_TXP_b06FwTextLen _bsd_bce_TXP_b06FwTextLen
-#define	bce_TXP_b09FwBss _bsd_bce_TXP_b09FwBss
-#define	bce_TXP_b09FwBssAddr _bsd_bce_TXP_b09FwBssAddr
-#define	bce_TXP_b09FwBssLen _bsd_bce_TXP_b09FwBssLen
-#define	bce_TXP_b09FwData _bsd_bce_TXP_b09FwData
-#define	bce_TXP_b09FwDataAddr _bsd_bce_TXP_b09FwDataAddr
-#define	bce_TXP_b09FwDataLen _bsd_bce_TXP_b09FwDataLen
-#define	bce_TXP_b09FwReleaseFix _bsd_bce_TXP_b09FwReleaseFix
-#define	bce_TXP_b09FwReleaseMajor _bsd_bce_TXP_b09FwReleaseMajor
-#define	bce_TXP_b09FwReleaseMinor _bsd_bce_TXP_b09FwReleaseMinor
-#define	bce_TXP_b09FwRodata _bsd_bce_TXP_b09FwRodata
-#define	bce_TXP_b09FwRodataAddr _bsd_bce_TXP_b09FwRodataAddr
-#define	bce_TXP_b09FwRodataLen _bsd_bce_TXP_b09FwRodataLen
-#define	bce_TXP_b09FwSbss _bsd_bce_TXP_b09FwSbss
-#define	bce_TXP_b09FwSbssAddr _bsd_bce_TXP_b09FwSbssAddr
-#define	bce_TXP_b09FwSbssLen _bsd_bce_TXP_b09FwSbssLen
-#define	bce_TXP_b09FwSdata _bsd_bce_TXP_b09FwSdata
-#define	bce_TXP_b09FwSDataAddr _bsd_bce_TXP_b09FwSDataAddr
-#define	bce_TXP_b09FwSDataLen _bsd_bce_TXP_b09FwSDataLen
-#define	bce_TXP_b09FwStartAddr _bsd_bce_TXP_b09FwStartAddr
-#define	bce_TXP_b09FwText _bsd_bce_TXP_b09FwText
-#define	bce_TXP_b09FwTextAddr _bsd_bce_TXP_b09FwTextAddr
-#define	bce_TXP_b09FwTextLen _bsd_bce_TXP_b09FwTextLen
-#define	bce_xi90_rv2p_proc1 _bsd_bce_xi90_rv2p_proc1
-#define	bce_xi90_rv2p_proc2 _bsd_bce_xi90_rv2p_proc2
-#define	bce_xi_rv2p_proc1 _bsd_bce_xi_rv2p_proc1
-#define	bce_xi_rv2p_proc2 _bsd_bce_xi_rv2p_proc2
-#define	be_uuid_dec _bsd_be_uuid_dec
-#define	be_uuid_enc _bsd_be_uuid_enc
-#define	BF_decrypt _bsd_BF_decrypt
-#define	BF_ecb_encrypt _bsd_BF_ecb_encrypt
-#define	BF_encrypt _bsd_BF_encrypt
-#define	BF_set_key _bsd_BF_set_key
-#define	bin2bcd_data _bsd_bin2bcd_data
-#define	blake2b_final_ref _bsd_blake2b_final_ref
-#define	blake2b_init_key_ref _bsd_blake2b_init_key_ref
-#define	blake2b_init_param_ref _bsd_blake2b_init_param_ref
-#define	blake2b_init_ref _bsd_blake2b_init_ref
-#define	blake2b_ref _bsd_blake2b_ref
-#define	blake2b_update_ref _bsd_blake2b_update_ref
-#define	blake2s_final_ref _bsd_blake2s_final_ref
-#define	blake2s_init_key_ref _bsd_blake2s_init_key_ref
-#define	blake2s_init_param_ref _bsd_blake2s_init_param_ref
-#define	blake2s_init_ref _bsd_blake2s_init_ref
-#define	blake2s_ref _bsd_blake2s_ref
-#define	blake2s_update_ref _bsd_blake2s_update_ref
-#define	blist_alloc _bsd_blist_alloc
-#define	blist_avail _bsd_blist_avail
-#define	blist_create _bsd_blist_create
-#define	blist_destroy _bsd_blist_destroy
-#define	blist_fill _bsd_blist_fill
-#define	blist_free _bsd_blist_free
-#define	blist_resize _bsd_blist_resize
-#define	blist_stats _bsd_blist_stats
-#define	bpfattach _bsd_bpfattach
-#define	bpfattach2 _bsd_bpfattach2
-#define	bpf_buffer_append_bytes _bsd_bpf_buffer_append_bytes
-#define	bpf_buffer_append_mbuf _bsd_bpf_buffer_append_mbuf
-#define	bpf_buffer_free _bsd_bpf_buffer_free
-#define	bpf_buffer_init _bsd_bpf_buffer_init
-#define	bpf_buffer_ioctl_sblen _bsd_bpf_buffer_ioctl_sblen
-#define	bpf_buffer_uiomove _bsd_bpf_buffer_uiomove
-#define	bpf_bufheld _bsd_bpf_bufheld
-#define	bpf_destroy_jit_filter _bsd_bpf_destroy_jit_filter
-#define	bpfdetach _bsd_bpfdetach
-#define	bpf_ifdetach_cookie _bsd_bpf_ifdetach_cookie
-#define	bpf_maxinsns _bsd_bpf_maxinsns
-#define	bpf_mtap _bsd_bpf_mtap
-#define	bpf_mtap2 _bsd_bpf_mtap2
-#define	bpf_tap _bsd_bpf_tap
-#define	bridge_control_table _bsd_bridge_control_table
-#define	bridge_control_table_size _bsd_bridge_control_table_size
-#define	bridge_dn_p _bsd_bridge_dn_p
-#define	bridge_rtable_prune_period _bsd_bridge_rtable_prune_period
-#define	bstp_attach _bsd_bstp_attach
-#define	bstp_create _bsd_bstp_create
-#define	bstp_destroy _bsd_bstp_destroy
-#define	bstp_detach _bsd_bstp_detach
-#define	bstp_disable _bsd_bstp_disable
-#define	bstp_enable _bsd_bstp_enable
-#define	bstp_etheraddr _bsd_bstp_etheraddr
-#define	bstp_init _bsd_bstp_init
-#define	bstp_input _bsd_bstp_input
-#define	bstp_linkstate _bsd_bstp_linkstate
-#define	bstp_list _bsd_bstp_list
-#define	bstp_set_autoedge _bsd_bstp_set_autoedge
-#define	bstp_set_autoptp _bsd_bstp_set_autoptp
-#define	bstp_set_edge _bsd_bstp_set_edge
-#define	bstp_set_fdelay _bsd_bstp_set_fdelay
-#define	bstp_set_holdcount _bsd_bstp_set_holdcount
-#define	bstp_set_htime _bsd_bstp_set_htime
-#define	bstp_set_maxage _bsd_bstp_set_maxage
-#define	bstp_set_path_cost _bsd_bstp_set_path_cost
-#define	bstp_set_port_priority _bsd_bstp_set_port_priority
-#define	bstp_set_priority _bsd_bstp_set_priority
-#define	bstp_set_protocol _bsd_bstp_set_protocol
-#define	bstp_set_ptp _bsd_bstp_set_ptp
-#define	bstp_stop _bsd_bstp_stop
-#define	bt_tickthreshold _bsd_bt_tickthreshold
-#define	bt_timethreshold _bsd_bt_timethreshold
-#define	bucket_zones _bsd_bucket_zones
-#define	buf_ring_alloc _bsd_buf_ring_alloc
-#define	buf_ring_free _bsd_buf_ring_free
-#define	bus_activate_resource _bsd_bus_activate_resource
-#define	bus_adjust_resource _bsd_bus_adjust_resource
-#define	bus_alloc_resource _bsd_bus_alloc_resource
-#define	bus_alloc_resources _bsd_bus_alloc_resources
-#define	bus_bind_intr _bsd_bus_bind_intr
-#define	bus_child_location_str _bsd_bus_child_location_str
-#define	bus_child_pnpinfo_str _bsd_bus_child_pnpinfo_str
-#define	bus_child_present _bsd_bus_child_present
-#define	bus_current_pass _bsd_bus_current_pass
-#define	bus_data_generation_check _bsd_bus_data_generation_check
-#define	bus_data_generation_update _bsd_bus_data_generation_update
-#define	bus_deactivate_resource _bsd_bus_deactivate_resource
-#define	bus_delayed_attach_children _bsd_bus_delayed_attach_children
-#define	bus_delete_resource _bsd_bus_delete_resource
-#define	bus_describe_intr _bsd_bus_describe_intr
-#define	busdma_lock_mutex _bsd_busdma_lock_mutex
-#define	bus_dmamap_create _bsd_bus_dmamap_create
-#define	bus_dmamap_destroy _bsd_bus_dmamap_destroy
-#define	bus_dmamap_load _bsd_bus_dmamap_load
-#define	bus_dmamap_load_buffer _bsd_bus_dmamap_load_buffer
-#define	bus_dmamap_load_mbuf _bsd_bus_dmamap_load_mbuf
-#define	bus_dmamap_load_mbuf_sg _bsd_bus_dmamap_load_mbuf_sg
-#define	bus_dmamap_sync _bsd_bus_dmamap_sync
-#define	bus_dmamap_unload _bsd_bus_dmamap_unload
-#define	bus_dmamem_alloc _bsd_bus_dmamem_alloc
-#define	bus_dmamem_free _bsd_bus_dmamem_free
-#define	bus_dma_tag_create _bsd_bus_dma_tag_create
-#define	bus_dma_tag_destroy _bsd_bus_dma_tag_destroy
-#define	bus_enumerate_hinted_children _bsd_bus_enumerate_hinted_children
-#define	bus_generic_activate_resource _bsd_bus_generic_activate_resource
-#define	bus_generic_add_child _bsd_bus_generic_add_child
-#define	bus_generic_adjust_resource _bsd_bus_generic_adjust_resource
-#define	bus_generic_alloc_resource _bsd_bus_generic_alloc_resource
-#define	bus_generic_attach _bsd_bus_generic_attach
-#define	bus_generic_bind_intr _bsd_bus_generic_bind_intr
-#define	bus_generic_child_present _bsd_bus_generic_child_present
-#define	bus_generic_config_intr _bsd_bus_generic_config_intr
-#define	bus_generic_deactivate_resource _bsd_bus_generic_deactivate_resource
-#define	bus_generic_describe_intr _bsd_bus_generic_describe_intr
-#define	bus_generic_detach _bsd_bus_generic_detach
-#define	bus_generic_driver_added _bsd_bus_generic_driver_added
-#define	bus_generic_get_bus_tag _bsd_bus_generic_get_bus_tag
-#define	bus_generic_get_cpus _bsd_bus_generic_get_cpus
-#define	bus_generic_get_dma_tag _bsd_bus_generic_get_dma_tag
-#define	bus_generic_get_domain _bsd_bus_generic_get_domain
-#define	bus_generic_get_resource_list _bsd_bus_generic_get_resource_list
-#define	bus_generic_map_resource _bsd_bus_generic_map_resource
-#define	bus_generic_new_pass _bsd_bus_generic_new_pass
-#define	bus_generic_print_child _bsd_bus_generic_print_child
-#define	bus_generic_probe _bsd_bus_generic_probe
-#define	bus_generic_read_ivar _bsd_bus_generic_read_ivar
-#define	bus_generic_release_resource _bsd_bus_generic_release_resource
-#define	bus_generic_resume _bsd_bus_generic_resume
-#define	bus_generic_resume_child _bsd_bus_generic_resume_child
-#define	bus_generic_resume_intr _bsd_bus_generic_resume_intr
-#define	bus_generic_rl_alloc_resource _bsd_bus_generic_rl_alloc_resource
-#define	bus_generic_rl_delete_resource _bsd_bus_generic_rl_delete_resource
-#define	bus_generic_rl_get_resource _bsd_bus_generic_rl_get_resource
-#define	bus_generic_rl_release_resource _bsd_bus_generic_rl_release_resource
-#define	bus_generic_rl_set_resource _bsd_bus_generic_rl_set_resource
-#define	bus_generic_setup_intr _bsd_bus_generic_setup_intr
-#define	bus_generic_shutdown _bsd_bus_generic_shutdown
-#define	bus_generic_suspend _bsd_bus_generic_suspend
-#define	bus_generic_suspend_child _bsd_bus_generic_suspend_child
-#define	bus_generic_suspend_intr _bsd_bus_generic_suspend_intr
-#define	bus_generic_teardown_intr _bsd_bus_generic_teardown_intr
-#define	bus_generic_unmap_resource _bsd_bus_generic_unmap_resource
-#define	bus_generic_write_ivar _bsd_bus_generic_write_ivar
-#define	bus_get_bus_tag _bsd_bus_get_bus_tag
-#define	bus_get_cpus _bsd_bus_get_cpus
-#define	bus_get_dma_tag _bsd_bus_get_dma_tag
-#define	bus_get_domain _bsd_bus_get_domain
-#define	bus_get_resource _bsd_bus_get_resource
-#define	bus_get_resource_count _bsd_bus_get_resource_count
-#define	bus_get_resource_start _bsd_bus_get_resource_start
-#define	bus_helper_reset_post _bsd_bus_helper_reset_post
-#define	bus_helper_reset_prepare _bsd_bus_helper_reset_prepare
-#define	bus_map_resource _bsd_bus_map_resource
-#define	bus_null_rescan _bsd_bus_null_rescan
-#define	bus_print_child_domain _bsd_bus_print_child_domain
-#define	bus_print_child_footer _bsd_bus_print_child_footer
-#define	bus_print_child_header _bsd_bus_print_child_header
-#define	bus_release_resource _bsd_bus_release_resource
-#define	bus_release_resources _bsd_bus_release_resources
-#define	bus_resume_intr _bsd_bus_resume_intr
-#define	bus_set_pass _bsd_bus_set_pass
-#define	bus_set_resource _bsd_bus_set_resource
-#define	bus_setup_intr _bsd_bus_setup_intr
-#define	bus_suspend_intr _bsd_bus_suspend_intr
-#define	bus_teardown_intr _bsd_bus_teardown_intr
-#define	bus_unmap_resource _bsd_bus_unmap_resource
-#define	calculate_crc32c _bsd_calculate_crc32c
-#define	callout_handle_init _bsd_callout_handle_init
-#define	callout_init _bsd_callout_init
-#define	_callout_init_lock _bsd__callout_init_lock
-#define	callout_process _bsd_callout_process
-#define	callout_reset_sbt_on _bsd_callout_reset_sbt_on
-#define	callout_schedule _bsd_callout_schedule
-#define	callout_schedule_on _bsd_callout_schedule_on
-#define	_callout_stop_safe _bsd__callout_stop_safe
-#define	callout_when _bsd_callout_when
-#define	camellia_decrypt _bsd_camellia_decrypt
-#define	camellia_decrypt128 _bsd_camellia_decrypt128
-#define	camellia_decrypt256 _bsd_camellia_decrypt256
-#define	Camellia_DecryptBlock _bsd_Camellia_DecryptBlock
-#define	Camellia_Ekeygen _bsd_Camellia_Ekeygen
-#define	camellia_encrypt _bsd_camellia_encrypt
-#define	camellia_encrypt128 _bsd_camellia_encrypt128
-#define	camellia_encrypt256 _bsd_camellia_encrypt256
-#define	Camellia_EncryptBlock _bsd_Camellia_EncryptBlock
-#define	camellia_set_key _bsd_camellia_set_key
-#define	camellia_setup128 _bsd_camellia_setup128
-#define	camellia_setup192 _bsd_camellia_setup192
-#define	camellia_setup256 _bsd_camellia_setup256
-#define	cam_fetch_status_entry _bsd_cam_fetch_status_entry
-#define	cam_quirkmatch _bsd_cam_quirkmatch
-#define	cam_sim_alloc _bsd_cam_sim_alloc
-#define	cam_sim_free _bsd_cam_sim_free
-#define	cam_simq_alloc _bsd_cam_simq_alloc
-#define	cam_simq_free _bsd_cam_simq_free
-#define	cam_sort_io_queues _bsd_cam_sort_io_queues
-#define	cam_status_table _bsd_cam_status_table
-#define	cam_strmatch _bsd_cam_strmatch
-#define	cam_strvis _bsd_cam_strvis
-#define	cam_strvis_sbuf _bsd_cam_strvis_sbuf
-#define	carp6_input _bsd_carp6_input
-#define	carp_attach _bsd_carp_attach
-#define	carp_attach_p _bsd_carp_attach_p
-#define	carp_demote_adj_p _bsd_carp_demote_adj_p
-#define	carp_detach _bsd_carp_detach
-#define	carp_detach_p _bsd_carp_detach_p
-#define	carp_forus _bsd_carp_forus
-#define	carp_forus_p _bsd_carp_forus_p
-#define	carp_get_vhid_p _bsd_carp_get_vhid_p
-#define	carp_iamatch _bsd_carp_iamatch
-#define	carp_iamatch6 _bsd_carp_iamatch6
-#define	carp_iamatch6_p _bsd_carp_iamatch6_p
-#define	carp_iamatch_p _bsd_carp_iamatch_p
-#define	carp_input _bsd_carp_input
-#define	carp_ioctl _bsd_carp_ioctl
-#define	carp_ioctl_p _bsd_carp_ioctl_p
-#define	carp_linkstate_p _bsd_carp_linkstate_p
-#define	carp_macmatch6 _bsd_carp_macmatch6
-#define	carp_macmatch6_p _bsd_carp_macmatch6_p
-#define	carp_master _bsd_carp_master
-#define	carp_master_p _bsd_carp_master_p
-#define	carp_output _bsd_carp_output
-#define	carp_output_p _bsd_carp_output_p
-#define	carpstats _bsd_carpstats
-#define	cast_decrypt _bsd_cast_decrypt
-#define	cast_encrypt _bsd_cast_encrypt
-#define	cast_setkey _bsd_cast_setkey
-#define	cc_abe_frlossreduce _bsd_cc_abe_frlossreduce
-#define	cc_ack_received _bsd_cc_ack_received
-#define	cc_cong_signal _bsd_cc_cong_signal
-#define	cc_conn_init _bsd_cc_conn_init
-#define	cc_cpu _bsd_cc_cpu
-#define	cc_deregister_algo _bsd_cc_deregister_algo
-#define	cc_do_abe _bsd_cc_do_abe
-#define	cc_list _bsd_cc_list
-#define	cc_list_lock _bsd_cc_list_lock
-#define	cc_modevent _bsd_cc_modevent
-#define	cc_post_recovery _bsd_cc_post_recovery
-#define	cc_register_algo _bsd_cc_register_algo
-#define	cdevpriv_mtx _bsd_cdevpriv_mtx
-#define	cgem_set_ref_clk _bsd_cgem_set_ref_clk
-#define	chacha_encrypt_bytes _bsd_chacha_encrypt_bytes
-#define	chacha_ivsetup _bsd_chacha_ivsetup
-#define	chacha_keysetup _bsd_chacha_keysetup
-#define	_ck_epoch_addref _bsd__ck_epoch_addref
-#define	ck_epoch_barrier _bsd_ck_epoch_barrier
-#define	ck_epoch_barrier_wait _bsd_ck_epoch_barrier_wait
-#define	_ck_epoch_delref _bsd__ck_epoch_delref
-#define	ck_epoch_init _bsd_ck_epoch_init
-#define	ck_epoch_poll _bsd_ck_epoch_poll
-#define	ck_epoch_poll_deferred _bsd_ck_epoch_poll_deferred
-#define	ck_epoch_reclaim _bsd_ck_epoch_reclaim
-#define	ck_epoch_recycle _bsd_ck_epoch_recycle
-#define	ck_epoch_register _bsd_ck_epoch_register
-#define	ck_epoch_synchronize _bsd_ck_epoch_synchronize
-#define	ck_epoch_synchronize_wait _bsd_ck_epoch_synchronize_wait
-#define	ck_epoch_unregister _bsd_ck_epoch_unregister
-#define	clean_unrhdr _bsd_clean_unrhdr
-#define	clean_unrhdrl _bsd_clean_unrhdrl
-#define	ClearCheckNewLink _bsd_ClearCheckNewLink
-#define	clear_unrhdr _bsd_clear_unrhdr
-#define	clk_intr_event _bsd_clk_intr_event
-#define	comp_algo_deflate _bsd_comp_algo_deflate
-#define	comp_algorithm_lookup _bsd_comp_algorithm_lookup
-#define	config_intrhook_disestablish _bsd_config_intrhook_disestablish
-#define	config_intrhook_establish _bsd_config_intrhook_establish
-#define	config_intrhook_oneshot _bsd_config_intrhook_oneshot
-#define	copyiniov _bsd_copyiniov
-#define	counter_ratecheck _bsd_counter_ratecheck
-#define	counter_u64_alloc _bsd_counter_u64_alloc
-#define	counter_u64_fetch _bsd_counter_u64_fetch
-#define	counter_u64_free _bsd_counter_u64_free
-#define	counter_u64_zero _bsd_counter_u64_zero
-#define	crc32_tab _bsd_crc32_tab
-#define	crypto_apply _bsd_crypto_apply
-#define	crypto_contiguous_subsegment _bsd_crypto_contiguous_subsegment
-#define	crypto_copyback _bsd_crypto_copyback
-#define	crypto_copydata _bsd_crypto_copydata
-#define	crypto_devallowsoft _bsd_crypto_devallowsoft
-#define	crypto_dispatch _bsd_crypto_dispatch
-#define	crypto_done _bsd_crypto_done
-#define	crypto_find_device_byhid _bsd_crypto_find_device_byhid
-#define	crypto_find_driver _bsd_crypto_find_driver
-#define	crypto_freereq _bsd_crypto_freereq
-#define	crypto_freesession _bsd_crypto_freesession
-#define	crypto_getcaps _bsd_crypto_getcaps
-#define	crypto_get_driverid _bsd_crypto_get_driverid
-#define	crypto_get_driver_session _bsd_crypto_get_driver_session
-#define	crypto_getfeat _bsd_crypto_getfeat
-#define	crypto_getreq _bsd_crypto_getreq
-#define	crypto_kdispatch _bsd_crypto_kdispatch
-#define	crypto_kdone _bsd_crypto_kdone
-#define	crypto_kregister _bsd_crypto_kregister
-#define	crypto_mbuftoiov _bsd_crypto_mbuftoiov
-#define	crypto_modevent _bsd_crypto_modevent
-#define	crypto_newsession _bsd_crypto_newsession
-#define	crypto_onetimeauth_poly1305 _bsd_crypto_onetimeauth_poly1305
-#define	crypto_onetimeauth_poly1305_bytes _bsd_crypto_onetimeauth_poly1305_bytes
-#define	crypto_onetimeauth_poly1305_donna_implementation _bsd_crypto_onetimeauth_poly1305_donna_implementation
-#define	crypto_onetimeauth_poly1305_final _bsd_crypto_onetimeauth_poly1305_final
-#define	crypto_onetimeauth_poly1305_init _bsd_crypto_onetimeauth_poly1305_init
-#define	crypto_onetimeauth_poly1305_keybytes _bsd_crypto_onetimeauth_poly1305_keybytes
-#define	_crypto_onetimeauth_poly1305_pick_best_implementation _bsd__crypto_onetimeauth_poly1305_pick_best_implementation
-#define	crypto_onetimeauth_poly1305_statebytes _bsd_crypto_onetimeauth_poly1305_statebytes
-#define	crypto_onetimeauth_poly1305_update _bsd_crypto_onetimeauth_poly1305_update
-#define	crypto_onetimeauth_poly1305_verify _bsd_crypto_onetimeauth_poly1305_verify
-#define	crypto_register _bsd_crypto_register
-#define	crypto_ses2caps _bsd_crypto_ses2caps
-#define	crypto_ses2hid _bsd_crypto_ses2hid
-#define	crypto_support _bsd_crypto_support
-#define	crypto_unblock _bsd_crypto_unblock
-#define	crypto_unregister _bsd_crypto_unregister
-#define	crypto_unregister_all _bsd_crypto_unregister_all
-#define	crypto_userasymcrypto _bsd_crypto_userasymcrypto
-#define	crypto_verify_16 _bsd_crypto_verify_16
-#define	crypto_verify_16_bytes _bsd_crypto_verify_16_bytes
-#define	crypto_verify_32 _bsd_crypto_verify_32
-#define	crypto_verify_32_bytes _bsd_crypto_verify_32_bytes
-#define	crypto_verify_64 _bsd_crypto_verify_64
-#define	crypto_verify_64_bytes _bsd_crypto_verify_64_bytes
-#define	ctl_subtype_name _bsd_ctl_subtype_name
-#define	cuio_apply _bsd_cuio_apply
-#define	cuio_copyback _bsd_cuio_copyback
-#define	cuio_copydata _bsd_cuio_copydata
-#define	cuio_getptr _bsd_cuio_getptr
-#define	cv_broadcastpri _bsd_cv_broadcastpri
-#define	cv_destroy _bsd_cv_destroy
-#define	cv_init _bsd_cv_init
-#define	cv_signal _bsd_cv_signal
-#define	_cv_timedwait_sbt _bsd__cv_timedwait_sbt
-#define	_cv_wait _bsd__cv_wait
-#define	_cv_wait_sig _bsd__cv_wait_sig
-#define	_cv_wait_unlock _bsd__cv_wait_unlock
-#define	deembed_scopeid _bsd_deembed_scopeid
-#define	default_cc_ptr _bsd_default_cc_ptr
-#define	deflate_global _bsd_deflate_global
-#define	defrouter_del _bsd_defrouter_del
-#define	defrouter_lookup _bsd_defrouter_lookup
-#define	defrouter_lookup_locked _bsd_defrouter_lookup_locked
-#define	defrouter_ref _bsd_defrouter_ref
-#define	defrouter_rele _bsd_defrouter_rele
-#define	defrouter_remove _bsd_defrouter_remove
-#define	defrouter_reset _bsd_defrouter_reset
-#define	defrouter_select _bsd_defrouter_select
-#define	defrouter_select_fib _bsd_defrouter_select_fib
-#define	defrouter_unlink _bsd_defrouter_unlink
-#define	DELAY _bsd_DELAY
-#define	delete_unrhdr _bsd_delete_unrhdr
-#define	delist_dev _bsd_delist_dev
-#define	deregister_tcp_functions _bsd_deregister_tcp_functions
-#define	des_check_key _bsd_des_check_key
-#define	des_check_key_parity _bsd_des_check_key_parity
-#define	des_decrypt3 _bsd_des_decrypt3
-#define	des_ecb3_encrypt _bsd_des_ecb3_encrypt
-#define	des_ecb_encrypt _bsd_des_ecb_encrypt
-#define	des_encrypt1 _bsd_des_encrypt1
-#define	des_encrypt2 _bsd_des_encrypt2
-#define	des_encrypt3 _bsd_des_encrypt3
-#define	des_fixup_key_parity _bsd_des_fixup_key_parity
-#define	des_is_weak_key _bsd_des_is_weak_key
-#define	des_key_sched _bsd_des_key_sched
-#define	des_options _bsd_des_options
-#define	des_set_key _bsd_des_set_key
-#define	des_set_key_checked _bsd_des_set_key_checked
-#define	des_set_key_unchecked _bsd_des_set_key_unchecked
-#define	des_set_odd_parity _bsd_des_set_odd_parity
-#define	des_SPtrans _bsd_des_SPtrans
-#define	dest6_input _bsd_dest6_input
-#define	destroy_dev _bsd_destroy_dev
-#define	destroy_dev_sched _bsd_destroy_dev_sched
-#define	destroy_dev_sched_cb _bsd_destroy_dev_sched_cb
-#define	devclass_add_driver _bsd_devclass_add_driver
-#define	devclass_create _bsd_devclass_create
-#define	devclass_delete_driver _bsd_devclass_delete_driver
-#define	devclass_find _bsd_devclass_find
-#define	devclass_find_free_unit _bsd_devclass_find_free_unit
-#define	devclass_get_count _bsd_devclass_get_count
-#define	devclass_get_device _bsd_devclass_get_device
-#define	devclass_get_devices _bsd_devclass_get_devices
-#define	devclass_get_drivers _bsd_devclass_get_drivers
-#define	devclass_get_maxunit _bsd_devclass_get_maxunit
-#define	devclass_get_name _bsd_devclass_get_name
-#define	devclass_get_parent _bsd_devclass_get_parent
-#define	devclass_get_softc _bsd_devclass_get_softc
-#define	devclass_get_sysctl_ctx _bsd_devclass_get_sysctl_ctx
-#define	devclass_get_sysctl_tree _bsd_devclass_get_sysctl_tree
-#define	devclass_set_parent _bsd_devclass_set_parent
-#define	devctl_notify _bsd_devctl_notify
-#define	devctl_notify_f _bsd_devctl_notify_f
-#define	devctl_queue_data _bsd_devctl_queue_data
-#define	devctl_queue_data_f _bsd_devctl_queue_data_f
-#define	dev_depends _bsd_dev_depends
-#define	devfs_clear_cdevpriv _bsd_devfs_clear_cdevpriv
-#define	devfs_destroy_cdevpriv _bsd_devfs_destroy_cdevpriv
-#define	devfs_fpdrop _bsd_devfs_fpdrop
-#define	devfs_get_cdevpriv _bsd_devfs_get_cdevpriv
-#define	devfs_set_cdevpriv _bsd_devfs_set_cdevpriv
-#define	device_add_child _bsd_device_add_child
-#define	device_add_child_ordered _bsd_device_add_child_ordered
-#define	device_attach _bsd_device_attach
-#define	device_busy _bsd_device_busy
-#define	device_claim_softc _bsd_device_claim_softc
-#define	device_delete_child _bsd_device_delete_child
-#define	device_delete_children _bsd_device_delete_children
-#define	device_detach _bsd_device_detach
-#define	device_disable _bsd_device_disable
-#define	device_enable _bsd_device_enable
-#define	device_find_child _bsd_device_find_child
-#define	device_free_softc _bsd_device_free_softc
-#define	device_get_children _bsd_device_get_children
-#define	device_get_desc _bsd_device_get_desc
-#define	device_get_devclass _bsd_device_get_devclass
-#define	device_get_driver _bsd_device_get_driver
-#define	device_get_flags _bsd_device_get_flags
-#define	device_get_ivars _bsd_device_get_ivars
-#define	device_get_name _bsd_device_get_name
-#define	device_get_nameunit _bsd_device_get_nameunit
-#define	device_get_parent _bsd_device_get_parent
-#define	device_get_softc _bsd_device_get_softc
-#define	device_get_state _bsd_device_get_state
-#define	device_get_sysctl_ctx _bsd_device_get_sysctl_ctx
-#define	device_get_sysctl_tree _bsd_device_get_sysctl_tree
-#define	device_get_unit _bsd_device_get_unit
-#define	device_has_quiet_children _bsd_device_has_quiet_children
-#define	device_is_alive _bsd_device_is_alive
-#define	device_is_attached _bsd_device_is_attached
-#define	device_is_devclass_fixed _bsd_device_is_devclass_fixed
-#define	device_is_enabled _bsd_device_is_enabled
-#define	device_is_quiet _bsd_device_is_quiet
-#define	device_is_suspended _bsd_device_is_suspended
-#define	device_printf _bsd_device_printf
-#define	device_print_prettyname _bsd_device_print_prettyname
-#define	device_probe _bsd_device_probe
-#define	device_probe_and_attach _bsd_device_probe_and_attach
-#define	device_probe_child _bsd_device_probe_child
-#define	device_quiesce _bsd_device_quiesce
-#define	device_quiet _bsd_device_quiet
-#define	device_quiet_children _bsd_device_quiet_children
-#define	device_set_desc _bsd_device_set_desc
-#define	device_set_desc_copy _bsd_device_set_desc_copy
-#define	device_set_devclass _bsd_device_set_devclass
-#define	device_set_devclass_fixed _bsd_device_set_devclass_fixed
-#define	device_set_driver _bsd_device_set_driver
-#define	device_set_flags _bsd_device_set_flags
-#define	device_set_ivars _bsd_device_set_ivars
-#define	device_set_softc _bsd_device_set_softc
-#define	device_set_unit _bsd_device_set_unit
-#define	device_set_usb_desc _bsd_device_set_usb_desc
-#define	device_shutdown _bsd_device_shutdown
-#define	device_unbusy _bsd_device_unbusy
-#define	device_verbose _bsd_device_verbose
-#define	dev_lock _bsd_dev_lock
-#define	devmtx _bsd_devmtx
-#define	dev_refl _bsd_dev_refl
-#define	dev_refthread _bsd_dev_refthread
-#define	dev_rel _bsd_dev_rel
-#define	dev_relthread _bsd_dev_relthread
-#define	devtoname _bsd_devtoname
-#define	dev_unlock _bsd_dev_unlock
-#define	DifferentialChecksum _bsd_DifferentialChecksum
-#define	div_protosw _bsd_div_protosw
-#define	div_usrreqs _bsd_div_usrreqs
-#define	domain_add _bsd_domain_add
-#define	domain_init _bsd_domain_init
-#define	domain_init_status _bsd_domain_init_status
-#define	domains _bsd_domains
-#define	drbr_dequeue_drv _bsd_drbr_dequeue_drv
-#define	drbr_enqueue_drv _bsd_drbr_enqueue_drv
-#define	drbr_inuse_drv _bsd_drbr_inuse_drv
-#define	drbr_needs_enqueue_drv _bsd_drbr_needs_enqueue_drv
-#define	driver_module_handler _bsd_driver_module_handler
-#define	dwc_driver _bsd_dwc_driver
-#define	dwc_otg_attach _bsd_dwc_otg_attach
-#define	dwc_otg_detach _bsd_dwc_otg_detach
-#define	dwc_otg_driver _bsd_dwc_otg_driver
-#define	dwc_otg_filter_interrupt _bsd_dwc_otg_filter_interrupt
-#define	dwc_otg_init _bsd_dwc_otg_init
-#define	dwc_otg_interrupt _bsd_dwc_otg_interrupt
-#define	dwc_otg_uninit _bsd_dwc_otg_uninit
-#define	e1000_acquire_nvm_generic _bsd_e1000_acquire_nvm_generic
-#define	e1000_acquire_phy _bsd_e1000_acquire_phy
-#define	e1000_acquire_swfw_sync _bsd_e1000_acquire_swfw_sync
-#define	e1000_blink_led _bsd_e1000_blink_led
-#define	e1000_blink_led_generic _bsd_e1000_blink_led_generic
-#define	e1000_calculate_checksum _bsd_e1000_calculate_checksum
-#define	e1000_cfg_on_link_up _bsd_e1000_cfg_on_link_up
-#define	e1000_check_alt_mac_addr_generic _bsd_e1000_check_alt_mac_addr_generic
-#define	e1000_check_downshift_generic _bsd_e1000_check_downshift_generic
-#define	e1000_check_for_ack _bsd_e1000_check_for_ack
-#define	e1000_check_for_copper_link_generic _bsd_e1000_check_for_copper_link_generic
-#define	e1000_check_for_fiber_link_generic _bsd_e1000_check_for_fiber_link_generic
-#define	e1000_check_for_link _bsd_e1000_check_for_link
-#define	e1000_check_for_msg _bsd_e1000_check_for_msg
-#define	e1000_check_for_rst _bsd_e1000_check_for_rst
-#define	e1000_check_for_serdes_link_generic _bsd_e1000_check_for_serdes_link_generic
-#define	e1000_check_mng_mode _bsd_e1000_check_mng_mode
-#define	e1000_check_mng_mode_generic _bsd_e1000_check_mng_mode_generic
-#define	e1000_check_phy_82574 _bsd_e1000_check_phy_82574
-#define	e1000_check_polarity_82577 _bsd_e1000_check_polarity_82577
-#define	e1000_check_polarity_ife _bsd_e1000_check_polarity_ife
-#define	e1000_check_polarity_igp _bsd_e1000_check_polarity_igp
-#define	e1000_check_polarity_m88 _bsd_e1000_check_polarity_m88
-#define	e1000_check_reset_block _bsd_e1000_check_reset_block
-#define	e1000_check_reset_block_generic _bsd_e1000_check_reset_block_generic
-#define	e1000_cleanup_led _bsd_e1000_cleanup_led
-#define	e1000_cleanup_led_generic _bsd_e1000_cleanup_led_generic
-#define	e1000_clear_hw_cntrs_base_generic _bsd_e1000_clear_hw_cntrs_base_generic
-#define	e1000_clear_vfta _bsd_e1000_clear_vfta
-#define	e1000_clear_vfta_generic _bsd_e1000_clear_vfta_generic
-#define	e1000_commit_fc_settings_generic _bsd_e1000_commit_fc_settings_generic
-#define	e1000_config_collision_dist _bsd_e1000_config_collision_dist
-#define	e1000_config_fc_after_link_up_generic _bsd_e1000_config_fc_after_link_up_generic
-#define	e1000_configure_k1_ich8lan _bsd_e1000_configure_k1_ich8lan
-#define	e1000_copper_link_autoneg _bsd_e1000_copper_link_autoneg
-#define	e1000_copper_link_setup_82577 _bsd_e1000_copper_link_setup_82577
-#define	e1000_copper_link_setup_igp _bsd_e1000_copper_link_setup_igp
-#define	e1000_copper_link_setup_m88 _bsd_e1000_copper_link_setup_m88
-#define	e1000_copper_link_setup_m88_gen2 _bsd_e1000_copper_link_setup_m88_gen2
-#define	e1000_copy_rx_addrs_to_phy_ich8lan _bsd_e1000_copy_rx_addrs_to_phy_ich8lan
-#define	e1000_determine_phy_address _bsd_e1000_determine_phy_address
-#define	e1000_disable_pcie_master _bsd_e1000_disable_pcie_master
-#define	e1000_disable_pcie_master_generic _bsd_e1000_disable_pcie_master_generic
-#define	e1000_disable_phy_wakeup_reg_access_bm _bsd_e1000_disable_phy_wakeup_reg_access_bm
-#define	e1000_disable_ulp_lpt_lp _bsd_e1000_disable_ulp_lpt_lp
-#define	e1000_enable_mng_pass_thru _bsd_e1000_enable_mng_pass_thru
-#define	e1000_enable_phy_wakeup_reg_access_bm _bsd_e1000_enable_phy_wakeup_reg_access_bm
-#define	e1000_enable_tx_pkt_filtering _bsd_e1000_enable_tx_pkt_filtering
-#define	e1000_enable_tx_pkt_filtering_generic _bsd_e1000_enable_tx_pkt_filtering_generic
-#define	e1000_enable_ulp_lpt_lp _bsd_e1000_enable_ulp_lpt_lp
-#define	e1000_force_mac_fc _bsd_e1000_force_mac_fc
-#define	e1000_force_mac_fc_generic _bsd_e1000_force_mac_fc_generic
-#define	e1000_get_auto_rd_done_generic _bsd_e1000_get_auto_rd_done_generic
-#define	e1000_get_bus_info _bsd_e1000_get_bus_info
-#define	e1000_get_bus_info_pcie_generic _bsd_e1000_get_bus_info_pcie_generic
-#define	e1000_get_bus_info_pci_generic _bsd_e1000_get_bus_info_pci_generic
-#define	e1000_get_cable_length _bsd_e1000_get_cable_length
-#define	e1000_get_cable_length_82577 _bsd_e1000_get_cable_length_82577
-#define	e1000_get_cable_length_igp_2 _bsd_e1000_get_cable_length_igp_2
-#define	e1000_get_cable_length_m88 _bsd_e1000_get_cable_length_m88
-#define	e1000_get_cable_length_m88_gen2 _bsd_e1000_get_cable_length_m88_gen2
-#define	e1000_get_cfg_done_generic _bsd_e1000_get_cfg_done_generic
-#define	e1000_get_eee_status_i354 _bsd_e1000_get_eee_status_i354
-#define	e1000_get_flash_presence_i210 _bsd_e1000_get_flash_presence_i210
-#define	e1000_get_hw_semaphore _bsd_e1000_get_hw_semaphore
-#define	e1000_get_laa_state_82571 _bsd_e1000_get_laa_state_82571
-#define	e1000_get_pba_block_size _bsd_e1000_get_pba_block_size
-#define	e1000_get_phy_id _bsd_e1000_get_phy_id
-#define	e1000_get_phy_info _bsd_e1000_get_phy_info
-#define	e1000_get_phy_info_82577 _bsd_e1000_get_phy_info_82577
-#define	e1000_get_phy_info_ife _bsd_e1000_get_phy_info_ife
-#define	e1000_get_phy_info_igp _bsd_e1000_get_phy_info_igp
-#define	e1000_get_phy_info_m88 _bsd_e1000_get_phy_info_m88
-#define	e1000_get_phy_type_from_id _bsd_e1000_get_phy_type_from_id
-#define	e1000_get_speed_and_duplex _bsd_e1000_get_speed_and_duplex
-#define	e1000_get_speed_and_duplex_copper_generic _bsd_e1000_get_speed_and_duplex_copper_generic
-#define	e1000_get_speed_and_duplex_fiber_serdes_generic _bsd_e1000_get_speed_and_duplex_fiber_serdes_generic
-#define	e1000_gig_downshift_workaround_ich8lan _bsd_e1000_gig_downshift_workaround_ich8lan
-#define	e1000_hash_mc_addr _bsd_e1000_hash_mc_addr
-#define	e1000_hash_mc_addr_generic _bsd_e1000_hash_mc_addr_generic
-#define	e1000_host_interface_command _bsd_e1000_host_interface_command
-#define	e1000_i2c_bus_clear _bsd_e1000_i2c_bus_clear
-#define	e1000_id_led_init _bsd_e1000_id_led_init
-#define	e1000_id_led_init_generic _bsd_e1000_id_led_init_generic
-#define	e1000_igp3_phy_powerdown_workaround_ich8lan _bsd_e1000_igp3_phy_powerdown_workaround_ich8lan
-#define	e1000_init_function_pointers_80003es2lan _bsd_e1000_init_function_pointers_80003es2lan
-#define	e1000_init_function_pointers_82540 _bsd_e1000_init_function_pointers_82540
-#define	e1000_init_function_pointers_82541 _bsd_e1000_init_function_pointers_82541
-#define	e1000_init_function_pointers_82542 _bsd_e1000_init_function_pointers_82542
-#define	e1000_init_function_pointers_82543 _bsd_e1000_init_function_pointers_82543
-#define	e1000_init_function_pointers_82571 _bsd_e1000_init_function_pointers_82571
-#define	e1000_init_function_pointers_82575 _bsd_e1000_init_function_pointers_82575
-#define	e1000_init_function_pointers_i210 _bsd_e1000_init_function_pointers_i210
-#define	e1000_init_function_pointers_ich8lan _bsd_e1000_init_function_pointers_ich8lan
-#define	e1000_init_function_pointers_vf _bsd_e1000_init_function_pointers_vf
-#define	e1000_init_hw _bsd_e1000_init_hw
-#define	e1000_init_hw_82575 _bsd_e1000_init_hw_82575
-#define	e1000_init_hw_i210 _bsd_e1000_init_hw_i210
-#define	e1000_initialize_M88E1512_phy _bsd_e1000_initialize_M88E1512_phy
-#define	e1000_initialize_M88E1543_phy _bsd_e1000_initialize_M88E1543_phy
-#define	e1000_init_mac_ops_generic _bsd_e1000_init_mac_ops_generic
-#define	e1000_init_mac_params _bsd_e1000_init_mac_params
-#define	e1000_init_mbx_ops_generic _bsd_e1000_init_mbx_ops_generic
-#define	e1000_init_mbx_params _bsd_e1000_init_mbx_params
-#define	e1000_init_mbx_params_pf _bsd_e1000_init_mbx_params_pf
-#define	e1000_init_mbx_params_vf _bsd_e1000_init_mbx_params_vf
-#define	e1000_init_nvm_ops_generic _bsd_e1000_init_nvm_ops_generic
-#define	e1000_init_nvm_params _bsd_e1000_init_nvm_params
-#define	e1000_init_nvm_params_82575 _bsd_e1000_init_nvm_params_82575
-#define	e1000_init_phy_ops_generic _bsd_e1000_init_phy_ops_generic
-#define	e1000_init_phy_params _bsd_e1000_init_phy_params
-#define	e1000_init_rx_addrs_generic _bsd_e1000_init_rx_addrs_generic
-#define	e1000_init_script_state_82541 _bsd_e1000_init_script_state_82541
-#define	e1000_is_mphy_ready _bsd_e1000_is_mphy_ready
-#define	e1000_led_off _bsd_e1000_led_off
-#define	e1000_led_off_generic _bsd_e1000_led_off_generic
-#define	e1000_led_on _bsd_e1000_led_on
-#define	e1000_led_on_generic _bsd_e1000_led_on_generic
-#define	e1000_link_stall_workaround_hv _bsd_e1000_link_stall_workaround_hv
-#define	e1000_load_firmware _bsd_e1000_load_firmware
-#define	e1000_lv_jumbo_workaround_ich8lan _bsd_e1000_lv_jumbo_workaround_ich8lan
-#define	e1000_mng_enable_host_if _bsd_e1000_mng_enable_host_if
-#define	e1000_mng_enable_host_if_generic _bsd_e1000_mng_enable_host_if_generic
-#define	e1000_mng_host_if_write _bsd_e1000_mng_host_if_write
-#define	e1000_mng_host_if_write_generic _bsd_e1000_mng_host_if_write_generic
-#define	e1000_mng_write_cmd_header _bsd_e1000_mng_write_cmd_header
-#define	e1000_mng_write_cmd_header_generic _bsd_e1000_mng_write_cmd_header_generic
-#define	e1000_mng_write_dhcp_info _bsd_e1000_mng_write_dhcp_info
-#define	e1000_mng_write_dhcp_info_generic _bsd_e1000_mng_write_dhcp_info_generic
-#define	e1000_null_led_default _bsd_e1000_null_led_default
-#define	e1000_null_link_info _bsd_e1000_null_link_info
-#define	e1000_null_lplu_state _bsd_e1000_null_lplu_state
-#define	e1000_null_mac_generic _bsd_e1000_null_mac_generic
-#define	e1000_null_mng_mode _bsd_e1000_null_mng_mode
-#define	e1000_null_nvm_generic _bsd_e1000_null_nvm_generic
-#define	e1000_null_ops_generic _bsd_e1000_null_ops_generic
-#define	e1000_null_phy_generic _bsd_e1000_null_phy_generic
-#define	e1000_null_rar_set _bsd_e1000_null_rar_set
-#define	e1000_null_read_nvm _bsd_e1000_null_read_nvm
-#define	e1000_null_read_reg _bsd_e1000_null_read_reg
-#define	e1000_null_set_obff_timer _bsd_e1000_null_set_obff_timer
-#define	e1000_null_set_page _bsd_e1000_null_set_page
-#define	e1000_null_update_mc _bsd_e1000_null_update_mc
-#define	e1000_null_write_nvm _bsd_e1000_null_write_nvm
-#define	e1000_null_write_reg _bsd_e1000_null_write_reg
-#define	e1000_null_write_vfta _bsd_e1000_null_write_vfta
-#define	e1000_pci_clear_mwi _bsd_e1000_pci_clear_mwi
-#define	e1000_pci_set_mwi _bsd_e1000_pci_set_mwi
-#define	e1000_pcix_mmrbc_workaround_generic _bsd_e1000_pcix_mmrbc_workaround_generic
-#define	e1000_phy_commit _bsd_e1000_phy_commit
-#define	e1000_phy_force_speed_duplex_82577 _bsd_e1000_phy_force_speed_duplex_82577
-#define	e1000_phy_force_speed_duplex_ife _bsd_e1000_phy_force_speed_duplex_ife
-#define	e1000_phy_force_speed_duplex_igp _bsd_e1000_phy_force_speed_duplex_igp
-#define	e1000_phy_force_speed_duplex_m88 _bsd_e1000_phy_force_speed_duplex_m88
-#define	e1000_phy_force_speed_duplex_setup _bsd_e1000_phy_force_speed_duplex_setup
-#define	e1000_phy_has_link_generic _bsd_e1000_phy_has_link_generic
-#define	e1000_phy_hw_reset _bsd_e1000_phy_hw_reset
-#define	e1000_phy_hw_reset_generic _bsd_e1000_phy_hw_reset_generic
-#define	e1000_phy_init_script_igp3 _bsd_e1000_phy_init_script_igp3
-#define	e1000_phy_reset_dsp_generic _bsd_e1000_phy_reset_dsp_generic
-#define	e1000_phy_setup_autoneg _bsd_e1000_phy_setup_autoneg
-#define	e1000_phy_sw_reset_generic _bsd_e1000_phy_sw_reset_generic
-#define	e1000_poll_eerd_eewr_done _bsd_e1000_poll_eerd_eewr_done
-#define	e1000_poll_fiber_serdes_link_generic _bsd_e1000_poll_fiber_serdes_link_generic
-#define	e1000_power_down_phy _bsd_e1000_power_down_phy
-#define	e1000_power_down_phy_copper _bsd_e1000_power_down_phy_copper
-#define	e1000_power_up_fiber_serdes_link _bsd_e1000_power_up_fiber_serdes_link
-#define	e1000_power_up_phy _bsd_e1000_power_up_phy
-#define	e1000_power_up_phy_copper _bsd_e1000_power_up_phy_copper
-#define	e1000_promisc_set_vf _bsd_e1000_promisc_set_vf
-#define	e1000_put_hw_semaphore _bsd_e1000_put_hw_semaphore
-#define	e1000_rar_set _bsd_e1000_rar_set
-#define	e1000_read_emi_reg _bsd_e1000_read_emi_reg
-#define	e1000_read_emi_reg_locked _bsd_e1000_read_emi_reg_locked
-#define	e1000_read_i2c_byte_generic _bsd_e1000_read_i2c_byte_generic
-#define	e1000_read_i2c_byte_null _bsd_e1000_read_i2c_byte_null
-#define	e1000_read_kmrn_reg _bsd_e1000_read_kmrn_reg
-#define	e1000_read_kmrn_reg_generic _bsd_e1000_read_kmrn_reg_generic
-#define	e1000_read_kmrn_reg_locked _bsd_e1000_read_kmrn_reg_locked
-#define	e1000_read_mac_addr _bsd_e1000_read_mac_addr
-#define	e1000_read_mac_addr_generic _bsd_e1000_read_mac_addr_generic
-#define	e1000_read_mbx _bsd_e1000_read_mbx
-#define	e1000_read_nvm _bsd_e1000_read_nvm
-#define	e1000_read_nvm_eerd _bsd_e1000_read_nvm_eerd
-#define	e1000_read_nvm_microwire _bsd_e1000_read_nvm_microwire
-#define	e1000_read_nvm_spi _bsd_e1000_read_nvm_spi
-#define	e1000_read_nvm_srrd_i210 _bsd_e1000_read_nvm_srrd_i210
-#define	e1000_read_pba_length _bsd_e1000_read_pba_length
-#define	e1000_read_pba_length_generic _bsd_e1000_read_pba_length_generic
-#define	e1000_read_pba_raw _bsd_e1000_read_pba_raw
-#define	e1000_read_pba_string _bsd_e1000_read_pba_string
-#define	e1000_read_pba_string_generic _bsd_e1000_read_pba_string_generic
-#define	e1000_read_pci_cfg _bsd_e1000_read_pci_cfg
-#define	e1000_read_pcie_cap_reg _bsd_e1000_read_pcie_cap_reg
-#define	e1000_read_phy_reg _bsd_e1000_read_phy_reg
-#define	e1000_read_phy_reg_bm _bsd_e1000_read_phy_reg_bm
-#define	e1000_read_phy_reg_bm2 _bsd_e1000_read_phy_reg_bm2
-#define	e1000_read_phy_reg_gs40g _bsd_e1000_read_phy_reg_gs40g
-#define	e1000_read_phy_reg_hv _bsd_e1000_read_phy_reg_hv
-#define	e1000_read_phy_reg_hv_locked _bsd_e1000_read_phy_reg_hv_locked
-#define	e1000_read_phy_reg_i2c _bsd_e1000_read_phy_reg_i2c
-#define	e1000_read_phy_reg_igp _bsd_e1000_read_phy_reg_igp
-#define	e1000_read_phy_reg_igp_locked _bsd_e1000_read_phy_reg_igp_locked
-#define	e1000_read_phy_reg_m88 _bsd_e1000_read_phy_reg_m88
-#define	e1000_read_phy_reg_mdic _bsd_e1000_read_phy_reg_mdic
-#define	e1000_read_phy_reg_mphy _bsd_e1000_read_phy_reg_mphy
-#define	e1000_read_phy_reg_page_hv _bsd_e1000_read_phy_reg_page_hv
-#define	e1000_read_posted_mbx _bsd_e1000_read_posted_mbx
-#define	e1000_read_sfp_data_byte _bsd_e1000_read_sfp_data_byte
-#define	e1000_read_xmdio_reg _bsd_e1000_read_xmdio_reg
-#define	e1000_release_nvm_generic _bsd_e1000_release_nvm_generic
-#define	e1000_release_phy _bsd_e1000_release_phy
-#define	e1000_release_swfw_sync _bsd_e1000_release_swfw_sync
-#define	e1000_reload_nvm _bsd_e1000_reload_nvm
-#define	e1000_reset_adaptive _bsd_e1000_reset_adaptive
-#define	e1000_reset_adaptive_generic _bsd_e1000_reset_adaptive_generic
-#define	e1000_reset_hw _bsd_e1000_reset_hw
-#define	e1000_resume_workarounds_pchlan _bsd_e1000_resume_workarounds_pchlan
-#define	e1000_rlpml_set_vf _bsd_e1000_rlpml_set_vf
-#define	e1000_rx_fifo_flush_82575 _bsd_e1000_rx_fifo_flush_82575
-#define	e1000_rxpbs_adjust_82580 _bsd_e1000_rxpbs_adjust_82580
-#define	e1000_set_d0_lplu_state _bsd_e1000_set_d0_lplu_state
-#define	e1000_set_d3_lplu_state _bsd_e1000_set_d3_lplu_state
-#define	e1000_set_d3_lplu_state_generic _bsd_e1000_set_d3_lplu_state_generic
-#define	e1000_set_default_fc_generic _bsd_e1000_set_default_fc_generic
-#define	e1000_set_eee_i350 _bsd_e1000_set_eee_i350
-#define	e1000_set_eee_i354 _bsd_e1000_set_eee_i354
-#define	e1000_set_eee_pchlan _bsd_e1000_set_eee_pchlan
-#define	e1000_set_fc_watermarks_generic _bsd_e1000_set_fc_watermarks_generic
-#define	e1000_set_i2c_bb _bsd_e1000_set_i2c_bb
-#define	e1000_set_kmrn_lock_loss_workaround_ich8lan _bsd_e1000_set_kmrn_lock_loss_workaround_ich8lan
-#define	e1000_set_laa_state_82571 _bsd_e1000_set_laa_state_82571
-#define	e1000_set_lan_id_multi_port_pci _bsd_e1000_set_lan_id_multi_port_pci
-#define	e1000_set_lan_id_single_port _bsd_e1000_set_lan_id_single_port
-#define	e1000_set_mac_type _bsd_e1000_set_mac_type
-#define	e1000_set_obff_timer _bsd_e1000_set_obff_timer
-#define	e1000_set_page_igp _bsd_e1000_set_page_igp
-#define	e1000_set_pcie_no_snoop_generic _bsd_e1000_set_pcie_no_snoop_generic
-#define	e1000_set_tbi_compatibility_82543 _bsd_e1000_set_tbi_compatibility_82543
-#define	e1000_setup_copper_link_generic _bsd_e1000_setup_copper_link_generic
-#define	e1000_setup_fiber_serdes_link_generic _bsd_e1000_setup_fiber_serdes_link_generic
-#define	e1000_setup_init_funcs _bsd_e1000_setup_init_funcs
-#define	e1000_setup_led _bsd_e1000_setup_led
-#define	e1000_setup_led_generic _bsd_e1000_setup_led_generic
-#define	e1000_setup_link _bsd_e1000_setup_link
-#define	e1000_setup_link_generic _bsd_e1000_setup_link_generic
-#define	e1000_shutdown_fiber_serdes_link _bsd_e1000_shutdown_fiber_serdes_link
-#define	e1000_stop_nvm _bsd_e1000_stop_nvm
-#define	e1000_suspend_workarounds_ich8lan _bsd_e1000_suspend_workarounds_ich8lan
-#define	e1000_tbi_adjust_stats_82543 _bsd_e1000_tbi_adjust_stats_82543
-#define	e1000_tbi_sbp_enabled_82543 _bsd_e1000_tbi_sbp_enabled_82543
-#define	e1000_translate_register_82542 _bsd_e1000_translate_register_82542
-#define	e1000_update_adaptive _bsd_e1000_update_adaptive
-#define	e1000_update_adaptive_generic _bsd_e1000_update_adaptive_generic
-#define	e1000_update_flash_i210 _bsd_e1000_update_flash_i210
-#define	e1000_update_mc_addr_list _bsd_e1000_update_mc_addr_list
-#define	e1000_update_mc_addr_list_generic _bsd_e1000_update_mc_addr_list_generic
-#define	e1000_update_nvm_checksum _bsd_e1000_update_nvm_checksum
-#define	e1000_update_nvm_checksum_generic _bsd_e1000_update_nvm_checksum_generic
-#define	e1000_update_nvm_checksum_i210 _bsd_e1000_update_nvm_checksum_i210
-#define	e1000_validate_mdi_setting _bsd_e1000_validate_mdi_setting
-#define	e1000_validate_mdi_setting_crossover_generic _bsd_e1000_validate_mdi_setting_crossover_generic
-#define	e1000_validate_nvm_checksum _bsd_e1000_validate_nvm_checksum
-#define	e1000_validate_nvm_checksum_generic _bsd_e1000_validate_nvm_checksum_generic
-#define	e1000_validate_nvm_checksum_i210 _bsd_e1000_validate_nvm_checksum_i210
-#define	e1000_valid_led_default_generic _bsd_e1000_valid_led_default_generic
-#define	e1000_vfta_set_vf _bsd_e1000_vfta_set_vf
-#define	e1000_vmdq_set_anti_spoofing_pf _bsd_e1000_vmdq_set_anti_spoofing_pf
-#define	e1000_vmdq_set_loopback_pf _bsd_e1000_vmdq_set_loopback_pf
-#define	e1000_vmdq_set_replication_pf _bsd_e1000_vmdq_set_replication_pf
-#define	e1000_write_8bit_ctrl_reg _bsd_e1000_write_8bit_ctrl_reg
-#define	e1000_write_8bit_ctrl_reg_generic _bsd_e1000_write_8bit_ctrl_reg_generic
-#define	e1000_write_emi_reg_locked _bsd_e1000_write_emi_reg_locked
-#define	e1000_write_i2c_byte_generic _bsd_e1000_write_i2c_byte_generic
-#define	e1000_write_i2c_byte_null _bsd_e1000_write_i2c_byte_null
-#define	e1000_write_kmrn_reg _bsd_e1000_write_kmrn_reg
-#define	e1000_write_kmrn_reg_generic _bsd_e1000_write_kmrn_reg_generic
-#define	e1000_write_kmrn_reg_locked _bsd_e1000_write_kmrn_reg_locked
-#define	e1000_write_mbx _bsd_e1000_write_mbx
-#define	e1000_write_nvm _bsd_e1000_write_nvm
-#define	e1000_write_nvm_microwire _bsd_e1000_write_nvm_microwire
-#define	e1000_write_nvm_spi _bsd_e1000_write_nvm_spi
-#define	e1000_write_nvm_srwr_i210 _bsd_e1000_write_nvm_srwr_i210
-#define	e1000_write_pba_raw _bsd_e1000_write_pba_raw
-#define	e1000_write_pci_cfg _bsd_e1000_write_pci_cfg
-#define	e1000_write_pcie_cap_reg _bsd_e1000_write_pcie_cap_reg
-#define	e1000_write_phy_reg _bsd_e1000_write_phy_reg
-#define	e1000_write_phy_reg_bm _bsd_e1000_write_phy_reg_bm
-#define	e1000_write_phy_reg_bm2 _bsd_e1000_write_phy_reg_bm2
-#define	e1000_write_phy_reg_gs40g _bsd_e1000_write_phy_reg_gs40g
-#define	e1000_write_phy_reg_hv _bsd_e1000_write_phy_reg_hv
-#define	e1000_write_phy_reg_hv_locked _bsd_e1000_write_phy_reg_hv_locked
-#define	e1000_write_phy_reg_i2c _bsd_e1000_write_phy_reg_i2c
-#define	e1000_write_phy_reg_igp _bsd_e1000_write_phy_reg_igp
-#define	e1000_write_phy_reg_igp_locked _bsd_e1000_write_phy_reg_igp_locked
-#define	e1000_write_phy_reg_m88 _bsd_e1000_write_phy_reg_m88
-#define	e1000_write_phy_reg_mdic _bsd_e1000_write_phy_reg_mdic
-#define	e1000_write_phy_reg_mphy _bsd_e1000_write_phy_reg_mphy
-#define	e1000_write_phy_reg_page_hv _bsd_e1000_write_phy_reg_page_hv
-#define	e1000_write_posted_mbx _bsd_e1000_write_posted_mbx
-#define	e1000_write_sfp_data_byte _bsd_e1000_write_sfp_data_byte
-#define	e1000_write_vfta _bsd_e1000_write_vfta
-#define	e1000_write_vfta_generic _bsd_e1000_write_vfta_generic
-#define	e1000_write_vfta_i350 _bsd_e1000_write_vfta_i350
-#define	e1000_write_xmdio_reg _bsd_e1000_write_xmdio_reg
-#define	early_counter _bsd_early_counter
-#define	edid_is_valid _bsd_edid_is_valid
-#define	edid_nproducts _bsd_edid_nproducts
-#define	edid_nvendors _bsd_edid_nvendors
-#define	edid_parse _bsd_edid_parse
-#define	edid_print _bsd_edid_print
-#define	edid_products _bsd_edid_products
-#define	edid_vendors _bsd_edid_vendors
-#define	ehci_detach _bsd_ehci_detach
-#define	ehci_get_port_speed_hostc _bsd_ehci_get_port_speed_hostc
-#define	ehci_get_port_speed_portsc _bsd_ehci_get_port_speed_portsc
-#define	ehci_init _bsd_ehci_init
-#define	ehci_interrupt _bsd_ehci_interrupt
-#define	ehci_iterate_hw_softc _bsd_ehci_iterate_hw_softc
-#define	ehci_reset _bsd_ehci_reset
-#define	ehci_resume _bsd_ehci_resume
-#define	ehci_suspend _bsd_ehci_suspend
-#define	em_driver_version _bsd_em_driver_version
-#define	em_dump_rs _bsd_em_dump_rs
-#define	em_intr _bsd_em_intr
-#define	em_sctx _bsd_em_sctx
-#define	em_txrx _bsd_em_txrx
-#define	enc_algorithm_lookup _bsd_enc_algorithm_lookup
-#define	encap4_input _bsd_encap4_input
-#define	encap6_input _bsd_encap6_input
-#define	enc_xform_3des _bsd_enc_xform_3des
-#define	enc_xform_aes_icm _bsd_enc_xform_aes_icm
-#define	enc_xform_aes_nist_gcm _bsd_enc_xform_aes_nist_gcm
-#define	enc_xform_aes_nist_gmac _bsd_enc_xform_aes_nist_gmac
-#define	enc_xform_aes_xts _bsd_enc_xform_aes_xts
-#define	enc_xform_arc4 _bsd_enc_xform_arc4
-#define	enc_xform_blf _bsd_enc_xform_blf
-#define	enc_xform_camellia _bsd_enc_xform_camellia
-#define	enc_xform_cast5 _bsd_enc_xform_cast5
-#define	enc_xform_ccm _bsd_enc_xform_ccm
-#define	enc_xform_chacha20 _bsd_enc_xform_chacha20
-#define	enc_xform_des _bsd_enc_xform_des
-#define	enc_xform_null _bsd_enc_xform_null
-#define	enc_xform_rijndael128 _bsd_enc_xform_rijndael128
-#define	enc_xform_skipjack _bsd_enc_xform_skipjack
-#define	eopnotsupp _bsd_eopnotsupp
-#define	epoch_call _bsd_epoch_call
-#define	epoch_drain_callbacks _bsd_epoch_drain_callbacks
-#define	epoch_enter _bsd_epoch_enter
-#define	epoch_enter_preempt _bsd_epoch_enter_preempt
-#define	epoch_exit _bsd_epoch_exit
-#define	epoch_exit_preempt _bsd_epoch_exit_preempt
-#define	epoch_init _bsd_epoch_init
-#define	epoch_wait _bsd_epoch_wait
-#define	epoch_wait_preempt _bsd_epoch_wait_preempt
-#define	errno2iic _bsd_errno2iic
-#define	esp_enable _bsd_esp_enable
-#define	esp_hdrsiz _bsd_esp_hdrsiz
-#define	espstat _bsd_espstat
-#define	ether_8021q_frame _bsd_ether_8021q_frame
-#define	ether_crc32_be _bsd_ether_crc32_be
-#define	ether_crc32_le _bsd_ether_crc32_le
-#define	ether_demux _bsd_ether_demux
-#define	ether_gen_addr _bsd_ether_gen_addr
-#define	ether_ifattach _bsd_ether_ifattach
-#define	ether_ifdetach _bsd_ether_ifdetach
-#define	ether_ioctl _bsd_ether_ioctl
-#define	ethermulticastaddr_slowprotocols _bsd_ethermulticastaddr_slowprotocols
-#define	ether_output _bsd_ether_output
-#define	ether_output_frame _bsd_ether_output_frame
-#define	ether_sprintf _bsd_ether_sprintf
-#define	ether_vlanencap _bsd_ether_vlanencap
-#define	ether_vlan_mtap _bsd_ether_vlan_mtap
-#define	evdev_alloc _bsd_evdev_alloc
-#define	evdev_cdev_create _bsd_evdev_cdev_create
-#define	evdev_cdev_destroy _bsd_evdev_cdev_destroy
-#define	evdev_client_dumpqueue _bsd_evdev_client_dumpqueue
-#define	evdev_client_push _bsd_evdev_client_push
-#define	evdev_dispose_client _bsd_evdev_dispose_client
-#define	evdev_event_supported _bsd_evdev_event_supported
-#define	evdev_free _bsd_evdev_free
-#define	evdev_get_last_mt_slot _bsd_evdev_get_last_mt_slot
-#define	evdev_get_mt_slot_by_tracking_id _bsd_evdev_get_mt_slot_by_tracking_id
-#define	evdev_get_mt_value _bsd_evdev_get_mt_value
-#define	evdev_get_softc _bsd_evdev_get_softc
-#define	evdev_grab_client _bsd_evdev_grab_client
-#define	evdev_hid2key _bsd_evdev_hid2key
-#define	evdev_inject_event _bsd_evdev_inject_event
-#define	evdev_mt_free _bsd_evdev_mt_free
-#define	evdev_mt_init _bsd_evdev_mt_init
-#define	evdev_notify_event _bsd_evdev_notify_event
-#define	evdev_push_event _bsd_evdev_push_event
-#define	evdev_push_leds _bsd_evdev_push_leds
-#define	evdev_push_mouse_btn _bsd_evdev_push_mouse_btn
-#define	evdev_push_mt_compat _bsd_evdev_push_mt_compat
-#define	evdev_push_nfingers _bsd_evdev_push_nfingers
-#define	evdev_push_repeats _bsd_evdev_push_repeats
-#define	evdev_rcpt_mask _bsd_evdev_rcpt_mask
-#define	evdev_register _bsd_evdev_register
-#define	evdev_register_client _bsd_evdev_register_client
-#define	evdev_register_mtx _bsd_evdev_register_mtx
-#define	evdev_release_client _bsd_evdev_release_client
-#define	evdev_restore_after_kdb _bsd_evdev_restore_after_kdb
-#define	evdev_revoke_client _bsd_evdev_revoke_client
-#define	evdev_scancode2key _bsd_evdev_scancode2key
-#define	evdev_send_event _bsd_evdev_send_event
-#define	evdev_send_mt_autorel _bsd_evdev_send_mt_autorel
-#define	evdev_send_mt_compat _bsd_evdev_send_mt_compat
-#define	evdev_set_abs_bit _bsd_evdev_set_abs_bit
-#define	evdev_set_absinfo _bsd_evdev_set_absinfo
-#define	evdev_set_flag _bsd_evdev_set_flag
-#define	evdev_set_id _bsd_evdev_set_id
-#define	evdev_set_last_mt_slot _bsd_evdev_set_last_mt_slot
-#define	evdev_set_methods _bsd_evdev_set_methods
-#define	evdev_set_mt_value _bsd_evdev_set_mt_value
-#define	evdev_set_name _bsd_evdev_set_name
-#define	evdev_set_phys _bsd_evdev_set_phys
-#define	evdev_set_repeat_params _bsd_evdev_set_repeat_params
-#define	evdev_set_report_size _bsd_evdev_set_report_size
-#define	evdev_set_serial _bsd_evdev_set_serial
-#define	evdev_support_abs _bsd_evdev_support_abs
-#define	evdev_support_all_known_keys _bsd_evdev_support_all_known_keys
-#define	evdev_support_event _bsd_evdev_support_event
-#define	evdev_support_key _bsd_evdev_support_key
-#define	evdev_support_led _bsd_evdev_support_led
-#define	evdev_support_msc _bsd_evdev_support_msc
-#define	evdev_support_mt_compat _bsd_evdev_support_mt_compat
-#define	evdev_support_nfingers _bsd_evdev_support_nfingers
-#define	evdev_support_prop _bsd_evdev_support_prop
-#define	evdev_support_rel _bsd_evdev_support_rel
-#define	evdev_support_snd _bsd_evdev_support_snd
-#define	evdev_support_sw _bsd_evdev_support_sw
-#define	evdev_sysmouse_t_axis _bsd_evdev_sysmouse_t_axis
-#define	evdev_unregister _bsd_evdev_unregister
-#define	eventhandler_create_list _bsd_eventhandler_create_list
-#define	eventhandler_deregister _bsd_eventhandler_deregister
-#define	eventhandler_deregister_nowait _bsd_eventhandler_deregister_nowait
-#define	eventhandler_find_list _bsd_eventhandler_find_list
-#define	eventhandler_prune_list _bsd_eventhandler_prune_list
-#define	eventhandler_register _bsd_eventhandler_register
-#define	fb_commonioctl _bsd_fb_commonioctl
-#define	fbd_devclass _bsd_fbd_devclass
-#define	fbd_driver _bsd_fbd_driver
-#define	fbd_list _bsd_fbd_list
-#define	fbd_register _bsd_fbd_register
-#define	fb_dump_adp_info _bsd_fb_dump_adp_info
-#define	fb_dump_mode_info _bsd_fb_dump_mode_info
-#define	fbd_unregister _bsd_fbd_unregister
-#define	fb_list_head _bsd_fb_list_head
-#define	fb_type _bsd_fb_type
-#define	fdt_addrsize_cells _bsd_fdt_addrsize_cells
-#define	fdt_data_get _bsd_fdt_data_get
-#define	fdt_data_to_res _bsd_fdt_data_to_res
-#define	fdt_depth_search_compatible _bsd_fdt_depth_search_compatible
-#define	fdt_find_compatible _bsd_fdt_find_compatible
-#define	fdt_get_chosen_bootargs _bsd_fdt_get_chosen_bootargs
-#define	fdt_get_mem_regions _bsd_fdt_get_mem_regions
-#define	fdt_get_phyaddr _bsd_fdt_get_phyaddr
-#define	fdt_get_range _bsd_fdt_get_range
-#define	fdt_get_reserved_mem _bsd_fdt_get_reserved_mem
-#define	fdt_get_reserved_regions _bsd_fdt_get_reserved_regions
-#define	fdt_ic_list_head _bsd_fdt_ic_list_head
-#define	fdt_immr_addr _bsd_fdt_immr_addr
-#define	fdt_immr_pa _bsd_fdt_immr_pa
-#define	fdt_immr_size _bsd_fdt_immr_size
-#define	fdt_immr_va _bsd_fdt_immr_va
-#define	fdt_is_compatible_strict _bsd_fdt_is_compatible_strict
-#define	fdt_parent_addr_cells _bsd_fdt_parent_addr_cells
-#define	fdt_pinctrl_configure _bsd_fdt_pinctrl_configure
-#define	fdt_pinctrl_configure_by_name _bsd_fdt_pinctrl_configure_by_name
-#define	fdt_pinctrl_configure_tree _bsd_fdt_pinctrl_configure_tree
-#define	fdt_pinctrl_register _bsd_fdt_pinctrl_register
-#define	fdt_regsize _bsd_fdt_regsize
-#define	fib4_free_nh_ext _bsd_fib4_free_nh_ext
-#define	fib4_lookup_nh_basic _bsd_fib4_lookup_nh_basic
-#define	fib4_lookup_nh_ext _bsd_fib4_lookup_nh_ext
-#define	fib6_free_nh_ext _bsd_fib6_free_nh_ext
-#define	fib6_lookup_nh_basic _bsd_fib6_lookup_nh_basic
-#define	fib6_lookup_nh_ext _bsd_fib6_lookup_nh_ext
-#define	FindAliasAddress _bsd_FindAliasAddress
-#define	find_and_ref_tcp_fb _bsd_find_and_ref_tcp_fb
-#define	find_and_ref_tcp_functions _bsd_find_and_ref_tcp_functions
-#define	FindFragmentIn1 _bsd_FindFragmentIn1
-#define	FindFragmentIn2 _bsd_FindFragmentIn2
-#define	FindFragmentPtr _bsd_FindFragmentPtr
-#define	find_handler _bsd_find_handler
-#define	FindIcmpIn _bsd_FindIcmpIn
-#define	FindIcmpOut _bsd_FindIcmpOut
-#define	FindNewPortGroup _bsd_FindNewPortGroup
-#define	FindOriginalAddress _bsd_FindOriginalAddress
-#define	FindPptpInByCallId _bsd_FindPptpInByCallId
-#define	FindPptpInByPeerCallId _bsd_FindPptpInByPeerCallId
-#define	FindPptpOutByCallId _bsd_FindPptpOutByCallId
-#define	FindPptpOutByPeerCallId _bsd_FindPptpOutByPeerCallId
-#define	FindProtoIn _bsd_FindProtoIn
-#define	FindProtoOut _bsd_FindProtoOut
-#define	FindRtspOut _bsd_FindRtspOut
-#define	FindSctpRedirectAddress _bsd_FindSctpRedirectAddress
-#define	FindUdpTcpIn _bsd_FindUdpTcpIn
-#define	FindUdpTcpOut _bsd_FindUdpTcpOut
-#define	firewire_broadcastaddr _bsd_firewire_broadcastaddr
-#define	firewire_busreset _bsd_firewire_busreset
-#define	firewire_ifattach _bsd_firewire_ifattach
-#define	firewire_ifdetach _bsd_firewire_ifdetach
-#define	firewire_input _bsd_firewire_input
-#define	firewire_ioctl _bsd_firewire_ioctl
-#define	firmware_get _bsd_firmware_get
-#define	firmware_put _bsd_firmware_put
-#define	firmware_register _bsd_firmware_register
-#define	firmware_unregister _bsd_firmware_unregister
-#define	first_handler _bsd_first_handler
-#define	frag6_drain _bsd_frag6_drain
-#define	frag6_init _bsd_frag6_init
-#define	frag6_input _bsd_frag6_input
-#define	frag6_nfrags _bsd_frag6_nfrags
-#define	frag6_set_bucketsize _bsd_frag6_set_bucketsize
-#define	frag6_slowtimo _bsd_frag6_slowtimo
-#define	free_unr _bsd_free_unr
-#define	genkbd_commonioctl _bsd_genkbd_commonioctl
-#define	genkbd_diag _bsd_genkbd_diag
-#define	genkbd_get_fkeystr _bsd_genkbd_get_fkeystr
-#define	genkbd_keyaction _bsd_genkbd_keyaction
-#define	GetAckModified _bsd_GetAckModified
-#define	GetAliasAddress _bsd_GetAliasAddress
-#define	GetAliasPort _bsd_GetAliasPort
-#define	getcredhostuuid _bsd_getcredhostuuid
-#define	GetDefaultAliasAddress _bsd_GetDefaultAliasAddress
-#define	GetDeltaAckIn _bsd_GetDeltaAckIn
-#define	GetDeltaSeqOut _bsd_GetDeltaSeqOut
-#define	GetDestAddress _bsd_GetDestAddress
-#define	GetFragmentAddr _bsd_GetFragmentAddr
-#define	GetFragmentPtr _bsd_GetFragmentPtr
-#define	get_keybuf _bsd_get_keybuf
-#define	GetOriginalAddress _bsd_GetOriginalAddress
-#define	GetOriginalPort _bsd_GetOriginalPort
-#define	GetProtocolFlags _bsd_GetProtocolFlags
-#define	GetProxyAddress _bsd_GetProxyAddress
-#define	GetProxyPort _bsd_GetProxyPort
-#define	get_random_bytes _bsd_get_random_bytes
-#define	GetStateIn _bsd_GetStateIn
-#define	GetStateOut _bsd_GetStateOut
-#define	gf128_genmultable _bsd_gf128_genmultable
-#define	gf128_genmultable4 _bsd_gf128_genmultable4
-#define	gf128_mul _bsd_gf128_mul
-#define	gf128_mul4 _bsd_gf128_mul4
-#define	gf128_mul4b _bsd_gf128_mul4b
-#define	Giant _bsd_Giant
-#define	gif_hashdestroy _bsd_gif_hashdestroy
-#define	gif_hashinit _bsd_gif_hashinit
-#define	gif_input _bsd_gif_input
-#define	gif_output _bsd_gif_output
-#define	gpio_alloc_intr_resource _bsd_gpio_alloc_intr_resource
-#define	gpiobus_acquire_pin _bsd_gpiobus_acquire_pin
-#define	gpiobus_alloc_ivars _bsd_gpiobus_alloc_ivars
-#define	gpiobus_attach_bus _bsd_gpiobus_attach_bus
-#define	gpiobus_detach_bus _bsd_gpiobus_detach_bus
-#define	gpiobus_devclass _bsd_gpiobus_devclass
-#define	gpiobus_driver _bsd_gpiobus_driver
-#define	gpiobus_free_ivars _bsd_gpiobus_free_ivars
-#define	gpiobus_init_softc _bsd_gpiobus_init_softc
-#define	gpiobus_release_pin _bsd_gpiobus_release_pin
-#define	gpio_check_flags _bsd_gpio_check_flags
-#define	gpio_pin_get_by_bus_pinnum _bsd_gpio_pin_get_by_bus_pinnum
-#define	gpio_pin_get_by_child_index _bsd_gpio_pin_get_by_child_index
-#define	gpio_pin_get_by_ofw_idx _bsd_gpio_pin_get_by_ofw_idx
-#define	gpio_pin_get_by_ofw_name _bsd_gpio_pin_get_by_ofw_name
-#define	gpio_pin_get_by_ofw_property _bsd_gpio_pin_get_by_ofw_property
-#define	gpio_pin_get_by_ofw_propidx _bsd_gpio_pin_get_by_ofw_propidx
-#define	gpio_pin_getcaps _bsd_gpio_pin_getcaps
-#define	gpio_pin_is_active _bsd_gpio_pin_is_active
-#define	gpio_pin_release _bsd_gpio_pin_release
-#define	gpio_pin_set_active _bsd_gpio_pin_set_active
-#define	gpio_pin_setflags _bsd_gpio_pin_setflags
-#define	gre_hashdestroy _bsd_gre_hashdestroy
-#define	gre_hashinit _bsd_gre_hashinit
-#define	gre_input _bsd_gre_input
-#define	gre_sofree _bsd_gre_sofree
-#define	gre_update_hdr _bsd_gre_update_hdr
-#define	gre_update_udphdr _bsd_gre_update_udphdr
-#define	grouptask_block _bsd_grouptask_block
-#define	grouptaskqueue_enqueue _bsd_grouptaskqueue_enqueue
-#define	grouptask_unblock _bsd_grouptask_unblock
-#define	gtaskqueue_block _bsd_gtaskqueue_block
-#define	gtaskqueue_cancel _bsd_gtaskqueue_cancel
-#define	gtaskqueue_drain _bsd_gtaskqueue_drain
-#define	gtaskqueue_drain_all _bsd_gtaskqueue_drain_all
-#define	gtaskqueue_unblock _bsd_gtaskqueue_unblock
-#define	handlers _bsd_handlers
-#define	hashdestroy _bsd_hashdestroy
-#define	hashinit _bsd_hashinit
-#define	hashinit_flags _bsd_hashinit_flags
-#define	hex2ascii_data _bsd_hex2ascii_data
-#define	hhook_add_hook _bsd_hhook_add_hook
-#define	hhook_add_hook_lookup _bsd_hhook_add_hook_lookup
-#define	hhook_head_deregister _bsd_hhook_head_deregister
-#define	hhook_head_deregister_lookup _bsd_hhook_head_deregister_lookup
-#define	hhook_head_get _bsd_hhook_head_get
-#define	hhook_head_is_virtualised _bsd_hhook_head_is_virtualised
-#define	hhook_head_is_virtualised_lookup _bsd_hhook_head_is_virtualised_lookup
-#define	hhook_head_list _bsd_hhook_head_list
-#define	hhook_head_register _bsd_hhook_head_register
-#define	hhook_head_release _bsd_hhook_head_release
-#define	hhook_remove_hook _bsd_hhook_remove_hook
-#define	hhook_remove_hook_lookup _bsd_hhook_remove_hook_lookup
-#define	hhook_run_hooks _bsd_hhook_run_hooks
-#define	hhook_vhead_list _bsd_hhook_vhead_list
-#define	hid_end_parse _bsd_hid_end_parse
-#define	hid_get_data _bsd_hid_get_data
-#define	hid_get_data_unsigned _bsd_hid_get_data_unsigned
-#define	hid_get_descriptor_from_usb _bsd_hid_get_descriptor_from_usb
-#define	hid_get_item _bsd_hid_get_item
-#define	hid_is_collection _bsd_hid_is_collection
-#define	hid_is_keyboard _bsd_hid_is_keyboard
-#define	hid_is_mouse _bsd_hid_is_mouse
-#define	hid_item_resolution _bsd_hid_item_resolution
-#define	hid_locate _bsd_hid_locate
-#define	hid_put_data_unsigned _bsd_hid_put_data_unsigned
-#define	hid_report_size _bsd_hid_report_size
-#define	hid_start_parse _bsd_hid_start_parse
-#define	hmac_ipad_buffer _bsd_hmac_ipad_buffer
-#define	hmac_opad_buffer _bsd_hmac_opad_buffer
-#define	HouseKeeping _bsd_HouseKeeping
-#define	hz _bsd_hz
-#define	icmp6_ctloutput _bsd_icmp6_ctloutput
-#define	icmp6_error _bsd_icmp6_error
-#define	icmp6_error2 _bsd_icmp6_error2
-#define	icmp6errppslim _bsd_icmp6errppslim
-#define	icmp6_fasttimo _bsd_icmp6_fasttimo
-#define	icmp6_input _bsd_icmp6_input
-#define	icmp6_mtudisc_update _bsd_icmp6_mtudisc_update
-#define	icmp6_nodeinfo _bsd_icmp6_nodeinfo
-#define	icmp6_nodeinfo_oldmcprefix _bsd_icmp6_nodeinfo_oldmcprefix
-#define	icmp6_rediraccept _bsd_icmp6_rediraccept
-#define	icmp6_redirect_input _bsd_icmp6_redirect_input
-#define	icmp6_redirect_output _bsd_icmp6_redirect_output
-#define	icmp6_redirtimeout _bsd_icmp6_redirtimeout
-#define	icmp6_reflect _bsd_icmp6_reflect
-#define	icmp6_slowtimo _bsd_icmp6_slowtimo
-#define	icmp6stat _bsd_icmp6stat
-#define	icmp_error _bsd_icmp_error
-#define	icmp_input _bsd_icmp_input
-#define	icmpstat _bsd_icmpstat
-#define	ic_printf _bsd_ic_printf
-#define	ieee80211_aclator_get _bsd_ieee80211_aclator_get
-#define	ieee80211_aclator_register _bsd_ieee80211_aclator_register
-#define	ieee80211_aclator_unregister _bsd_ieee80211_aclator_unregister
-#define	ieee80211_addbasicrates _bsd_ieee80211_addbasicrates
-#define	ieee80211_add_callback _bsd_ieee80211_add_callback
-#define	ieee80211_add_channel _bsd_ieee80211_add_channel
-#define	ieee80211_add_channel_ht40 _bsd_ieee80211_add_channel_ht40
-#define	ieee80211_add_channel_list_2ghz _bsd_ieee80211_add_channel_list_2ghz
-#define	ieee80211_add_channel_list_5ghz _bsd_ieee80211_add_channel_list_5ghz
-#define	ieee80211_add_channels_default_2ghz _bsd_ieee80211_add_channels_default_2ghz
-#define	ieee80211_add_htcap _bsd_ieee80211_add_htcap
-#define	ieee80211_add_htcap_ch _bsd_ieee80211_add_htcap_ch
-#define	ieee80211_add_htcap_vendor _bsd_ieee80211_add_htcap_vendor
-#define	ieee80211_add_htinfo _bsd_ieee80211_add_htinfo
-#define	ieee80211_add_htinfo_vendor _bsd_ieee80211_add_htinfo_vendor
-#define	ieee80211_add_meshconf _bsd_ieee80211_add_meshconf
-#define	ieee80211_add_meshgate _bsd_ieee80211_add_meshgate
-#define	ieee80211_add_meshid _bsd_ieee80211_add_meshid
-#define	ieee80211_add_meshlmetric _bsd_ieee80211_add_meshlmetric
-#define	ieee80211_add_meshpeer _bsd_ieee80211_add_meshpeer
-#define	ieee80211_add_neighbor _bsd_ieee80211_add_neighbor
-#define	ieee80211_add_qos _bsd_ieee80211_add_qos
-#define	ieee80211_add_rates _bsd_ieee80211_add_rates
-#define	ieee80211_add_rsn _bsd_ieee80211_add_rsn
-#define	ieee80211_add_rx_params _bsd_ieee80211_add_rx_params
-#define	ieee80211_add_scan _bsd_ieee80211_add_scan
-#define	ieee80211_add_ssid _bsd_ieee80211_add_ssid
-#define	ieee80211_add_toa_params _bsd_ieee80211_add_toa_params
-#define	ieee80211_add_vhtcap _bsd_ieee80211_add_vhtcap
-#define	ieee80211_add_vhtinfo _bsd_ieee80211_add_vhtinfo
-#define	ieee80211_add_wme_info _bsd_ieee80211_add_wme_info
-#define	ieee80211_add_wpa _bsd_ieee80211_add_wpa
-#define	ieee80211_add_xmit_params _bsd_ieee80211_add_xmit_params
-#define	ieee80211_add_xrates _bsd_ieee80211_add_xrates
-#define	ieee80211_adhoc_attach _bsd_ieee80211_adhoc_attach
-#define	ieee80211_adhoc_detach _bsd_ieee80211_adhoc_detach
-#define	ieee80211_ageq_age _bsd_ieee80211_ageq_age
-#define	ieee80211_ageq_append _bsd_ieee80211_ageq_append
-#define	ieee80211_ageq_cleanup _bsd_ieee80211_ageq_cleanup
-#define	ieee80211_ageq_drain _bsd_ieee80211_ageq_drain
-#define	ieee80211_ageq_drain_node _bsd_ieee80211_ageq_drain_node
-#define	ieee80211_ageq_init _bsd_ieee80211_ageq_init
-#define	ieee80211_ageq_mfree _bsd_ieee80211_ageq_mfree
-#define	ieee80211_ageq_remove _bsd_ieee80211_ageq_remove
-#define	ieee80211_allmulti _bsd_ieee80211_allmulti
-#define	ieee80211_alloc_challenge _bsd_ieee80211_alloc_challenge
-#define	ieee80211_alloc_countryie _bsd_ieee80211_alloc_countryie
-#define	ieee80211_alloc_cts _bsd_ieee80211_alloc_cts
-#define	ieee80211_alloc_node _bsd_ieee80211_alloc_node
-#define	ieee80211_alloc_proberesp _bsd_ieee80211_alloc_proberesp
-#define	ieee80211_alloc_prot _bsd_ieee80211_alloc_prot
-#define	ieee80211_alloc_rts _bsd_ieee80211_alloc_rts
-#define	ieee80211_ampdu_reorder _bsd_ieee80211_ampdu_reorder
-#define	ieee80211_ampdu_request _bsd_ieee80211_ampdu_request
-#define	ieee80211_ampdu_rx_start_ext _bsd_ieee80211_ampdu_rx_start_ext
-#define	ieee80211_ampdu_rx_stop_ext _bsd_ieee80211_ampdu_rx_stop_ext
-#define	ieee80211_ampdu_stop _bsd_ieee80211_ampdu_stop
-#define	ieee80211_ampdu_tx_request_active_ext _bsd_ieee80211_ampdu_tx_request_active_ext
-#define	ieee80211_ampdu_tx_request_ext _bsd_ieee80211_ampdu_tx_request_ext
-#define	ieee80211_announce _bsd_ieee80211_announce
-#define	ieee80211_announce_channels _bsd_ieee80211_announce_channels
-#define	ieee80211_authenticator_get _bsd_ieee80211_authenticator_get
-#define	ieee80211_authenticator_register _bsd_ieee80211_authenticator_register
-#define	ieee80211_authenticator_unregister _bsd_ieee80211_authenticator_unregister
-#define	ieee80211_beacon_alloc _bsd_ieee80211_beacon_alloc
-#define	ieee80211_beacon_miss _bsd_ieee80211_beacon_miss
-#define	ieee80211_beacon_update _bsd_ieee80211_beacon_update
-#define	ieee80211_bg_scan _bsd_ieee80211_bg_scan
-#define	ieee80211broadcastaddr _bsd_ieee80211broadcastaddr
-#define	ieee80211_cac_completeswitch _bsd_ieee80211_cac_completeswitch
-#define	ieee80211_cancel_anyscan _bsd_ieee80211_cancel_anyscan
-#define	ieee80211_cancel_scan _bsd_ieee80211_cancel_scan
-#define	ieee80211_chan2ieee _bsd_ieee80211_chan2ieee
-#define	ieee80211_chan2mode _bsd_ieee80211_chan2mode
-#define	ieee80211_chan_init _bsd_ieee80211_chan_init
-#define	ieee80211_channel_type_char _bsd_ieee80211_channel_type_char
-#define	ieee80211_check_scan _bsd_ieee80211_check_scan
-#define	ieee80211_check_scan_current _bsd_ieee80211_check_scan_current
-#define	ieee80211_cipher_none _bsd_ieee80211_cipher_none
-#define	ieee80211_classify _bsd_ieee80211_classify
-#define	ieee80211_compute_duration _bsd_ieee80211_compute_duration
-#define	ieee80211_compute_duration_ht _bsd_ieee80211_compute_duration_ht
-#define	ieee80211_com_vdecref _bsd_ieee80211_com_vdecref
-#define	ieee80211_com_vdetach _bsd_ieee80211_com_vdetach
-#define	ieee80211_com_vincref _bsd_ieee80211_com_vincref
-#define	ieee80211_create_ibss _bsd_ieee80211_create_ibss
-#define	ieee80211_crypto_attach _bsd_ieee80211_crypto_attach
-#define	ieee80211_crypto_available _bsd_ieee80211_crypto_available
-#define	ieee80211_crypto_decap _bsd_ieee80211_crypto_decap
-#define	ieee80211_crypto_delglobalkeys _bsd_ieee80211_crypto_delglobalkeys
-#define	ieee80211_crypto_delkey _bsd_ieee80211_crypto_delkey
-#define	ieee80211_crypto_demic _bsd_ieee80211_crypto_demic
-#define	ieee80211_crypto_detach _bsd_ieee80211_crypto_detach
-#define	ieee80211_crypto_encap _bsd_ieee80211_crypto_encap
-#define	ieee80211_crypto_get_keyid _bsd_ieee80211_crypto_get_keyid
-#define	ieee80211_crypto_get_key_wepidx _bsd_ieee80211_crypto_get_key_wepidx
-#define	ieee80211_crypto_get_txkey _bsd_ieee80211_crypto_get_txkey
-#define	ieee80211_crypto_newkey _bsd_ieee80211_crypto_newkey
-#define	ieee80211_crypto_register _bsd_ieee80211_crypto_register
-#define	ieee80211_crypto_reload_keys _bsd_ieee80211_crypto_reload_keys
-#define	ieee80211_crypto_set_deftxkey _bsd_ieee80211_crypto_set_deftxkey
-#define	ieee80211_crypto_setkey _bsd_ieee80211_crypto_setkey
-#define	ieee80211_crypto_unregister _bsd_ieee80211_crypto_unregister
-#define	ieee80211_crypto_vattach _bsd_ieee80211_crypto_vattach
-#define	ieee80211_crypto_vdetach _bsd_ieee80211_crypto_vdetach
-#define	ieee80211_csa_cancelswitch _bsd_ieee80211_csa_cancelswitch
-#define	ieee80211_csa_completeswitch _bsd_ieee80211_csa_completeswitch
-#define	ieee80211_csa_startswitch _bsd_ieee80211_csa_startswitch
-#define	ieee80211_decap _bsd_ieee80211_decap
-#define	ieee80211_decap1 _bsd_ieee80211_decap1
-#define	ieee80211_decap_amsdu _bsd_ieee80211_decap_amsdu
-#define	ieee80211_defrag _bsd_ieee80211_defrag
-#define	ieee80211_deliver_data _bsd_ieee80211_deliver_data
-#define	ieee80211_dfs_attach _bsd_ieee80211_dfs_attach
-#define	ieee80211_dfs_cac_clear _bsd_ieee80211_dfs_cac_clear
-#define	ieee80211_dfs_cac_start _bsd_ieee80211_dfs_cac_start
-#define	ieee80211_dfs_cac_stop _bsd_ieee80211_dfs_cac_stop
-#define	ieee80211_dfs_detach _bsd_ieee80211_dfs_detach
-#define	ieee80211_dfs_notify_radar _bsd_ieee80211_dfs_notify_radar
-#define	ieee80211_dfs_pickchannel _bsd_ieee80211_dfs_pickchannel
-#define	ieee80211_dfs_reset _bsd_ieee80211_dfs_reset
-#define	ieee80211_drain _bsd_ieee80211_drain
-#define	ieee80211_drain_ifq _bsd_ieee80211_drain_ifq
-#define	ieee80211_dump_node _bsd_ieee80211_dump_node
-#define	ieee80211_dump_nodes _bsd_ieee80211_dump_nodes
-#define	ieee80211_dump_pkt _bsd_ieee80211_dump_pkt
-#define	ieee80211_dup_bss _bsd_ieee80211_dup_bss
-#define	ieee80211_dwds_discover _bsd_ieee80211_dwds_discover
-#define	ieee80211_dwds_mcast _bsd_ieee80211_dwds_mcast
-#define	ieee80211_encap _bsd_ieee80211_encap
-#define	ieee80211_fakeup_adhoc_node _bsd_ieee80211_fakeup_adhoc_node
-#define	ieee80211_ff_encap1 _bsd_ieee80211_ff_encap1
-#define	ieee80211_find_channel _bsd_ieee80211_find_channel
-#define	ieee80211_find_channel_byieee _bsd_ieee80211_find_channel_byieee
-#define	ieee80211_find_com _bsd_ieee80211_find_com
-#define	ieee80211_find_node _bsd_ieee80211_find_node
-#define	ieee80211_find_node_locked _bsd_ieee80211_find_node_locked
-#define	ieee80211_find_rxnode _bsd_ieee80211_find_rxnode
-#define	ieee80211_find_rxnode_withkey _bsd_ieee80211_find_rxnode_withkey
-#define	ieee80211_find_txnode _bsd_ieee80211_find_txnode
-#define	ieee80211_find_vap_node _bsd_ieee80211_find_vap_node
-#define	ieee80211_find_vap_node_locked _bsd_ieee80211_find_vap_node_locked
-#define	ieee80211_fix_rate _bsd_ieee80211_fix_rate
-#define	ieee80211_flush_ifq _bsd_ieee80211_flush_ifq
-#define	ieee80211_free_mbuf _bsd_ieee80211_free_mbuf
-#define	ieee80211_free_node _bsd_ieee80211_free_node
-#define	ieee80211_getcapinfo _bsd_ieee80211_getcapinfo
-#define	ieee80211_get_channel_center_freq _bsd_ieee80211_get_channel_center_freq
-#define	ieee80211_get_channel_center_freq1 _bsd_ieee80211_get_channel_center_freq1
-#define	ieee80211_get_channel_center_freq2 _bsd_ieee80211_get_channel_center_freq2
-#define	ieee80211_getmgtframe _bsd_ieee80211_getmgtframe
-#define	ieee80211_get_ratetable _bsd_ieee80211_get_ratetable
-#define	ieee80211_getrssi _bsd_ieee80211_getrssi
-#define	ieee80211_get_rx_params _bsd_ieee80211_get_rx_params
-#define	ieee80211_get_rx_params_ptr _bsd_ieee80211_get_rx_params_ptr
-#define	ieee80211_getsignal _bsd_ieee80211_getsignal
-#define	ieee80211_get_suphtrates _bsd_ieee80211_get_suphtrates
-#define	ieee80211_get_suprates _bsd_ieee80211_get_suprates
-#define	ieee80211_get_toa_params _bsd_ieee80211_get_toa_params
-#define	ieee80211_get_xmit_params _bsd_ieee80211_get_xmit_params
-#define	ieee80211_hostap_attach _bsd_ieee80211_hostap_attach
-#define	ieee80211_hostap_detach _bsd_ieee80211_hostap_detach
-#define	ieee80211_ht_adjust_channel _bsd_ieee80211_ht_adjust_channel
-#define	ieee80211_ht_announce _bsd_ieee80211_ht_announce
-#define	ieee80211_ht_attach _bsd_ieee80211_ht_attach
-#define	ieee80211_ht_detach _bsd_ieee80211_ht_detach
-#define	ieee80211_ht_node_age _bsd_ieee80211_ht_node_age
-#define	ieee80211_ht_node_cleanup _bsd_ieee80211_ht_node_cleanup
-#define	ieee80211_ht_node_init _bsd_ieee80211_ht_node_init
-#define	ieee80211_ht_node_join _bsd_ieee80211_ht_node_join
-#define	ieee80211_ht_node_leave _bsd_ieee80211_ht_node_leave
-#define	ieee80211_htprot_update _bsd_ieee80211_htprot_update
-#define	ieee80211_htrates _bsd_ieee80211_htrates
-#define	ieee80211_ht_timeout _bsd_ieee80211_ht_timeout
-#define	ieee80211_ht_update_beacon _bsd_ieee80211_ht_update_beacon
-#define	ieee80211_ht_updatehtcap _bsd_ieee80211_ht_updatehtcap
-#define	ieee80211_ht_updatehtcap_final _bsd_ieee80211_ht_updatehtcap_final
-#define	ieee80211_ht_updateparams _bsd_ieee80211_ht_updateparams
-#define	ieee80211_ht_updateparams_final _bsd_ieee80211_ht_updateparams_final
-#define	ieee80211_ht_vattach _bsd_ieee80211_ht_vattach
-#define	ieee80211_ht_vdetach _bsd_ieee80211_ht_vdetach
-#define	ieee80211_ht_wds_init _bsd_ieee80211_ht_wds_init
-#define	ieee80211_ibss_merge _bsd_ieee80211_ibss_merge
-#define	ieee80211_ibss_merge_check _bsd_ieee80211_ibss_merge_check
-#define	ieee80211_ibss_node_check_new _bsd_ieee80211_ibss_node_check_new
-#define	ieee80211_ieee2mhz _bsd_ieee80211_ieee2mhz
-#define	ieee80211_ies_cleanup _bsd_ieee80211_ies_cleanup
-#define	ieee80211_ies_expand _bsd_ieee80211_ies_expand
-#define	ieee80211_ies_init _bsd_ieee80211_ies_init
-#define	ieee80211_ifattach _bsd_ieee80211_ifattach
-#define	ieee80211_ifdetach _bsd_ieee80211_ifdetach
-#define	ieee80211_init _bsd_ieee80211_init
-#define	ieee80211_init_channels _bsd_ieee80211_init_channels
-#define	ieee80211_init_neighbor _bsd_ieee80211_init_neighbor
-#define	ieee80211_init_suphtrates _bsd_ieee80211_init_suphtrates
-#define	ieee80211_input_all _bsd_ieee80211_input_all
-#define	ieee80211_input_mimo _bsd_ieee80211_input_mimo
-#define	ieee80211_input_mimo_all _bsd_ieee80211_input_mimo_all
-#define	ieee80211_ioctl _bsd_ieee80211_ioctl
-#define	ieee80211_iserp_rateset _bsd_ieee80211_iserp_rateset
-#define	ieee80211_iterate_coms _bsd_ieee80211_iterate_coms
-#define	ieee80211_iterate_nodes _bsd_ieee80211_iterate_nodes
-#define	ieee80211_iterate_nodes_vap _bsd_ieee80211_iterate_nodes_vap
-#define	ieee80211_load_module _bsd_ieee80211_load_module
-#define	ieee80211_lookup_channel_rxstatus _bsd_ieee80211_lookup_channel_rxstatus
-#define	ieee80211_mac_hash _bsd_ieee80211_mac_hash
-#define	ieee80211_mbuf_adjust _bsd_ieee80211_mbuf_adjust
-#define	ieee80211_media2rate _bsd_ieee80211_media2rate
-#define	ieee80211_media_change _bsd_ieee80211_media_change
-#define	ieee80211_media_status _bsd_ieee80211_media_status
-#define	ieee80211_mesh_attach _bsd_ieee80211_mesh_attach
-#define	ieee80211_mesh_detach _bsd_ieee80211_mesh_detach
-#define	ieee80211_mesh_find_txnode _bsd_ieee80211_mesh_find_txnode
-#define	ieee80211_mesh_forward_to_gates _bsd_ieee80211_mesh_forward_to_gates
-#define	ieee80211_mesh_init_neighbor _bsd_ieee80211_mesh_init_neighbor
-#define	ieee80211_mesh_mark_gate _bsd_ieee80211_mesh_mark_gate
-#define	ieee80211_mesh_node_cleanup _bsd_ieee80211_mesh_node_cleanup
-#define	ieee80211_mesh_node_init _bsd_ieee80211_mesh_node_init
-#define	ieee80211_mesh_proxy_check _bsd_ieee80211_mesh_proxy_check
-#define	ieee80211_mesh_register_proto_metric _bsd_ieee80211_mesh_register_proto_metric
-#define	ieee80211_mesh_register_proto_path _bsd_ieee80211_mesh_register_proto_path
-#define	ieee80211_mesh_rt_add _bsd_ieee80211_mesh_rt_add
-#define	ieee80211_mesh_rt_del _bsd_ieee80211_mesh_rt_del
-#define	ieee80211_mesh_rt_find _bsd_ieee80211_mesh_rt_find
-#define	ieee80211_mesh_rt_flush _bsd_ieee80211_mesh_rt_flush
-#define	ieee80211_mesh_rt_flush_peer _bsd_ieee80211_mesh_rt_flush_peer
-#define	ieee80211_mesh_rt_update _bsd_ieee80211_mesh_rt_update
-#define	ieee80211_mesh_update_beacon _bsd_ieee80211_mesh_update_beacon
-#define	ieee80211_mgmt_output _bsd_ieee80211_mgmt_output
-#define	ieee80211_mhz2ieee _bsd_ieee80211_mhz2ieee
-#define	ieee80211_monitor_attach _bsd_ieee80211_monitor_attach
-#define	ieee80211_monitor_detach _bsd_ieee80211_monitor_detach
-#define	ieee80211_new_state _bsd_ieee80211_new_state
-#define	ieee80211_new_state_locked _bsd_ieee80211_new_state_locked
-#define	ieee80211_node_attach _bsd_ieee80211_node_attach
-#define	ieee80211_node_authorize _bsd_ieee80211_node_authorize
-#define	ieee80211_node_create_wds _bsd_ieee80211_node_create_wds
-#define	ieee80211_node_deauth _bsd_ieee80211_node_deauth
-#define	ieee80211_node_dectestref _bsd_ieee80211_node_dectestref
-#define	ieee80211_node_delucastkey _bsd_ieee80211_node_delucastkey
-#define	ieee80211_node_detach _bsd_ieee80211_node_detach
-#define	ieee80211_node_join _bsd_ieee80211_node_join
-#define	ieee80211_node_latevattach _bsd_ieee80211_node_latevattach
-#define	ieee80211_node_leave _bsd_ieee80211_node_leave
-#define	ieee80211_node_psq_age _bsd_ieee80211_node_psq_age
-#define	ieee80211_node_psq_dequeue _bsd_ieee80211_node_psq_dequeue
-#define	ieee80211_node_psq_drain _bsd_ieee80211_node_psq_drain
-#define	ieee80211_node_pwrsave _bsd_ieee80211_node_pwrsave
-#define	ieee80211_node_set_chan _bsd_ieee80211_node_set_chan
-#define	ieee80211_node_setuptxparms _bsd_ieee80211_node_setuptxparms
-#define	ieee80211_node_timeout _bsd_ieee80211_node_timeout
-#define	ieee80211_node_unauthorize _bsd_ieee80211_node_unauthorize
-#define	ieee80211_node_vattach _bsd_ieee80211_node_vattach
-#define	ieee80211_node_vdetach _bsd_ieee80211_node_vdetach
-#define	ieee80211_notify_cac _bsd_ieee80211_notify_cac
-#define	ieee80211_notify_country _bsd_ieee80211_notify_country
-#define	ieee80211_notify_csa _bsd_ieee80211_notify_csa
-#define	ieee80211_notify_erp _bsd_ieee80211_notify_erp
-#define	ieee80211_notify_michael_failure _bsd_ieee80211_notify_michael_failure
-#define	ieee80211_notify_node_auth _bsd_ieee80211_notify_node_auth
-#define	ieee80211_notify_node_deauth _bsd_ieee80211_notify_node_deauth
-#define	ieee80211_notify_node_join _bsd_ieee80211_notify_node_join
-#define	ieee80211_notify_node_leave _bsd_ieee80211_notify_node_leave
-#define	ieee80211_notify_radar _bsd_ieee80211_notify_radar
-#define	ieee80211_notify_radio _bsd_ieee80211_notify_radio
-#define	ieee80211_notify_replay_failure _bsd_ieee80211_notify_replay_failure
-#define	ieee80211_notify_scan_done _bsd_ieee80211_notify_scan_done
-#define	ieee80211_notify_wds_discover _bsd_ieee80211_notify_wds_discover
-#define	ieee80211_opcap _bsd_ieee80211_opcap
-#define	ieee80211_opmode_name _bsd_ieee80211_opmode_name
-#define	ieee80211_output _bsd_ieee80211_output
-#define	ieee80211_parent_xmitpkt _bsd_ieee80211_parent_xmitpkt
-#define	ieee80211_parse_action _bsd_ieee80211_parse_action
-#define	ieee80211_parse_beacon _bsd_ieee80211_parse_beacon
-#define	ieee80211_parse_htcap _bsd_ieee80211_parse_htcap
-#define	ieee80211_parse_htinfo _bsd_ieee80211_parse_htinfo
-#define	ieee80211_parse_meshid _bsd_ieee80211_parse_meshid
-#define	ieee80211_parse_vhtcap _bsd_ieee80211_parse_vhtcap
-#define	ieee80211_parse_vhtopmode _bsd_ieee80211_parse_vhtopmode
-#define	ieee80211_parse_wmeparams _bsd_ieee80211_parse_wmeparams
-#define	ieee80211_phymode_name _bsd_ieee80211_phymode_name
-#define	ieee80211_plcp2rate _bsd_ieee80211_plcp2rate
-#define	ieee80211_power_attach _bsd_ieee80211_power_attach
-#define	ieee80211_power_detach _bsd_ieee80211_power_detach
-#define	ieee80211_power_latevattach _bsd_ieee80211_power_latevattach
-#define	ieee80211_power_vattach _bsd_ieee80211_power_vattach
-#define	ieee80211_power_vdetach _bsd_ieee80211_power_vdetach
-#define	ieee80211_print_essid _bsd_ieee80211_print_essid
-#define	ieee80211_probe_curchan _bsd_ieee80211_probe_curchan
-#define	ieee80211_process_callback _bsd_ieee80211_process_callback
-#define	ieee80211_promisc _bsd_ieee80211_promisc
-#define	ieee80211_proto_attach _bsd_ieee80211_proto_attach
-#define	ieee80211_proto_detach _bsd_ieee80211_proto_detach
-#define	ieee80211_proto_vattach _bsd_ieee80211_proto_vattach
-#define	ieee80211_proto_vdetach _bsd_ieee80211_proto_vdetach
-#define	ieee80211_psq_cleanup _bsd_ieee80211_psq_cleanup
-#define	ieee80211_psq_init _bsd_ieee80211_psq_init
-#define	ieee80211_pwrsave _bsd_ieee80211_pwrsave
-#define	ieee80211_radiotap_attach _bsd_ieee80211_radiotap_attach
-#define	ieee80211_radiotap_attachv _bsd_ieee80211_radiotap_attachv
-#define	ieee80211_radiotap_chan_change _bsd_ieee80211_radiotap_chan_change
-#define	ieee80211_radiotap_detach _bsd_ieee80211_radiotap_detach
-#define	ieee80211_radiotap_rx _bsd_ieee80211_radiotap_rx
-#define	ieee80211_radiotap_rx_all _bsd_ieee80211_radiotap_rx_all
-#define	ieee80211_radiotap_tx _bsd_ieee80211_radiotap_tx
-#define	ieee80211_radiotap_vattach _bsd_ieee80211_radiotap_vattach
-#define	ieee80211_radiotap_vdetach _bsd_ieee80211_radiotap_vdetach
-#define	ieee80211_rate2media _bsd_ieee80211_rate2media
-#define	ieee80211_rate2plcp _bsd_ieee80211_rate2plcp
-#define	ieee80211_ratectl_init _bsd_ieee80211_ratectl_init
-#define	ieee80211_ratectl_register _bsd_ieee80211_ratectl_register
-#define	ieee80211_ratectl_set _bsd_ieee80211_ratectl_set
-#define	ieee80211_ratectl_unregister _bsd_ieee80211_ratectl_unregister
-#define	ieee80211_raw_output _bsd_ieee80211_raw_output
-#define	ieee80211_realign _bsd_ieee80211_realign
-#define	ieee80211_reason_to_string _bsd_ieee80211_reason_to_string
-#define	ieee80211_recv_action _bsd_ieee80211_recv_action
-#define	ieee80211_recv_action_register _bsd_ieee80211_recv_action_register
-#define	ieee80211_recv_action_unregister _bsd_ieee80211_recv_action_unregister
-#define	ieee80211_recv_bar _bsd_ieee80211_recv_bar
-#define	ieee80211_recv_pspoll _bsd_ieee80211_recv_pspoll
-#define	ieee80211_regdomain_attach _bsd_ieee80211_regdomain_attach
-#define	ieee80211_regdomain_detach _bsd_ieee80211_regdomain_detach
-#define	ieee80211_regdomain_vattach _bsd_ieee80211_regdomain_vattach
-#define	ieee80211_regdomain_vdetach _bsd_ieee80211_regdomain_vdetach
-#define	ieee80211_reset_bss _bsd_ieee80211_reset_bss
-#define	ieee80211_reset_erp _bsd_ieee80211_reset_erp
-#define	ieee80211_restart_all _bsd_ieee80211_restart_all
-#define	ieee80211_resume_all _bsd_ieee80211_resume_all
-#define	ieee80211_scan_assoc_fail _bsd_ieee80211_scan_assoc_fail
-#define	ieee80211_scan_assoc_success _bsd_ieee80211_scan_assoc_success
-#define	ieee80211_scan_attach _bsd_ieee80211_scan_attach
-#define	ieee80211_scan_copy_ssid _bsd_ieee80211_scan_copy_ssid
-#define	ieee80211_scan_detach _bsd_ieee80211_scan_detach
-#define	ieee80211_scan_done _bsd_ieee80211_scan_done
-#define	ieee80211_scan_dump_channels _bsd_ieee80211_scan_dump_channels
-#define	ieee80211_scan_flush _bsd_ieee80211_scan_flush
-#define	ieee80211_scan_iterate _bsd_ieee80211_scan_iterate
-#define	ieee80211_scanner_get _bsd_ieee80211_scanner_get
-#define	ieee80211_scanner_register _bsd_ieee80211_scanner_register
-#define	ieee80211_scanner_unregister _bsd_ieee80211_scanner_unregister
-#define	ieee80211_scanner_unregister_all _bsd_ieee80211_scanner_unregister_all
-#define	ieee80211_scan_next _bsd_ieee80211_scan_next
-#define	ieee80211_scan_pickchannel _bsd_ieee80211_scan_pickchannel
-#define	ieee80211_scan_timeout _bsd_ieee80211_scan_timeout
-#define	ieee80211_scan_update_locked _bsd_ieee80211_scan_update_locked
-#define	ieee80211_scan_vattach _bsd_ieee80211_scan_vattach
-#define	ieee80211_scan_vdetach _bsd_ieee80211_scan_vdetach
-#define	ieee80211_send_action _bsd_ieee80211_send_action
-#define	ieee80211_send_action_register _bsd_ieee80211_send_action_register
-#define	ieee80211_send_action_unregister _bsd_ieee80211_send_action_unregister
-#define	ieee80211_send_bar _bsd_ieee80211_send_bar
-#define	ieee80211_send_error _bsd_ieee80211_send_error
-#define	ieee80211_send_mgmt _bsd_ieee80211_send_mgmt
-#define	ieee80211_send_nulldata _bsd_ieee80211_send_nulldata
-#define	ieee80211_send_probereq _bsd_ieee80211_send_probereq
-#define	ieee80211_send_proberesp _bsd_ieee80211_send_proberesp
-#define	ieee80211_send_setup _bsd_ieee80211_send_setup
-#define	ieee80211_setbasicrates _bsd_ieee80211_setbasicrates
-#define	ieee80211_setcurchan _bsd_ieee80211_setcurchan
-#define	ieee80211_setmode _bsd_ieee80211_setmode
-#define	ieee80211_setregdomain _bsd_ieee80211_setregdomain
-#define	ieee80211_set_shortslottime _bsd_ieee80211_set_shortslottime
-#define	ieee80211_setup_basic_htrates _bsd_ieee80211_setup_basic_htrates
-#define	ieee80211_setupcurchan _bsd_ieee80211_setupcurchan
-#define	ieee80211_setup_htrates _bsd_ieee80211_setup_htrates
-#define	ieee80211_setup_rates _bsd_ieee80211_setup_rates
-#define	ieee80211_setup_vht_rates _bsd_ieee80211_setup_vht_rates
-#define	ieee80211_sort_channels _bsd_ieee80211_sort_channels
-#define	ieee80211_sta_attach _bsd_ieee80211_sta_attach
-#define	ieee80211_sta_detach _bsd_ieee80211_sta_detach
-#define	ieee80211_sta_join _bsd_ieee80211_sta_join
-#define	ieee80211_sta_leave _bsd_ieee80211_sta_leave
-#define	ieee80211_sta_ps_timer_check _bsd_ieee80211_sta_ps_timer_check
-#define	ieee80211_sta_pwrsave _bsd_ieee80211_sta_pwrsave
-#define	ieee80211_start_all _bsd_ieee80211_start_all
-#define	ieee80211_start_locked _bsd_ieee80211_start_locked
-#define	ieee80211_start_scan _bsd_ieee80211_start_scan
-#define	ieee80211_state_name _bsd_ieee80211_state_name
-#define	ieee80211_sta_tim_notify _bsd_ieee80211_sta_tim_notify
-#define	ieee80211_stop _bsd_ieee80211_stop
-#define	ieee80211_stop_all _bsd_ieee80211_stop_all
-#define	ieee80211_stop_locked _bsd_ieee80211_stop_locked
-#define	ieee80211_suspend_all _bsd_ieee80211_suspend_all
-#define	ieee80211_swbmiss _bsd_ieee80211_swbmiss
-#define	ieee80211_swscan_attach _bsd_ieee80211_swscan_attach
-#define	ieee80211_sync_curchan _bsd_ieee80211_sync_curchan
-#define	ieee80211_syncflag _bsd_ieee80211_syncflag
-#define	ieee80211_syncflag_ext _bsd_ieee80211_syncflag_ext
-#define	ieee80211_syncflag_ht _bsd_ieee80211_syncflag_ht
-#define	ieee80211_syncflag_vht _bsd_ieee80211_syncflag_vht
-#define	ieee80211_sysctl_attach _bsd_ieee80211_sysctl_attach
-#define	ieee80211_sysctl_detach _bsd_ieee80211_sysctl_detach
-#define	ieee80211_sysctl_msecs_ticks _bsd_ieee80211_sysctl_msecs_ticks
-#define	ieee80211_sysctl_vattach _bsd_ieee80211_sysctl_vattach
-#define	ieee80211_sysctl_vdetach _bsd_ieee80211_sysctl_vdetach
-#define	ieee80211_tmp_node _bsd_ieee80211_tmp_node
-#define	ieee80211_tx_complete _bsd_ieee80211_tx_complete
-#define	ieee80211_update_chw _bsd_ieee80211_update_chw
-#define	ieee80211_vap_attach _bsd_ieee80211_vap_attach
-#define	ieee80211_vap_destroy _bsd_ieee80211_vap_destroy
-#define	ieee80211_vap_detach _bsd_ieee80211_vap_detach
-#define	ieee80211_vap_pkt_send_dest _bsd_ieee80211_vap_pkt_send_dest
-#define	ieee80211_vap_qflush _bsd_ieee80211_vap_qflush
-#define	ieee80211_vap_setup _bsd_ieee80211_vap_setup
-#define	ieee80211_vap_transmit _bsd_ieee80211_vap_transmit
-#define	ieee80211_vap_xmitpkt _bsd_ieee80211_vap_xmitpkt
-#define	ieee80211_vht_adjust_channel _bsd_ieee80211_vht_adjust_channel
-#define	ieee80211_vht_announce _bsd_ieee80211_vht_announce
-#define	ieee80211_vht_attach _bsd_ieee80211_vht_attach
-#define	ieee80211_vht_detach _bsd_ieee80211_vht_detach
-#define	ieee80211_vht_get_vhtcap_ie _bsd_ieee80211_vht_get_vhtcap_ie
-#define	ieee80211_vht_get_vhtinfo_ie _bsd_ieee80211_vht_get_vhtinfo_ie
-#define	ieee80211_vht_node_cleanup _bsd_ieee80211_vht_node_cleanup
-#define	ieee80211_vht_node_init _bsd_ieee80211_vht_node_init
-#define	ieee80211_vht_node_join _bsd_ieee80211_vht_node_join
-#define	ieee80211_vht_node_leave _bsd_ieee80211_vht_node_leave
-#define	ieee80211_vht_timeout _bsd_ieee80211_vht_timeout
-#define	ieee80211_vht_update_cap _bsd_ieee80211_vht_update_cap
-#define	ieee80211_vht_updateparams _bsd_ieee80211_vht_updateparams
-#define	ieee80211_vht_vattach _bsd_ieee80211_vht_vattach
-#define	ieee80211_vht_vdetach _bsd_ieee80211_vht_vdetach
-#define	ieee80211_waitfor_parent _bsd_ieee80211_waitfor_parent
-#define	ieee80211_wds_attach _bsd_ieee80211_wds_attach
-#define	ieee80211_wds_detach _bsd_ieee80211_wds_detach
-#define	ieee80211_wme_acnames _bsd_ieee80211_wme_acnames
-#define	ieee80211_wme_ic_getparams _bsd_ieee80211_wme_ic_getparams
-#define	ieee80211_wme_initparams _bsd_ieee80211_wme_initparams
-#define	ieee80211_wme_updateparams _bsd_ieee80211_wme_updateparams
-#define	ieee80211_wme_updateparams_locked _bsd_ieee80211_wme_updateparams_locked
-#define	ieee80211_wme_vap_ac_is_noack _bsd_ieee80211_wme_vap_ac_is_noack
-#define	ieee80211_wme_vap_getparams _bsd_ieee80211_wme_vap_getparams
-#define	ifa_add_loopback_route _bsd_ifa_add_loopback_route
-#define	ifa_alloc _bsd_ifa_alloc
-#define	if_addgroup _bsd_if_addgroup
-#define	if_addmulti _bsd_if_addmulti
-#define	ifaddr_byindex _bsd_ifaddr_byindex
-#define	if_addr_rlock _bsd_if_addr_rlock
-#define	if_addr_runlock _bsd_if_addr_runlock
-#define	ifa_del_loopback_route _bsd_ifa_del_loopback_route
-#define	ifa_free _bsd_ifa_free
-#define	ifa_ifwithaddr _bsd_ifa_ifwithaddr
-#define	ifa_ifwithaddr_check _bsd_ifa_ifwithaddr_check
-#define	ifa_ifwithbroadaddr _bsd_ifa_ifwithbroadaddr
-#define	ifa_ifwithdstaddr _bsd_ifa_ifwithdstaddr
-#define	ifa_ifwithnet _bsd_ifa_ifwithnet
-#define	ifa_ifwithroute _bsd_ifa_ifwithroute
-#define	if_allmulti _bsd_if_allmulti
-#define	if_alloc _bsd_if_alloc
-#define	if_alloc_dev _bsd_if_alloc_dev
-#define	if_alloc_domain _bsd_if_alloc_domain
-#define	ifaof_ifpforaddr _bsd_ifaof_ifpforaddr
-#define	ifa_preferred _bsd_ifa_preferred
-#define	ifa_ref _bsd_ifa_ref
-#define	ifa_switch_loopback_route _bsd_ifa_switch_loopback_route
-#define	if_attach _bsd_if_attach
-#define	if_bpfmtap _bsd_if_bpfmtap
-#define	ifc_alloc_unit _bsd_ifc_alloc_unit
-#define	ifc_flags_get _bsd_ifc_flags_get
-#define	ifc_flags_set _bsd_ifc_flags_set
-#define	ifc_free_unit _bsd_ifc_free_unit
-#define	if_clearhwassist _bsd_if_clearhwassist
-#define	if_clone_addgroup _bsd_if_clone_addgroup
-#define	if_clone_addif _bsd_if_clone_addif
-#define	if_clone_advanced _bsd_if_clone_advanced
-#define	if_clone_create _bsd_if_clone_create
-#define	if_clone_destroy _bsd_if_clone_destroy
-#define	if_clone_destroyif _bsd_if_clone_destroyif
-#define	if_clone_detach _bsd_if_clone_detach
-#define	if_clone_findifc _bsd_if_clone_findifc
-#define	if_clone_list _bsd_if_clone_list
-#define	if_cloners _bsd_if_cloners
-#define	if_clone_simple _bsd_if_clone_simple
-#define	ifc_name _bsd_ifc_name
-#define	ifc_name2unit _bsd_ifc_name2unit
-#define	if_data_copy _bsd_if_data_copy
-#define	if_dead _bsd_if_dead
-#define	if_delallmulti _bsd_if_delallmulti
-#define	if_delgroup _bsd_if_delgroup
-#define	if_delmulti _bsd_if_delmulti
-#define	if_delmulti_ifma _bsd_if_delmulti_ifma
-#define	if_delmulti_ifma_flags _bsd_if_delmulti_ifma_flags
-#define	if_dequeue _bsd_if_dequeue
-#define	if_deregister_com_alloc _bsd_if_deregister_com_alloc
-#define	if_detach _bsd_if_detach
-#define	if_down _bsd_if_down
-#define	if_etherbpfmtap _bsd_if_etherbpfmtap
-#define	if_findmulti _bsd_if_findmulti
-#define	if_free _bsd_if_free
-#define	if_freemulti _bsd_if_freemulti
-#define	if_getamcount _bsd_if_getamcount
-#define	if_getbaudrate _bsd_if_getbaudrate
-#define	if_getcapabilities _bsd_if_getcapabilities
-#define	if_getcapenable _bsd_if_getcapenable
-#define	if_get_counter_default _bsd_if_get_counter_default
-#define	if_getdname _bsd_if_getdname
-#define	if_getdrvflags _bsd_if_getdrvflags
-#define	if_getflags _bsd_if_getflags
-#define	if_gethandle _bsd_if_gethandle
-#define	if_gethwaddr _bsd_if_gethwaddr
-#define	if_gethwassist _bsd_if_gethwassist
-#define	if_gethwtsomax _bsd_if_gethwtsomax
-#define	if_gethwtsomaxsegcount _bsd_if_gethwtsomaxsegcount
-#define	if_gethwtsomaxsegsize _bsd_if_gethwtsomaxsegsize
-#define	if_getifaddr _bsd_if_getifaddr
-#define	if_getlladdr _bsd_if_getlladdr
-#define	if_getmtu _bsd_if_getmtu
-#define	if_getmtu_family _bsd_if_getmtu_family
-#define	if_getsoftc _bsd_if_getsoftc
-#define	if_getvtag _bsd_if_getvtag
-#define	ifg_head _bsd_ifg_head
-#define	if_handoff _bsd_if_handoff
-#define	ifhwioctl _bsd_ifhwioctl
-#define	if_hw_tsomax_common _bsd_if_hw_tsomax_common
-#define	if_hw_tsomax_update _bsd_if_hw_tsomax_update
-#define	if_inc_counter _bsd_if_inc_counter
-#define	if_index _bsd_if_index
-#define	ifindex_table _bsd_ifindex_table
-#define	if_initname _bsd_if_initname
-#define	if_input _bsd_if_input
-#define	ifioctl _bsd_ifioctl
-#define	if_link_state_change _bsd_if_link_state_change
-#define	if_maddr_rlock _bsd_if_maddr_rlock
-#define	if_maddr_runlock _bsd_if_maddr_runlock
-#define	ifma_restart _bsd_ifma_restart
-#define	ifmedia_add _bsd_ifmedia_add
-#define	ifmedia_baudrate _bsd_ifmedia_baudrate
-#define	ifmedia_init _bsd_ifmedia_init
-#define	ifmedia_ioctl _bsd_ifmedia_ioctl
-#define	ifmedia_list_add _bsd_ifmedia_list_add
-#define	ifmedia_removeall _bsd_ifmedia_removeall
-#define	ifmedia_set _bsd_ifmedia_set
-#define	if_multiaddr_array _bsd_if_multiaddr_array
-#define	if_multiaddr_count _bsd_if_multiaddr_count
-#define	if_multi_apply _bsd_if_multi_apply
-#define	ifnet _bsd_ifnet
-#define	ifnet_byindex _bsd_ifnet_byindex
-#define	ifnet_byindex_locked _bsd_ifnet_byindex_locked
-#define	ifnet_byindex_ref _bsd_ifnet_byindex_ref
-#define	ifnet_rwlock _bsd_ifnet_rwlock
-#define	ifnet_sxlock _bsd_ifnet_sxlock
-#define	if_printf _bsd_if_printf
-#define	ifpromisc _bsd_ifpromisc
-#define	if_purgeaddrs _bsd_if_purgeaddrs
-#define	ifq_delete _bsd_ifq_delete
-#define	if_qflush _bsd_if_qflush
-#define	ifq_init _bsd_ifq_init
-#define	ifr_data_get_ptr _bsd_ifr_data_get_ptr
-#define	if_ref _bsd_if_ref
-#define	if_register_com_alloc _bsd_if_register_com_alloc
-#define	if_rele _bsd_if_rele
-#define	if_sendq_empty _bsd_if_sendq_empty
-#define	if_sendq_prepend _bsd_if_sendq_prepend
-#define	if_setbaudrate _bsd_if_setbaudrate
-#define	if_setcapabilities _bsd_if_setcapabilities
-#define	if_setcapabilitiesbit _bsd_if_setcapabilitiesbit
-#define	if_setcapenable _bsd_if_setcapenable
-#define	if_setcapenablebit _bsd_if_setcapenablebit
-#define	if_setdev _bsd_if_setdev
-#define	if_setdrvflagbits _bsd_if_setdrvflagbits
-#define	if_setdrvflags _bsd_if_setdrvflags
-#define	if_setflagbits _bsd_if_setflagbits
-#define	if_setflags _bsd_if_setflags
-#define	if_setgetcounterfn _bsd_if_setgetcounterfn
-#define	if_sethwassist _bsd_if_sethwassist
-#define	if_sethwassistbits _bsd_if_sethwassistbits
-#define	if_sethwtsomax _bsd_if_sethwtsomax
-#define	if_sethwtsomaxsegcount _bsd_if_sethwtsomaxsegcount
-#define	if_sethwtsomaxsegsize _bsd_if_sethwtsomaxsegsize
-#define	if_setifheaderlen _bsd_if_setifheaderlen
-#define	if_setinitfn _bsd_if_setinitfn
-#define	if_setioctlfn _bsd_if_setioctlfn
-#define	if_setlladdr _bsd_if_setlladdr
-#define	if_setmtu _bsd_if_setmtu
-#define	if_setqflushfn _bsd_if_setqflushfn
-#define	if_setrcvif _bsd_if_setrcvif
-#define	if_setsendqlen _bsd_if_setsendqlen
-#define	if_setsendqready _bsd_if_setsendqready
-#define	if_setsoftc _bsd_if_setsoftc
-#define	if_setstartfn _bsd_if_setstartfn
-#define	if_settransmitfn _bsd_if_settransmitfn
-#define	if_setupmultiaddr _bsd_if_setupmultiaddr
-#define	if_setvtag _bsd_if_setvtag
-#define	if_simloop _bsd_if_simloop
-#define	if_start _bsd_if_start
-#define	if_togglecapenable _bsd_if_togglecapenable
-#define	if_tunnel_check_nesting _bsd_if_tunnel_check_nesting
-#define	ifunit _bsd_ifunit
-#define	ifunit_ref _bsd_ifunit_ref
-#define	if_up _bsd_if_up
-#define	if_vlancap _bsd_if_vlancap
-#define	if_vlantrunkinuse _bsd_if_vlantrunkinuse
-#define	igb_sctx _bsd_igb_sctx
-#define	igb_txrx _bsd_igb_txrx
-#define	igmp_change_state _bsd_igmp_change_state
-#define	igmp_domifattach _bsd_igmp_domifattach
-#define	igmp_domifdetach _bsd_igmp_domifdetach
-#define	igmp_fasttimo _bsd_igmp_fasttimo
-#define	igmp_ifdetach _bsd_igmp_ifdetach
-#define	igmp_input _bsd_igmp_input
-#define	igmp_mtx _bsd_igmp_mtx
-#define	igmp_slowtimo _bsd_igmp_slowtimo
-#define	iic2errno _bsd_iic2errno
-#define	iicbus_block_read _bsd_iicbus_block_read
-#define	iicbus_block_write _bsd_iicbus_block_write
-#define	iicbus_devclass _bsd_iicbus_devclass
-#define	iicbus_driver _bsd_iicbus_driver
-#define	iicbus_generic_intr _bsd_iicbus_generic_intr
-#define	iicbus_init_frequency _bsd_iicbus_init_frequency
-#define	iicbus_intr _bsd_iicbus_intr
-#define	iicbus_null_callback _bsd_iicbus_null_callback
-#define	iicbus_null_repeated_start _bsd_iicbus_null_repeated_start
-#define	iicbus_read _bsd_iicbus_read
-#define	iicbus_read_byte _bsd_iicbus_read_byte
-#define	iicbus_release_bus _bsd_iicbus_release_bus
-#define	iicbus_repeated_start _bsd_iicbus_repeated_start
-#define	iicbus_request_bus _bsd_iicbus_request_bus
-#define	iicbus_start _bsd_iicbus_start
-#define	iicbus_started _bsd_iicbus_started
-#define	iicbus_stop _bsd_iicbus_stop
-#define	iicbus_transfer _bsd_iicbus_transfer
-#define	iicbus_transfer_excl _bsd_iicbus_transfer_excl
-#define	iicbus_transfer_gen _bsd_iicbus_transfer_gen
-#define	iicbus_write _bsd_iicbus_write
-#define	iicbus_write_byte _bsd_iicbus_write_byte
-#define	iicdev_readfrom _bsd_iicdev_readfrom
-#define	iicdev_writeto _bsd_iicdev_writeto
-#define	im6o_mc_filter _bsd_im6o_mc_filter
-#define	imo_multi_filter _bsd_imo_multi_filter
-#define	in4_cksum _bsd_in4_cksum
-#define	in6addr_linklocal_allrouters _bsd_in6addr_linklocal_allrouters
-#define	in6addr_linklocal_allv2routers _bsd_in6addr_linklocal_allv2routers
-#define	in6_addrscope _bsd_in6_addrscope
-#define	in6_are_prefix_equal _bsd_in6_are_prefix_equal
-#define	in6_cksum _bsd_in6_cksum
-#define	in6_cksum_partial _bsd_in6_cksum_partial
-#define	in6_cksum_pseudo _bsd_in6_cksum_pseudo
-#define	in6_clearscope _bsd_in6_clearscope
-#define	in6_control _bsd_in6_control
-#define	in6_delayed_cksum _bsd_in6_delayed_cksum
-#define	in6_domifattach _bsd_in6_domifattach
-#define	in6_domifdetach _bsd_in6_domifdetach
-#define	in6_domifmtu _bsd_in6_domifmtu
-#define	in6_get_hw_ifid _bsd_in6_get_hw_ifid
-#define	in6_getlinkifnet _bsd_in6_getlinkifnet
-#define	in6_getpeeraddr _bsd_in6_getpeeraddr
-#define	in6_getscope _bsd_in6_getscope
-#define	in6_getscopezone _bsd_in6_getscopezone
-#define	in6_getsockaddr _bsd_in6_getsockaddr
-#define	in6_get_tmpifid _bsd_in6_get_tmpifid
-#define	in6_gif_init _bsd_in6_gif_init
-#define	in6_gif_ioctl _bsd_in6_gif_ioctl
-#define	in6_gif_output _bsd_in6_gif_output
-#define	in6_gif_setopts _bsd_in6_gif_setopts
-#define	in6_gif_uninit _bsd_in6_gif_uninit
-#define	in6_if2idlen _bsd_in6_if2idlen
-#define	in6_ifaddrhashtbl _bsd_in6_ifaddrhashtbl
-#define	in6_ifaddrhead _bsd_in6_ifaddrhead
-#define	in6_ifaddrhmask _bsd_in6_ifaddrhmask
-#define	in6_ifaddr_lock _bsd_in6_ifaddr_lock
-#define	in6ifa_ifpforlinklocal _bsd_in6ifa_ifpforlinklocal
-#define	in6ifa_ifpwithaddr _bsd_in6ifa_ifpwithaddr
-#define	in6ifa_ifwithaddr _bsd_in6ifa_ifwithaddr
-#define	in6ifa_llaonifp _bsd_in6ifa_llaonifp
-#define	in6_ifattach _bsd_in6_ifattach
-#define	in6_ifattach_destroy _bsd_in6_ifattach_destroy
-#define	in6_ifawithifp _bsd_in6_ifawithifp
-#define	in6_ifdetach _bsd_in6_ifdetach
-#define	in6_ifdetach_destroy _bsd_in6_ifdetach_destroy
-#define	in6if_do_dad _bsd_in6if_do_dad
-#define	in6_ifhasaddr _bsd_in6_ifhasaddr
-#define	in6_if_up _bsd_in6_if_up
-#define	in6_inithead _bsd_in6_inithead
-#define	in6_is_addr_deprecated _bsd_in6_is_addr_deprecated
-#define	in6_joingroup _bsd_in6_joingroup
-#define	in6_joingroup_locked _bsd_in6_joingroup_locked
-#define	in6_leavegroup _bsd_in6_leavegroup
-#define	in6_leavegroup_locked _bsd_in6_leavegroup_locked
-#define	in6_localaddr _bsd_in6_localaddr
-#define	in6_localip _bsd_in6_localip
-#define	in6_losing _bsd_in6_losing
-#define	in6_mapped_peeraddr _bsd_in6_mapped_peeraddr
-#define	in6_mapped_sockaddr _bsd_in6_mapped_sockaddr
-#define	in6mask0 _bsd_in6mask0
-#define	in6mask128 _bsd_in6mask128
-#define	in6_mask2len _bsd_in6_mask2len
-#define	in6mask32 _bsd_in6mask32
-#define	in6mask64 _bsd_in6mask64
-#define	in6mask96 _bsd_in6mask96
-#define	in6_matchlen _bsd_in6_matchlen
-#define	in6_maxmtu _bsd_in6_maxmtu
-#define	in6_mcast_loop _bsd_in6_mcast_loop
-#define	in6m_clear_recorded _bsd_in6m_clear_recorded
-#define	in6m_commit _bsd_in6m_commit
-#define	in6m_disconnect_locked _bsd_in6m_disconnect_locked
-#define	in6m_print _bsd_in6m_print
-#define	in6m_record_source _bsd_in6m_record_source
-#define	in6m_release_list_deferred _bsd_in6m_release_list_deferred
-#define	in6m_release_wait _bsd_in6m_release_wait
-#define	in6_multi_free_mtx _bsd_in6_multi_free_mtx
-#define	in6_multi_list_mtx _bsd_in6_multi_list_mtx
-#define	in6_multi_sx _bsd_in6_multi_sx
-#define	in6_newaddrmsg _bsd_in6_newaddrmsg
-#define	in6_nigroup _bsd_in6_nigroup
-#define	in6_nigroup_oldmcprefix _bsd_in6_nigroup_oldmcprefix
-#define	in6_pcbbind _bsd_in6_pcbbind
-#define	in6_pcbconnect _bsd_in6_pcbconnect
-#define	in6_pcbconnect_mbuf _bsd_in6_pcbconnect_mbuf
-#define	in6_pcbdisconnect _bsd_in6_pcbdisconnect
-#define	in6_pcblookup _bsd_in6_pcblookup
-#define	in6_pcblookup_local _bsd_in6_pcblookup_local
-#define	in6_pcblookup_mbuf _bsd_in6_pcblookup_mbuf
-#define	in6_pcbnotify _bsd_in6_pcbnotify
-#define	in6_pcbpurgeif0 _bsd_in6_pcbpurgeif0
-#define	in6_pcbsetport _bsd_in6_pcbsetport
-#define	in6_prefixlen2mask _bsd_in6_prefixlen2mask
-#define	in6_prepare_ifra _bsd_in6_prepare_ifra
-#define	in6_purgeaddr _bsd_in6_purgeaddr
-#define	in6_rtalloc _bsd_in6_rtalloc
-#define	in6_rtalloc1 _bsd_in6_rtalloc1
-#define	in6_rtalloc_ign _bsd_in6_rtalloc_ign
-#define	in6_rtchange _bsd_in6_rtchange
-#define	in6_rtredirect _bsd_in6_rtredirect
-#define	in6_rtrequest _bsd_in6_rtrequest
-#define	in6_selecthlim _bsd_in6_selecthlim
-#define	in6_selectroute _bsd_in6_selectroute
-#define	in6_selectroute_fib _bsd_in6_selectroute_fib
-#define	in6_selectsrc_addr _bsd_in6_selectsrc_addr
-#define	in6_selectsrc_socket _bsd_in6_selectsrc_socket
-#define	in6_setmaxmtu _bsd_in6_setmaxmtu
-#define	in6_setscope _bsd_in6_setscope
-#define	in6_sin_2_v4mapsin6 _bsd_in6_sin_2_v4mapsin6
-#define	in6_sin_2_v4mapsin6_in_sock _bsd_in6_sin_2_v4mapsin6_in_sock
-#define	in6_sin6_2_sin _bsd_in6_sin6_2_sin
-#define	in6_sin6_2_sin_in_sock _bsd_in6_sin6_2_sin_in_sock
-#define	in6_sockaddr _bsd_in6_sockaddr
-#define	in6_splitscope _bsd_in6_splitscope
-#define	in6_src_ioctl _bsd_in6_src_ioctl
-#define	in6_tmpaddrtimer _bsd_in6_tmpaddrtimer
-#define	in6_tmpaddrtimer_ch _bsd_in6_tmpaddrtimer_ch
-#define	in6_tmpifadd _bsd_in6_tmpifadd
-#define	in6_update_ifa _bsd_in6_update_ifa
-#define	in6_v4mapsin6_sockaddr _bsd_in6_v4mapsin6_sockaddr
-#define	in_addmulti _bsd_in_addmulti
-#define	in_addprefix _bsd_in_addprefix
-#define	in_addword _bsd_in_addword
-#define	in_broadcast _bsd_in_broadcast
-#define	in_canforward _bsd_in_canforward
-#define	in_cksum_hdr _bsd_in_cksum_hdr
-#define	in_cksum_skip _bsd_in_cksum_skip
-#define	in_control _bsd_in_control
-#define	in_delayed_cksum _bsd_in_delayed_cksum
-#define	in_domifattach _bsd_in_domifattach
-#define	in_domifdetach _bsd_in_domifdetach
-#define	inet6ctlerrmap _bsd_inet6ctlerrmap
-#define	inet6domain _bsd_inet6domain
-#define	inet6_pfil_head _bsd_inet6_pfil_head
-#define	inet6_pfil_hook _bsd_inet6_pfil_hook
-#define	inet6sw _bsd_inet6sw
-#define	inetctlerrmap _bsd_inetctlerrmap
-#define	inetdomain _bsd_inetdomain
-#define	inet_ntoa_r _bsd_inet_ntoa_r
-#define	inet_pfil_head _bsd_inet_pfil_head
-#define	inet_pfil_hook _bsd_inet_pfil_hook
-#define	inetsw _bsd_inetsw
-#define	in_getpeeraddr _bsd_in_getpeeraddr
-#define	in_getsockaddr _bsd_in_getsockaddr
-#define	in_gif_init _bsd_in_gif_init
-#define	in_gif_ioctl _bsd_in_gif_ioctl
-#define	in_gif_output _bsd_in_gif_output
-#define	in_gif_setopts _bsd_in_gif_setopts
-#define	in_gif_uninit _bsd_in_gif_uninit
-#define	in_gre_init _bsd_in_gre_init
-#define	in_gre_ioctl _bsd_in_gre_ioctl
-#define	in_gre_output _bsd_in_gre_output
-#define	in_gre_setopts _bsd_in_gre_setopts
-#define	in_gre_uninit _bsd_in_gre_uninit
-#define	in_ifaddr_broadcast _bsd_in_ifaddr_broadcast
-#define	in_ifaddrhashtbl _bsd_in_ifaddrhashtbl
-#define	in_ifaddrhead _bsd_in_ifaddrhead
-#define	in_ifaddrhmask _bsd_in_ifaddrhmask
-#define	in_ifaddr_lock _bsd_in_ifaddr_lock
-#define	in_ifadown _bsd_in_ifadown
-#define	in_ifdetach _bsd_in_ifdetach
-#define	in_ifhasaddr _bsd_in_ifhasaddr
-#define	in_ifscrub_all _bsd_in_ifscrub_all
-#define	in_inithead _bsd_in_inithead
-#define	init_machclk _bsd_init_machclk
-#define	init_sin6 _bsd_init_sin6
-#define	init_sleepqueues _bsd_init_sleepqueues
-#define	init_unrhdr _bsd_init_unrhdr
-#define	in_joingroup _bsd_in_joingroup
-#define	in_joingroup_locked _bsd_in_joingroup_locked
-#define	in_leavegroup _bsd_in_leavegroup
-#define	in_leavegroup_locked _bsd_in_leavegroup_locked
-#define	in_localaddr _bsd_in_localaddr
-#define	in_localip _bsd_in_localip
-#define	in_losing _bsd_in_losing
-#define	in_mcast_loop _bsd_in_mcast_loop
-#define	inm_clear_recorded _bsd_inm_clear_recorded
-#define	inm_commit _bsd_inm_commit
-#define	inm_disconnect _bsd_inm_disconnect
-#define	inm_lookup _bsd_inm_lookup
-#define	inm_lookup_locked _bsd_inm_lookup_locked
-#define	inm_print _bsd_inm_print
-#define	inm_record_source _bsd_inm_record_source
-#define	inm_release_deferred _bsd_inm_release_deferred
-#define	inm_release_list_deferred _bsd_inm_release_list_deferred
-#define	in_multi_free_mtx _bsd_in_multi_free_mtx
-#define	in_multi_list_mtx _bsd_in_multi_list_mtx
-#define	in_multi_sx _bsd_in_multi_sx
-#define	inp_4tuple_get _bsd_inp_4tuple_get
-#define	inp_apply_all _bsd_inp_apply_all
-#define	in_pcballoc _bsd_in_pcballoc
-#define	in_pcbbind _bsd_in_pcbbind
-#define	in_pcbbind_check_bindmulti _bsd_in_pcbbind_check_bindmulti
-#define	in_pcbbind_setup _bsd_in_pcbbind_setup
-#define	in_pcbconnect _bsd_in_pcbconnect
-#define	in_pcbconnect_mbuf _bsd_in_pcbconnect_mbuf
-#define	in_pcbconnect_setup _bsd_in_pcbconnect_setup
-#define	in_pcbdetach _bsd_in_pcbdetach
-#define	in_pcbdisconnect _bsd_in_pcbdisconnect
-#define	in_pcbdrop _bsd_in_pcbdrop
-#define	in_pcbfree _bsd_in_pcbfree
-#define	in_pcbinfo_destroy _bsd_in_pcbinfo_destroy
-#define	in_pcbinfo_init _bsd_in_pcbinfo_init
-#define	in_pcbinshash _bsd_in_pcbinshash
-#define	in_pcbinshash_nopcbgroup _bsd_in_pcbinshash_nopcbgroup
-#define	in_pcbladdr _bsd_in_pcbladdr
-#define	in_pcblist_rele_rlocked _bsd_in_pcblist_rele_rlocked
-#define	in_pcblookup _bsd_in_pcblookup
-#define	in_pcblookup_local _bsd_in_pcblookup_local
-#define	in_pcblookup_mbuf _bsd_in_pcblookup_mbuf
-#define	in_pcb_lport _bsd_in_pcb_lport
-#define	in_pcbnotifyall _bsd_in_pcbnotifyall
-#define	in_pcbpurgeif0 _bsd_in_pcbpurgeif0
-#define	in_pcbref _bsd_in_pcbref
-#define	in_pcbrehash _bsd_in_pcbrehash
-#define	in_pcbrehash_mbuf _bsd_in_pcbrehash_mbuf
-#define	in_pcbrele _bsd_in_pcbrele
-#define	in_pcbrele_rlocked _bsd_in_pcbrele_rlocked
-#define	in_pcbrele_wlocked _bsd_in_pcbrele_wlocked
-#define	in_pcbsosetlabel _bsd_in_pcbsosetlabel
-#define	in_pcbtoxinpcb _bsd_in_pcbtoxinpcb
-#define	inp_freemoptions _bsd_inp_freemoptions
-#define	inp_getmoptions _bsd_inp_getmoptions
-#define	inp_inpcbtosocket _bsd_inp_inpcbtosocket
-#define	inp_inpcbtotcpcb _bsd_inp_inpcbtotcpcb
-#define	inp_ip_tos_get _bsd_inp_ip_tos_get
-#define	inp_ip_tos_set _bsd_inp_ip_tos_set
-#define	inp_rlock _bsd_inp_rlock
-#define	inp_runlock _bsd_inp_runlock
-#define	inp_setmoptions _bsd_inp_setmoptions
-#define	in_pseudo _bsd_in_pseudo
-#define	inp_so_options _bsd_inp_so_options
-#define	inp_to_cpuid _bsd_inp_to_cpuid
-#define	inp_wlock _bsd_inp_wlock
-#define	inp_wunlock _bsd_inp_wunlock
-#define	in_rtalloc_ign _bsd_in_rtalloc_ign
-#define	in_rtredirect _bsd_in_rtredirect
-#define	in_scrubprefix _bsd_in_scrubprefix
-#define	in_sockaddr _bsd_in_sockaddr
-#define	intr_event_add_handler _bsd_intr_event_add_handler
-#define	intr_event_create _bsd_intr_event_create
-#define	ip4_ah_net_deflev _bsd_ip4_ah_net_deflev
-#define	ip4_ah_trans_deflev _bsd_ip4_ah_trans_deflev
-#define	ip4_esp_net_deflev _bsd_ip4_esp_net_deflev
-#define	ip4_esp_trans_deflev _bsd_ip4_esp_trans_deflev
-#define	ip4_ipsec_dfbit _bsd_ip4_ipsec_dfbit
-#define	ip4_ipsec_ecn _bsd_ip4_ipsec_ecn
-#define	ip6_accept_rtadv _bsd_ip6_accept_rtadv
-#define	ip6_ah_net_deflev _bsd_ip6_ah_net_deflev
-#define	ip6_ah_trans_deflev _bsd_ip6_ah_trans_deflev
-#define	ip6_auto_flowlabel _bsd_ip6_auto_flowlabel
-#define	ip6_auto_linklocal _bsd_ip6_auto_linklocal
-#define	ip6_clearpktopts _bsd_ip6_clearpktopts
-#define	ip6_copypktopts _bsd_ip6_copypktopts
-#define	ip6_ctloutput _bsd_ip6_ctloutput
-#define	ip6_dad_count _bsd_ip6_dad_count
-#define	ip6_defhlim _bsd_ip6_defhlim
-#define	ip6_defmcasthlim _bsd_ip6_defmcasthlim
-#define	ip6_deletefraghdr _bsd_ip6_deletefraghdr
-#define	ip6_desync_factor _bsd_ip6_desync_factor
-#define	ip6_ecn_egress _bsd_ip6_ecn_egress
-#define	ip6_ecn_ingress _bsd_ip6_ecn_ingress
-#define	ip6_encap_attach _bsd_ip6_encap_attach
-#define	ip6_encap_detach _bsd_ip6_encap_detach
-#define	ip6_encap_register_srcaddr _bsd_ip6_encap_register_srcaddr
-#define	ip6_encap_unregister_srcaddr _bsd_ip6_encap_unregister_srcaddr
-#define	ip6_esp_net_deflev _bsd_ip6_esp_net_deflev
-#define	ip6_esp_trans_deflev _bsd_ip6_esp_trans_deflev
-#define	ip6_forward _bsd_ip6_forward
-#define	ip6_forwarding _bsd_ip6_forwarding
-#define	ip6_fragment _bsd_ip6_fragment
-#define	ip6_freemoptions _bsd_ip6_freemoptions
-#define	ip6_freepcbopts _bsd_ip6_freepcbopts
-#define	ip6_getmoptions _bsd_ip6_getmoptions
-#define	ip6_get_prevhdr _bsd_ip6_get_prevhdr
-#define	ip6_hdrnestlimit _bsd_ip6_hdrnestlimit
-#define	ip6_init _bsd_ip6_init
-#define	ip6_initpktopts _bsd_ip6_initpktopts
-#define	ip6_input _bsd_ip6_input
-#define	ip6_ipsec_ecn _bsd_ip6_ipsec_ecn
-#define	ip6_lasthdr _bsd_ip6_lasthdr
-#define	ip6_log_interval _bsd_ip6_log_interval
-#define	ip6_log_time _bsd_ip6_log_time
-#define	ip6_maxfragbucketsize _bsd_ip6_maxfragbucketsize
-#define	ip6_maxfragpackets _bsd_ip6_maxfragpackets
-#define	ip6_maxfrags _bsd_ip6_maxfrags
-#define	ip6_maxfragsperpacket _bsd_ip6_maxfragsperpacket
-#define	ip6_mcast_pmtu _bsd_ip6_mcast_pmtu
-#define	ip6_mfilter_alloc _bsd_ip6_mfilter_alloc
-#define	ip6_mfilter_free _bsd_ip6_mfilter_free
-#define	ip6_mforward _bsd_ip6_mforward
-#define	ip6_mloopback _bsd_ip6_mloopback
-#define	ip6_mrouter _bsd_ip6_mrouter
-#define	ip6_mrouter_done _bsd_ip6_mrouter_done
-#define	ip6_mrouter_get _bsd_ip6_mrouter_get
-#define	ip6_mrouter_set _bsd_ip6_mrouter_set
-#define	ip6_msource_tree_RB_FIND _bsd_ip6_msource_tree_RB_FIND
-#define	ip6_msource_tree_RB_INSERT _bsd_ip6_msource_tree_RB_INSERT
-#define	ip6_msource_tree_RB_INSERT_COLOR _bsd_ip6_msource_tree_RB_INSERT_COLOR
-#define	ip6_msource_tree_RB_MINMAX _bsd_ip6_msource_tree_RB_MINMAX
-#define	ip6_msource_tree_RB_NEXT _bsd_ip6_msource_tree_RB_NEXT
-#define	ip6_msource_tree_RB_NFIND _bsd_ip6_msource_tree_RB_NFIND
-#define	ip6_msource_tree_RB_PREV _bsd_ip6_msource_tree_RB_PREV
-#define	ip6_msource_tree_RB_REMOVE _bsd_ip6_msource_tree_RB_REMOVE
-#define	ip6_msource_tree_RB_REMOVE_COLOR _bsd_ip6_msource_tree_RB_REMOVE_COLOR
-#define	ip6_nexthdr _bsd_ip6_nexthdr
-#define	ip6_no_radr _bsd_ip6_no_radr
-#define	ip6_norbit_raif _bsd_ip6_norbit_raif
-#define	ip6_notify_pmtu _bsd_ip6_notify_pmtu
-#define	ip6_optlen _bsd_ip6_optlen
-#define	ip6_output _bsd_ip6_output
-#define	ip6_prefer_tempaddr _bsd_ip6_prefer_tempaddr
-#define	ip6_process_hopopts _bsd_ip6_process_hopopts
-#define	ip6proto_register _bsd_ip6proto_register
-#define	ip6proto_unregister _bsd_ip6proto_unregister
-#define	ip6_protox _bsd_ip6_protox
-#define	ip6_randomflowlabel _bsd_ip6_randomflowlabel
-#define	ip6_randomid _bsd_ip6_randomid
-#define	ip6_raw_ctloutput _bsd_ip6_raw_ctloutput
-#define	ip6_rfc6204w3 _bsd_ip6_rfc6204w3
-#define	ip6_rr_prune _bsd_ip6_rr_prune
-#define	ip6_savecontrol _bsd_ip6_savecontrol
-#define	ip6_savecontrol_v4 _bsd_ip6_savecontrol_v4
-#define	ip6_sendredirects _bsd_ip6_sendredirects
-#define	ip6_setmoptions _bsd_ip6_setmoptions
-#define	ip6_setpktopts _bsd_ip6_setpktopts
-#define	ip6_sprintf _bsd_ip6_sprintf
-#define	ip6stat _bsd_ip6stat
-#define	ip6_temp_preferred_lifetime _bsd_ip6_temp_preferred_lifetime
-#define	ip6_temp_regen_advance _bsd_ip6_temp_regen_advance
-#define	ip6_temp_valid_lifetime _bsd_ip6_temp_valid_lifetime
-#define	ip6_tryforward _bsd_ip6_tryforward
-#define	ip6_unknown_opt _bsd_ip6_unknown_opt
-#define	ip6_use_defzone _bsd_ip6_use_defzone
-#define	ip6_use_deprecated _bsd_ip6_use_deprecated
-#define	ip6_use_tempaddr _bsd_ip6_use_tempaddr
-#define	ip6_v6only _bsd_ip6_v6only
-#define	ip_checkrouteralert _bsd_ip_checkrouteralert
-#define	ipcomp_enable _bsd_ipcomp_enable
-#define	ipcompstat _bsd_ipcompstat
-#define	ip_ctloutput _bsd_ip_ctloutput
-#define	ip_defttl _bsd_ip_defttl
-#define	ip_divert_ptr _bsd_ip_divert_ptr
-#define	ip_dn_ctl_ptr _bsd_ip_dn_ctl_ptr
-#define	ip_dn_io_ptr _bsd_ip_dn_io_ptr
-#define	ip_dooptions _bsd_ip_dooptions
-#define	ip_doopts _bsd_ip_doopts
-#define	ip_drain _bsd_ip_drain
-#define	ip_ecn_egress _bsd_ip_ecn_egress
-#define	ip_ecn_ingress _bsd_ip_ecn_ingress
-#define	ip_encap_attach _bsd_ip_encap_attach
-#define	ip_encap_detach _bsd_ip_encap_detach
-#define	ip_encap_register_srcaddr _bsd_ip_encap_register_srcaddr
-#define	ip_encap_unregister_srcaddr _bsd_ip_encap_unregister_srcaddr
-#define	ip_fillid _bsd_ip_fillid
-#define	ip_forward _bsd_ip_forward
-#define	ipforwarding _bsd_ipforwarding
-#define	ip_fragment _bsd_ip_fragment
-#define	ip_fw_chk_ptr _bsd_ip_fw_chk_ptr
-#define	ip_fw_ctl_ptr _bsd_ip_fw_ctl_ptr
-#define	ip_gre_ttl _bsd_ip_gre_ttl
-#define	ip_init _bsd_ip_init
-#define	ip_input _bsd_ip_input
-#define	ip_insertoptions _bsd_ip_insertoptions
-#define	ip_mcast_src _bsd_ip_mcast_src
-#define	ip_mfilter_alloc _bsd_ip_mfilter_alloc
-#define	ip_mfilter_free _bsd_ip_mfilter_free
-#define	ip_mforward _bsd_ip_mforward
-#define	ip_mrouter _bsd_ip_mrouter
-#define	ip_mrouter_done _bsd_ip_mrouter_done
-#define	ip_mrouter_get _bsd_ip_mrouter_get
-#define	ip_mrouter_set _bsd_ip_mrouter_set
-#define	ip_msource_tree_RB_FIND _bsd_ip_msource_tree_RB_FIND
-#define	ip_msource_tree_RB_INSERT _bsd_ip_msource_tree_RB_INSERT
-#define	ip_msource_tree_RB_INSERT_COLOR _bsd_ip_msource_tree_RB_INSERT_COLOR
-#define	ip_msource_tree_RB_MINMAX _bsd_ip_msource_tree_RB_MINMAX
-#define	ip_msource_tree_RB_NEXT _bsd_ip_msource_tree_RB_NEXT
-#define	ip_msource_tree_RB_NFIND _bsd_ip_msource_tree_RB_NFIND
-#define	ip_msource_tree_RB_PREV _bsd_ip_msource_tree_RB_PREV
-#define	ip_msource_tree_RB_REMOVE _bsd_ip_msource_tree_RB_REMOVE
-#define	ip_msource_tree_RB_REMOVE_COLOR _bsd_ip_msource_tree_RB_REMOVE_COLOR
-#define	ip_next_mtu _bsd_ip_next_mtu
-#define	ip_optcopy _bsd_ip_optcopy
-#define	ip_output _bsd_ip_output
-#define	ip_pcbopts _bsd_ip_pcbopts
-#define	ipport_firstauto _bsd_ipport_firstauto
-#define	ipport_hifirstauto _bsd_ipport_hifirstauto
-#define	ipport_hilastauto _bsd_ipport_hilastauto
-#define	ipport_lastauto _bsd_ipport_lastauto
-#define	ipport_lowfirstauto _bsd_ipport_lowfirstauto
-#define	ipport_lowlastauto _bsd_ipport_lowlastauto
-#define	ipport_randomcps _bsd_ipport_randomcps
-#define	ipport_randomized _bsd_ipport_randomized
-#define	ipport_randomtime _bsd_ipport_randomtime
-#define	ipport_reservedhigh _bsd_ipport_reservedhigh
-#define	ipport_reservedlow _bsd_ipport_reservedlow
-#define	ipport_stoprandom _bsd_ipport_stoprandom
-#define	ipport_tcpallocs _bsd_ipport_tcpallocs
-#define	ipproto_register _bsd_ipproto_register
-#define	ipproto_unregister _bsd_ipproto_unregister
-#define	ip_protox _bsd_ip_protox
-#define	ip_reass _bsd_ip_reass
-#define	ipreass_drain _bsd_ipreass_drain
-#define	ipreass_init _bsd_ipreass_init
-#define	ipreass_slowtimo _bsd_ipreass_slowtimo
-#define	ip_rsvpd _bsd_ip_rsvpd
-#define	ip_rsvp_done _bsd_ip_rsvp_done
-#define	ip_rsvp_force_done _bsd_ip_rsvp_force_done
-#define	ip_rsvp_init _bsd_ip_rsvp_init
-#define	ip_rsvp_vif _bsd_ip_rsvp_vif
-#define	ip_savecontrol _bsd_ip_savecontrol
-#define	ipsec4_capability _bsd_ipsec4_capability
-#define	ipsec4_checkpolicy _bsd_ipsec4_checkpolicy
-#define	ipsec4_common_input_cb _bsd_ipsec4_common_input_cb
-#define	ipsec4_forward _bsd_ipsec4_forward
-#define	ipsec4_input _bsd_ipsec4_input
-#define	ipsec4_in_reject _bsd_ipsec4_in_reject
-#define	ipsec4_output _bsd_ipsec4_output
-#define	ipsec4_pcbctl _bsd_ipsec4_pcbctl
-#define	ipsec4_process_packet _bsd_ipsec4_process_packet
-#define	ipsec4_setsockaddrs _bsd_ipsec4_setsockaddrs
-#define	ipsec4stat _bsd_ipsec4stat
-#define	ipsec6_capability _bsd_ipsec6_capability
-#define	ipsec6_checkpolicy _bsd_ipsec6_checkpolicy
-#define	ipsec6_common_input_cb _bsd_ipsec6_common_input_cb
-#define	ipsec6_forward _bsd_ipsec6_forward
-#define	ipsec6_input _bsd_ipsec6_input
-#define	ipsec6_in_reject _bsd_ipsec6_in_reject
-#define	ipsec6_output _bsd_ipsec6_output
-#define	ipsec6_pcbctl _bsd_ipsec6_pcbctl
-#define	ipsec6_process_packet _bsd_ipsec6_process_packet
-#define	ipsec6_setsockaddrs _bsd_ipsec6_setsockaddrs
-#define	ipsec6stat _bsd_ipsec6stat
-#define	ipsec_address _bsd_ipsec_address
-#define	ipsec_bindump _bsd_ipsec_bindump
-#define	ipsec_chkreplay _bsd_ipsec_chkreplay
-#define	ipsec_copy_pcbpolicy _bsd_ipsec_copy_pcbpolicy
-#define	ipsec_debug _bsd_ipsec_debug
-#define	ipsec_delete_pcbpolicy _bsd_ipsec_delete_pcbpolicy
-#define	ipsec_delisr _bsd_ipsec_delisr
-#define	ipsec_get_reqlevel _bsd_ipsec_get_reqlevel
-#define	ipsec_hdrsiz_inpcb _bsd_ipsec_hdrsiz_inpcb
-#define	ipsec_hexdump _bsd_ipsec_hexdump
-#define	ipsec_hhh_in _bsd_ipsec_hhh_in
-#define	ipsec_hhh_out _bsd_ipsec_hhh_out
-#define	ipsec_if_input _bsd_ipsec_if_input
-#define	ipsec_initialized _bsd_ipsec_initialized
-#define	ipsec_init_pcbpolicy _bsd_ipsec_init_pcbpolicy
-#define	ipsec_newisr _bsd_ipsec_newisr
-#define	ipsec_process_done _bsd_ipsec_process_done
-#define	ipsec_run_hhooks _bsd_ipsec_run_hhooks
-#define	ipsec_sa2str _bsd_ipsec_sa2str
-#define	ipsec_setspidx_inpcb _bsd_ipsec_setspidx_inpcb
-#define	ipsec_updateid _bsd_ipsec_updateid
-#define	ipsec_updatereplay _bsd_ipsec_updatereplay
-#define	ipsec_warn_interval _bsd_ipsec_warn_interval
-#define	ip_slowtimo _bsd_ip_slowtimo
-#define	ip_srcroute _bsd_ip_srcroute
-#define	ipstat _bsd_ipstat
-#define	ip_stripoptions _bsd_ip_stripoptions
-#define	iptime _bsd_iptime
-#define	ip_tryforward _bsd_ip_tryforward
-#define	ipv4_ipsec_support _bsd_ipv4_ipsec_support
-#define	ipv6_ipsec_support _bsd_ipv6_ipsec_support
-#define	itimerfix _bsd_itimerfix
-#define	jenkins_hash _bsd_jenkins_hash
-#define	jenkins_hash32 _bsd_jenkins_hash32
-#define	kbd_add_driver _bsd_kbd_add_driver
-#define	kbd_allocate _bsd_kbd_allocate
-#define	kbd_attach _bsd_kbd_attach
-#define	kbd_change_callback _bsd_kbd_change_callback
-#define	kbd_configure _bsd_kbd_configure
-#define	kbd_delete_driver _bsd_kbd_delete_driver
-#define	kbd_detach _bsd_kbd_detach
-#define	kbd_ev_event _bsd_kbd_ev_event
-#define	kbd_find_keyboard _bsd_kbd_find_keyboard
-#define	kbd_find_keyboard2 _bsd_kbd_find_keyboard2
-#define	kbd_get_keyboard _bsd_kbd_get_keyboard
-#define	kbd_get_switch _bsd_kbd_get_switch
-#define	kbd_init_struct _bsd_kbd_init_struct
-#define	kbd_register _bsd_kbd_register
-#define	kbd_release _bsd_kbd_release
-#define	kbd_set_maps _bsd_kbd_set_maps
-#define	kbdsw _bsd_kbdsw
-#define	kbd_unregister _bsd_kbd_unregister
-#define	kdebug_ipsecrequest_level _bsd_kdebug_ipsecrequest_level
-#define	kdebug_mbuf _bsd_kdebug_mbuf
-#define	kdebug_mbufhdr _bsd_kdebug_mbufhdr
-#define	kdebug_sadb _bsd_kdebug_sadb
-#define	kdebug_sadb_x_policy _bsd_kdebug_sadb_x_policy
-#define	kdebug_secash _bsd_kdebug_secash
-#define	kdebug_secasindex _bsd_kdebug_secasindex
-#define	kdebug_secasindex_mode _bsd_kdebug_secasindex_mode
-#define	kdebug_secasv _bsd_kdebug_secasv
-#define	kdebug_secasv_state _bsd_kdebug_secasv_state
-#define	kdebug_secpolicy _bsd_kdebug_secpolicy
-#define	kdebug_secpolicyindex _bsd_kdebug_secpolicyindex
-#define	kdebug_secpolicyindex_dir _bsd_kdebug_secpolicyindex_dir
-#define	kdebug_secpolicy_policy _bsd_kdebug_secpolicy_policy
-#define	kdebug_secpolicy_state _bsd_kdebug_secpolicy_state
-#define	kdebug_sockaddr _bsd_kdebug_sockaddr
-#define	kernel_sysctl _bsd_kernel_sysctl
-#define	key_addref _bsd_key_addref
-#define	key_allocsa _bsd_key_allocsa
-#define	key_allocsa_policy _bsd_key_allocsa_policy
-#define	key_allocsa_tcpmd5 _bsd_key_allocsa_tcpmd5
-#define	key_allocsa_tunnel _bsd_key_allocsa_tunnel
-#define	key_allocsp _bsd_key_allocsp
-#define	key_bumpspgen _bsd_key_bumpspgen
-#define	key_debug_level _bsd_key_debug_level
-#define	key_delete_xform _bsd_key_delete_xform
-#define	keydomain _bsd_keydomain
-#define	key_freereg _bsd_key_freereg
-#define	key_freesav _bsd_key_freesav
-#define	key_freesp _bsd_key_freesp
-#define	key_getspgen _bsd_key_getspgen
-#define	key_havesp _bsd_key_havesp
-#define	key_init _bsd_key_init
-#define	key_msg2sp _bsd_key_msg2sp
-#define	key_newreqid _bsd_key_newreqid
-#define	key_newsp _bsd_key_newsp
-#define	key_output _bsd_key_output
-#define	key_parse _bsd_key_parse
-#define	key_portfromsaddr _bsd_key_portfromsaddr
-#define	key_porttosaddr _bsd_key_porttosaddr
-#define	key_random _bsd_key_random
-#define	key_randomfill _bsd_key_randomfill
-#define	key_register_ifnet _bsd_key_register_ifnet
-#define	key_sa_recordxfer _bsd_key_sa_recordxfer
-#define	key_sendup_mbuf _bsd_key_sendup_mbuf
-#define	key_sockaddrcmp _bsd_key_sockaddrcmp
-#define	key_sockaddrcmp_withmask _bsd_key_sockaddrcmp_withmask
-#define	key_sp2msg _bsd_key_sp2msg
-#define	key_spdacquire _bsd_key_spdacquire
-#define	keystat _bsd_keystat
-#define	keysw _bsd_keysw
-#define	key_unregister_ifnet _bsd_key_unregister_ifnet
-#define	key_usrreqs _bsd_key_usrreqs
-#define	khelp_add_hhook _bsd_khelp_add_hhook
-#define	khelp_deregister_helper _bsd_khelp_deregister_helper
-#define	khelp_destroy_osd _bsd_khelp_destroy_osd
-#define	khelp_get_id _bsd_khelp_get_id
-#define	khelp_get_osd _bsd_khelp_get_osd
-#define	khelp_init_osd _bsd_khelp_init_osd
-#define	khelp_new_hhook_registered _bsd_khelp_new_hhook_registered
-#define	khelp_register_helper _bsd_khelp_register_helper
-#define	khelp_remove_hhook _bsd_khelp_remove_hhook
-#define	kmod_icmp6stat_inc _bsd_kmod_icmp6stat_inc
-#define	kmod_icmpstat_inc _bsd_kmod_icmpstat_inc
-#define	kmod_ipstat_dec _bsd_kmod_ipstat_dec
-#define	kmod_ipstat_inc _bsd_kmod_ipstat_inc
-#define	kmod_tcpstat_inc _bsd_kmod_tcpstat_inc
-#define	kmod_udpstat_inc _bsd_kmod_udpstat_inc
-#define	knlist_add _bsd_knlist_add
-#define	knlist_alloc _bsd_knlist_alloc
-#define	knlist_cleardel _bsd_knlist_cleardel
-#define	knlist_destroy _bsd_knlist_destroy
-#define	knlist_detach _bsd_knlist_detach
-#define	knlist_empty _bsd_knlist_empty
-#define	knlist_init _bsd_knlist_init
-#define	knlist_init_mtx _bsd_knlist_init_mtx
-#define	knlist_remove _bsd_knlist_remove
-#define	knote _bsd_knote
-#define	knote_fdclose _bsd_knote_fdclose
-#define	kobj_class_compile _bsd_kobj_class_compile
-#define	kobj_class_compile_static _bsd_kobj_class_compile_static
-#define	kobj_class_free _bsd_kobj_class_free
-#define	kobj_create _bsd_kobj_create
-#define	kobj_delete _bsd_kobj_delete
-#define	kobj_error_method _bsd_kobj_error_method
-#define	kobj_init _bsd_kobj_init
-#define	kobj_init_static _bsd_kobj_init_static
-#define	kobj_lookup_method _bsd_kobj_lookup_method
-#define	kproc_create _bsd_kproc_create
-#define	kproc_exit _bsd_kproc_exit
-#define	kproc_kthread_add _bsd_kproc_kthread_add
-#define	kproc_start _bsd_kproc_start
-#define	kqfd_register _bsd_kqfd_register
-#define	kqueue_add_filteropts _bsd_kqueue_add_filteropts
-#define	kqueue_del_filteropts _bsd_kqueue_del_filteropts
-#define	kthread_add _bsd_kthread_add
-#define	kthread_exit _bsd_kthread_exit
-#define	kthread_start _bsd_kthread_start
-#define	kvprintf _bsd_kvprintf
-#define	lacp_attach _bsd_lacp_attach
-#define	lacp_detach _bsd_lacp_detach
-#define	lacp_init _bsd_lacp_init
-#define	lacp_input _bsd_lacp_input
-#define	lacp_linkstate _bsd_lacp_linkstate
-#define	lacp_port_create _bsd_lacp_port_create
-#define	lacp_port_destroy _bsd_lacp_port_destroy
-#define	lacp_portreq _bsd_lacp_portreq
-#define	lacp_req _bsd_lacp_req
-#define	lacp_select_tx_port _bsd_lacp_select_tx_port
-#define	lacp_stop _bsd_lacp_stop
-#define	lagg_detach_cookie _bsd_lagg_detach_cookie
-#define	lagg_enqueue _bsd_lagg_enqueue
-#define	lagg_input_p _bsd_lagg_input_p
-#define	lagg_linkstate_p _bsd_lagg_linkstate_p
-#define	lagg_list _bsd_lagg_list
-#define	led_create _bsd_led_create
-#define	led_create_state _bsd_led_create_state
-#define	led_destroy _bsd_led_destroy
-#define	led_set _bsd_led_set
-#define	legal_vif_num _bsd_legal_vif_num
-#define	lem_txrx _bsd_lem_txrx
-#define	le_uuid_dec _bsd_le_uuid_dec
-#define	le_uuid_enc _bsd_le_uuid_enc
-#define	LibAliasAddServer _bsd_LibAliasAddServer
-#define	LibAliasAttachHandlers _bsd_LibAliasAttachHandlers
-#define	LibAliasCheckNewLink _bsd_LibAliasCheckNewLink
-#define	LibAliasDetachHandlers _bsd_LibAliasDetachHandlers
-#define	LibAliasFragmentIn _bsd_LibAliasFragmentIn
-#define	LibAliasGetFragment _bsd_LibAliasGetFragment
-#define	LibAliasIn _bsd_LibAliasIn
-#define	LibAliasInit _bsd_LibAliasInit
-#define	LibAliasInternetChecksum _bsd_LibAliasInternetChecksum
-#define	LibAliasOut _bsd_LibAliasOut
-#define	LibAliasOutTry _bsd_LibAliasOutTry
-#define	LibAliasProxyRule _bsd_LibAliasProxyRule
-#define	LibAliasRedirectAddr _bsd_LibAliasRedirectAddr
-#define	LibAliasRedirectDelete _bsd_LibAliasRedirectDelete
-#define	LibAliasRedirectDynamic _bsd_LibAliasRedirectDynamic
-#define	LibAliasRedirectPort _bsd_LibAliasRedirectPort
-#define	LibAliasRedirectProto _bsd_LibAliasRedirectProto
-#define	LibAliasSaveFragment _bsd_LibAliasSaveFragment
-#define	LibAliasSetAddress _bsd_LibAliasSetAddress
-#define	LibAliasSetFWBase _bsd_LibAliasSetFWBase
-#define	LibAliasSetMode _bsd_LibAliasSetMode
-#define	LibAliasSetSkinnyPort _bsd_LibAliasSetSkinnyPort
-#define	LibAliasSetTarget _bsd_LibAliasSetTarget
-#define	LibAliasUnaliasOut _bsd_LibAliasUnaliasOut
-#define	LibAliasUninit _bsd_LibAliasUninit
-#define	_libmd_SHA224_Final _bsd__libmd_SHA224_Final
-#define	_libmd_SHA224_Init _bsd__libmd_SHA224_Init
-#define	_libmd_SHA224_Update _bsd__libmd_SHA224_Update
-#define	_libmd_SHA512_224_Final _bsd__libmd_SHA512_224_Final
-#define	_libmd_SHA512_224_Init _bsd__libmd_SHA512_224_Init
-#define	_libmd_SHA512_224_Update _bsd__libmd_SHA512_224_Update
-#define	_libmd_SHA512_256_Final _bsd__libmd_SHA512_256_Final
-#define	_libmd_SHA512_256_Init _bsd__libmd_SHA512_256_Init
-#define	_libmd_SHA512_256_Update _bsd__libmd_SHA512_256_Update
-#define	_libmd_SKEIN1024_Final _bsd__libmd_SKEIN1024_Final
-#define	_libmd_SKEIN1024_Init _bsd__libmd_SKEIN1024_Init
-#define	_libmd_SKEIN1024_Update _bsd__libmd_SKEIN1024_Update
-#define	_libmd_SKEIN256_Final _bsd__libmd_SKEIN256_Final
-#define	_libmd_SKEIN256_Init _bsd__libmd_SKEIN256_Init
-#define	_libmd_SKEIN256_Update _bsd__libmd_SKEIN256_Update
-#define	_libmd_SKEIN512_Final _bsd__libmd_SKEIN512_Final
-#define	_libmd_SKEIN512_Init _bsd__libmd_SKEIN512_Init
-#define	_libmd_SKEIN512_Update _bsd__libmd_SKEIN512_Update
-#define	link_alloc_sdl _bsd_link_alloc_sdl
-#define	link_free_sdl _bsd_link_free_sdl
-#define	link_init_sdl _bsd_link_init_sdl
-#define	link_pfil_head _bsd_link_pfil_head
-#define	link_pfil_hook _bsd_link_pfil_hook
-#define	lla_rt_output _bsd_lla_rt_output
-#define	llentry_alloc _bsd_llentry_alloc
-#define	llentry_free _bsd_llentry_free
-#define	lltable_allocate_htbl _bsd_lltable_allocate_htbl
-#define	lltable_alloc_entry _bsd_lltable_alloc_entry
-#define	lltable_calc_llheader _bsd_lltable_calc_llheader
-#define	lltable_delete_addr _bsd_lltable_delete_addr
-#define	lltable_drop_entry_queue _bsd_lltable_drop_entry_queue
-#define	lltable_fill_sa_entry _bsd_lltable_fill_sa_entry
-#define	lltable_foreach_lle _bsd_lltable_foreach_lle
-#define	lltable_free _bsd_lltable_free
-#define	lltable_free_entry _bsd_lltable_free_entry
-#define	lltable_get_af _bsd_lltable_get_af
-#define	lltable_get_ifp _bsd_lltable_get_ifp
-#define	lltable_link _bsd_lltable_link
-#define	lltable_link_entry _bsd_lltable_link_entry
-#define	lltable_prefix_free _bsd_lltable_prefix_free
-#define	lltable_set_entry_addr _bsd_lltable_set_entry_addr
-#define	lltable_sysctl_dumparp _bsd_lltable_sysctl_dumparp
-#define	lltable_try_set_entry_addr _bsd_lltable_try_set_entry_addr
-#define	lltable_unlink_entry _bsd_lltable_unlink_entry
-#define	lltable_update_ifaddr _bsd_lltable_update_ifaddr
-#define	lock_classes _bsd_lock_classes
-#define	lock_class_mtx_sleep _bsd_lock_class_mtx_sleep
-#define	lock_class_mtx_spin _bsd_lock_class_mtx_spin
-#define	lock_class_rw _bsd_lock_class_rw
-#define	lock_class_sx _bsd_lock_class_sx
-#define	lock_destroy _bsd_lock_destroy
-#define	lock_init _bsd_lock_init
-#define	log _bsd_log
-#define	loif _bsd_loif
-#define	loioctl _bsd_loioctl
-#define	looutput _bsd_looutput
-#define	lpc_pwr_read _bsd_lpc_pwr_read
-#define	lpc_pwr_write _bsd_lpc_pwr_write
-#define	M_80211_CRYPTO _bsd_M_80211_CRYPTO
-#define	M_80211_MESH_GT_RT _bsd_M_80211_MESH_GT_RT
-#define	M_80211_MESH_PERR _bsd_M_80211_MESH_PERR
-#define	M_80211_MESH_PREP _bsd_M_80211_MESH_PREP
-#define	M_80211_MESH_PREQ _bsd_M_80211_MESH_PREQ
-#define	M_80211_MESH_RT _bsd_M_80211_MESH_RT
-#define	M_80211_NODE _bsd_M_80211_NODE
-#define	M_80211_NODE_IE _bsd_M_80211_NODE_IE
-#define	M_80211_RATECTL _bsd_M_80211_RATECTL
-#define	M_80211_SCAN _bsd_M_80211_SCAN
-#define	M_80211_VAP _bsd_M_80211_VAP
-#define	M_ACCF _bsd_M_ACCF
-#define	machclk_freq _bsd_machclk_freq
-#define	machclk_per_tick _bsd_machclk_per_tick
-#define	machclk_usepcc _bsd_machclk_usepcc
-#define	m_adj _bsd_m_adj
-#define	make_dev _bsd_make_dev
-#define	make_dev_alias _bsd_make_dev_alias
-#define	make_dev_args_init_impl _bsd_make_dev_args_init_impl
-#define	make_dev_s _bsd_make_dev_s
-#define	M_ALIAS _bsd_M_ALIAS
-#define	mallocarray _bsd_mallocarray
-#define	malloc_init _bsd_malloc_init
-#define	malloc_uninit _bsd_malloc_uninit
-#define	m_append _bsd_m_append
-#define	m_apply _bsd_m_apply
-#define	maxpipekva _bsd_maxpipekva
-#define	mb_dupcl _bsd_mb_dupcl
-#define	mb_free_ext _bsd_mb_free_ext
-#define	mb_free_notready _bsd_mb_free_notready
-#define	M_BPF _bsd_M_BPF
-#define	M_BPFJIT _bsd_M_BPFJIT
-#define	mb_use_ext_pgs _bsd_mb_use_ext_pgs
-#define	M_CAMSIM _bsd_M_CAMSIM
-#define	m_cat _bsd_m_cat
-#define	m_catpkt _bsd_m_catpkt
-#define	m_checkalignment _bsd_m_checkalignment
-#define	m_clget _bsd_m_clget
-#define	m_cljget _bsd_m_cljget
-#define	m_collapse _bsd_m_collapse
-#define	m_copyback _bsd_m_copyback
-#define	m_copydata _bsd_m_copydata
-#define	m_copym _bsd_m_copym
-#define	m_copypacket _bsd_m_copypacket
-#define	m_copyup _bsd_m_copyup
-#define	M_CRYPTO_DATA _bsd_M_CRYPTO_DATA
-#define	m_defrag _bsd_m_defrag
-#define	m_demote _bsd_m_demote
-#define	m_demote_pkthdr _bsd_m_demote_pkthdr
-#define	M_DEVBUF _bsd_M_DEVBUF
-#define	m_devget _bsd_m_devget
-#define	m_dispose_extcontrolm _bsd_m_dispose_extcontrolm
-#define	m_dup _bsd_m_dup
-#define	m_dup_pkthdr _bsd_m_dup_pkthdr
-#define	mesh_airtime_calc _bsd_mesh_airtime_calc
-#define	m_ether_tcpip_hash _bsd_m_ether_tcpip_hash
-#define	m_ether_tcpip_hash_init _bsd_m_ether_tcpip_hash_init
-#define	M_EVDEV _bsd_M_EVDEV
-#define	m_extadd _bsd_m_extadd
-#define	m_fixhdr _bsd_m_fixhdr
-#define	m_freem _bsd_m_freem
-#define	m_get2 _bsd_m_get2
-#define	m_getjcl _bsd_m_getjcl
-#define	m_getm2 _bsd_m_getm2
-#define	m_getptr _bsd_m_getptr
-#define	M_GIF _bsd_M_GIF
-#define	M_GRE _bsd_M_GRE
-#define	mgt_subtype_name _bsd_mgt_subtype_name
-#define	M_IFADDR _bsd_M_IFADDR
-#define	M_IFMADDR _bsd_M_IFMADDR
-#define	mii_attach _bsd_mii_attach
-#define	mii_bitbang_readreg _bsd_mii_bitbang_readreg
-#define	mii_bitbang_sync _bsd_mii_bitbang_sync
-#define	mii_bitbang_writereg _bsd_mii_bitbang_writereg
-#define	miibus_devclass _bsd_miibus_devclass
-#define	miibus_driver _bsd_miibus_driver
-#define	mii_dev_mac_match _bsd_mii_dev_mac_match
-#define	mii_dev_mac_softc _bsd_mii_dev_mac_softc
-#define	mii_fdt_contype_from_name _bsd_mii_fdt_contype_from_name
-#define	mii_fdt_contype_to_name _bsd_mii_fdt_contype_to_name
-#define	mii_fdt_free_config _bsd_mii_fdt_free_config
-#define	mii_fdt_get_config _bsd_mii_fdt_get_config
-#define	mii_fdt_get_contype _bsd_mii_fdt_get_contype
-#define	mii_mediachg _bsd_mii_mediachg
-#define	mii_oui _bsd_mii_oui
-#define	mii_phy_add_media _bsd_mii_phy_add_media
-#define	mii_phy_auto _bsd_mii_phy_auto
-#define	mii_phy_detach _bsd_mii_phy_detach
-#define	mii_phy_dev_attach _bsd_mii_phy_dev_attach
-#define	mii_phy_dev_probe _bsd_mii_phy_dev_probe
-#define	mii_phy_flowstatus _bsd_mii_phy_flowstatus
-#define	mii_phy_mac_match _bsd_mii_phy_mac_match
-#define	mii_phy_mac_softc _bsd_mii_phy_mac_softc
-#define	mii_phy_match _bsd_mii_phy_match
-#define	mii_phy_match_gen _bsd_mii_phy_match_gen
-#define	mii_phy_reset _bsd_mii_phy_reset
-#define	mii_phy_setmedia _bsd_mii_phy_setmedia
-#define	mii_phy_tick _bsd_mii_phy_tick
-#define	mii_phy_update _bsd_mii_phy_update
-#define	mii_pollstat _bsd_mii_pollstat
-#define	mii_tick _bsd_mii_tick
-#define	M_IOV _bsd_M_IOV
-#define	M_IP6MADDR _bsd_M_IP6MADDR
-#define	M_IP6NDP _bsd_M_IP6NDP
-#define	M_IPSEC_INPCB _bsd_M_IPSEC_INPCB
-#define	M_IPSEC_MISC _bsd_M_IPSEC_MISC
-#define	M_IPSEC_SA _bsd_M_IPSEC_SA
-#define	M_IPSEC_SAH _bsd_M_IPSEC_SAH
-#define	M_IPSEC_SAQ _bsd_M_IPSEC_SAQ
-#define	M_IPSEC_SAR _bsd_M_IPSEC_SAR
-#define	M_IPSEC_SP _bsd_M_IPSEC_SP
-#define	M_IPSEC_SPDCACHE _bsd_M_IPSEC_SPDCACHE
-#define	M_IPSEC_SR _bsd_M_IPSEC_SR
-#define	mi_startup _bsd_mi_startup
-#define	mld_change_state _bsd_mld_change_state
-#define	mld_domifattach _bsd_mld_domifattach
-#define	mld_domifdetach _bsd_mld_domifdetach
-#define	mld_fasttimo _bsd_mld_fasttimo
-#define	mld_ifdetach _bsd_mld_ifdetach
-#define	mld_input _bsd_mld_input
-#define	mld_slowtimo _bsd_mld_slowtimo
-#define	m_length _bsd_m_length
-#define	M_LLTABLE _bsd_M_LLTABLE
-#define	m_makespace _bsd_m_makespace
-#define	m_mbuftouio _bsd_m_mbuftouio
-#define	mmc_devclass _bsd_mmc_devclass
-#define	mmc_driver _bsd_mmc_driver
-#define	mmc_send_ext_csd _bsd_mmc_send_ext_csd
-#define	mmc_send_status _bsd_mmc_send_status
-#define	mmc_switch _bsd_mmc_switch
-#define	mmc_switch_status _bsd_mmc_switch_status
-#define	mmc_wait_for_app_cmd _bsd_mmc_wait_for_app_cmd
-#define	mmc_wait_for_cmd _bsd_mmc_wait_for_cmd
-#define	m_megapullup _bsd_m_megapullup
-#define	m_move_pkthdr _bsd_m_move_pkthdr
-#define	M_NVME _bsd_M_NVME
-#define	module_lookupbyname _bsd_module_lookupbyname
-#define	module_register _bsd_module_register
-#define	module_register_init _bsd_module_register_init
-#define	module_release _bsd_module_release
-#define	modules_sx _bsd_modules_sx
-#define	M_OFWPROP _bsd_M_OFWPROP
-#define	m_pad _bsd_m_pad
-#define	M_PCB _bsd_M_PCB
-#define	M_PFHASH _bsd_M_PFHASH
-#define	m_pkthdr_init _bsd_m_pkthdr_init
-#define	m_prepend _bsd_m_prepend
-#define	m_print _bsd_m_print
-#define	m_pulldown _bsd_m_pulldown
-#define	m_pullup _bsd_m_pullup
-#define	m_raopt _bsd_m_raopt
-#define	mrt6_ioctl _bsd_mrt6_ioctl
-#define	M_RTABLE _bsd_M_RTABLE
-#define	mrt_ioctl _bsd_mrt_ioctl
-#define	M_RTWN_PRIV _bsd_M_RTWN_PRIV
-#define	m_sanity _bsd_m_sanity
-#define	m_snd_tag_destroy _bsd_m_snd_tag_destroy
-#define	m_snd_tag_init _bsd_m_snd_tag_init
-#define	M_SONAME _bsd_M_SONAME
-#define	m_split _bsd_m_split
-#define	m_striphdr _bsd_m_striphdr
-#define	m_tag_alloc _bsd_m_tag_alloc
-#define	m_tag_copy _bsd_m_tag_copy
-#define	m_tag_copy_chain _bsd_m_tag_copy_chain
-#define	m_tag_delete _bsd_m_tag_delete
-#define	m_tag_delete_chain _bsd_m_tag_delete_chain
-#define	m_tag_delete_nonpersistent _bsd_m_tag_delete_nonpersistent
-#define	m_tag_free_default _bsd_m_tag_free_default
-#define	m_tag_locate _bsd_m_tag_locate
-#define	M_TAP _bsd_M_TAP
-#define	M_TCPFUNCTIONS _bsd_M_TCPFUNCTIONS
-#define	M_TCPLOG _bsd_M_TCPLOG
-#define	M_TEMP _bsd_M_TEMP
-#define	mtrash_ctor _bsd_mtrash_ctor
-#define	mtrash_dtor _bsd_mtrash_dtor
-#define	mtrash_fini _bsd_mtrash_fini
-#define	mtrash_init _bsd_mtrash_init
-#define	mtx_destroy _bsd_mtx_destroy
-#define	mtx_init _bsd_mtx_init
-#define	_mtx_lock_flags _bsd__mtx_lock_flags
-#define	mtx_owned _bsd_mtx_owned
-#define	mtx_pool_alloc _bsd_mtx_pool_alloc
-#define	mtx_pool_create _bsd_mtx_pool_create
-#define	mtx_pool_destroy _bsd_mtx_pool_destroy
-#define	mtx_pool_find _bsd_mtx_pool_find
-#define	mtxpool_sleep _bsd_mtxpool_sleep
-#define	mtx_recursed _bsd_mtx_recursed
-#define	mtx_sysinit _bsd_mtx_sysinit
-#define	mtx_trylock_flags_ _bsd_mtx_trylock_flags_
-#define	_mtx_unlock_flags _bsd__mtx_unlock_flags
-#define	m_uiotombuf _bsd_m_uiotombuf
-#define	m_unmappedtouio _bsd_m_unmappedtouio
-#define	m_unshare _bsd_m_unshare
-#define	murmur3_32_hash _bsd_murmur3_32_hash
-#define	murmur3_32_hash32 _bsd_murmur3_32_hash32
-#define	M_USB _bsd_M_USB
-#define	M_USBDEV _bsd_M_USBDEV
-#define	musbotg_connect_interrupt _bsd_musbotg_connect_interrupt
-#define	musbotg_init _bsd_musbotg_init
-#define	musbotg_interrupt _bsd_musbotg_interrupt
-#define	musbotg_uninit _bsd_musbotg_uninit
-#define	musbotg_vbus_interrupt _bsd_musbotg_vbus_interrupt
-#define	mutex_init _bsd_mutex_init
-#define	M_XDATA _bsd_M_XDATA
-#define	natt_cksum_policy _bsd_natt_cksum_policy
-#define	nd6_add_ifa_lle _bsd_nd6_add_ifa_lle
-#define	nd6_alloc _bsd_nd6_alloc
-#define	nd6_cache_lladdr _bsd_nd6_cache_lladdr
-#define	nd6_dad_init _bsd_nd6_dad_init
-#define	nd6_dad_start _bsd_nd6_dad_start
-#define	nd6_dad_stop _bsd_nd6_dad_stop
-#define	nd6_defifindex _bsd_nd6_defifindex
-#define	nd6_defrouter_flush_all _bsd_nd6_defrouter_flush_all
-#define	nd6_defrouter_init _bsd_nd6_defrouter_init
-#define	nd6_defrouter_list_empty _bsd_nd6_defrouter_list_empty
-#define	nd6_defrouter_purge _bsd_nd6_defrouter_purge
-#define	nd6_defrouter_timer _bsd_nd6_defrouter_timer
-#define	nd6_flush_holdchain _bsd_nd6_flush_holdchain
-#define	nd6_grab_holdchain _bsd_nd6_grab_holdchain
-#define	nd6_ifattach _bsd_nd6_ifattach
-#define	nd6_ifdetach _bsd_nd6_ifdetach
-#define	nd6_ifnet_link_event _bsd_nd6_ifnet_link_event
-#define	nd6_ifptomac _bsd_nd6_ifptomac
-#define	nd6_init _bsd_nd6_init
-#define	nd6_ioctl _bsd_nd6_ioctl
-#define	nd6_is_addr_neighbor _bsd_nd6_is_addr_neighbor
-#define	nd6_list_genid _bsd_nd6_list_genid
-#define	nd6_llinfo_setstate _bsd_nd6_llinfo_setstate
-#define	nd6_lock _bsd_nd6_lock
-#define	nd6_lookup _bsd_nd6_lookup
-#define	nd6_na_input _bsd_nd6_na_input
-#define	nd6_na_output _bsd_nd6_na_output
-#define	nd6_ns_input _bsd_nd6_ns_input
-#define	nd6_ns_output _bsd_nd6_ns_output
-#define	nd6_onlink_mtx _bsd_nd6_onlink_mtx
-#define	nd6_option _bsd_nd6_option
-#define	nd6_option_init _bsd_nd6_option_init
-#define	nd6_options _bsd_nd6_options
-#define	nd6_output_ifp _bsd_nd6_output_ifp
-#define	nd6_prefix_del _bsd_nd6_prefix_del
-#define	nd6_prefix_lookup _bsd_nd6_prefix_lookup
-#define	nd6_prefix_offlink _bsd_nd6_prefix_offlink
-#define	nd6_prefix_onlink _bsd_nd6_prefix_onlink
-#define	nd6_prefix_ref _bsd_nd6_prefix_ref
-#define	nd6_prefix_rele _bsd_nd6_prefix_rele
-#define	nd6_prefix_unlink _bsd_nd6_prefix_unlink
-#define	nd6_prelist_add _bsd_nd6_prelist_add
-#define	nd6_purge _bsd_nd6_purge
-#define	nd6_ra_input _bsd_nd6_ra_input
-#define	nd6_recalc_reachtm_interval _bsd_nd6_recalc_reachtm_interval
-#define	nd6_rem_ifa_lle _bsd_nd6_rem_ifa_lle
-#define	nd6_resolve _bsd_nd6_resolve
-#define	nd6_resolve_addr _bsd_nd6_resolve_addr
-#define	nd6_rs_input _bsd_nd6_rs_input
-#define	nd6_setdefaultiface _bsd_nd6_setdefaultiface
-#define	nd6_setmtu _bsd_nd6_setmtu
-#define	nd6_timer _bsd_nd6_timer
-#define	nd6_timer_ch _bsd_nd6_timer_ch
-#define	nd_defrouter _bsd_nd_defrouter
-#define	nd_prefix _bsd_nd_prefix
-#define	netisr_clearqdrops _bsd_netisr_clearqdrops
-#define	netisr_dispatch _bsd_netisr_dispatch
-#define	netisr_dispatch_src _bsd_netisr_dispatch_src
-#define	netisr_getqdrops _bsd_netisr_getqdrops
-#define	netisr_getqlimit _bsd_netisr_getqlimit
-#define	netisr_queue _bsd_netisr_queue
-#define	netisr_queue_src _bsd_netisr_queue_src
-#define	netisr_register _bsd_netisr_register
-#define	netisr_setqlimit _bsd_netisr_setqlimit
-#define	netisr_unregister _bsd_netisr_unregister
-#define	newpacket _bsd_newpacket
-#define	newreno_cc_algo _bsd_newreno_cc_algo
-#define	new_unrhdr _bsd_new_unrhdr
-#define	ng_ether_attach_p _bsd_ng_ether_attach_p
-#define	ng_ether_detach_p _bsd_ng_ether_detach_p
-#define	ng_ether_input_orphan_p _bsd_ng_ether_input_orphan_p
-#define	ng_ether_input_p _bsd_ng_ether_input_p
-#define	ng_ether_link_state_p _bsd_ng_ether_link_state_p
-#define	ng_ether_output_p _bsd_ng_ether_output_p
-#define	ng_gif_attach_p _bsd_ng_gif_attach_p
-#define	ng_gif_detach_p _bsd_ng_gif_detach_p
-#define	ng_gif_input_orphan_p _bsd_ng_gif_input_orphan_p
-#define	ng_gif_input_p _bsd_ng_gif_input_p
-#define	ng_ipfw_input_p _bsd_ng_ipfw_input_p
-#define	nousrreqs _bsd_nousrreqs
-#define	null_class _bsd_null_class
-#define	null_filtops _bsd_null_filtops
-#define	nullop _bsd_nullop
-#define	nvme_admin_qpair_destroy _bsd_nvme_admin_qpair_destroy
-#define	nvme_admin_qpair_disable _bsd_nvme_admin_qpair_disable
-#define	nvme_admin_qpair_enable _bsd_nvme_admin_qpair_enable
-#define	nvme_attach _bsd_nvme_attach
-#define	nvme_completion_poll_cb _bsd_nvme_completion_poll_cb
-#define	nvme_consumer _bsd_nvme_consumer
-#define	nvme_ctrlr_cmd_abort _bsd_nvme_ctrlr_cmd_abort
-#define	nvme_ctrlr_cmd_create_io_cq _bsd_nvme_ctrlr_cmd_create_io_cq
-#define	nvme_ctrlr_cmd_create_io_sq _bsd_nvme_ctrlr_cmd_create_io_sq
-#define	nvme_ctrlr_cmd_delete_io_cq _bsd_nvme_ctrlr_cmd_delete_io_cq
-#define	nvme_ctrlr_cmd_delete_io_sq _bsd_nvme_ctrlr_cmd_delete_io_sq
-#define	nvme_ctrlr_cmd_get_error_page _bsd_nvme_ctrlr_cmd_get_error_page
-#define	nvme_ctrlr_cmd_get_feature _bsd_nvme_ctrlr_cmd_get_feature
-#define	nvme_ctrlr_cmd_get_firmware_page _bsd_nvme_ctrlr_cmd_get_firmware_page
-#define	nvme_ctrlr_cmd_get_health_information_page _bsd_nvme_ctrlr_cmd_get_health_information_page
-#define	nvme_ctrlr_cmd_get_log_page _bsd_nvme_ctrlr_cmd_get_log_page
-#define	nvme_ctrlr_cmd_identify_controller _bsd_nvme_ctrlr_cmd_identify_controller
-#define	nvme_ctrlr_cmd_identify_namespace _bsd_nvme_ctrlr_cmd_identify_namespace
-#define	nvme_ctrlr_cmd_set_async_event_config _bsd_nvme_ctrlr_cmd_set_async_event_config
-#define	nvme_ctrlr_cmd_set_feature _bsd_nvme_ctrlr_cmd_set_feature
-#define	nvme_ctrlr_cmd_set_interrupt_coalescing _bsd_nvme_ctrlr_cmd_set_interrupt_coalescing
-#define	nvme_ctrlr_cmd_set_num_queues _bsd_nvme_ctrlr_cmd_set_num_queues
-#define	nvme_ctrlr_construct _bsd_nvme_ctrlr_construct
-#define	nvme_ctrlr_destruct _bsd_nvme_ctrlr_destruct
-#define	nvme_ctrlr_get_data _bsd_nvme_ctrlr_get_data
-#define	nvme_ctrlr_get_device _bsd_nvme_ctrlr_get_device
-#define	nvme_ctrlr_hw_reset _bsd_nvme_ctrlr_hw_reset
-#define	nvme_ctrlr_intx_handler _bsd_nvme_ctrlr_intx_handler
-#define	nvme_ctrlr_passthrough_cmd _bsd_nvme_ctrlr_passthrough_cmd
-#define	nvme_ctrlr_poll _bsd_nvme_ctrlr_poll
-#define	nvme_ctrlr_post_failed_request _bsd_nvme_ctrlr_post_failed_request
-#define	nvme_ctrlr_reset _bsd_nvme_ctrlr_reset
-#define	nvme_ctrlr_resume _bsd_nvme_ctrlr_resume
-#define	nvme_ctrlr_shutdown _bsd_nvme_ctrlr_shutdown
-#define	nvme_ctrlr_start_config_hook _bsd_nvme_ctrlr_start_config_hook
-#define	nvme_ctrlr_submit_admin_request _bsd_nvme_ctrlr_submit_admin_request
-#define	nvme_ctrlr_submit_io_request _bsd_nvme_ctrlr_submit_io_request
-#define	nvme_ctrlr_suspend _bsd_nvme_ctrlr_suspend
-#define	nvme_detach _bsd_nvme_detach
-#define	nvme_devclass _bsd_nvme_devclass
-#define	nvme_dump_command _bsd_nvme_dump_command
-#define	nvme_dump_completion _bsd_nvme_dump_completion
-#define	nvme_io_qpair_destroy _bsd_nvme_io_qpair_destroy
-#define	nvme_io_qpair_disable _bsd_nvme_io_qpair_disable
-#define	nvme_io_qpair_enable _bsd_nvme_io_qpair_enable
-#define	nvme_notify_async_consumers _bsd_nvme_notify_async_consumers
-#define	nvme_notify_fail_consumers _bsd_nvme_notify_fail_consumers
-#define	nvme_notify_new_controller _bsd_nvme_notify_new_controller
-#define	nvme_notify_ns _bsd_nvme_notify_ns
-#define	nvme_ns_cmd_deallocate _bsd_nvme_ns_cmd_deallocate
-#define	nvme_ns_cmd_flush _bsd_nvme_ns_cmd_flush
-#define	nvme_ns_cmd_read _bsd_nvme_ns_cmd_read
-#define	nvme_ns_cmd_read_iov _bsd_nvme_ns_cmd_read_iov
-#define	nvme_ns_cmd_write _bsd_nvme_ns_cmd_write
-#define	nvme_ns_cmd_write_iov _bsd_nvme_ns_cmd_write_iov
-#define	nvme_ns_construct _bsd_nvme_ns_construct
-#define	nvme_ns_destruct _bsd_nvme_ns_destruct
-#define	nvme_ns_dump _bsd_nvme_ns_dump
-#define	nvme_ns_get_data _bsd_nvme_ns_get_data
-#define	nvme_ns_get_flags _bsd_nvme_ns_get_flags
-#define	nvme_ns_get_max_io_xfer_size _bsd_nvme_ns_get_max_io_xfer_size
-#define	nvme_ns_get_model_number _bsd_nvme_ns_get_model_number
-#define	nvme_ns_get_num_sectors _bsd_nvme_ns_get_num_sectors
-#define	nvme_ns_get_sector_size _bsd_nvme_ns_get_sector_size
-#define	nvme_ns_get_serial_number _bsd_nvme_ns_get_serial_number
-#define	nvme_ns_get_size _bsd_nvme_ns_get_size
-#define	nvme_ns_get_stripesize _bsd_nvme_ns_get_stripesize
-#define	nvme_ns_ioctl_process _bsd_nvme_ns_ioctl_process
-#define	nvme_qpair_construct _bsd_nvme_qpair_construct
-#define	nvme_qpair_fail _bsd_nvme_qpair_fail
-#define	nvme_qpair_manual_complete_request _bsd_nvme_qpair_manual_complete_request
-#define	nvme_qpair_process_completions _bsd_nvme_qpair_process_completions
-#define	nvme_qpair_reset _bsd_nvme_qpair_reset
-#define	nvme_qpair_submit_request _bsd_nvme_qpair_submit_request
-#define	nvme_qpair_submit_tracker _bsd_nvme_qpair_submit_tracker
-#define	nvme_register_consumer _bsd_nvme_register_consumer
-#define	nvme_request_zone _bsd_nvme_request_zone
-#define	nvme_retry_count _bsd_nvme_retry_count
-#define	nvme_shutdown _bsd_nvme_shutdown
-#define	nvme_sysctl_initialize_ctrlr _bsd_nvme_sysctl_initialize_ctrlr
-#define	nvme_unregister_consumer _bsd_nvme_unregister_consumer
-#define	nvme_use_nvd _bsd_nvme_use_nvd
-#define	nvme_verbose_cmd_dump _bsd_nvme_verbose_cmd_dump
-#define	OF_call_method _bsd_OF_call_method
-#define	OF_canon _bsd_OF_canon
-#define	OF_child _bsd_OF_child
-#define	OF_claim _bsd_OF_claim
-#define	OF_close _bsd_OF_close
-#define	OF_device_from_xref _bsd_OF_device_from_xref
-#define	OF_device_register_xref _bsd_OF_device_register_xref
-#define	OF_enter _bsd_OF_enter
-#define	OF_exit _bsd_OF_exit
-#define	OF_finddevice _bsd_OF_finddevice
-#define	OF_getencprop _bsd_OF_getencprop
-#define	OF_getencprop_alloc _bsd_OF_getencprop_alloc
-#define	OF_getencprop_alloc_multi _bsd_OF_getencprop_alloc_multi
-#define	OF_getprop _bsd_OF_getprop
-#define	OF_getprop_alloc _bsd_OF_getprop_alloc
-#define	OF_getprop_alloc_multi _bsd_OF_getprop_alloc_multi
-#define	OF_getproplen _bsd_OF_getproplen
-#define	OF_hasprop _bsd_OF_hasprop
-#define	OF_init _bsd_OF_init
-#define	OF_install _bsd_OF_install
-#define	OF_instance_to_package _bsd_OF_instance_to_package
-#define	OF_instance_to_path _bsd_OF_instance_to_path
-#define	OF_interpret _bsd_OF_interpret
-#define	OF_nextprop _bsd_OF_nextprop
-#define	OF_node_from_xref _bsd_OF_node_from_xref
-#define	OF_open _bsd_OF_open
-#define	OF_package_to_path _bsd_OF_package_to_path
-#define	OF_parent _bsd_OF_parent
-#define	OF_peer _bsd_OF_peer
-#define	OF_printf _bsd_OF_printf
-#define	OF_prop_free _bsd_OF_prop_free
-#define	OF_read _bsd_OF_read
-#define	OF_release _bsd_OF_release
-#define	OF_searchencprop _bsd_OF_searchencprop
-#define	OF_searchprop _bsd_OF_searchprop
-#define	OF_seek _bsd_OF_seek
-#define	OF_setprop _bsd_OF_setprop
-#define	OF_test _bsd_OF_test
-#define	ofw_bus_assigned_addresses_to_rl _bsd_ofw_bus_assigned_addresses_to_rl
-#define	ofwbus_driver _bsd_ofwbus_driver
-#define	ofw_bus_find_child _bsd_ofw_bus_find_child
-#define	ofw_bus_find_child_device_by_phandle _bsd_ofw_bus_find_child_device_by_phandle
-#define	ofw_bus_find_compatible _bsd_ofw_bus_find_compatible
-#define	ofw_bus_find_iparent _bsd_ofw_bus_find_iparent
-#define	ofw_bus_find_string_index _bsd_ofw_bus_find_string_index
-#define	ofw_bus_gen_child_pnpinfo_str _bsd_ofw_bus_gen_child_pnpinfo_str
-#define	ofw_bus_gen_destroy_devinfo _bsd_ofw_bus_gen_destroy_devinfo
-#define	ofw_bus_gen_get_compat _bsd_ofw_bus_gen_get_compat
-#define	ofw_bus_gen_get_model _bsd_ofw_bus_gen_get_model
-#define	ofw_bus_gen_get_name _bsd_ofw_bus_gen_get_name
-#define	ofw_bus_gen_get_node _bsd_ofw_bus_gen_get_node
-#define	ofw_bus_gen_get_type _bsd_ofw_bus_gen_get_type
-#define	ofw_bus_gen_setup_devinfo _bsd_ofw_bus_gen_setup_devinfo
-#define	ofw_bus_get_status _bsd_ofw_bus_get_status
-#define	ofw_bus_has_prop _bsd_ofw_bus_has_prop
-#define	ofw_bus_intr_by_rid _bsd_ofw_bus_intr_by_rid
-#define	ofw_bus_intr_to_rl _bsd_ofw_bus_intr_to_rl
-#define	ofw_bus_is_compatible _bsd_ofw_bus_is_compatible
-#define	ofw_bus_is_compatible_strict _bsd_ofw_bus_is_compatible_strict
-#define	ofw_bus_lookup_imap _bsd_ofw_bus_lookup_imap
-#define	ofw_bus_msimap _bsd_ofw_bus_msimap
-#define	ofw_bus_node_is_compatible _bsd_ofw_bus_node_is_compatible
-#define	ofw_bus_node_status_okay _bsd_ofw_bus_node_status_okay
-#define	ofw_bus_parse_xref_list_alloc _bsd_ofw_bus_parse_xref_list_alloc
-#define	ofw_bus_parse_xref_list_get_length _bsd_ofw_bus_parse_xref_list_get_length
-#define	ofw_bus_reg_to_rl _bsd_ofw_bus_reg_to_rl
-#define	ofw_bus_search_compatible _bsd_ofw_bus_search_compatible
-#define	ofw_bus_search_intrmap _bsd_ofw_bus_search_intrmap
-#define	ofw_bus_setup_iinfo _bsd_ofw_bus_setup_iinfo
-#define	ofw_bus_status_okay _bsd_ofw_bus_status_okay
-#define	ofw_bus_string_list_to_array _bsd_ofw_bus_string_list_to_array
-#define	ofw_fdt _bsd_ofw_fdt
-#define	ofw_gpiobus_add_fdt_child _bsd_ofw_gpiobus_add_fdt_child
-#define	ofwgpiobus_devclass _bsd_ofwgpiobus_devclass
-#define	ofw_gpiobus_driver _bsd_ofw_gpiobus_driver
-#define	ofw_gpiobus_parse_gpios _bsd_ofw_gpiobus_parse_gpios
-#define	ofw_gpiobus_register_provider _bsd_ofw_gpiobus_register_provider
-#define	ofw_gpiobus_unregister_provider _bsd_ofw_gpiobus_unregister_provider
-#define	ofw_iicbus_devclass _bsd_ofw_iicbus_devclass
-#define	ofw_iicbus_driver _bsd_ofw_iicbus_driver
-#define	ofw_parse_bootargs _bsd_ofw_parse_bootargs
-#define	ofw_reg_to_paddr _bsd_ofw_reg_to_paddr
-#define	OF_write _bsd_OF_write
-#define	OF_xref_from_device _bsd_OF_xref_from_device
-#define	OF_xref_from_node _bsd_OF_xref_from_node
-#define	ohci_detach _bsd_ohci_detach
-#define	ohci_init _bsd_ohci_init
-#define	ohci_interrupt _bsd_ohci_interrupt
-#define	ohci_iterate_hw_softc _bsd_ohci_iterate_hw_softc
-#define	osd_call _bsd_osd_call
-#define	osd_del _bsd_osd_del
-#define	osd_deregister _bsd_osd_deregister
-#define	osd_exit _bsd_osd_exit
-#define	osd_free_reserved _bsd_osd_free_reserved
-#define	osd_get _bsd_osd_get
-#define	osdm _bsd_osdm
-#define	osd_register _bsd_osd_register
-#define	osd_reserve _bsd_osd_reserve
-#define	osd_set _bsd_osd_set
-#define	osd_set_reserved _bsd_osd_set_reserved
-#define	panic _bsd_panic
-#define	parse_uuid _bsd_parse_uuid
-#define	pause_sbt _bsd_pause_sbt
-#define	pci_activate_resource _bsd_pci_activate_resource
-#define	pci_add_bar _bsd_pci_add_bar
-#define	pci_add_child _bsd_pci_add_child
-#define	pci_add_children _bsd_pci_add_children
-#define	pci_add_resources _bsd_pci_add_resources
-#define	pci_add_resources_ea _bsd_pci_add_resources_ea
-#define	pci_alloc_devinfo_method _bsd_pci_alloc_devinfo_method
-#define	pci_alloc_msi_method _bsd_pci_alloc_msi_method
-#define	pci_alloc_msix_method _bsd_pci_alloc_msix_method
-#define	pci_alloc_multi_resource _bsd_pci_alloc_multi_resource
-#define	pci_alloc_resource _bsd_pci_alloc_resource
-#define	pci_assign_interrupt_method _bsd_pci_assign_interrupt_method
-#define	pci_attach _bsd_pci_attach
-#define	pci_attach_common _bsd_pci_attach_common
-#define	pcib_alloc_msi _bsd_pcib_alloc_msi
-#define	pcib_alloc_msix _bsd_pcib_alloc_msix
-#define	pcib_alloc_resource _bsd_pcib_alloc_resource
-#define	pci_bar_enabled _bsd_pci_bar_enabled
-#define	pcib_attach _bsd_pcib_attach
-#define	pcib_attach_child _bsd_pcib_attach_child
-#define	pcib_attach_common _bsd_pcib_attach_common
-#define	pcib_bridge_init _bsd_pcib_bridge_init
-#define	pcib_child_present _bsd_pcib_child_present
-#define	pcib_decode_rid _bsd_pcib_decode_rid
-#define	pcib_detach _bsd_pcib_detach
-#define	pcib_driver _bsd_pcib_driver
-#define	pcib_get_id _bsd_pcib_get_id
-#define	pcibios_pcib_route_interrupt _bsd_pcibios_pcib_route_interrupt
-#define	pcib_map_msi _bsd_pcib_map_msi
-#define	pcib_maxfuncs _bsd_pcib_maxfuncs
-#define	pcib_maxslots _bsd_pcib_maxslots
-#define	pcib_read_ivar _bsd_pcib_read_ivar
-#define	pcib_release_msi _bsd_pcib_release_msi
-#define	pcib_release_msix _bsd_pcib_release_msix
-#define	pcib_request_feature _bsd_pcib_request_feature
-#define	pcib_request_feature_allow _bsd_pcib_request_feature_allow
-#define	pcib_route_interrupt _bsd_pcib_route_interrupt
-#define	pcib_write_ivar _bsd_pcib_write_ivar
-#define	pcicdev _bsd_pcicdev
-#define	pci_cfgregopen _bsd_pci_cfgregopen
-#define	pci_cfgregread _bsd_pci_cfgregread
-#define	pci_cfgregwrite _bsd_pci_cfgregwrite
-#define	pci_cfg_restore _bsd_pci_cfg_restore
-#define	pci_cfg_save _bsd_pci_cfg_save
-#define	pci_child_added_method _bsd_pci_child_added_method
-#define	pci_child_deleted _bsd_pci_child_deleted
-#define	pci_child_detached _bsd_pci_child_detached
-#define	pci_child_location_str_method _bsd_pci_child_location_str_method
-#define	pci_child_pnpinfo_str_method _bsd_pci_child_pnpinfo_str_method
-#define	pci_deactivate_resource _bsd_pci_deactivate_resource
-#define	pci_delete_resource _bsd_pci_delete_resource
-#define	pci_detach _bsd_pci_detach
-#define	pci_devq _bsd_pci_devq
-#define	pci_disable_busmaster_method _bsd_pci_disable_busmaster_method
-#define	pci_disable_io_method _bsd_pci_disable_io_method
-#define	pci_disable_msi_method _bsd_pci_disable_msi_method
-#define	pci_do_power_resume _bsd_pci_do_power_resume
-#define	pci_do_power_suspend _bsd_pci_do_power_suspend
-#define	pci_driver _bsd_pci_driver
-#define	pci_driver_added _bsd_pci_driver_added
-#define	pcie_adjust_config _bsd_pcie_adjust_config
-#define	pci_ea_is_enabled _bsd_pci_ea_is_enabled
-#define	pcie_flr _bsd_pcie_flr
-#define	pcie_get_max_completion_timeout _bsd_pcie_get_max_completion_timeout
-#define	pcie_link_reset _bsd_pcie_link_reset
-#define	pci_enable_busmaster_method _bsd_pci_enable_busmaster_method
-#define	pci_enable_io_method _bsd_pci_enable_io_method
-#define	pci_enable_msi_method _bsd_pci_enable_msi_method
-#define	pci_enable_msix_method _bsd_pci_enable_msix_method
-#define	pcie_read_config _bsd_pcie_read_config
-#define	pcie_wait_for_pending_transactions _bsd_pcie_wait_for_pending_transactions
-#define	pcie_write_config _bsd_pcie_write_config
-#define	pci_fetch_vpd_list _bsd_pci_fetch_vpd_list
-#define	pci_find_bar _bsd_pci_find_bar
-#define	pci_find_bsf _bsd_pci_find_bsf
-#define	pci_find_cap_method _bsd_pci_find_cap_method
-#define	pci_find_class _bsd_pci_find_class
-#define	pci_find_dbsf _bsd_pci_find_dbsf
-#define	pci_find_extcap_method _bsd_pci_find_extcap_method
-#define	pci_find_htcap_method _bsd_pci_find_htcap_method
-#define	pci_find_next_cap_method _bsd_pci_find_next_cap_method
-#define	pci_find_next_extcap_method _bsd_pci_find_next_extcap_method
-#define	pci_find_next_htcap_method _bsd_pci_find_next_htcap_method
-#define	pci_find_pcie_root_port _bsd_pci_find_pcie_root_port
-#define	pci_freecfg _bsd_pci_freecfg
-#define	pci_generation _bsd_pci_generation
-#define	pci_get_dma_tag _bsd_pci_get_dma_tag
-#define	pci_get_max_payload _bsd_pci_get_max_payload
-#define	pci_get_max_read_req _bsd_pci_get_max_read_req
-#define	pci_get_powerstate_method _bsd_pci_get_powerstate_method
-#define	pci_get_resource_list _bsd_pci_get_resource_list
-#define	pci_get_vpd_ident_method _bsd_pci_get_vpd_ident_method
-#define	pci_get_vpd_readonly_method _bsd_pci_get_vpd_readonly_method
-#define	pci_ht_map_msi _bsd_pci_ht_map_msi
-#define	pci_mapsize _bsd_pci_mapsize
-#define	pci_match_device _bsd_pci_match_device
-#define	pci_msi_count_method _bsd_pci_msi_count_method
-#define	pci_msi_device_blacklisted _bsd_pci_msi_device_blacklisted
-#define	pci_msix_count_method _bsd_pci_msix_count_method
-#define	pci_msix_device_blacklisted _bsd_pci_msix_device_blacklisted
-#define	pci_msix_pba_bar_method _bsd_pci_msix_pba_bar_method
-#define	pci_msix_table_bar_method _bsd_pci_msix_table_bar_method
-#define	pci_numdevs _bsd_pci_numdevs
-#define	pci_pending_msix _bsd_pci_pending_msix
-#define	pci_power_reset _bsd_pci_power_reset
-#define	pci_print_child _bsd_pci_print_child
-#define	pci_print_faulted_dev _bsd_pci_print_faulted_dev
-#define	pci_print_verbose _bsd_pci_print_verbose
-#define	pci_probe_nomatch _bsd_pci_probe_nomatch
-#define	pci_read_bar _bsd_pci_read_bar
-#define	pci_read_config_method _bsd_pci_read_config_method
-#define	pci_read_device _bsd_pci_read_device
-#define	pci_read_ivar _bsd_pci_read_ivar
-#define	pci_release_msi_method _bsd_pci_release_msi_method
-#define	pci_release_resource _bsd_pci_release_resource
-#define	pci_remap_msix_method _bsd_pci_remap_msix_method
-#define	pci_rescan_method _bsd_pci_rescan_method
-#define	pci_restore_state _bsd_pci_restore_state
-#define	pci_resume _bsd_pci_resume
-#define	pci_resume_child _bsd_pci_resume_child
-#define	pci_save_state _bsd_pci_save_state
-#define	pci_set_max_read_req _bsd_pci_set_max_read_req
-#define	pci_set_powerstate_method _bsd_pci_set_powerstate_method
-#define	pci_setup_intr _bsd_pci_setup_intr
-#define	pci_suspend_child _bsd_pci_suspend_child
-#define	pci_teardown_intr _bsd_pci_teardown_intr
-#define	pci_write_config_method _bsd_pci_write_config_method
-#define	pci_write_ivar _bsd_pci_write_ivar
-#define	pcpu_entry_epair_dpcpu _bsd_pcpu_entry_epair_dpcpu
-#define	pcpu_zone_64 _bsd_pcpu_zone_64
-#define	pcpu_zone_int _bsd_pcpu_zone_int
-#define	pcpu_zone_ptr _bsd_pcpu_zone_ptr
-#define	pf_addr_cmp _bsd_pf_addr_cmp
-#define	pf_addrcpy _bsd_pf_addrcpy
-#define	pf_addr_inc _bsd_pf_addr_inc
-#define	pf_altq_ifs_active _bsd_pf_altq_ifs_active
-#define	pf_altq_ifs_inactive _bsd_pf_altq_ifs_inactive
-#define	pf_altqs _bsd_pf_altqs
-#define	pf_altqs_active _bsd_pf_altqs_active
-#define	pf_altqs_inactive _bsd_pf_altqs_inactive
-#define	pf_anchor_copyout _bsd_pf_anchor_copyout
-#define	pf_anchor_global_RB_FIND _bsd_pf_anchor_global_RB_FIND
-#define	pf_anchor_global_RB_INSERT _bsd_pf_anchor_global_RB_INSERT
-#define	pf_anchor_global_RB_INSERT_COLOR _bsd_pf_anchor_global_RB_INSERT_COLOR
-#define	pf_anchor_global_RB_MINMAX _bsd_pf_anchor_global_RB_MINMAX
-#define	pf_anchor_global_RB_NEXT _bsd_pf_anchor_global_RB_NEXT
-#define	pf_anchor_global_RB_NFIND _bsd_pf_anchor_global_RB_NFIND
-#define	pf_anchor_global_RB_PREV _bsd_pf_anchor_global_RB_PREV
-#define	pf_anchor_global_RB_REMOVE _bsd_pf_anchor_global_RB_REMOVE
-#define	pf_anchor_global_RB_REMOVE_COLOR _bsd_pf_anchor_global_RB_REMOVE_COLOR
-#define	pf_anchor_node_RB_FIND _bsd_pf_anchor_node_RB_FIND
-#define	pf_anchor_node_RB_INSERT _bsd_pf_anchor_node_RB_INSERT
-#define	pf_anchor_node_RB_INSERT_COLOR _bsd_pf_anchor_node_RB_INSERT_COLOR
-#define	pf_anchor_node_RB_MINMAX _bsd_pf_anchor_node_RB_MINMAX
-#define	pf_anchor_node_RB_NEXT _bsd_pf_anchor_node_RB_NEXT
-#define	pf_anchor_node_RB_NFIND _bsd_pf_anchor_node_RB_NFIND
-#define	pf_anchor_node_RB_PREV _bsd_pf_anchor_node_RB_PREV
-#define	pf_anchor_node_RB_REMOVE _bsd_pf_anchor_node_RB_REMOVE
-#define	pf_anchor_node_RB_REMOVE_COLOR _bsd_pf_anchor_node_RB_REMOVE_COLOR
-#define	pf_anchor_remove _bsd_pf_anchor_remove
-#define	pf_anchors _bsd_pf_anchors
-#define	pf_anchor_setup _bsd_pf_anchor_setup
-#define	pf_calc_skip_steps _bsd_pf_calc_skip_steps
-#define	pf_change_a _bsd_pf_change_a
-#define	pf_change_proto_a _bsd_pf_change_proto_a
-#define	pf_cksum_fixup _bsd_pf_cksum_fixup
-#define	pf_cleanup _bsd_pf_cleanup
-#define	pfctlinput _bsd_pfctlinput
-#define	pfctlinput2 _bsd_pfctlinput2
-#define	pf_default_rule _bsd_pf_default_rule
-#define	pf_dev _bsd_pf_dev
-#define	pf_end_lock _bsd_pf_end_lock
-#define	pf_end_threads _bsd_pf_end_threads
-#define	pffinddomain _bsd_pffinddomain
-#define	pf_find_or_create_ruleset _bsd_pf_find_or_create_ruleset
-#define	pffindproto _bsd_pffindproto
-#define	pf_find_ruleset _bsd_pf_find_ruleset
-#define	pf_find_src_node _bsd_pf_find_src_node
-#define	pf_find_state_all _bsd_pf_find_state_all
-#define	pf_find_state_byid _bsd_pf_find_state_byid
-#define	pffindtype _bsd_pffindtype
-#define	pf_frag_tree_RB_FIND _bsd_pf_frag_tree_RB_FIND
-#define	pf_frag_tree_RB_INSERT _bsd_pf_frag_tree_RB_INSERT
-#define	pf_frag_tree_RB_MINMAX _bsd_pf_frag_tree_RB_MINMAX
-#define	pf_frag_tree_RB_NEXT _bsd_pf_frag_tree_RB_NEXT
-#define	pf_frag_tree_RB_NFIND _bsd_pf_frag_tree_RB_NFIND
-#define	pf_frag_tree_RB_PREV _bsd_pf_frag_tree_RB_PREV
-#define	pf_frag_tree_RB_REMOVE _bsd_pf_frag_tree_RB_REMOVE
-#define	pf_frag_tree_RB_REMOVE_COLOR _bsd_pf_frag_tree_RB_REMOVE_COLOR
-#define	pf_free_rule _bsd_pf_free_rule
-#define	pf_free_src_nodes _bsd_pf_free_src_nodes
-#define	pf_free_state _bsd_pf_free_state
-#define	pf_frent_previous _bsd_pf_frent_previous
-#define	pf_frent_remove _bsd_pf_frent_remove
-#define	pf_get_mtag _bsd_pf_get_mtag
-#define	pf_get_ruleset_number _bsd_pf_get_ruleset_number
-#define	pf_get_translation _bsd_pf_get_translation
-#define	pf_hashmask _bsd_pf_hashmask
-#define	pf_hashseed _bsd_pf_hashseed
-#define	pfi_all _bsd_pfi_all
-#define	pfi_attach_cookie _bsd_pfi_attach_cookie
-#define	pfi_attach_group_cookie _bsd_pfi_attach_group_cookie
-#define	pfi_change_group_cookie _bsd_pfi_change_group_cookie
-#define	pfi_cleanup _bsd_pfi_cleanup
-#define	pfi_cleanup_vnet _bsd_pfi_cleanup_vnet
-#define	pfi_clear_flags _bsd_pfi_clear_flags
-#define	pfi_detach_cookie _bsd_pfi_detach_cookie
-#define	pfi_detach_group_cookie _bsd_pfi_detach_group_cookie
-#define	pf_idhash _bsd_pf_idhash
-#define	pfi_dynaddr_copyout _bsd_pfi_dynaddr_copyout
-#define	pfi_dynaddr_remove _bsd_pfi_dynaddr_remove
-#define	pfi_dynaddr_setup _bsd_pfi_dynaddr_setup
-#define	pfi_get_ifaces _bsd_pfi_get_ifaces
-#define	pfi_ifaddr_event_cookie _bsd_pfi_ifaddr_event_cookie
-#define	pfi_ifhead_RB_FIND _bsd_pfi_ifhead_RB_FIND
-#define	pfi_ifhead_RB_INSERT _bsd_pfi_ifhead_RB_INSERT
-#define	pfi_ifhead_RB_MINMAX _bsd_pfi_ifhead_RB_MINMAX
-#define	pfi_ifhead_RB_NEXT _bsd_pfi_ifhead_RB_NEXT
-#define	pfi_ifhead_RB_NFIND _bsd_pfi_ifhead_RB_NFIND
-#define	pfi_ifhead_RB_PREV _bsd_pfi_ifhead_RB_PREV
-#define	pfi_ifhead_RB_REMOVE _bsd_pfi_ifhead_RB_REMOVE
-#define	pfi_ifhead_RB_REMOVE_COLOR _bsd_pfi_ifhead_RB_REMOVE_COLOR
-#define	pfi_initialize _bsd_pfi_initialize
-#define	pfi_initialize_vnet _bsd_pfi_initialize_vnet
-#define	pfi_kif_attach _bsd_pfi_kif_attach
-#define	pfi_kif_find _bsd_pfi_kif_find
-#define	pfi_kif_match _bsd_pfi_kif_match
-#define	pfi_kif_purge _bsd_pfi_kif_purge
-#define	pfi_kif_ref _bsd_pfi_kif_ref
-#define	pfi_kif_unref _bsd_pfi_kif_unref
-#define	pfil_add_hook _bsd_pfil_add_hook
-#define	pfil_add_hook_flags _bsd_pfil_add_hook_flags
-#define	pfil_head_get _bsd_pfil_head_get
-#define	pfil_head_list _bsd_pfil_head_list
-#define	pfil_head_register _bsd_pfil_head_register
-#define	pfil_head_unregister _bsd_pfil_head_unregister
-#define	pfil_link _bsd_pfil_link
-#define	pfil_lock _bsd_pfil_lock
-#define	pfil_realloc _bsd_pfil_realloc
-#define	pfil_remove_hook _bsd_pfil_remove_hook
-#define	pfil_remove_hook_flags _bsd_pfil_remove_hook_flags
-#define	pfil_rlock _bsd_pfil_rlock
-#define	pfil_run_hooks _bsd_pfil_run_hooks
-#define	pfil_runlock _bsd_pfil_runlock
-#define	pfil_wlock _bsd_pfil_wlock
-#define	pfil_wowned _bsd_pfil_wowned
-#define	pfil_wunlock _bsd_pfil_wunlock
-#define	pfi_match_addr _bsd_pfi_match_addr
-#define	PFI_MTYPE _bsd_PFI_MTYPE
-#define	pf_initialize _bsd_pf_initialize
-#define	pf_init_ruleset _bsd_pf_init_ruleset
-#define	pf_intr _bsd_pf_intr
-#define	pf_ioctl_lock _bsd_pf_ioctl_lock
-#define	pf_ioctl_maxcount _bsd_pf_ioctl_maxcount
-#define	pfi_set_flags _bsd_pfi_set_flags
-#define	pfi_update_status _bsd_pfi_update_status
-#define	pf_keyhash _bsd_pf_keyhash
-#define	pfkeystat _bsd_pfkeystat
-#define	pf_limits _bsd_pf_limits
-#define	pflogifs _bsd_pflogifs
-#define	pflog_packet_ptr _bsd_pflog_packet_ptr
-#define	pf_main_anchor _bsd_pf_main_anchor
-#define	pf_map_addr _bsd_pf_map_addr
-#define	pf_match_addr _bsd_pf_match_addr
-#define	pf_match_addr_range _bsd_pf_match_addr_range
-#define	pf_match_port _bsd_pf_match_port
-#define	pf_match_tag _bsd_pf_match_tag
-#define	pf_mtag_cleanup _bsd_pf_mtag_cleanup
-#define	pf_mtag_initialize _bsd_pf_mtag_initialize
-#define	pf_mtag_z _bsd_pf_mtag_z
-#define	pf_normalize_cleanup _bsd_pf_normalize_cleanup
-#define	pf_normalize_init _bsd_pf_normalize_init
-#define	pf_normalize_ip _bsd_pf_normalize_ip
-#define	pf_normalize_ip6 _bsd_pf_normalize_ip6
-#define	pf_normalize_tcp _bsd_pf_normalize_tcp
-#define	pf_normalize_tcp_cleanup _bsd_pf_normalize_tcp_cleanup
-#define	pf_normalize_tcp_init _bsd_pf_normalize_tcp_init
-#define	pf_normalize_tcp_stateful _bsd_pf_normalize_tcp_stateful
-#define	pf_osfp_add _bsd_pf_osfp_add
-#define	pf_osfp_fingerprint _bsd_pf_osfp_fingerprint
-#define	pf_osfp_flush _bsd_pf_osfp_flush
-#define	pf_osfp_get _bsd_pf_osfp_get
-#define	pf_osfp_match _bsd_pf_osfp_match
-#define	pf_pabuf _bsd_pf_pabuf
-#define	pf_poolmask _bsd_pf_poolmask
-#define	pf_print_flags _bsd_pf_print_flags
-#define	pf_print_host _bsd_pf_print_host
-#define	pf_print_state _bsd_pf_print_state
-#define	pf_proto_cksum_fixup _bsd_pf_proto_cksum_fixup
-#define	pf_proto_register _bsd_pf_proto_register
-#define	pf_proto_unregister _bsd_pf_proto_unregister
-#define	pf_pull_hdr _bsd_pf_pull_hdr
-#define	pf_purge_expired_fragments _bsd_pf_purge_expired_fragments
-#define	pf_purge_expired_src_nodes _bsd_pf_purge_expired_src_nodes
-#define	pf_purge_fragments _bsd_pf_purge_fragments
-#define	pf_purge_proc _bsd_pf_purge_proc
-#define	pf_purge_thread _bsd_pf_purge_thread
-#define	pfr_add_addrs _bsd_pfr_add_addrs
-#define	pfr_add_tables _bsd_pfr_add_tables
-#define	pfr_attach_table _bsd_pfr_attach_table
-#define	pfr_cleanup _bsd_pfr_cleanup
-#define	pfr_clr_addrs _bsd_pfr_clr_addrs
-#define	pfr_clr_astats _bsd_pfr_clr_astats
-#define	pfr_clr_tables _bsd_pfr_clr_tables
-#define	pfr_clr_tstats _bsd_pfr_clr_tstats
-#define	pfr_del_addrs _bsd_pfr_del_addrs
-#define	pfr_del_tables _bsd_pfr_del_tables
-#define	pfr_detach_table _bsd_pfr_detach_table
-#define	pfr_dynaddr_update _bsd_pfr_dynaddr_update
-#define	pf_refragment6 _bsd_pf_refragment6
-#define	pf_remove_if_empty_ruleset _bsd_pf_remove_if_empty_ruleset
-#define	pfr_get_addrs _bsd_pfr_get_addrs
-#define	pfr_get_astats _bsd_pfr_get_astats
-#define	pfr_get_tables _bsd_pfr_get_tables
-#define	pfr_get_tstats _bsd_pfr_get_tstats
-#define	pfr_ina_begin _bsd_pfr_ina_begin
-#define	pfr_ina_commit _bsd_pfr_ina_commit
-#define	pfr_ina_define _bsd_pfr_ina_define
-#define	pfr_ina_rollback _bsd_pfr_ina_rollback
-#define	pfr_initialize _bsd_pfr_initialize
-#define	pfr_insert_kentry _bsd_pfr_insert_kentry
-#define	pfr_ktablehead_RB_FIND _bsd_pfr_ktablehead_RB_FIND
-#define	pfr_ktablehead_RB_INSERT _bsd_pfr_ktablehead_RB_INSERT
-#define	pfr_ktablehead_RB_MINMAX _bsd_pfr_ktablehead_RB_MINMAX
-#define	pfr_ktablehead_RB_NEXT _bsd_pfr_ktablehead_RB_NEXT
-#define	pfr_ktablehead_RB_NFIND _bsd_pfr_ktablehead_RB_NFIND
-#define	pfr_ktablehead_RB_PREV _bsd_pfr_ktablehead_RB_PREV
-#define	pfr_ktablehead_RB_REMOVE _bsd_pfr_ktablehead_RB_REMOVE
-#define	pfr_ktablehead_RB_REMOVE_COLOR _bsd_pfr_ktablehead_RB_REMOVE_COLOR
-#define	pfr_match_addr _bsd_pfr_match_addr
-#define	pf_routable _bsd_pf_routable
-#define	pfr_pool_get _bsd_pfr_pool_get
-#define	pfr_set_addrs _bsd_pfr_set_addrs
-#define	pfr_set_tflags _bsd_pfr_set_tflags
-#define	pfr_table_count _bsd_pfr_table_count
-#define	pfr_tst_addrs _bsd_pfr_tst_addrs
-#define	pf_rules_lock _bsd_pf_rules_lock
-#define	pfr_update_stats _bsd_pfr_update_stats
-#define	pf_socket_lookup _bsd_pf_socket_lookup
-#define	pf_srchash _bsd_pf_srchash
-#define	pf_srchashmask _bsd_pf_srchashmask
-#define	pf_state_expires _bsd_pf_state_expires
-#define	pf_stateid _bsd_pf_stateid
-#define	pf_state_insert _bsd_pf_state_insert
-#define	pf_state_key_clone _bsd_pf_state_key_clone
-#define	pf_state_key_setup _bsd_pf_state_key_setup
-#define	pf_state_key_z _bsd_pf_state_key_z
-#define	pf_state_scrub_z _bsd_pf_state_scrub_z
-#define	pf_state_z _bsd_pf_state_z
-#define	pf_status _bsd_pf_status
-#define	pf_step_into_anchor _bsd_pf_step_into_anchor
-#define	pf_step_out_of_anchor _bsd_pf_step_out_of_anchor
-#define	pf_swi_cookie _bsd_pf_swi_cookie
-#define	pfsync_clear_states_ptr _bsd_pfsync_clear_states_ptr
-#define	pfsync_cloner _bsd_pfsync_cloner
-#define	pfsync_defer_ptr _bsd_pfsync_defer_ptr
-#define	pfsync_delete_state_ptr _bsd_pfsync_delete_state_ptr
-#define	pfsync_detach_ifnet_ptr _bsd_pfsync_detach_ifnet_ptr
-#define	pfsync_insert_state_ptr _bsd_pfsync_insert_state_ptr
-#define	pfsync_state_export _bsd_pfsync_state_export
-#define	pfsync_state_import_ptr _bsd_pfsync_state_import_ptr
-#define	pfsync_update_state_ptr _bsd_pfsync_update_state_ptr
-#define	pf_tag_packet _bsd_pf_tag_packet
-#define	pf_tags _bsd_pf_tags
-#define	pf_tag_z _bsd_pf_tag_z
-#define	pf_tcp_iss_off _bsd_pf_tcp_iss_off
-#define	pf_tcp_secret _bsd_pf_tcp_secret
-#define	pf_tcp_secret_ctx _bsd_pf_tcp_secret_ctx
-#define	pf_tcp_secret_init _bsd_pf_tcp_secret_init
-#define	pf_test _bsd_pf_test
-#define	pf_test6 _bsd_pf_test6
-#define	pf_unlinked_rules _bsd_pf_unlinked_rules
-#define	pf_unlink_src_node _bsd_pf_unlink_src_node
-#define	pf_unlink_state _bsd_pf_unlink_state
-#define	pf_unlnkdrules_mtx _bsd_pf_unlnkdrules_mtx
-#define	pf_unload_vnet_purge _bsd_pf_unload_vnet_purge
-#define	pf_vnet_active _bsd_pf_vnet_active
-#define	pfxlist_onlink_check _bsd_pfxlist_onlink_check
-#define	phashinit _bsd_phashinit
-#define	phashinit_flags _bsd_phashinit_flags
-#define	pick_mode_by_dotclock _bsd_pick_mode_by_dotclock
-#define	pick_mode_by_ref _bsd_pick_mode_by_ref
-#define	pipe_dtor _bsd_pipe_dtor
-#define	pipe_named_ctor _bsd_pipe_named_ctor
-#define	pipeselwakeup _bsd_pipeselwakeup
-#define	pmtu_expire _bsd_pmtu_expire
-#define	pmtu_probe _bsd_pmtu_probe
-#define	poll_no_poll _bsd_poll_no_poll
-#define	Poly1305_Final _bsd_Poly1305_Final
-#define	Poly1305_Init _bsd_Poly1305_Init
-#define	Poly1305_Setkey _bsd_Poly1305_Setkey
-#define	Poly1305_Update _bsd_Poly1305_Update
-#define	ppsratecheck _bsd_ppsratecheck
-#define	printf _bsd_printf
-#define	printf_uuid _bsd_printf_uuid
-#define	prison0 _bsd_prison0
-#define	ProxyCheck _bsd_ProxyCheck
-#define	ProxyModify _bsd_ProxyModify
-#define	pru_accept_notsupp _bsd_pru_accept_notsupp
-#define	pru_aio_queue_notsupp _bsd_pru_aio_queue_notsupp
-#define	pru_attach_notsupp _bsd_pru_attach_notsupp
-#define	pru_bindat_notsupp _bsd_pru_bindat_notsupp
-#define	pru_bind_notsupp _bsd_pru_bind_notsupp
-#define	pru_connect2_notsupp _bsd_pru_connect2_notsupp
-#define	pru_connectat_notsupp _bsd_pru_connectat_notsupp
-#define	pru_connect_notsupp _bsd_pru_connect_notsupp
-#define	pru_control_notsupp _bsd_pru_control_notsupp
-#define	pru_disconnect_notsupp _bsd_pru_disconnect_notsupp
-#define	pru_listen_notsupp _bsd_pru_listen_notsupp
-#define	pru_peeraddr_notsupp _bsd_pru_peeraddr_notsupp
-#define	pru_rcvd_notsupp _bsd_pru_rcvd_notsupp
-#define	pru_rcvoob_notsupp _bsd_pru_rcvoob_notsupp
-#define	pru_ready_notsupp _bsd_pru_ready_notsupp
-#define	pru_send_notsupp _bsd_pru_send_notsupp
-#define	pru_sense_null _bsd_pru_sense_null
-#define	pru_shutdown_notsupp _bsd_pru_shutdown_notsupp
-#define	pru_sockaddr_notsupp _bsd_pru_sockaddr_notsupp
-#define	pru_sopoll_notsupp _bsd_pru_sopoll_notsupp
-#define	pru_soreceive_notsupp _bsd_pru_soreceive_notsupp
-#define	pru_sosend_notsupp _bsd_pru_sosend_notsupp
-#define	qgroup_config _bsd_qgroup_config
-#define	qgroup_softirq _bsd_qgroup_softirq
-#define	r12a_beacon_init _bsd_r12a_beacon_init
-#define	r12a_beacon_set_rate _bsd_r12a_beacon_set_rate
-#define	r12a_c_cut_rf_read _bsd_r12a_c_cut_rf_read
-#define	r12a_check_condition _bsd_r12a_check_condition
-#define	r12a_check_frame_checksum _bsd_r12a_check_frame_checksum
-#define	r12a_crystalcap_write _bsd_r12a_crystalcap_write
-#define	r12a_detach_private _bsd_r12a_detach_private
-#define	r12a_fill_tx_desc _bsd_r12a_fill_tx_desc
-#define	r12a_fill_tx_desc_null _bsd_r12a_fill_tx_desc_null
-#define	r12a_fill_tx_desc_raw _bsd_r12a_fill_tx_desc_raw
-#define	r12a_fix_spur _bsd_r12a_fix_spur
-#define	r12a_fw_download_enable _bsd_r12a_fw_download_enable
-#define	r12a_fw_reset _bsd_r12a_fw_reset
-#define	r12a_get_rx_stats _bsd_r12a_get_rx_stats
-#define	r12a_handle_c2h_report _bsd_r12a_handle_c2h_report
-#define	r12a_init_antsel _bsd_r12a_init_antsel
-#define	r12a_init_bb _bsd_r12a_init_bb
-#define	r12a_init_edca _bsd_r12a_init_edca
-#define	r12a_init_intr _bsd_r12a_init_intr
-#define	r12a_init_rf _bsd_r12a_init_rf
-#define	r12a_ioctl_net _bsd_r12a_ioctl_net
-#define	r12a_iq_calib _bsd_r12a_iq_calib
-#define	r12a_iq_calib_fw _bsd_r12a_iq_calib_fw
-#define	r12a_iq_calib_fw_supported _bsd_r12a_iq_calib_fw_supported
-#define	r12a_iq_calib_sw _bsd_r12a_iq_calib_sw
-#define	r12a_lc_calib _bsd_r12a_lc_calib
-#define	r12a_parse_rom _bsd_r12a_parse_rom
-#define	r12a_parse_rom_common _bsd_r12a_parse_rom_common
-#define	r12a_power_off _bsd_r12a_power_off
-#define	r12a_power_on _bsd_r12a_power_on
-#define	r12a_ratectl_tx_complete _bsd_r12a_ratectl_tx_complete
-#define	r12a_restore_bb_afe_vals _bsd_r12a_restore_bb_afe_vals
-#define	r12a_restore_rf_vals _bsd_r12a_restore_rf_vals
-#define	r12a_rf_read _bsd_r12a_rf_read
-#define	r12a_rf_write _bsd_r12a_rf_write
-#define	r12a_rx_radiotap_flags _bsd_r12a_rx_radiotap_flags
-#define	r12a_save_bb_afe_vals _bsd_r12a_save_bb_afe_vals
-#define	r12a_save_rf_vals _bsd_r12a_save_rf_vals
-#define	r12a_set_band_2ghz _bsd_r12a_set_band_2ghz
-#define	r12a_set_band_5ghz _bsd_r12a_set_band_5ghz
-#define	r12a_set_chan _bsd_r12a_set_chan
-#define	r12a_set_led _bsd_r12a_set_led
-#define	r12a_set_media_status _bsd_r12a_set_media_status
-#define	r12a_set_page_size _bsd_r12a_set_page_size
-#define	r12a_set_pwrmode _bsd_r12a_set_pwrmode
-#define	r12a_tx_radiotap_flags _bsd_r12a_tx_radiotap_flags
-#define	r12au_align_rx _bsd_r12au_align_rx
-#define	r12au_attach _bsd_r12au_attach
-#define	r12au_classify_intr _bsd_r12au_classify_intr
-#define	r12au_dump_tx_desc _bsd_r12au_dump_tx_desc
-#define	r12au_init_ampdu _bsd_r12au_init_ampdu
-#define	r12au_init_ampdu_fwhw _bsd_r12au_init_ampdu_fwhw
-#define	r12au_init_burstlen _bsd_r12au_init_burstlen
-#define	r12au_init_burstlen_usb2 _bsd_r12au_init_burstlen_usb2
-#define	r12au_init_rx_agg _bsd_r12au_init_rx_agg
-#define	r12au_post_init _bsd_r12au_post_init
-#define	r12a_vap_preattach _bsd_r12a_vap_preattach
-#define	r21a_beacon_init _bsd_r21a_beacon_init
-#define	r21a_beacon_select _bsd_r21a_beacon_select
-#define	r21a_check_condition _bsd_r21a_check_condition
-#define	r21a_crystalcap_write _bsd_r21a_crystalcap_write
-#define	r21a_fw_reset _bsd_r21a_fw_reset
-#define	r21a_get_rssi_cck _bsd_r21a_get_rssi_cck
-#define	r21a_init_ampdu_fwhw _bsd_r21a_init_ampdu_fwhw
-#define	r21a_init_bcnq1_boundary _bsd_r21a_init_bcnq1_boundary
-#define	r21a_iq_calib_fw_supported _bsd_r21a_iq_calib_fw_supported
-#define	r21a_iq_calib_sw _bsd_r21a_iq_calib_sw
-#define	r21a_parse_rom _bsd_r21a_parse_rom
-#define	r21a_power_off _bsd_r21a_power_off
-#define	r21a_power_on _bsd_r21a_power_on
-#define	r21a_set_band_2ghz _bsd_r21a_set_band_2ghz
-#define	r21a_set_band_5ghz _bsd_r21a_set_band_5ghz
-#define	r21a_set_led _bsd_r21a_set_led
-#define	r21au_attach _bsd_r21au_attach
-#define	r21au_chan_check _bsd_r21au_chan_check
-#define	r21au_init_tx_agg _bsd_r21au_init_tx_agg
-#define	r21au_newstate _bsd_r21au_newstate
-#define	r21au_scan_end _bsd_r21au_scan_end
-#define	r21au_scan_start _bsd_r21au_scan_start
-#define	r88e_beacon_enable _bsd_r88e_beacon_enable
-#define	r88e_classify_intr _bsd_r88e_classify_intr
-#define	r88e_fw_cmd _bsd_r88e_fw_cmd
-#define	r88e_fw_download_enable _bsd_r88e_fw_download_enable
-#define	r88e_fw_reset _bsd_r88e_fw_reset
-#define	r88e_get_rssi_cck _bsd_r88e_get_rssi_cck
-#define	r88e_get_rssi_ofdm _bsd_r88e_get_rssi_ofdm
-#define	r88e_get_rx_stats _bsd_r88e_get_rx_stats
-#define	r88e_get_txpower _bsd_r88e_get_txpower
-#define	r88e_handle_c2h_report _bsd_r88e_handle_c2h_report
-#define	r88e_init_bb_common _bsd_r88e_init_bb_common
-#define	r88e_iq_calib _bsd_r88e_iq_calib
-#define	r88e_macid_enable_link _bsd_r88e_macid_enable_link
-#define	r88e_parse_rom _bsd_r88e_parse_rom
-#define	r88e_ratectl_tx_complete _bsd_r88e_ratectl_tx_complete
-#define	r88e_rf_write _bsd_r88e_rf_write
-#define	r88e_set_bw20 _bsd_r88e_set_bw20
-#define	r88e_set_gain _bsd_r88e_set_gain
-#define	r88e_set_led _bsd_r88e_set_led
-#define	r88e_set_media_status _bsd_r88e_set_media_status
-#define	r88e_set_pwrmode _bsd_r88e_set_pwrmode
-#define	r88e_set_rsvd_page _bsd_r88e_set_rsvd_page
-#define	r88e_temp_measure _bsd_r88e_temp_measure
-#define	r88e_temp_read _bsd_r88e_temp_read
-#define	r88e_tx_enable_ampdu _bsd_r88e_tx_enable_ampdu
-#define	r88e_tx_setup_hwseq _bsd_r88e_tx_setup_hwseq
-#define	r88e_tx_setup_macid _bsd_r88e_tx_setup_macid
-#define	r88eu_attach _bsd_r88eu_attach
-#define	r88eu_classify_intr _bsd_r88eu_classify_intr
-#define	r88eu_init_bb _bsd_r88eu_init_bb
-#define	r88eu_init_intr _bsd_r88eu_init_intr
-#define	r88eu_init_rx_agg _bsd_r88eu_init_rx_agg
-#define	r88eu_post_init _bsd_r88eu_post_init
-#define	r88eu_power_off _bsd_r88eu_power_off
-#define	r88eu_power_on _bsd_r88eu_power_on
-#define	r92c_beacon_enable _bsd_r92c_beacon_enable
-#define	r92c_beacon_init _bsd_r92c_beacon_init
-#define	r92c_check_condition _bsd_r92c_check_condition
-#define	r92c_classify_intr _bsd_r92c_classify_intr
-#define	r92c_detach_private _bsd_r92c_detach_private
-#define	r92ce_attach _bsd_r92ce_attach
-#define	r92ce_copy_tx_desc _bsd_r92ce_copy_tx_desc
-#define	r92ce_dump_tx_desc _bsd_r92ce_dump_tx_desc
-#define	r92ce_enable_intr _bsd_r92ce_enable_intr
-#define	r92c_efuse_postread _bsd_r92c_efuse_postread
-#define	r92ce_fw_reset _bsd_r92ce_fw_reset
-#define	r92ce_get_intr_status _bsd_r92ce_get_intr_status
-#define	r92ce_init_ampdu _bsd_r92ce_init_ampdu
-#define	r92ce_init_bb _bsd_r92ce_init_bb
-#define	r92ce_init_edca _bsd_r92ce_init_edca
-#define	r92ce_init_intr _bsd_r92ce_init_intr
-#define	r92ce_iq_calib _bsd_r92ce_iq_calib
-#define	r92ce_post_init _bsd_r92ce_post_init
-#define	r92ce_power_off _bsd_r92ce_power_off
-#define	r92ce_power_on _bsd_r92ce_power_on
-#define	r92ce_set_led _bsd_r92ce_set_led
-#define	r92ce_setup_tx_desc _bsd_r92ce_setup_tx_desc
-#define	r92ce_start_xfers _bsd_r92ce_start_xfers
-#define	r92ce_tx_postsetup _bsd_r92ce_tx_postsetup
-#define	r92c_fill_tx_desc _bsd_r92c_fill_tx_desc
-#define	r92c_fill_tx_desc_null _bsd_r92c_fill_tx_desc_null
-#define	r92c_fill_tx_desc_raw _bsd_r92c_fill_tx_desc_raw
-#define	r92c_fw_download_enable _bsd_r92c_fw_download_enable
-#define	r92c_fw_reset _bsd_r92c_fw_reset
-#define	r92c_get_rssi_cck _bsd_r92c_get_rssi_cck
-#define	r92c_get_rssi_ofdm _bsd_r92c_get_rssi_ofdm
-#define	r92c_get_rx_stats _bsd_r92c_get_rx_stats
-#define	r92c_get_txpower _bsd_r92c_get_txpower
-#define	r92c_handle_c2h_report _bsd_r92c_handle_c2h_report
-#define	r92c_init_ampdu _bsd_r92c_init_ampdu
-#define	r92c_init_antsel _bsd_r92c_init_antsel
-#define	r92c_init_bb_common _bsd_r92c_init_bb_common
-#define	r92c_init_edca _bsd_r92c_init_edca
-#define	r92c_init_rf _bsd_r92c_init_rf
-#define	r92c_init_rf_chain _bsd_r92c_init_rf_chain
-#define	r92c_iq_calib _bsd_r92c_iq_calib
-#define	r92c_joinbss_rpt _bsd_r92c_joinbss_rpt
-#define	r92c_lc_calib _bsd_r92c_lc_calib
-#define	r92c_llt_init _bsd_r92c_llt_init
-#define	r92c_llt_write _bsd_r92c_llt_write
-#define	r92c_pa_bias_init _bsd_r92c_pa_bias_init
-#define	r92c_parse_rom _bsd_r92c_parse_rom
-#define	r92c_read_chipid_vendor _bsd_r92c_read_chipid_vendor
-#define	r92c_rf_read _bsd_r92c_rf_read
-#define	r92c_rf_write _bsd_r92c_rf_write
-#define	r92c_rx_radiotap_flags _bsd_r92c_rx_radiotap_flags
-#define	r92c_scan_end _bsd_r92c_scan_end
-#define	r92c_scan_start _bsd_r92c_scan_start
-#define	r92c_set_bw20 _bsd_r92c_set_bw20
-#define	r92c_set_chan _bsd_r92c_set_chan
-#define	r92c_set_gain _bsd_r92c_set_gain
-#define	r92c_set_page_size _bsd_r92c_set_page_size
-#define	r92c_set_pwrmode _bsd_r92c_set_pwrmode
-#define	r92c_set_rssi _bsd_r92c_set_rssi
-#define	r92c_set_rsvd_page _bsd_r92c_set_rsvd_page
-#define	r92c_temp_measure _bsd_r92c_temp_measure
-#define	r92c_temp_read _bsd_r92c_temp_read
-#define	r92c_tx_enable_ampdu _bsd_r92c_tx_enable_ampdu
-#define	r92c_tx_radiotap_flags _bsd_r92c_tx_radiotap_flags
-#define	r92c_tx_setup_hwseq _bsd_r92c_tx_setup_hwseq
-#define	r92c_tx_setup_macid _bsd_r92c_tx_setup_macid
-#define	r92cu_align_rx _bsd_r92cu_align_rx
-#define	r92cu_attach _bsd_r92cu_attach
-#define	r92cu_dump_tx_desc _bsd_r92cu_dump_tx_desc
-#define	r92cu_init_bb _bsd_r92cu_init_bb
-#define	r92cu_init_intr _bsd_r92cu_init_intr
-#define	r92cu_init_rx_agg _bsd_r92cu_init_rx_agg
-#define	r92cu_init_tx_agg _bsd_r92cu_init_tx_agg
-#define	r92cu_post_init _bsd_r92cu_post_init
-#define	r92cu_power_off _bsd_r92cu_power_off
-#define	r92cu_power_on _bsd_r92cu_power_on
-#define	r92cu_set_led _bsd_r92cu_set_led
-#define	r92c_write_txpower _bsd_r92c_write_txpower
-#define	r92e_detach_private _bsd_r92e_detach_private
-#define	r92e_fw_reset _bsd_r92e_fw_reset
-#define	r92e_get_rssi_cck _bsd_r92e_get_rssi_cck
-#define	r92e_handle_c2h_report _bsd_r92e_handle_c2h_report
-#define	r92e_init_bb _bsd_r92e_init_bb
-#define	r92e_init_rf _bsd_r92e_init_rf
-#define	r92e_llt_init _bsd_r92e_llt_init
-#define	r92e_parse_rom _bsd_r92e_parse_rom
-#define	r92e_power_off _bsd_r92e_power_off
-#define	r92e_power_on _bsd_r92e_power_on
-#define	r92e_rf_read _bsd_r92e_rf_read
-#define	r92e_rf_write _bsd_r92e_rf_write
-#define	r92e_set_chan _bsd_r92e_set_chan
-#define	r92e_set_led _bsd_r92e_set_led
-#define	r92e_set_media_status _bsd_r92e_set_media_status
-#define	r92e_set_pwrmode _bsd_r92e_set_pwrmode
-#define	r92eu_attach _bsd_r92eu_attach
-#define	r92eu_init_rx_agg _bsd_r92eu_init_rx_agg
-#define	r92eu_post_init _bsd_r92eu_post_init
-#define	ratecheck _bsd_ratecheck
-#define	raw_attach _bsd_raw_attach
-#define	rawcb_list _bsd_rawcb_list
-#define	rawcb_mtx _bsd_rawcb_mtx
-#define	raw_ctlinput _bsd_raw_ctlinput
-#define	raw_detach _bsd_raw_detach
-#define	raw_init _bsd_raw_init
-#define	raw_input _bsd_raw_input
-#define	raw_input_ext _bsd_raw_input_ext
-#define	raw_usrreqs _bsd_raw_usrreqs
-#define	rc4_crypt _bsd_rc4_crypt
-#define	rc4_init _bsd_rc4_init
-#define	read_dsfield _bsd_read_dsfield
-#define	read_machclk _bsd_read_machclk
-#define	refcount_release_last _bsd_refcount_release_last
-#define	refcount_sleep _bsd_refcount_sleep
-#define	registered_toedevs _bsd_registered_toedevs
-#define	register_tcp_functions _bsd_register_tcp_functions
-#define	register_tcp_functions_as_name _bsd_register_tcp_functions_as_name
-#define	register_tcp_functions_as_names _bsd_register_tcp_functions_as_names
-#define	resource_disabled _bsd_resource_disabled
-#define	resource_find_match _bsd_resource_find_match
-#define	resource_int_value _bsd_resource_int_value
-#define	resource_list_add _bsd_resource_list_add
-#define	resource_list_add_next _bsd_resource_list_add_next
-#define	resource_list_alloc _bsd_resource_list_alloc
-#define	resource_list_busy _bsd_resource_list_busy
-#define	resource_list_delete _bsd_resource_list_delete
-#define	resource_list_find _bsd_resource_list_find
-#define	resource_list_free _bsd_resource_list_free
-#define	resource_list_init _bsd_resource_list_init
-#define	resource_list_print_type _bsd_resource_list_print_type
-#define	resource_list_purge _bsd_resource_list_purge
-#define	resource_list_release _bsd_resource_list_release
-#define	resource_list_release_active _bsd_resource_list_release_active
-#define	resource_list_reserve _bsd_resource_list_reserve
-#define	resource_list_reserved _bsd_resource_list_reserved
-#define	resource_list_unreserve _bsd_resource_list_unreserve
-#define	resource_string_value _bsd_resource_string_value
-#define	resource_unset_value _bsd_resource_unset_value
-#define	rib_free_info _bsd_rib_free_info
-#define	rib_lookup_info _bsd_rib_lookup_info
-#define	rijndael_blockDecrypt _bsd_rijndael_blockDecrypt
-#define	rijndael_blockEncrypt _bsd_rijndael_blockEncrypt
-#define	rijndael_cipherInit _bsd_rijndael_cipherInit
-#define	rijndael_decrypt _bsd_rijndael_decrypt
-#define	rijndaelDecrypt _bsd_rijndaelDecrypt
-#define	rijndael_encrypt _bsd_rijndael_encrypt
-#define	rijndaelEncrypt _bsd_rijndaelEncrypt
-#define	rijndaelKeySetupDec _bsd_rijndaelKeySetupDec
-#define	rijndaelKeySetupEnc _bsd_rijndaelKeySetupEnc
-#define	rijndael_makeKey _bsd_rijndael_makeKey
-#define	rijndael_padDecrypt _bsd_rijndael_padDecrypt
-#define	rijndael_padEncrypt _bsd_rijndael_padEncrypt
-#define	rijndael_set_key _bsd_rijndael_set_key
-#define	rip6_ctlinput _bsd_rip6_ctlinput
-#define	rip6_ctloutput _bsd_rip6_ctloutput
-#define	rip6_input _bsd_rip6_input
-#define	rip6_output _bsd_rip6_output
-#define	rip6stat _bsd_rip6stat
-#define	rip6_usrreqs _bsd_rip6_usrreqs
-#define	ripcb _bsd_ripcb
-#define	ripcbinfo _bsd_ripcbinfo
-#define	rip_ctlinput _bsd_rip_ctlinput
-#define	rip_ctloutput _bsd_rip_ctloutput
-#define	rip_init _bsd_rip_init
-#define	rip_input _bsd_rip_input
-#define	rip_output _bsd_rip_output
-#define	rip_recvspace _bsd_rip_recvspace
-#define	rip_sendspace _bsd_rip_sendspace
-#define	rip_usrreqs _bsd_rip_usrreqs
-#define	rman_activate_resource _bsd_rman_activate_resource
-#define	rman_adjust_resource _bsd_rman_adjust_resource
-#define	rman_deactivate_resource _bsd_rman_deactivate_resource
-#define	rman_fini _bsd_rman_fini
-#define	rman_first_free_region _bsd_rman_first_free_region
-#define	rman_get_bushandle _bsd_rman_get_bushandle
-#define	rman_get_bustag _bsd_rman_get_bustag
-#define	rman_get_device _bsd_rman_get_device
-#define	rman_get_end _bsd_rman_get_end
-#define	rman_get_flags _bsd_rman_get_flags
-#define	rman_get_irq_cookie _bsd_rman_get_irq_cookie
-#define	rman_get_mapping _bsd_rman_get_mapping
-#define	rman_get_rid _bsd_rman_get_rid
-#define	rman_get_size _bsd_rman_get_size
-#define	rman_get_start _bsd_rman_get_start
-#define	rman_get_virtual _bsd_rman_get_virtual
-#define	rman_head _bsd_rman_head
-#define	rman_init _bsd_rman_init
-#define	rman_init_from_resource _bsd_rman_init_from_resource
-#define	rman_is_region_manager _bsd_rman_is_region_manager
-#define	rman_last_free_region _bsd_rman_last_free_region
-#define	rman_make_alignment_flags _bsd_rman_make_alignment_flags
-#define	rman_manage_region _bsd_rman_manage_region
-#define	rman_release_resource _bsd_rman_release_resource
-#define	rman_reserve_resource _bsd_rman_reserve_resource
-#define	rman_reserve_resource_bound _bsd_rman_reserve_resource_bound
-#define	rman_set_bushandle _bsd_rman_set_bushandle
-#define	rman_set_bustag _bsd_rman_set_bustag
-#define	rman_set_device _bsd_rman_set_device
-#define	rman_set_end _bsd_rman_set_end
-#define	rman_set_irq_cookie _bsd_rman_set_irq_cookie
-#define	rman_set_mapping _bsd_rman_set_mapping
-#define	rman_set_rid _bsd_rman_set_rid
-#define	rman_set_start _bsd_rman_set_start
-#define	rman_set_virtual _bsd_rman_set_virtual
-#define	RMD160Final _bsd_RMD160Final
-#define	RMD160Init _bsd_RMD160Init
-#define	RMD160Transform _bsd_RMD160Transform
-#define	RMD160Update _bsd_RMD160Update
-#define	rn4_mpath_inithead _bsd_rn4_mpath_inithead
-#define	rn6_mpath_inithead _bsd_rn6_mpath_inithead
-#define	rn_addroute _bsd_rn_addroute
-#define	rn_delete _bsd_rn_delete
-#define	rn_detachhead _bsd_rn_detachhead
-#define	rn_inithead _bsd_rn_inithead
-#define	rn_inithead_internal _bsd_rn_inithead_internal
-#define	rn_lookup _bsd_rn_lookup
-#define	rn_match _bsd_rn_match
-#define	rn_mpath_capable _bsd_rn_mpath_capable
-#define	rn_mpath_count _bsd_rn_mpath_count
-#define	rn_mpath_next _bsd_rn_mpath_next
-#define	rn_refines _bsd_rn_refines
-#define	rn_walktree _bsd_rn_walktree
-#define	rn_walktree_from _bsd_rn_walktree_from
-#define	root_bus _bsd_root_bus
-#define	root_bus_configure _bsd_root_bus_configure
-#define	root_devclass _bsd_root_devclass
-#define	route6_input _bsd_route6_input
-#define	rsvp_input _bsd_rsvp_input
-#define	rsvp_input_p _bsd_rsvp_input_p
-#define	rsvp_on _bsd_rsvp_on
-#define	rt3070_freqs _bsd_rt3070_freqs
-#define	rt6_flush _bsd_rt6_flush
-#define	rt_add_addr_allfibs _bsd_rt_add_addr_allfibs
-#define	rt_addrmsg _bsd_rt_addrmsg
-#define	rtalloc1 _bsd_rtalloc1
-#define	rtalloc1_fib _bsd_rtalloc1_fib
-#define	rtalloc_ign_fib _bsd_rtalloc_ign_fib
-#define	rtalloc_mpath_fib _bsd_rtalloc_mpath_fib
-#define	rt_flushifroutes _bsd_rt_flushifroutes
-#define	rt_flushifroutes_af _bsd_rt_flushifroutes_af
-#define	rt_foreach_fib_walk _bsd_rt_foreach_fib_walk
-#define	rt_foreach_fib_walk_del _bsd_rt_foreach_fib_walk_del
-#define	rtfree _bsd_rtfree
-#define	rt_getifa_fib _bsd_rt_getifa_fib
-#define	rt_ieee80211msg _bsd_rt_ieee80211msg
-#define	rt_ifannouncemsg _bsd_rt_ifannouncemsg
-#define	rt_ifmsg _bsd_rt_ifmsg
-#define	rtinit _bsd_rtinit
-#define	rtioctl_fib _bsd_rtioctl_fib
-#define	rt_maskedcopy _bsd_rt_maskedcopy
-#define	rt_missmsg _bsd_rt_missmsg
-#define	rt_missmsg_fib _bsd_rt_missmsg_fib
-#define	rt_mpath_capable _bsd_rt_mpath_capable
-#define	rt_mpath_conflict _bsd_rt_mpath_conflict
-#define	rt_mpath_deldup _bsd_rt_mpath_deldup
-#define	rt_mpath_matchgate _bsd_rt_mpath_matchgate
-#define	rt_mpath_select _bsd_rt_mpath_select
-#define	rt_newaddrmsg _bsd_rt_newaddrmsg
-#define	rt_newaddrmsg_fib _bsd_rt_newaddrmsg_fib
-#define	rt_newmaddrmsg _bsd_rt_newmaddrmsg
-#define	rt_numfibs _bsd_rt_numfibs
-#define	rto_logging _bsd_rto_logging
-#define	rtredirect_fib _bsd_rtredirect_fib
-#define	rtrequest1_fib _bsd_rtrequest1_fib
-#define	rtrequest_fib _bsd_rtrequest_fib
-#define	rt_routemsg _bsd_rt_routemsg
-#define	rt_setgate _bsd_rt_setgate
-#define	rtsock_addrmsg _bsd_rtsock_addrmsg
-#define	rtsock_mtx _bsd_rtsock_mtx
-#define	rtsock_routemsg _bsd_rtsock_routemsg
-#define	rtstat _bsd_rtstat
-#define	rt_table_destroy _bsd_rt_table_destroy
-#define	rt_table_init _bsd_rt_table_init
-#define	rt_tables _bsd_rt_tables
-#define	rt_tables_get_gen _bsd_rt_tables_get_gen
-#define	rt_tables_get_rnh _bsd_rt_tables_get_rnh
-#define	rttrash _bsd_rttrash
-#define	rt_updatemtu _bsd_rt_updatemtu
-#define	rtwn_adhoc_recv_mgmt _bsd_rtwn_adhoc_recv_mgmt
-#define	rtwn_attach _bsd_rtwn_attach
-#define	rtwn_bulk_rx_callback _bsd_rtwn_bulk_rx_callback
-#define	rtwn_bulk_tx_callback _bsd_rtwn_bulk_tx_callback
-#define	rtwn_calib_to _bsd_rtwn_calib_to
-#define	rtwn_cmdq_destroy _bsd_rtwn_cmdq_destroy
-#define	rtwn_cmdq_init _bsd_rtwn_cmdq_init
-#define	rtwn_cmd_sleepable _bsd_rtwn_cmd_sleepable
-#define	rtwn_detach _bsd_rtwn_detach
-#define	rtwn_drain_mbufq _bsd_rtwn_drain_mbufq
-#define	rtwn_efuse_read_next _bsd_rtwn_efuse_read_next
-#define	rtwn_get_rates _bsd_rtwn_get_rates
-#define	rtwn_init_cam _bsd_rtwn_init_cam
-#define	rtwn_init_seccfg _bsd_rtwn_init_seccfg
-#define	rtwn_init_static_keys _bsd_rtwn_init_static_keys
-#define	rtwn_key_alloc _bsd_rtwn_key_alloc
-#define	rtwn_key_delete _bsd_rtwn_key_delete
-#define	rtwn_key_set _bsd_rtwn_key_set
-#define	rtwn_load_firmware _bsd_rtwn_load_firmware
-#define	rtwn_pci_delay _bsd_rtwn_pci_delay
-#define	rtwn_pci_dma_map_addr _bsd_rtwn_pci_dma_map_addr
-#define	rtwn_pci_intr _bsd_rtwn_pci_intr
-#define	rtwn_pci_read_1 _bsd_rtwn_pci_read_1
-#define	rtwn_pci_read_2 _bsd_rtwn_pci_read_2
-#define	rtwn_pci_read_4 _bsd_rtwn_pci_read_4
-#define	rtwn_pci_setup_rx_desc _bsd_rtwn_pci_setup_rx_desc
-#define	rtwn_pci_tx_start _bsd_rtwn_pci_tx_start
-#define	rtwn_pci_write_1 _bsd_rtwn_pci_write_1
-#define	rtwn_pci_write_2 _bsd_rtwn_pci_write_2
-#define	rtwn_pci_write_4 _bsd_rtwn_pci_write_4
-#define	rtwn_raw_xmit _bsd_rtwn_raw_xmit
-#define	rtwn_read_rom _bsd_rtwn_read_rom
-#define	rtwn_resume _bsd_rtwn_resume
-#define	rtwn_rx_common _bsd_rtwn_rx_common
-#define	rtwn_rxfilter_init _bsd_rtwn_rxfilter_init
-#define	rtwn_rxfilter_set _bsd_rtwn_rxfilter_set
-#define	rtwn_rxfilter_update _bsd_rtwn_rxfilter_update
-#define	rtwn_set_basicrates _bsd_rtwn_set_basicrates
-#define	rtwn_set_multi _bsd_rtwn_set_multi
-#define	rtwn_set_promisc _bsd_rtwn_set_promisc
-#define	rtwn_set_rx_bssid_all _bsd_rtwn_set_rx_bssid_all
-#define	rtwn_setup_beacon _bsd_rtwn_setup_beacon
-#define	rtwn_start _bsd_rtwn_start
-#define	rtwn_suspend _bsd_rtwn_suspend
-#define	rtwn_switch_bcnq _bsd_rtwn_switch_bcnq
-#define	rtwn_sysctlattach _bsd_rtwn_sysctlattach
-#define	rtwn_transmit _bsd_rtwn_transmit
-#define	rtwn_tx_beacon_check _bsd_rtwn_tx_beacon_check
-#define	rtwn_tx_beacon_csa _bsd_rtwn_tx_beacon_csa
-#define	rtwn_update_beacon _bsd_rtwn_update_beacon
-#define	rtwn_usb_delay _bsd_rtwn_usb_delay
-#define	rtwn_usb_get_qmap _bsd_rtwn_usb_get_qmap
-#define	rtwn_usb_read_1 _bsd_rtwn_usb_read_1
-#define	rtwn_usb_read_2 _bsd_rtwn_usb_read_2
-#define	rtwn_usb_read_4 _bsd_rtwn_usb_read_4
-#define	rtwn_usb_setup_endpoints _bsd_rtwn_usb_setup_endpoints
-#define	rtwn_usb_tx_start _bsd_rtwn_usb_tx_start
-#define	rtwn_usb_write_1 _bsd_rtwn_usb_write_1
-#define	rtwn_usb_write_2 _bsd_rtwn_usb_write_2
-#define	rtwn_usb_write_4 _bsd_rtwn_usb_write_4
-#define	rtwn_usb_write_region_1 _bsd_rtwn_usb_write_region_1
-#define	run_debug _bsd_run_debug
-#define	rw_destroy _bsd_rw_destroy
-#define	_rw_downgrade _bsd__rw_downgrade
-#define	rw_init_flags _bsd_rw_init_flags
-#define	_rw_rlock _bsd__rw_rlock
-#define	_rw_runlock _bsd__rw_runlock
-#define	rw_sysinit _bsd_rw_sysinit
-#define	_rw_try_rlock _bsd__rw_try_rlock
-#define	_rw_try_upgrade _bsd__rw_try_upgrade
-#define	_rw_try_wlock _bsd__rw_try_wlock
-#define	_rw_wlock _bsd__rw_wlock
-#define	rw_wowned _bsd_rw_wowned
-#define	_rw_wunlock _bsd__rw_wunlock
-#define	sa6_any _bsd_sa6_any
-#define	sa6_checkzone _bsd_sa6_checkzone
-#define	sa6_checkzone_ifp _bsd_sa6_checkzone_ifp
-#define	sa6_embedscope _bsd_sa6_embedscope
-#define	sa6_recoverscope _bsd_sa6_recoverscope
-#define	sack_array _bsd_sack_array
-#define	sack_hole_zone _bsd_sack_hole_zone
-#define	saf1761_otg_filter_interrupt _bsd_saf1761_otg_filter_interrupt
-#define	saf1761_otg_init _bsd_saf1761_otg_init
-#define	saf1761_otg_interrupt _bsd_saf1761_otg_interrupt
-#define	saf1761_otg_uninit _bsd_saf1761_otg_uninit
-#define	sballoc _bsd_sballoc
-#define	sbappend _bsd_sbappend
-#define	sbappendaddr _bsd_sbappendaddr
-#define	sbappendaddr_locked _bsd_sbappendaddr_locked
-#define	sbappendaddr_nospacecheck_locked _bsd_sbappendaddr_nospacecheck_locked
-#define	sbappendcontrol _bsd_sbappendcontrol
-#define	sbappendcontrol_locked _bsd_sbappendcontrol_locked
-#define	sbappend_locked _bsd_sbappend_locked
-#define	sbappendrecord _bsd_sbappendrecord
-#define	sbappendrecord_locked _bsd_sbappendrecord_locked
-#define	sbappendstream _bsd_sbappendstream
-#define	sbappendstream_locked _bsd_sbappendstream_locked
-#define	sbcompress _bsd_sbcompress
-#define	sbcreatecontrol _bsd_sbcreatecontrol
-#define	sbcut_locked _bsd_sbcut_locked
-#define	sbdestroy _bsd_sbdestroy
-#define	sbdrop _bsd_sbdrop
-#define	sbdrop_locked _bsd_sbdrop_locked
-#define	sbdroprecord _bsd_sbdroprecord
-#define	sbdroprecord_locked _bsd_sbdroprecord_locked
-#define	sbflush _bsd_sbflush
-#define	sbflush_locked _bsd_sbflush_locked
-#define	sbfree _bsd_sbfree
-#define	sblock _bsd_sblock
-#define	sb_max _bsd_sb_max
-#define	sb_max_adj _bsd_sb_max_adj
-#define	sbready _bsd_sbready
-#define	sbrelease _bsd_sbrelease
-#define	sbrelease_internal _bsd_sbrelease_internal
-#define	sbrelease_locked _bsd_sbrelease_locked
-#define	sbreserve_locked _bsd_sbreserve_locked
-#define	sbsetopt _bsd_sbsetopt
-#define	sbsndmbuf _bsd_sbsndmbuf
-#define	sbsndptr _bsd_sbsndptr
-#define	sbsndptr_adv _bsd_sbsndptr_adv
-#define	sbsndptr_noadv _bsd_sbsndptr_noadv
-#define	sbtoxsockbuf _bsd_sbtoxsockbuf
-#define	sbt_tickthreshold _bsd_sbt_tickthreshold
-#define	sbt_timethreshold _bsd_sbt_timethreshold
-#define	sbuf_bcat _bsd_sbuf_bcat
-#define	sbuf_bcopyin _bsd_sbuf_bcopyin
-#define	sbuf_bcpy _bsd_sbuf_bcpy
-#define	sbuf_cat _bsd_sbuf_cat
-#define	sbuf_clear _bsd_sbuf_clear
-#define	sbuf_clear_flags _bsd_sbuf_clear_flags
-#define	sbuf_copyin _bsd_sbuf_copyin
-#define	sbuf_count_drain _bsd_sbuf_count_drain
-#define	sbuf_cpy _bsd_sbuf_cpy
-#define	sbuf_data _bsd_sbuf_data
-#define	sbuf_delete _bsd_sbuf_delete
-#define	sbuf_done _bsd_sbuf_done
-#define	sbuf_end_section _bsd_sbuf_end_section
-#define	sbuf_error _bsd_sbuf_error
-#define	sbuf_finish _bsd_sbuf_finish
-#define	sbuf_get_flags _bsd_sbuf_get_flags
-#define	sbuf_hexdump _bsd_sbuf_hexdump
-#define	sbuf_len _bsd_sbuf_len
-#define	sbuf_new _bsd_sbuf_new
-#define	sbuf_new_for_sysctl _bsd_sbuf_new_for_sysctl
-#define	sbuf_nl_terminate _bsd_sbuf_nl_terminate
-#define	sbuf_printf _bsd_sbuf_printf
-#define	sbuf_printf_drain _bsd_sbuf_printf_drain
-#define	sbuf_printf_uuid _bsd_sbuf_printf_uuid
-#define	sbuf_putbuf _bsd_sbuf_putbuf
-#define	sbuf_putc _bsd_sbuf_putc
-#define	sbuf_set_drain _bsd_sbuf_set_drain
-#define	sbuf_set_flags _bsd_sbuf_set_flags
-#define	sbuf_setpos _bsd_sbuf_setpos
-#define	sbuf_start_section _bsd_sbuf_start_section
-#define	sbuf_trim _bsd_sbuf_trim
-#define	sbuf_uionew _bsd_sbuf_uionew
-#define	sbuf_vprintf _bsd_sbuf_vprintf
-#define	sbunlock _bsd_sbunlock
-#define	sbwait _bsd_sbwait
-#define	scope6_addr2default _bsd_scope6_addr2default
-#define	scope6_get_default _bsd_scope6_get_default
-#define	scope6_ifattach _bsd_scope6_ifattach
-#define	scope6_ifdetach _bsd_scope6_ifdetach
-#define	scope6_init _bsd_scope6_init
-#define	scope6_ioctl _bsd_scope6_ioctl
-#define	scope6_setdefault _bsd_scope6_setdefault
-#define	scsi_attrib_ascii_sbuf _bsd_scsi_attrib_ascii_sbuf
-#define	scsi_attrib_hexdump_sbuf _bsd_scsi_attrib_hexdump_sbuf
-#define	scsi_attrib_int_sbuf _bsd_scsi_attrib_int_sbuf
-#define	scsi_attrib_prefix_sbuf _bsd_scsi_attrib_prefix_sbuf
-#define	scsi_attrib_sbuf _bsd_scsi_attrib_sbuf
-#define	scsi_attrib_text_sbuf _bsd_scsi_attrib_text_sbuf
-#define	scsi_attrib_value_sbuf _bsd_scsi_attrib_value_sbuf
-#define	scsi_attrib_vendser_sbuf _bsd_scsi_attrib_vendser_sbuf
-#define	scsi_attrib_volcoh_sbuf _bsd_scsi_attrib_volcoh_sbuf
-#define	scsi_devid_is_lun_eui64 _bsd_scsi_devid_is_lun_eui64
-#define	scsi_devid_is_lun_md5 _bsd_scsi_devid_is_lun_md5
-#define	scsi_devid_is_lun_naa _bsd_scsi_devid_is_lun_naa
-#define	scsi_devid_is_lun_name _bsd_scsi_devid_is_lun_name
-#define	scsi_devid_is_lun_t10 _bsd_scsi_devid_is_lun_t10
-#define	scsi_devid_is_lun_uuid _bsd_scsi_devid_is_lun_uuid
-#define	scsi_devid_is_naa_ieee_reg _bsd_scsi_devid_is_naa_ieee_reg
-#define	scsi_devid_is_port_naa _bsd_scsi_devid_is_port_naa
-#define	scsi_devid_is_sas_target _bsd_scsi_devid_is_sas_target
-#define	scsi_extract_sense_len _bsd_scsi_extract_sense_len
-#define	scsi_find_attrib_entry _bsd_scsi_find_attrib_entry
-#define	scsi_get_attrib_entry _bsd_scsi_get_attrib_entry
-#define	scsi_get_devid _bsd_scsi_get_devid
-#define	scsi_get_devid_desc _bsd_scsi_get_devid_desc
-#define	scsi_get_nv _bsd_scsi_get_nv
-#define	scsi_get_sense_key _bsd_scsi_get_sense_key
-#define	scsi_inquiry _bsd_scsi_inquiry
-#define	scsi_log_select _bsd_scsi_log_select
-#define	scsi_log_sense _bsd_scsi_log_sense
-#define	scsi_mam_attr_table _bsd_scsi_mam_attr_table
-#define	scsi_mode_select _bsd_scsi_mode_select
-#define	scsi_mode_select_len _bsd_scsi_mode_select_len
-#define	scsi_mode_sense _bsd_scsi_mode_sense
-#define	scsi_mode_sense_len _bsd_scsi_mode_sense_len
-#define	scsi_mode_sense_subpage _bsd_scsi_mode_sense_subpage
-#define	scsi_nv_to_str _bsd_scsi_nv_to_str
-#define	scsi_parse_transportid _bsd_scsi_parse_transportid
-#define	scsi_parse_transportid_64bit _bsd_scsi_parse_transportid_64bit
-#define	scsi_parse_transportid_iscsi _bsd_scsi_parse_transportid_iscsi
-#define	scsi_parse_transportid_rdma _bsd_scsi_parse_transportid_rdma
-#define	scsi_parse_transportid_sop _bsd_scsi_parse_transportid_sop
-#define	scsi_parse_transportid_spi _bsd_scsi_parse_transportid_spi
-#define	scsi_prevent _bsd_scsi_prevent
-#define	scsi_print_inquiry _bsd_scsi_print_inquiry
-#define	scsi_print_inquiry_sbuf _bsd_scsi_print_inquiry_sbuf
-#define	scsi_print_inquiry_short _bsd_scsi_print_inquiry_short
-#define	scsi_print_inquiry_short_sbuf _bsd_scsi_print_inquiry_short_sbuf
-#define	scsi_proto_map _bsd_scsi_proto_map
-#define	scsi_read_capacity _bsd_scsi_read_capacity
-#define	scsi_read_write _bsd_scsi_read_write
-#define	scsi_request_sense _bsd_scsi_request_sense
-#define	scsi_set_sense_data _bsd_scsi_set_sense_data
-#define	scsi_set_sense_data_len _bsd_scsi_set_sense_data_len
-#define	scsi_set_sense_data_va _bsd_scsi_set_sense_data_va
-#define	scsi_test_unit_ready _bsd_scsi_test_unit_ready
-#define	scsi_transportid_sbuf _bsd_scsi_transportid_sbuf
-#define	scsi_write_same _bsd_scsi_write_same
-#define	SCTP6_ARE_ADDR_EQUAL _bsd_SCTP6_ARE_ADDR_EQUAL
-#define	sctp6_ctlinput _bsd_sctp6_ctlinput
-#define	sctp6_input _bsd_sctp6_input
-#define	sctp6_input_with_port _bsd_sctp6_input_with_port
-#define	sctp6_notify _bsd_sctp6_notify
-#define	sctp6_usrreqs _bsd_sctp6_usrreqs
-#define	sctp_abort_an_association _bsd_sctp_abort_an_association
-#define	sctp_abort_association _bsd_sctp_abort_association
-#define	sctp_abort_notification _bsd_sctp_abort_notification
-#define	sctp_accept _bsd_sctp_accept
-#define	sctp_add_addresses_to_i_ia _bsd_sctp_add_addresses_to_i_ia
-#define	sctp_add_addr_to_vrf _bsd_sctp_add_addr_to_vrf
-#define	sctp_add_auth_chunk _bsd_sctp_add_auth_chunk
-#define	sctp_add_local_addr_ep _bsd_sctp_add_local_addr_ep
-#define	sctp_add_local_addr_restricted _bsd_sctp_add_local_addr_restricted
-#define	sctp_add_or_del_interfaces _bsd_sctp_add_or_del_interfaces
-#define	sctp_add_pad_tombuf _bsd_sctp_add_pad_tombuf
-#define	sctp_addr_change _bsd_sctp_addr_change
-#define	sctp_add_remote_addr _bsd_sctp_add_remote_addr
-#define	sctp_addr_mgmt_ep_sa _bsd_sctp_addr_mgmt_ep_sa
-#define	sctp_add_stream_reset_result _bsd_sctp_add_stream_reset_result
-#define	sctp_add_stream_reset_result_tsn _bsd_sctp_add_stream_reset_result_tsn
-#define	sctp_add_substate _bsd_sctp_add_substate
-#define	sctp_add_to_readq _bsd_sctp_add_to_readq
-#define	sctp_add_vtag_to_timewait _bsd_sctp_add_vtag_to_timewait
-#define	SctpAlias _bsd_SctpAlias
-#define	sctp_allocate_vrf _bsd_sctp_allocate_vrf
-#define	sctp_alloc_authinfo _bsd_sctp_alloc_authinfo
-#define	sctp_alloc_chunklist _bsd_sctp_alloc_chunklist
-#define	sctp_alloc_hmaclist _bsd_sctp_alloc_hmaclist
-#define	sctp_alloc_key _bsd_sctp_alloc_key
-#define	sctp_alloc_sharedkey _bsd_sctp_alloc_sharedkey
-#define	sctp_aloc_assoc _bsd_sctp_aloc_assoc
-#define	sctp_arethere_unrecognized_parameters _bsd_sctp_arethere_unrecognized_parameters
-#define	sctp_asconf_cleanup _bsd_sctp_asconf_cleanup
-#define	sctp_asconf_iterator_end _bsd_sctp_asconf_iterator_end
-#define	sctp_asconf_iterator_ep _bsd_sctp_asconf_iterator_ep
-#define	sctp_asconf_iterator_stcb _bsd_sctp_asconf_iterator_stcb
-#define	sctp_asconf_send_nat_state_update _bsd_sctp_asconf_send_nat_state_update
-#define	sctp_asconf_timer _bsd_sctp_asconf_timer
-#define	sctp_assoc_immediate_retrans _bsd_sctp_assoc_immediate_retrans
-#define	sctp_audit_retranmission_queue _bsd_sctp_audit_retranmission_queue
-#define	sctp_auth_add_chunk _bsd_sctp_auth_add_chunk
-#define	sctp_auth_add_hmacid _bsd_sctp_auth_add_hmacid
-#define	sctp_auth_delete_chunk _bsd_sctp_auth_delete_chunk
-#define	sctp_auth_get_chklist_size _bsd_sctp_auth_get_chklist_size
-#define	sctp_auth_get_cookie_params _bsd_sctp_auth_get_cookie_params
-#define	sctp_auth_is_supported_hmac _bsd_sctp_auth_is_supported_hmac
-#define	sctp_auth_key_acquire _bsd_sctp_auth_key_acquire
-#define	sctp_auth_key_release _bsd_sctp_auth_key_release
-#define	sctp_auth_setactivekey _bsd_sctp_auth_setactivekey
-#define	sctp_auth_setactivekey_ep _bsd_sctp_auth_setactivekey_ep
-#define	sctp_autoclose_timer _bsd_sctp_autoclose_timer
-#define	sctp_bindx_add_address _bsd_sctp_bindx_add_address
-#define	sctp_bindx_delete_address _bsd_sctp_bindx_delete_address
-#define	sctp_build_ctl_nchunk _bsd_sctp_build_ctl_nchunk
-#define	sctp_build_readq_entry _bsd_sctp_build_readq_entry
-#define	sctp_calc_rwnd _bsd_sctp_calc_rwnd
-#define	sctp_calculate_cksum _bsd_sctp_calculate_cksum
-#define	sctp_calculate_len _bsd_sctp_calculate_len
-#define	sctp_calculate_rto _bsd_sctp_calculate_rto
-#define	sctp_can_peel_off _bsd_sctp_can_peel_off
-#define	sctp_cc_functions _bsd_sctp_cc_functions
-#define	sctp_check_address_list _bsd_sctp_check_address_list
-#define	sctp_CheckTimers _bsd_sctp_CheckTimers
-#define	sctp_chunk_output _bsd_sctp_chunk_output
-#define	sctp_clean_up_stream _bsd_sctp_clean_up_stream
-#define	sctp_clear_cachedkeys _bsd_sctp_clear_cachedkeys
-#define	sctp_clear_cachedkeys_ep _bsd_sctp_clear_cachedkeys_ep
-#define	sctp_clear_chunklist _bsd_sctp_clear_chunklist
-#define	sctp_close _bsd_sctp_close
-#define	sctp_cmpaddr _bsd_sctp_cmpaddr
-#define	sctp_common_input_processing _bsd_sctp_common_input_processing
-#define	sctp_compose_asconf _bsd_sctp_compose_asconf
-#define	sctp_compute_hashkey _bsd_sctp_compute_hashkey
-#define	sctp_compute_hmac _bsd_sctp_compute_hmac
-#define	sctp_compute_hmac_m _bsd_sctp_compute_hmac_m
-#define	sctp_connectx_helper_add _bsd_sctp_connectx_helper_add
-#define	sctp_connectx_helper_find _bsd_sctp_connectx_helper_find
-#define	sctp_cookie_timer _bsd_sctp_cookie_timer
-#define	sctp_copy_chunklist _bsd_sctp_copy_chunklist
-#define	sctp_copy_hmaclist _bsd_sctp_copy_hmaclist
-#define	sctp_copy_skeylist _bsd_sctp_copy_skeylist
-#define	sctp_ctlinput _bsd_sctp_ctlinput
-#define	sctp_ctloutput _bsd_sctp_ctloutput
-#define	sctp_deact_sharedkey _bsd_sctp_deact_sharedkey
-#define	sctp_deact_sharedkey_ep _bsd_sctp_deact_sharedkey_ep
-#define	sctp_default_supported_hmaclist _bsd_sctp_default_supported_hmaclist
-#define	sctp_del_addr_from_vrf _bsd_sctp_del_addr_from_vrf
-#define	sctp_delete_from_timewait _bsd_sctp_delete_from_timewait
-#define	sctp_delete_prim_timer _bsd_sctp_delete_prim_timer
-#define	sctp_delete_sharedkey _bsd_sctp_delete_sharedkey
-#define	sctp_delete_sharedkey_ep _bsd_sctp_delete_sharedkey_ep
-#define	sctp_del_local_addr_ep _bsd_sctp_del_local_addr_ep
-#define	sctp_del_local_addr_restricted _bsd_sctp_del_local_addr_restricted
-#define	sctp_del_remote_addr _bsd_sctp_del_remote_addr
-#define	sctp_destination_is_reachable _bsd_sctp_destination_is_reachable
-#define	sctp_disconnect _bsd_sctp_disconnect
-#define	sctp_do_peeloff _bsd_sctp_do_peeloff
-#define	sctp_drain _bsd_sctp_drain
-#define	sctp_dynamic_set_primary _bsd_sctp_dynamic_set_primary
-#define	sctp_expand_mapping_array _bsd_sctp_expand_mapping_array
-#define	sctp_express_handle_sack _bsd_sctp_express_handle_sack
-#define	sctp_fill_hmac_digest_m _bsd_sctp_fill_hmac_digest_m
-#define	sctp_fill_pcbinfo _bsd_sctp_fill_pcbinfo
-#define	sctp_fill_random_store _bsd_sctp_fill_random_store
-#define	sctp_fill_stat_log _bsd_sctp_fill_stat_log
-#define	sctp_find_alternate_net _bsd_sctp_find_alternate_net
-#define	sctp_findasoc_ep_asocid_locked _bsd_sctp_findasoc_ep_asocid_locked
-#define	sctp_findassociation_addr _bsd_sctp_findassociation_addr
-#define	sctp_findassociation_addr_sa _bsd_sctp_findassociation_addr_sa
-#define	sctp_findassociation_ep_addr _bsd_sctp_findassociation_ep_addr
-#define	sctp_findassociation_ep_asconf _bsd_sctp_findassociation_ep_asconf
-#define	sctp_findassociation_ep_asocid _bsd_sctp_findassociation_ep_asocid
-#define	sctp_find_ifa_by_addr _bsd_sctp_find_ifa_by_addr
-#define	sctp_find_ifa_in_ep _bsd_sctp_find_ifa_in_ep
-#define	sctp_find_ifn _bsd_sctp_find_ifn
-#define	sctp_findnet _bsd_sctp_findnet
-#define	sctp_find_sharedkey _bsd_sctp_find_sharedkey
-#define	sctp_find_stream_reset _bsd_sctp_find_stream_reset
-#define	sctp_find_vrf _bsd_sctp_find_vrf
-#define	sctp_fix_ecn_echo _bsd_sctp_fix_ecn_echo
-#define	sctp_flush _bsd_sctp_flush
-#define	sctp_free_assoc _bsd_sctp_free_assoc
-#define	sctp_free_authinfo _bsd_sctp_free_authinfo
-#define	sctp_free_chunklist _bsd_sctp_free_chunklist
-#define	sctp_free_hmaclist _bsd_sctp_free_hmaclist
-#define	sctp_free_ifa _bsd_sctp_free_ifa
-#define	sctp_free_ifn _bsd_sctp_free_ifn
-#define	sctp_free_key _bsd_sctp_free_key
-#define	sctp_free_sharedkey _bsd_sctp_free_sharedkey
-#define	sctp_free_vrf _bsd_sctp_free_vrf
-#define	sctp_gather_internal_ifa_flags _bsd_sctp_gather_internal_ifa_flags
-#define	sctp_generate_cause _bsd_sctp_generate_cause
-#define	sctp_generate_no_user_data_cause _bsd_sctp_generate_no_user_data_cause
-#define	sctp_generate_random_key _bsd_sctp_generate_random_key
-#define	sctp_get_auth_chunk_len _bsd_sctp_get_auth_chunk_len
-#define	sctp_get_frag_point _bsd_sctp_get_frag_point
-#define	sctp_get_hmac_digest_len _bsd_sctp_get_hmac_digest_len
-#define	sctp_get_ifa_hash_val _bsd_sctp_get_ifa_hash_val
-#define	sctp_get_mbuf_for_msg _bsd_sctp_get_mbuf_for_msg
-#define	sctp_get_next_mtu _bsd_sctp_get_next_mtu
-#define	sctp_get_next_param _bsd_sctp_get_next_param
-#define	sctp_get_prev_mtu _bsd_sctp_get_prev_mtu
-#define	sctp_handle_asconf _bsd_sctp_handle_asconf
-#define	sctp_handle_asconf_ack _bsd_sctp_handle_asconf_ack
-#define	sctp_handle_auth _bsd_sctp_handle_auth
-#define	sctp_handle_forward_tsn _bsd_sctp_handle_forward_tsn
-#define	sctp_handle_ootb _bsd_sctp_handle_ootb
-#define	sctp_handle_sack _bsd_sctp_handle_sack
-#define	sctp_hc_get_mtu _bsd_sctp_hc_get_mtu
-#define	sctp_hc_set_mtu _bsd_sctp_hc_set_mtu
-#define	sctp_heartbeat_timer _bsd_sctp_heartbeat_timer
-#define	sctp_hmac _bsd_sctp_hmac
-#define	sctp_hmac_m _bsd_sctp_hmac_m
-#define	sctp_ingetaddr _bsd_sctp_ingetaddr
-#define	sctp_init _bsd_sctp_init
-#define	sctp_init_asoc _bsd_sctp_init_asoc
-#define	sctp_initialize_auth_params _bsd_sctp_initialize_auth_params
-#define	sctp_initiate_iterator _bsd_sctp_initiate_iterator
-#define	sctp_init_sysctls _bsd_sctp_init_sysctls
-#define	sctp_init_vrf_list _bsd_sctp_init_vrf_list
-#define	sctp_inpcb_alloc _bsd_sctp_inpcb_alloc
-#define	sctp_inpcb_bind _bsd_sctp_inpcb_bind
-#define	sctp_inpcb_free _bsd_sctp_inpcb_free
-#define	sctp_input _bsd_sctp_input
-#define	sctp_input_with_port _bsd_sctp_input_with_port
-#define	sctp_insert_sharedkey _bsd_sctp_insert_sharedkey
-#define	sctp_is_address_in_scope _bsd_sctp_is_address_in_scope
-#define	sctp_is_address_on_local_host _bsd_sctp_is_address_on_local_host
-#define	sctp_is_addr_in_ep _bsd_sctp_is_addr_in_ep
-#define	sctp_is_addr_pending _bsd_sctp_is_addr_pending
-#define	sctp_is_addr_restricted _bsd_sctp_is_addr_restricted
-#define	sctp_is_in_timewait _bsd_sctp_is_in_timewait
-#define	sctp_is_same_scope _bsd_sctp_is_same_scope
-#define	sctp_is_there_an_abort_here _bsd_sctp_is_there_an_abort_here
-#define	sctp_is_there_unsent_data _bsd_sctp_is_there_unsent_data
-#define	sctp_is_vtag_good _bsd_sctp_is_vtag_good
-#define	sctp_it_ctl _bsd_sctp_it_ctl
-#define	sctp_iterator_worker _bsd_sctp_iterator_worker
-#define	sctp_listen _bsd_sctp_listen
-#define	sctp_load_addresses_from_init _bsd_sctp_load_addresses_from_init
-#define	sctp_local_addr_count _bsd_sctp_local_addr_count
-#define	sctp_log_block _bsd_sctp_log_block
-#define	sctp_log_closing _bsd_sctp_log_closing
-#define	sctp_log_cwnd _bsd_sctp_log_cwnd
-#define	sctp_log_fr _bsd_sctp_log_fr
-#define	sctp_log_lock _bsd_sctp_log_lock
-#define	sctp_log_map _bsd_sctp_log_map
-#define	sctp_log_maxburst _bsd_sctp_log_maxburst
-#define	sctp_log_nagle_event _bsd_sctp_log_nagle_event
-#define	sctp_log_rwnd _bsd_sctp_log_rwnd
-#define	sctp_log_rwnd_set _bsd_sctp_log_rwnd_set
-#define	sctp_log_sack _bsd_sctp_log_sack
-#define	sctp_log_strm_del _bsd_sctp_log_strm_del
-#define	sctp_log_strm_del_alt _bsd_sctp_log_strm_del_alt
-#define	sctp_lower_sosend _bsd_sctp_lower_sosend
-#define	sctp_map_assoc_state _bsd_sctp_map_assoc_state
-#define	sctp_mark_ifa_addr_down _bsd_sctp_mark_ifa_addr_down
-#define	sctp_mark_ifa_addr_up _bsd_sctp_mark_ifa_addr_up
-#define	SCTP_M_ASC_ADDR _bsd_SCTP_M_ASC_ADDR
-#define	SCTP_M_ASC_IT _bsd_SCTP_M_ASC_IT
-#define	SCTP_M_AUTH_CL _bsd_SCTP_M_AUTH_CL
-#define	SCTP_M_AUTH_HL _bsd_SCTP_M_AUTH_HL
-#define	SCTP_M_AUTH_IF _bsd_SCTP_M_AUTH_IF
-#define	SCTP_M_AUTH_KY _bsd_SCTP_M_AUTH_KY
-#define	SCTP_M_CMSG _bsd_SCTP_M_CMSG
-#define	SCTP_M_COPYAL _bsd_SCTP_M_COPYAL
-#define	sctp_m_getptr _bsd_sctp_m_getptr
-#define	SCTP_M_IFA _bsd_SCTP_M_IFA
-#define	SCTP_M_IFN _bsd_SCTP_M_IFN
-#define	sctp_min_mtu _bsd_sctp_min_mtu
-#define	sctp_misc_ints _bsd_sctp_misc_ints
-#define	SCTP_M_ITER _bsd_SCTP_M_ITER
-#define	SCTP_M_MAP _bsd_SCTP_M_MAP
-#define	SCTP_M_MCORE _bsd_SCTP_M_MCORE
-#define	SCTP_M_MVRF _bsd_SCTP_M_MVRF
-#define	sctp_move_chunks_from_net _bsd_sctp_move_chunks_from_net
-#define	sctp_move_pcb_and_assoc _bsd_sctp_move_pcb_and_assoc
-#define	SCTP_M_SOCKOPT _bsd_SCTP_M_SOCKOPT
-#define	SCTP_M_STRESET _bsd_SCTP_M_STRESET
-#define	SCTP_M_STRMI _bsd_SCTP_M_STRMI
-#define	SCTP_M_STRMO _bsd_SCTP_M_STRMO
-#define	SCTP_M_TIMW _bsd_SCTP_M_TIMW
-#define	sctp_mtu_size_reset _bsd_sctp_mtu_size_reset
-#define	SCTP_M_VRF _bsd_SCTP_M_VRF
-#define	sctp_negotiate_hmacid _bsd_sctp_negotiate_hmacid
-#define	sctp_net_immediate_retrans _bsd_sctp_net_immediate_retrans
-#define	sctp_notify _bsd_sctp_notify
-#define	sctp_notify_authentication _bsd_sctp_notify_authentication
-#define	sctp_notify_stream_reset_add _bsd_sctp_notify_stream_reset_add
-#define	sctp_notify_stream_reset_tsn _bsd_sctp_notify_stream_reset_tsn
-#define	sctp_output _bsd_sctp_output
-#define	sctp_over_udp_start _bsd_sctp_over_udp_start
-#define	sctp_over_udp_stop _bsd_sctp_over_udp_stop
-#define	sctp_pack_auth_chunks _bsd_sctp_pack_auth_chunks
-#define	sctp_pad_lastmbuf _bsd_sctp_pad_lastmbuf
-#define	sctp_pathmtu_adjustment _bsd_sctp_pathmtu_adjustment
-#define	sctp_pathmtu_timer _bsd_sctp_pathmtu_timer
-#define	sctp_pcb_findep _bsd_sctp_pcb_findep
-#define	sctp_pcb_finish _bsd_sctp_pcb_finish
-#define	sctp_pcb_init _bsd_sctp_pcb_init
-#define	sctp_peeraddr _bsd_sctp_peeraddr
-#define	sctp_print_address _bsd_sctp_print_address
-#define	sctp_print_key _bsd_sctp_print_key
-#define	sctp_print_mapping_array _bsd_sctp_print_mapping_array
-#define	sctp_process_data _bsd_sctp_process_data
-#define	sctp_pull_off_control_to_new_inp _bsd_sctp_pull_off_control_to_new_inp
-#define	sctp_queue_op_err _bsd_sctp_queue_op_err
-#define	sctp_recover_scope _bsd_sctp_recover_scope
-#define	sctp_release_pr_sctp_chunk _bsd_sctp_release_pr_sctp_chunk
-#define	sctp_remove_net _bsd_sctp_remove_net
-#define	sctp_report_all_outbound _bsd_sctp_report_all_outbound
-#define	sctp_reset_in_stream _bsd_sctp_reset_in_stream
-#define	sctp_sack_check _bsd_sctp_sack_check
-#define	sctp_sblog _bsd_sctp_sblog
-#define	sctp_select_a_tag _bsd_sctp_select_a_tag
-#define	sctp_select_initial_TSN _bsd_sctp_select_initial_TSN
-#define	sctp_send_abort _bsd_sctp_send_abort
-#define	sctp_send_abort_tcb _bsd_sctp_send_abort_tcb
-#define	sctp_send_asconf _bsd_sctp_send_asconf
-#define	sctp_send_asconf_ack _bsd_sctp_send_asconf_ack
-#define	sctp_send_cookie_ack _bsd_sctp_send_cookie_ack
-#define	sctp_send_cookie_echo _bsd_sctp_send_cookie_echo
-#define	sctp_send_cwr _bsd_sctp_send_cwr
-#define	sctp_send_deferred_reset_response _bsd_sctp_send_deferred_reset_response
-#define	sctp_send_ecn_echo _bsd_sctp_send_ecn_echo
-#define	sctp_send_hb _bsd_sctp_send_hb
-#define	sctp_send_heartbeat_ack _bsd_sctp_send_heartbeat_ack
-#define	sctp_send_initiate _bsd_sctp_send_initiate
-#define	sctp_send_initiate_ack _bsd_sctp_send_initiate_ack
-#define	sctp_sendm _bsd_sctp_sendm
-#define	sctp_send_operr_to _bsd_sctp_send_operr_to
-#define	sctp_send_packet_dropped _bsd_sctp_send_packet_dropped
-#define	sctp_send_sack _bsd_sctp_send_sack
-#define	sctp_send_shutdown _bsd_sctp_send_shutdown
-#define	sctp_send_shutdown_ack _bsd_sctp_send_shutdown_ack
-#define	sctp_send_shutdown_complete _bsd_sctp_send_shutdown_complete
-#define	sctp_send_shutdown_complete2 _bsd_sctp_send_shutdown_complete2
-#define	sctp_send_stream_reset_out_if_possible _bsd_sctp_send_stream_reset_out_if_possible
-#define	sctp_send_str_reset_req _bsd_sctp_send_str_reset_req
-#define	sctp_serialize_auth_chunks _bsd_sctp_serialize_auth_chunks
-#define	sctp_serialize_hmaclist _bsd_sctp_serialize_hmaclist
-#define	sctp_set_key _bsd_sctp_set_key
-#define	sctp_set_primary_addr _bsd_sctp_set_primary_addr
-#define	sctp_set_primary_ip_address_sa _bsd_sctp_set_primary_ip_address_sa
-#define	sctp_set_rwnd _bsd_sctp_set_rwnd
-#define	sctp_set_state _bsd_sctp_set_state
-#define	SctpShowAliasStats _bsd_SctpShowAliasStats
-#define	sctp_show_key _bsd_sctp_show_key
-#define	sctp_shutdown _bsd_sctp_shutdown
-#define	sctp_shutdownack_timer _bsd_sctp_shutdownack_timer
-#define	sctp_shutdown_timer _bsd_sctp_shutdown_timer
-#define	sctp_slide_mapping_arrays _bsd_sctp_slide_mapping_arrays
-#define	sctp_soreceive _bsd_sctp_soreceive
-#define	sctp_sorecvmsg _bsd_sctp_sorecvmsg
-#define	sctp_sosend _bsd_sctp_sosend
-#define	sctp_source_address_selection _bsd_sctp_source_address_selection
-#define	sctp_startup_iterator _bsd_sctp_startup_iterator
-#define	sctp_stop_timers_for_shutdown _bsd_sctp_stop_timers_for_shutdown
-#define	sctp_strreset_timer _bsd_sctp_strreset_timer
-#define	sctp_swap_inpcb_for_listen _bsd_sctp_swap_inpcb_for_listen
-#define	sctp_t1init_timer _bsd_sctp_t1init_timer
-#define	sctp_t3rxt_timer _bsd_sctp_t3rxt_timer
-#define	sctp_timeout_handler _bsd_sctp_timeout_handler
-#define	sctp_timer_start _bsd_sctp_timer_start
-#define	sctp_timer_stop _bsd_sctp_timer_stop
-#define	sctp_toss_old_asconf _bsd_sctp_toss_old_asconf
-#define	sctp_toss_old_cookies _bsd_sctp_toss_old_cookies
-#define	sctp_try_advance_peer_ack_point _bsd_sctp_try_advance_peer_ack_point
-#define	sctp_ulp_notify _bsd_sctp_ulp_notify
-#define	sctp_unpack_auth_chunks _bsd_sctp_unpack_auth_chunks
-#define	sctp_update_acked _bsd_sctp_update_acked
-#define	sctp_update_ifn_mtu _bsd_sctp_update_ifn_mtu
-#define	sctp_usrreqs _bsd_sctp_usrreqs
-#define	sctp_v4src_match_nexthop _bsd_sctp_v4src_match_nexthop
-#define	sctp_v6src_match_nexthop _bsd_sctp_v6src_match_nexthop
-#define	sctp_validate_init_auth_params _bsd_sctp_validate_init_auth_params
-#define	sctp_verify_hmac_param _bsd_sctp_verify_hmac_param
-#define	sctp_wakeup_iterator _bsd_sctp_wakeup_iterator
-#define	sctp_wakeup_log _bsd_sctp_wakeup_log
-#define	sctp_wakeup_the_read_socket _bsd_sctp_wakeup_the_read_socket
-#define	sdhci_cleanup_slot _bsd_sdhci_cleanup_slot
-#define	sdhci_fdt_gpio_get_present _bsd_sdhci_fdt_gpio_get_present
-#define	sdhci_fdt_gpio_get_readonly _bsd_sdhci_fdt_gpio_get_readonly
-#define	sdhci_fdt_gpio_setup _bsd_sdhci_fdt_gpio_setup
-#define	sdhci_fdt_gpio_teardown _bsd_sdhci_fdt_gpio_teardown
-#define	sdhci_finish_data _bsd_sdhci_finish_data
-#define	sdhci_generic_acquire_host _bsd_sdhci_generic_acquire_host
-#define	sdhci_generic_get_card_present _bsd_sdhci_generic_get_card_present
-#define	sdhci_generic_get_ro _bsd_sdhci_generic_get_ro
-#define	sdhci_generic_intr _bsd_sdhci_generic_intr
-#define	sdhci_generic_min_freq _bsd_sdhci_generic_min_freq
-#define	sdhci_generic_read_ivar _bsd_sdhci_generic_read_ivar
-#define	sdhci_generic_release_host _bsd_sdhci_generic_release_host
-#define	sdhci_generic_request _bsd_sdhci_generic_request
-#define	sdhci_generic_resume _bsd_sdhci_generic_resume
-#define	sdhci_generic_retune _bsd_sdhci_generic_retune
-#define	sdhci_generic_set_uhs_timing _bsd_sdhci_generic_set_uhs_timing
-#define	sdhci_generic_suspend _bsd_sdhci_generic_suspend
-#define	sdhci_generic_switch_vccq _bsd_sdhci_generic_switch_vccq
-#define	sdhci_generic_tune _bsd_sdhci_generic_tune
-#define	sdhci_generic_update_ios _bsd_sdhci_generic_update_ios
-#define	sdhci_generic_write_ivar _bsd_sdhci_generic_write_ivar
-#define	sdhci_handle_card_present _bsd_sdhci_handle_card_present
-#define	sdhci_init_slot _bsd_sdhci_init_slot
-#define	sdhci_quirk_clear _bsd_sdhci_quirk_clear
-#define	sdhci_quirk_set _bsd_sdhci_quirk_set
-#define	sdhci_start_slot _bsd_sdhci_start_slot
-#define	seldrain _bsd_seldrain
-#define	selrecord _bsd_selrecord
-#define	seltdfini _bsd_seltdfini
-#define	selwakeup _bsd_selwakeup
-#define	selwakeuppri _bsd_selwakeuppri
-#define	send_forward_tsn _bsd_send_forward_tsn
-#define	send_sendso_input_hook _bsd_send_sendso_input_hook
-#define	SetAckModified _bsd_SetAckModified
-#define	SetDefaultAliasAddress _bsd_SetDefaultAliasAddress
-#define	SetDestCallId _bsd_SetDestCallId
-#define	SetExpire _bsd_SetExpire
-#define	SetFragmentAddr _bsd_SetFragmentAddr
-#define	SetFragmentPtr _bsd_SetFragmentPtr
-#define	SetProtocolFlags _bsd_SetProtocolFlags
-#define	SetProxyAddress _bsd_SetProxyAddress
-#define	SetProxyPort _bsd_SetProxyPort
-#define	SetStateIn _bsd_SetStateIn
-#define	SetStateOut _bsd_SetStateOut
-#define	sha1_init _bsd_sha1_init
-#define	sha1_loop _bsd_sha1_loop
-#define	sha1_pad _bsd_sha1_pad
-#define	sha1_result _bsd_sha1_result
-#define	SHA256_Final _bsd_SHA256_Final
-#define	SHA256_Init _bsd_SHA256_Init
-#define	SHA256_Update _bsd_SHA256_Update
-#define	SHA384_Final _bsd_SHA384_Final
-#define	SHA384_Init _bsd_SHA384_Init
-#define	SHA384_Update _bsd_SHA384_Update
-#define	SHA512_Final _bsd_SHA512_Final
-#define	SHA512_Init _bsd_SHA512_Init
-#define	SHA512_Update _bsd_SHA512_Update
-#define	simplebus_add_device _bsd_simplebus_add_device
-#define	simplebus_driver _bsd_simplebus_driver
-#define	simplebus_fill_ranges _bsd_simplebus_fill_ranges
-#define	simplebus_init _bsd_simplebus_init
-#define	simplebus_setup_dinfo _bsd_simplebus_setup_dinfo
-#define	SipHash_End _bsd_SipHash_End
-#define	SipHash_Final _bsd_SipHash_Final
-#define	SipHash_InitX _bsd_SipHash_InitX
-#define	SipHash_SetKey _bsd_SipHash_SetKey
-#define	SipHash_Update _bsd_SipHash_Update
-#define	SipHashX _bsd_SipHashX
-#define	Skein1024_Final _bsd_Skein1024_Final
-#define	Skein1024_Final_Pad _bsd_Skein1024_Final_Pad
-#define	Skein1024_Init _bsd_Skein1024_Init
-#define	Skein1024_InitExt _bsd_Skein1024_InitExt
-#define	SKEIN1024_IV_1024 _bsd_SKEIN1024_IV_1024
-#define	SKEIN1024_IV_384 _bsd_SKEIN1024_IV_384
-#define	SKEIN1024_IV_512 _bsd_SKEIN1024_IV_512
-#define	Skein1024_Output _bsd_Skein1024_Output
-#define	Skein1024_Process_Block _bsd_Skein1024_Process_Block
-#define	Skein1024_Update _bsd_Skein1024_Update
-#define	Skein_256_Final _bsd_Skein_256_Final
-#define	Skein_256_Final_Pad _bsd_Skein_256_Final_Pad
-#define	Skein_256_Init _bsd_Skein_256_Init
-#define	Skein_256_InitExt _bsd_Skein_256_InitExt
-#define	SKEIN_256_IV_128 _bsd_SKEIN_256_IV_128
-#define	SKEIN_256_IV_160 _bsd_SKEIN_256_IV_160
-#define	SKEIN_256_IV_224 _bsd_SKEIN_256_IV_224
-#define	SKEIN_256_IV_256 _bsd_SKEIN_256_IV_256
-#define	Skein_256_Output _bsd_Skein_256_Output
-#define	Skein_256_Process_Block _bsd_Skein_256_Process_Block
-#define	Skein_256_Update _bsd_Skein_256_Update
-#define	Skein_512_Final _bsd_Skein_512_Final
-#define	Skein_512_Final_Pad _bsd_Skein_512_Final_Pad
-#define	Skein_512_Init _bsd_Skein_512_Init
-#define	Skein_512_InitExt _bsd_Skein_512_InitExt
-#define	SKEIN_512_IV_128 _bsd_SKEIN_512_IV_128
-#define	SKEIN_512_IV_160 _bsd_SKEIN_512_IV_160
-#define	SKEIN_512_IV_224 _bsd_SKEIN_512_IV_224
-#define	SKEIN_512_IV_256 _bsd_SKEIN_512_IV_256
-#define	SKEIN_512_IV_384 _bsd_SKEIN_512_IV_384
-#define	SKEIN_512_IV_512 _bsd_SKEIN_512_IV_512
-#define	Skein_512_Output _bsd_Skein_512_Output
-#define	Skein_512_Process_Block _bsd_Skein_512_Process_Block
-#define	Skein_512_Update _bsd_Skein_512_Update
-#define	skipjack_backwards _bsd_skipjack_backwards
-#define	skipjack_forwards _bsd_skipjack_forwards
-#define	sl_compress_init _bsd_sl_compress_init
-#define	sl_compress_tcp _bsd_sl_compress_tcp
-#define	_sleep _bsd__sleep
-#define	sleepq_add _bsd_sleepq_add
-#define	sleepq_alloc _bsd_sleepq_alloc
-#define	sleepq_broadcast _bsd_sleepq_broadcast
-#define	sleepq_chains_remove_matching _bsd_sleepq_chains_remove_matching
-#define	sleepq_free _bsd_sleepq_free
-#define	sleepq_lock _bsd_sleepq_lock
-#define	sleepq_lookup _bsd_sleepq_lookup
-#define	sleepq_release _bsd_sleepq_release
-#define	sleepq_remove _bsd_sleepq_remove
-#define	sleepq_remove_matching _bsd_sleepq_remove_matching
-#define	sleepq_set_timeout_sbt _bsd_sleepq_set_timeout_sbt
-#define	sleepq_signal _bsd_sleepq_signal
-#define	sleepq_sleepcnt _bsd_sleepq_sleepcnt
-#define	sleepq_timedwait _bsd_sleepq_timedwait
-#define	sleepq_type _bsd_sleepq_type
-#define	sleepq_wait _bsd_sleepq_wait
-#define	sl_uncompress_tcp _bsd_sl_uncompress_tcp
-#define	sl_uncompress_tcp_core _bsd_sl_uncompress_tcp_core
-#define	smc_attach _bsd_smc_attach
-#define	smc_detach _bsd_smc_detach
-#define	smc_devclass _bsd_smc_devclass
-#define	smc_miibus_readreg _bsd_smc_miibus_readreg
-#define	smc_miibus_statchg _bsd_smc_miibus_statchg
-#define	smc_miibus_writereg _bsd_smc_miibus_writereg
-#define	smc_probe _bsd_smc_probe
-#define	snprintf _bsd_snprintf
-#define	snprintf_uuid _bsd_snprintf_uuid
-#define	soabort _bsd_soabort
-#define	soaccept _bsd_soaccept
-#define	sobind _bsd_sobind
-#define	sobindat _bsd_sobindat
-#define	socantrcvmore _bsd_socantrcvmore
-#define	socantrcvmore_locked _bsd_socantrcvmore_locked
-#define	socantsendmore _bsd_socantsendmore
-#define	socantsendmore_locked _bsd_socantsendmore_locked
-#define	socketops _bsd_socketops
-#define	soclose _bsd_soclose
-#define	soconnect _bsd_soconnect
-#define	soconnect2 _bsd_soconnect2
-#define	soconnectat _bsd_soconnectat
-#define	socreate _bsd_socreate
-#define	sodisconnect _bsd_sodisconnect
-#define	sodium_memzero _bsd_sodium_memzero
-#define	sodtor_set _bsd_sodtor_set
-#define	sodupsockaddr _bsd_sodupsockaddr
-#define	so_error_get _bsd_so_error_get
-#define	so_error_set _bsd_so_error_set
-#define	sofree _bsd_sofree
-#define	so_gencnt _bsd_so_gencnt
-#define	sogetopt _bsd_sogetopt
-#define	sohasoutofband _bsd_sohasoutofband
-#define	soisconnected _bsd_soisconnected
-#define	soisconnecting _bsd_soisconnecting
-#define	soisdisconnected _bsd_soisdisconnected
-#define	soisdisconnecting _bsd_soisdisconnecting
-#define	so_linger_get _bsd_so_linger_get
-#define	so_linger_set _bsd_so_linger_set
-#define	solisten _bsd_solisten
-#define	solisten_dequeue _bsd_solisten_dequeue
-#define	solisten_proto _bsd_solisten_proto
-#define	solisten_proto_check _bsd_solisten_proto_check
-#define	solisten_upcall_set _bsd_solisten_upcall_set
-#define	solisten_wakeup _bsd_solisten_wakeup
-#define	so_lock _bsd_so_lock
-#define	sonewconn _bsd_sonewconn
-#define	soo_close _bsd_soo_close
-#define	soo_ioctl _bsd_soo_ioctl
-#define	soo_poll _bsd_soo_poll
-#define	sooptcopyin _bsd_sooptcopyin
-#define	sooptcopyout _bsd_sooptcopyout
-#define	soopt_getm _bsd_soopt_getm
-#define	so_options_get _bsd_so_options_get
-#define	so_options_set _bsd_so_options_set
-#define	soopt_mcopyin _bsd_soopt_mcopyin
-#define	soopt_mcopyout _bsd_soopt_mcopyout
-#define	soo_read _bsd_soo_read
-#define	soo_write _bsd_soo_write
-#define	sopoll _bsd_sopoll
-#define	sopoll_generic _bsd_sopoll_generic
-#define	so_protosw_get _bsd_so_protosw_get
-#define	so_protosw_set _bsd_so_protosw_set
-#define	soreceive _bsd_soreceive
-#define	soreceive_dgram _bsd_soreceive_dgram
-#define	soreceive_generic _bsd_soreceive_generic
-#define	soreserve _bsd_soreserve
-#define	sorflush _bsd_sorflush
-#define	sort_modes _bsd_sort_modes
-#define	sosend _bsd_sosend
-#define	sosend_dgram _bsd_sosend_dgram
-#define	sosend_generic _bsd_sosend_generic
-#define	sosetopt _bsd_sosetopt
-#define	so_setsockopt _bsd_so_setsockopt
-#define	soshutdown _bsd_soshutdown
-#define	so_sockbuf_rcv _bsd_so_sockbuf_rcv
-#define	so_sockbuf_snd _bsd_so_sockbuf_snd
-#define	so_sorwakeup _bsd_so_sorwakeup
-#define	so_sorwakeup_locked _bsd_so_sorwakeup_locked
-#define	so_sotoinpcb _bsd_so_sotoinpcb
-#define	so_sototcpcb _bsd_so_sototcpcb
-#define	so_sowwakeup _bsd_so_sowwakeup
-#define	so_sowwakeup_locked _bsd_so_sowwakeup_locked
-#define	so_state_get _bsd_so_state_get
-#define	so_state_set _bsd_so_state_set
-#define	sotoxsocket _bsd_sotoxsocket
-#define	so_unlock _bsd_so_unlock
-#define	soupcall_clear _bsd_soupcall_clear
-#define	soupcall_set _bsd_soupcall_set
-#define	sowakeup _bsd_sowakeup
-#define	sppp_attach _bsd_sppp_attach
-#define	sppp_dequeue _bsd_sppp_dequeue
-#define	sppp_detach _bsd_sppp_detach
-#define	sppp_flush _bsd_sppp_flush
-#define	sppp_fr_header _bsd_sppp_fr_header
-#define	sppp_fr_input _bsd_sppp_fr_input
-#define	sppp_fr_keepalive _bsd_sppp_fr_keepalive
-#define	sppp_get_ip_addrs _bsd_sppp_get_ip_addrs
-#define	sppp_input _bsd_sppp_input
-#define	sppp_ioctl _bsd_sppp_ioctl
-#define	sppp_isempty _bsd_sppp_isempty
-#define	sppp_pick _bsd_sppp_pick
-#define	sprintf _bsd_sprintf
-#define	_start_set_crypto_set _bsd__start_set_crypto_set
-#define	_start_set_ieee80211_ioctl_getset _bsd__start_set_ieee80211_ioctl_getset
-#define	_start_set_ieee80211_ioctl_setset _bsd__start_set_ieee80211_ioctl_setset
-#define	_start_set_kbddriver_set _bsd__start_set_kbddriver_set
-#define	_start_set_modmetadata_set _bsd__start_set_modmetadata_set
-#define	_start_set_nexus _bsd__start_set_nexus
-#define	_start_set_ratectl_set _bsd__start_set_ratectl_set
-#define	_start_set_scanner_set _bsd__start_set_scanner_set
-#define	_start_set_sysctl_set _bsd__start_set_sysctl_set
-#define	_start_set_sysinit_set _bsd__start_set_sysinit_set
-#define	_stop_set_crypto_set _bsd__stop_set_crypto_set
-#define	_stop_set_ieee80211_ioctl_getset _bsd__stop_set_ieee80211_ioctl_getset
-#define	_stop_set_ieee80211_ioctl_setset _bsd__stop_set_ieee80211_ioctl_setset
-#define	_stop_set_kbddriver_set _bsd__stop_set_kbddriver_set
-#define	_stop_set_modmetadata_set _bsd__stop_set_modmetadata_set
-#define	_stop_set_nexus _bsd__stop_set_nexus
-#define	_stop_set_ratectl_set _bsd__stop_set_ratectl_set
-#define	_stop_set_scanner_set _bsd__stop_set_scanner_set
-#define	_stop_set_sysctl_set _bsd__stop_set_sysctl_set
-#define	_stop_set_sysinit_set _bsd__stop_set_sysinit_set
-#define	subkey_table_gen _bsd_subkey_table_gen
-#define	swi_add _bsd_swi_add
-#define	swi_sched _bsd_swi_sched
-#define	sx_destroy _bsd_sx_destroy
-#define	sx_downgrade_int _bsd_sx_downgrade_int
-#define	sx_init_flags _bsd_sx_init_flags
-#define	_sx_slock_int _bsd__sx_slock_int
-#define	_sx_sunlock_int _bsd__sx_sunlock_int
-#define	sx_sysinit _bsd_sx_sysinit
-#define	sx_try_slock_int _bsd_sx_try_slock_int
-#define	sx_try_upgrade_int _bsd_sx_try_upgrade_int
-#define	sx_xlocked _bsd_sx_xlocked
-#define	syncache_add _bsd_syncache_add
-#define	syncache_badack _bsd_syncache_badack
-#define	syncache_chkrst _bsd_syncache_chkrst
-#define	syncache_expand _bsd_syncache_expand
-#define	syncache_init _bsd_syncache_init
-#define	syncache_pcblist _bsd_syncache_pcblist
-#define	syncache_unreach _bsd_syncache_unreach
-#define	sysctl_add_oid _bsd_sysctl_add_oid
-#define	sysctl_chg_accept_global_ootb_addip _bsd_sysctl_chg_accept_global_ootb_addip
-#define	sysctl_chg_chunk_proc_limit _bsd_sysctl_chg_chunk_proc_limit
-#define	sysctl_chg_error_on_ootb _bsd_sysctl_chg_error_on_ootb
-#define	sysctl_chg_hashtable_size _bsd_sysctl_chg_hashtable_size
-#define	sysctl_chg_initialising_chunk_proc_limit _bsd_sysctl_chg_initialising_chunk_proc_limit
-#define	sysctl_chg_loglevel _bsd_sysctl_chg_loglevel
-#define	sysctl_chg_param_proc_limit _bsd_sysctl_chg_param_proc_limit
-#define	sysctl_chg_timer _bsd_sysctl_chg_timer
-#define	sysctl_chg_track_global_addresses _bsd_sysctl_chg_track_global_addresses
-#define	sysctl__children _bsd_sysctl__children
-#define	sysctl_ctx_entry_add _bsd_sysctl_ctx_entry_add
-#define	sysctl_ctx_entry_del _bsd_sysctl_ctx_entry_del
-#define	sysctl_ctx_entry_find _bsd_sysctl_ctx_entry_find
-#define	sysctl_ctx_free _bsd_sysctl_ctx_free
-#define	sysctl_ctx_init _bsd_sysctl_ctx_init
-#define	sysctl___debug _bsd_sysctl___debug
-#define	sysctl___dev _bsd_sysctl___dev
-#define	sysctl_enable_oid _bsd_sysctl_enable_oid
-#define	sysctl_find_oid _bsd_sysctl_find_oid
-#define	sysctl_handle_16 _bsd_sysctl_handle_16
-#define	sysctl_handle_32 _bsd_sysctl_handle_32
-#define	sysctl_handle_64 _bsd_sysctl_handle_64
-#define	sysctl_handle_8 _bsd_sysctl_handle_8
-#define	sysctl_handle_bool _bsd_sysctl_handle_bool
-#define	sysctl_handle_counter_u64 _bsd_sysctl_handle_counter_u64
-#define	sysctl_handle_counter_u64_array _bsd_sysctl_handle_counter_u64_array
-#define	sysctl_handle_int _bsd_sysctl_handle_int
-#define	sysctl_handle_long _bsd_sysctl_handle_long
-#define	sysctl_handle_opaque _bsd_sysctl_handle_opaque
-#define	sysctl_handle_string _bsd_sysctl_handle_string
-#define	sysctl_handle_uma_zone_cur _bsd_sysctl_handle_uma_zone_cur
-#define	sysctl_handle_uma_zone_max _bsd_sysctl_handle_uma_zone_max
-#define	sysctl___hw _bsd_sysctl___hw
-#define	sysctl___hw_bus _bsd_sysctl___hw_bus
-#define	sysctl___hw_fdt _bsd_sysctl___hw_fdt
-#define	sysctl___hw_nvme _bsd_sysctl___hw_nvme
-#define	sysctl___hw_pci _bsd_sysctl___hw_pci
-#define	sysctl___hw_sdhci _bsd_sysctl___hw_sdhci
-#define	sysctl___hw_usb _bsd_sysctl___hw_usb
-#define	sysctl___hw_usb_rsu _bsd_sysctl___hw_usb_rsu
-#define	sysctl___hw_usb_smsc _bsd_sysctl___hw_usb_smsc
-#define	sysctl___hw_zynq _bsd_sysctl___hw_zynq
-#define	sysctl___kern _bsd_sysctl___kern
-#define	sysctl___kern_cam _bsd_sysctl___kern_cam
-#define	sysctl___kern_evdev _bsd_sysctl___kern_evdev
-#define	sysctl___kern_evdev_input _bsd_sysctl___kern_evdev_input
-#define	sysctl___kern_features _bsd_sysctl___kern_features
-#define	sysctl___kern_ipc _bsd_sysctl___kern_ipc
-#define	sysctl_move_oid _bsd_sysctl_move_oid
-#define	sysctl_msec_to_sbintime _bsd_sysctl_msec_to_sbintime
-#define	sysctl_msec_to_ticks _bsd_sysctl_msec_to_ticks
-#define	sysctl___net _bsd_sysctl___net
-#define	sysctl___net_accf _bsd_sysctl___net_accf
-#define	sysctl___net_bpf _bsd_sysctl___net_bpf
-#define	sysctl___net_bpf_jitter _bsd_sysctl___net_bpf_jitter
-#define	sysctl___net_inet _bsd_sysctl___net_inet
-#define	sysctl___net_inet6 _bsd_sysctl___net_inet6
-#define	sysctl___net_inet6_icmp6 _bsd_sysctl___net_inet6_icmp6
-#define	sysctl___net_inet6_ip6 _bsd_sysctl___net_inet6_ip6
-#define	sysctl___net_inet6_ipsec6 _bsd_sysctl___net_inet6_ipsec6
-#define	sysctl___net_inet6_mld _bsd_sysctl___net_inet6_mld
-#define	sysctl___net_inet6_tcp6 _bsd_sysctl___net_inet6_tcp6
-#define	sysctl___net_inet6_udp6 _bsd_sysctl___net_inet6_udp6
-#define	sysctl___net_inet_accf _bsd_sysctl___net_inet_accf
-#define	sysctl___net_inet_ah _bsd_sysctl___net_inet_ah
-#define	sysctl___net_inet_carp _bsd_sysctl___net_inet_carp
-#define	sysctl___net_inet_esp _bsd_sysctl___net_inet_esp
-#define	sysctl___net_inet_icmp _bsd_sysctl___net_inet_icmp
-#define	sysctl___net_inet_igmp _bsd_sysctl___net_inet_igmp
-#define	sysctl___net_inet_ip _bsd_sysctl___net_inet_ip
-#define	sysctl___net_inet_ip_alias _bsd_sysctl___net_inet_ip_alias
-#define	sysctl___net_inet_ipcomp _bsd_sysctl___net_inet_ipcomp
-#define	sysctl___net_inet_ipip _bsd_sysctl___net_inet_ipip
-#define	sysctl___net_inet_ipsec _bsd_sysctl___net_inet_ipsec
-#define	sysctl___net_inet_pim _bsd_sysctl___net_inet_pim
-#define	sysctl___net_inet_raw _bsd_sysctl___net_inet_raw
-#define	sysctl___net_inet_tcp _bsd_sysctl___net_inet_tcp
-#define	sysctl___net_inet_tcp_cc _bsd_sysctl___net_inet_tcp_cc
-#define	sysctl___net_inet_tcp_cc_newreno _bsd_sysctl___net_inet_tcp_cc_newreno
-#define	sysctl___net_inet_tcp_lro _bsd_sysctl___net_inet_tcp_lro
-#define	sysctl___net_inet_tcp_sack _bsd_sysctl___net_inet_tcp_sack
-#define	sysctl___net_inet_udp _bsd_sysctl___net_inet_udp
-#define	sysctl___net_key _bsd_sysctl___net_key
-#define	sysctl___net_link _bsd_sysctl___net_link
-#define	sysctl___net_link_ether _bsd_sysctl___net_link_ether
-#define	sysctl___net_link_generic _bsd_sysctl___net_link_generic
-#define	sysctl___net_link_lagg _bsd_sysctl___net_link_lagg
-#define	sysctl___net_link_lagg_lacp _bsd_sysctl___net_link_lagg_lacp
-#define	sysctl___net_pf _bsd_sysctl___net_pf
-#define	sysctl___net_pfsync _bsd_sysctl___net_pfsync
-#define	sysctl___net_wlan _bsd_sysctl___net_wlan
-#define	sysctl_register_disabled_oid _bsd_sysctl_register_disabled_oid
-#define	sysctl_register_oid _bsd_sysctl_register_oid
-#define	sysctl_remove_name _bsd_sysctl_remove_name
-#define	sysctl_remove_oid _bsd_sysctl_remove_oid
-#define	sysctl_rename_oid _bsd_sysctl_rename_oid
-#define	sysctl_sec_to_timeval _bsd_sysctl_sec_to_timeval
-#define	sysctl___security _bsd_sysctl___security
-#define	sysctl___sysctl _bsd_sysctl___sysctl
-#define	sysctl_unregister_oid _bsd_sysctl_unregister_oid
-#define	sysctl_usec_to_sbintime _bsd_sysctl_usec_to_sbintime
-#define	sysctl___vm _bsd_sysctl___vm
-#define	sysctl_wire_old_buffer _bsd_sysctl_wire_old_buffer
-#define	sysctl_wlock _bsd_sysctl_wlock
-#define	sysctl_wunlock _bsd_sysctl_wunlock
-#define	system_base_info _bsd_system_base_info
-#define	taskqgroup_adjust _bsd_taskqgroup_adjust
-#define	taskqgroup_attach _bsd_taskqgroup_attach
-#define	taskqgroup_attach_cpu _bsd_taskqgroup_attach_cpu
-#define	taskqgroup_config_gtask_deinit _bsd_taskqgroup_config_gtask_deinit
-#define	taskqgroup_config_gtask_init _bsd_taskqgroup_config_gtask_init
-#define	taskqgroup_create _bsd_taskqgroup_create
-#define	taskqgroup_destroy _bsd_taskqgroup_destroy
-#define	taskqgroup_detach _bsd_taskqgroup_detach
-#define	TB_DRAIN_WAITER _bsd_TB_DRAIN_WAITER
-#define	tbr_dequeue_ptr _bsd_tbr_dequeue_ptr
-#define	tbr_set _bsd_tbr_set
-#define	tcb _bsd_tcb
-#define	tcbinfo _bsd_tcbinfo
-#define	tcp6_ctlinput _bsd_tcp6_ctlinput
-#define	tcp6_input _bsd_tcp6_input
-#define	tcp6_usrreqs _bsd_tcp6_usrreqs
-#define	tcp_abc_l_var _bsd_tcp_abc_l_var
-#define	tcp_addoptions _bsd_tcp_addoptions
-#define	tcp_always_keepalive _bsd_tcp_always_keepalive
-#define	tcp_autorcvbuf _bsd_tcp_autorcvbuf
-#define	tcp_autorcvbuf_inc _bsd_tcp_autorcvbuf_inc
-#define	tcp_autorcvbuf_max _bsd_tcp_autorcvbuf_max
-#define	tcp_autosndbuf_inc _bsd_tcp_autosndbuf_inc
-#define	tcp_autosndbuf_max _bsd_tcp_autosndbuf_max
-#define	tcp_backoff _bsd_tcp_backoff
-#define	tcp_ccalgounload _bsd_tcp_ccalgounload
-#define	tcp_clean_dsack_blocks _bsd_tcp_clean_dsack_blocks
-#define	tcp_clean_sackreport _bsd_tcp_clean_sackreport
-#define	tcp_close _bsd_tcp_close
-#define	tcp_compute_initwnd _bsd_tcp_compute_initwnd
-#define	tcp_compute_pipe _bsd_tcp_compute_pipe
-#define	tcp_ctlinput _bsd_tcp_ctlinput
-#define	tcp_ctloutput _bsd_tcp_ctloutput
-#define	tcp_debug_mtx _bsd_tcp_debug_mtx
-#define	tcp_default_ctloutput _bsd_tcp_default_ctloutput
-#define	tcp_delack_enabled _bsd_tcp_delack_enabled
-#define	tcp_delacktime _bsd_tcp_delacktime
-#define	tcp_discardcb _bsd_tcp_discardcb
-#define	tcp_do_autorcvbuf _bsd_tcp_do_autorcvbuf
-#define	tcp_do_autosndbuf _bsd_tcp_do_autosndbuf
-#define	tcp_do_ecn _bsd_tcp_do_ecn
-#define	tcp_dooptions _bsd_tcp_dooptions
-#define	tcp_do_rfc1323 _bsd_tcp_do_rfc1323
-#define	tcp_do_rfc3042 _bsd_tcp_do_rfc3042
-#define	tcp_do_rfc3390 _bsd_tcp_do_rfc3390
-#define	tcp_do_rfc3465 _bsd_tcp_do_rfc3465
-#define	tcp_do_rfc6675_pipe _bsd_tcp_do_rfc6675_pipe
-#define	tcp_do_sack _bsd_tcp_do_sack
-#define	tcp_do_segment _bsd_tcp_do_segment
-#define	tcp_do_tso _bsd_tcp_do_tso
-#define	tcp_drain _bsd_tcp_drain
-#define	tcp_drop _bsd_tcp_drop
-#define	tcp_drop_syn_sent _bsd_tcp_drop_syn_sent
-#define	tcp_dropwithreset _bsd_tcp_dropwithreset
-#define	tcp_ecn_maxretries _bsd_tcp_ecn_maxretries
-#define	tcp_fast_finwait2_recycle _bsd_tcp_fast_finwait2_recycle
-#define	tcp_fini _bsd_tcp_fini
-#define	tcp_finwait2_timeout _bsd_tcp_finwait2_timeout
-#define	tcp_free_sackholes _bsd_tcp_free_sackholes
-#define	tcp_function_lock _bsd_tcp_function_lock
-#define	tcp_hc_get _bsd_tcp_hc_get
-#define	tcp_hc_getmtu _bsd_tcp_hc_getmtu
-#define	tcp_hc_init _bsd_tcp_hc_init
-#define	tcp_hc_update _bsd_tcp_hc_update
-#define	tcp_hc_updatemtu _bsd_tcp_hc_updatemtu
-#define	tcp_init _bsd_tcp_init
-#define	tcp_initcwnd_segments _bsd_tcp_initcwnd_segments
-#define	tcp_inpinfo_lock_del _bsd_tcp_inpinfo_lock_del
-#define	tcp_inp_lro_compressed _bsd_tcp_inp_lro_compressed
-#define	tcp_inp_lro_direct_queue _bsd_tcp_inp_lro_direct_queue
-#define	tcp_inp_lro_locks_taken _bsd_tcp_inp_lro_locks_taken
-#define	tcp_inp_lro_sack_wake _bsd_tcp_inp_lro_sack_wake
-#define	tcp_inp_lro_single_push _bsd_tcp_inp_lro_single_push
-#define	tcp_inp_lro_wokeup_queue _bsd_tcp_inp_lro_wokeup_queue
-#define	tcp_inptoxtp _bsd_tcp_inptoxtp
-#define	tcp_input _bsd_tcp_input
-#define	tcp_insecure_rst _bsd_tcp_insecure_rst
-#define	tcp_insecure_syn _bsd_tcp_insecure_syn
-#define	tcpip_fillheaders _bsd_tcpip_fillheaders
-#define	tcpip_maketemplate _bsd_tcpip_maketemplate
-#define	tcp_ipsec_support _bsd_tcp_ipsec_support
-#define	tcp_keepcnt _bsd_tcp_keepcnt
-#define	tcp_keepidle _bsd_tcp_keepidle
-#define	tcp_keepinit _bsd_tcp_keepinit
-#define	tcp_keepintvl _bsd_tcp_keepintvl
-#define	tcp_log_addrs _bsd_tcp_log_addrs
-#define	tcp_log_in_vain _bsd_tcp_log_in_vain
-#define	tcp_log_vain _bsd_tcp_log_vain
-#define	tcp_lro_dereg_mbufq _bsd_tcp_lro_dereg_mbufq
-#define	tcp_lro_flush _bsd_tcp_lro_flush
-#define	tcp_lro_flush_all _bsd_tcp_lro_flush_all
-#define	tcp_lro_flush_inactive _bsd_tcp_lro_flush_inactive
-#define	tcp_lro_free _bsd_tcp_lro_free
-#define	tcp_lro_init _bsd_tcp_lro_init
-#define	tcp_lro_init_args _bsd_tcp_lro_init_args
-#define	tcp_lro_queue_mbuf _bsd_tcp_lro_queue_mbuf
-#define	tcp_lro_reg_mbufq _bsd_tcp_lro_reg_mbufq
-#define	tcp_lro_rx _bsd_tcp_lro_rx
-#define	tcp_maxmtu _bsd_tcp_maxmtu
-#define	tcp_maxmtu6 _bsd_tcp_maxmtu6
-#define	tcp_maxpersistidle _bsd_tcp_maxpersistidle
-#define	tcp_maxseg _bsd_tcp_maxseg
-#define	tcp_m_copym _bsd_tcp_m_copym
-#define	tcp_minmss _bsd_tcp_minmss
-#define	tcp_msl _bsd_tcp_msl
-#define	tcp_mss _bsd_tcp_mss
-#define	tcp_mssdflt _bsd_tcp_mssdflt
-#define	tcp_mssopt _bsd_tcp_mssopt
-#define	tcp_mss_update _bsd_tcp_mss_update
-#define	tcp_new_isn _bsd_tcp_new_isn
-#define	tcp_newreno_partial_ack _bsd_tcp_newreno_partial_ack
-#define	tcp_newtcpcb _bsd_tcp_newtcpcb
-#define	tcp_new_ts_offset _bsd_tcp_new_ts_offset
-#define	tcp_offload_connect _bsd_tcp_offload_connect
-#define	tcp_offload_ctloutput _bsd_tcp_offload_ctloutput
-#define	tcp_offload_detach _bsd_tcp_offload_detach
-#define	tcp_offload_input _bsd_tcp_offload_input
-#define	tcp_offload_output _bsd_tcp_offload_output
-#define	tcp_offload_rcvd _bsd_tcp_offload_rcvd
-#define	tcp_offload_tcp_info _bsd_tcp_offload_tcp_info
-#define	tcp_output _bsd_tcp_output
-#define	tcp_persmax _bsd_tcp_persmax
-#define	tcp_persmin _bsd_tcp_persmin
-#define	tcp_pmtud_blackhole_detect _bsd_tcp_pmtud_blackhole_detect
-#define	tcp_pmtud_blackhole_mss _bsd_tcp_pmtud_blackhole_mss
-#define	tcp_pulloutofband _bsd_tcp_pulloutofband
-#define	tcp_reass _bsd_tcp_reass
-#define	tcp_reass_flush _bsd_tcp_reass_flush
-#define	tcp_reass_global_init _bsd_tcp_reass_global_init
-#define	tc_precexp _bsd_tc_precexp
-#define	tcp_recvspace _bsd_tcp_recvspace
-#define	tcp_respond _bsd_tcp_respond
-#define	tcp_rexmit_drop_options _bsd_tcp_rexmit_drop_options
-#define	tcp_rexmit_initial _bsd_tcp_rexmit_initial
-#define	tcp_rexmit_min _bsd_tcp_rexmit_min
-#define	tcp_rexmit_slop _bsd_tcp_rexmit_slop
-#define	tcprexmtthresh _bsd_tcprexmtthresh
-#define	tcp_sack_adjust _bsd_tcp_sack_adjust
-#define	tcp_sack_doack _bsd_tcp_sack_doack
-#define	tcp_sack_globalholes _bsd_tcp_sack_globalholes
-#define	tcp_sack_globalmaxholes _bsd_tcp_sack_globalmaxholes
-#define	tcp_sack_maxholes _bsd_tcp_sack_maxholes
-#define	tcp_sack_output _bsd_tcp_sack_output
-#define	tcp_sack_partialack _bsd_tcp_sack_partialack
-#define	tcp_sc_rst_sock_fail _bsd_tcp_sc_rst_sock_fail
-#define	tcp_sendbuf_auto_lowat _bsd_tcp_sendbuf_auto_lowat
-#define	tcp_sendspace _bsd_tcp_sendspace
-#define	tcp_setpersist _bsd_tcp_setpersist
-#define	tcp_slowtimo _bsd_tcp_slowtimo
-#define	tcp_sndbuf_autoscale _bsd_tcp_sndbuf_autoscale
-#define	tcps_states _bsd_tcps_states
-#define	tcpstat _bsd_tcpstat
-#define	tcp_state_change _bsd_tcp_state_change
-#define	tcp_switch_back_to_default _bsd_tcp_switch_back_to_default
-#define	tcp_timer_2msl _bsd_tcp_timer_2msl
-#define	tcp_timer_activate _bsd_tcp_timer_activate
-#define	tcp_timer_active _bsd_tcp_timer_active
-#define	tcp_timer_delack _bsd_tcp_timer_delack
-#define	tcp_timer_discard _bsd_tcp_timer_discard
-#define	tcp_timer_keep _bsd_tcp_timer_keep
-#define	tcp_timer_persist _bsd_tcp_timer_persist
-#define	tcp_timer_rexmt _bsd_tcp_timer_rexmt
-#define	tcp_timer_stop _bsd_tcp_timer_stop
-#define	tcp_timers_unsuspend _bsd_tcp_timers_unsuspend
-#define	tcp_timer_suspend _bsd_tcp_timer_suspend
-#define	tcp_totbackoff _bsd_tcp_totbackoff
-#define	tcp_trace _bsd_tcp_trace
-#define	tcp_ts_offset_per_conn _bsd_tcp_ts_offset_per_conn
-#define	tcp_tw_2msl_scan _bsd_tcp_tw_2msl_scan
-#define	tcp_twcheck _bsd_tcp_twcheck
-#define	tcp_twclose _bsd_tcp_twclose
-#define	tcp_tw_init _bsd_tcp_tw_init
-#define	tcp_twstart _bsd_tcp_twstart
-#define	tcp_tw_zone_change _bsd_tcp_tw_zone_change
-#define	tcp_update_dsack_list _bsd_tcp_update_dsack_list
-#define	tcp_update_sack_list _bsd_tcp_update_sack_list
-#define	tcp_use_hostcache _bsd_tcp_use_hostcache
-#define	tcp_usrreqs _bsd_tcp_usrreqs
-#define	tcp_v6mssdflt _bsd_tcp_v6mssdflt
-#define	tcp_v6pmtud_blackhole_mss _bsd_tcp_v6pmtud_blackhole_mss
-#define	tcp_xmit_timer _bsd_tcp_xmit_timer
-#define	tc_tick_bt _bsd_tc_tick_bt
-#define	tc_tick_sbt _bsd_tc_tick_sbt
-#define	t_functions _bsd_t_functions
-#define	t_functions_inited _bsd_t_functions_inited
-#define	ti_am335x_clk_devmap _bsd_ti_am335x_clk_devmap
-#define	ti_am335x_pinmux_dev _bsd_ti_am335x_pinmux_dev
-#define	tick _bsd_tick
-#define	ticket_altqs_active _bsd_ticket_altqs_active
-#define	ticket_altqs_inactive _bsd_ticket_altqs_inactive
-#define	ticket_pabuf _bsd_ticket_pabuf
-#define	ticks _bsd_ticks
-#define	tick_sbt _bsd_tick_sbt
-#define	ti_hwmods _bsd_ti_hwmods
-#define	ti_hwmods_contains _bsd_ti_hwmods_contains
-#define	ti_hwmods_get_clock _bsd_ti_hwmods_get_clock
-#define	ti_hwmods_get_unit _bsd_ti_hwmods_get_unit
-#define	timeout _bsd_timeout
-#define	_timeout_task_init _bsd__timeout_task_init
-#define	timevaladd _bsd_timevaladd
-#define	timevalsub _bsd_timevalsub
-#define	ti_pinmux_padconf_get _bsd_ti_pinmux_padconf_get
-#define	ti_pinmux_padconf_get_gpiomode _bsd_ti_pinmux_padconf_get_gpiomode
-#define	ti_pinmux_padconf_set _bsd_ti_pinmux_padconf_set
-#define	ti_pinmux_padconf_set_gpiomode _bsd_ti_pinmux_padconf_set_gpiomode
-#define	ti_prcm_clk_disable _bsd_ti_prcm_clk_disable
-#define	ti_prcm_clk_enable _bsd_ti_prcm_clk_enable
-#define	ti_prcm_clk_get_source_freq _bsd_ti_prcm_clk_get_source_freq
-#define	ti_prcm_clk_set_source _bsd_ti_prcm_clk_set_source
-#define	ti_prcm_clk_set_source_freq _bsd_ti_prcm_clk_set_source_freq
-#define	ti_prcm_clk_valid _bsd_ti_prcm_clk_valid
-#define	ti_scm_reg_read_4 _bsd_ti_scm_reg_read_4
-#define	ti_scm_reg_write_4 _bsd_ti_scm_reg_write_4
-#define	trash_ctor _bsd_trash_ctor
-#define	trash_dtor _bsd_trash_dtor
-#define	trash_fini _bsd_trash_fini
-#define	trash_init _bsd_trash_init
-#define	tsec_attach _bsd_tsec_attach
-#define	tsec_detach _bsd_tsec_detach
-#define	tsec_devclass _bsd_tsec_devclass
-#define	tsec_error_intr _bsd_tsec_error_intr
-#define	tsec_get_hwaddr _bsd_tsec_get_hwaddr
-#define	tsec_miibus_readreg _bsd_tsec_miibus_readreg
-#define	tsec_miibus_statchg _bsd_tsec_miibus_statchg
-#define	tsec_miibus_writereg _bsd_tsec_miibus_writereg
-#define	tsec_phy_mtx _bsd_tsec_phy_mtx
-#define	tsec_receive_intr _bsd_tsec_receive_intr
-#define	tsec_resume _bsd_tsec_resume
-#define	tsec_shutdown _bsd_tsec_shutdown
-#define	tsec_suspend _bsd_tsec_suspend
-#define	tsec_transmit_intr _bsd_tsec_transmit_intr
-#define	tty_alloc _bsd_tty_alloc
-#define	tty_alloc_mutex _bsd_tty_alloc_mutex
-#define	tty_checkoutq _bsd_tty_checkoutq
-#define	ttydisc_close _bsd_ttydisc_close
-#define	ttydisc_getc _bsd_ttydisc_getc
-#define	ttydisc_getc_poll _bsd_ttydisc_getc_poll
-#define	ttydisc_getc_uio _bsd_ttydisc_getc_uio
-#define	ttydisc_modem _bsd_ttydisc_modem
-#define	ttydisc_open _bsd_ttydisc_open
-#define	ttydisc_optimize _bsd_ttydisc_optimize
-#define	ttydisc_read _bsd_ttydisc_read
-#define	ttydisc_rint _bsd_ttydisc_rint
-#define	ttydisc_rint_bypass _bsd_ttydisc_rint_bypass
-#define	ttydisc_rint_done _bsd_ttydisc_rint_done
-#define	ttydisc_rint_poll _bsd_ttydisc_rint_poll
-#define	ttydisc_rint_simple _bsd_ttydisc_rint_simple
-#define	ttydisc_write _bsd_ttydisc_write
-#define	tty_flush _bsd_tty_flush
-#define	tty_hiwat_in_block _bsd_tty_hiwat_in_block
-#define	tty_hiwat_in_unblock _bsd_tty_hiwat_in_unblock
-#define	tty_init_console _bsd_tty_init_console
-#define	ttyinq_canonicalize _bsd_ttyinq_canonicalize
-#define	ttyinq_findchar _bsd_ttyinq_findchar
-#define	ttyinq_flush _bsd_ttyinq_flush
-#define	ttyinq_free _bsd_ttyinq_free
-#define	ttyinq_line_iterate_from_linestart _bsd_ttyinq_line_iterate_from_linestart
-#define	ttyinq_line_iterate_from_reprintpos _bsd_ttyinq_line_iterate_from_reprintpos
-#define	ttyinq_peekchar _bsd_ttyinq_peekchar
-#define	ttyinq_read_uio _bsd_ttyinq_read_uio
-#define	ttyinq_reprintpos_reset _bsd_ttyinq_reprintpos_reset
-#define	ttyinq_reprintpos_set _bsd_ttyinq_reprintpos_set
-#define	ttyinq_setsize _bsd_ttyinq_setsize
-#define	ttyinq_unputchar _bsd_ttyinq_unputchar
-#define	ttyinq_write _bsd_ttyinq_write
-#define	ttyinq_write_nofrag _bsd_ttyinq_write_nofrag
-#define	tty_ioctl _bsd_tty_ioctl
-#define	tty_makedevf _bsd_tty_makedevf
-#define	ttyoutq_flush _bsd_ttyoutq_flush
-#define	ttyoutq_free _bsd_ttyoutq_free
-#define	ttyoutq_read _bsd_ttyoutq_read
-#define	ttyoutq_read_uio _bsd_ttyoutq_read_uio
-#define	ttyoutq_setsize _bsd_ttyoutq_setsize
-#define	ttyoutq_write _bsd_ttyoutq_write
-#define	ttyoutq_write_nofrag _bsd_ttyoutq_write_nofrag
-#define	tty_putchar _bsd_tty_putchar
-#define	tty_putstrn _bsd_tty_putstrn
-#define	tty_rel_gone _bsd_tty_rel_gone
-#define	tty_rel_pgrp _bsd_tty_rel_pgrp
-#define	tty_rel_sess _bsd_tty_rel_sess
-#define	tty_set_winsize _bsd_tty_set_winsize
-#define	tty_signal_pgrp _bsd_tty_signal_pgrp
-#define	tty_signal_sessleader _bsd_tty_signal_sessleader
-#define	tty_timedwait _bsd_tty_timedwait
-#define	tty_wait _bsd_tty_wait
-#define	tty_wait_background _bsd_tty_wait_background
-#define	tty_wakeup _bsd_tty_wakeup
-#define	tvtohz _bsd_tvtohz
-#define	ucom_attach _bsd_ucom_attach
-#define	ucom_cfg_is_gone _bsd_ucom_cfg_is_gone
-#define	ucom_cnops _bsd_ucom_cnops
-#define	ucom_detach _bsd_ucom_detach
-#define	ucom_drain _bsd_ucom_drain
-#define	ucom_drain_all _bsd_ucom_drain_all
-#define	ucom_get_data _bsd_ucom_get_data
-#define	ucom_put_data _bsd_ucom_put_data
-#define	ucom_ref _bsd_ucom_ref
-#define	ucom_set_pnpinfo_usb _bsd_ucom_set_pnpinfo_usb
-#define	ucom_set_usb_mode _bsd_ucom_set_usb_mode
-#define	ucom_status_change _bsd_ucom_status_change
-#define	ucom_unref _bsd_ucom_unref
-#define	udb _bsd_udb
-#define	udbinfo _bsd_udbinfo
-#define	udp6_ctlinput _bsd_udp6_ctlinput
-#define	udp6_input _bsd_udp6_input
-#define	udp6_usrreqs _bsd_udp6_usrreqs
-#define	udp_blackhole _bsd_udp_blackhole
-#define	udp_cksum _bsd_udp_cksum
-#define	udp_ctlinput _bsd_udp_ctlinput
-#define	udp_ctloutput _bsd_udp_ctloutput
-#define	udp_discardcb _bsd_udp_discardcb
-#define	udp_init _bsd_udp_init
-#define	udp_input _bsd_udp_input
-#define	udp_ipsec_adjust_cksum _bsd_udp_ipsec_adjust_cksum
-#define	udp_ipsec_input _bsd_udp_ipsec_input
-#define	udp_ipsec_output _bsd_udp_ipsec_output
-#define	udp_ipsec_pcbctl _bsd_udp_ipsec_pcbctl
-#define	udplite6_ctlinput _bsd_udplite6_ctlinput
-#define	udplite_ctlinput _bsd_udplite_ctlinput
-#define	udplite_init _bsd_udplite_init
-#define	udp_log_in_vain _bsd_udp_log_in_vain
-#define	udp_newudpcb _bsd_udp_newudpcb
-#define	udp_notify _bsd_udp_notify
-#define	udp_recvspace _bsd_udp_recvspace
-#define	udp_sendspace _bsd_udp_sendspace
-#define	udp_set_kernel_tunneling _bsd_udp_set_kernel_tunneling
-#define	udp_shutdown _bsd_udp_shutdown
-#define	udpstat _bsd_udpstat
-#define	udp_usrreqs _bsd_udp_usrreqs
-#define	uether_getifp _bsd_uether_getifp
-#define	uether_getmii _bsd_uether_getmii
-#define	uether_getsc _bsd_uether_getsc
-#define	uether_ifattach _bsd_uether_ifattach
-#define	uether_ifattach_wait _bsd_uether_ifattach_wait
-#define	uether_ifdetach _bsd_uether_ifdetach
-#define	uether_ifmedia_upd _bsd_uether_ifmedia_upd
-#define	uether_init _bsd_uether_init
-#define	uether_ioctl _bsd_uether_ioctl
-#define	uether_is_gone _bsd_uether_is_gone
-#define	uether_newbuf _bsd_uether_newbuf
-#define	uether_pause _bsd_uether_pause
-#define	uether_rxbuf _bsd_uether_rxbuf
-#define	uether_rxflush _bsd_uether_rxflush
-#define	uether_rxmbuf _bsd_uether_rxmbuf
-#define	uether_start _bsd_uether_start
-#define	ugen_do_request _bsd_ugen_do_request
-#define	uhub_attach _bsd_uhub_attach
-#define	uhub_child_location_string _bsd_uhub_child_location_string
-#define	uhub_count_active_host_ports _bsd_uhub_count_active_host_ports
-#define	uhub_detach _bsd_uhub_detach
-#define	uhub_driver _bsd_uhub_driver
-#define	uhub_explore_handle_re_enumerate _bsd_uhub_explore_handle_re_enumerate
-#define	uhub_find_iface_index _bsd_uhub_find_iface_index
-#define	uhub_probe _bsd_uhub_probe
-#define	uhub_query_info _bsd_uhub_query_info
-#define	uhub_root_intr _bsd_uhub_root_intr
-#define	uhub_tt_buffer_reset_async_locked _bsd_uhub_tt_buffer_reset_async_locked
-#define	uiomove _bsd_uiomove
-#define	uiomove_nofault _bsd_uiomove_nofault
-#define	ukphy_status _bsd_ukphy_status
-#define	ulitecb _bsd_ulitecb
-#define	ulitecbinfo _bsd_ulitecbinfo
-#define	uma_align_cache _bsd_uma_align_cache
-#define	uma_avail _bsd_uma_avail
-#define	uma_limit _bsd_uma_limit
-#define	uma_print_stats _bsd_uma_print_stats
-#define	uma_print_zone _bsd_uma_print_zone
-#define	uma_reclaim _bsd_uma_reclaim
-#define	uma_reclaim_wakeup _bsd_uma_reclaim_wakeup
-#define	uma_reclaim_worker _bsd_uma_reclaim_worker
-#define	uma_set_align _bsd_uma_set_align
-#define	uma_set_limit _bsd_uma_set_limit
-#define	uma_size _bsd_uma_size
-#define	uma_startup _bsd_uma_startup
-#define	uma_zalloc_arg _bsd_uma_zalloc_arg
-#define	uma_zalloc_domain _bsd_uma_zalloc_domain
-#define	uma_zalloc_pcpu_arg _bsd_uma_zalloc_pcpu_arg
-#define	uma_zcache_create _bsd_uma_zcache_create
-#define	uma_zcreate _bsd_uma_zcreate
-#define	uma_zdestroy _bsd_uma_zdestroy
-#define	uma_zfree_arg _bsd_uma_zfree_arg
-#define	uma_zfree_domain _bsd_uma_zfree_domain
-#define	uma_zfree_pcpu_arg _bsd_uma_zfree_pcpu_arg
-#define	uma_zone_exhausted _bsd_uma_zone_exhausted
-#define	uma_zone_exhausted_nolock _bsd_uma_zone_exhausted_nolock
-#define	uma_zone_get_cur _bsd_uma_zone_get_cur
-#define	uma_zone_get_max _bsd_uma_zone_get_max
-#define	uma_zone_reclaim _bsd_uma_zone_reclaim
-#define	uma_zone_reserve _bsd_uma_zone_reserve
-#define	uma_zone_set_allocf _bsd_uma_zone_set_allocf
-#define	uma_zone_set_fini _bsd_uma_zone_set_fini
-#define	uma_zone_set_freef _bsd_uma_zone_set_freef
-#define	uma_zone_set_init _bsd_uma_zone_set_init
-#define	uma_zone_set_max _bsd_uma_zone_set_max
-#define	uma_zone_set_maxaction _bsd_uma_zone_set_maxaction
-#define	uma_zone_set_maxcache _bsd_uma_zone_set_maxcache
-#define	uma_zone_set_warning _bsd_uma_zone_set_warning
-#define	uma_zone_set_zfini _bsd_uma_zone_set_zfini
-#define	uma_zone_set_zinit _bsd_uma_zone_set_zinit
-#define	uma_zsecond_create _bsd_uma_zsecond_create
-#define	uma_zwait _bsd_uma_zwait
-#define	unp_copy_peercred _bsd_unp_copy_peercred
-#define	untimeout _bsd_untimeout
-#define	usb_alloc_device _bsd_usb_alloc_device
-#define	usb_alloc_mbufs _bsd_usb_alloc_mbufs
-#define	usb_alloc_symlink _bsd_usb_alloc_symlink
-#define	usb_bdma_done_event _bsd_usb_bdma_done_event
-#define	usb_bdma_post_sync _bsd_usb_bdma_post_sync
-#define	usb_bdma_pre_sync _bsd_usb_bdma_pre_sync
-#define	usb_bdma_work_loop _bsd_usb_bdma_work_loop
-#define	usb_bus_mem_alloc_all _bsd_usb_bus_mem_alloc_all
-#define	usb_bus_mem_flush_all _bsd_usb_bus_mem_flush_all
-#define	usb_bus_mem_free_all _bsd_usb_bus_mem_free_all
-#define	usb_bus_port_get_device _bsd_usb_bus_port_get_device
-#define	usb_bus_port_set_device _bsd_usb_bus_port_set_device
-#define	usb_bus_powerd _bsd_usb_bus_powerd
-#define	usb_bus_power_update _bsd_usb_bus_power_update
-#define	usb_bus_reset_async_locked _bsd_usb_bus_reset_async_locked
-#define	usb_bus_unload _bsd_usb_bus_unload
-#define	usb_command_wrapper _bsd_usb_command_wrapper
-#define	usbd_add_dynamic_quirk _bsd_usbd_add_dynamic_quirk
-#define	usbd_alloc_config_desc _bsd_usbd_alloc_config_desc
-#define	usbd_clear_data_toggle _bsd_usbd_clear_data_toggle
-#define	usbd_clear_stall_callback _bsd_usbd_clear_stall_callback
-#define	usbd_clear_stall_locked _bsd_usbd_clear_stall_locked
-#define	usbd_copy_in _bsd_usbd_copy_in
-#define	usbd_copy_out _bsd_usbd_copy_out
-#define	usbd_ctrl_lock _bsd_usbd_ctrl_lock
-#define	usbd_ctrl_transfer_setup _bsd_usbd_ctrl_transfer_setup
-#define	usbd_ctrl_unlock _bsd_usbd_ctrl_unlock
-#define	usbd_device_attached _bsd_usbd_device_attached
-#define	usbd_do_request_callback _bsd_usbd_do_request_callback
-#define	usbd_do_request_flags _bsd_usbd_do_request_flags
-#define	usbd_do_request_proc _bsd_usbd_do_request_proc
-#define	usbd_dummy_timeout _bsd_usbd_dummy_timeout
-#define	usb_debug _bsd_usb_debug
-#define	usbd_enum_is_locked _bsd_usbd_enum_is_locked
-#define	usbd_enum_lock _bsd_usbd_enum_lock
-#define	usbd_enum_lock_sig _bsd_usbd_enum_lock_sig
-#define	usbd_enum_unlock _bsd_usbd_enum_unlock
-#define	usbd_errstr _bsd_usbd_errstr
-#define	usb_desc_foreach _bsd_usb_desc_foreach
-#define	usb_destroy_dev _bsd_usb_destroy_dev
-#define	usb_destroy_dev_sync _bsd_usb_destroy_dev_sync
-#define	usb_detach_device _bsd_usb_detach_device
-#define	usb_devclass_ptr _bsd_usb_devclass_ptr
-#define	usb_devinfo _bsd_usb_devinfo
-#define	usb_devsw _bsd_usb_devsw
-#define	usbd_filter_power_mode _bsd_usbd_filter_power_mode
-#define	usbd_find_descriptor _bsd_usbd_find_descriptor
-#define	usbd_frame_zero _bsd_usbd_frame_zero
-#define	usbd_free_config_desc _bsd_usbd_free_config_desc
-#define	usbd_fs_isoc_schedule_alloc_slot _bsd_usbd_fs_isoc_schedule_alloc_slot
-#define	usbd_get_bus_index _bsd_usbd_get_bus_index
-#define	usbd_get_config_descriptor _bsd_usbd_get_config_descriptor
-#define	usbd_get_device_descriptor _bsd_usbd_get_device_descriptor
-#define	usbd_get_device_index _bsd_usbd_get_device_index
-#define	usbd_get_dma_delay _bsd_usbd_get_dma_delay
-#define	usbd_get_endpoint _bsd_usbd_get_endpoint
-#define	usbd_get_endpoint_mode _bsd_usbd_get_endpoint_mode
-#define	usbd_get_ep_by_addr _bsd_usbd_get_ep_by_addr
-#define	usbd_get_iface _bsd_usbd_get_iface
-#define	usbd_get_interface_altindex _bsd_usbd_get_interface_altindex
-#define	usbd_get_interface_descriptor _bsd_usbd_get_interface_descriptor
-#define	usbd_get_isoc_fps _bsd_usbd_get_isoc_fps
-#define	usbd_get_mode _bsd_usbd_get_mode
-#define	usbd_get_no_alts _bsd_usbd_get_no_alts
-#define	usbd_get_no_descriptors _bsd_usbd_get_no_descriptors
-#define	usbd_get_page _bsd_usbd_get_page
-#define	usbd_get_speed _bsd_usbd_get_speed
-#define	usbd_in_polling_mode _bsd_usbd_in_polling_mode
-#define	usbd_interface_count _bsd_usbd_interface_count
-#define	usbd_lookup_id_by_info _bsd_usbd_lookup_id_by_info
-#define	usbd_lookup_id_by_uaa _bsd_usbd_lookup_id_by_uaa
-#define	usb_dma_delay_done_cb _bsd_usb_dma_delay_done_cb
-#define	usb_dma_tag_find _bsd_usb_dma_tag_find
-#define	usb_dma_tag_setup _bsd_usb_dma_tag_setup
-#define	usb_dma_tag_unsetup _bsd_usb_dma_tag_unsetup
-#define	usbd_m_copy_in _bsd_usbd_m_copy_in
-#define	usb_do_clear_stall_callback _bsd_usb_do_clear_stall_callback
-#define	usbd_pipe_enter _bsd_usbd_pipe_enter
-#define	usbd_pipe_start _bsd_usbd_pipe_start
-#define	usbd_req_clear_device_feature _bsd_usbd_req_clear_device_feature
-#define	usbd_req_clear_hub_feature _bsd_usbd_req_clear_hub_feature
-#define	usbd_req_clear_port_feature _bsd_usbd_req_clear_port_feature
-#define	usbd_req_clear_tt_buffer _bsd_usbd_req_clear_tt_buffer
-#define	usbd_req_get_alt_interface_no _bsd_usbd_req_get_alt_interface_no
-#define	usbd_req_get_config _bsd_usbd_req_get_config
-#define	usbd_req_get_config_desc _bsd_usbd_req_get_config_desc
-#define	usbd_req_get_config_desc_full _bsd_usbd_req_get_config_desc_full
-#define	usbd_req_get_desc _bsd_usbd_req_get_desc
-#define	usbd_req_get_descriptor_ptr _bsd_usbd_req_get_descriptor_ptr
-#define	usbd_req_get_device_desc _bsd_usbd_req_get_device_desc
-#define	usbd_req_get_device_status _bsd_usbd_req_get_device_status
-#define	usbd_req_get_hid_desc _bsd_usbd_req_get_hid_desc
-#define	usbd_req_get_hub_descriptor _bsd_usbd_req_get_hub_descriptor
-#define	usbd_req_get_hub_status _bsd_usbd_req_get_hub_status
-#define	usbd_req_get_port_status _bsd_usbd_req_get_port_status
-#define	usbd_req_get_report _bsd_usbd_req_get_report
-#define	usbd_req_get_report_descriptor _bsd_usbd_req_get_report_descriptor
-#define	usbd_req_get_ss_hub_descriptor _bsd_usbd_req_get_ss_hub_descriptor
-#define	usbd_req_get_string_any _bsd_usbd_req_get_string_any
-#define	usbd_req_get_string_desc _bsd_usbd_req_get_string_desc
-#define	usbd_req_re_enumerate _bsd_usbd_req_re_enumerate
-#define	usbd_req_reset_port _bsd_usbd_req_reset_port
-#define	usbd_req_reset_tt _bsd_usbd_req_reset_tt
-#define	usbd_req_set_address _bsd_usbd_req_set_address
-#define	usbd_req_set_alt_interface_no _bsd_usbd_req_set_alt_interface_no
-#define	usbd_req_set_config _bsd_usbd_req_set_config
-#define	usbd_req_set_device_feature _bsd_usbd_req_set_device_feature
-#define	usbd_req_set_hub_depth _bsd_usbd_req_set_hub_depth
-#define	usbd_req_set_hub_feature _bsd_usbd_req_set_hub_feature
-#define	usbd_req_set_hub_u1_timeout _bsd_usbd_req_set_hub_u1_timeout
-#define	usbd_req_set_hub_u2_timeout _bsd_usbd_req_set_hub_u2_timeout
-#define	usbd_req_set_idle _bsd_usbd_req_set_idle
-#define	usbd_req_set_lpm_info _bsd_usbd_req_set_lpm_info
-#define	usbd_req_set_port_feature _bsd_usbd_req_set_port_feature
-#define	usbd_req_set_port_link_state _bsd_usbd_req_set_port_link_state
-#define	usbd_req_set_protocol _bsd_usbd_req_set_protocol
-#define	usbd_req_set_report _bsd_usbd_req_set_report
-#define	usbd_req_warm_reset_port _bsd_usbd_req_warm_reset_port
-#define	usbd_set_alt_interface_index _bsd_usbd_set_alt_interface_index
-#define	usbd_set_config_index _bsd_usbd_set_config_index
-#define	usbd_set_endpoint_mode _bsd_usbd_set_endpoint_mode
-#define	usbd_set_endpoint_stall _bsd_usbd_set_endpoint_stall
-#define	usbd_set_parent_iface _bsd_usbd_set_parent_iface
-#define	usbd_set_pnpinfo _bsd_usbd_set_pnpinfo
-#define	usbd_set_power_mode _bsd_usbd_set_power_mode
-#define	usbd_setup_device_desc _bsd_usbd_setup_device_desc
-#define	usbd_sr_lock _bsd_usbd_sr_lock
-#define	usbd_sr_unlock _bsd_usbd_sr_unlock
-#define	usbd_start_re_enumerate _bsd_usbd_start_re_enumerate
-#define	usbd_start_set_config _bsd_usbd_start_set_config
-#define	usbd_transfer_clear_stall _bsd_usbd_transfer_clear_stall
-#define	usbd_transfer_dequeue _bsd_usbd_transfer_dequeue
-#define	usbd_transfer_done _bsd_usbd_transfer_done
-#define	usbd_transfer_drain _bsd_usbd_transfer_drain
-#define	usbd_transfer_enqueue _bsd_usbd_transfer_enqueue
-#define	usbd_transfer_pending _bsd_usbd_transfer_pending
-#define	usbd_transfer_poll _bsd_usbd_transfer_poll
-#define	usbd_transfer_power_ref _bsd_usbd_transfer_power_ref
-#define	usbd_transfer_setup _bsd_usbd_transfer_setup
-#define	usbd_transfer_setup_sub _bsd_usbd_transfer_setup_sub
-#define	usbd_transfer_setup_sub_malloc _bsd_usbd_transfer_setup_sub_malloc
-#define	usbd_transfer_start _bsd_usbd_transfer_start
-#define	usbd_transfer_stop _bsd_usbd_transfer_stop
-#define	usbd_transfer_submit _bsd_usbd_transfer_submit
-#define	usbd_transfer_timeout_ms _bsd_usbd_transfer_timeout_ms
-#define	usbd_transfer_unsetup _bsd_usbd_transfer_unsetup
-#define	usb_dump_device _bsd_usb_dump_device
-#define	usb_dump_endpoint _bsd_usb_dump_endpoint
-#define	usb_dump_iface _bsd_usb_dump_iface
-#define	usb_dump_queue _bsd_usb_dump_queue
-#define	usb_dump_xfer _bsd_usb_dump_xfer
-#define	usbd_xfer_clr_flag _bsd_usbd_xfer_clr_flag
-#define	usbd_xfer_frame_data _bsd_usbd_xfer_frame_data
-#define	usbd_xfer_frame_len _bsd_usbd_xfer_frame_len
-#define	usbd_xfer_get_fps_shift _bsd_usbd_xfer_get_fps_shift
-#define	usbd_xfer_get_frame _bsd_usbd_xfer_get_frame
-#define	usbd_xfer_get_frame_buffer _bsd_usbd_xfer_get_frame_buffer
-#define	usbd_xfer_get_priv _bsd_usbd_xfer_get_priv
-#define	usbd_xfer_get_timestamp _bsd_usbd_xfer_get_timestamp
-#define	usbd_xfer_is_stalled _bsd_usbd_xfer_is_stalled
-#define	usbd_xfer_max_framelen _bsd_usbd_xfer_max_framelen
-#define	usbd_xfer_max_frames _bsd_usbd_xfer_max_frames
-#define	usbd_xfer_max_len _bsd_usbd_xfer_max_len
-#define	usbd_xfer_maxp_was_clamped _bsd_usbd_xfer_maxp_was_clamped
-#define	usbd_xfer_old_frame_length _bsd_usbd_xfer_old_frame_length
-#define	usbd_xfer_set_flag _bsd_usbd_xfer_set_flag
-#define	usbd_xfer_set_frame_data _bsd_usbd_xfer_set_frame_data
-#define	usbd_xfer_set_frame_len _bsd_usbd_xfer_set_frame_len
-#define	usbd_xfer_set_frame_offset _bsd_usbd_xfer_set_frame_offset
-#define	usbd_xfer_set_frames _bsd_usbd_xfer_set_frames
-#define	usbd_xfer_set_interval _bsd_usbd_xfer_set_interval
-#define	usbd_xfer_set_priv _bsd_usbd_xfer_set_priv
-#define	usbd_xfer_set_stall _bsd_usbd_xfer_set_stall
-#define	usbd_xfer_set_timeout _bsd_usbd_xfer_set_timeout
-#define	usbd_xfer_softc _bsd_usbd_xfer_softc
-#define	usbd_xfer_state _bsd_usbd_xfer_state
-#define	usbd_xfer_status _bsd_usbd_xfer_status
-#define	usb_dymo_eject _bsd_usb_dymo_eject
-#define	usb_ed_comp_foreach _bsd_usb_ed_comp_foreach
-#define	usb_edesc_foreach _bsd_usb_edesc_foreach
-#define	usb_endpoint_foreach _bsd_usb_endpoint_foreach
-#define	usb_extra_power_up_time _bsd_usb_extra_power_up_time
-#define	usb_fifo_alloc_buffer _bsd_usb_fifo_alloc_buffer
-#define	usb_fifo_attach _bsd_usb_fifo_attach
-#define	usb_fifo_detach _bsd_usb_fifo_detach
-#define	usb_fifo_free _bsd_usb_fifo_free
-#define	usb_fifo_free_buffer _bsd_usb_fifo_free_buffer
-#define	usb_fifo_get_data _bsd_usb_fifo_get_data
-#define	usb_fifo_get_data_buffer _bsd_usb_fifo_get_data_buffer
-#define	usb_fifo_get_data_error _bsd_usb_fifo_get_data_error
-#define	usb_fifo_get_data_linear _bsd_usb_fifo_get_data_linear
-#define	usb_fifo_put_bytes_max _bsd_usb_fifo_put_bytes_max
-#define	usb_fifo_put_data _bsd_usb_fifo_put_data
-#define	usb_fifo_put_data_buffer _bsd_usb_fifo_put_data_buffer
-#define	usb_fifo_put_data_error _bsd_usb_fifo_put_data_error
-#define	usb_fifo_put_data_linear _bsd_usb_fifo_put_data_linear
-#define	usb_fifo_reset _bsd_usb_fifo_reset
-#define	usb_fifo_set_close_zlp _bsd_usb_fifo_set_close_zlp
-#define	usb_fifo_set_write_defrag _bsd_usb_fifo_set_write_defrag
-#define	usb_fifo_signal _bsd_usb_fifo_signal
-#define	usb_fifo_softc _bsd_usb_fifo_softc
-#define	usb_fifo_wait _bsd_usb_fifo_wait
-#define	usb_fifo_wakeup _bsd_usb_fifo_wakeup
-#define	usb_free_device _bsd_usb_free_device
-#define	usb_free_symlink _bsd_usb_free_symlink
-#define	usb_get_device_state _bsd_usb_get_device_state
-#define	usb_get_manufacturer _bsd_usb_get_manufacturer
-#define	usb_get_product _bsd_usb_get_product
-#define	usb_get_serial _bsd_usb_get_serial
-#define	usb_handle_request_callback _bsd_usb_handle_request_callback
-#define	usb_hs_bandwidth_alloc _bsd_usb_hs_bandwidth_alloc
-#define	usb_hs_bandwidth_free _bsd_usb_hs_bandwidth_free
-#define	usb_idesc_foreach _bsd_usb_idesc_foreach
-#define	usb_iface_is_cdrom _bsd_usb_iface_is_cdrom
-#define	usb_isoc_time_expand _bsd_usb_isoc_time_expand
-#define	usb_make_dev _bsd_usb_make_dev
-#define	usb_make_str_desc _bsd_usb_make_str_desc
-#define	usb_msc_auto_quirk _bsd_usb_msc_auto_quirk
-#define	usb_msc_eject _bsd_usb_msc_eject
-#define	usb_msc_read_10 _bsd_usb_msc_read_10
-#define	usb_msc_read_capacity _bsd_usb_msc_read_capacity
-#define	usb_msc_write_10 _bsd_usb_msc_write_10
-#define	usb_needs_explore _bsd_usb_needs_explore
-#define	usb_needs_explore_all _bsd_usb_needs_explore_all
-#define	usb_pause_mtx _bsd_usb_pause_mtx
-#define	usb_pc_alloc_mem _bsd_usb_pc_alloc_mem
-#define	usb_pc_buffer_is_aligned _bsd_usb_pc_buffer_is_aligned
-#define	usb_pc_cpu_flush _bsd_usb_pc_cpu_flush
-#define	usb_pc_cpu_invalidate _bsd_usb_pc_cpu_invalidate
-#define	usb_pc_dmamap_create _bsd_usb_pc_dmamap_create
-#define	usb_pc_dmamap_destroy _bsd_usb_pc_dmamap_destroy
-#define	usb_pc_free_mem _bsd_usb_pc_free_mem
-#define	usb_pc_load_mem _bsd_usb_pc_load_mem
-#define	usb_peer_can_wakeup _bsd_usb_peer_can_wakeup
-#define	usb_port_powerup_delay _bsd_usb_port_powerup_delay
-#define	usb_port_reset_delay _bsd_usb_port_reset_delay
-#define	usb_port_reset_recovery _bsd_usb_port_reset_recovery
-#define	usb_port_resume_delay _bsd_usb_port_resume_delay
-#define	usb_port_root_reset_delay _bsd_usb_port_root_reset_delay
-#define	usb_printbcd _bsd_usb_printbcd
-#define	usb_probe_and_attach _bsd_usb_probe_and_attach
-#define	usb_proc_create _bsd_usb_proc_create
-#define	usb_proc_drain _bsd_usb_proc_drain
-#define	usb_proc_explore_lock _bsd_usb_proc_explore_lock
-#define	usb_proc_explore_msignal _bsd_usb_proc_explore_msignal
-#define	usb_proc_explore_mwait _bsd_usb_proc_explore_mwait
-#define	usb_proc_explore_unlock _bsd_usb_proc_explore_unlock
-#define	usb_proc_free _bsd_usb_proc_free
-#define	usb_proc_is_called_from _bsd_usb_proc_is_called_from
-#define	usb_proc_is_gone _bsd_usb_proc_is_gone
-#define	usb_proc_msignal _bsd_usb_proc_msignal
-#define	usb_proc_mwait _bsd_usb_proc_mwait
-#define	usb_proc_rewakeup _bsd_usb_proc_rewakeup
-#define	usb_quirk_ioctl_p _bsd_usb_quirk_ioctl_p
-#define	usb_quirk_unload _bsd_usb_quirk_unload
-#define	usb_read_symlink _bsd_usb_read_symlink
-#define	usb_ref_lock _bsd_usb_ref_lock
-#define	usb_reset_iface_endpoints _bsd_usb_reset_iface_endpoints
-#define	usb_resume_delay _bsd_usb_resume_delay
-#define	usb_resume_recovery _bsd_usb_resume_recovery
-#define	usb_resume_wait _bsd_usb_resume_wait
-#define	usb_set_address_settle _bsd_usb_set_address_settle
-#define	usb_set_device_state _bsd_usb_set_device_state
-#define	usbss_driver _bsd_usbss_driver
-#define	usb_statestr _bsd_usb_statestr
-#define	usb_string_lang_en _bsd_usb_string_lang_en
-#define	usb_suspend_resume _bsd_usb_suspend_resume
-#define	usb_temp_get_desc_p _bsd_usb_temp_get_desc_p
-#define	usb_template _bsd_usb_template
-#define	usb_temp_setup_by_index_p _bsd_usb_temp_setup_by_index_p
-#define	usb_temp_unload _bsd_usb_temp_unload
-#define	usb_temp_unsetup_p _bsd_usb_temp_unsetup_p
-#define	usb_test_quirk _bsd_usb_test_quirk
-#define	usb_test_quirk_p _bsd_usb_test_quirk_p
-#define	usb_trim_spaces _bsd_usb_trim_spaces
-#define	usb_ugen_methods _bsd_usb_ugen_methods
-#define	uuidcmp _bsd_uuidcmp
-#define	uuid_ether_add _bsd_uuid_ether_add
-#define	uuid_ether_del _bsd_uuid_ether_del
-#define	vesagtf_mode _bsd_vesagtf_mode
-#define	vesagtf_mode_params _bsd_vesagtf_mode_params
-#define	vht80_chan_ranges _bsd_vht80_chan_ranges
-#define	vid_allocate _bsd_vid_allocate
-#define	vid_configure _bsd_vid_configure
-#define	videomode_count _bsd_videomode_count
-#define	videomode_list _bsd_videomode_list
-#define	vid_find_adapter _bsd_vid_find_adapter
-#define	vid_get_adapter _bsd_vid_get_adapter
-#define	vid_get_switch _bsd_vid_get_switch
-#define	vid_init_struct _bsd_vid_init_struct
-#define	vid_register _bsd_vid_register
-#define	vid_release _bsd_vid_release
-#define	vidsw _bsd_vidsw
-#define	vid_unregister _bsd_vid_unregister
-#define	vlan_cookie_p _bsd_vlan_cookie_p
-#define	vlan_devat_p _bsd_vlan_devat_p
-#define	vlan_input_p _bsd_vlan_input_p
-#define	vlan_link_state_p _bsd_vlan_link_state_p
-#define	vlan_mtag_pcp _bsd_vlan_mtag_pcp
-#define	vlan_pcp_p _bsd_vlan_pcp_p
-#define	vlan_setcookie_p _bsd_vlan_setcookie_p
-#define	vlan_tag_p _bsd_vlan_tag_p
-#define	vlan_trunk_cap_p _bsd_vlan_trunk_cap_p
-#define	vlan_trunkdev_p _bsd_vlan_trunkdev_p
-#define	vlog _bsd_vlog
-#define	vnet_if_clone_init _bsd_vnet_if_clone_init
-#define	vprintf _bsd_vprintf
-#define	vsnprintf _bsd_vsnprintf
-#define	vsnrprintf _bsd_vsnrprintf
-#define	vsprintf _bsd_vsprintf
-#define	wakeup _bsd_wakeup
-#define	wakeup_any _bsd_wakeup_any
-#define	wakeup_one _bsd_wakeup_one
-#define	window_deflate _bsd_window_deflate
-#define	window_inflate _bsd_window_inflate
-#define	write_dsfield _bsd_write_dsfield
-#define	xform_ah_authsize _bsd_xform_ah_authsize
-#define	xform_attach _bsd_xform_attach
-#define	xform_detach _bsd_xform_detach
-#define	xform_init _bsd_xform_init
-#define	X_ip6_mforward _bsd_X_ip6_mforward
-#define	X_ip6_mrouter_done _bsd_X_ip6_mrouter_done
-#define	X_ip6_mrouter_get _bsd_X_ip6_mrouter_get
-#define	X_ip6_mrouter_set _bsd_X_ip6_mrouter_set
-#define	X_mrt6_ioctl _bsd_X_mrt6_ioctl
-#define	xpt_bus_deregister _bsd_xpt_bus_deregister
-#define	xpt_bus_register _bsd_xpt_bus_register
-#define	xpt_done _bsd_xpt_done
-#define	z_alloc _bsd_z_alloc
-#define	zd1211b_firmware _bsd_zd1211b_firmware
-#define	zd1211_firmware _bsd_zd1211_firmware
-#define	z_free _bsd_z_free
-#define	zone_clust _bsd_zone_clust
-#define	zone_drain _bsd_zone_drain
-#define	zone_extpgs _bsd_zone_extpgs
-#define	zone_jumbo16 _bsd_zone_jumbo16
-#define	zone_jumbo9 _bsd_zone_jumbo9
-#define	zone_jumbop _bsd_zone_jumbop
-#define	zone_mbuf _bsd_zone_mbuf
-#define	zone_pack _bsd_zone_pack
-#define	zy7_pl_fclk_disable _bsd_zy7_pl_fclk_disable
-#define	zy7_pl_fclk_enable _bsd_zy7_pl_fclk_enable
-#define	zy7_pl_fclk_enabled _bsd_zy7_pl_fclk_enabled
-#define	zy7_pl_fclk_get_freq _bsd_zy7_pl_fclk_get_freq
-#define	zy7_pl_fclk_get_source _bsd_zy7_pl_fclk_get_source
-#define	zy7_pl_fclk_set_freq _bsd_zy7_pl_fclk_set_freq
-#define	zy7_pl_fclk_set_source _bsd_zy7_pl_fclk_set_source
-#define	zy7_pl_level_shifters_disable _bsd_zy7_pl_level_shifters_disable
-#define	zy7_pl_level_shifters_enable _bsd_zy7_pl_level_shifters_enable
-#define	zy7_pl_level_shifters_enabled _bsd_zy7_pl_level_shifters_enabled
-#define	zy7_slcr_postload_pl _bsd_zy7_slcr_postload_pl
+#define AES_CBC_MAC_Final _bsd_AES_CBC_MAC_Final
+#define AES_CBC_MAC_Init _bsd_AES_CBC_MAC_Init
+#define AES_CBC_MAC_Reinit _bsd_AES_CBC_MAC_Reinit
+#define AES_CBC_MAC_Setkey _bsd_AES_CBC_MAC_Setkey
+#define AES_CBC_MAC_Update _bsd_AES_CBC_MAC_Update
+#define AES_GMAC_Final _bsd_AES_GMAC_Final
+#define AES_GMAC_Init _bsd_AES_GMAC_Init
+#define AES_GMAC_Reinit _bsd_AES_GMAC_Reinit
+#define AES_GMAC_Setkey _bsd_AES_GMAC_Setkey
+#define AES_GMAC_Update _bsd_AES_GMAC_Update
+#define AddFragmentPtrLink _bsd_AddFragmentPtrLink
+#define AddLink _bsd_AddLink
+#define AddPptp _bsd_AddPptp
+#define AddSeq _bsd_AddSeq
+#define AliasSctpInit _bsd_AliasSctpInit
+#define AliasSctpTerm _bsd_AliasSctpTerm
+#define BF_decrypt _bsd_BF_decrypt
+#define BF_ecb_encrypt _bsd_BF_ecb_encrypt
+#define BF_encrypt _bsd_BF_encrypt
+#define BF_set_key _bsd_BF_set_key
+#define Camellia_DecryptBlock _bsd_Camellia_DecryptBlock
+#define Camellia_Ekeygen _bsd_Camellia_Ekeygen
+#define Camellia_EncryptBlock _bsd_Camellia_EncryptBlock
+#define ClearCheckNewLink _bsd_ClearCheckNewLink
+#define DELAY _bsd_DELAY
+#define DifferentialChecksum _bsd_DifferentialChecksum
+#define FindAliasAddress _bsd_FindAliasAddress
+#define FindFragmentIn1 _bsd_FindFragmentIn1
+#define FindFragmentIn2 _bsd_FindFragmentIn2
+#define FindFragmentPtr _bsd_FindFragmentPtr
+#define FindIcmpIn _bsd_FindIcmpIn
+#define FindIcmpOut _bsd_FindIcmpOut
+#define FindNewPortGroup _bsd_FindNewPortGroup
+#define FindOriginalAddress _bsd_FindOriginalAddress
+#define FindPptpInByCallId _bsd_FindPptpInByCallId
+#define FindPptpInByPeerCallId _bsd_FindPptpInByPeerCallId
+#define FindPptpOutByCallId _bsd_FindPptpOutByCallId
+#define FindPptpOutByPeerCallId _bsd_FindPptpOutByPeerCallId
+#define FindProtoIn _bsd_FindProtoIn
+#define FindProtoOut _bsd_FindProtoOut
+#define FindRtspOut _bsd_FindRtspOut
+#define FindSctpRedirectAddress _bsd_FindSctpRedirectAddress
+#define FindUdpTcpIn _bsd_FindUdpTcpIn
+#define FindUdpTcpOut _bsd_FindUdpTcpOut
+#define GetAckModified _bsd_GetAckModified
+#define GetAliasAddress _bsd_GetAliasAddress
+#define GetAliasPort _bsd_GetAliasPort
+#define GetDefaultAliasAddress _bsd_GetDefaultAliasAddress
+#define GetDeltaAckIn _bsd_GetDeltaAckIn
+#define GetDeltaSeqOut _bsd_GetDeltaSeqOut
+#define GetDestAddress _bsd_GetDestAddress
+#define GetFragmentAddr _bsd_GetFragmentAddr
+#define GetFragmentPtr _bsd_GetFragmentPtr
+#define GetOriginalAddress _bsd_GetOriginalAddress
+#define GetOriginalPort _bsd_GetOriginalPort
+#define GetProtocolFlags _bsd_GetProtocolFlags
+#define GetProxyAddress _bsd_GetProxyAddress
+#define GetProxyPort _bsd_GetProxyPort
+#define GetStateIn _bsd_GetStateIn
+#define GetStateOut _bsd_GetStateOut
+#define Giant _bsd_Giant
+#define HouseKeeping _bsd_HouseKeeping
+#define LibAliasAddServer _bsd_LibAliasAddServer
+#define LibAliasAttachHandlers _bsd_LibAliasAttachHandlers
+#define LibAliasCheckNewLink _bsd_LibAliasCheckNewLink
+#define LibAliasDetachHandlers _bsd_LibAliasDetachHandlers
+#define LibAliasFragmentIn _bsd_LibAliasFragmentIn
+#define LibAliasGetFragment _bsd_LibAliasGetFragment
+#define LibAliasIn _bsd_LibAliasIn
+#define LibAliasInit _bsd_LibAliasInit
+#define LibAliasInternetChecksum _bsd_LibAliasInternetChecksum
+#define LibAliasOut _bsd_LibAliasOut
+#define LibAliasOutTry _bsd_LibAliasOutTry
+#define LibAliasProxyRule _bsd_LibAliasProxyRule
+#define LibAliasRedirectAddr _bsd_LibAliasRedirectAddr
+#define LibAliasRedirectDelete _bsd_LibAliasRedirectDelete
+#define LibAliasRedirectDynamic _bsd_LibAliasRedirectDynamic
+#define LibAliasRedirectPort _bsd_LibAliasRedirectPort
+#define LibAliasRedirectProto _bsd_LibAliasRedirectProto
+#define LibAliasSaveFragment _bsd_LibAliasSaveFragment
+#define LibAliasSetAddress _bsd_LibAliasSetAddress
+#define LibAliasSetFWBase _bsd_LibAliasSetFWBase
+#define LibAliasSetMode _bsd_LibAliasSetMode
+#define LibAliasSetSkinnyPort _bsd_LibAliasSetSkinnyPort
+#define LibAliasSetTarget _bsd_LibAliasSetTarget
+#define LibAliasUnaliasOut _bsd_LibAliasUnaliasOut
+#define LibAliasUninit _bsd_LibAliasUninit
+#define M_80211_CRYPTO _bsd_M_80211_CRYPTO
+#define M_80211_MESH_GT_RT _bsd_M_80211_MESH_GT_RT
+#define M_80211_MESH_PERR _bsd_M_80211_MESH_PERR
+#define M_80211_MESH_PREP _bsd_M_80211_MESH_PREP
+#define M_80211_MESH_PREQ _bsd_M_80211_MESH_PREQ
+#define M_80211_MESH_RT _bsd_M_80211_MESH_RT
+#define M_80211_NODE _bsd_M_80211_NODE
+#define M_80211_NODE_IE _bsd_M_80211_NODE_IE
+#define M_80211_RATECTL _bsd_M_80211_RATECTL
+#define M_80211_SCAN _bsd_M_80211_SCAN
+#define M_80211_VAP _bsd_M_80211_VAP
+#define M_ACCF _bsd_M_ACCF
+#define M_ALIAS _bsd_M_ALIAS
+#define M_BPF _bsd_M_BPF
+#define M_BPFJIT _bsd_M_BPFJIT
+#define M_CAMSIM _bsd_M_CAMSIM
+#define M_CRYPTO_DATA _bsd_M_CRYPTO_DATA
+#define M_DEVBUF _bsd_M_DEVBUF
+#define M_EVDEV _bsd_M_EVDEV
+#define M_GIF _bsd_M_GIF
+#define M_GRE _bsd_M_GRE
+#define M_IFADDR _bsd_M_IFADDR
+#define M_IFMADDR _bsd_M_IFMADDR
+#define M_IOV _bsd_M_IOV
+#define M_IP6MADDR _bsd_M_IP6MADDR
+#define M_IP6NDP _bsd_M_IP6NDP
+#define M_IPSEC_INPCB _bsd_M_IPSEC_INPCB
+#define M_IPSEC_MISC _bsd_M_IPSEC_MISC
+#define M_IPSEC_SA _bsd_M_IPSEC_SA
+#define M_IPSEC_SAH _bsd_M_IPSEC_SAH
+#define M_IPSEC_SAQ _bsd_M_IPSEC_SAQ
+#define M_IPSEC_SAR _bsd_M_IPSEC_SAR
+#define M_IPSEC_SP _bsd_M_IPSEC_SP
+#define M_IPSEC_SPDCACHE _bsd_M_IPSEC_SPDCACHE
+#define M_IPSEC_SR _bsd_M_IPSEC_SR
+#define M_LLTABLE _bsd_M_LLTABLE
+#define M_NVME _bsd_M_NVME
+#define M_OFWPROP _bsd_M_OFWPROP
+#define M_PCB _bsd_M_PCB
+#define M_PFHASH _bsd_M_PFHASH
+#define M_RTABLE _bsd_M_RTABLE
+#define M_RTWN_PRIV _bsd_M_RTWN_PRIV
+#define M_SONAME _bsd_M_SONAME
+#define M_TAP _bsd_M_TAP
+#define M_TCPFUNCTIONS _bsd_M_TCPFUNCTIONS
+#define M_TCPLOG _bsd_M_TCPLOG
+#define M_TEMP _bsd_M_TEMP
+#define M_USB _bsd_M_USB
+#define M_USBDEV _bsd_M_USBDEV
+#define M_XDATA _bsd_M_XDATA
+#define OF_call_method _bsd_OF_call_method
+#define OF_canon _bsd_OF_canon
+#define OF_child _bsd_OF_child
+#define OF_claim _bsd_OF_claim
+#define OF_close _bsd_OF_close
+#define OF_device_from_xref _bsd_OF_device_from_xref
+#define OF_device_register_xref _bsd_OF_device_register_xref
+#define OF_enter _bsd_OF_enter
+#define OF_exit _bsd_OF_exit
+#define OF_finddevice _bsd_OF_finddevice
+#define OF_getencprop _bsd_OF_getencprop
+#define OF_getencprop_alloc _bsd_OF_getencprop_alloc
+#define OF_getencprop_alloc_multi _bsd_OF_getencprop_alloc_multi
+#define OF_getprop _bsd_OF_getprop
+#define OF_getprop_alloc _bsd_OF_getprop_alloc
+#define OF_getprop_alloc_multi _bsd_OF_getprop_alloc_multi
+#define OF_getproplen _bsd_OF_getproplen
+#define OF_hasprop _bsd_OF_hasprop
+#define OF_init _bsd_OF_init
+#define OF_install _bsd_OF_install
+#define OF_instance_to_package _bsd_OF_instance_to_package
+#define OF_instance_to_path _bsd_OF_instance_to_path
+#define OF_interpret _bsd_OF_interpret
+#define OF_nextprop _bsd_OF_nextprop
+#define OF_node_from_xref _bsd_OF_node_from_xref
+#define OF_open _bsd_OF_open
+#define OF_package_to_path _bsd_OF_package_to_path
+#define OF_parent _bsd_OF_parent
+#define OF_peer _bsd_OF_peer
+#define OF_printf _bsd_OF_printf
+#define OF_prop_free _bsd_OF_prop_free
+#define OF_read _bsd_OF_read
+#define OF_release _bsd_OF_release
+#define OF_searchencprop _bsd_OF_searchencprop
+#define OF_searchprop _bsd_OF_searchprop
+#define OF_seek _bsd_OF_seek
+#define OF_setprop _bsd_OF_setprop
+#define OF_test _bsd_OF_test
+#define OF_write _bsd_OF_write
+#define OF_xref_from_device _bsd_OF_xref_from_device
+#define OF_xref_from_node _bsd_OF_xref_from_node
+#define PFI_MTYPE _bsd_PFI_MTYPE
+#define Poly1305_Final _bsd_Poly1305_Final
+#define Poly1305_Init _bsd_Poly1305_Init
+#define Poly1305_Setkey _bsd_Poly1305_Setkey
+#define Poly1305_Update _bsd_Poly1305_Update
+#define ProxyCheck _bsd_ProxyCheck
+#define ProxyModify _bsd_ProxyModify
+#define RMD160Final _bsd_RMD160Final
+#define RMD160Init _bsd_RMD160Init
+#define RMD160Transform _bsd_RMD160Transform
+#define RMD160Update _bsd_RMD160Update
+#define SCTP6_ARE_ADDR_EQUAL _bsd_SCTP6_ARE_ADDR_EQUAL
+#define SCTP_M_ASC_ADDR _bsd_SCTP_M_ASC_ADDR
+#define SCTP_M_ASC_IT _bsd_SCTP_M_ASC_IT
+#define SCTP_M_AUTH_CL _bsd_SCTP_M_AUTH_CL
+#define SCTP_M_AUTH_HL _bsd_SCTP_M_AUTH_HL
+#define SCTP_M_AUTH_IF _bsd_SCTP_M_AUTH_IF
+#define SCTP_M_AUTH_KY _bsd_SCTP_M_AUTH_KY
+#define SCTP_M_CMSG _bsd_SCTP_M_CMSG
+#define SCTP_M_COPYAL _bsd_SCTP_M_COPYAL
+#define SCTP_M_IFA _bsd_SCTP_M_IFA
+#define SCTP_M_IFN _bsd_SCTP_M_IFN
+#define SCTP_M_ITER _bsd_SCTP_M_ITER
+#define SCTP_M_MAP _bsd_SCTP_M_MAP
+#define SCTP_M_MCORE _bsd_SCTP_M_MCORE
+#define SCTP_M_MVRF _bsd_SCTP_M_MVRF
+#define SCTP_M_SOCKOPT _bsd_SCTP_M_SOCKOPT
+#define SCTP_M_STRESET _bsd_SCTP_M_STRESET
+#define SCTP_M_STRMI _bsd_SCTP_M_STRMI
+#define SCTP_M_STRMO _bsd_SCTP_M_STRMO
+#define SCTP_M_TIMW _bsd_SCTP_M_TIMW
+#define SCTP_M_VRF _bsd_SCTP_M_VRF
+#define SHA256_Final _bsd_SHA256_Final
+#define SHA256_Init _bsd_SHA256_Init
+#define SHA256_Update _bsd_SHA256_Update
+#define SHA384_Final _bsd_SHA384_Final
+#define SHA384_Init _bsd_SHA384_Init
+#define SHA384_Update _bsd_SHA384_Update
+#define SHA512_Final _bsd_SHA512_Final
+#define SHA512_Init _bsd_SHA512_Init
+#define SHA512_Update _bsd_SHA512_Update
+#define SKEIN1024_IV_1024 _bsd_SKEIN1024_IV_1024
+#define SKEIN1024_IV_384 _bsd_SKEIN1024_IV_384
+#define SKEIN1024_IV_512 _bsd_SKEIN1024_IV_512
+#define SKEIN_256_IV_128 _bsd_SKEIN_256_IV_128
+#define SKEIN_256_IV_160 _bsd_SKEIN_256_IV_160
+#define SKEIN_256_IV_224 _bsd_SKEIN_256_IV_224
+#define SKEIN_256_IV_256 _bsd_SKEIN_256_IV_256
+#define SKEIN_512_IV_128 _bsd_SKEIN_512_IV_128
+#define SKEIN_512_IV_160 _bsd_SKEIN_512_IV_160
+#define SKEIN_512_IV_224 _bsd_SKEIN_512_IV_224
+#define SKEIN_512_IV_256 _bsd_SKEIN_512_IV_256
+#define SKEIN_512_IV_384 _bsd_SKEIN_512_IV_384
+#define SKEIN_512_IV_512 _bsd_SKEIN_512_IV_512
+#define SctpAlias _bsd_SctpAlias
+#define SctpShowAliasStats _bsd_SctpShowAliasStats
+#define SetAckModified _bsd_SetAckModified
+#define SetDefaultAliasAddress _bsd_SetDefaultAliasAddress
+#define SetDestCallId _bsd_SetDestCallId
+#define SetExpire _bsd_SetExpire
+#define SetFragmentAddr _bsd_SetFragmentAddr
+#define SetFragmentPtr _bsd_SetFragmentPtr
+#define SetProtocolFlags _bsd_SetProtocolFlags
+#define SetProxyAddress _bsd_SetProxyAddress
+#define SetProxyPort _bsd_SetProxyPort
+#define SetStateIn _bsd_SetStateIn
+#define SetStateOut _bsd_SetStateOut
+#define SipHashX _bsd_SipHashX
+#define SipHash_End _bsd_SipHash_End
+#define SipHash_Final _bsd_SipHash_Final
+#define SipHash_InitX _bsd_SipHash_InitX
+#define SipHash_SetKey _bsd_SipHash_SetKey
+#define SipHash_Update _bsd_SipHash_Update
+#define Skein1024_Final _bsd_Skein1024_Final
+#define Skein1024_Final_Pad _bsd_Skein1024_Final_Pad
+#define Skein1024_Init _bsd_Skein1024_Init
+#define Skein1024_InitExt _bsd_Skein1024_InitExt
+#define Skein1024_Output _bsd_Skein1024_Output
+#define Skein1024_Process_Block _bsd_Skein1024_Process_Block
+#define Skein1024_Update _bsd_Skein1024_Update
+#define Skein_256_Final _bsd_Skein_256_Final
+#define Skein_256_Final_Pad _bsd_Skein_256_Final_Pad
+#define Skein_256_Init _bsd_Skein_256_Init
+#define Skein_256_InitExt _bsd_Skein_256_InitExt
+#define Skein_256_Output _bsd_Skein_256_Output
+#define Skein_256_Process_Block _bsd_Skein_256_Process_Block
+#define Skein_256_Update _bsd_Skein_256_Update
+#define Skein_512_Final _bsd_Skein_512_Final
+#define Skein_512_Final_Pad _bsd_Skein_512_Final_Pad
+#define Skein_512_Init _bsd_Skein_512_Init
+#define Skein_512_InitExt _bsd_Skein_512_InitExt
+#define Skein_512_Output _bsd_Skein_512_Output
+#define Skein_512_Process_Block _bsd_Skein_512_Process_Block
+#define Skein_512_Update _bsd_Skein_512_Update
+#define TB_DRAIN_WAITER _bsd_TB_DRAIN_WAITER
+#define X_ip6_mforward _bsd_X_ip6_mforward
+#define X_ip6_mrouter_done _bsd_X_ip6_mrouter_done
+#define X_ip6_mrouter_get _bsd_X_ip6_mrouter_get
+#define X_ip6_mrouter_set _bsd_X_ip6_mrouter_set
+#define X_mrt6_ioctl _bsd_X_mrt6_ioctl
+#define _callout_init_lock _bsd__callout_init_lock
+#define _callout_stop_safe _bsd__callout_stop_safe
+#define _ck_epoch_addref _bsd__ck_epoch_addref
+#define _ck_epoch_delref _bsd__ck_epoch_delref
+#define _crypto_onetimeauth_poly1305_pick_best_implementation _bsd__crypto_onetimeauth_poly1305_pick_best_implementation
+#define _cv_timedwait_sbt _bsd__cv_timedwait_sbt
+#define _cv_wait _bsd__cv_wait
+#define _cv_wait_sig _bsd__cv_wait_sig
+#define _cv_wait_unlock _bsd__cv_wait_unlock
+#define _libmd_SHA224_Final _bsd__libmd_SHA224_Final
+#define _libmd_SHA224_Init _bsd__libmd_SHA224_Init
+#define _libmd_SHA224_Update _bsd__libmd_SHA224_Update
+#define _libmd_SHA512_224_Final _bsd__libmd_SHA512_224_Final
+#define _libmd_SHA512_224_Init _bsd__libmd_SHA512_224_Init
+#define _libmd_SHA512_224_Update _bsd__libmd_SHA512_224_Update
+#define _libmd_SHA512_256_Final _bsd__libmd_SHA512_256_Final
+#define _libmd_SHA512_256_Init _bsd__libmd_SHA512_256_Init
+#define _libmd_SHA512_256_Update _bsd__libmd_SHA512_256_Update
+#define _libmd_SKEIN1024_Final _bsd__libmd_SKEIN1024_Final
+#define _libmd_SKEIN1024_Init _bsd__libmd_SKEIN1024_Init
+#define _libmd_SKEIN1024_Update _bsd__libmd_SKEIN1024_Update
+#define _libmd_SKEIN256_Final _bsd__libmd_SKEIN256_Final
+#define _libmd_SKEIN256_Init _bsd__libmd_SKEIN256_Init
+#define _libmd_SKEIN256_Update _bsd__libmd_SKEIN256_Update
+#define _libmd_SKEIN512_Final _bsd__libmd_SKEIN512_Final
+#define _libmd_SKEIN512_Init _bsd__libmd_SKEIN512_Init
+#define _libmd_SKEIN512_Update _bsd__libmd_SKEIN512_Update
+#define _mtx_lock_flags _bsd__mtx_lock_flags
+#define _mtx_unlock_flags _bsd__mtx_unlock_flags
+#define _rw_downgrade _bsd__rw_downgrade
+#define _rw_rlock _bsd__rw_rlock
+#define _rw_runlock _bsd__rw_runlock
+#define _rw_try_rlock _bsd__rw_try_rlock
+#define _rw_try_upgrade _bsd__rw_try_upgrade
+#define _rw_try_wlock _bsd__rw_try_wlock
+#define _rw_wlock _bsd__rw_wlock
+#define _rw_wunlock _bsd__rw_wunlock
+#define _sleep _bsd__sleep
+#define _start_set_crypto_set _bsd__start_set_crypto_set
+#define _start_set_ieee80211_ioctl_getset _bsd__start_set_ieee80211_ioctl_getset
+#define _start_set_ieee80211_ioctl_setset _bsd__start_set_ieee80211_ioctl_setset
+#define _start_set_kbddriver_set _bsd__start_set_kbddriver_set
+#define _start_set_modmetadata_set _bsd__start_set_modmetadata_set
+#define _start_set_nexus _bsd__start_set_nexus
+#define _start_set_ratectl_set _bsd__start_set_ratectl_set
+#define _start_set_scanner_set _bsd__start_set_scanner_set
+#define _start_set_sysctl_set _bsd__start_set_sysctl_set
+#define _start_set_sysinit_set _bsd__start_set_sysinit_set
+#define _stop_set_crypto_set _bsd__stop_set_crypto_set
+#define _stop_set_ieee80211_ioctl_getset _bsd__stop_set_ieee80211_ioctl_getset
+#define _stop_set_ieee80211_ioctl_setset _bsd__stop_set_ieee80211_ioctl_setset
+#define _stop_set_kbddriver_set _bsd__stop_set_kbddriver_set
+#define _stop_set_modmetadata_set _bsd__stop_set_modmetadata_set
+#define _stop_set_nexus _bsd__stop_set_nexus
+#define _stop_set_ratectl_set _bsd__stop_set_ratectl_set
+#define _stop_set_scanner_set _bsd__stop_set_scanner_set
+#define _stop_set_sysctl_set _bsd__stop_set_sysctl_set
+#define _stop_set_sysinit_set _bsd__stop_set_sysinit_set
+#define _sx_slock_int _bsd__sx_slock_int
+#define _sx_sunlock_int _bsd__sx_sunlock_int
+#define _timeout_task_init _bsd__timeout_task_init
+#define accept_filt_add _bsd_accept_filt_add
+#define accept_filt_del _bsd_accept_filt_del
+#define accept_filt_generic_mod_event _bsd_accept_filt_generic_mod_event
+#define accept_filt_get _bsd_accept_filt_get
+#define accept_filt_getopt _bsd_accept_filt_getopt
+#define accept_filt_setopt _bsd_accept_filt_setopt
+#define accept_mtx _bsd_accept_mtx
+#define addrsel_policy_init _bsd_addrsel_policy_init
+#define ah_cleartos _bsd_ah_cleartos
+#define ah_enable _bsd_ah_enable
+#define ah_hdrsiz _bsd_ah_hdrsiz
+#define ah_init0 _bsd_ah_init0
+#define ah_zeroize _bsd_ah_zeroize
+#define ahstat _bsd_ahstat
+#define aio_swake _bsd_aio_swake
+#define alloc_unr _bsd_alloc_unr
+#define alloc_unr64 _bsd_alloc_unr64
+#define alloc_unr_specific _bsd_alloc_unr_specific
+#define alloc_unrl _bsd_alloc_unrl
+#define altq_add _bsd_altq_add
+#define altq_add_queue _bsd_altq_add_queue
+#define altq_attach _bsd_altq_attach
+#define altq_detach _bsd_altq_detach
+#define altq_disable _bsd_altq_disable
+#define altq_enable _bsd_altq_enable
+#define altq_getqstats _bsd_altq_getqstats
+#define altq_input _bsd_altq_input
+#define altq_lookup _bsd_altq_lookup
+#define altq_pfattach _bsd_altq_pfattach
+#define altq_pfdetach _bsd_altq_pfdetach
+#define altq_remove _bsd_altq_remove
+#define altq_remove_queue _bsd_altq_remove_queue
+#define altqs_inactive_open _bsd_altqs_inactive_open
+#define am335x_pwm_config_ecap _bsd_am335x_pwm_config_ecap
+#define am335x_pwmss_driver _bsd_am335x_pwmss_driver
+#define arp_announce_ifaddr _bsd_arp_announce_ifaddr
+#define arp_ifinit _bsd_arp_ifinit
+#define arprequest _bsd_arprequest
+#define arpresolve _bsd_arpresolve
+#define arpresolve_addr _bsd_arpresolve_addr
+#define arpstat _bsd_arpstat
+#define async_crypto _bsd_async_crypto
+#define auth_algorithm_lookup _bsd_auth_algorithm_lookup
+#define auth_hash_blake2b _bsd_auth_hash_blake2b
+#define auth_hash_blake2s _bsd_auth_hash_blake2s
+#define auth_hash_ccm_cbc_mac_128 _bsd_auth_hash_ccm_cbc_mac_128
+#define auth_hash_ccm_cbc_mac_192 _bsd_auth_hash_ccm_cbc_mac_192
+#define auth_hash_ccm_cbc_mac_256 _bsd_auth_hash_ccm_cbc_mac_256
+#define auth_hash_hmac_md5 _bsd_auth_hash_hmac_md5
+#define auth_hash_hmac_ripemd_160 _bsd_auth_hash_hmac_ripemd_160
+#define auth_hash_hmac_sha1 _bsd_auth_hash_hmac_sha1
+#define auth_hash_hmac_sha2_224 _bsd_auth_hash_hmac_sha2_224
+#define auth_hash_hmac_sha2_256 _bsd_auth_hash_hmac_sha2_256
+#define auth_hash_hmac_sha2_384 _bsd_auth_hash_hmac_sha2_384
+#define auth_hash_hmac_sha2_512 _bsd_auth_hash_hmac_sha2_512
+#define auth_hash_key_md5 _bsd_auth_hash_key_md5
+#define auth_hash_key_sha1 _bsd_auth_hash_key_sha1
+#define auth_hash_nist_gmac_aes_128 _bsd_auth_hash_nist_gmac_aes_128
+#define auth_hash_nist_gmac_aes_192 _bsd_auth_hash_nist_gmac_aes_192
+#define auth_hash_nist_gmac_aes_256 _bsd_auth_hash_nist_gmac_aes_256
+#define auth_hash_null _bsd_auth_hash_null
+#define auth_hash_poly1305 _bsd_auth_hash_poly1305
+#define auth_hash_sha1 _bsd_auth_hash_sha1
+#define auth_hash_sha2_224 _bsd_auth_hash_sha2_224
+#define auth_hash_sha2_256 _bsd_auth_hash_sha2_256
+#define auth_hash_sha2_384 _bsd_auth_hash_sha2_384
+#define auth_hash_sha2_512 _bsd_auth_hash_sha2_512
+#define badport_bandlim _bsd_badport_bandlim
+#define bcd2bin_data _bsd_bcd2bin_data
+#define bce_COM_b06FwBss _bsd_bce_COM_b06FwBss
+#define bce_COM_b06FwBssAddr _bsd_bce_COM_b06FwBssAddr
+#define bce_COM_b06FwBssLen _bsd_bce_COM_b06FwBssLen
+#define bce_COM_b06FwData _bsd_bce_COM_b06FwData
+#define bce_COM_b06FwDataAddr _bsd_bce_COM_b06FwDataAddr
+#define bce_COM_b06FwDataLen _bsd_bce_COM_b06FwDataLen
+#define bce_COM_b06FwReleaseFix _bsd_bce_COM_b06FwReleaseFix
+#define bce_COM_b06FwReleaseMajor _bsd_bce_COM_b06FwReleaseMajor
+#define bce_COM_b06FwReleaseMinor _bsd_bce_COM_b06FwReleaseMinor
+#define bce_COM_b06FwRodata _bsd_bce_COM_b06FwRodata
+#define bce_COM_b06FwRodataAddr _bsd_bce_COM_b06FwRodataAddr
+#define bce_COM_b06FwRodataLen _bsd_bce_COM_b06FwRodataLen
+#define bce_COM_b06FwSDataAddr _bsd_bce_COM_b06FwSDataAddr
+#define bce_COM_b06FwSDataLen _bsd_bce_COM_b06FwSDataLen
+#define bce_COM_b06FwSbss _bsd_bce_COM_b06FwSbss
+#define bce_COM_b06FwSbssAddr _bsd_bce_COM_b06FwSbssAddr
+#define bce_COM_b06FwSbssLen _bsd_bce_COM_b06FwSbssLen
+#define bce_COM_b06FwSdata _bsd_bce_COM_b06FwSdata
+#define bce_COM_b06FwStartAddr _bsd_bce_COM_b06FwStartAddr
+#define bce_COM_b06FwText _bsd_bce_COM_b06FwText
+#define bce_COM_b06FwTextAddr _bsd_bce_COM_b06FwTextAddr
+#define bce_COM_b06FwTextLen _bsd_bce_COM_b06FwTextLen
+#define bce_COM_b09FwBss _bsd_bce_COM_b09FwBss
+#define bce_COM_b09FwBssAddr _bsd_bce_COM_b09FwBssAddr
+#define bce_COM_b09FwBssLen _bsd_bce_COM_b09FwBssLen
+#define bce_COM_b09FwData _bsd_bce_COM_b09FwData
+#define bce_COM_b09FwDataAddr _bsd_bce_COM_b09FwDataAddr
+#define bce_COM_b09FwDataLen _bsd_bce_COM_b09FwDataLen
+#define bce_COM_b09FwReleaseFix _bsd_bce_COM_b09FwReleaseFix
+#define bce_COM_b09FwReleaseMajor _bsd_bce_COM_b09FwReleaseMajor
+#define bce_COM_b09FwReleaseMinor _bsd_bce_COM_b09FwReleaseMinor
+#define bce_COM_b09FwRodata _bsd_bce_COM_b09FwRodata
+#define bce_COM_b09FwRodataAddr _bsd_bce_COM_b09FwRodataAddr
+#define bce_COM_b09FwRodataLen _bsd_bce_COM_b09FwRodataLen
+#define bce_COM_b09FwSDataAddr _bsd_bce_COM_b09FwSDataAddr
+#define bce_COM_b09FwSDataLen _bsd_bce_COM_b09FwSDataLen
+#define bce_COM_b09FwSbss _bsd_bce_COM_b09FwSbss
+#define bce_COM_b09FwSbssAddr _bsd_bce_COM_b09FwSbssAddr
+#define bce_COM_b09FwSbssLen _bsd_bce_COM_b09FwSbssLen
+#define bce_COM_b09FwSdata _bsd_bce_COM_b09FwSdata
+#define bce_COM_b09FwStartAddr _bsd_bce_COM_b09FwStartAddr
+#define bce_COM_b09FwText _bsd_bce_COM_b09FwText
+#define bce_COM_b09FwTextAddr _bsd_bce_COM_b09FwTextAddr
+#define bce_COM_b09FwTextLen _bsd_bce_COM_b09FwTextLen
+#define bce_CP_b06FwBss _bsd_bce_CP_b06FwBss
+#define bce_CP_b06FwBssAddr _bsd_bce_CP_b06FwBssAddr
+#define bce_CP_b06FwBssLen _bsd_bce_CP_b06FwBssLen
+#define bce_CP_b06FwData _bsd_bce_CP_b06FwData
+#define bce_CP_b06FwDataAddr _bsd_bce_CP_b06FwDataAddr
+#define bce_CP_b06FwDataLen _bsd_bce_CP_b06FwDataLen
+#define bce_CP_b06FwReleaseFix _bsd_bce_CP_b06FwReleaseFix
+#define bce_CP_b06FwReleaseMajor _bsd_bce_CP_b06FwReleaseMajor
+#define bce_CP_b06FwReleaseMinor _bsd_bce_CP_b06FwReleaseMinor
+#define bce_CP_b06FwRodata _bsd_bce_CP_b06FwRodata
+#define bce_CP_b06FwRodataAddr _bsd_bce_CP_b06FwRodataAddr
+#define bce_CP_b06FwRodataLen _bsd_bce_CP_b06FwRodataLen
+#define bce_CP_b06FwSDataAddr _bsd_bce_CP_b06FwSDataAddr
+#define bce_CP_b06FwSDataLen _bsd_bce_CP_b06FwSDataLen
+#define bce_CP_b06FwSbss _bsd_bce_CP_b06FwSbss
+#define bce_CP_b06FwSbssAddr _bsd_bce_CP_b06FwSbssAddr
+#define bce_CP_b06FwSbssLen _bsd_bce_CP_b06FwSbssLen
+#define bce_CP_b06FwSdata _bsd_bce_CP_b06FwSdata
+#define bce_CP_b06FwStartAddr _bsd_bce_CP_b06FwStartAddr
+#define bce_CP_b06FwText _bsd_bce_CP_b06FwText
+#define bce_CP_b06FwTextAddr _bsd_bce_CP_b06FwTextAddr
+#define bce_CP_b06FwTextLen _bsd_bce_CP_b06FwTextLen
+#define bce_CP_b09FwBss _bsd_bce_CP_b09FwBss
+#define bce_CP_b09FwBssAddr _bsd_bce_CP_b09FwBssAddr
+#define bce_CP_b09FwBssLen _bsd_bce_CP_b09FwBssLen
+#define bce_CP_b09FwData _bsd_bce_CP_b09FwData
+#define bce_CP_b09FwDataAddr _bsd_bce_CP_b09FwDataAddr
+#define bce_CP_b09FwDataLen _bsd_bce_CP_b09FwDataLen
+#define bce_CP_b09FwReleaseFix _bsd_bce_CP_b09FwReleaseFix
+#define bce_CP_b09FwReleaseMajor _bsd_bce_CP_b09FwReleaseMajor
+#define bce_CP_b09FwReleaseMinor _bsd_bce_CP_b09FwReleaseMinor
+#define bce_CP_b09FwRodata _bsd_bce_CP_b09FwRodata
+#define bce_CP_b09FwRodataAddr _bsd_bce_CP_b09FwRodataAddr
+#define bce_CP_b09FwRodataLen _bsd_bce_CP_b09FwRodataLen
+#define bce_CP_b09FwSDataAddr _bsd_bce_CP_b09FwSDataAddr
+#define bce_CP_b09FwSDataLen _bsd_bce_CP_b09FwSDataLen
+#define bce_CP_b09FwSbss _bsd_bce_CP_b09FwSbss
+#define bce_CP_b09FwSbssAddr _bsd_bce_CP_b09FwSbssAddr
+#define bce_CP_b09FwSbssLen _bsd_bce_CP_b09FwSbssLen
+#define bce_CP_b09FwSdata _bsd_bce_CP_b09FwSdata
+#define bce_CP_b09FwStartAddr _bsd_bce_CP_b09FwStartAddr
+#define bce_CP_b09FwText _bsd_bce_CP_b09FwText
+#define bce_CP_b09FwTextAddr _bsd_bce_CP_b09FwTextAddr
+#define bce_CP_b09FwTextLen _bsd_bce_CP_b09FwTextLen
+#define bce_RXP_b06FwBss _bsd_bce_RXP_b06FwBss
+#define bce_RXP_b06FwBssAddr _bsd_bce_RXP_b06FwBssAddr
+#define bce_RXP_b06FwBssLen _bsd_bce_RXP_b06FwBssLen
+#define bce_RXP_b06FwData _bsd_bce_RXP_b06FwData
+#define bce_RXP_b06FwDataAddr _bsd_bce_RXP_b06FwDataAddr
+#define bce_RXP_b06FwDataLen _bsd_bce_RXP_b06FwDataLen
+#define bce_RXP_b06FwReleaseFix _bsd_bce_RXP_b06FwReleaseFix
+#define bce_RXP_b06FwReleaseMajor _bsd_bce_RXP_b06FwReleaseMajor
+#define bce_RXP_b06FwReleaseMinor _bsd_bce_RXP_b06FwReleaseMinor
+#define bce_RXP_b06FwRodata _bsd_bce_RXP_b06FwRodata
+#define bce_RXP_b06FwRodataAddr _bsd_bce_RXP_b06FwRodataAddr
+#define bce_RXP_b06FwRodataLen _bsd_bce_RXP_b06FwRodataLen
+#define bce_RXP_b06FwSDataAddr _bsd_bce_RXP_b06FwSDataAddr
+#define bce_RXP_b06FwSDataLen _bsd_bce_RXP_b06FwSDataLen
+#define bce_RXP_b06FwSbss _bsd_bce_RXP_b06FwSbss
+#define bce_RXP_b06FwSbssAddr _bsd_bce_RXP_b06FwSbssAddr
+#define bce_RXP_b06FwSbssLen _bsd_bce_RXP_b06FwSbssLen
+#define bce_RXP_b06FwSdata _bsd_bce_RXP_b06FwSdata
+#define bce_RXP_b06FwStartAddr _bsd_bce_RXP_b06FwStartAddr
+#define bce_RXP_b06FwText _bsd_bce_RXP_b06FwText
+#define bce_RXP_b06FwTextAddr _bsd_bce_RXP_b06FwTextAddr
+#define bce_RXP_b06FwTextLen _bsd_bce_RXP_b06FwTextLen
+#define bce_RXP_b09FwBss _bsd_bce_RXP_b09FwBss
+#define bce_RXP_b09FwBssAddr _bsd_bce_RXP_b09FwBssAddr
+#define bce_RXP_b09FwBssLen _bsd_bce_RXP_b09FwBssLen
+#define bce_RXP_b09FwData _bsd_bce_RXP_b09FwData
+#define bce_RXP_b09FwDataAddr _bsd_bce_RXP_b09FwDataAddr
+#define bce_RXP_b09FwDataLen _bsd_bce_RXP_b09FwDataLen
+#define bce_RXP_b09FwReleaseFix _bsd_bce_RXP_b09FwReleaseFix
+#define bce_RXP_b09FwReleaseMajor _bsd_bce_RXP_b09FwReleaseMajor
+#define bce_RXP_b09FwReleaseMinor _bsd_bce_RXP_b09FwReleaseMinor
+#define bce_RXP_b09FwRodata _bsd_bce_RXP_b09FwRodata
+#define bce_RXP_b09FwRodataAddr _bsd_bce_RXP_b09FwRodataAddr
+#define bce_RXP_b09FwRodataLen _bsd_bce_RXP_b09FwRodataLen
+#define bce_RXP_b09FwSDataAddr _bsd_bce_RXP_b09FwSDataAddr
+#define bce_RXP_b09FwSDataLen _bsd_bce_RXP_b09FwSDataLen
+#define bce_RXP_b09FwSbss _bsd_bce_RXP_b09FwSbss
+#define bce_RXP_b09FwSbssAddr _bsd_bce_RXP_b09FwSbssAddr
+#define bce_RXP_b09FwSbssLen _bsd_bce_RXP_b09FwSbssLen
+#define bce_RXP_b09FwSdata _bsd_bce_RXP_b09FwSdata
+#define bce_RXP_b09FwStartAddr _bsd_bce_RXP_b09FwStartAddr
+#define bce_RXP_b09FwText _bsd_bce_RXP_b09FwText
+#define bce_RXP_b09FwTextAddr _bsd_bce_RXP_b09FwTextAddr
+#define bce_RXP_b09FwTextLen _bsd_bce_RXP_b09FwTextLen
+#define bce_TPAT_b06FwBss _bsd_bce_TPAT_b06FwBss
+#define bce_TPAT_b06FwBssAddr _bsd_bce_TPAT_b06FwBssAddr
+#define bce_TPAT_b06FwBssLen _bsd_bce_TPAT_b06FwBssLen
+#define bce_TPAT_b06FwData _bsd_bce_TPAT_b06FwData
+#define bce_TPAT_b06FwDataAddr _bsd_bce_TPAT_b06FwDataAddr
+#define bce_TPAT_b06FwDataLen _bsd_bce_TPAT_b06FwDataLen
+#define bce_TPAT_b06FwReleaseFix _bsd_bce_TPAT_b06FwReleaseFix
+#define bce_TPAT_b06FwReleaseMajor _bsd_bce_TPAT_b06FwReleaseMajor
+#define bce_TPAT_b06FwReleaseMinor _bsd_bce_TPAT_b06FwReleaseMinor
+#define bce_TPAT_b06FwRodata _bsd_bce_TPAT_b06FwRodata
+#define bce_TPAT_b06FwRodataAddr _bsd_bce_TPAT_b06FwRodataAddr
+#define bce_TPAT_b06FwRodataLen _bsd_bce_TPAT_b06FwRodataLen
+#define bce_TPAT_b06FwSDataAddr _bsd_bce_TPAT_b06FwSDataAddr
+#define bce_TPAT_b06FwSDataLen _bsd_bce_TPAT_b06FwSDataLen
+#define bce_TPAT_b06FwSbss _bsd_bce_TPAT_b06FwSbss
+#define bce_TPAT_b06FwSbssAddr _bsd_bce_TPAT_b06FwSbssAddr
+#define bce_TPAT_b06FwSbssLen _bsd_bce_TPAT_b06FwSbssLen
+#define bce_TPAT_b06FwSdata _bsd_bce_TPAT_b06FwSdata
+#define bce_TPAT_b06FwStartAddr _bsd_bce_TPAT_b06FwStartAddr
+#define bce_TPAT_b06FwText _bsd_bce_TPAT_b06FwText
+#define bce_TPAT_b06FwTextAddr _bsd_bce_TPAT_b06FwTextAddr
+#define bce_TPAT_b06FwTextLen _bsd_bce_TPAT_b06FwTextLen
+#define bce_TPAT_b09FwBss _bsd_bce_TPAT_b09FwBss
+#define bce_TPAT_b09FwBssAddr _bsd_bce_TPAT_b09FwBssAddr
+#define bce_TPAT_b09FwBssLen _bsd_bce_TPAT_b09FwBssLen
+#define bce_TPAT_b09FwData _bsd_bce_TPAT_b09FwData
+#define bce_TPAT_b09FwDataAddr _bsd_bce_TPAT_b09FwDataAddr
+#define bce_TPAT_b09FwDataLen _bsd_bce_TPAT_b09FwDataLen
+#define bce_TPAT_b09FwReleaseFix _bsd_bce_TPAT_b09FwReleaseFix
+#define bce_TPAT_b09FwReleaseMajor _bsd_bce_TPAT_b09FwReleaseMajor
+#define bce_TPAT_b09FwReleaseMinor _bsd_bce_TPAT_b09FwReleaseMinor
+#define bce_TPAT_b09FwRodata _bsd_bce_TPAT_b09FwRodata
+#define bce_TPAT_b09FwRodataAddr _bsd_bce_TPAT_b09FwRodataAddr
+#define bce_TPAT_b09FwRodataLen _bsd_bce_TPAT_b09FwRodataLen
+#define bce_TPAT_b09FwSDataAddr _bsd_bce_TPAT_b09FwSDataAddr
+#define bce_TPAT_b09FwSDataLen _bsd_bce_TPAT_b09FwSDataLen
+#define bce_TPAT_b09FwSbss _bsd_bce_TPAT_b09FwSbss
+#define bce_TPAT_b09FwSbssAddr _bsd_bce_TPAT_b09FwSbssAddr
+#define bce_TPAT_b09FwSbssLen _bsd_bce_TPAT_b09FwSbssLen
+#define bce_TPAT_b09FwSdata _bsd_bce_TPAT_b09FwSdata
+#define bce_TPAT_b09FwStartAddr _bsd_bce_TPAT_b09FwStartAddr
+#define bce_TPAT_b09FwText _bsd_bce_TPAT_b09FwText
+#define bce_TPAT_b09FwTextAddr _bsd_bce_TPAT_b09FwTextAddr
+#define bce_TPAT_b09FwTextLen _bsd_bce_TPAT_b09FwTextLen
+#define bce_TXP_b06FwBss _bsd_bce_TXP_b06FwBss
+#define bce_TXP_b06FwBssAddr _bsd_bce_TXP_b06FwBssAddr
+#define bce_TXP_b06FwBssLen _bsd_bce_TXP_b06FwBssLen
+#define bce_TXP_b06FwData _bsd_bce_TXP_b06FwData
+#define bce_TXP_b06FwDataAddr _bsd_bce_TXP_b06FwDataAddr
+#define bce_TXP_b06FwDataLen _bsd_bce_TXP_b06FwDataLen
+#define bce_TXP_b06FwReleaseFix _bsd_bce_TXP_b06FwReleaseFix
+#define bce_TXP_b06FwReleaseMajor _bsd_bce_TXP_b06FwReleaseMajor
+#define bce_TXP_b06FwReleaseMinor _bsd_bce_TXP_b06FwReleaseMinor
+#define bce_TXP_b06FwRodata _bsd_bce_TXP_b06FwRodata
+#define bce_TXP_b06FwRodataAddr _bsd_bce_TXP_b06FwRodataAddr
+#define bce_TXP_b06FwRodataLen _bsd_bce_TXP_b06FwRodataLen
+#define bce_TXP_b06FwSDataAddr _bsd_bce_TXP_b06FwSDataAddr
+#define bce_TXP_b06FwSDataLen _bsd_bce_TXP_b06FwSDataLen
+#define bce_TXP_b06FwSbss _bsd_bce_TXP_b06FwSbss
+#define bce_TXP_b06FwSbssAddr _bsd_bce_TXP_b06FwSbssAddr
+#define bce_TXP_b06FwSbssLen _bsd_bce_TXP_b06FwSbssLen
+#define bce_TXP_b06FwSdata _bsd_bce_TXP_b06FwSdata
+#define bce_TXP_b06FwStartAddr _bsd_bce_TXP_b06FwStartAddr
+#define bce_TXP_b06FwText _bsd_bce_TXP_b06FwText
+#define bce_TXP_b06FwTextAddr _bsd_bce_TXP_b06FwTextAddr
+#define bce_TXP_b06FwTextLen _bsd_bce_TXP_b06FwTextLen
+#define bce_TXP_b09FwBss _bsd_bce_TXP_b09FwBss
+#define bce_TXP_b09FwBssAddr _bsd_bce_TXP_b09FwBssAddr
+#define bce_TXP_b09FwBssLen _bsd_bce_TXP_b09FwBssLen
+#define bce_TXP_b09FwData _bsd_bce_TXP_b09FwData
+#define bce_TXP_b09FwDataAddr _bsd_bce_TXP_b09FwDataAddr
+#define bce_TXP_b09FwDataLen _bsd_bce_TXP_b09FwDataLen
+#define bce_TXP_b09FwReleaseFix _bsd_bce_TXP_b09FwReleaseFix
+#define bce_TXP_b09FwReleaseMajor _bsd_bce_TXP_b09FwReleaseMajor
+#define bce_TXP_b09FwReleaseMinor _bsd_bce_TXP_b09FwReleaseMinor
+#define bce_TXP_b09FwRodata _bsd_bce_TXP_b09FwRodata
+#define bce_TXP_b09FwRodataAddr _bsd_bce_TXP_b09FwRodataAddr
+#define bce_TXP_b09FwRodataLen _bsd_bce_TXP_b09FwRodataLen
+#define bce_TXP_b09FwSDataAddr _bsd_bce_TXP_b09FwSDataAddr
+#define bce_TXP_b09FwSDataLen _bsd_bce_TXP_b09FwSDataLen
+#define bce_TXP_b09FwSbss _bsd_bce_TXP_b09FwSbss
+#define bce_TXP_b09FwSbssAddr _bsd_bce_TXP_b09FwSbssAddr
+#define bce_TXP_b09FwSbssLen _bsd_bce_TXP_b09FwSbssLen
+#define bce_TXP_b09FwSdata _bsd_bce_TXP_b09FwSdata
+#define bce_TXP_b09FwStartAddr _bsd_bce_TXP_b09FwStartAddr
+#define bce_TXP_b09FwText _bsd_bce_TXP_b09FwText
+#define bce_TXP_b09FwTextAddr _bsd_bce_TXP_b09FwTextAddr
+#define bce_TXP_b09FwTextLen _bsd_bce_TXP_b09FwTextLen
+#define bce_rv2p_proc1 _bsd_bce_rv2p_proc1
+#define bce_rv2p_proc2 _bsd_bce_rv2p_proc2
+#define bce_xi90_rv2p_proc1 _bsd_bce_xi90_rv2p_proc1
+#define bce_xi90_rv2p_proc2 _bsd_bce_xi90_rv2p_proc2
+#define bce_xi_rv2p_proc1 _bsd_bce_xi_rv2p_proc1
+#define bce_xi_rv2p_proc2 _bsd_bce_xi_rv2p_proc2
+#define be_uuid_dec _bsd_be_uuid_dec
+#define be_uuid_enc _bsd_be_uuid_enc
+#define bin2bcd_data _bsd_bin2bcd_data
+#define blake2b_final_ref _bsd_blake2b_final_ref
+#define blake2b_init_key_ref _bsd_blake2b_init_key_ref
+#define blake2b_init_param_ref _bsd_blake2b_init_param_ref
+#define blake2b_init_ref _bsd_blake2b_init_ref
+#define blake2b_ref _bsd_blake2b_ref
+#define blake2b_update_ref _bsd_blake2b_update_ref
+#define blake2s_final_ref _bsd_blake2s_final_ref
+#define blake2s_init_key_ref _bsd_blake2s_init_key_ref
+#define blake2s_init_param_ref _bsd_blake2s_init_param_ref
+#define blake2s_init_ref _bsd_blake2s_init_ref
+#define blake2s_ref _bsd_blake2s_ref
+#define blake2s_update_ref _bsd_blake2s_update_ref
+#define blist_alloc _bsd_blist_alloc
+#define blist_avail _bsd_blist_avail
+#define blist_create _bsd_blist_create
+#define blist_destroy _bsd_blist_destroy
+#define blist_fill _bsd_blist_fill
+#define blist_free _bsd_blist_free
+#define blist_resize _bsd_blist_resize
+#define blist_stats _bsd_blist_stats
+#define bpf_buffer_append_bytes _bsd_bpf_buffer_append_bytes
+#define bpf_buffer_append_mbuf _bsd_bpf_buffer_append_mbuf
+#define bpf_buffer_free _bsd_bpf_buffer_free
+#define bpf_buffer_init _bsd_bpf_buffer_init
+#define bpf_buffer_ioctl_sblen _bsd_bpf_buffer_ioctl_sblen
+#define bpf_buffer_uiomove _bsd_bpf_buffer_uiomove
+#define bpf_bufheld _bsd_bpf_bufheld
+#define bpf_destroy_jit_filter _bsd_bpf_destroy_jit_filter
+#define bpf_ifdetach_cookie _bsd_bpf_ifdetach_cookie
+#define bpf_maxinsns _bsd_bpf_maxinsns
+#define bpf_mtap _bsd_bpf_mtap
+#define bpf_mtap2 _bsd_bpf_mtap2
+#define bpf_tap _bsd_bpf_tap
+#define bpfattach _bsd_bpfattach
+#define bpfattach2 _bsd_bpfattach2
+#define bpfdetach _bsd_bpfdetach
+#define bridge_control_table _bsd_bridge_control_table
+#define bridge_control_table_size _bsd_bridge_control_table_size
+#define bridge_dn_p _bsd_bridge_dn_p
+#define bridge_rtable_prune_period _bsd_bridge_rtable_prune_period
+#define bstp_attach _bsd_bstp_attach
+#define bstp_create _bsd_bstp_create
+#define bstp_destroy _bsd_bstp_destroy
+#define bstp_detach _bsd_bstp_detach
+#define bstp_disable _bsd_bstp_disable
+#define bstp_enable _bsd_bstp_enable
+#define bstp_etheraddr _bsd_bstp_etheraddr
+#define bstp_init _bsd_bstp_init
+#define bstp_input _bsd_bstp_input
+#define bstp_linkstate _bsd_bstp_linkstate
+#define bstp_list _bsd_bstp_list
+#define bstp_set_autoedge _bsd_bstp_set_autoedge
+#define bstp_set_autoptp _bsd_bstp_set_autoptp
+#define bstp_set_edge _bsd_bstp_set_edge
+#define bstp_set_fdelay _bsd_bstp_set_fdelay
+#define bstp_set_holdcount _bsd_bstp_set_holdcount
+#define bstp_set_htime _bsd_bstp_set_htime
+#define bstp_set_maxage _bsd_bstp_set_maxage
+#define bstp_set_path_cost _bsd_bstp_set_path_cost
+#define bstp_set_port_priority _bsd_bstp_set_port_priority
+#define bstp_set_priority _bsd_bstp_set_priority
+#define bstp_set_protocol _bsd_bstp_set_protocol
+#define bstp_set_ptp _bsd_bstp_set_ptp
+#define bstp_stop _bsd_bstp_stop
+#define bt_tickthreshold _bsd_bt_tickthreshold
+#define bt_timethreshold _bsd_bt_timethreshold
+#define bucket_zones _bsd_bucket_zones
+#define buf_ring_alloc _bsd_buf_ring_alloc
+#define buf_ring_free _bsd_buf_ring_free
+#define bus_activate_resource _bsd_bus_activate_resource
+#define bus_adjust_resource _bsd_bus_adjust_resource
+#define bus_alloc_resource _bsd_bus_alloc_resource
+#define bus_alloc_resources _bsd_bus_alloc_resources
+#define bus_bind_intr _bsd_bus_bind_intr
+#define bus_child_location_str _bsd_bus_child_location_str
+#define bus_child_pnpinfo_str _bsd_bus_child_pnpinfo_str
+#define bus_child_present _bsd_bus_child_present
+#define bus_current_pass _bsd_bus_current_pass
+#define bus_data_generation_check _bsd_bus_data_generation_check
+#define bus_data_generation_update _bsd_bus_data_generation_update
+#define bus_deactivate_resource _bsd_bus_deactivate_resource
+#define bus_delayed_attach_children _bsd_bus_delayed_attach_children
+#define bus_delete_resource _bsd_bus_delete_resource
+#define bus_describe_intr _bsd_bus_describe_intr
+#define bus_dma_tag_create _bsd_bus_dma_tag_create
+#define bus_dma_tag_destroy _bsd_bus_dma_tag_destroy
+#define bus_dmamap_create _bsd_bus_dmamap_create
+#define bus_dmamap_destroy _bsd_bus_dmamap_destroy
+#define bus_dmamap_load _bsd_bus_dmamap_load
+#define bus_dmamap_load_buffer _bsd_bus_dmamap_load_buffer
+#define bus_dmamap_load_mbuf _bsd_bus_dmamap_load_mbuf
+#define bus_dmamap_load_mbuf_sg _bsd_bus_dmamap_load_mbuf_sg
+#define bus_dmamap_sync _bsd_bus_dmamap_sync
+#define bus_dmamap_unload _bsd_bus_dmamap_unload
+#define bus_dmamem_alloc _bsd_bus_dmamem_alloc
+#define bus_dmamem_free _bsd_bus_dmamem_free
+#define bus_enumerate_hinted_children _bsd_bus_enumerate_hinted_children
+#define bus_generic_activate_resource _bsd_bus_generic_activate_resource
+#define bus_generic_add_child _bsd_bus_generic_add_child
+#define bus_generic_adjust_resource _bsd_bus_generic_adjust_resource
+#define bus_generic_alloc_resource _bsd_bus_generic_alloc_resource
+#define bus_generic_attach _bsd_bus_generic_attach
+#define bus_generic_bind_intr _bsd_bus_generic_bind_intr
+#define bus_generic_child_present _bsd_bus_generic_child_present
+#define bus_generic_config_intr _bsd_bus_generic_config_intr
+#define bus_generic_deactivate_resource _bsd_bus_generic_deactivate_resource
+#define bus_generic_describe_intr _bsd_bus_generic_describe_intr
+#define bus_generic_detach _bsd_bus_generic_detach
+#define bus_generic_driver_added _bsd_bus_generic_driver_added
+#define bus_generic_get_bus_tag _bsd_bus_generic_get_bus_tag
+#define bus_generic_get_cpus _bsd_bus_generic_get_cpus
+#define bus_generic_get_dma_tag _bsd_bus_generic_get_dma_tag
+#define bus_generic_get_domain _bsd_bus_generic_get_domain
+#define bus_generic_get_resource_list _bsd_bus_generic_get_resource_list
+#define bus_generic_map_resource _bsd_bus_generic_map_resource
+#define bus_generic_new_pass _bsd_bus_generic_new_pass
+#define bus_generic_print_child _bsd_bus_generic_print_child
+#define bus_generic_probe _bsd_bus_generic_probe
+#define bus_generic_read_ivar _bsd_bus_generic_read_ivar
+#define bus_generic_release_resource _bsd_bus_generic_release_resource
+#define bus_generic_resume _bsd_bus_generic_resume
+#define bus_generic_resume_child _bsd_bus_generic_resume_child
+#define bus_generic_resume_intr _bsd_bus_generic_resume_intr
+#define bus_generic_rl_alloc_resource _bsd_bus_generic_rl_alloc_resource
+#define bus_generic_rl_delete_resource _bsd_bus_generic_rl_delete_resource
+#define bus_generic_rl_get_resource _bsd_bus_generic_rl_get_resource
+#define bus_generic_rl_release_resource _bsd_bus_generic_rl_release_resource
+#define bus_generic_rl_set_resource _bsd_bus_generic_rl_set_resource
+#define bus_generic_setup_intr _bsd_bus_generic_setup_intr
+#define bus_generic_shutdown _bsd_bus_generic_shutdown
+#define bus_generic_suspend _bsd_bus_generic_suspend
+#define bus_generic_suspend_child _bsd_bus_generic_suspend_child
+#define bus_generic_suspend_intr _bsd_bus_generic_suspend_intr
+#define bus_generic_teardown_intr _bsd_bus_generic_teardown_intr
+#define bus_generic_unmap_resource _bsd_bus_generic_unmap_resource
+#define bus_generic_write_ivar _bsd_bus_generic_write_ivar
+#define bus_get_bus_tag _bsd_bus_get_bus_tag
+#define bus_get_cpus _bsd_bus_get_cpus
+#define bus_get_dma_tag _bsd_bus_get_dma_tag
+#define bus_get_domain _bsd_bus_get_domain
+#define bus_get_resource _bsd_bus_get_resource
+#define bus_get_resource_count _bsd_bus_get_resource_count
+#define bus_get_resource_start _bsd_bus_get_resource_start
+#define bus_helper_reset_post _bsd_bus_helper_reset_post
+#define bus_helper_reset_prepare _bsd_bus_helper_reset_prepare
+#define bus_map_resource _bsd_bus_map_resource
+#define bus_null_rescan _bsd_bus_null_rescan
+#define bus_print_child_domain _bsd_bus_print_child_domain
+#define bus_print_child_footer _bsd_bus_print_child_footer
+#define bus_print_child_header _bsd_bus_print_child_header
+#define bus_release_resource _bsd_bus_release_resource
+#define bus_release_resources _bsd_bus_release_resources
+#define bus_resume_intr _bsd_bus_resume_intr
+#define bus_set_pass _bsd_bus_set_pass
+#define bus_set_resource _bsd_bus_set_resource
+#define bus_setup_intr _bsd_bus_setup_intr
+#define bus_suspend_intr _bsd_bus_suspend_intr
+#define bus_teardown_intr _bsd_bus_teardown_intr
+#define bus_unmap_resource _bsd_bus_unmap_resource
+#define busdma_lock_mutex _bsd_busdma_lock_mutex
+#define calculate_crc32c _bsd_calculate_crc32c
+#define callout_handle_init _bsd_callout_handle_init
+#define callout_init _bsd_callout_init
+#define callout_process _bsd_callout_process
+#define callout_reset_sbt_on _bsd_callout_reset_sbt_on
+#define callout_schedule _bsd_callout_schedule
+#define callout_schedule_on _bsd_callout_schedule_on
+#define callout_when _bsd_callout_when
+#define cam_fetch_status_entry _bsd_cam_fetch_status_entry
+#define cam_quirkmatch _bsd_cam_quirkmatch
+#define cam_sim_alloc _bsd_cam_sim_alloc
+#define cam_sim_free _bsd_cam_sim_free
+#define cam_simq_alloc _bsd_cam_simq_alloc
+#define cam_simq_free _bsd_cam_simq_free
+#define cam_sort_io_queues _bsd_cam_sort_io_queues
+#define cam_status_table _bsd_cam_status_table
+#define cam_strmatch _bsd_cam_strmatch
+#define cam_strvis _bsd_cam_strvis
+#define cam_strvis_sbuf _bsd_cam_strvis_sbuf
+#define camellia_decrypt _bsd_camellia_decrypt
+#define camellia_decrypt128 _bsd_camellia_decrypt128
+#define camellia_decrypt256 _bsd_camellia_decrypt256
+#define camellia_encrypt _bsd_camellia_encrypt
+#define camellia_encrypt128 _bsd_camellia_encrypt128
+#define camellia_encrypt256 _bsd_camellia_encrypt256
+#define camellia_set_key _bsd_camellia_set_key
+#define camellia_setup128 _bsd_camellia_setup128
+#define camellia_setup192 _bsd_camellia_setup192
+#define camellia_setup256 _bsd_camellia_setup256
+#define carp6_input _bsd_carp6_input
+#define carp_attach _bsd_carp_attach
+#define carp_attach_p _bsd_carp_attach_p
+#define carp_demote_adj_p _bsd_carp_demote_adj_p
+#define carp_detach _bsd_carp_detach
+#define carp_detach_p _bsd_carp_detach_p
+#define carp_forus _bsd_carp_forus
+#define carp_forus_p _bsd_carp_forus_p
+#define carp_get_vhid_p _bsd_carp_get_vhid_p
+#define carp_iamatch _bsd_carp_iamatch
+#define carp_iamatch6 _bsd_carp_iamatch6
+#define carp_iamatch6_p _bsd_carp_iamatch6_p
+#define carp_iamatch_p _bsd_carp_iamatch_p
+#define carp_input _bsd_carp_input
+#define carp_ioctl _bsd_carp_ioctl
+#define carp_ioctl_p _bsd_carp_ioctl_p
+#define carp_linkstate_p _bsd_carp_linkstate_p
+#define carp_macmatch6 _bsd_carp_macmatch6
+#define carp_macmatch6_p _bsd_carp_macmatch6_p
+#define carp_master _bsd_carp_master
+#define carp_master_p _bsd_carp_master_p
+#define carp_output _bsd_carp_output
+#define carp_output_p _bsd_carp_output_p
+#define carpstats _bsd_carpstats
+#define cast_decrypt _bsd_cast_decrypt
+#define cast_encrypt _bsd_cast_encrypt
+#define cast_setkey _bsd_cast_setkey
+#define cc_abe_frlossreduce _bsd_cc_abe_frlossreduce
+#define cc_ack_received _bsd_cc_ack_received
+#define cc_cong_signal _bsd_cc_cong_signal
+#define cc_conn_init _bsd_cc_conn_init
+#define cc_cpu _bsd_cc_cpu
+#define cc_deregister_algo _bsd_cc_deregister_algo
+#define cc_do_abe _bsd_cc_do_abe
+#define cc_list _bsd_cc_list
+#define cc_list_lock _bsd_cc_list_lock
+#define cc_modevent _bsd_cc_modevent
+#define cc_post_recovery _bsd_cc_post_recovery
+#define cc_register_algo _bsd_cc_register_algo
+#define cdevpriv_mtx _bsd_cdevpriv_mtx
+#define cgem_set_ref_clk _bsd_cgem_set_ref_clk
+#define chacha_encrypt_bytes _bsd_chacha_encrypt_bytes
+#define chacha_ivsetup _bsd_chacha_ivsetup
+#define chacha_keysetup _bsd_chacha_keysetup
+#define ck_epoch_barrier _bsd_ck_epoch_barrier
+#define ck_epoch_barrier_wait _bsd_ck_epoch_barrier_wait
+#define ck_epoch_init _bsd_ck_epoch_init
+#define ck_epoch_poll _bsd_ck_epoch_poll
+#define ck_epoch_poll_deferred _bsd_ck_epoch_poll_deferred
+#define ck_epoch_reclaim _bsd_ck_epoch_reclaim
+#define ck_epoch_recycle _bsd_ck_epoch_recycle
+#define ck_epoch_register _bsd_ck_epoch_register
+#define ck_epoch_synchronize _bsd_ck_epoch_synchronize
+#define ck_epoch_synchronize_wait _bsd_ck_epoch_synchronize_wait
+#define ck_epoch_unregister _bsd_ck_epoch_unregister
+#define clean_unrhdr _bsd_clean_unrhdr
+#define clean_unrhdrl _bsd_clean_unrhdrl
+#define clear_unrhdr _bsd_clear_unrhdr
+#define clk_intr_event _bsd_clk_intr_event
+#define comp_algo_deflate _bsd_comp_algo_deflate
+#define comp_algorithm_lookup _bsd_comp_algorithm_lookup
+#define config_intrhook_disestablish _bsd_config_intrhook_disestablish
+#define config_intrhook_establish _bsd_config_intrhook_establish
+#define config_intrhook_oneshot _bsd_config_intrhook_oneshot
+#define copyiniov _bsd_copyiniov
+#define counter_ratecheck _bsd_counter_ratecheck
+#define counter_u64_alloc _bsd_counter_u64_alloc
+#define counter_u64_fetch _bsd_counter_u64_fetch
+#define counter_u64_free _bsd_counter_u64_free
+#define counter_u64_zero _bsd_counter_u64_zero
+#define crc32_tab _bsd_crc32_tab
+#define crypto_apply _bsd_crypto_apply
+#define crypto_contiguous_subsegment _bsd_crypto_contiguous_subsegment
+#define crypto_copyback _bsd_crypto_copyback
+#define crypto_copydata _bsd_crypto_copydata
+#define crypto_devallowsoft _bsd_crypto_devallowsoft
+#define crypto_dispatch _bsd_crypto_dispatch
+#define crypto_done _bsd_crypto_done
+#define crypto_find_device_byhid _bsd_crypto_find_device_byhid
+#define crypto_find_driver _bsd_crypto_find_driver
+#define crypto_freereq _bsd_crypto_freereq
+#define crypto_freesession _bsd_crypto_freesession
+#define crypto_get_driver_session _bsd_crypto_get_driver_session
+#define crypto_get_driverid _bsd_crypto_get_driverid
+#define crypto_getcaps _bsd_crypto_getcaps
+#define crypto_getfeat _bsd_crypto_getfeat
+#define crypto_getreq _bsd_crypto_getreq
+#define crypto_kdispatch _bsd_crypto_kdispatch
+#define crypto_kdone _bsd_crypto_kdone
+#define crypto_kregister _bsd_crypto_kregister
+#define crypto_mbuftoiov _bsd_crypto_mbuftoiov
+#define crypto_modevent _bsd_crypto_modevent
+#define crypto_newsession _bsd_crypto_newsession
+#define crypto_onetimeauth_poly1305 _bsd_crypto_onetimeauth_poly1305
+#define crypto_onetimeauth_poly1305_bytes _bsd_crypto_onetimeauth_poly1305_bytes
+#define crypto_onetimeauth_poly1305_donna_implementation _bsd_crypto_onetimeauth_poly1305_donna_implementation
+#define crypto_onetimeauth_poly1305_final _bsd_crypto_onetimeauth_poly1305_final
+#define crypto_onetimeauth_poly1305_init _bsd_crypto_onetimeauth_poly1305_init
+#define crypto_onetimeauth_poly1305_keybytes _bsd_crypto_onetimeauth_poly1305_keybytes
+#define crypto_onetimeauth_poly1305_statebytes _bsd_crypto_onetimeauth_poly1305_statebytes
+#define crypto_onetimeauth_poly1305_update _bsd_crypto_onetimeauth_poly1305_update
+#define crypto_onetimeauth_poly1305_verify _bsd_crypto_onetimeauth_poly1305_verify
+#define crypto_register _bsd_crypto_register
+#define crypto_ses2caps _bsd_crypto_ses2caps
+#define crypto_ses2hid _bsd_crypto_ses2hid
+#define crypto_support _bsd_crypto_support
+#define crypto_unblock _bsd_crypto_unblock
+#define crypto_unregister _bsd_crypto_unregister
+#define crypto_unregister_all _bsd_crypto_unregister_all
+#define crypto_userasymcrypto _bsd_crypto_userasymcrypto
+#define crypto_verify_16 _bsd_crypto_verify_16
+#define crypto_verify_16_bytes _bsd_crypto_verify_16_bytes
+#define crypto_verify_32 _bsd_crypto_verify_32
+#define crypto_verify_32_bytes _bsd_crypto_verify_32_bytes
+#define crypto_verify_64 _bsd_crypto_verify_64
+#define crypto_verify_64_bytes _bsd_crypto_verify_64_bytes
+#define ctl_subtype_name _bsd_ctl_subtype_name
+#define cuio_apply _bsd_cuio_apply
+#define cuio_copyback _bsd_cuio_copyback
+#define cuio_copydata _bsd_cuio_copydata
+#define cuio_getptr _bsd_cuio_getptr
+#define cv_broadcastpri _bsd_cv_broadcastpri
+#define cv_destroy _bsd_cv_destroy
+#define cv_init _bsd_cv_init
+#define cv_signal _bsd_cv_signal
+#define deembed_scopeid _bsd_deembed_scopeid
+#define default_cc_ptr _bsd_default_cc_ptr
+#define deflate_global _bsd_deflate_global
+#define defrouter_del _bsd_defrouter_del
+#define defrouter_lookup _bsd_defrouter_lookup
+#define defrouter_lookup_locked _bsd_defrouter_lookup_locked
+#define defrouter_ref _bsd_defrouter_ref
+#define defrouter_rele _bsd_defrouter_rele
+#define defrouter_remove _bsd_defrouter_remove
+#define defrouter_reset _bsd_defrouter_reset
+#define defrouter_select _bsd_defrouter_select
+#define defrouter_select_fib _bsd_defrouter_select_fib
+#define defrouter_unlink _bsd_defrouter_unlink
+#define delete_unrhdr _bsd_delete_unrhdr
+#define delist_dev _bsd_delist_dev
+#define deregister_tcp_functions _bsd_deregister_tcp_functions
+#define des_SPtrans _bsd_des_SPtrans
+#define des_check_key _bsd_des_check_key
+#define des_check_key_parity _bsd_des_check_key_parity
+#define des_decrypt3 _bsd_des_decrypt3
+#define des_ecb3_encrypt _bsd_des_ecb3_encrypt
+#define des_ecb_encrypt _bsd_des_ecb_encrypt
+#define des_encrypt1 _bsd_des_encrypt1
+#define des_encrypt2 _bsd_des_encrypt2
+#define des_encrypt3 _bsd_des_encrypt3
+#define des_fixup_key_parity _bsd_des_fixup_key_parity
+#define des_is_weak_key _bsd_des_is_weak_key
+#define des_key_sched _bsd_des_key_sched
+#define des_options _bsd_des_options
+#define des_set_key _bsd_des_set_key
+#define des_set_key_checked _bsd_des_set_key_checked
+#define des_set_key_unchecked _bsd_des_set_key_unchecked
+#define des_set_odd_parity _bsd_des_set_odd_parity
+#define dest6_input _bsd_dest6_input
+#define destroy_dev _bsd_destroy_dev
+#define destroy_dev_sched _bsd_destroy_dev_sched
+#define destroy_dev_sched_cb _bsd_destroy_dev_sched_cb
+#define dev_depends _bsd_dev_depends
+#define dev_lock _bsd_dev_lock
+#define dev_refl _bsd_dev_refl
+#define dev_refthread _bsd_dev_refthread
+#define dev_rel _bsd_dev_rel
+#define dev_relthread _bsd_dev_relthread
+#define dev_unlock _bsd_dev_unlock
+#define devclass_add_driver _bsd_devclass_add_driver
+#define devclass_create _bsd_devclass_create
+#define devclass_delete_driver _bsd_devclass_delete_driver
+#define devclass_find _bsd_devclass_find
+#define devclass_find_free_unit _bsd_devclass_find_free_unit
+#define devclass_get_count _bsd_devclass_get_count
+#define devclass_get_device _bsd_devclass_get_device
+#define devclass_get_devices _bsd_devclass_get_devices
+#define devclass_get_drivers _bsd_devclass_get_drivers
+#define devclass_get_maxunit _bsd_devclass_get_maxunit
+#define devclass_get_name _bsd_devclass_get_name
+#define devclass_get_parent _bsd_devclass_get_parent
+#define devclass_get_softc _bsd_devclass_get_softc
+#define devclass_get_sysctl_ctx _bsd_devclass_get_sysctl_ctx
+#define devclass_get_sysctl_tree _bsd_devclass_get_sysctl_tree
+#define devclass_set_parent _bsd_devclass_set_parent
+#define devctl_notify _bsd_devctl_notify
+#define devctl_notify_f _bsd_devctl_notify_f
+#define devctl_queue_data _bsd_devctl_queue_data
+#define devctl_queue_data_f _bsd_devctl_queue_data_f
+#define devfs_clear_cdevpriv _bsd_devfs_clear_cdevpriv
+#define devfs_destroy_cdevpriv _bsd_devfs_destroy_cdevpriv
+#define devfs_fpdrop _bsd_devfs_fpdrop
+#define devfs_get_cdevpriv _bsd_devfs_get_cdevpriv
+#define devfs_set_cdevpriv _bsd_devfs_set_cdevpriv
+#define device_add_child _bsd_device_add_child
+#define device_add_child_ordered _bsd_device_add_child_ordered
+#define device_attach _bsd_device_attach
+#define device_busy _bsd_device_busy
+#define device_claim_softc _bsd_device_claim_softc
+#define device_delete_child _bsd_device_delete_child
+#define device_delete_children _bsd_device_delete_children
+#define device_detach _bsd_device_detach
+#define device_disable _bsd_device_disable
+#define device_enable _bsd_device_enable
+#define device_find_child _bsd_device_find_child
+#define device_free_softc _bsd_device_free_softc
+#define device_get_children _bsd_device_get_children
+#define device_get_desc _bsd_device_get_desc
+#define device_get_devclass _bsd_device_get_devclass
+#define device_get_driver _bsd_device_get_driver
+#define device_get_flags _bsd_device_get_flags
+#define device_get_ivars _bsd_device_get_ivars
+#define device_get_name _bsd_device_get_name
+#define device_get_nameunit _bsd_device_get_nameunit
+#define device_get_parent _bsd_device_get_parent
+#define device_get_softc _bsd_device_get_softc
+#define device_get_state _bsd_device_get_state
+#define device_get_sysctl_ctx _bsd_device_get_sysctl_ctx
+#define device_get_sysctl_tree _bsd_device_get_sysctl_tree
+#define device_get_unit _bsd_device_get_unit
+#define device_has_quiet_children _bsd_device_has_quiet_children
+#define device_is_alive _bsd_device_is_alive
+#define device_is_attached _bsd_device_is_attached
+#define device_is_devclass_fixed _bsd_device_is_devclass_fixed
+#define device_is_enabled _bsd_device_is_enabled
+#define device_is_quiet _bsd_device_is_quiet
+#define device_is_suspended _bsd_device_is_suspended
+#define device_print_prettyname _bsd_device_print_prettyname
+#define device_printf _bsd_device_printf
+#define device_probe _bsd_device_probe
+#define device_probe_and_attach _bsd_device_probe_and_attach
+#define device_probe_child _bsd_device_probe_child
+#define device_quiesce _bsd_device_quiesce
+#define device_quiet _bsd_device_quiet
+#define device_quiet_children _bsd_device_quiet_children
+#define device_set_desc _bsd_device_set_desc
+#define device_set_desc_copy _bsd_device_set_desc_copy
+#define device_set_devclass _bsd_device_set_devclass
+#define device_set_devclass_fixed _bsd_device_set_devclass_fixed
+#define device_set_driver _bsd_device_set_driver
+#define device_set_flags _bsd_device_set_flags
+#define device_set_ivars _bsd_device_set_ivars
+#define device_set_softc _bsd_device_set_softc
+#define device_set_unit _bsd_device_set_unit
+#define device_set_usb_desc _bsd_device_set_usb_desc
+#define device_shutdown _bsd_device_shutdown
+#define device_unbusy _bsd_device_unbusy
+#define device_verbose _bsd_device_verbose
+#define devmtx _bsd_devmtx
+#define devtoname _bsd_devtoname
+#define div_protosw _bsd_div_protosw
+#define div_usrreqs _bsd_div_usrreqs
+#define domain_add _bsd_domain_add
+#define domain_init _bsd_domain_init
+#define domain_init_status _bsd_domain_init_status
+#define domains _bsd_domains
+#define drbr_dequeue_drv _bsd_drbr_dequeue_drv
+#define drbr_enqueue_drv _bsd_drbr_enqueue_drv
+#define drbr_inuse_drv _bsd_drbr_inuse_drv
+#define drbr_needs_enqueue_drv _bsd_drbr_needs_enqueue_drv
+#define driver_module_handler _bsd_driver_module_handler
+#define dwc_driver _bsd_dwc_driver
+#define dwc_otg_attach _bsd_dwc_otg_attach
+#define dwc_otg_detach _bsd_dwc_otg_detach
+#define dwc_otg_driver _bsd_dwc_otg_driver
+#define dwc_otg_filter_interrupt _bsd_dwc_otg_filter_interrupt
+#define dwc_otg_init _bsd_dwc_otg_init
+#define dwc_otg_interrupt _bsd_dwc_otg_interrupt
+#define dwc_otg_uninit _bsd_dwc_otg_uninit
+#define e1000_acquire_nvm_generic _bsd_e1000_acquire_nvm_generic
+#define e1000_acquire_phy _bsd_e1000_acquire_phy
+#define e1000_acquire_swfw_sync _bsd_e1000_acquire_swfw_sync
+#define e1000_blink_led _bsd_e1000_blink_led
+#define e1000_blink_led_generic _bsd_e1000_blink_led_generic
+#define e1000_calculate_checksum _bsd_e1000_calculate_checksum
+#define e1000_cfg_on_link_up _bsd_e1000_cfg_on_link_up
+#define e1000_check_alt_mac_addr_generic _bsd_e1000_check_alt_mac_addr_generic
+#define e1000_check_downshift_generic _bsd_e1000_check_downshift_generic
+#define e1000_check_for_ack _bsd_e1000_check_for_ack
+#define e1000_check_for_copper_link_generic _bsd_e1000_check_for_copper_link_generic
+#define e1000_check_for_fiber_link_generic _bsd_e1000_check_for_fiber_link_generic
+#define e1000_check_for_link _bsd_e1000_check_for_link
+#define e1000_check_for_msg _bsd_e1000_check_for_msg
+#define e1000_check_for_rst _bsd_e1000_check_for_rst
+#define e1000_check_for_serdes_link_generic _bsd_e1000_check_for_serdes_link_generic
+#define e1000_check_mng_mode _bsd_e1000_check_mng_mode
+#define e1000_check_mng_mode_generic _bsd_e1000_check_mng_mode_generic
+#define e1000_check_phy_82574 _bsd_e1000_check_phy_82574
+#define e1000_check_polarity_82577 _bsd_e1000_check_polarity_82577
+#define e1000_check_polarity_ife _bsd_e1000_check_polarity_ife
+#define e1000_check_polarity_igp _bsd_e1000_check_polarity_igp
+#define e1000_check_polarity_m88 _bsd_e1000_check_polarity_m88
+#define e1000_check_reset_block _bsd_e1000_check_reset_block
+#define e1000_check_reset_block_generic _bsd_e1000_check_reset_block_generic
+#define e1000_cleanup_led _bsd_e1000_cleanup_led
+#define e1000_cleanup_led_generic _bsd_e1000_cleanup_led_generic
+#define e1000_clear_hw_cntrs_base_generic _bsd_e1000_clear_hw_cntrs_base_generic
+#define e1000_clear_vfta _bsd_e1000_clear_vfta
+#define e1000_clear_vfta_generic _bsd_e1000_clear_vfta_generic
+#define e1000_commit_fc_settings_generic _bsd_e1000_commit_fc_settings_generic
+#define e1000_config_collision_dist _bsd_e1000_config_collision_dist
+#define e1000_config_fc_after_link_up_generic _bsd_e1000_config_fc_after_link_up_generic
+#define e1000_configure_k1_ich8lan _bsd_e1000_configure_k1_ich8lan
+#define e1000_copper_link_autoneg _bsd_e1000_copper_link_autoneg
+#define e1000_copper_link_setup_82577 _bsd_e1000_copper_link_setup_82577
+#define e1000_copper_link_setup_igp _bsd_e1000_copper_link_setup_igp
+#define e1000_copper_link_setup_m88 _bsd_e1000_copper_link_setup_m88
+#define e1000_copper_link_setup_m88_gen2 _bsd_e1000_copper_link_setup_m88_gen2
+#define e1000_copy_rx_addrs_to_phy_ich8lan _bsd_e1000_copy_rx_addrs_to_phy_ich8lan
+#define e1000_determine_phy_address _bsd_e1000_determine_phy_address
+#define e1000_disable_pcie_master _bsd_e1000_disable_pcie_master
+#define e1000_disable_pcie_master_generic _bsd_e1000_disable_pcie_master_generic
+#define e1000_disable_phy_wakeup_reg_access_bm _bsd_e1000_disable_phy_wakeup_reg_access_bm
+#define e1000_disable_ulp_lpt_lp _bsd_e1000_disable_ulp_lpt_lp
+#define e1000_enable_mng_pass_thru _bsd_e1000_enable_mng_pass_thru
+#define e1000_enable_phy_wakeup_reg_access_bm _bsd_e1000_enable_phy_wakeup_reg_access_bm
+#define e1000_enable_tx_pkt_filtering _bsd_e1000_enable_tx_pkt_filtering
+#define e1000_enable_tx_pkt_filtering_generic _bsd_e1000_enable_tx_pkt_filtering_generic
+#define e1000_enable_ulp_lpt_lp _bsd_e1000_enable_ulp_lpt_lp
+#define e1000_force_mac_fc _bsd_e1000_force_mac_fc
+#define e1000_force_mac_fc_generic _bsd_e1000_force_mac_fc_generic
+#define e1000_get_auto_rd_done_generic _bsd_e1000_get_auto_rd_done_generic
+#define e1000_get_bus_info _bsd_e1000_get_bus_info
+#define e1000_get_bus_info_pci_generic _bsd_e1000_get_bus_info_pci_generic
+#define e1000_get_bus_info_pcie_generic _bsd_e1000_get_bus_info_pcie_generic
+#define e1000_get_cable_length _bsd_e1000_get_cable_length
+#define e1000_get_cable_length_82577 _bsd_e1000_get_cable_length_82577
+#define e1000_get_cable_length_igp_2 _bsd_e1000_get_cable_length_igp_2
+#define e1000_get_cable_length_m88 _bsd_e1000_get_cable_length_m88
+#define e1000_get_cable_length_m88_gen2 _bsd_e1000_get_cable_length_m88_gen2
+#define e1000_get_cfg_done_generic _bsd_e1000_get_cfg_done_generic
+#define e1000_get_eee_status_i354 _bsd_e1000_get_eee_status_i354
+#define e1000_get_flash_presence_i210 _bsd_e1000_get_flash_presence_i210
+#define e1000_get_hw_semaphore _bsd_e1000_get_hw_semaphore
+#define e1000_get_laa_state_82571 _bsd_e1000_get_laa_state_82571
+#define e1000_get_pba_block_size _bsd_e1000_get_pba_block_size
+#define e1000_get_phy_id _bsd_e1000_get_phy_id
+#define e1000_get_phy_info _bsd_e1000_get_phy_info
+#define e1000_get_phy_info_82577 _bsd_e1000_get_phy_info_82577
+#define e1000_get_phy_info_ife _bsd_e1000_get_phy_info_ife
+#define e1000_get_phy_info_igp _bsd_e1000_get_phy_info_igp
+#define e1000_get_phy_info_m88 _bsd_e1000_get_phy_info_m88
+#define e1000_get_phy_type_from_id _bsd_e1000_get_phy_type_from_id
+#define e1000_get_speed_and_duplex _bsd_e1000_get_speed_and_duplex
+#define e1000_get_speed_and_duplex_copper_generic _bsd_e1000_get_speed_and_duplex_copper_generic
+#define e1000_get_speed_and_duplex_fiber_serdes_generic _bsd_e1000_get_speed_and_duplex_fiber_serdes_generic
+#define e1000_gig_downshift_workaround_ich8lan _bsd_e1000_gig_downshift_workaround_ich8lan
+#define e1000_hash_mc_addr _bsd_e1000_hash_mc_addr
+#define e1000_hash_mc_addr_generic _bsd_e1000_hash_mc_addr_generic
+#define e1000_host_interface_command _bsd_e1000_host_interface_command
+#define e1000_i2c_bus_clear _bsd_e1000_i2c_bus_clear
+#define e1000_id_led_init _bsd_e1000_id_led_init
+#define e1000_id_led_init_generic _bsd_e1000_id_led_init_generic
+#define e1000_igp3_phy_powerdown_workaround_ich8lan _bsd_e1000_igp3_phy_powerdown_workaround_ich8lan
+#define e1000_init_function_pointers_80003es2lan _bsd_e1000_init_function_pointers_80003es2lan
+#define e1000_init_function_pointers_82540 _bsd_e1000_init_function_pointers_82540
+#define e1000_init_function_pointers_82541 _bsd_e1000_init_function_pointers_82541
+#define e1000_init_function_pointers_82542 _bsd_e1000_init_function_pointers_82542
+#define e1000_init_function_pointers_82543 _bsd_e1000_init_function_pointers_82543
+#define e1000_init_function_pointers_82571 _bsd_e1000_init_function_pointers_82571
+#define e1000_init_function_pointers_82575 _bsd_e1000_init_function_pointers_82575
+#define e1000_init_function_pointers_i210 _bsd_e1000_init_function_pointers_i210
+#define e1000_init_function_pointers_ich8lan _bsd_e1000_init_function_pointers_ich8lan
+#define e1000_init_function_pointers_vf _bsd_e1000_init_function_pointers_vf
+#define e1000_init_hw _bsd_e1000_init_hw
+#define e1000_init_hw_82575 _bsd_e1000_init_hw_82575
+#define e1000_init_hw_i210 _bsd_e1000_init_hw_i210
+#define e1000_init_mac_ops_generic _bsd_e1000_init_mac_ops_generic
+#define e1000_init_mac_params _bsd_e1000_init_mac_params
+#define e1000_init_mbx_ops_generic _bsd_e1000_init_mbx_ops_generic
+#define e1000_init_mbx_params _bsd_e1000_init_mbx_params
+#define e1000_init_mbx_params_pf _bsd_e1000_init_mbx_params_pf
+#define e1000_init_mbx_params_vf _bsd_e1000_init_mbx_params_vf
+#define e1000_init_nvm_ops_generic _bsd_e1000_init_nvm_ops_generic
+#define e1000_init_nvm_params _bsd_e1000_init_nvm_params
+#define e1000_init_nvm_params_82575 _bsd_e1000_init_nvm_params_82575
+#define e1000_init_phy_ops_generic _bsd_e1000_init_phy_ops_generic
+#define e1000_init_phy_params _bsd_e1000_init_phy_params
+#define e1000_init_rx_addrs_generic _bsd_e1000_init_rx_addrs_generic
+#define e1000_init_script_state_82541 _bsd_e1000_init_script_state_82541
+#define e1000_initialize_M88E1512_phy _bsd_e1000_initialize_M88E1512_phy
+#define e1000_initialize_M88E1543_phy _bsd_e1000_initialize_M88E1543_phy
+#define e1000_is_mphy_ready _bsd_e1000_is_mphy_ready
+#define e1000_led_off _bsd_e1000_led_off
+#define e1000_led_off_generic _bsd_e1000_led_off_generic
+#define e1000_led_on _bsd_e1000_led_on
+#define e1000_led_on_generic _bsd_e1000_led_on_generic
+#define e1000_link_stall_workaround_hv _bsd_e1000_link_stall_workaround_hv
+#define e1000_load_firmware _bsd_e1000_load_firmware
+#define e1000_lv_jumbo_workaround_ich8lan _bsd_e1000_lv_jumbo_workaround_ich8lan
+#define e1000_mng_enable_host_if _bsd_e1000_mng_enable_host_if
+#define e1000_mng_enable_host_if_generic _bsd_e1000_mng_enable_host_if_generic
+#define e1000_mng_host_if_write _bsd_e1000_mng_host_if_write
+#define e1000_mng_host_if_write_generic _bsd_e1000_mng_host_if_write_generic
+#define e1000_mng_write_cmd_header _bsd_e1000_mng_write_cmd_header
+#define e1000_mng_write_cmd_header_generic _bsd_e1000_mng_write_cmd_header_generic
+#define e1000_mng_write_dhcp_info _bsd_e1000_mng_write_dhcp_info
+#define e1000_mng_write_dhcp_info_generic _bsd_e1000_mng_write_dhcp_info_generic
+#define e1000_null_led_default _bsd_e1000_null_led_default
+#define e1000_null_link_info _bsd_e1000_null_link_info
+#define e1000_null_lplu_state _bsd_e1000_null_lplu_state
+#define e1000_null_mac_generic _bsd_e1000_null_mac_generic
+#define e1000_null_mng_mode _bsd_e1000_null_mng_mode
+#define e1000_null_nvm_generic _bsd_e1000_null_nvm_generic
+#define e1000_null_ops_generic _bsd_e1000_null_ops_generic
+#define e1000_null_phy_generic _bsd_e1000_null_phy_generic
+#define e1000_null_rar_set _bsd_e1000_null_rar_set
+#define e1000_null_read_nvm _bsd_e1000_null_read_nvm
+#define e1000_null_read_reg _bsd_e1000_null_read_reg
+#define e1000_null_set_obff_timer _bsd_e1000_null_set_obff_timer
+#define e1000_null_set_page _bsd_e1000_null_set_page
+#define e1000_null_update_mc _bsd_e1000_null_update_mc
+#define e1000_null_write_nvm _bsd_e1000_null_write_nvm
+#define e1000_null_write_reg _bsd_e1000_null_write_reg
+#define e1000_null_write_vfta _bsd_e1000_null_write_vfta
+#define e1000_pci_clear_mwi _bsd_e1000_pci_clear_mwi
+#define e1000_pci_set_mwi _bsd_e1000_pci_set_mwi
+#define e1000_pcix_mmrbc_workaround_generic _bsd_e1000_pcix_mmrbc_workaround_generic
+#define e1000_phy_commit _bsd_e1000_phy_commit
+#define e1000_phy_force_speed_duplex_82577 _bsd_e1000_phy_force_speed_duplex_82577
+#define e1000_phy_force_speed_duplex_ife _bsd_e1000_phy_force_speed_duplex_ife
+#define e1000_phy_force_speed_duplex_igp _bsd_e1000_phy_force_speed_duplex_igp
+#define e1000_phy_force_speed_duplex_m88 _bsd_e1000_phy_force_speed_duplex_m88
+#define e1000_phy_force_speed_duplex_setup _bsd_e1000_phy_force_speed_duplex_setup
+#define e1000_phy_has_link_generic _bsd_e1000_phy_has_link_generic
+#define e1000_phy_hw_reset _bsd_e1000_phy_hw_reset
+#define e1000_phy_hw_reset_generic _bsd_e1000_phy_hw_reset_generic
+#define e1000_phy_init_script_igp3 _bsd_e1000_phy_init_script_igp3
+#define e1000_phy_reset_dsp_generic _bsd_e1000_phy_reset_dsp_generic
+#define e1000_phy_setup_autoneg _bsd_e1000_phy_setup_autoneg
+#define e1000_phy_sw_reset_generic _bsd_e1000_phy_sw_reset_generic
+#define e1000_poll_eerd_eewr_done _bsd_e1000_poll_eerd_eewr_done
+#define e1000_poll_fiber_serdes_link_generic _bsd_e1000_poll_fiber_serdes_link_generic
+#define e1000_power_down_phy _bsd_e1000_power_down_phy
+#define e1000_power_down_phy_copper _bsd_e1000_power_down_phy_copper
+#define e1000_power_up_fiber_serdes_link _bsd_e1000_power_up_fiber_serdes_link
+#define e1000_power_up_phy _bsd_e1000_power_up_phy
+#define e1000_power_up_phy_copper _bsd_e1000_power_up_phy_copper
+#define e1000_promisc_set_vf _bsd_e1000_promisc_set_vf
+#define e1000_put_hw_semaphore _bsd_e1000_put_hw_semaphore
+#define e1000_rar_set _bsd_e1000_rar_set
+#define e1000_read_emi_reg _bsd_e1000_read_emi_reg
+#define e1000_read_emi_reg_locked _bsd_e1000_read_emi_reg_locked
+#define e1000_read_i2c_byte_generic _bsd_e1000_read_i2c_byte_generic
+#define e1000_read_i2c_byte_null _bsd_e1000_read_i2c_byte_null
+#define e1000_read_kmrn_reg _bsd_e1000_read_kmrn_reg
+#define e1000_read_kmrn_reg_generic _bsd_e1000_read_kmrn_reg_generic
+#define e1000_read_kmrn_reg_locked _bsd_e1000_read_kmrn_reg_locked
+#define e1000_read_mac_addr _bsd_e1000_read_mac_addr
+#define e1000_read_mac_addr_generic _bsd_e1000_read_mac_addr_generic
+#define e1000_read_mbx _bsd_e1000_read_mbx
+#define e1000_read_nvm _bsd_e1000_read_nvm
+#define e1000_read_nvm_eerd _bsd_e1000_read_nvm_eerd
+#define e1000_read_nvm_microwire _bsd_e1000_read_nvm_microwire
+#define e1000_read_nvm_spi _bsd_e1000_read_nvm_spi
+#define e1000_read_nvm_srrd_i210 _bsd_e1000_read_nvm_srrd_i210
+#define e1000_read_pba_length _bsd_e1000_read_pba_length
+#define e1000_read_pba_length_generic _bsd_e1000_read_pba_length_generic
+#define e1000_read_pba_raw _bsd_e1000_read_pba_raw
+#define e1000_read_pba_string _bsd_e1000_read_pba_string
+#define e1000_read_pba_string_generic _bsd_e1000_read_pba_string_generic
+#define e1000_read_pci_cfg _bsd_e1000_read_pci_cfg
+#define e1000_read_pcie_cap_reg _bsd_e1000_read_pcie_cap_reg
+#define e1000_read_phy_reg _bsd_e1000_read_phy_reg
+#define e1000_read_phy_reg_bm _bsd_e1000_read_phy_reg_bm
+#define e1000_read_phy_reg_bm2 _bsd_e1000_read_phy_reg_bm2
+#define e1000_read_phy_reg_gs40g _bsd_e1000_read_phy_reg_gs40g
+#define e1000_read_phy_reg_hv _bsd_e1000_read_phy_reg_hv
+#define e1000_read_phy_reg_hv_locked _bsd_e1000_read_phy_reg_hv_locked
+#define e1000_read_phy_reg_i2c _bsd_e1000_read_phy_reg_i2c
+#define e1000_read_phy_reg_igp _bsd_e1000_read_phy_reg_igp
+#define e1000_read_phy_reg_igp_locked _bsd_e1000_read_phy_reg_igp_locked
+#define e1000_read_phy_reg_m88 _bsd_e1000_read_phy_reg_m88
+#define e1000_read_phy_reg_mdic _bsd_e1000_read_phy_reg_mdic
+#define e1000_read_phy_reg_mphy _bsd_e1000_read_phy_reg_mphy
+#define e1000_read_phy_reg_page_hv _bsd_e1000_read_phy_reg_page_hv
+#define e1000_read_posted_mbx _bsd_e1000_read_posted_mbx
+#define e1000_read_sfp_data_byte _bsd_e1000_read_sfp_data_byte
+#define e1000_read_xmdio_reg _bsd_e1000_read_xmdio_reg
+#define e1000_release_nvm_generic _bsd_e1000_release_nvm_generic
+#define e1000_release_phy _bsd_e1000_release_phy
+#define e1000_release_swfw_sync _bsd_e1000_release_swfw_sync
+#define e1000_reload_nvm _bsd_e1000_reload_nvm
+#define e1000_reset_adaptive _bsd_e1000_reset_adaptive
+#define e1000_reset_adaptive_generic _bsd_e1000_reset_adaptive_generic
+#define e1000_reset_hw _bsd_e1000_reset_hw
+#define e1000_resume_workarounds_pchlan _bsd_e1000_resume_workarounds_pchlan
+#define e1000_rlpml_set_vf _bsd_e1000_rlpml_set_vf
+#define e1000_rx_fifo_flush_82575 _bsd_e1000_rx_fifo_flush_82575
+#define e1000_rxpbs_adjust_82580 _bsd_e1000_rxpbs_adjust_82580
+#define e1000_set_d0_lplu_state _bsd_e1000_set_d0_lplu_state
+#define e1000_set_d3_lplu_state _bsd_e1000_set_d3_lplu_state
+#define e1000_set_d3_lplu_state_generic _bsd_e1000_set_d3_lplu_state_generic
+#define e1000_set_default_fc_generic _bsd_e1000_set_default_fc_generic
+#define e1000_set_eee_i350 _bsd_e1000_set_eee_i350
+#define e1000_set_eee_i354 _bsd_e1000_set_eee_i354
+#define e1000_set_eee_pchlan _bsd_e1000_set_eee_pchlan
+#define e1000_set_fc_watermarks_generic _bsd_e1000_set_fc_watermarks_generic
+#define e1000_set_i2c_bb _bsd_e1000_set_i2c_bb
+#define e1000_set_kmrn_lock_loss_workaround_ich8lan _bsd_e1000_set_kmrn_lock_loss_workaround_ich8lan
+#define e1000_set_laa_state_82571 _bsd_e1000_set_laa_state_82571
+#define e1000_set_lan_id_multi_port_pci _bsd_e1000_set_lan_id_multi_port_pci
+#define e1000_set_lan_id_single_port _bsd_e1000_set_lan_id_single_port
+#define e1000_set_mac_type _bsd_e1000_set_mac_type
+#define e1000_set_obff_timer _bsd_e1000_set_obff_timer
+#define e1000_set_page_igp _bsd_e1000_set_page_igp
+#define e1000_set_pcie_no_snoop_generic _bsd_e1000_set_pcie_no_snoop_generic
+#define e1000_set_tbi_compatibility_82543 _bsd_e1000_set_tbi_compatibility_82543
+#define e1000_setup_copper_link_generic _bsd_e1000_setup_copper_link_generic
+#define e1000_setup_fiber_serdes_link_generic _bsd_e1000_setup_fiber_serdes_link_generic
+#define e1000_setup_init_funcs _bsd_e1000_setup_init_funcs
+#define e1000_setup_led _bsd_e1000_setup_led
+#define e1000_setup_led_generic _bsd_e1000_setup_led_generic
+#define e1000_setup_link _bsd_e1000_setup_link
+#define e1000_setup_link_generic _bsd_e1000_setup_link_generic
+#define e1000_shutdown_fiber_serdes_link _bsd_e1000_shutdown_fiber_serdes_link
+#define e1000_stop_nvm _bsd_e1000_stop_nvm
+#define e1000_suspend_workarounds_ich8lan _bsd_e1000_suspend_workarounds_ich8lan
+#define e1000_tbi_adjust_stats_82543 _bsd_e1000_tbi_adjust_stats_82543
+#define e1000_tbi_sbp_enabled_82543 _bsd_e1000_tbi_sbp_enabled_82543
+#define e1000_translate_register_82542 _bsd_e1000_translate_register_82542
+#define e1000_update_adaptive _bsd_e1000_update_adaptive
+#define e1000_update_adaptive_generic _bsd_e1000_update_adaptive_generic
+#define e1000_update_flash_i210 _bsd_e1000_update_flash_i210
+#define e1000_update_mc_addr_list _bsd_e1000_update_mc_addr_list
+#define e1000_update_mc_addr_list_generic _bsd_e1000_update_mc_addr_list_generic
+#define e1000_update_nvm_checksum _bsd_e1000_update_nvm_checksum
+#define e1000_update_nvm_checksum_generic _bsd_e1000_update_nvm_checksum_generic
+#define e1000_update_nvm_checksum_i210 _bsd_e1000_update_nvm_checksum_i210
+#define e1000_valid_led_default_generic _bsd_e1000_valid_led_default_generic
+#define e1000_validate_mdi_setting _bsd_e1000_validate_mdi_setting
+#define e1000_validate_mdi_setting_crossover_generic _bsd_e1000_validate_mdi_setting_crossover_generic
+#define e1000_validate_nvm_checksum _bsd_e1000_validate_nvm_checksum
+#define e1000_validate_nvm_checksum_generic _bsd_e1000_validate_nvm_checksum_generic
+#define e1000_validate_nvm_checksum_i210 _bsd_e1000_validate_nvm_checksum_i210
+#define e1000_vfta_set_vf _bsd_e1000_vfta_set_vf
+#define e1000_vmdq_set_anti_spoofing_pf _bsd_e1000_vmdq_set_anti_spoofing_pf
+#define e1000_vmdq_set_loopback_pf _bsd_e1000_vmdq_set_loopback_pf
+#define e1000_vmdq_set_replication_pf _bsd_e1000_vmdq_set_replication_pf
+#define e1000_write_8bit_ctrl_reg _bsd_e1000_write_8bit_ctrl_reg
+#define e1000_write_8bit_ctrl_reg_generic _bsd_e1000_write_8bit_ctrl_reg_generic
+#define e1000_write_emi_reg_locked _bsd_e1000_write_emi_reg_locked
+#define e1000_write_i2c_byte_generic _bsd_e1000_write_i2c_byte_generic
+#define e1000_write_i2c_byte_null _bsd_e1000_write_i2c_byte_null
+#define e1000_write_kmrn_reg _bsd_e1000_write_kmrn_reg
+#define e1000_write_kmrn_reg_generic _bsd_e1000_write_kmrn_reg_generic
+#define e1000_write_kmrn_reg_locked _bsd_e1000_write_kmrn_reg_locked
+#define e1000_write_mbx _bsd_e1000_write_mbx
+#define e1000_write_nvm _bsd_e1000_write_nvm
+#define e1000_write_nvm_microwire _bsd_e1000_write_nvm_microwire
+#define e1000_write_nvm_spi _bsd_e1000_write_nvm_spi
+#define e1000_write_nvm_srwr_i210 _bsd_e1000_write_nvm_srwr_i210
+#define e1000_write_pba_raw _bsd_e1000_write_pba_raw
+#define e1000_write_pci_cfg _bsd_e1000_write_pci_cfg
+#define e1000_write_pcie_cap_reg _bsd_e1000_write_pcie_cap_reg
+#define e1000_write_phy_reg _bsd_e1000_write_phy_reg
+#define e1000_write_phy_reg_bm _bsd_e1000_write_phy_reg_bm
+#define e1000_write_phy_reg_bm2 _bsd_e1000_write_phy_reg_bm2
+#define e1000_write_phy_reg_gs40g _bsd_e1000_write_phy_reg_gs40g
+#define e1000_write_phy_reg_hv _bsd_e1000_write_phy_reg_hv
+#define e1000_write_phy_reg_hv_locked _bsd_e1000_write_phy_reg_hv_locked
+#define e1000_write_phy_reg_i2c _bsd_e1000_write_phy_reg_i2c
+#define e1000_write_phy_reg_igp _bsd_e1000_write_phy_reg_igp
+#define e1000_write_phy_reg_igp_locked _bsd_e1000_write_phy_reg_igp_locked
+#define e1000_write_phy_reg_m88 _bsd_e1000_write_phy_reg_m88
+#define e1000_write_phy_reg_mdic _bsd_e1000_write_phy_reg_mdic
+#define e1000_write_phy_reg_mphy _bsd_e1000_write_phy_reg_mphy
+#define e1000_write_phy_reg_page_hv _bsd_e1000_write_phy_reg_page_hv
+#define e1000_write_posted_mbx _bsd_e1000_write_posted_mbx
+#define e1000_write_sfp_data_byte _bsd_e1000_write_sfp_data_byte
+#define e1000_write_vfta _bsd_e1000_write_vfta
+#define e1000_write_vfta_generic _bsd_e1000_write_vfta_generic
+#define e1000_write_vfta_i350 _bsd_e1000_write_vfta_i350
+#define e1000_write_xmdio_reg _bsd_e1000_write_xmdio_reg
+#define early_counter _bsd_early_counter
+#define edid_is_valid _bsd_edid_is_valid
+#define edid_nproducts _bsd_edid_nproducts
+#define edid_nvendors _bsd_edid_nvendors
+#define edid_parse _bsd_edid_parse
+#define edid_print _bsd_edid_print
+#define edid_products _bsd_edid_products
+#define edid_vendors _bsd_edid_vendors
+#define ehci_detach _bsd_ehci_detach
+#define ehci_get_port_speed_hostc _bsd_ehci_get_port_speed_hostc
+#define ehci_get_port_speed_portsc _bsd_ehci_get_port_speed_portsc
+#define ehci_init _bsd_ehci_init
+#define ehci_interrupt _bsd_ehci_interrupt
+#define ehci_iterate_hw_softc _bsd_ehci_iterate_hw_softc
+#define ehci_reset _bsd_ehci_reset
+#define ehci_resume _bsd_ehci_resume
+#define ehci_suspend _bsd_ehci_suspend
+#define em_driver_version _bsd_em_driver_version
+#define em_dump_rs _bsd_em_dump_rs
+#define em_intr _bsd_em_intr
+#define em_sctx _bsd_em_sctx
+#define em_txrx _bsd_em_txrx
+#define enc_algorithm_lookup _bsd_enc_algorithm_lookup
+#define enc_xform_3des _bsd_enc_xform_3des
+#define enc_xform_aes_icm _bsd_enc_xform_aes_icm
+#define enc_xform_aes_nist_gcm _bsd_enc_xform_aes_nist_gcm
+#define enc_xform_aes_nist_gmac _bsd_enc_xform_aes_nist_gmac
+#define enc_xform_aes_xts _bsd_enc_xform_aes_xts
+#define enc_xform_arc4 _bsd_enc_xform_arc4
+#define enc_xform_blf _bsd_enc_xform_blf
+#define enc_xform_camellia _bsd_enc_xform_camellia
+#define enc_xform_cast5 _bsd_enc_xform_cast5
+#define enc_xform_ccm _bsd_enc_xform_ccm
+#define enc_xform_chacha20 _bsd_enc_xform_chacha20
+#define enc_xform_des _bsd_enc_xform_des
+#define enc_xform_null _bsd_enc_xform_null
+#define enc_xform_rijndael128 _bsd_enc_xform_rijndael128
+#define enc_xform_skipjack _bsd_enc_xform_skipjack
+#define encap4_input _bsd_encap4_input
+#define encap6_input _bsd_encap6_input
+#define eopnotsupp _bsd_eopnotsupp
+#define epoch_call _bsd_epoch_call
+#define epoch_drain_callbacks _bsd_epoch_drain_callbacks
+#define epoch_enter _bsd_epoch_enter
+#define epoch_enter_preempt _bsd_epoch_enter_preempt
+#define epoch_exit _bsd_epoch_exit
+#define epoch_exit_preempt _bsd_epoch_exit_preempt
+#define epoch_init _bsd_epoch_init
+#define epoch_wait _bsd_epoch_wait
+#define epoch_wait_preempt _bsd_epoch_wait_preempt
+#define errno2iic _bsd_errno2iic
+#define esp_enable _bsd_esp_enable
+#define esp_hdrsiz _bsd_esp_hdrsiz
+#define espstat _bsd_espstat
+#define ether_8021q_frame _bsd_ether_8021q_frame
+#define ether_crc32_be _bsd_ether_crc32_be
+#define ether_crc32_le _bsd_ether_crc32_le
+#define ether_demux _bsd_ether_demux
+#define ether_gen_addr _bsd_ether_gen_addr
+#define ether_ifattach _bsd_ether_ifattach
+#define ether_ifdetach _bsd_ether_ifdetach
+#define ether_ioctl _bsd_ether_ioctl
+#define ether_output _bsd_ether_output
+#define ether_output_frame _bsd_ether_output_frame
+#define ether_sprintf _bsd_ether_sprintf
+#define ether_vlan_mtap _bsd_ether_vlan_mtap
+#define ether_vlanencap _bsd_ether_vlanencap
+#define ethermulticastaddr_slowprotocols _bsd_ethermulticastaddr_slowprotocols
+#define evdev_alloc _bsd_evdev_alloc
+#define evdev_cdev_create _bsd_evdev_cdev_create
+#define evdev_cdev_destroy _bsd_evdev_cdev_destroy
+#define evdev_client_dumpqueue _bsd_evdev_client_dumpqueue
+#define evdev_client_push _bsd_evdev_client_push
+#define evdev_dispose_client _bsd_evdev_dispose_client
+#define evdev_event_supported _bsd_evdev_event_supported
+#define evdev_free _bsd_evdev_free
+#define evdev_get_last_mt_slot _bsd_evdev_get_last_mt_slot
+#define evdev_get_mt_slot_by_tracking_id _bsd_evdev_get_mt_slot_by_tracking_id
+#define evdev_get_mt_value _bsd_evdev_get_mt_value
+#define evdev_get_softc _bsd_evdev_get_softc
+#define evdev_grab_client _bsd_evdev_grab_client
+#define evdev_hid2key _bsd_evdev_hid2key
+#define evdev_inject_event _bsd_evdev_inject_event
+#define evdev_mt_free _bsd_evdev_mt_free
+#define evdev_mt_init _bsd_evdev_mt_init
+#define evdev_notify_event _bsd_evdev_notify_event
+#define evdev_push_event _bsd_evdev_push_event
+#define evdev_push_leds _bsd_evdev_push_leds
+#define evdev_push_mouse_btn _bsd_evdev_push_mouse_btn
+#define evdev_push_mt_compat _bsd_evdev_push_mt_compat
+#define evdev_push_nfingers _bsd_evdev_push_nfingers
+#define evdev_push_repeats _bsd_evdev_push_repeats
+#define evdev_rcpt_mask _bsd_evdev_rcpt_mask
+#define evdev_register _bsd_evdev_register
+#define evdev_register_client _bsd_evdev_register_client
+#define evdev_register_mtx _bsd_evdev_register_mtx
+#define evdev_release_client _bsd_evdev_release_client
+#define evdev_restore_after_kdb _bsd_evdev_restore_after_kdb
+#define evdev_revoke_client _bsd_evdev_revoke_client
+#define evdev_scancode2key _bsd_evdev_scancode2key
+#define evdev_send_event _bsd_evdev_send_event
+#define evdev_send_mt_autorel _bsd_evdev_send_mt_autorel
+#define evdev_send_mt_compat _bsd_evdev_send_mt_compat
+#define evdev_set_abs_bit _bsd_evdev_set_abs_bit
+#define evdev_set_absinfo _bsd_evdev_set_absinfo
+#define evdev_set_flag _bsd_evdev_set_flag
+#define evdev_set_id _bsd_evdev_set_id
+#define evdev_set_last_mt_slot _bsd_evdev_set_last_mt_slot
+#define evdev_set_methods _bsd_evdev_set_methods
+#define evdev_set_mt_value _bsd_evdev_set_mt_value
+#define evdev_set_name _bsd_evdev_set_name
+#define evdev_set_phys _bsd_evdev_set_phys
+#define evdev_set_repeat_params _bsd_evdev_set_repeat_params
+#define evdev_set_report_size _bsd_evdev_set_report_size
+#define evdev_set_serial _bsd_evdev_set_serial
+#define evdev_support_abs _bsd_evdev_support_abs
+#define evdev_support_all_known_keys _bsd_evdev_support_all_known_keys
+#define evdev_support_event _bsd_evdev_support_event
+#define evdev_support_key _bsd_evdev_support_key
+#define evdev_support_led _bsd_evdev_support_led
+#define evdev_support_msc _bsd_evdev_support_msc
+#define evdev_support_mt_compat _bsd_evdev_support_mt_compat
+#define evdev_support_nfingers _bsd_evdev_support_nfingers
+#define evdev_support_prop _bsd_evdev_support_prop
+#define evdev_support_rel _bsd_evdev_support_rel
+#define evdev_support_snd _bsd_evdev_support_snd
+#define evdev_support_sw _bsd_evdev_support_sw
+#define evdev_sysmouse_t_axis _bsd_evdev_sysmouse_t_axis
+#define evdev_unregister _bsd_evdev_unregister
+#define eventhandler_create_list _bsd_eventhandler_create_list
+#define eventhandler_deregister _bsd_eventhandler_deregister
+#define eventhandler_deregister_nowait _bsd_eventhandler_deregister_nowait
+#define eventhandler_find_list _bsd_eventhandler_find_list
+#define eventhandler_prune_list _bsd_eventhandler_prune_list
+#define eventhandler_register _bsd_eventhandler_register
+#define fb_commonioctl _bsd_fb_commonioctl
+#define fb_dump_adp_info _bsd_fb_dump_adp_info
+#define fb_dump_mode_info _bsd_fb_dump_mode_info
+#define fb_list_head _bsd_fb_list_head
+#define fb_type _bsd_fb_type
+#define fbd_devclass _bsd_fbd_devclass
+#define fbd_driver _bsd_fbd_driver
+#define fbd_list _bsd_fbd_list
+#define fbd_register _bsd_fbd_register
+#define fbd_unregister _bsd_fbd_unregister
+#define fdt_addrsize_cells _bsd_fdt_addrsize_cells
+#define fdt_data_get _bsd_fdt_data_get
+#define fdt_data_to_res _bsd_fdt_data_to_res
+#define fdt_depth_search_compatible _bsd_fdt_depth_search_compatible
+#define fdt_find_compatible _bsd_fdt_find_compatible
+#define fdt_get_chosen_bootargs _bsd_fdt_get_chosen_bootargs
+#define fdt_get_mem_regions _bsd_fdt_get_mem_regions
+#define fdt_get_phyaddr _bsd_fdt_get_phyaddr
+#define fdt_get_range _bsd_fdt_get_range
+#define fdt_get_reserved_mem _bsd_fdt_get_reserved_mem
+#define fdt_get_reserved_regions _bsd_fdt_get_reserved_regions
+#define fdt_ic_list_head _bsd_fdt_ic_list_head
+#define fdt_immr_addr _bsd_fdt_immr_addr
+#define fdt_immr_pa _bsd_fdt_immr_pa
+#define fdt_immr_size _bsd_fdt_immr_size
+#define fdt_immr_va _bsd_fdt_immr_va
+#define fdt_is_compatible_strict _bsd_fdt_is_compatible_strict
+#define fdt_parent_addr_cells _bsd_fdt_parent_addr_cells
+#define fdt_pinctrl_configure _bsd_fdt_pinctrl_configure
+#define fdt_pinctrl_configure_by_name _bsd_fdt_pinctrl_configure_by_name
+#define fdt_pinctrl_configure_tree _bsd_fdt_pinctrl_configure_tree
+#define fdt_pinctrl_register _bsd_fdt_pinctrl_register
+#define fdt_regsize _bsd_fdt_regsize
+#define fib4_free_nh_ext _bsd_fib4_free_nh_ext
+#define fib4_lookup_nh_basic _bsd_fib4_lookup_nh_basic
+#define fib4_lookup_nh_ext _bsd_fib4_lookup_nh_ext
+#define fib6_free_nh_ext _bsd_fib6_free_nh_ext
+#define fib6_lookup_nh_basic _bsd_fib6_lookup_nh_basic
+#define fib6_lookup_nh_ext _bsd_fib6_lookup_nh_ext
+#define find_and_ref_tcp_fb _bsd_find_and_ref_tcp_fb
+#define find_and_ref_tcp_functions _bsd_find_and_ref_tcp_functions
+#define find_handler _bsd_find_handler
+#define firewire_broadcastaddr _bsd_firewire_broadcastaddr
+#define firewire_busreset _bsd_firewire_busreset
+#define firewire_ifattach _bsd_firewire_ifattach
+#define firewire_ifdetach _bsd_firewire_ifdetach
+#define firewire_input _bsd_firewire_input
+#define firewire_ioctl _bsd_firewire_ioctl
+#define firmware_get _bsd_firmware_get
+#define firmware_put _bsd_firmware_put
+#define firmware_register _bsd_firmware_register
+#define firmware_unregister _bsd_firmware_unregister
+#define first_handler _bsd_first_handler
+#define frag6_drain _bsd_frag6_drain
+#define frag6_init _bsd_frag6_init
+#define frag6_input _bsd_frag6_input
+#define frag6_nfrags _bsd_frag6_nfrags
+#define frag6_set_bucketsize _bsd_frag6_set_bucketsize
+#define frag6_slowtimo _bsd_frag6_slowtimo
+#define free_unr _bsd_free_unr
+#define genkbd_commonioctl _bsd_genkbd_commonioctl
+#define genkbd_diag _bsd_genkbd_diag
+#define genkbd_get_fkeystr _bsd_genkbd_get_fkeystr
+#define genkbd_keyaction _bsd_genkbd_keyaction
+#define get_keybuf _bsd_get_keybuf
+#define get_random_bytes _bsd_get_random_bytes
+#define getcredhostuuid _bsd_getcredhostuuid
+#define gf128_genmultable _bsd_gf128_genmultable
+#define gf128_genmultable4 _bsd_gf128_genmultable4
+#define gf128_mul _bsd_gf128_mul
+#define gf128_mul4 _bsd_gf128_mul4
+#define gf128_mul4b _bsd_gf128_mul4b
+#define gif_hashdestroy _bsd_gif_hashdestroy
+#define gif_hashinit _bsd_gif_hashinit
+#define gif_input _bsd_gif_input
+#define gif_output _bsd_gif_output
+#define gpio_alloc_intr_resource _bsd_gpio_alloc_intr_resource
+#define gpio_check_flags _bsd_gpio_check_flags
+#define gpio_pin_get_by_bus_pinnum _bsd_gpio_pin_get_by_bus_pinnum
+#define gpio_pin_get_by_child_index _bsd_gpio_pin_get_by_child_index
+#define gpio_pin_get_by_ofw_idx _bsd_gpio_pin_get_by_ofw_idx
+#define gpio_pin_get_by_ofw_name _bsd_gpio_pin_get_by_ofw_name
+#define gpio_pin_get_by_ofw_property _bsd_gpio_pin_get_by_ofw_property
+#define gpio_pin_get_by_ofw_propidx _bsd_gpio_pin_get_by_ofw_propidx
+#define gpio_pin_getcaps _bsd_gpio_pin_getcaps
+#define gpio_pin_is_active _bsd_gpio_pin_is_active
+#define gpio_pin_release _bsd_gpio_pin_release
+#define gpio_pin_set_active _bsd_gpio_pin_set_active
+#define gpio_pin_setflags _bsd_gpio_pin_setflags
+#define gpiobus_acquire_pin _bsd_gpiobus_acquire_pin
+#define gpiobus_alloc_ivars _bsd_gpiobus_alloc_ivars
+#define gpiobus_attach_bus _bsd_gpiobus_attach_bus
+#define gpiobus_detach_bus _bsd_gpiobus_detach_bus
+#define gpiobus_devclass _bsd_gpiobus_devclass
+#define gpiobus_driver _bsd_gpiobus_driver
+#define gpiobus_free_ivars _bsd_gpiobus_free_ivars
+#define gpiobus_init_softc _bsd_gpiobus_init_softc
+#define gpiobus_release_pin _bsd_gpiobus_release_pin
+#define gre_hashdestroy _bsd_gre_hashdestroy
+#define gre_hashinit _bsd_gre_hashinit
+#define gre_input _bsd_gre_input
+#define gre_sofree _bsd_gre_sofree
+#define gre_update_hdr _bsd_gre_update_hdr
+#define gre_update_udphdr _bsd_gre_update_udphdr
+#define grouptask_block _bsd_grouptask_block
+#define grouptask_unblock _bsd_grouptask_unblock
+#define grouptaskqueue_enqueue _bsd_grouptaskqueue_enqueue
+#define gtaskqueue_block _bsd_gtaskqueue_block
+#define gtaskqueue_cancel _bsd_gtaskqueue_cancel
+#define gtaskqueue_drain _bsd_gtaskqueue_drain
+#define gtaskqueue_drain_all _bsd_gtaskqueue_drain_all
+#define gtaskqueue_unblock _bsd_gtaskqueue_unblock
+#define handlers _bsd_handlers
+#define hashdestroy _bsd_hashdestroy
+#define hashinit _bsd_hashinit
+#define hashinit_flags _bsd_hashinit_flags
+#define hex2ascii_data _bsd_hex2ascii_data
+#define hhook_add_hook _bsd_hhook_add_hook
+#define hhook_add_hook_lookup _bsd_hhook_add_hook_lookup
+#define hhook_head_deregister _bsd_hhook_head_deregister
+#define hhook_head_deregister_lookup _bsd_hhook_head_deregister_lookup
+#define hhook_head_get _bsd_hhook_head_get
+#define hhook_head_is_virtualised _bsd_hhook_head_is_virtualised
+#define hhook_head_is_virtualised_lookup _bsd_hhook_head_is_virtualised_lookup
+#define hhook_head_list _bsd_hhook_head_list
+#define hhook_head_register _bsd_hhook_head_register
+#define hhook_head_release _bsd_hhook_head_release
+#define hhook_remove_hook _bsd_hhook_remove_hook
+#define hhook_remove_hook_lookup _bsd_hhook_remove_hook_lookup
+#define hhook_run_hooks _bsd_hhook_run_hooks
+#define hhook_vhead_list _bsd_hhook_vhead_list
+#define hid_end_parse _bsd_hid_end_parse
+#define hid_get_data _bsd_hid_get_data
+#define hid_get_data_unsigned _bsd_hid_get_data_unsigned
+#define hid_get_descriptor_from_usb _bsd_hid_get_descriptor_from_usb
+#define hid_get_item _bsd_hid_get_item
+#define hid_is_collection _bsd_hid_is_collection
+#define hid_is_keyboard _bsd_hid_is_keyboard
+#define hid_is_mouse _bsd_hid_is_mouse
+#define hid_item_resolution _bsd_hid_item_resolution
+#define hid_locate _bsd_hid_locate
+#define hid_put_data_unsigned _bsd_hid_put_data_unsigned
+#define hid_report_size _bsd_hid_report_size
+#define hid_start_parse _bsd_hid_start_parse
+#define hmac_ipad_buffer _bsd_hmac_ipad_buffer
+#define hmac_opad_buffer _bsd_hmac_opad_buffer
+#define hz _bsd_hz
+#define ic_printf _bsd_ic_printf
+#define icmp6_ctloutput _bsd_icmp6_ctloutput
+#define icmp6_error _bsd_icmp6_error
+#define icmp6_error2 _bsd_icmp6_error2
+#define icmp6_fasttimo _bsd_icmp6_fasttimo
+#define icmp6_input _bsd_icmp6_input
+#define icmp6_mtudisc_update _bsd_icmp6_mtudisc_update
+#define icmp6_nodeinfo _bsd_icmp6_nodeinfo
+#define icmp6_nodeinfo_oldmcprefix _bsd_icmp6_nodeinfo_oldmcprefix
+#define icmp6_rediraccept _bsd_icmp6_rediraccept
+#define icmp6_redirect_input _bsd_icmp6_redirect_input
+#define icmp6_redirect_output _bsd_icmp6_redirect_output
+#define icmp6_redirtimeout _bsd_icmp6_redirtimeout
+#define icmp6_reflect _bsd_icmp6_reflect
+#define icmp6_slowtimo _bsd_icmp6_slowtimo
+#define icmp6errppslim _bsd_icmp6errppslim
+#define icmp6stat _bsd_icmp6stat
+#define icmp_error _bsd_icmp_error
+#define icmp_input _bsd_icmp_input
+#define icmpstat _bsd_icmpstat
+#define ieee80211_aclator_get _bsd_ieee80211_aclator_get
+#define ieee80211_aclator_register _bsd_ieee80211_aclator_register
+#define ieee80211_aclator_unregister _bsd_ieee80211_aclator_unregister
+#define ieee80211_add_callback _bsd_ieee80211_add_callback
+#define ieee80211_add_channel _bsd_ieee80211_add_channel
+#define ieee80211_add_channel_ht40 _bsd_ieee80211_add_channel_ht40
+#define ieee80211_add_channel_list_2ghz _bsd_ieee80211_add_channel_list_2ghz
+#define ieee80211_add_channel_list_5ghz _bsd_ieee80211_add_channel_list_5ghz
+#define ieee80211_add_channels_default_2ghz _bsd_ieee80211_add_channels_default_2ghz
+#define ieee80211_add_htcap _bsd_ieee80211_add_htcap
+#define ieee80211_add_htcap_ch _bsd_ieee80211_add_htcap_ch
+#define ieee80211_add_htcap_vendor _bsd_ieee80211_add_htcap_vendor
+#define ieee80211_add_htinfo _bsd_ieee80211_add_htinfo
+#define ieee80211_add_htinfo_vendor _bsd_ieee80211_add_htinfo_vendor
+#define ieee80211_add_meshconf _bsd_ieee80211_add_meshconf
+#define ieee80211_add_meshgate _bsd_ieee80211_add_meshgate
+#define ieee80211_add_meshid _bsd_ieee80211_add_meshid
+#define ieee80211_add_meshlmetric _bsd_ieee80211_add_meshlmetric
+#define ieee80211_add_meshpeer _bsd_ieee80211_add_meshpeer
+#define ieee80211_add_neighbor _bsd_ieee80211_add_neighbor
+#define ieee80211_add_qos _bsd_ieee80211_add_qos
+#define ieee80211_add_rates _bsd_ieee80211_add_rates
+#define ieee80211_add_rsn _bsd_ieee80211_add_rsn
+#define ieee80211_add_rx_params _bsd_ieee80211_add_rx_params
+#define ieee80211_add_scan _bsd_ieee80211_add_scan
+#define ieee80211_add_ssid _bsd_ieee80211_add_ssid
+#define ieee80211_add_toa_params _bsd_ieee80211_add_toa_params
+#define ieee80211_add_vhtcap _bsd_ieee80211_add_vhtcap
+#define ieee80211_add_vhtinfo _bsd_ieee80211_add_vhtinfo
+#define ieee80211_add_wme_info _bsd_ieee80211_add_wme_info
+#define ieee80211_add_wpa _bsd_ieee80211_add_wpa
+#define ieee80211_add_xmit_params _bsd_ieee80211_add_xmit_params
+#define ieee80211_add_xrates _bsd_ieee80211_add_xrates
+#define ieee80211_addbasicrates _bsd_ieee80211_addbasicrates
+#define ieee80211_adhoc_attach _bsd_ieee80211_adhoc_attach
+#define ieee80211_adhoc_detach _bsd_ieee80211_adhoc_detach
+#define ieee80211_ageq_age _bsd_ieee80211_ageq_age
+#define ieee80211_ageq_append _bsd_ieee80211_ageq_append
+#define ieee80211_ageq_cleanup _bsd_ieee80211_ageq_cleanup
+#define ieee80211_ageq_drain _bsd_ieee80211_ageq_drain
+#define ieee80211_ageq_drain_node _bsd_ieee80211_ageq_drain_node
+#define ieee80211_ageq_init _bsd_ieee80211_ageq_init
+#define ieee80211_ageq_mfree _bsd_ieee80211_ageq_mfree
+#define ieee80211_ageq_remove _bsd_ieee80211_ageq_remove
+#define ieee80211_allmulti _bsd_ieee80211_allmulti
+#define ieee80211_alloc_challenge _bsd_ieee80211_alloc_challenge
+#define ieee80211_alloc_countryie _bsd_ieee80211_alloc_countryie
+#define ieee80211_alloc_cts _bsd_ieee80211_alloc_cts
+#define ieee80211_alloc_node _bsd_ieee80211_alloc_node
+#define ieee80211_alloc_proberesp _bsd_ieee80211_alloc_proberesp
+#define ieee80211_alloc_prot _bsd_ieee80211_alloc_prot
+#define ieee80211_alloc_rts _bsd_ieee80211_alloc_rts
+#define ieee80211_ampdu_reorder _bsd_ieee80211_ampdu_reorder
+#define ieee80211_ampdu_request _bsd_ieee80211_ampdu_request
+#define ieee80211_ampdu_rx_start_ext _bsd_ieee80211_ampdu_rx_start_ext
+#define ieee80211_ampdu_rx_stop_ext _bsd_ieee80211_ampdu_rx_stop_ext
+#define ieee80211_ampdu_stop _bsd_ieee80211_ampdu_stop
+#define ieee80211_ampdu_tx_request_active_ext _bsd_ieee80211_ampdu_tx_request_active_ext
+#define ieee80211_ampdu_tx_request_ext _bsd_ieee80211_ampdu_tx_request_ext
+#define ieee80211_announce _bsd_ieee80211_announce
+#define ieee80211_announce_channels _bsd_ieee80211_announce_channels
+#define ieee80211_authenticator_get _bsd_ieee80211_authenticator_get
+#define ieee80211_authenticator_register _bsd_ieee80211_authenticator_register
+#define ieee80211_authenticator_unregister _bsd_ieee80211_authenticator_unregister
+#define ieee80211_beacon_alloc _bsd_ieee80211_beacon_alloc
+#define ieee80211_beacon_miss _bsd_ieee80211_beacon_miss
+#define ieee80211_beacon_update _bsd_ieee80211_beacon_update
+#define ieee80211_bg_scan _bsd_ieee80211_bg_scan
+#define ieee80211_cac_completeswitch _bsd_ieee80211_cac_completeswitch
+#define ieee80211_cancel_anyscan _bsd_ieee80211_cancel_anyscan
+#define ieee80211_cancel_scan _bsd_ieee80211_cancel_scan
+#define ieee80211_chan2ieee _bsd_ieee80211_chan2ieee
+#define ieee80211_chan2mode _bsd_ieee80211_chan2mode
+#define ieee80211_chan_init _bsd_ieee80211_chan_init
+#define ieee80211_channel_type_char _bsd_ieee80211_channel_type_char
+#define ieee80211_check_scan _bsd_ieee80211_check_scan
+#define ieee80211_check_scan_current _bsd_ieee80211_check_scan_current
+#define ieee80211_cipher_none _bsd_ieee80211_cipher_none
+#define ieee80211_classify _bsd_ieee80211_classify
+#define ieee80211_com_vdecref _bsd_ieee80211_com_vdecref
+#define ieee80211_com_vdetach _bsd_ieee80211_com_vdetach
+#define ieee80211_com_vincref _bsd_ieee80211_com_vincref
+#define ieee80211_compute_duration _bsd_ieee80211_compute_duration
+#define ieee80211_compute_duration_ht _bsd_ieee80211_compute_duration_ht
+#define ieee80211_create_ibss _bsd_ieee80211_create_ibss
+#define ieee80211_crypto_attach _bsd_ieee80211_crypto_attach
+#define ieee80211_crypto_available _bsd_ieee80211_crypto_available
+#define ieee80211_crypto_decap _bsd_ieee80211_crypto_decap
+#define ieee80211_crypto_delglobalkeys _bsd_ieee80211_crypto_delglobalkeys
+#define ieee80211_crypto_delkey _bsd_ieee80211_crypto_delkey
+#define ieee80211_crypto_demic _bsd_ieee80211_crypto_demic
+#define ieee80211_crypto_detach _bsd_ieee80211_crypto_detach
+#define ieee80211_crypto_encap _bsd_ieee80211_crypto_encap
+#define ieee80211_crypto_get_key_wepidx _bsd_ieee80211_crypto_get_key_wepidx
+#define ieee80211_crypto_get_keyid _bsd_ieee80211_crypto_get_keyid
+#define ieee80211_crypto_get_txkey _bsd_ieee80211_crypto_get_txkey
+#define ieee80211_crypto_newkey _bsd_ieee80211_crypto_newkey
+#define ieee80211_crypto_register _bsd_ieee80211_crypto_register
+#define ieee80211_crypto_reload_keys _bsd_ieee80211_crypto_reload_keys
+#define ieee80211_crypto_set_deftxkey _bsd_ieee80211_crypto_set_deftxkey
+#define ieee80211_crypto_setkey _bsd_ieee80211_crypto_setkey
+#define ieee80211_crypto_unregister _bsd_ieee80211_crypto_unregister
+#define ieee80211_crypto_vattach _bsd_ieee80211_crypto_vattach
+#define ieee80211_crypto_vdetach _bsd_ieee80211_crypto_vdetach
+#define ieee80211_csa_cancelswitch _bsd_ieee80211_csa_cancelswitch
+#define ieee80211_csa_completeswitch _bsd_ieee80211_csa_completeswitch
+#define ieee80211_csa_startswitch _bsd_ieee80211_csa_startswitch
+#define ieee80211_decap _bsd_ieee80211_decap
+#define ieee80211_decap1 _bsd_ieee80211_decap1
+#define ieee80211_decap_amsdu _bsd_ieee80211_decap_amsdu
+#define ieee80211_defrag _bsd_ieee80211_defrag
+#define ieee80211_deliver_data _bsd_ieee80211_deliver_data
+#define ieee80211_dfs_attach _bsd_ieee80211_dfs_attach
+#define ieee80211_dfs_cac_clear _bsd_ieee80211_dfs_cac_clear
+#define ieee80211_dfs_cac_start _bsd_ieee80211_dfs_cac_start
+#define ieee80211_dfs_cac_stop _bsd_ieee80211_dfs_cac_stop
+#define ieee80211_dfs_detach _bsd_ieee80211_dfs_detach
+#define ieee80211_dfs_notify_radar _bsd_ieee80211_dfs_notify_radar
+#define ieee80211_dfs_pickchannel _bsd_ieee80211_dfs_pickchannel
+#define ieee80211_dfs_reset _bsd_ieee80211_dfs_reset
+#define ieee80211_drain _bsd_ieee80211_drain
+#define ieee80211_drain_ifq _bsd_ieee80211_drain_ifq
+#define ieee80211_dump_node _bsd_ieee80211_dump_node
+#define ieee80211_dump_nodes _bsd_ieee80211_dump_nodes
+#define ieee80211_dump_pkt _bsd_ieee80211_dump_pkt
+#define ieee80211_dup_bss _bsd_ieee80211_dup_bss
+#define ieee80211_dwds_discover _bsd_ieee80211_dwds_discover
+#define ieee80211_dwds_mcast _bsd_ieee80211_dwds_mcast
+#define ieee80211_encap _bsd_ieee80211_encap
+#define ieee80211_fakeup_adhoc_node _bsd_ieee80211_fakeup_adhoc_node
+#define ieee80211_ff_encap1 _bsd_ieee80211_ff_encap1
+#define ieee80211_find_channel _bsd_ieee80211_find_channel
+#define ieee80211_find_channel_byieee _bsd_ieee80211_find_channel_byieee
+#define ieee80211_find_com _bsd_ieee80211_find_com
+#define ieee80211_find_node _bsd_ieee80211_find_node
+#define ieee80211_find_node_locked _bsd_ieee80211_find_node_locked
+#define ieee80211_find_rxnode _bsd_ieee80211_find_rxnode
+#define ieee80211_find_rxnode_withkey _bsd_ieee80211_find_rxnode_withkey
+#define ieee80211_find_txnode _bsd_ieee80211_find_txnode
+#define ieee80211_find_vap_node _bsd_ieee80211_find_vap_node
+#define ieee80211_find_vap_node_locked _bsd_ieee80211_find_vap_node_locked
+#define ieee80211_fix_rate _bsd_ieee80211_fix_rate
+#define ieee80211_flush_ifq _bsd_ieee80211_flush_ifq
+#define ieee80211_free_mbuf _bsd_ieee80211_free_mbuf
+#define ieee80211_free_node _bsd_ieee80211_free_node
+#define ieee80211_get_channel_center_freq _bsd_ieee80211_get_channel_center_freq
+#define ieee80211_get_channel_center_freq1 _bsd_ieee80211_get_channel_center_freq1
+#define ieee80211_get_channel_center_freq2 _bsd_ieee80211_get_channel_center_freq2
+#define ieee80211_get_ratetable _bsd_ieee80211_get_ratetable
+#define ieee80211_get_rx_params _bsd_ieee80211_get_rx_params
+#define ieee80211_get_rx_params_ptr _bsd_ieee80211_get_rx_params_ptr
+#define ieee80211_get_suphtrates _bsd_ieee80211_get_suphtrates
+#define ieee80211_get_suprates _bsd_ieee80211_get_suprates
+#define ieee80211_get_toa_params _bsd_ieee80211_get_toa_params
+#define ieee80211_get_xmit_params _bsd_ieee80211_get_xmit_params
+#define ieee80211_getcapinfo _bsd_ieee80211_getcapinfo
+#define ieee80211_getmgtframe _bsd_ieee80211_getmgtframe
+#define ieee80211_getrssi _bsd_ieee80211_getrssi
+#define ieee80211_getsignal _bsd_ieee80211_getsignal
+#define ieee80211_hostap_attach _bsd_ieee80211_hostap_attach
+#define ieee80211_hostap_detach _bsd_ieee80211_hostap_detach
+#define ieee80211_ht_adjust_channel _bsd_ieee80211_ht_adjust_channel
+#define ieee80211_ht_announce _bsd_ieee80211_ht_announce
+#define ieee80211_ht_attach _bsd_ieee80211_ht_attach
+#define ieee80211_ht_detach _bsd_ieee80211_ht_detach
+#define ieee80211_ht_node_age _bsd_ieee80211_ht_node_age
+#define ieee80211_ht_node_cleanup _bsd_ieee80211_ht_node_cleanup
+#define ieee80211_ht_node_init _bsd_ieee80211_ht_node_init
+#define ieee80211_ht_node_join _bsd_ieee80211_ht_node_join
+#define ieee80211_ht_node_leave _bsd_ieee80211_ht_node_leave
+#define ieee80211_ht_timeout _bsd_ieee80211_ht_timeout
+#define ieee80211_ht_update_beacon _bsd_ieee80211_ht_update_beacon
+#define ieee80211_ht_updatehtcap _bsd_ieee80211_ht_updatehtcap
+#define ieee80211_ht_updatehtcap_final _bsd_ieee80211_ht_updatehtcap_final
+#define ieee80211_ht_updateparams _bsd_ieee80211_ht_updateparams
+#define ieee80211_ht_updateparams_final _bsd_ieee80211_ht_updateparams_final
+#define ieee80211_ht_vattach _bsd_ieee80211_ht_vattach
+#define ieee80211_ht_vdetach _bsd_ieee80211_ht_vdetach
+#define ieee80211_ht_wds_init _bsd_ieee80211_ht_wds_init
+#define ieee80211_htprot_update _bsd_ieee80211_htprot_update
+#define ieee80211_htrates _bsd_ieee80211_htrates
+#define ieee80211_ibss_merge _bsd_ieee80211_ibss_merge
+#define ieee80211_ibss_merge_check _bsd_ieee80211_ibss_merge_check
+#define ieee80211_ibss_node_check_new _bsd_ieee80211_ibss_node_check_new
+#define ieee80211_ieee2mhz _bsd_ieee80211_ieee2mhz
+#define ieee80211_ies_cleanup _bsd_ieee80211_ies_cleanup
+#define ieee80211_ies_expand _bsd_ieee80211_ies_expand
+#define ieee80211_ies_init _bsd_ieee80211_ies_init
+#define ieee80211_ifattach _bsd_ieee80211_ifattach
+#define ieee80211_ifdetach _bsd_ieee80211_ifdetach
+#define ieee80211_init _bsd_ieee80211_init
+#define ieee80211_init_channels _bsd_ieee80211_init_channels
+#define ieee80211_init_neighbor _bsd_ieee80211_init_neighbor
+#define ieee80211_init_suphtrates _bsd_ieee80211_init_suphtrates
+#define ieee80211_input_all _bsd_ieee80211_input_all
+#define ieee80211_input_mimo _bsd_ieee80211_input_mimo
+#define ieee80211_input_mimo_all _bsd_ieee80211_input_mimo_all
+#define ieee80211_ioctl _bsd_ieee80211_ioctl
+#define ieee80211_iserp_rateset _bsd_ieee80211_iserp_rateset
+#define ieee80211_iterate_coms _bsd_ieee80211_iterate_coms
+#define ieee80211_iterate_nodes _bsd_ieee80211_iterate_nodes
+#define ieee80211_iterate_nodes_vap _bsd_ieee80211_iterate_nodes_vap
+#define ieee80211_load_module _bsd_ieee80211_load_module
+#define ieee80211_lookup_channel_rxstatus _bsd_ieee80211_lookup_channel_rxstatus
+#define ieee80211_mac_hash _bsd_ieee80211_mac_hash
+#define ieee80211_mbuf_adjust _bsd_ieee80211_mbuf_adjust
+#define ieee80211_media2rate _bsd_ieee80211_media2rate
+#define ieee80211_media_change _bsd_ieee80211_media_change
+#define ieee80211_media_status _bsd_ieee80211_media_status
+#define ieee80211_mesh_attach _bsd_ieee80211_mesh_attach
+#define ieee80211_mesh_detach _bsd_ieee80211_mesh_detach
+#define ieee80211_mesh_find_txnode _bsd_ieee80211_mesh_find_txnode
+#define ieee80211_mesh_forward_to_gates _bsd_ieee80211_mesh_forward_to_gates
+#define ieee80211_mesh_init_neighbor _bsd_ieee80211_mesh_init_neighbor
+#define ieee80211_mesh_mark_gate _bsd_ieee80211_mesh_mark_gate
+#define ieee80211_mesh_node_cleanup _bsd_ieee80211_mesh_node_cleanup
+#define ieee80211_mesh_node_init _bsd_ieee80211_mesh_node_init
+#define ieee80211_mesh_proxy_check _bsd_ieee80211_mesh_proxy_check
+#define ieee80211_mesh_register_proto_metric _bsd_ieee80211_mesh_register_proto_metric
+#define ieee80211_mesh_register_proto_path _bsd_ieee80211_mesh_register_proto_path
+#define ieee80211_mesh_rt_add _bsd_ieee80211_mesh_rt_add
+#define ieee80211_mesh_rt_del _bsd_ieee80211_mesh_rt_del
+#define ieee80211_mesh_rt_find _bsd_ieee80211_mesh_rt_find
+#define ieee80211_mesh_rt_flush _bsd_ieee80211_mesh_rt_flush
+#define ieee80211_mesh_rt_flush_peer _bsd_ieee80211_mesh_rt_flush_peer
+#define ieee80211_mesh_rt_update _bsd_ieee80211_mesh_rt_update
+#define ieee80211_mesh_update_beacon _bsd_ieee80211_mesh_update_beacon
+#define ieee80211_mgmt_output _bsd_ieee80211_mgmt_output
+#define ieee80211_mhz2ieee _bsd_ieee80211_mhz2ieee
+#define ieee80211_monitor_attach _bsd_ieee80211_monitor_attach
+#define ieee80211_monitor_detach _bsd_ieee80211_monitor_detach
+#define ieee80211_new_state _bsd_ieee80211_new_state
+#define ieee80211_new_state_locked _bsd_ieee80211_new_state_locked
+#define ieee80211_node_attach _bsd_ieee80211_node_attach
+#define ieee80211_node_authorize _bsd_ieee80211_node_authorize
+#define ieee80211_node_create_wds _bsd_ieee80211_node_create_wds
+#define ieee80211_node_deauth _bsd_ieee80211_node_deauth
+#define ieee80211_node_dectestref _bsd_ieee80211_node_dectestref
+#define ieee80211_node_delucastkey _bsd_ieee80211_node_delucastkey
+#define ieee80211_node_detach _bsd_ieee80211_node_detach
+#define ieee80211_node_join _bsd_ieee80211_node_join
+#define ieee80211_node_latevattach _bsd_ieee80211_node_latevattach
+#define ieee80211_node_leave _bsd_ieee80211_node_leave
+#define ieee80211_node_psq_age _bsd_ieee80211_node_psq_age
+#define ieee80211_node_psq_dequeue _bsd_ieee80211_node_psq_dequeue
+#define ieee80211_node_psq_drain _bsd_ieee80211_node_psq_drain
+#define ieee80211_node_pwrsave _bsd_ieee80211_node_pwrsave
+#define ieee80211_node_set_chan _bsd_ieee80211_node_set_chan
+#define ieee80211_node_setuptxparms _bsd_ieee80211_node_setuptxparms
+#define ieee80211_node_timeout _bsd_ieee80211_node_timeout
+#define ieee80211_node_unauthorize _bsd_ieee80211_node_unauthorize
+#define ieee80211_node_vattach _bsd_ieee80211_node_vattach
+#define ieee80211_node_vdetach _bsd_ieee80211_node_vdetach
+#define ieee80211_notify_cac _bsd_ieee80211_notify_cac
+#define ieee80211_notify_country _bsd_ieee80211_notify_country
+#define ieee80211_notify_csa _bsd_ieee80211_notify_csa
+#define ieee80211_notify_erp _bsd_ieee80211_notify_erp
+#define ieee80211_notify_michael_failure _bsd_ieee80211_notify_michael_failure
+#define ieee80211_notify_node_auth _bsd_ieee80211_notify_node_auth
+#define ieee80211_notify_node_deauth _bsd_ieee80211_notify_node_deauth
+#define ieee80211_notify_node_join _bsd_ieee80211_notify_node_join
+#define ieee80211_notify_node_leave _bsd_ieee80211_notify_node_leave
+#define ieee80211_notify_radar _bsd_ieee80211_notify_radar
+#define ieee80211_notify_radio _bsd_ieee80211_notify_radio
+#define ieee80211_notify_replay_failure _bsd_ieee80211_notify_replay_failure
+#define ieee80211_notify_scan_done _bsd_ieee80211_notify_scan_done
+#define ieee80211_notify_wds_discover _bsd_ieee80211_notify_wds_discover
+#define ieee80211_opcap _bsd_ieee80211_opcap
+#define ieee80211_opmode_name _bsd_ieee80211_opmode_name
+#define ieee80211_output _bsd_ieee80211_output
+#define ieee80211_parent_xmitpkt _bsd_ieee80211_parent_xmitpkt
+#define ieee80211_parse_action _bsd_ieee80211_parse_action
+#define ieee80211_parse_beacon _bsd_ieee80211_parse_beacon
+#define ieee80211_parse_htcap _bsd_ieee80211_parse_htcap
+#define ieee80211_parse_htinfo _bsd_ieee80211_parse_htinfo
+#define ieee80211_parse_meshid _bsd_ieee80211_parse_meshid
+#define ieee80211_parse_vhtcap _bsd_ieee80211_parse_vhtcap
+#define ieee80211_parse_vhtopmode _bsd_ieee80211_parse_vhtopmode
+#define ieee80211_parse_wmeparams _bsd_ieee80211_parse_wmeparams
+#define ieee80211_phymode_name _bsd_ieee80211_phymode_name
+#define ieee80211_plcp2rate _bsd_ieee80211_plcp2rate
+#define ieee80211_power_attach _bsd_ieee80211_power_attach
+#define ieee80211_power_detach _bsd_ieee80211_power_detach
+#define ieee80211_power_latevattach _bsd_ieee80211_power_latevattach
+#define ieee80211_power_vattach _bsd_ieee80211_power_vattach
+#define ieee80211_power_vdetach _bsd_ieee80211_power_vdetach
+#define ieee80211_print_essid _bsd_ieee80211_print_essid
+#define ieee80211_probe_curchan _bsd_ieee80211_probe_curchan
+#define ieee80211_process_callback _bsd_ieee80211_process_callback
+#define ieee80211_promisc _bsd_ieee80211_promisc
+#define ieee80211_proto_attach _bsd_ieee80211_proto_attach
+#define ieee80211_proto_detach _bsd_ieee80211_proto_detach
+#define ieee80211_proto_vattach _bsd_ieee80211_proto_vattach
+#define ieee80211_proto_vdetach _bsd_ieee80211_proto_vdetach
+#define ieee80211_psq_cleanup _bsd_ieee80211_psq_cleanup
+#define ieee80211_psq_init _bsd_ieee80211_psq_init
+#define ieee80211_pwrsave _bsd_ieee80211_pwrsave
+#define ieee80211_radiotap_attach _bsd_ieee80211_radiotap_attach
+#define ieee80211_radiotap_attachv _bsd_ieee80211_radiotap_attachv
+#define ieee80211_radiotap_chan_change _bsd_ieee80211_radiotap_chan_change
+#define ieee80211_radiotap_detach _bsd_ieee80211_radiotap_detach
+#define ieee80211_radiotap_rx _bsd_ieee80211_radiotap_rx
+#define ieee80211_radiotap_rx_all _bsd_ieee80211_radiotap_rx_all
+#define ieee80211_radiotap_tx _bsd_ieee80211_radiotap_tx
+#define ieee80211_radiotap_vattach _bsd_ieee80211_radiotap_vattach
+#define ieee80211_radiotap_vdetach _bsd_ieee80211_radiotap_vdetach
+#define ieee80211_rate2media _bsd_ieee80211_rate2media
+#define ieee80211_rate2plcp _bsd_ieee80211_rate2plcp
+#define ieee80211_ratectl_init _bsd_ieee80211_ratectl_init
+#define ieee80211_ratectl_register _bsd_ieee80211_ratectl_register
+#define ieee80211_ratectl_set _bsd_ieee80211_ratectl_set
+#define ieee80211_ratectl_unregister _bsd_ieee80211_ratectl_unregister
+#define ieee80211_raw_output _bsd_ieee80211_raw_output
+#define ieee80211_realign _bsd_ieee80211_realign
+#define ieee80211_reason_to_string _bsd_ieee80211_reason_to_string
+#define ieee80211_recv_action _bsd_ieee80211_recv_action
+#define ieee80211_recv_action_register _bsd_ieee80211_recv_action_register
+#define ieee80211_recv_action_unregister _bsd_ieee80211_recv_action_unregister
+#define ieee80211_recv_bar _bsd_ieee80211_recv_bar
+#define ieee80211_recv_pspoll _bsd_ieee80211_recv_pspoll
+#define ieee80211_regdomain_attach _bsd_ieee80211_regdomain_attach
+#define ieee80211_regdomain_detach _bsd_ieee80211_regdomain_detach
+#define ieee80211_regdomain_vattach _bsd_ieee80211_regdomain_vattach
+#define ieee80211_regdomain_vdetach _bsd_ieee80211_regdomain_vdetach
+#define ieee80211_reset_bss _bsd_ieee80211_reset_bss
+#define ieee80211_reset_erp _bsd_ieee80211_reset_erp
+#define ieee80211_restart_all _bsd_ieee80211_restart_all
+#define ieee80211_resume_all _bsd_ieee80211_resume_all
+#define ieee80211_scan_assoc_fail _bsd_ieee80211_scan_assoc_fail
+#define ieee80211_scan_assoc_success _bsd_ieee80211_scan_assoc_success
+#define ieee80211_scan_attach _bsd_ieee80211_scan_attach
+#define ieee80211_scan_copy_ssid _bsd_ieee80211_scan_copy_ssid
+#define ieee80211_scan_detach _bsd_ieee80211_scan_detach
+#define ieee80211_scan_done _bsd_ieee80211_scan_done
+#define ieee80211_scan_dump_channels _bsd_ieee80211_scan_dump_channels
+#define ieee80211_scan_flush _bsd_ieee80211_scan_flush
+#define ieee80211_scan_iterate _bsd_ieee80211_scan_iterate
+#define ieee80211_scan_next _bsd_ieee80211_scan_next
+#define ieee80211_scan_pickchannel _bsd_ieee80211_scan_pickchannel
+#define ieee80211_scan_timeout _bsd_ieee80211_scan_timeout
+#define ieee80211_scan_update_locked _bsd_ieee80211_scan_update_locked
+#define ieee80211_scan_vattach _bsd_ieee80211_scan_vattach
+#define ieee80211_scan_vdetach _bsd_ieee80211_scan_vdetach
+#define ieee80211_scanner_get _bsd_ieee80211_scanner_get
+#define ieee80211_scanner_register _bsd_ieee80211_scanner_register
+#define ieee80211_scanner_unregister _bsd_ieee80211_scanner_unregister
+#define ieee80211_scanner_unregister_all _bsd_ieee80211_scanner_unregister_all
+#define ieee80211_send_action _bsd_ieee80211_send_action
+#define ieee80211_send_action_register _bsd_ieee80211_send_action_register
+#define ieee80211_send_action_unregister _bsd_ieee80211_send_action_unregister
+#define ieee80211_send_bar _bsd_ieee80211_send_bar
+#define ieee80211_send_error _bsd_ieee80211_send_error
+#define ieee80211_send_mgmt _bsd_ieee80211_send_mgmt
+#define ieee80211_send_nulldata _bsd_ieee80211_send_nulldata
+#define ieee80211_send_probereq _bsd_ieee80211_send_probereq
+#define ieee80211_send_proberesp _bsd_ieee80211_send_proberesp
+#define ieee80211_send_setup _bsd_ieee80211_send_setup
+#define ieee80211_set_shortslottime _bsd_ieee80211_set_shortslottime
+#define ieee80211_setbasicrates _bsd_ieee80211_setbasicrates
+#define ieee80211_setcurchan _bsd_ieee80211_setcurchan
+#define ieee80211_setmode _bsd_ieee80211_setmode
+#define ieee80211_setregdomain _bsd_ieee80211_setregdomain
+#define ieee80211_setup_basic_htrates _bsd_ieee80211_setup_basic_htrates
+#define ieee80211_setup_htrates _bsd_ieee80211_setup_htrates
+#define ieee80211_setup_rates _bsd_ieee80211_setup_rates
+#define ieee80211_setup_vht_rates _bsd_ieee80211_setup_vht_rates
+#define ieee80211_setupcurchan _bsd_ieee80211_setupcurchan
+#define ieee80211_sort_channels _bsd_ieee80211_sort_channels
+#define ieee80211_sta_attach _bsd_ieee80211_sta_attach
+#define ieee80211_sta_detach _bsd_ieee80211_sta_detach
+#define ieee80211_sta_join _bsd_ieee80211_sta_join
+#define ieee80211_sta_leave _bsd_ieee80211_sta_leave
+#define ieee80211_sta_ps_timer_check _bsd_ieee80211_sta_ps_timer_check
+#define ieee80211_sta_pwrsave _bsd_ieee80211_sta_pwrsave
+#define ieee80211_sta_tim_notify _bsd_ieee80211_sta_tim_notify
+#define ieee80211_start_all _bsd_ieee80211_start_all
+#define ieee80211_start_locked _bsd_ieee80211_start_locked
+#define ieee80211_start_scan _bsd_ieee80211_start_scan
+#define ieee80211_state_name _bsd_ieee80211_state_name
+#define ieee80211_stop _bsd_ieee80211_stop
+#define ieee80211_stop_all _bsd_ieee80211_stop_all
+#define ieee80211_stop_locked _bsd_ieee80211_stop_locked
+#define ieee80211_suspend_all _bsd_ieee80211_suspend_all
+#define ieee80211_swbmiss _bsd_ieee80211_swbmiss
+#define ieee80211_swscan_attach _bsd_ieee80211_swscan_attach
+#define ieee80211_sync_curchan _bsd_ieee80211_sync_curchan
+#define ieee80211_syncflag _bsd_ieee80211_syncflag
+#define ieee80211_syncflag_ext _bsd_ieee80211_syncflag_ext
+#define ieee80211_syncflag_ht _bsd_ieee80211_syncflag_ht
+#define ieee80211_syncflag_vht _bsd_ieee80211_syncflag_vht
+#define ieee80211_sysctl_attach _bsd_ieee80211_sysctl_attach
+#define ieee80211_sysctl_detach _bsd_ieee80211_sysctl_detach
+#define ieee80211_sysctl_msecs_ticks _bsd_ieee80211_sysctl_msecs_ticks
+#define ieee80211_sysctl_vattach _bsd_ieee80211_sysctl_vattach
+#define ieee80211_sysctl_vdetach _bsd_ieee80211_sysctl_vdetach
+#define ieee80211_tmp_node _bsd_ieee80211_tmp_node
+#define ieee80211_tx_complete _bsd_ieee80211_tx_complete
+#define ieee80211_update_chw _bsd_ieee80211_update_chw
+#define ieee80211_vap_attach _bsd_ieee80211_vap_attach
+#define ieee80211_vap_destroy _bsd_ieee80211_vap_destroy
+#define ieee80211_vap_detach _bsd_ieee80211_vap_detach
+#define ieee80211_vap_pkt_send_dest _bsd_ieee80211_vap_pkt_send_dest
+#define ieee80211_vap_qflush _bsd_ieee80211_vap_qflush
+#define ieee80211_vap_setup _bsd_ieee80211_vap_setup
+#define ieee80211_vap_transmit _bsd_ieee80211_vap_transmit
+#define ieee80211_vap_xmitpkt _bsd_ieee80211_vap_xmitpkt
+#define ieee80211_vht_adjust_channel _bsd_ieee80211_vht_adjust_channel
+#define ieee80211_vht_announce _bsd_ieee80211_vht_announce
+#define ieee80211_vht_attach _bsd_ieee80211_vht_attach
+#define ieee80211_vht_detach _bsd_ieee80211_vht_detach
+#define ieee80211_vht_get_vhtcap_ie _bsd_ieee80211_vht_get_vhtcap_ie
+#define ieee80211_vht_get_vhtinfo_ie _bsd_ieee80211_vht_get_vhtinfo_ie
+#define ieee80211_vht_node_cleanup _bsd_ieee80211_vht_node_cleanup
+#define ieee80211_vht_node_init _bsd_ieee80211_vht_node_init
+#define ieee80211_vht_node_join _bsd_ieee80211_vht_node_join
+#define ieee80211_vht_node_leave _bsd_ieee80211_vht_node_leave
+#define ieee80211_vht_timeout _bsd_ieee80211_vht_timeout
+#define ieee80211_vht_update_cap _bsd_ieee80211_vht_update_cap
+#define ieee80211_vht_updateparams _bsd_ieee80211_vht_updateparams
+#define ieee80211_vht_vattach _bsd_ieee80211_vht_vattach
+#define ieee80211_vht_vdetach _bsd_ieee80211_vht_vdetach
+#define ieee80211_waitfor_parent _bsd_ieee80211_waitfor_parent
+#define ieee80211_wds_attach _bsd_ieee80211_wds_attach
+#define ieee80211_wds_detach _bsd_ieee80211_wds_detach
+#define ieee80211_wme_acnames _bsd_ieee80211_wme_acnames
+#define ieee80211_wme_ic_getparams _bsd_ieee80211_wme_ic_getparams
+#define ieee80211_wme_initparams _bsd_ieee80211_wme_initparams
+#define ieee80211_wme_updateparams _bsd_ieee80211_wme_updateparams
+#define ieee80211_wme_updateparams_locked _bsd_ieee80211_wme_updateparams_locked
+#define ieee80211_wme_vap_ac_is_noack _bsd_ieee80211_wme_vap_ac_is_noack
+#define ieee80211_wme_vap_getparams _bsd_ieee80211_wme_vap_getparams
+#define ieee80211broadcastaddr _bsd_ieee80211broadcastaddr
+#define if_addgroup _bsd_if_addgroup
+#define if_addmulti _bsd_if_addmulti
+#define if_addr_rlock _bsd_if_addr_rlock
+#define if_addr_runlock _bsd_if_addr_runlock
+#define if_allmulti _bsd_if_allmulti
+#define if_alloc _bsd_if_alloc
+#define if_alloc_dev _bsd_if_alloc_dev
+#define if_alloc_domain _bsd_if_alloc_domain
+#define if_attach _bsd_if_attach
+#define if_bpfmtap _bsd_if_bpfmtap
+#define if_clearhwassist _bsd_if_clearhwassist
+#define if_clone_addgroup _bsd_if_clone_addgroup
+#define if_clone_addif _bsd_if_clone_addif
+#define if_clone_advanced _bsd_if_clone_advanced
+#define if_clone_create _bsd_if_clone_create
+#define if_clone_destroy _bsd_if_clone_destroy
+#define if_clone_destroyif _bsd_if_clone_destroyif
+#define if_clone_detach _bsd_if_clone_detach
+#define if_clone_findifc _bsd_if_clone_findifc
+#define if_clone_list _bsd_if_clone_list
+#define if_clone_simple _bsd_if_clone_simple
+#define if_cloners _bsd_if_cloners
+#define if_data_copy _bsd_if_data_copy
+#define if_dead _bsd_if_dead
+#define if_delallmulti _bsd_if_delallmulti
+#define if_delgroup _bsd_if_delgroup
+#define if_delmulti _bsd_if_delmulti
+#define if_delmulti_ifma _bsd_if_delmulti_ifma
+#define if_delmulti_ifma_flags _bsd_if_delmulti_ifma_flags
+#define if_dequeue _bsd_if_dequeue
+#define if_deregister_com_alloc _bsd_if_deregister_com_alloc
+#define if_detach _bsd_if_detach
+#define if_down _bsd_if_down
+#define if_etherbpfmtap _bsd_if_etherbpfmtap
+#define if_findmulti _bsd_if_findmulti
+#define if_free _bsd_if_free
+#define if_freemulti _bsd_if_freemulti
+#define if_get_counter_default _bsd_if_get_counter_default
+#define if_getamcount _bsd_if_getamcount
+#define if_getbaudrate _bsd_if_getbaudrate
+#define if_getcapabilities _bsd_if_getcapabilities
+#define if_getcapenable _bsd_if_getcapenable
+#define if_getdname _bsd_if_getdname
+#define if_getdrvflags _bsd_if_getdrvflags
+#define if_getflags _bsd_if_getflags
+#define if_gethandle _bsd_if_gethandle
+#define if_gethwaddr _bsd_if_gethwaddr
+#define if_gethwassist _bsd_if_gethwassist
+#define if_gethwtsomax _bsd_if_gethwtsomax
+#define if_gethwtsomaxsegcount _bsd_if_gethwtsomaxsegcount
+#define if_gethwtsomaxsegsize _bsd_if_gethwtsomaxsegsize
+#define if_getifaddr _bsd_if_getifaddr
+#define if_getlladdr _bsd_if_getlladdr
+#define if_getmtu _bsd_if_getmtu
+#define if_getmtu_family _bsd_if_getmtu_family
+#define if_getsoftc _bsd_if_getsoftc
+#define if_getvtag _bsd_if_getvtag
+#define if_handoff _bsd_if_handoff
+#define if_hw_tsomax_common _bsd_if_hw_tsomax_common
+#define if_hw_tsomax_update _bsd_if_hw_tsomax_update
+#define if_inc_counter _bsd_if_inc_counter
+#define if_index _bsd_if_index
+#define if_initname _bsd_if_initname
+#define if_input _bsd_if_input
+#define if_link_state_change _bsd_if_link_state_change
+#define if_maddr_rlock _bsd_if_maddr_rlock
+#define if_maddr_runlock _bsd_if_maddr_runlock
+#define if_multi_apply _bsd_if_multi_apply
+#define if_multiaddr_array _bsd_if_multiaddr_array
+#define if_multiaddr_count _bsd_if_multiaddr_count
+#define if_printf _bsd_if_printf
+#define if_purgeaddrs _bsd_if_purgeaddrs
+#define if_qflush _bsd_if_qflush
+#define if_ref _bsd_if_ref
+#define if_register_com_alloc _bsd_if_register_com_alloc
+#define if_rele _bsd_if_rele
+#define if_sendq_empty _bsd_if_sendq_empty
+#define if_sendq_prepend _bsd_if_sendq_prepend
+#define if_setbaudrate _bsd_if_setbaudrate
+#define if_setcapabilities _bsd_if_setcapabilities
+#define if_setcapabilitiesbit _bsd_if_setcapabilitiesbit
+#define if_setcapenable _bsd_if_setcapenable
+#define if_setcapenablebit _bsd_if_setcapenablebit
+#define if_setdev _bsd_if_setdev
+#define if_setdrvflagbits _bsd_if_setdrvflagbits
+#define if_setdrvflags _bsd_if_setdrvflags
+#define if_setflagbits _bsd_if_setflagbits
+#define if_setflags _bsd_if_setflags
+#define if_setgetcounterfn _bsd_if_setgetcounterfn
+#define if_sethwassist _bsd_if_sethwassist
+#define if_sethwassistbits _bsd_if_sethwassistbits
+#define if_sethwtsomax _bsd_if_sethwtsomax
+#define if_sethwtsomaxsegcount _bsd_if_sethwtsomaxsegcount
+#define if_sethwtsomaxsegsize _bsd_if_sethwtsomaxsegsize
+#define if_setifheaderlen _bsd_if_setifheaderlen
+#define if_setinitfn _bsd_if_setinitfn
+#define if_setioctlfn _bsd_if_setioctlfn
+#define if_setlladdr _bsd_if_setlladdr
+#define if_setmtu _bsd_if_setmtu
+#define if_setqflushfn _bsd_if_setqflushfn
+#define if_setrcvif _bsd_if_setrcvif
+#define if_setsendqlen _bsd_if_setsendqlen
+#define if_setsendqready _bsd_if_setsendqready
+#define if_setsoftc _bsd_if_setsoftc
+#define if_setstartfn _bsd_if_setstartfn
+#define if_settransmitfn _bsd_if_settransmitfn
+#define if_setupmultiaddr _bsd_if_setupmultiaddr
+#define if_setvtag _bsd_if_setvtag
+#define if_simloop _bsd_if_simloop
+#define if_start _bsd_if_start
+#define if_togglecapenable _bsd_if_togglecapenable
+#define if_tunnel_check_nesting _bsd_if_tunnel_check_nesting
+#define if_up _bsd_if_up
+#define if_vlancap _bsd_if_vlancap
+#define if_vlantrunkinuse _bsd_if_vlantrunkinuse
+#define ifa_add_loopback_route _bsd_ifa_add_loopback_route
+#define ifa_alloc _bsd_ifa_alloc
+#define ifa_del_loopback_route _bsd_ifa_del_loopback_route
+#define ifa_free _bsd_ifa_free
+#define ifa_ifwithaddr _bsd_ifa_ifwithaddr
+#define ifa_ifwithaddr_check _bsd_ifa_ifwithaddr_check
+#define ifa_ifwithbroadaddr _bsd_ifa_ifwithbroadaddr
+#define ifa_ifwithdstaddr _bsd_ifa_ifwithdstaddr
+#define ifa_ifwithnet _bsd_ifa_ifwithnet
+#define ifa_ifwithroute _bsd_ifa_ifwithroute
+#define ifa_preferred _bsd_ifa_preferred
+#define ifa_ref _bsd_ifa_ref
+#define ifa_switch_loopback_route _bsd_ifa_switch_loopback_route
+#define ifaddr_byindex _bsd_ifaddr_byindex
+#define ifaof_ifpforaddr _bsd_ifaof_ifpforaddr
+#define ifc_alloc_unit _bsd_ifc_alloc_unit
+#define ifc_flags_get _bsd_ifc_flags_get
+#define ifc_flags_set _bsd_ifc_flags_set
+#define ifc_free_unit _bsd_ifc_free_unit
+#define ifc_name _bsd_ifc_name
+#define ifc_name2unit _bsd_ifc_name2unit
+#define ifg_head _bsd_ifg_head
+#define ifhwioctl _bsd_ifhwioctl
+#define ifindex_table _bsd_ifindex_table
+#define ifioctl _bsd_ifioctl
+#define ifma_restart _bsd_ifma_restart
+#define ifmedia_add _bsd_ifmedia_add
+#define ifmedia_baudrate _bsd_ifmedia_baudrate
+#define ifmedia_init _bsd_ifmedia_init
+#define ifmedia_ioctl _bsd_ifmedia_ioctl
+#define ifmedia_list_add _bsd_ifmedia_list_add
+#define ifmedia_removeall _bsd_ifmedia_removeall
+#define ifmedia_set _bsd_ifmedia_set
+#define ifnet _bsd_ifnet
+#define ifnet_byindex _bsd_ifnet_byindex
+#define ifnet_byindex_locked _bsd_ifnet_byindex_locked
+#define ifnet_byindex_ref _bsd_ifnet_byindex_ref
+#define ifnet_rwlock _bsd_ifnet_rwlock
+#define ifnet_sxlock _bsd_ifnet_sxlock
+#define ifpromisc _bsd_ifpromisc
+#define ifq_delete _bsd_ifq_delete
+#define ifq_init _bsd_ifq_init
+#define ifr_data_get_ptr _bsd_ifr_data_get_ptr
+#define ifunit _bsd_ifunit
+#define ifunit_ref _bsd_ifunit_ref
+#define igb_sctx _bsd_igb_sctx
+#define igb_txrx _bsd_igb_txrx
+#define igmp_change_state _bsd_igmp_change_state
+#define igmp_domifattach _bsd_igmp_domifattach
+#define igmp_domifdetach _bsd_igmp_domifdetach
+#define igmp_fasttimo _bsd_igmp_fasttimo
+#define igmp_ifdetach _bsd_igmp_ifdetach
+#define igmp_input _bsd_igmp_input
+#define igmp_mtx _bsd_igmp_mtx
+#define igmp_slowtimo _bsd_igmp_slowtimo
+#define iic2errno _bsd_iic2errno
+#define iicbus_block_read _bsd_iicbus_block_read
+#define iicbus_block_write _bsd_iicbus_block_write
+#define iicbus_devclass _bsd_iicbus_devclass
+#define iicbus_driver _bsd_iicbus_driver
+#define iicbus_generic_intr _bsd_iicbus_generic_intr
+#define iicbus_init_frequency _bsd_iicbus_init_frequency
+#define iicbus_intr _bsd_iicbus_intr
+#define iicbus_null_callback _bsd_iicbus_null_callback
+#define iicbus_null_repeated_start _bsd_iicbus_null_repeated_start
+#define iicbus_read _bsd_iicbus_read
+#define iicbus_read_byte _bsd_iicbus_read_byte
+#define iicbus_release_bus _bsd_iicbus_release_bus
+#define iicbus_repeated_start _bsd_iicbus_repeated_start
+#define iicbus_request_bus _bsd_iicbus_request_bus
+#define iicbus_start _bsd_iicbus_start
+#define iicbus_started _bsd_iicbus_started
+#define iicbus_stop _bsd_iicbus_stop
+#define iicbus_transfer _bsd_iicbus_transfer
+#define iicbus_transfer_excl _bsd_iicbus_transfer_excl
+#define iicbus_transfer_gen _bsd_iicbus_transfer_gen
+#define iicbus_write _bsd_iicbus_write
+#define iicbus_write_byte _bsd_iicbus_write_byte
+#define iicdev_readfrom _bsd_iicdev_readfrom
+#define iicdev_writeto _bsd_iicdev_writeto
+#define im6o_mc_filter _bsd_im6o_mc_filter
+#define imo_multi_filter _bsd_imo_multi_filter
+#define in4_cksum _bsd_in4_cksum
+#define in6_addrscope _bsd_in6_addrscope
+#define in6_are_prefix_equal _bsd_in6_are_prefix_equal
+#define in6_cksum _bsd_in6_cksum
+#define in6_cksum_partial _bsd_in6_cksum_partial
+#define in6_cksum_pseudo _bsd_in6_cksum_pseudo
+#define in6_clearscope _bsd_in6_clearscope
+#define in6_control _bsd_in6_control
+#define in6_delayed_cksum _bsd_in6_delayed_cksum
+#define in6_domifattach _bsd_in6_domifattach
+#define in6_domifdetach _bsd_in6_domifdetach
+#define in6_domifmtu _bsd_in6_domifmtu
+#define in6_get_hw_ifid _bsd_in6_get_hw_ifid
+#define in6_get_tmpifid _bsd_in6_get_tmpifid
+#define in6_getlinkifnet _bsd_in6_getlinkifnet
+#define in6_getpeeraddr _bsd_in6_getpeeraddr
+#define in6_getscope _bsd_in6_getscope
+#define in6_getscopezone _bsd_in6_getscopezone
+#define in6_getsockaddr _bsd_in6_getsockaddr
+#define in6_gif_init _bsd_in6_gif_init
+#define in6_gif_ioctl _bsd_in6_gif_ioctl
+#define in6_gif_output _bsd_in6_gif_output
+#define in6_gif_setopts _bsd_in6_gif_setopts
+#define in6_gif_uninit _bsd_in6_gif_uninit
+#define in6_if2idlen _bsd_in6_if2idlen
+#define in6_if_up _bsd_in6_if_up
+#define in6_ifaddr_lock _bsd_in6_ifaddr_lock
+#define in6_ifaddrhashtbl _bsd_in6_ifaddrhashtbl
+#define in6_ifaddrhead _bsd_in6_ifaddrhead
+#define in6_ifaddrhmask _bsd_in6_ifaddrhmask
+#define in6_ifattach _bsd_in6_ifattach
+#define in6_ifattach_destroy _bsd_in6_ifattach_destroy
+#define in6_ifawithifp _bsd_in6_ifawithifp
+#define in6_ifdetach _bsd_in6_ifdetach
+#define in6_ifdetach_destroy _bsd_in6_ifdetach_destroy
+#define in6_ifhasaddr _bsd_in6_ifhasaddr
+#define in6_inithead _bsd_in6_inithead
+#define in6_is_addr_deprecated _bsd_in6_is_addr_deprecated
+#define in6_joingroup _bsd_in6_joingroup
+#define in6_joingroup_locked _bsd_in6_joingroup_locked
+#define in6_leavegroup _bsd_in6_leavegroup
+#define in6_leavegroup_locked _bsd_in6_leavegroup_locked
+#define in6_localaddr _bsd_in6_localaddr
+#define in6_localip _bsd_in6_localip
+#define in6_losing _bsd_in6_losing
+#define in6_mapped_peeraddr _bsd_in6_mapped_peeraddr
+#define in6_mapped_sockaddr _bsd_in6_mapped_sockaddr
+#define in6_mask2len _bsd_in6_mask2len
+#define in6_matchlen _bsd_in6_matchlen
+#define in6_maxmtu _bsd_in6_maxmtu
+#define in6_mcast_loop _bsd_in6_mcast_loop
+#define in6_multi_free_mtx _bsd_in6_multi_free_mtx
+#define in6_multi_list_mtx _bsd_in6_multi_list_mtx
+#define in6_multi_sx _bsd_in6_multi_sx
+#define in6_newaddrmsg _bsd_in6_newaddrmsg
+#define in6_nigroup _bsd_in6_nigroup
+#define in6_nigroup_oldmcprefix _bsd_in6_nigroup_oldmcprefix
+#define in6_pcbbind _bsd_in6_pcbbind
+#define in6_pcbconnect _bsd_in6_pcbconnect
+#define in6_pcbconnect_mbuf _bsd_in6_pcbconnect_mbuf
+#define in6_pcbdisconnect _bsd_in6_pcbdisconnect
+#define in6_pcblookup _bsd_in6_pcblookup
+#define in6_pcblookup_local _bsd_in6_pcblookup_local
+#define in6_pcblookup_mbuf _bsd_in6_pcblookup_mbuf
+#define in6_pcbnotify _bsd_in6_pcbnotify
+#define in6_pcbpurgeif0 _bsd_in6_pcbpurgeif0
+#define in6_pcbsetport _bsd_in6_pcbsetport
+#define in6_prefixlen2mask _bsd_in6_prefixlen2mask
+#define in6_prepare_ifra _bsd_in6_prepare_ifra
+#define in6_purgeaddr _bsd_in6_purgeaddr
+#define in6_rtalloc _bsd_in6_rtalloc
+#define in6_rtalloc1 _bsd_in6_rtalloc1
+#define in6_rtalloc_ign _bsd_in6_rtalloc_ign
+#define in6_rtchange _bsd_in6_rtchange
+#define in6_rtredirect _bsd_in6_rtredirect
+#define in6_rtrequest _bsd_in6_rtrequest
+#define in6_selecthlim _bsd_in6_selecthlim
+#define in6_selectroute _bsd_in6_selectroute
+#define in6_selectroute_fib _bsd_in6_selectroute_fib
+#define in6_selectsrc_addr _bsd_in6_selectsrc_addr
+#define in6_selectsrc_socket _bsd_in6_selectsrc_socket
+#define in6_setmaxmtu _bsd_in6_setmaxmtu
+#define in6_setscope _bsd_in6_setscope
+#define in6_sin6_2_sin _bsd_in6_sin6_2_sin
+#define in6_sin6_2_sin_in_sock _bsd_in6_sin6_2_sin_in_sock
+#define in6_sin_2_v4mapsin6 _bsd_in6_sin_2_v4mapsin6
+#define in6_sin_2_v4mapsin6_in_sock _bsd_in6_sin_2_v4mapsin6_in_sock
+#define in6_sockaddr _bsd_in6_sockaddr
+#define in6_splitscope _bsd_in6_splitscope
+#define in6_src_ioctl _bsd_in6_src_ioctl
+#define in6_tmpaddrtimer _bsd_in6_tmpaddrtimer
+#define in6_tmpaddrtimer_ch _bsd_in6_tmpaddrtimer_ch
+#define in6_tmpifadd _bsd_in6_tmpifadd
+#define in6_update_ifa _bsd_in6_update_ifa
+#define in6_v4mapsin6_sockaddr _bsd_in6_v4mapsin6_sockaddr
+#define in6addr_linklocal_allrouters _bsd_in6addr_linklocal_allrouters
+#define in6addr_linklocal_allv2routers _bsd_in6addr_linklocal_allv2routers
+#define in6if_do_dad _bsd_in6if_do_dad
+#define in6ifa_ifpforlinklocal _bsd_in6ifa_ifpforlinklocal
+#define in6ifa_ifpwithaddr _bsd_in6ifa_ifpwithaddr
+#define in6ifa_ifwithaddr _bsd_in6ifa_ifwithaddr
+#define in6ifa_llaonifp _bsd_in6ifa_llaonifp
+#define in6m_clear_recorded _bsd_in6m_clear_recorded
+#define in6m_commit _bsd_in6m_commit
+#define in6m_disconnect_locked _bsd_in6m_disconnect_locked
+#define in6m_print _bsd_in6m_print
+#define in6m_record_source _bsd_in6m_record_source
+#define in6m_release_list_deferred _bsd_in6m_release_list_deferred
+#define in6m_release_wait _bsd_in6m_release_wait
+#define in6mask0 _bsd_in6mask0
+#define in6mask128 _bsd_in6mask128
+#define in6mask32 _bsd_in6mask32
+#define in6mask64 _bsd_in6mask64
+#define in6mask96 _bsd_in6mask96
+#define in_addmulti _bsd_in_addmulti
+#define in_addprefix _bsd_in_addprefix
+#define in_addword _bsd_in_addword
+#define in_broadcast _bsd_in_broadcast
+#define in_canforward _bsd_in_canforward
+#define in_cksum_hdr _bsd_in_cksum_hdr
+#define in_cksum_skip _bsd_in_cksum_skip
+#define in_control _bsd_in_control
+#define in_delayed_cksum _bsd_in_delayed_cksum
+#define in_domifattach _bsd_in_domifattach
+#define in_domifdetach _bsd_in_domifdetach
+#define in_getpeeraddr _bsd_in_getpeeraddr
+#define in_getsockaddr _bsd_in_getsockaddr
+#define in_gif_init _bsd_in_gif_init
+#define in_gif_ioctl _bsd_in_gif_ioctl
+#define in_gif_output _bsd_in_gif_output
+#define in_gif_setopts _bsd_in_gif_setopts
+#define in_gif_uninit _bsd_in_gif_uninit
+#define in_gre_init _bsd_in_gre_init
+#define in_gre_ioctl _bsd_in_gre_ioctl
+#define in_gre_output _bsd_in_gre_output
+#define in_gre_setopts _bsd_in_gre_setopts
+#define in_gre_uninit _bsd_in_gre_uninit
+#define in_ifaddr_broadcast _bsd_in_ifaddr_broadcast
+#define in_ifaddr_lock _bsd_in_ifaddr_lock
+#define in_ifaddrhashtbl _bsd_in_ifaddrhashtbl
+#define in_ifaddrhead _bsd_in_ifaddrhead
+#define in_ifaddrhmask _bsd_in_ifaddrhmask
+#define in_ifadown _bsd_in_ifadown
+#define in_ifdetach _bsd_in_ifdetach
+#define in_ifhasaddr _bsd_in_ifhasaddr
+#define in_ifscrub_all _bsd_in_ifscrub_all
+#define in_inithead _bsd_in_inithead
+#define in_joingroup _bsd_in_joingroup
+#define in_joingroup_locked _bsd_in_joingroup_locked
+#define in_leavegroup _bsd_in_leavegroup
+#define in_leavegroup_locked _bsd_in_leavegroup_locked
+#define in_localaddr _bsd_in_localaddr
+#define in_localip _bsd_in_localip
+#define in_losing _bsd_in_losing
+#define in_mcast_loop _bsd_in_mcast_loop
+#define in_multi_free_mtx _bsd_in_multi_free_mtx
+#define in_multi_list_mtx _bsd_in_multi_list_mtx
+#define in_multi_sx _bsd_in_multi_sx
+#define in_pcb_lport _bsd_in_pcb_lport
+#define in_pcballoc _bsd_in_pcballoc
+#define in_pcbbind _bsd_in_pcbbind
+#define in_pcbbind_check_bindmulti _bsd_in_pcbbind_check_bindmulti
+#define in_pcbbind_setup _bsd_in_pcbbind_setup
+#define in_pcbconnect _bsd_in_pcbconnect
+#define in_pcbconnect_mbuf _bsd_in_pcbconnect_mbuf
+#define in_pcbconnect_setup _bsd_in_pcbconnect_setup
+#define in_pcbdetach _bsd_in_pcbdetach
+#define in_pcbdisconnect _bsd_in_pcbdisconnect
+#define in_pcbdrop _bsd_in_pcbdrop
+#define in_pcbfree _bsd_in_pcbfree
+#define in_pcbinfo_destroy _bsd_in_pcbinfo_destroy
+#define in_pcbinfo_init _bsd_in_pcbinfo_init
+#define in_pcbinshash _bsd_in_pcbinshash
+#define in_pcbinshash_nopcbgroup _bsd_in_pcbinshash_nopcbgroup
+#define in_pcbladdr _bsd_in_pcbladdr
+#define in_pcblist_rele_rlocked _bsd_in_pcblist_rele_rlocked
+#define in_pcblookup _bsd_in_pcblookup
+#define in_pcblookup_local _bsd_in_pcblookup_local
+#define in_pcblookup_mbuf _bsd_in_pcblookup_mbuf
+#define in_pcbnotifyall _bsd_in_pcbnotifyall
+#define in_pcbpurgeif0 _bsd_in_pcbpurgeif0
+#define in_pcbref _bsd_in_pcbref
+#define in_pcbrehash _bsd_in_pcbrehash
+#define in_pcbrehash_mbuf _bsd_in_pcbrehash_mbuf
+#define in_pcbrele _bsd_in_pcbrele
+#define in_pcbrele_rlocked _bsd_in_pcbrele_rlocked
+#define in_pcbrele_wlocked _bsd_in_pcbrele_wlocked
+#define in_pcbsosetlabel _bsd_in_pcbsosetlabel
+#define in_pcbtoxinpcb _bsd_in_pcbtoxinpcb
+#define in_pseudo _bsd_in_pseudo
+#define in_rtalloc_ign _bsd_in_rtalloc_ign
+#define in_rtredirect _bsd_in_rtredirect
+#define in_scrubprefix _bsd_in_scrubprefix
+#define in_sockaddr _bsd_in_sockaddr
+#define inet6_pfil_head _bsd_inet6_pfil_head
+#define inet6_pfil_hook _bsd_inet6_pfil_hook
+#define inet6ctlerrmap _bsd_inet6ctlerrmap
+#define inet6domain _bsd_inet6domain
+#define inet6sw _bsd_inet6sw
+#define inet_ntoa_r _bsd_inet_ntoa_r
+#define inet_pfil_head _bsd_inet_pfil_head
+#define inet_pfil_hook _bsd_inet_pfil_hook
+#define inetctlerrmap _bsd_inetctlerrmap
+#define inetdomain _bsd_inetdomain
+#define inetsw _bsd_inetsw
+#define init_machclk _bsd_init_machclk
+#define init_sin6 _bsd_init_sin6
+#define init_sleepqueues _bsd_init_sleepqueues
+#define init_unrhdr _bsd_init_unrhdr
+#define inm_clear_recorded _bsd_inm_clear_recorded
+#define inm_commit _bsd_inm_commit
+#define inm_disconnect _bsd_inm_disconnect
+#define inm_lookup _bsd_inm_lookup
+#define inm_lookup_locked _bsd_inm_lookup_locked
+#define inm_print _bsd_inm_print
+#define inm_record_source _bsd_inm_record_source
+#define inm_release_deferred _bsd_inm_release_deferred
+#define inm_release_list_deferred _bsd_inm_release_list_deferred
+#define inp_4tuple_get _bsd_inp_4tuple_get
+#define inp_apply_all _bsd_inp_apply_all
+#define inp_freemoptions _bsd_inp_freemoptions
+#define inp_getmoptions _bsd_inp_getmoptions
+#define inp_inpcbtosocket _bsd_inp_inpcbtosocket
+#define inp_inpcbtotcpcb _bsd_inp_inpcbtotcpcb
+#define inp_ip_tos_get _bsd_inp_ip_tos_get
+#define inp_ip_tos_set _bsd_inp_ip_tos_set
+#define inp_rlock _bsd_inp_rlock
+#define inp_runlock _bsd_inp_runlock
+#define inp_setmoptions _bsd_inp_setmoptions
+#define inp_so_options _bsd_inp_so_options
+#define inp_to_cpuid _bsd_inp_to_cpuid
+#define inp_wlock _bsd_inp_wlock
+#define inp_wunlock _bsd_inp_wunlock
+#define intr_event_add_handler _bsd_intr_event_add_handler
+#define intr_event_create _bsd_intr_event_create
+#define ip4_ah_net_deflev _bsd_ip4_ah_net_deflev
+#define ip4_ah_trans_deflev _bsd_ip4_ah_trans_deflev
+#define ip4_esp_net_deflev _bsd_ip4_esp_net_deflev
+#define ip4_esp_trans_deflev _bsd_ip4_esp_trans_deflev
+#define ip4_ipsec_dfbit _bsd_ip4_ipsec_dfbit
+#define ip4_ipsec_ecn _bsd_ip4_ipsec_ecn
+#define ip6_accept_rtadv _bsd_ip6_accept_rtadv
+#define ip6_ah_net_deflev _bsd_ip6_ah_net_deflev
+#define ip6_ah_trans_deflev _bsd_ip6_ah_trans_deflev
+#define ip6_auto_flowlabel _bsd_ip6_auto_flowlabel
+#define ip6_auto_linklocal _bsd_ip6_auto_linklocal
+#define ip6_clearpktopts _bsd_ip6_clearpktopts
+#define ip6_copypktopts _bsd_ip6_copypktopts
+#define ip6_ctloutput _bsd_ip6_ctloutput
+#define ip6_dad_count _bsd_ip6_dad_count
+#define ip6_defhlim _bsd_ip6_defhlim
+#define ip6_defmcasthlim _bsd_ip6_defmcasthlim
+#define ip6_deletefraghdr _bsd_ip6_deletefraghdr
+#define ip6_desync_factor _bsd_ip6_desync_factor
+#define ip6_ecn_egress _bsd_ip6_ecn_egress
+#define ip6_ecn_ingress _bsd_ip6_ecn_ingress
+#define ip6_encap_attach _bsd_ip6_encap_attach
+#define ip6_encap_detach _bsd_ip6_encap_detach
+#define ip6_encap_register_srcaddr _bsd_ip6_encap_register_srcaddr
+#define ip6_encap_unregister_srcaddr _bsd_ip6_encap_unregister_srcaddr
+#define ip6_esp_net_deflev _bsd_ip6_esp_net_deflev
+#define ip6_esp_trans_deflev _bsd_ip6_esp_trans_deflev
+#define ip6_forward _bsd_ip6_forward
+#define ip6_forwarding _bsd_ip6_forwarding
+#define ip6_fragment _bsd_ip6_fragment
+#define ip6_freemoptions _bsd_ip6_freemoptions
+#define ip6_freepcbopts _bsd_ip6_freepcbopts
+#define ip6_get_prevhdr _bsd_ip6_get_prevhdr
+#define ip6_getmoptions _bsd_ip6_getmoptions
+#define ip6_hdrnestlimit _bsd_ip6_hdrnestlimit
+#define ip6_init _bsd_ip6_init
+#define ip6_initpktopts _bsd_ip6_initpktopts
+#define ip6_input _bsd_ip6_input
+#define ip6_ipsec_ecn _bsd_ip6_ipsec_ecn
+#define ip6_lasthdr _bsd_ip6_lasthdr
+#define ip6_log_interval _bsd_ip6_log_interval
+#define ip6_log_time _bsd_ip6_log_time
+#define ip6_maxfragbucketsize _bsd_ip6_maxfragbucketsize
+#define ip6_maxfragpackets _bsd_ip6_maxfragpackets
+#define ip6_maxfrags _bsd_ip6_maxfrags
+#define ip6_maxfragsperpacket _bsd_ip6_maxfragsperpacket
+#define ip6_mcast_pmtu _bsd_ip6_mcast_pmtu
+#define ip6_mfilter_alloc _bsd_ip6_mfilter_alloc
+#define ip6_mfilter_free _bsd_ip6_mfilter_free
+#define ip6_mforward _bsd_ip6_mforward
+#define ip6_mloopback _bsd_ip6_mloopback
+#define ip6_mrouter _bsd_ip6_mrouter
+#define ip6_mrouter_done _bsd_ip6_mrouter_done
+#define ip6_mrouter_get _bsd_ip6_mrouter_get
+#define ip6_mrouter_set _bsd_ip6_mrouter_set
+#define ip6_msource_tree_RB_FIND _bsd_ip6_msource_tree_RB_FIND
+#define ip6_msource_tree_RB_INSERT _bsd_ip6_msource_tree_RB_INSERT
+#define ip6_msource_tree_RB_INSERT_COLOR _bsd_ip6_msource_tree_RB_INSERT_COLOR
+#define ip6_msource_tree_RB_MINMAX _bsd_ip6_msource_tree_RB_MINMAX
+#define ip6_msource_tree_RB_NEXT _bsd_ip6_msource_tree_RB_NEXT
+#define ip6_msource_tree_RB_NFIND _bsd_ip6_msource_tree_RB_NFIND
+#define ip6_msource_tree_RB_PREV _bsd_ip6_msource_tree_RB_PREV
+#define ip6_msource_tree_RB_REMOVE _bsd_ip6_msource_tree_RB_REMOVE
+#define ip6_msource_tree_RB_REMOVE_COLOR _bsd_ip6_msource_tree_RB_REMOVE_COLOR
+#define ip6_nexthdr _bsd_ip6_nexthdr
+#define ip6_no_radr _bsd_ip6_no_radr
+#define ip6_norbit_raif _bsd_ip6_norbit_raif
+#define ip6_notify_pmtu _bsd_ip6_notify_pmtu
+#define ip6_optlen _bsd_ip6_optlen
+#define ip6_output _bsd_ip6_output
+#define ip6_prefer_tempaddr _bsd_ip6_prefer_tempaddr
+#define ip6_process_hopopts _bsd_ip6_process_hopopts
+#define ip6_protox _bsd_ip6_protox
+#define ip6_randomflowlabel _bsd_ip6_randomflowlabel
+#define ip6_randomid _bsd_ip6_randomid
+#define ip6_raw_ctloutput _bsd_ip6_raw_ctloutput
+#define ip6_rfc6204w3 _bsd_ip6_rfc6204w3
+#define ip6_rr_prune _bsd_ip6_rr_prune
+#define ip6_savecontrol _bsd_ip6_savecontrol
+#define ip6_savecontrol_v4 _bsd_ip6_savecontrol_v4
+#define ip6_sendredirects _bsd_ip6_sendredirects
+#define ip6_setmoptions _bsd_ip6_setmoptions
+#define ip6_setpktopts _bsd_ip6_setpktopts
+#define ip6_sprintf _bsd_ip6_sprintf
+#define ip6_temp_preferred_lifetime _bsd_ip6_temp_preferred_lifetime
+#define ip6_temp_regen_advance _bsd_ip6_temp_regen_advance
+#define ip6_temp_valid_lifetime _bsd_ip6_temp_valid_lifetime
+#define ip6_tryforward _bsd_ip6_tryforward
+#define ip6_unknown_opt _bsd_ip6_unknown_opt
+#define ip6_use_defzone _bsd_ip6_use_defzone
+#define ip6_use_deprecated _bsd_ip6_use_deprecated
+#define ip6_use_tempaddr _bsd_ip6_use_tempaddr
+#define ip6_v6only _bsd_ip6_v6only
+#define ip6proto_register _bsd_ip6proto_register
+#define ip6proto_unregister _bsd_ip6proto_unregister
+#define ip6stat _bsd_ip6stat
+#define ip_checkrouteralert _bsd_ip_checkrouteralert
+#define ip_ctloutput _bsd_ip_ctloutput
+#define ip_defttl _bsd_ip_defttl
+#define ip_divert_ptr _bsd_ip_divert_ptr
+#define ip_dn_ctl_ptr _bsd_ip_dn_ctl_ptr
+#define ip_dn_io_ptr _bsd_ip_dn_io_ptr
+#define ip_dooptions _bsd_ip_dooptions
+#define ip_doopts _bsd_ip_doopts
+#define ip_drain _bsd_ip_drain
+#define ip_ecn_egress _bsd_ip_ecn_egress
+#define ip_ecn_ingress _bsd_ip_ecn_ingress
+#define ip_encap_attach _bsd_ip_encap_attach
+#define ip_encap_detach _bsd_ip_encap_detach
+#define ip_encap_register_srcaddr _bsd_ip_encap_register_srcaddr
+#define ip_encap_unregister_srcaddr _bsd_ip_encap_unregister_srcaddr
+#define ip_fillid _bsd_ip_fillid
+#define ip_forward _bsd_ip_forward
+#define ip_fragment _bsd_ip_fragment
+#define ip_fw_chk_ptr _bsd_ip_fw_chk_ptr
+#define ip_fw_ctl_ptr _bsd_ip_fw_ctl_ptr
+#define ip_gre_ttl _bsd_ip_gre_ttl
+#define ip_init _bsd_ip_init
+#define ip_input _bsd_ip_input
+#define ip_insertoptions _bsd_ip_insertoptions
+#define ip_mcast_src _bsd_ip_mcast_src
+#define ip_mfilter_alloc _bsd_ip_mfilter_alloc
+#define ip_mfilter_free _bsd_ip_mfilter_free
+#define ip_mforward _bsd_ip_mforward
+#define ip_mrouter _bsd_ip_mrouter
+#define ip_mrouter_done _bsd_ip_mrouter_done
+#define ip_mrouter_get _bsd_ip_mrouter_get
+#define ip_mrouter_set _bsd_ip_mrouter_set
+#define ip_msource_tree_RB_FIND _bsd_ip_msource_tree_RB_FIND
+#define ip_msource_tree_RB_INSERT _bsd_ip_msource_tree_RB_INSERT
+#define ip_msource_tree_RB_INSERT_COLOR _bsd_ip_msource_tree_RB_INSERT_COLOR
+#define ip_msource_tree_RB_MINMAX _bsd_ip_msource_tree_RB_MINMAX
+#define ip_msource_tree_RB_NEXT _bsd_ip_msource_tree_RB_NEXT
+#define ip_msource_tree_RB_NFIND _bsd_ip_msource_tree_RB_NFIND
+#define ip_msource_tree_RB_PREV _bsd_ip_msource_tree_RB_PREV
+#define ip_msource_tree_RB_REMOVE _bsd_ip_msource_tree_RB_REMOVE
+#define ip_msource_tree_RB_REMOVE_COLOR _bsd_ip_msource_tree_RB_REMOVE_COLOR
+#define ip_next_mtu _bsd_ip_next_mtu
+#define ip_optcopy _bsd_ip_optcopy
+#define ip_output _bsd_ip_output
+#define ip_pcbopts _bsd_ip_pcbopts
+#define ip_protox _bsd_ip_protox
+#define ip_reass _bsd_ip_reass
+#define ip_rsvp_done _bsd_ip_rsvp_done
+#define ip_rsvp_force_done _bsd_ip_rsvp_force_done
+#define ip_rsvp_init _bsd_ip_rsvp_init
+#define ip_rsvp_vif _bsd_ip_rsvp_vif
+#define ip_rsvpd _bsd_ip_rsvpd
+#define ip_savecontrol _bsd_ip_savecontrol
+#define ip_slowtimo _bsd_ip_slowtimo
+#define ip_srcroute _bsd_ip_srcroute
+#define ip_stripoptions _bsd_ip_stripoptions
+#define ip_tryforward _bsd_ip_tryforward
+#define ipcomp_enable _bsd_ipcomp_enable
+#define ipcompstat _bsd_ipcompstat
+#define ipforwarding _bsd_ipforwarding
+#define ipport_firstauto _bsd_ipport_firstauto
+#define ipport_hifirstauto _bsd_ipport_hifirstauto
+#define ipport_hilastauto _bsd_ipport_hilastauto
+#define ipport_lastauto _bsd_ipport_lastauto
+#define ipport_lowfirstauto _bsd_ipport_lowfirstauto
+#define ipport_lowlastauto _bsd_ipport_lowlastauto
+#define ipport_randomcps _bsd_ipport_randomcps
+#define ipport_randomized _bsd_ipport_randomized
+#define ipport_randomtime _bsd_ipport_randomtime
+#define ipport_reservedhigh _bsd_ipport_reservedhigh
+#define ipport_reservedlow _bsd_ipport_reservedlow
+#define ipport_stoprandom _bsd_ipport_stoprandom
+#define ipport_tcpallocs _bsd_ipport_tcpallocs
+#define ipproto_register _bsd_ipproto_register
+#define ipproto_unregister _bsd_ipproto_unregister
+#define ipreass_drain _bsd_ipreass_drain
+#define ipreass_init _bsd_ipreass_init
+#define ipreass_slowtimo _bsd_ipreass_slowtimo
+#define ipsec4_capability _bsd_ipsec4_capability
+#define ipsec4_checkpolicy _bsd_ipsec4_checkpolicy
+#define ipsec4_common_input_cb _bsd_ipsec4_common_input_cb
+#define ipsec4_forward _bsd_ipsec4_forward
+#define ipsec4_in_reject _bsd_ipsec4_in_reject
+#define ipsec4_input _bsd_ipsec4_input
+#define ipsec4_output _bsd_ipsec4_output
+#define ipsec4_pcbctl _bsd_ipsec4_pcbctl
+#define ipsec4_process_packet _bsd_ipsec4_process_packet
+#define ipsec4_setsockaddrs _bsd_ipsec4_setsockaddrs
+#define ipsec4stat _bsd_ipsec4stat
+#define ipsec6_capability _bsd_ipsec6_capability
+#define ipsec6_checkpolicy _bsd_ipsec6_checkpolicy
+#define ipsec6_common_input_cb _bsd_ipsec6_common_input_cb
+#define ipsec6_forward _bsd_ipsec6_forward
+#define ipsec6_in_reject _bsd_ipsec6_in_reject
+#define ipsec6_input _bsd_ipsec6_input
+#define ipsec6_output _bsd_ipsec6_output
+#define ipsec6_pcbctl _bsd_ipsec6_pcbctl
+#define ipsec6_process_packet _bsd_ipsec6_process_packet
+#define ipsec6_setsockaddrs _bsd_ipsec6_setsockaddrs
+#define ipsec6stat _bsd_ipsec6stat
+#define ipsec_address _bsd_ipsec_address
+#define ipsec_bindump _bsd_ipsec_bindump
+#define ipsec_chkreplay _bsd_ipsec_chkreplay
+#define ipsec_copy_pcbpolicy _bsd_ipsec_copy_pcbpolicy
+#define ipsec_debug _bsd_ipsec_debug
+#define ipsec_delete_pcbpolicy _bsd_ipsec_delete_pcbpolicy
+#define ipsec_delisr _bsd_ipsec_delisr
+#define ipsec_get_reqlevel _bsd_ipsec_get_reqlevel
+#define ipsec_hdrsiz_inpcb _bsd_ipsec_hdrsiz_inpcb
+#define ipsec_hexdump _bsd_ipsec_hexdump
+#define ipsec_hhh_in _bsd_ipsec_hhh_in
+#define ipsec_hhh_out _bsd_ipsec_hhh_out
+#define ipsec_if_input _bsd_ipsec_if_input
+#define ipsec_init_pcbpolicy _bsd_ipsec_init_pcbpolicy
+#define ipsec_initialized _bsd_ipsec_initialized
+#define ipsec_newisr _bsd_ipsec_newisr
+#define ipsec_process_done _bsd_ipsec_process_done
+#define ipsec_run_hhooks _bsd_ipsec_run_hhooks
+#define ipsec_sa2str _bsd_ipsec_sa2str
+#define ipsec_setspidx_inpcb _bsd_ipsec_setspidx_inpcb
+#define ipsec_updateid _bsd_ipsec_updateid
+#define ipsec_updatereplay _bsd_ipsec_updatereplay
+#define ipsec_warn_interval _bsd_ipsec_warn_interval
+#define ipstat _bsd_ipstat
+#define iptime _bsd_iptime
+#define ipv4_ipsec_support _bsd_ipv4_ipsec_support
+#define ipv6_ipsec_support _bsd_ipv6_ipsec_support
+#define itimerfix _bsd_itimerfix
+#define jenkins_hash _bsd_jenkins_hash
+#define jenkins_hash32 _bsd_jenkins_hash32
+#define kbd_add_driver _bsd_kbd_add_driver
+#define kbd_allocate _bsd_kbd_allocate
+#define kbd_attach _bsd_kbd_attach
+#define kbd_change_callback _bsd_kbd_change_callback
+#define kbd_configure _bsd_kbd_configure
+#define kbd_delete_driver _bsd_kbd_delete_driver
+#define kbd_detach _bsd_kbd_detach
+#define kbd_ev_event _bsd_kbd_ev_event
+#define kbd_find_keyboard _bsd_kbd_find_keyboard
+#define kbd_find_keyboard2 _bsd_kbd_find_keyboard2
+#define kbd_get_keyboard _bsd_kbd_get_keyboard
+#define kbd_get_switch _bsd_kbd_get_switch
+#define kbd_init_struct _bsd_kbd_init_struct
+#define kbd_register _bsd_kbd_register
+#define kbd_release _bsd_kbd_release
+#define kbd_set_maps _bsd_kbd_set_maps
+#define kbd_unregister _bsd_kbd_unregister
+#define kbdsw _bsd_kbdsw
+#define kdebug_ipsecrequest_level _bsd_kdebug_ipsecrequest_level
+#define kdebug_mbuf _bsd_kdebug_mbuf
+#define kdebug_mbufhdr _bsd_kdebug_mbufhdr
+#define kdebug_sadb _bsd_kdebug_sadb
+#define kdebug_sadb_x_policy _bsd_kdebug_sadb_x_policy
+#define kdebug_secash _bsd_kdebug_secash
+#define kdebug_secasindex _bsd_kdebug_secasindex
+#define kdebug_secasindex_mode _bsd_kdebug_secasindex_mode
+#define kdebug_secasv _bsd_kdebug_secasv
+#define kdebug_secasv_state _bsd_kdebug_secasv_state
+#define kdebug_secpolicy _bsd_kdebug_secpolicy
+#define kdebug_secpolicy_policy _bsd_kdebug_secpolicy_policy
+#define kdebug_secpolicy_state _bsd_kdebug_secpolicy_state
+#define kdebug_secpolicyindex _bsd_kdebug_secpolicyindex
+#define kdebug_secpolicyindex_dir _bsd_kdebug_secpolicyindex_dir
+#define kdebug_sockaddr _bsd_kdebug_sockaddr
+#define kernel_sysctl _bsd_kernel_sysctl
+#define key_addref _bsd_key_addref
+#define key_allocsa _bsd_key_allocsa
+#define key_allocsa_policy _bsd_key_allocsa_policy
+#define key_allocsa_tcpmd5 _bsd_key_allocsa_tcpmd5
+#define key_allocsa_tunnel _bsd_key_allocsa_tunnel
+#define key_allocsp _bsd_key_allocsp
+#define key_bumpspgen _bsd_key_bumpspgen
+#define key_debug_level _bsd_key_debug_level
+#define key_delete_xform _bsd_key_delete_xform
+#define key_freereg _bsd_key_freereg
+#define key_freesav _bsd_key_freesav
+#define key_freesp _bsd_key_freesp
+#define key_getspgen _bsd_key_getspgen
+#define key_havesp _bsd_key_havesp
+#define key_init _bsd_key_init
+#define key_msg2sp _bsd_key_msg2sp
+#define key_newreqid _bsd_key_newreqid
+#define key_newsp _bsd_key_newsp
+#define key_output _bsd_key_output
+#define key_parse _bsd_key_parse
+#define key_portfromsaddr _bsd_key_portfromsaddr
+#define key_porttosaddr _bsd_key_porttosaddr
+#define key_random _bsd_key_random
+#define key_randomfill _bsd_key_randomfill
+#define key_register_ifnet _bsd_key_register_ifnet
+#define key_sa_recordxfer _bsd_key_sa_recordxfer
+#define key_sendup_mbuf _bsd_key_sendup_mbuf
+#define key_sockaddrcmp _bsd_key_sockaddrcmp
+#define key_sockaddrcmp_withmask _bsd_key_sockaddrcmp_withmask
+#define key_sp2msg _bsd_key_sp2msg
+#define key_spdacquire _bsd_key_spdacquire
+#define key_unregister_ifnet _bsd_key_unregister_ifnet
+#define key_usrreqs _bsd_key_usrreqs
+#define keydomain _bsd_keydomain
+#define keystat _bsd_keystat
+#define keysw _bsd_keysw
+#define khelp_add_hhook _bsd_khelp_add_hhook
+#define khelp_deregister_helper _bsd_khelp_deregister_helper
+#define khelp_destroy_osd _bsd_khelp_destroy_osd
+#define khelp_get_id _bsd_khelp_get_id
+#define khelp_get_osd _bsd_khelp_get_osd
+#define khelp_init_osd _bsd_khelp_init_osd
+#define khelp_new_hhook_registered _bsd_khelp_new_hhook_registered
+#define khelp_register_helper _bsd_khelp_register_helper
+#define khelp_remove_hhook _bsd_khelp_remove_hhook
+#define kmod_icmp6stat_inc _bsd_kmod_icmp6stat_inc
+#define kmod_icmpstat_inc _bsd_kmod_icmpstat_inc
+#define kmod_ipstat_dec _bsd_kmod_ipstat_dec
+#define kmod_ipstat_inc _bsd_kmod_ipstat_inc
+#define kmod_tcpstat_inc _bsd_kmod_tcpstat_inc
+#define kmod_udpstat_inc _bsd_kmod_udpstat_inc
+#define knlist_add _bsd_knlist_add
+#define knlist_alloc _bsd_knlist_alloc
+#define knlist_cleardel _bsd_knlist_cleardel
+#define knlist_destroy _bsd_knlist_destroy
+#define knlist_detach _bsd_knlist_detach
+#define knlist_empty _bsd_knlist_empty
+#define knlist_init _bsd_knlist_init
+#define knlist_init_mtx _bsd_knlist_init_mtx
+#define knlist_remove _bsd_knlist_remove
+#define knote _bsd_knote
+#define knote_fdclose _bsd_knote_fdclose
+#define kobj_class_compile _bsd_kobj_class_compile
+#define kobj_class_compile_static _bsd_kobj_class_compile_static
+#define kobj_class_free _bsd_kobj_class_free
+#define kobj_create _bsd_kobj_create
+#define kobj_delete _bsd_kobj_delete
+#define kobj_error_method _bsd_kobj_error_method
+#define kobj_init _bsd_kobj_init
+#define kobj_init_static _bsd_kobj_init_static
+#define kobj_lookup_method _bsd_kobj_lookup_method
+#define kproc_create _bsd_kproc_create
+#define kproc_exit _bsd_kproc_exit
+#define kproc_kthread_add _bsd_kproc_kthread_add
+#define kproc_start _bsd_kproc_start
+#define kqfd_register _bsd_kqfd_register
+#define kqueue_add_filteropts _bsd_kqueue_add_filteropts
+#define kqueue_del_filteropts _bsd_kqueue_del_filteropts
+#define kthread_add _bsd_kthread_add
+#define kthread_exit _bsd_kthread_exit
+#define kthread_start _bsd_kthread_start
+#define kvprintf _bsd_kvprintf
+#define lacp_attach _bsd_lacp_attach
+#define lacp_detach _bsd_lacp_detach
+#define lacp_init _bsd_lacp_init
+#define lacp_input _bsd_lacp_input
+#define lacp_linkstate _bsd_lacp_linkstate
+#define lacp_port_create _bsd_lacp_port_create
+#define lacp_port_destroy _bsd_lacp_port_destroy
+#define lacp_portreq _bsd_lacp_portreq
+#define lacp_req _bsd_lacp_req
+#define lacp_select_tx_port _bsd_lacp_select_tx_port
+#define lacp_stop _bsd_lacp_stop
+#define lagg_detach_cookie _bsd_lagg_detach_cookie
+#define lagg_enqueue _bsd_lagg_enqueue
+#define lagg_input_p _bsd_lagg_input_p
+#define lagg_linkstate_p _bsd_lagg_linkstate_p
+#define lagg_list _bsd_lagg_list
+#define le_uuid_dec _bsd_le_uuid_dec
+#define le_uuid_enc _bsd_le_uuid_enc
+#define led_create _bsd_led_create
+#define led_create_state _bsd_led_create_state
+#define led_destroy _bsd_led_destroy
+#define led_set _bsd_led_set
+#define legal_vif_num _bsd_legal_vif_num
+#define lem_txrx _bsd_lem_txrx
+#define link_alloc_sdl _bsd_link_alloc_sdl
+#define link_free_sdl _bsd_link_free_sdl
+#define link_init_sdl _bsd_link_init_sdl
+#define link_pfil_head _bsd_link_pfil_head
+#define link_pfil_hook _bsd_link_pfil_hook
+#define lla_rt_output _bsd_lla_rt_output
+#define llentry_alloc _bsd_llentry_alloc
+#define llentry_free _bsd_llentry_free
+#define lltable_alloc_entry _bsd_lltable_alloc_entry
+#define lltable_allocate_htbl _bsd_lltable_allocate_htbl
+#define lltable_calc_llheader _bsd_lltable_calc_llheader
+#define lltable_delete_addr _bsd_lltable_delete_addr
+#define lltable_drop_entry_queue _bsd_lltable_drop_entry_queue
+#define lltable_fill_sa_entry _bsd_lltable_fill_sa_entry
+#define lltable_foreach_lle _bsd_lltable_foreach_lle
+#define lltable_free _bsd_lltable_free
+#define lltable_free_entry _bsd_lltable_free_entry
+#define lltable_get_af _bsd_lltable_get_af
+#define lltable_get_ifp _bsd_lltable_get_ifp
+#define lltable_link _bsd_lltable_link
+#define lltable_link_entry _bsd_lltable_link_entry
+#define lltable_prefix_free _bsd_lltable_prefix_free
+#define lltable_set_entry_addr _bsd_lltable_set_entry_addr
+#define lltable_sysctl_dumparp _bsd_lltable_sysctl_dumparp
+#define lltable_try_set_entry_addr _bsd_lltable_try_set_entry_addr
+#define lltable_unlink_entry _bsd_lltable_unlink_entry
+#define lltable_update_ifaddr _bsd_lltable_update_ifaddr
+#define lock_class_mtx_sleep _bsd_lock_class_mtx_sleep
+#define lock_class_mtx_spin _bsd_lock_class_mtx_spin
+#define lock_class_rw _bsd_lock_class_rw
+#define lock_class_sx _bsd_lock_class_sx
+#define lock_classes _bsd_lock_classes
+#define lock_destroy _bsd_lock_destroy
+#define lock_init _bsd_lock_init
+#define log _bsd_log
+#define loif _bsd_loif
+#define loioctl _bsd_loioctl
+#define looutput _bsd_looutput
+#define lpc_pwr_read _bsd_lpc_pwr_read
+#define lpc_pwr_write _bsd_lpc_pwr_write
+#define m_adj _bsd_m_adj
+#define m_append _bsd_m_append
+#define m_apply _bsd_m_apply
+#define m_cat _bsd_m_cat
+#define m_catpkt _bsd_m_catpkt
+#define m_checkalignment _bsd_m_checkalignment
+#define m_clget _bsd_m_clget
+#define m_cljget _bsd_m_cljget
+#define m_collapse _bsd_m_collapse
+#define m_copyback _bsd_m_copyback
+#define m_copydata _bsd_m_copydata
+#define m_copym _bsd_m_copym
+#define m_copypacket _bsd_m_copypacket
+#define m_copyup _bsd_m_copyup
+#define m_defrag _bsd_m_defrag
+#define m_demote _bsd_m_demote
+#define m_demote_pkthdr _bsd_m_demote_pkthdr
+#define m_devget _bsd_m_devget
+#define m_dispose_extcontrolm _bsd_m_dispose_extcontrolm
+#define m_dup _bsd_m_dup
+#define m_dup_pkthdr _bsd_m_dup_pkthdr
+#define m_ether_tcpip_hash _bsd_m_ether_tcpip_hash
+#define m_ether_tcpip_hash_init _bsd_m_ether_tcpip_hash_init
+#define m_extadd _bsd_m_extadd
+#define m_fixhdr _bsd_m_fixhdr
+#define m_freem _bsd_m_freem
+#define m_get2 _bsd_m_get2
+#define m_getjcl _bsd_m_getjcl
+#define m_getm2 _bsd_m_getm2
+#define m_getptr _bsd_m_getptr
+#define m_length _bsd_m_length
+#define m_makespace _bsd_m_makespace
+#define m_mbuftouio _bsd_m_mbuftouio
+#define m_megapullup _bsd_m_megapullup
+#define m_move_pkthdr _bsd_m_move_pkthdr
+#define m_pad _bsd_m_pad
+#define m_pkthdr_init _bsd_m_pkthdr_init
+#define m_prepend _bsd_m_prepend
+#define m_print _bsd_m_print
+#define m_pulldown _bsd_m_pulldown
+#define m_pullup _bsd_m_pullup
+#define m_raopt _bsd_m_raopt
+#define m_sanity _bsd_m_sanity
+#define m_snd_tag_destroy _bsd_m_snd_tag_destroy
+#define m_snd_tag_init _bsd_m_snd_tag_init
+#define m_split _bsd_m_split
+#define m_striphdr _bsd_m_striphdr
+#define m_tag_alloc _bsd_m_tag_alloc
+#define m_tag_copy _bsd_m_tag_copy
+#define m_tag_copy_chain _bsd_m_tag_copy_chain
+#define m_tag_delete _bsd_m_tag_delete
+#define m_tag_delete_chain _bsd_m_tag_delete_chain
+#define m_tag_delete_nonpersistent _bsd_m_tag_delete_nonpersistent
+#define m_tag_free_default _bsd_m_tag_free_default
+#define m_tag_locate _bsd_m_tag_locate
+#define m_uiotombuf _bsd_m_uiotombuf
+#define m_unmappedtouio _bsd_m_unmappedtouio
+#define m_unshare _bsd_m_unshare
+#define machclk_freq _bsd_machclk_freq
+#define machclk_per_tick _bsd_machclk_per_tick
+#define machclk_usepcc _bsd_machclk_usepcc
+#define make_dev _bsd_make_dev
+#define make_dev_alias _bsd_make_dev_alias
+#define make_dev_args_init_impl _bsd_make_dev_args_init_impl
+#define make_dev_s _bsd_make_dev_s
+#define malloc_init _bsd_malloc_init
+#define malloc_uninit _bsd_malloc_uninit
+#define mallocarray _bsd_mallocarray
+#define maxpipekva _bsd_maxpipekva
+#define mb_dupcl _bsd_mb_dupcl
+#define mb_free_ext _bsd_mb_free_ext
+#define mb_free_notready _bsd_mb_free_notready
+#define mb_use_ext_pgs _bsd_mb_use_ext_pgs
+#define mesh_airtime_calc _bsd_mesh_airtime_calc
+#define mgt_subtype_name _bsd_mgt_subtype_name
+#define mi_startup _bsd_mi_startup
+#define mii_attach _bsd_mii_attach
+#define mii_bitbang_readreg _bsd_mii_bitbang_readreg
+#define mii_bitbang_sync _bsd_mii_bitbang_sync
+#define mii_bitbang_writereg _bsd_mii_bitbang_writereg
+#define mii_dev_mac_match _bsd_mii_dev_mac_match
+#define mii_dev_mac_softc _bsd_mii_dev_mac_softc
+#define mii_fdt_contype_from_name _bsd_mii_fdt_contype_from_name
+#define mii_fdt_contype_to_name _bsd_mii_fdt_contype_to_name
+#define mii_fdt_free_config _bsd_mii_fdt_free_config
+#define mii_fdt_get_config _bsd_mii_fdt_get_config
+#define mii_fdt_get_contype _bsd_mii_fdt_get_contype
+#define mii_mediachg _bsd_mii_mediachg
+#define mii_oui _bsd_mii_oui
+#define mii_phy_add_media _bsd_mii_phy_add_media
+#define mii_phy_auto _bsd_mii_phy_auto
+#define mii_phy_detach _bsd_mii_phy_detach
+#define mii_phy_dev_attach _bsd_mii_phy_dev_attach
+#define mii_phy_dev_probe _bsd_mii_phy_dev_probe
+#define mii_phy_flowstatus _bsd_mii_phy_flowstatus
+#define mii_phy_mac_match _bsd_mii_phy_mac_match
+#define mii_phy_mac_softc _bsd_mii_phy_mac_softc
+#define mii_phy_match _bsd_mii_phy_match
+#define mii_phy_match_gen _bsd_mii_phy_match_gen
+#define mii_phy_reset _bsd_mii_phy_reset
+#define mii_phy_setmedia _bsd_mii_phy_setmedia
+#define mii_phy_tick _bsd_mii_phy_tick
+#define mii_phy_update _bsd_mii_phy_update
+#define mii_pollstat _bsd_mii_pollstat
+#define mii_tick _bsd_mii_tick
+#define miibus_devclass _bsd_miibus_devclass
+#define miibus_driver _bsd_miibus_driver
+#define mld_change_state _bsd_mld_change_state
+#define mld_domifattach _bsd_mld_domifattach
+#define mld_domifdetach _bsd_mld_domifdetach
+#define mld_fasttimo _bsd_mld_fasttimo
+#define mld_ifdetach _bsd_mld_ifdetach
+#define mld_input _bsd_mld_input
+#define mld_slowtimo _bsd_mld_slowtimo
+#define mmc_devclass _bsd_mmc_devclass
+#define mmc_driver _bsd_mmc_driver
+#define mmc_send_ext_csd _bsd_mmc_send_ext_csd
+#define mmc_send_status _bsd_mmc_send_status
+#define mmc_switch _bsd_mmc_switch
+#define mmc_switch_status _bsd_mmc_switch_status
+#define mmc_wait_for_app_cmd _bsd_mmc_wait_for_app_cmd
+#define mmc_wait_for_cmd _bsd_mmc_wait_for_cmd
+#define module_lookupbyname _bsd_module_lookupbyname
+#define module_register _bsd_module_register
+#define module_register_init _bsd_module_register_init
+#define module_release _bsd_module_release
+#define modules_sx _bsd_modules_sx
+#define mrt6_ioctl _bsd_mrt6_ioctl
+#define mrt_ioctl _bsd_mrt_ioctl
+#define mtrash_ctor _bsd_mtrash_ctor
+#define mtrash_dtor _bsd_mtrash_dtor
+#define mtrash_fini _bsd_mtrash_fini
+#define mtrash_init _bsd_mtrash_init
+#define mtx_destroy _bsd_mtx_destroy
+#define mtx_init _bsd_mtx_init
+#define mtx_owned _bsd_mtx_owned
+#define mtx_pool_alloc _bsd_mtx_pool_alloc
+#define mtx_pool_create _bsd_mtx_pool_create
+#define mtx_pool_destroy _bsd_mtx_pool_destroy
+#define mtx_pool_find _bsd_mtx_pool_find
+#define mtx_recursed _bsd_mtx_recursed
+#define mtx_sysinit _bsd_mtx_sysinit
+#define mtx_trylock_flags_ _bsd_mtx_trylock_flags_
+#define mtxpool_sleep _bsd_mtxpool_sleep
+#define murmur3_32_hash _bsd_murmur3_32_hash
+#define murmur3_32_hash32 _bsd_murmur3_32_hash32
+#define musbotg_connect_interrupt _bsd_musbotg_connect_interrupt
+#define musbotg_init _bsd_musbotg_init
+#define musbotg_interrupt _bsd_musbotg_interrupt
+#define musbotg_uninit _bsd_musbotg_uninit
+#define musbotg_vbus_interrupt _bsd_musbotg_vbus_interrupt
+#define mutex_init _bsd_mutex_init
+#define natt_cksum_policy _bsd_natt_cksum_policy
+#define nd6_add_ifa_lle _bsd_nd6_add_ifa_lle
+#define nd6_alloc _bsd_nd6_alloc
+#define nd6_cache_lladdr _bsd_nd6_cache_lladdr
+#define nd6_dad_init _bsd_nd6_dad_init
+#define nd6_dad_start _bsd_nd6_dad_start
+#define nd6_dad_stop _bsd_nd6_dad_stop
+#define nd6_defifindex _bsd_nd6_defifindex
+#define nd6_defrouter_flush_all _bsd_nd6_defrouter_flush_all
+#define nd6_defrouter_init _bsd_nd6_defrouter_init
+#define nd6_defrouter_list_empty _bsd_nd6_defrouter_list_empty
+#define nd6_defrouter_purge _bsd_nd6_defrouter_purge
+#define nd6_defrouter_timer _bsd_nd6_defrouter_timer
+#define nd6_flush_holdchain _bsd_nd6_flush_holdchain
+#define nd6_grab_holdchain _bsd_nd6_grab_holdchain
+#define nd6_ifattach _bsd_nd6_ifattach
+#define nd6_ifdetach _bsd_nd6_ifdetach
+#define nd6_ifnet_link_event _bsd_nd6_ifnet_link_event
+#define nd6_ifptomac _bsd_nd6_ifptomac
+#define nd6_init _bsd_nd6_init
+#define nd6_ioctl _bsd_nd6_ioctl
+#define nd6_is_addr_neighbor _bsd_nd6_is_addr_neighbor
+#define nd6_list_genid _bsd_nd6_list_genid
+#define nd6_llinfo_setstate _bsd_nd6_llinfo_setstate
+#define nd6_lock _bsd_nd6_lock
+#define nd6_lookup _bsd_nd6_lookup
+#define nd6_na_input _bsd_nd6_na_input
+#define nd6_na_output _bsd_nd6_na_output
+#define nd6_ns_input _bsd_nd6_ns_input
+#define nd6_ns_output _bsd_nd6_ns_output
+#define nd6_onlink_mtx _bsd_nd6_onlink_mtx
+#define nd6_option _bsd_nd6_option
+#define nd6_option_init _bsd_nd6_option_init
+#define nd6_options _bsd_nd6_options
+#define nd6_output_ifp _bsd_nd6_output_ifp
+#define nd6_prefix_del _bsd_nd6_prefix_del
+#define nd6_prefix_lookup _bsd_nd6_prefix_lookup
+#define nd6_prefix_offlink _bsd_nd6_prefix_offlink
+#define nd6_prefix_onlink _bsd_nd6_prefix_onlink
+#define nd6_prefix_ref _bsd_nd6_prefix_ref
+#define nd6_prefix_rele _bsd_nd6_prefix_rele
+#define nd6_prefix_unlink _bsd_nd6_prefix_unlink
+#define nd6_prelist_add _bsd_nd6_prelist_add
+#define nd6_purge _bsd_nd6_purge
+#define nd6_ra_input _bsd_nd6_ra_input
+#define nd6_recalc_reachtm_interval _bsd_nd6_recalc_reachtm_interval
+#define nd6_rem_ifa_lle _bsd_nd6_rem_ifa_lle
+#define nd6_resolve _bsd_nd6_resolve
+#define nd6_resolve_addr _bsd_nd6_resolve_addr
+#define nd6_rs_input _bsd_nd6_rs_input
+#define nd6_setdefaultiface _bsd_nd6_setdefaultiface
+#define nd6_setmtu _bsd_nd6_setmtu
+#define nd6_timer _bsd_nd6_timer
+#define nd6_timer_ch _bsd_nd6_timer_ch
+#define nd_defrouter _bsd_nd_defrouter
+#define nd_prefix _bsd_nd_prefix
+#define netisr_clearqdrops _bsd_netisr_clearqdrops
+#define netisr_dispatch _bsd_netisr_dispatch
+#define netisr_dispatch_src _bsd_netisr_dispatch_src
+#define netisr_getqdrops _bsd_netisr_getqdrops
+#define netisr_getqlimit _bsd_netisr_getqlimit
+#define netisr_queue _bsd_netisr_queue
+#define netisr_queue_src _bsd_netisr_queue_src
+#define netisr_register _bsd_netisr_register
+#define netisr_setqlimit _bsd_netisr_setqlimit
+#define netisr_unregister _bsd_netisr_unregister
+#define new_unrhdr _bsd_new_unrhdr
+#define newpacket _bsd_newpacket
+#define newreno_cc_algo _bsd_newreno_cc_algo
+#define ng_ether_attach_p _bsd_ng_ether_attach_p
+#define ng_ether_detach_p _bsd_ng_ether_detach_p
+#define ng_ether_input_orphan_p _bsd_ng_ether_input_orphan_p
+#define ng_ether_input_p _bsd_ng_ether_input_p
+#define ng_ether_link_state_p _bsd_ng_ether_link_state_p
+#define ng_ether_output_p _bsd_ng_ether_output_p
+#define ng_gif_attach_p _bsd_ng_gif_attach_p
+#define ng_gif_detach_p _bsd_ng_gif_detach_p
+#define ng_gif_input_orphan_p _bsd_ng_gif_input_orphan_p
+#define ng_gif_input_p _bsd_ng_gif_input_p
+#define ng_ipfw_input_p _bsd_ng_ipfw_input_p
+#define nousrreqs _bsd_nousrreqs
+#define null_class _bsd_null_class
+#define null_filtops _bsd_null_filtops
+#define nullop _bsd_nullop
+#define nvme_admin_qpair_destroy _bsd_nvme_admin_qpair_destroy
+#define nvme_admin_qpair_disable _bsd_nvme_admin_qpair_disable
+#define nvme_admin_qpair_enable _bsd_nvme_admin_qpair_enable
+#define nvme_attach _bsd_nvme_attach
+#define nvme_completion_poll_cb _bsd_nvme_completion_poll_cb
+#define nvme_consumer _bsd_nvme_consumer
+#define nvme_ctrlr_cmd_abort _bsd_nvme_ctrlr_cmd_abort
+#define nvme_ctrlr_cmd_create_io_cq _bsd_nvme_ctrlr_cmd_create_io_cq
+#define nvme_ctrlr_cmd_create_io_sq _bsd_nvme_ctrlr_cmd_create_io_sq
+#define nvme_ctrlr_cmd_delete_io_cq _bsd_nvme_ctrlr_cmd_delete_io_cq
+#define nvme_ctrlr_cmd_delete_io_sq _bsd_nvme_ctrlr_cmd_delete_io_sq
+#define nvme_ctrlr_cmd_get_error_page _bsd_nvme_ctrlr_cmd_get_error_page
+#define nvme_ctrlr_cmd_get_feature _bsd_nvme_ctrlr_cmd_get_feature
+#define nvme_ctrlr_cmd_get_firmware_page _bsd_nvme_ctrlr_cmd_get_firmware_page
+#define nvme_ctrlr_cmd_get_health_information_page _bsd_nvme_ctrlr_cmd_get_health_information_page
+#define nvme_ctrlr_cmd_get_log_page _bsd_nvme_ctrlr_cmd_get_log_page
+#define nvme_ctrlr_cmd_identify_controller _bsd_nvme_ctrlr_cmd_identify_controller
+#define nvme_ctrlr_cmd_identify_namespace _bsd_nvme_ctrlr_cmd_identify_namespace
+#define nvme_ctrlr_cmd_set_async_event_config _bsd_nvme_ctrlr_cmd_set_async_event_config
+#define nvme_ctrlr_cmd_set_feature _bsd_nvme_ctrlr_cmd_set_feature
+#define nvme_ctrlr_cmd_set_interrupt_coalescing _bsd_nvme_ctrlr_cmd_set_interrupt_coalescing
+#define nvme_ctrlr_cmd_set_num_queues _bsd_nvme_ctrlr_cmd_set_num_queues
+#define nvme_ctrlr_construct _bsd_nvme_ctrlr_construct
+#define nvme_ctrlr_destruct _bsd_nvme_ctrlr_destruct
+#define nvme_ctrlr_get_data _bsd_nvme_ctrlr_get_data
+#define nvme_ctrlr_get_device _bsd_nvme_ctrlr_get_device
+#define nvme_ctrlr_hw_reset _bsd_nvme_ctrlr_hw_reset
+#define nvme_ctrlr_intx_handler _bsd_nvme_ctrlr_intx_handler
+#define nvme_ctrlr_passthrough_cmd _bsd_nvme_ctrlr_passthrough_cmd
+#define nvme_ctrlr_poll _bsd_nvme_ctrlr_poll
+#define nvme_ctrlr_post_failed_request _bsd_nvme_ctrlr_post_failed_request
+#define nvme_ctrlr_reset _bsd_nvme_ctrlr_reset
+#define nvme_ctrlr_resume _bsd_nvme_ctrlr_resume
+#define nvme_ctrlr_shutdown _bsd_nvme_ctrlr_shutdown
+#define nvme_ctrlr_start_config_hook _bsd_nvme_ctrlr_start_config_hook
+#define nvme_ctrlr_submit_admin_request _bsd_nvme_ctrlr_submit_admin_request
+#define nvme_ctrlr_submit_io_request _bsd_nvme_ctrlr_submit_io_request
+#define nvme_ctrlr_suspend _bsd_nvme_ctrlr_suspend
+#define nvme_detach _bsd_nvme_detach
+#define nvme_devclass _bsd_nvme_devclass
+#define nvme_dump_command _bsd_nvme_dump_command
+#define nvme_dump_completion _bsd_nvme_dump_completion
+#define nvme_io_qpair_destroy _bsd_nvme_io_qpair_destroy
+#define nvme_io_qpair_disable _bsd_nvme_io_qpair_disable
+#define nvme_io_qpair_enable _bsd_nvme_io_qpair_enable
+#define nvme_notify_async_consumers _bsd_nvme_notify_async_consumers
+#define nvme_notify_fail_consumers _bsd_nvme_notify_fail_consumers
+#define nvme_notify_new_controller _bsd_nvme_notify_new_controller
+#define nvme_notify_ns _bsd_nvme_notify_ns
+#define nvme_ns_cmd_deallocate _bsd_nvme_ns_cmd_deallocate
+#define nvme_ns_cmd_flush _bsd_nvme_ns_cmd_flush
+#define nvme_ns_cmd_read _bsd_nvme_ns_cmd_read
+#define nvme_ns_cmd_read_iov _bsd_nvme_ns_cmd_read_iov
+#define nvme_ns_cmd_write _bsd_nvme_ns_cmd_write
+#define nvme_ns_cmd_write_iov _bsd_nvme_ns_cmd_write_iov
+#define nvme_ns_construct _bsd_nvme_ns_construct
+#define nvme_ns_destruct _bsd_nvme_ns_destruct
+#define nvme_ns_dump _bsd_nvme_ns_dump
+#define nvme_ns_get_data _bsd_nvme_ns_get_data
+#define nvme_ns_get_flags _bsd_nvme_ns_get_flags
+#define nvme_ns_get_max_io_xfer_size _bsd_nvme_ns_get_max_io_xfer_size
+#define nvme_ns_get_model_number _bsd_nvme_ns_get_model_number
+#define nvme_ns_get_num_sectors _bsd_nvme_ns_get_num_sectors
+#define nvme_ns_get_sector_size _bsd_nvme_ns_get_sector_size
+#define nvme_ns_get_serial_number _bsd_nvme_ns_get_serial_number
+#define nvme_ns_get_size _bsd_nvme_ns_get_size
+#define nvme_ns_get_stripesize _bsd_nvme_ns_get_stripesize
+#define nvme_ns_ioctl_process _bsd_nvme_ns_ioctl_process
+#define nvme_qpair_construct _bsd_nvme_qpair_construct
+#define nvme_qpair_fail _bsd_nvme_qpair_fail
+#define nvme_qpair_manual_complete_request _bsd_nvme_qpair_manual_complete_request
+#define nvme_qpair_process_completions _bsd_nvme_qpair_process_completions
+#define nvme_qpair_reset _bsd_nvme_qpair_reset
+#define nvme_qpair_submit_request _bsd_nvme_qpair_submit_request
+#define nvme_qpair_submit_tracker _bsd_nvme_qpair_submit_tracker
+#define nvme_register_consumer _bsd_nvme_register_consumer
+#define nvme_request_zone _bsd_nvme_request_zone
+#define nvme_retry_count _bsd_nvme_retry_count
+#define nvme_shutdown _bsd_nvme_shutdown
+#define nvme_sysctl_initialize_ctrlr _bsd_nvme_sysctl_initialize_ctrlr
+#define nvme_unregister_consumer _bsd_nvme_unregister_consumer
+#define nvme_use_nvd _bsd_nvme_use_nvd
+#define nvme_verbose_cmd_dump _bsd_nvme_verbose_cmd_dump
+#define ofw_bus_assigned_addresses_to_rl _bsd_ofw_bus_assigned_addresses_to_rl
+#define ofw_bus_find_child _bsd_ofw_bus_find_child
+#define ofw_bus_find_child_device_by_phandle _bsd_ofw_bus_find_child_device_by_phandle
+#define ofw_bus_find_compatible _bsd_ofw_bus_find_compatible
+#define ofw_bus_find_iparent _bsd_ofw_bus_find_iparent
+#define ofw_bus_find_string_index _bsd_ofw_bus_find_string_index
+#define ofw_bus_gen_child_pnpinfo_str _bsd_ofw_bus_gen_child_pnpinfo_str
+#define ofw_bus_gen_destroy_devinfo _bsd_ofw_bus_gen_destroy_devinfo
+#define ofw_bus_gen_get_compat _bsd_ofw_bus_gen_get_compat
+#define ofw_bus_gen_get_model _bsd_ofw_bus_gen_get_model
+#define ofw_bus_gen_get_name _bsd_ofw_bus_gen_get_name
+#define ofw_bus_gen_get_node _bsd_ofw_bus_gen_get_node
+#define ofw_bus_gen_get_type _bsd_ofw_bus_gen_get_type
+#define ofw_bus_gen_setup_devinfo _bsd_ofw_bus_gen_setup_devinfo
+#define ofw_bus_get_status _bsd_ofw_bus_get_status
+#define ofw_bus_has_prop _bsd_ofw_bus_has_prop
+#define ofw_bus_intr_by_rid _bsd_ofw_bus_intr_by_rid
+#define ofw_bus_intr_to_rl _bsd_ofw_bus_intr_to_rl
+#define ofw_bus_is_compatible _bsd_ofw_bus_is_compatible
+#define ofw_bus_is_compatible_strict _bsd_ofw_bus_is_compatible_strict
+#define ofw_bus_lookup_imap _bsd_ofw_bus_lookup_imap
+#define ofw_bus_msimap _bsd_ofw_bus_msimap
+#define ofw_bus_node_is_compatible _bsd_ofw_bus_node_is_compatible
+#define ofw_bus_node_status_okay _bsd_ofw_bus_node_status_okay
+#define ofw_bus_parse_xref_list_alloc _bsd_ofw_bus_parse_xref_list_alloc
+#define ofw_bus_parse_xref_list_get_length _bsd_ofw_bus_parse_xref_list_get_length
+#define ofw_bus_reg_to_rl _bsd_ofw_bus_reg_to_rl
+#define ofw_bus_search_compatible _bsd_ofw_bus_search_compatible
+#define ofw_bus_search_intrmap _bsd_ofw_bus_search_intrmap
+#define ofw_bus_setup_iinfo _bsd_ofw_bus_setup_iinfo
+#define ofw_bus_status_okay _bsd_ofw_bus_status_okay
+#define ofw_bus_string_list_to_array _bsd_ofw_bus_string_list_to_array
+#define ofw_fdt _bsd_ofw_fdt
+#define ofw_gpiobus_add_fdt_child _bsd_ofw_gpiobus_add_fdt_child
+#define ofw_gpiobus_driver _bsd_ofw_gpiobus_driver
+#define ofw_gpiobus_parse_gpios _bsd_ofw_gpiobus_parse_gpios
+#define ofw_gpiobus_register_provider _bsd_ofw_gpiobus_register_provider
+#define ofw_gpiobus_unregister_provider _bsd_ofw_gpiobus_unregister_provider
+#define ofw_iicbus_devclass _bsd_ofw_iicbus_devclass
+#define ofw_iicbus_driver _bsd_ofw_iicbus_driver
+#define ofw_parse_bootargs _bsd_ofw_parse_bootargs
+#define ofw_reg_to_paddr _bsd_ofw_reg_to_paddr
+#define ofwbus_driver _bsd_ofwbus_driver
+#define ofwgpiobus_devclass _bsd_ofwgpiobus_devclass
+#define ohci_detach _bsd_ohci_detach
+#define ohci_init _bsd_ohci_init
+#define ohci_interrupt _bsd_ohci_interrupt
+#define ohci_iterate_hw_softc _bsd_ohci_iterate_hw_softc
+#define osd_call _bsd_osd_call
+#define osd_del _bsd_osd_del
+#define osd_deregister _bsd_osd_deregister
+#define osd_exit _bsd_osd_exit
+#define osd_free_reserved _bsd_osd_free_reserved
+#define osd_get _bsd_osd_get
+#define osd_register _bsd_osd_register
+#define osd_reserve _bsd_osd_reserve
+#define osd_set _bsd_osd_set
+#define osd_set_reserved _bsd_osd_set_reserved
+#define osdm _bsd_osdm
+#define panic _bsd_panic
+#define parse_uuid _bsd_parse_uuid
+#define pause_sbt _bsd_pause_sbt
+#define pci_activate_resource _bsd_pci_activate_resource
+#define pci_add_bar _bsd_pci_add_bar
+#define pci_add_child _bsd_pci_add_child
+#define pci_add_children _bsd_pci_add_children
+#define pci_add_resources _bsd_pci_add_resources
+#define pci_add_resources_ea _bsd_pci_add_resources_ea
+#define pci_alloc_devinfo_method _bsd_pci_alloc_devinfo_method
+#define pci_alloc_msi_method _bsd_pci_alloc_msi_method
+#define pci_alloc_msix_method _bsd_pci_alloc_msix_method
+#define pci_alloc_multi_resource _bsd_pci_alloc_multi_resource
+#define pci_alloc_resource _bsd_pci_alloc_resource
+#define pci_assign_interrupt_method _bsd_pci_assign_interrupt_method
+#define pci_attach _bsd_pci_attach
+#define pci_attach_common _bsd_pci_attach_common
+#define pci_bar_enabled _bsd_pci_bar_enabled
+#define pci_cfg_restore _bsd_pci_cfg_restore
+#define pci_cfg_save _bsd_pci_cfg_save
+#define pci_cfgregopen _bsd_pci_cfgregopen
+#define pci_cfgregread _bsd_pci_cfgregread
+#define pci_cfgregwrite _bsd_pci_cfgregwrite
+#define pci_child_added_method _bsd_pci_child_added_method
+#define pci_child_deleted _bsd_pci_child_deleted
+#define pci_child_detached _bsd_pci_child_detached
+#define pci_child_location_str_method _bsd_pci_child_location_str_method
+#define pci_child_pnpinfo_str_method _bsd_pci_child_pnpinfo_str_method
+#define pci_deactivate_resource _bsd_pci_deactivate_resource
+#define pci_delete_resource _bsd_pci_delete_resource
+#define pci_detach _bsd_pci_detach
+#define pci_devq _bsd_pci_devq
+#define pci_disable_busmaster_method _bsd_pci_disable_busmaster_method
+#define pci_disable_io_method _bsd_pci_disable_io_method
+#define pci_disable_msi_method _bsd_pci_disable_msi_method
+#define pci_do_power_resume _bsd_pci_do_power_resume
+#define pci_do_power_suspend _bsd_pci_do_power_suspend
+#define pci_driver _bsd_pci_driver
+#define pci_driver_added _bsd_pci_driver_added
+#define pci_ea_is_enabled _bsd_pci_ea_is_enabled
+#define pci_enable_busmaster_method _bsd_pci_enable_busmaster_method
+#define pci_enable_io_method _bsd_pci_enable_io_method
+#define pci_enable_msi_method _bsd_pci_enable_msi_method
+#define pci_enable_msix_method _bsd_pci_enable_msix_method
+#define pci_fetch_vpd_list _bsd_pci_fetch_vpd_list
+#define pci_find_bar _bsd_pci_find_bar
+#define pci_find_bsf _bsd_pci_find_bsf
+#define pci_find_cap_method _bsd_pci_find_cap_method
+#define pci_find_class _bsd_pci_find_class
+#define pci_find_dbsf _bsd_pci_find_dbsf
+#define pci_find_extcap_method _bsd_pci_find_extcap_method
+#define pci_find_htcap_method _bsd_pci_find_htcap_method
+#define pci_find_next_cap_method _bsd_pci_find_next_cap_method
+#define pci_find_next_extcap_method _bsd_pci_find_next_extcap_method
+#define pci_find_next_htcap_method _bsd_pci_find_next_htcap_method
+#define pci_find_pcie_root_port _bsd_pci_find_pcie_root_port
+#define pci_freecfg _bsd_pci_freecfg
+#define pci_generation _bsd_pci_generation
+#define pci_get_dma_tag _bsd_pci_get_dma_tag
+#define pci_get_max_payload _bsd_pci_get_max_payload
+#define pci_get_max_read_req _bsd_pci_get_max_read_req
+#define pci_get_powerstate_method _bsd_pci_get_powerstate_method
+#define pci_get_resource_list _bsd_pci_get_resource_list
+#define pci_get_vpd_ident_method _bsd_pci_get_vpd_ident_method
+#define pci_get_vpd_readonly_method _bsd_pci_get_vpd_readonly_method
+#define pci_ht_map_msi _bsd_pci_ht_map_msi
+#define pci_mapsize _bsd_pci_mapsize
+#define pci_match_device _bsd_pci_match_device
+#define pci_msi_count_method _bsd_pci_msi_count_method
+#define pci_msi_device_blacklisted _bsd_pci_msi_device_blacklisted
+#define pci_msix_count_method _bsd_pci_msix_count_method
+#define pci_msix_device_blacklisted _bsd_pci_msix_device_blacklisted
+#define pci_msix_pba_bar_method _bsd_pci_msix_pba_bar_method
+#define pci_msix_table_bar_method _bsd_pci_msix_table_bar_method
+#define pci_numdevs _bsd_pci_numdevs
+#define pci_pending_msix _bsd_pci_pending_msix
+#define pci_power_reset _bsd_pci_power_reset
+#define pci_print_child _bsd_pci_print_child
+#define pci_print_faulted_dev _bsd_pci_print_faulted_dev
+#define pci_print_verbose _bsd_pci_print_verbose
+#define pci_probe_nomatch _bsd_pci_probe_nomatch
+#define pci_read_bar _bsd_pci_read_bar
+#define pci_read_config_method _bsd_pci_read_config_method
+#define pci_read_device _bsd_pci_read_device
+#define pci_read_ivar _bsd_pci_read_ivar
+#define pci_release_msi_method _bsd_pci_release_msi_method
+#define pci_release_resource _bsd_pci_release_resource
+#define pci_remap_msix_method _bsd_pci_remap_msix_method
+#define pci_rescan_method _bsd_pci_rescan_method
+#define pci_restore_state _bsd_pci_restore_state
+#define pci_resume _bsd_pci_resume
+#define pci_resume_child _bsd_pci_resume_child
+#define pci_save_state _bsd_pci_save_state
+#define pci_set_max_read_req _bsd_pci_set_max_read_req
+#define pci_set_powerstate_method _bsd_pci_set_powerstate_method
+#define pci_setup_intr _bsd_pci_setup_intr
+#define pci_suspend_child _bsd_pci_suspend_child
+#define pci_teardown_intr _bsd_pci_teardown_intr
+#define pci_write_config_method _bsd_pci_write_config_method
+#define pci_write_ivar _bsd_pci_write_ivar
+#define pcib_alloc_msi _bsd_pcib_alloc_msi
+#define pcib_alloc_msix _bsd_pcib_alloc_msix
+#define pcib_alloc_resource _bsd_pcib_alloc_resource
+#define pcib_attach _bsd_pcib_attach
+#define pcib_attach_child _bsd_pcib_attach_child
+#define pcib_attach_common _bsd_pcib_attach_common
+#define pcib_bridge_init _bsd_pcib_bridge_init
+#define pcib_child_present _bsd_pcib_child_present
+#define pcib_decode_rid _bsd_pcib_decode_rid
+#define pcib_detach _bsd_pcib_detach
+#define pcib_driver _bsd_pcib_driver
+#define pcib_get_id _bsd_pcib_get_id
+#define pcib_map_msi _bsd_pcib_map_msi
+#define pcib_maxfuncs _bsd_pcib_maxfuncs
+#define pcib_maxslots _bsd_pcib_maxslots
+#define pcib_read_ivar _bsd_pcib_read_ivar
+#define pcib_release_msi _bsd_pcib_release_msi
+#define pcib_release_msix _bsd_pcib_release_msix
+#define pcib_request_feature _bsd_pcib_request_feature
+#define pcib_request_feature_allow _bsd_pcib_request_feature_allow
+#define pcib_route_interrupt _bsd_pcib_route_interrupt
+#define pcib_write_ivar _bsd_pcib_write_ivar
+#define pcibios_pcib_route_interrupt _bsd_pcibios_pcib_route_interrupt
+#define pcicdev _bsd_pcicdev
+#define pcie_adjust_config _bsd_pcie_adjust_config
+#define pcie_flr _bsd_pcie_flr
+#define pcie_get_max_completion_timeout _bsd_pcie_get_max_completion_timeout
+#define pcie_link_reset _bsd_pcie_link_reset
+#define pcie_read_config _bsd_pcie_read_config
+#define pcie_wait_for_pending_transactions _bsd_pcie_wait_for_pending_transactions
+#define pcie_write_config _bsd_pcie_write_config
+#define pcpu_entry_epair_dpcpu _bsd_pcpu_entry_epair_dpcpu
+#define pcpu_zone_64 _bsd_pcpu_zone_64
+#define pcpu_zone_int _bsd_pcpu_zone_int
+#define pcpu_zone_ptr _bsd_pcpu_zone_ptr
+#define pf_addr_cmp _bsd_pf_addr_cmp
+#define pf_addr_inc _bsd_pf_addr_inc
+#define pf_addrcpy _bsd_pf_addrcpy
+#define pf_altq_ifs_active _bsd_pf_altq_ifs_active
+#define pf_altq_ifs_inactive _bsd_pf_altq_ifs_inactive
+#define pf_altqs _bsd_pf_altqs
+#define pf_altqs_active _bsd_pf_altqs_active
+#define pf_altqs_inactive _bsd_pf_altqs_inactive
+#define pf_anchor_copyout _bsd_pf_anchor_copyout
+#define pf_anchor_global_RB_FIND _bsd_pf_anchor_global_RB_FIND
+#define pf_anchor_global_RB_INSERT _bsd_pf_anchor_global_RB_INSERT
+#define pf_anchor_global_RB_INSERT_COLOR _bsd_pf_anchor_global_RB_INSERT_COLOR
+#define pf_anchor_global_RB_MINMAX _bsd_pf_anchor_global_RB_MINMAX
+#define pf_anchor_global_RB_NEXT _bsd_pf_anchor_global_RB_NEXT
+#define pf_anchor_global_RB_NFIND _bsd_pf_anchor_global_RB_NFIND
+#define pf_anchor_global_RB_PREV _bsd_pf_anchor_global_RB_PREV
+#define pf_anchor_global_RB_REMOVE _bsd_pf_anchor_global_RB_REMOVE
+#define pf_anchor_global_RB_REMOVE_COLOR _bsd_pf_anchor_global_RB_REMOVE_COLOR
+#define pf_anchor_node_RB_FIND _bsd_pf_anchor_node_RB_FIND
+#define pf_anchor_node_RB_INSERT _bsd_pf_anchor_node_RB_INSERT
+#define pf_anchor_node_RB_INSERT_COLOR _bsd_pf_anchor_node_RB_INSERT_COLOR
+#define pf_anchor_node_RB_MINMAX _bsd_pf_anchor_node_RB_MINMAX
+#define pf_anchor_node_RB_NEXT _bsd_pf_anchor_node_RB_NEXT
+#define pf_anchor_node_RB_NFIND _bsd_pf_anchor_node_RB_NFIND
+#define pf_anchor_node_RB_PREV _bsd_pf_anchor_node_RB_PREV
+#define pf_anchor_node_RB_REMOVE _bsd_pf_anchor_node_RB_REMOVE
+#define pf_anchor_node_RB_REMOVE_COLOR _bsd_pf_anchor_node_RB_REMOVE_COLOR
+#define pf_anchor_remove _bsd_pf_anchor_remove
+#define pf_anchor_setup _bsd_pf_anchor_setup
+#define pf_anchors _bsd_pf_anchors
+#define pf_calc_skip_steps _bsd_pf_calc_skip_steps
+#define pf_change_a _bsd_pf_change_a
+#define pf_change_proto_a _bsd_pf_change_proto_a
+#define pf_cksum_fixup _bsd_pf_cksum_fixup
+#define pf_cleanup _bsd_pf_cleanup
+#define pf_default_rule _bsd_pf_default_rule
+#define pf_dev _bsd_pf_dev
+#define pf_end_lock _bsd_pf_end_lock
+#define pf_end_threads _bsd_pf_end_threads
+#define pf_find_or_create_ruleset _bsd_pf_find_or_create_ruleset
+#define pf_find_ruleset _bsd_pf_find_ruleset
+#define pf_find_src_node _bsd_pf_find_src_node
+#define pf_find_state_all _bsd_pf_find_state_all
+#define pf_find_state_byid _bsd_pf_find_state_byid
+#define pf_frag_tree_RB_FIND _bsd_pf_frag_tree_RB_FIND
+#define pf_frag_tree_RB_INSERT _bsd_pf_frag_tree_RB_INSERT
+#define pf_frag_tree_RB_MINMAX _bsd_pf_frag_tree_RB_MINMAX
+#define pf_frag_tree_RB_NEXT _bsd_pf_frag_tree_RB_NEXT
+#define pf_frag_tree_RB_NFIND _bsd_pf_frag_tree_RB_NFIND
+#define pf_frag_tree_RB_PREV _bsd_pf_frag_tree_RB_PREV
+#define pf_frag_tree_RB_REMOVE _bsd_pf_frag_tree_RB_REMOVE
+#define pf_frag_tree_RB_REMOVE_COLOR _bsd_pf_frag_tree_RB_REMOVE_COLOR
+#define pf_free_rule _bsd_pf_free_rule
+#define pf_free_src_nodes _bsd_pf_free_src_nodes
+#define pf_free_state _bsd_pf_free_state
+#define pf_frent_previous _bsd_pf_frent_previous
+#define pf_frent_remove _bsd_pf_frent_remove
+#define pf_get_mtag _bsd_pf_get_mtag
+#define pf_get_ruleset_number _bsd_pf_get_ruleset_number
+#define pf_get_translation _bsd_pf_get_translation
+#define pf_hashmask _bsd_pf_hashmask
+#define pf_hashseed _bsd_pf_hashseed
+#define pf_idhash _bsd_pf_idhash
+#define pf_init_ruleset _bsd_pf_init_ruleset
+#define pf_initialize _bsd_pf_initialize
+#define pf_intr _bsd_pf_intr
+#define pf_ioctl_lock _bsd_pf_ioctl_lock
+#define pf_ioctl_maxcount _bsd_pf_ioctl_maxcount
+#define pf_keyhash _bsd_pf_keyhash
+#define pf_limits _bsd_pf_limits
+#define pf_main_anchor _bsd_pf_main_anchor
+#define pf_map_addr _bsd_pf_map_addr
+#define pf_match_addr _bsd_pf_match_addr
+#define pf_match_addr_range _bsd_pf_match_addr_range
+#define pf_match_port _bsd_pf_match_port
+#define pf_match_tag _bsd_pf_match_tag
+#define pf_mtag_cleanup _bsd_pf_mtag_cleanup
+#define pf_mtag_initialize _bsd_pf_mtag_initialize
+#define pf_mtag_z _bsd_pf_mtag_z
+#define pf_normalize_cleanup _bsd_pf_normalize_cleanup
+#define pf_normalize_init _bsd_pf_normalize_init
+#define pf_normalize_ip _bsd_pf_normalize_ip
+#define pf_normalize_ip6 _bsd_pf_normalize_ip6
+#define pf_normalize_tcp _bsd_pf_normalize_tcp
+#define pf_normalize_tcp_cleanup _bsd_pf_normalize_tcp_cleanup
+#define pf_normalize_tcp_init _bsd_pf_normalize_tcp_init
+#define pf_normalize_tcp_stateful _bsd_pf_normalize_tcp_stateful
+#define pf_osfp_add _bsd_pf_osfp_add
+#define pf_osfp_fingerprint _bsd_pf_osfp_fingerprint
+#define pf_osfp_flush _bsd_pf_osfp_flush
+#define pf_osfp_get _bsd_pf_osfp_get
+#define pf_osfp_match _bsd_pf_osfp_match
+#define pf_pabuf _bsd_pf_pabuf
+#define pf_poolmask _bsd_pf_poolmask
+#define pf_print_flags _bsd_pf_print_flags
+#define pf_print_host _bsd_pf_print_host
+#define pf_print_state _bsd_pf_print_state
+#define pf_proto_cksum_fixup _bsd_pf_proto_cksum_fixup
+#define pf_proto_register _bsd_pf_proto_register
+#define pf_proto_unregister _bsd_pf_proto_unregister
+#define pf_pull_hdr _bsd_pf_pull_hdr
+#define pf_purge_expired_fragments _bsd_pf_purge_expired_fragments
+#define pf_purge_expired_src_nodes _bsd_pf_purge_expired_src_nodes
+#define pf_purge_fragments _bsd_pf_purge_fragments
+#define pf_purge_proc _bsd_pf_purge_proc
+#define pf_purge_thread _bsd_pf_purge_thread
+#define pf_refragment6 _bsd_pf_refragment6
+#define pf_remove_if_empty_ruleset _bsd_pf_remove_if_empty_ruleset
+#define pf_routable _bsd_pf_routable
+#define pf_rules_lock _bsd_pf_rules_lock
+#define pf_socket_lookup _bsd_pf_socket_lookup
+#define pf_srchash _bsd_pf_srchash
+#define pf_srchashmask _bsd_pf_srchashmask
+#define pf_state_expires _bsd_pf_state_expires
+#define pf_state_insert _bsd_pf_state_insert
+#define pf_state_key_clone _bsd_pf_state_key_clone
+#define pf_state_key_setup _bsd_pf_state_key_setup
+#define pf_state_key_z _bsd_pf_state_key_z
+#define pf_state_scrub_z _bsd_pf_state_scrub_z
+#define pf_state_z _bsd_pf_state_z
+#define pf_stateid _bsd_pf_stateid
+#define pf_status _bsd_pf_status
+#define pf_step_into_anchor _bsd_pf_step_into_anchor
+#define pf_step_out_of_anchor _bsd_pf_step_out_of_anchor
+#define pf_swi_cookie _bsd_pf_swi_cookie
+#define pf_tag_packet _bsd_pf_tag_packet
+#define pf_tag_z _bsd_pf_tag_z
+#define pf_tags _bsd_pf_tags
+#define pf_tcp_iss_off _bsd_pf_tcp_iss_off
+#define pf_tcp_secret _bsd_pf_tcp_secret
+#define pf_tcp_secret_ctx _bsd_pf_tcp_secret_ctx
+#define pf_tcp_secret_init _bsd_pf_tcp_secret_init
+#define pf_test _bsd_pf_test
+#define pf_test6 _bsd_pf_test6
+#define pf_unlink_src_node _bsd_pf_unlink_src_node
+#define pf_unlink_state _bsd_pf_unlink_state
+#define pf_unlinked_rules _bsd_pf_unlinked_rules
+#define pf_unlnkdrules_mtx _bsd_pf_unlnkdrules_mtx
+#define pf_unload_vnet_purge _bsd_pf_unload_vnet_purge
+#define pf_vnet_active _bsd_pf_vnet_active
+#define pfctlinput _bsd_pfctlinput
+#define pfctlinput2 _bsd_pfctlinput2
+#define pffinddomain _bsd_pffinddomain
+#define pffindproto _bsd_pffindproto
+#define pffindtype _bsd_pffindtype
+#define pfi_all _bsd_pfi_all
+#define pfi_attach_cookie _bsd_pfi_attach_cookie
+#define pfi_attach_group_cookie _bsd_pfi_attach_group_cookie
+#define pfi_change_group_cookie _bsd_pfi_change_group_cookie
+#define pfi_cleanup _bsd_pfi_cleanup
+#define pfi_cleanup_vnet _bsd_pfi_cleanup_vnet
+#define pfi_clear_flags _bsd_pfi_clear_flags
+#define pfi_detach_cookie _bsd_pfi_detach_cookie
+#define pfi_detach_group_cookie _bsd_pfi_detach_group_cookie
+#define pfi_dynaddr_copyout _bsd_pfi_dynaddr_copyout
+#define pfi_dynaddr_remove _bsd_pfi_dynaddr_remove
+#define pfi_dynaddr_setup _bsd_pfi_dynaddr_setup
+#define pfi_get_ifaces _bsd_pfi_get_ifaces
+#define pfi_ifaddr_event_cookie _bsd_pfi_ifaddr_event_cookie
+#define pfi_ifhead_RB_FIND _bsd_pfi_ifhead_RB_FIND
+#define pfi_ifhead_RB_INSERT _bsd_pfi_ifhead_RB_INSERT
+#define pfi_ifhead_RB_MINMAX _bsd_pfi_ifhead_RB_MINMAX
+#define pfi_ifhead_RB_NEXT _bsd_pfi_ifhead_RB_NEXT
+#define pfi_ifhead_RB_NFIND _bsd_pfi_ifhead_RB_NFIND
+#define pfi_ifhead_RB_PREV _bsd_pfi_ifhead_RB_PREV
+#define pfi_ifhead_RB_REMOVE _bsd_pfi_ifhead_RB_REMOVE
+#define pfi_ifhead_RB_REMOVE_COLOR _bsd_pfi_ifhead_RB_REMOVE_COLOR
+#define pfi_initialize _bsd_pfi_initialize
+#define pfi_initialize_vnet _bsd_pfi_initialize_vnet
+#define pfi_kif_attach _bsd_pfi_kif_attach
+#define pfi_kif_find _bsd_pfi_kif_find
+#define pfi_kif_match _bsd_pfi_kif_match
+#define pfi_kif_purge _bsd_pfi_kif_purge
+#define pfi_kif_ref _bsd_pfi_kif_ref
+#define pfi_kif_unref _bsd_pfi_kif_unref
+#define pfi_match_addr _bsd_pfi_match_addr
+#define pfi_set_flags _bsd_pfi_set_flags
+#define pfi_update_status _bsd_pfi_update_status
+#define pfil_add_hook _bsd_pfil_add_hook
+#define pfil_add_hook_flags _bsd_pfil_add_hook_flags
+#define pfil_head_get _bsd_pfil_head_get
+#define pfil_head_list _bsd_pfil_head_list
+#define pfil_head_register _bsd_pfil_head_register
+#define pfil_head_unregister _bsd_pfil_head_unregister
+#define pfil_link _bsd_pfil_link
+#define pfil_lock _bsd_pfil_lock
+#define pfil_realloc _bsd_pfil_realloc
+#define pfil_remove_hook _bsd_pfil_remove_hook
+#define pfil_remove_hook_flags _bsd_pfil_remove_hook_flags
+#define pfil_rlock _bsd_pfil_rlock
+#define pfil_run_hooks _bsd_pfil_run_hooks
+#define pfil_runlock _bsd_pfil_runlock
+#define pfil_wlock _bsd_pfil_wlock
+#define pfil_wowned _bsd_pfil_wowned
+#define pfil_wunlock _bsd_pfil_wunlock
+#define pfkeystat _bsd_pfkeystat
+#define pflog_packet_ptr _bsd_pflog_packet_ptr
+#define pflogifs _bsd_pflogifs
+#define pfr_add_addrs _bsd_pfr_add_addrs
+#define pfr_add_tables _bsd_pfr_add_tables
+#define pfr_attach_table _bsd_pfr_attach_table
+#define pfr_cleanup _bsd_pfr_cleanup
+#define pfr_clr_addrs _bsd_pfr_clr_addrs
+#define pfr_clr_astats _bsd_pfr_clr_astats
+#define pfr_clr_tables _bsd_pfr_clr_tables
+#define pfr_clr_tstats _bsd_pfr_clr_tstats
+#define pfr_del_addrs _bsd_pfr_del_addrs
+#define pfr_del_tables _bsd_pfr_del_tables
+#define pfr_detach_table _bsd_pfr_detach_table
+#define pfr_dynaddr_update _bsd_pfr_dynaddr_update
+#define pfr_get_addrs _bsd_pfr_get_addrs
+#define pfr_get_astats _bsd_pfr_get_astats
+#define pfr_get_tables _bsd_pfr_get_tables
+#define pfr_get_tstats _bsd_pfr_get_tstats
+#define pfr_ina_begin _bsd_pfr_ina_begin
+#define pfr_ina_commit _bsd_pfr_ina_commit
+#define pfr_ina_define _bsd_pfr_ina_define
+#define pfr_ina_rollback _bsd_pfr_ina_rollback
+#define pfr_initialize _bsd_pfr_initialize
+#define pfr_insert_kentry _bsd_pfr_insert_kentry
+#define pfr_ktablehead_RB_FIND _bsd_pfr_ktablehead_RB_FIND
+#define pfr_ktablehead_RB_INSERT _bsd_pfr_ktablehead_RB_INSERT
+#define pfr_ktablehead_RB_MINMAX _bsd_pfr_ktablehead_RB_MINMAX
+#define pfr_ktablehead_RB_NEXT _bsd_pfr_ktablehead_RB_NEXT
+#define pfr_ktablehead_RB_NFIND _bsd_pfr_ktablehead_RB_NFIND
+#define pfr_ktablehead_RB_PREV _bsd_pfr_ktablehead_RB_PREV
+#define pfr_ktablehead_RB_REMOVE _bsd_pfr_ktablehead_RB_REMOVE
+#define pfr_ktablehead_RB_REMOVE_COLOR _bsd_pfr_ktablehead_RB_REMOVE_COLOR
+#define pfr_match_addr _bsd_pfr_match_addr
+#define pfr_pool_get _bsd_pfr_pool_get
+#define pfr_set_addrs _bsd_pfr_set_addrs
+#define pfr_set_tflags _bsd_pfr_set_tflags
+#define pfr_table_count _bsd_pfr_table_count
+#define pfr_tst_addrs _bsd_pfr_tst_addrs
+#define pfr_update_stats _bsd_pfr_update_stats
+#define pfsync_clear_states_ptr _bsd_pfsync_clear_states_ptr
+#define pfsync_cloner _bsd_pfsync_cloner
+#define pfsync_defer_ptr _bsd_pfsync_defer_ptr
+#define pfsync_delete_state_ptr _bsd_pfsync_delete_state_ptr
+#define pfsync_detach_ifnet_ptr _bsd_pfsync_detach_ifnet_ptr
+#define pfsync_insert_state_ptr _bsd_pfsync_insert_state_ptr
+#define pfsync_state_export _bsd_pfsync_state_export
+#define pfsync_state_import_ptr _bsd_pfsync_state_import_ptr
+#define pfsync_update_state_ptr _bsd_pfsync_update_state_ptr
+#define pfxlist_onlink_check _bsd_pfxlist_onlink_check
+#define phashinit _bsd_phashinit
+#define phashinit_flags _bsd_phashinit_flags
+#define pick_mode_by_dotclock _bsd_pick_mode_by_dotclock
+#define pick_mode_by_ref _bsd_pick_mode_by_ref
+#define pipe_dtor _bsd_pipe_dtor
+#define pipe_named_ctor _bsd_pipe_named_ctor
+#define pipeselwakeup _bsd_pipeselwakeup
+#define pmtu_expire _bsd_pmtu_expire
+#define pmtu_probe _bsd_pmtu_probe
+#define poll_no_poll _bsd_poll_no_poll
+#define ppsratecheck _bsd_ppsratecheck
+#define printf _bsd_printf
+#define printf_uuid _bsd_printf_uuid
+#define prison0 _bsd_prison0
+#define pru_accept_notsupp _bsd_pru_accept_notsupp
+#define pru_aio_queue_notsupp _bsd_pru_aio_queue_notsupp
+#define pru_attach_notsupp _bsd_pru_attach_notsupp
+#define pru_bind_notsupp _bsd_pru_bind_notsupp
+#define pru_bindat_notsupp _bsd_pru_bindat_notsupp
+#define pru_connect2_notsupp _bsd_pru_connect2_notsupp
+#define pru_connect_notsupp _bsd_pru_connect_notsupp
+#define pru_connectat_notsupp _bsd_pru_connectat_notsupp
+#define pru_control_notsupp _bsd_pru_control_notsupp
+#define pru_disconnect_notsupp _bsd_pru_disconnect_notsupp
+#define pru_listen_notsupp _bsd_pru_listen_notsupp
+#define pru_peeraddr_notsupp _bsd_pru_peeraddr_notsupp
+#define pru_rcvd_notsupp _bsd_pru_rcvd_notsupp
+#define pru_rcvoob_notsupp _bsd_pru_rcvoob_notsupp
+#define pru_ready_notsupp _bsd_pru_ready_notsupp
+#define pru_send_notsupp _bsd_pru_send_notsupp
+#define pru_sense_null _bsd_pru_sense_null
+#define pru_shutdown_notsupp _bsd_pru_shutdown_notsupp
+#define pru_sockaddr_notsupp _bsd_pru_sockaddr_notsupp
+#define pru_sopoll_notsupp _bsd_pru_sopoll_notsupp
+#define pru_soreceive_notsupp _bsd_pru_soreceive_notsupp
+#define pru_sosend_notsupp _bsd_pru_sosend_notsupp
+#define qgroup_config _bsd_qgroup_config
+#define qgroup_softirq _bsd_qgroup_softirq
+#define r12a_beacon_init _bsd_r12a_beacon_init
+#define r12a_beacon_set_rate _bsd_r12a_beacon_set_rate
+#define r12a_c_cut_rf_read _bsd_r12a_c_cut_rf_read
+#define r12a_check_condition _bsd_r12a_check_condition
+#define r12a_check_frame_checksum _bsd_r12a_check_frame_checksum
+#define r12a_crystalcap_write _bsd_r12a_crystalcap_write
+#define r12a_detach_private _bsd_r12a_detach_private
+#define r12a_fill_tx_desc _bsd_r12a_fill_tx_desc
+#define r12a_fill_tx_desc_null _bsd_r12a_fill_tx_desc_null
+#define r12a_fill_tx_desc_raw _bsd_r12a_fill_tx_desc_raw
+#define r12a_fix_spur _bsd_r12a_fix_spur
+#define r12a_fw_download_enable _bsd_r12a_fw_download_enable
+#define r12a_fw_reset _bsd_r12a_fw_reset
+#define r12a_get_rx_stats _bsd_r12a_get_rx_stats
+#define r12a_handle_c2h_report _bsd_r12a_handle_c2h_report
+#define r12a_init_antsel _bsd_r12a_init_antsel
+#define r12a_init_bb _bsd_r12a_init_bb
+#define r12a_init_edca _bsd_r12a_init_edca
+#define r12a_init_intr _bsd_r12a_init_intr
+#define r12a_init_rf _bsd_r12a_init_rf
+#define r12a_ioctl_net _bsd_r12a_ioctl_net
+#define r12a_iq_calib _bsd_r12a_iq_calib
+#define r12a_iq_calib_fw _bsd_r12a_iq_calib_fw
+#define r12a_iq_calib_fw_supported _bsd_r12a_iq_calib_fw_supported
+#define r12a_iq_calib_sw _bsd_r12a_iq_calib_sw
+#define r12a_lc_calib _bsd_r12a_lc_calib
+#define r12a_parse_rom _bsd_r12a_parse_rom
+#define r12a_parse_rom_common _bsd_r12a_parse_rom_common
+#define r12a_power_off _bsd_r12a_power_off
+#define r12a_power_on _bsd_r12a_power_on
+#define r12a_ratectl_tx_complete _bsd_r12a_ratectl_tx_complete
+#define r12a_restore_bb_afe_vals _bsd_r12a_restore_bb_afe_vals
+#define r12a_restore_rf_vals _bsd_r12a_restore_rf_vals
+#define r12a_rf_read _bsd_r12a_rf_read
+#define r12a_rf_write _bsd_r12a_rf_write
+#define r12a_rx_radiotap_flags _bsd_r12a_rx_radiotap_flags
+#define r12a_save_bb_afe_vals _bsd_r12a_save_bb_afe_vals
+#define r12a_save_rf_vals _bsd_r12a_save_rf_vals
+#define r12a_set_band_2ghz _bsd_r12a_set_band_2ghz
+#define r12a_set_band_5ghz _bsd_r12a_set_band_5ghz
+#define r12a_set_chan _bsd_r12a_set_chan
+#define r12a_set_led _bsd_r12a_set_led
+#define r12a_set_media_status _bsd_r12a_set_media_status
+#define r12a_set_page_size _bsd_r12a_set_page_size
+#define r12a_set_pwrmode _bsd_r12a_set_pwrmode
+#define r12a_tx_radiotap_flags _bsd_r12a_tx_radiotap_flags
+#define r12a_vap_preattach _bsd_r12a_vap_preattach
+#define r12au_align_rx _bsd_r12au_align_rx
+#define r12au_attach _bsd_r12au_attach
+#define r12au_classify_intr _bsd_r12au_classify_intr
+#define r12au_dump_tx_desc _bsd_r12au_dump_tx_desc
+#define r12au_init_ampdu _bsd_r12au_init_ampdu
+#define r12au_init_ampdu_fwhw _bsd_r12au_init_ampdu_fwhw
+#define r12au_init_burstlen _bsd_r12au_init_burstlen
+#define r12au_init_burstlen_usb2 _bsd_r12au_init_burstlen_usb2
+#define r12au_init_rx_agg _bsd_r12au_init_rx_agg
+#define r12au_post_init _bsd_r12au_post_init
+#define r21a_beacon_init _bsd_r21a_beacon_init
+#define r21a_beacon_select _bsd_r21a_beacon_select
+#define r21a_check_condition _bsd_r21a_check_condition
+#define r21a_crystalcap_write _bsd_r21a_crystalcap_write
+#define r21a_fw_reset _bsd_r21a_fw_reset
+#define r21a_get_rssi_cck _bsd_r21a_get_rssi_cck
+#define r21a_init_ampdu_fwhw _bsd_r21a_init_ampdu_fwhw
+#define r21a_init_bcnq1_boundary _bsd_r21a_init_bcnq1_boundary
+#define r21a_iq_calib_fw_supported _bsd_r21a_iq_calib_fw_supported
+#define r21a_iq_calib_sw _bsd_r21a_iq_calib_sw
+#define r21a_parse_rom _bsd_r21a_parse_rom
+#define r21a_power_off _bsd_r21a_power_off
+#define r21a_power_on _bsd_r21a_power_on
+#define r21a_set_band_2ghz _bsd_r21a_set_band_2ghz
+#define r21a_set_band_5ghz _bsd_r21a_set_band_5ghz
+#define r21a_set_led _bsd_r21a_set_led
+#define r21au_attach _bsd_r21au_attach
+#define r21au_chan_check _bsd_r21au_chan_check
+#define r21au_init_tx_agg _bsd_r21au_init_tx_agg
+#define r21au_newstate _bsd_r21au_newstate
+#define r21au_scan_end _bsd_r21au_scan_end
+#define r21au_scan_start _bsd_r21au_scan_start
+#define r88e_beacon_enable _bsd_r88e_beacon_enable
+#define r88e_classify_intr _bsd_r88e_classify_intr
+#define r88e_fw_cmd _bsd_r88e_fw_cmd
+#define r88e_fw_download_enable _bsd_r88e_fw_download_enable
+#define r88e_fw_reset _bsd_r88e_fw_reset
+#define r88e_get_rssi_cck _bsd_r88e_get_rssi_cck
+#define r88e_get_rssi_ofdm _bsd_r88e_get_rssi_ofdm
+#define r88e_get_rx_stats _bsd_r88e_get_rx_stats
+#define r88e_get_txpower _bsd_r88e_get_txpower
+#define r88e_handle_c2h_report _bsd_r88e_handle_c2h_report
+#define r88e_init_bb_common _bsd_r88e_init_bb_common
+#define r88e_iq_calib _bsd_r88e_iq_calib
+#define r88e_macid_enable_link _bsd_r88e_macid_enable_link
+#define r88e_parse_rom _bsd_r88e_parse_rom
+#define r88e_ratectl_tx_complete _bsd_r88e_ratectl_tx_complete
+#define r88e_rf_write _bsd_r88e_rf_write
+#define r88e_set_bw20 _bsd_r88e_set_bw20
+#define r88e_set_gain _bsd_r88e_set_gain
+#define r88e_set_led _bsd_r88e_set_led
+#define r88e_set_media_status _bsd_r88e_set_media_status
+#define r88e_set_pwrmode _bsd_r88e_set_pwrmode
+#define r88e_set_rsvd_page _bsd_r88e_set_rsvd_page
+#define r88e_temp_measure _bsd_r88e_temp_measure
+#define r88e_temp_read _bsd_r88e_temp_read
+#define r88e_tx_enable_ampdu _bsd_r88e_tx_enable_ampdu
+#define r88e_tx_setup_hwseq _bsd_r88e_tx_setup_hwseq
+#define r88e_tx_setup_macid _bsd_r88e_tx_setup_macid
+#define r88eu_attach _bsd_r88eu_attach
+#define r88eu_classify_intr _bsd_r88eu_classify_intr
+#define r88eu_init_bb _bsd_r88eu_init_bb
+#define r88eu_init_intr _bsd_r88eu_init_intr
+#define r88eu_init_rx_agg _bsd_r88eu_init_rx_agg
+#define r88eu_post_init _bsd_r88eu_post_init
+#define r88eu_power_off _bsd_r88eu_power_off
+#define r88eu_power_on _bsd_r88eu_power_on
+#define r92c_beacon_enable _bsd_r92c_beacon_enable
+#define r92c_beacon_init _bsd_r92c_beacon_init
+#define r92c_check_condition _bsd_r92c_check_condition
+#define r92c_classify_intr _bsd_r92c_classify_intr
+#define r92c_detach_private _bsd_r92c_detach_private
+#define r92c_efuse_postread _bsd_r92c_efuse_postread
+#define r92c_fill_tx_desc _bsd_r92c_fill_tx_desc
+#define r92c_fill_tx_desc_null _bsd_r92c_fill_tx_desc_null
+#define r92c_fill_tx_desc_raw _bsd_r92c_fill_tx_desc_raw
+#define r92c_fw_download_enable _bsd_r92c_fw_download_enable
+#define r92c_fw_reset _bsd_r92c_fw_reset
+#define r92c_get_rssi_cck _bsd_r92c_get_rssi_cck
+#define r92c_get_rssi_ofdm _bsd_r92c_get_rssi_ofdm
+#define r92c_get_rx_stats _bsd_r92c_get_rx_stats
+#define r92c_get_txpower _bsd_r92c_get_txpower
+#define r92c_handle_c2h_report _bsd_r92c_handle_c2h_report
+#define r92c_init_ampdu _bsd_r92c_init_ampdu
+#define r92c_init_antsel _bsd_r92c_init_antsel
+#define r92c_init_bb_common _bsd_r92c_init_bb_common
+#define r92c_init_edca _bsd_r92c_init_edca
+#define r92c_init_rf _bsd_r92c_init_rf
+#define r92c_init_rf_chain _bsd_r92c_init_rf_chain
+#define r92c_iq_calib _bsd_r92c_iq_calib
+#define r92c_joinbss_rpt _bsd_r92c_joinbss_rpt
+#define r92c_lc_calib _bsd_r92c_lc_calib
+#define r92c_llt_init _bsd_r92c_llt_init
+#define r92c_llt_write _bsd_r92c_llt_write
+#define r92c_pa_bias_init _bsd_r92c_pa_bias_init
+#define r92c_parse_rom _bsd_r92c_parse_rom
+#define r92c_read_chipid_vendor _bsd_r92c_read_chipid_vendor
+#define r92c_rf_read _bsd_r92c_rf_read
+#define r92c_rf_write _bsd_r92c_rf_write
+#define r92c_rx_radiotap_flags _bsd_r92c_rx_radiotap_flags
+#define r92c_scan_end _bsd_r92c_scan_end
+#define r92c_scan_start _bsd_r92c_scan_start
+#define r92c_set_bw20 _bsd_r92c_set_bw20
+#define r92c_set_chan _bsd_r92c_set_chan
+#define r92c_set_gain _bsd_r92c_set_gain
+#define r92c_set_page_size _bsd_r92c_set_page_size
+#define r92c_set_pwrmode _bsd_r92c_set_pwrmode
+#define r92c_set_rssi _bsd_r92c_set_rssi
+#define r92c_set_rsvd_page _bsd_r92c_set_rsvd_page
+#define r92c_temp_measure _bsd_r92c_temp_measure
+#define r92c_temp_read _bsd_r92c_temp_read
+#define r92c_tx_enable_ampdu _bsd_r92c_tx_enable_ampdu
+#define r92c_tx_radiotap_flags _bsd_r92c_tx_radiotap_flags
+#define r92c_tx_setup_hwseq _bsd_r92c_tx_setup_hwseq
+#define r92c_tx_setup_macid _bsd_r92c_tx_setup_macid
+#define r92c_write_txpower _bsd_r92c_write_txpower
+#define r92ce_attach _bsd_r92ce_attach
+#define r92ce_copy_tx_desc _bsd_r92ce_copy_tx_desc
+#define r92ce_dump_tx_desc _bsd_r92ce_dump_tx_desc
+#define r92ce_enable_intr _bsd_r92ce_enable_intr
+#define r92ce_fw_reset _bsd_r92ce_fw_reset
+#define r92ce_get_intr_status _bsd_r92ce_get_intr_status
+#define r92ce_init_ampdu _bsd_r92ce_init_ampdu
+#define r92ce_init_bb _bsd_r92ce_init_bb
+#define r92ce_init_edca _bsd_r92ce_init_edca
+#define r92ce_init_intr _bsd_r92ce_init_intr
+#define r92ce_iq_calib _bsd_r92ce_iq_calib
+#define r92ce_post_init _bsd_r92ce_post_init
+#define r92ce_power_off _bsd_r92ce_power_off
+#define r92ce_power_on _bsd_r92ce_power_on
+#define r92ce_set_led _bsd_r92ce_set_led
+#define r92ce_setup_tx_desc _bsd_r92ce_setup_tx_desc
+#define r92ce_start_xfers _bsd_r92ce_start_xfers
+#define r92ce_tx_postsetup _bsd_r92ce_tx_postsetup
+#define r92cu_align_rx _bsd_r92cu_align_rx
+#define r92cu_attach _bsd_r92cu_attach
+#define r92cu_dump_tx_desc _bsd_r92cu_dump_tx_desc
+#define r92cu_init_bb _bsd_r92cu_init_bb
+#define r92cu_init_intr _bsd_r92cu_init_intr
+#define r92cu_init_rx_agg _bsd_r92cu_init_rx_agg
+#define r92cu_init_tx_agg _bsd_r92cu_init_tx_agg
+#define r92cu_post_init _bsd_r92cu_post_init
+#define r92cu_power_off _bsd_r92cu_power_off
+#define r92cu_power_on _bsd_r92cu_power_on
+#define r92cu_set_led _bsd_r92cu_set_led
+#define r92e_detach_private _bsd_r92e_detach_private
+#define r92e_fw_reset _bsd_r92e_fw_reset
+#define r92e_get_rssi_cck _bsd_r92e_get_rssi_cck
+#define r92e_handle_c2h_report _bsd_r92e_handle_c2h_report
+#define r92e_init_bb _bsd_r92e_init_bb
+#define r92e_init_rf _bsd_r92e_init_rf
+#define r92e_llt_init _bsd_r92e_llt_init
+#define r92e_parse_rom _bsd_r92e_parse_rom
+#define r92e_power_off _bsd_r92e_power_off
+#define r92e_power_on _bsd_r92e_power_on
+#define r92e_rf_read _bsd_r92e_rf_read
+#define r92e_rf_write _bsd_r92e_rf_write
+#define r92e_set_chan _bsd_r92e_set_chan
+#define r92e_set_led _bsd_r92e_set_led
+#define r92e_set_media_status _bsd_r92e_set_media_status
+#define r92e_set_pwrmode _bsd_r92e_set_pwrmode
+#define r92eu_attach _bsd_r92eu_attach
+#define r92eu_init_rx_agg _bsd_r92eu_init_rx_agg
+#define r92eu_post_init _bsd_r92eu_post_init
+#define ratecheck _bsd_ratecheck
+#define raw_attach _bsd_raw_attach
+#define raw_ctlinput _bsd_raw_ctlinput
+#define raw_detach _bsd_raw_detach
+#define raw_init _bsd_raw_init
+#define raw_input _bsd_raw_input
+#define raw_input_ext _bsd_raw_input_ext
+#define raw_usrreqs _bsd_raw_usrreqs
+#define rawcb_list _bsd_rawcb_list
+#define rawcb_mtx _bsd_rawcb_mtx
+#define rc4_crypt _bsd_rc4_crypt
+#define rc4_init _bsd_rc4_init
+#define read_dsfield _bsd_read_dsfield
+#define read_machclk _bsd_read_machclk
+#define refcount_release_last _bsd_refcount_release_last
+#define refcount_sleep _bsd_refcount_sleep
+#define register_tcp_functions _bsd_register_tcp_functions
+#define register_tcp_functions_as_name _bsd_register_tcp_functions_as_name
+#define register_tcp_functions_as_names _bsd_register_tcp_functions_as_names
+#define registered_toedevs _bsd_registered_toedevs
+#define resource_disabled _bsd_resource_disabled
+#define resource_find_match _bsd_resource_find_match
+#define resource_int_value _bsd_resource_int_value
+#define resource_list_add _bsd_resource_list_add
+#define resource_list_add_next _bsd_resource_list_add_next
+#define resource_list_alloc _bsd_resource_list_alloc
+#define resource_list_busy _bsd_resource_list_busy
+#define resource_list_delete _bsd_resource_list_delete
+#define resource_list_find _bsd_resource_list_find
+#define resource_list_free _bsd_resource_list_free
+#define resource_list_init _bsd_resource_list_init
+#define resource_list_print_type _bsd_resource_list_print_type
+#define resource_list_purge _bsd_resource_list_purge
+#define resource_list_release _bsd_resource_list_release
+#define resource_list_release_active _bsd_resource_list_release_active
+#define resource_list_reserve _bsd_resource_list_reserve
+#define resource_list_reserved _bsd_resource_list_reserved
+#define resource_list_unreserve _bsd_resource_list_unreserve
+#define resource_string_value _bsd_resource_string_value
+#define resource_unset_value _bsd_resource_unset_value
+#define rib_free_info _bsd_rib_free_info
+#define rib_lookup_info _bsd_rib_lookup_info
+#define rijndaelDecrypt _bsd_rijndaelDecrypt
+#define rijndaelEncrypt _bsd_rijndaelEncrypt
+#define rijndaelKeySetupDec _bsd_rijndaelKeySetupDec
+#define rijndaelKeySetupEnc _bsd_rijndaelKeySetupEnc
+#define rijndael_blockDecrypt _bsd_rijndael_blockDecrypt
+#define rijndael_blockEncrypt _bsd_rijndael_blockEncrypt
+#define rijndael_cipherInit _bsd_rijndael_cipherInit
+#define rijndael_decrypt _bsd_rijndael_decrypt
+#define rijndael_encrypt _bsd_rijndael_encrypt
+#define rijndael_makeKey _bsd_rijndael_makeKey
+#define rijndael_padDecrypt _bsd_rijndael_padDecrypt
+#define rijndael_padEncrypt _bsd_rijndael_padEncrypt
+#define rijndael_set_key _bsd_rijndael_set_key
+#define rip6_ctlinput _bsd_rip6_ctlinput
+#define rip6_ctloutput _bsd_rip6_ctloutput
+#define rip6_input _bsd_rip6_input
+#define rip6_output _bsd_rip6_output
+#define rip6_usrreqs _bsd_rip6_usrreqs
+#define rip6stat _bsd_rip6stat
+#define rip_ctlinput _bsd_rip_ctlinput
+#define rip_ctloutput _bsd_rip_ctloutput
+#define rip_init _bsd_rip_init
+#define rip_input _bsd_rip_input
+#define rip_output _bsd_rip_output
+#define rip_recvspace _bsd_rip_recvspace
+#define rip_sendspace _bsd_rip_sendspace
+#define rip_usrreqs _bsd_rip_usrreqs
+#define ripcb _bsd_ripcb
+#define ripcbinfo _bsd_ripcbinfo
+#define rman_activate_resource _bsd_rman_activate_resource
+#define rman_adjust_resource _bsd_rman_adjust_resource
+#define rman_deactivate_resource _bsd_rman_deactivate_resource
+#define rman_fini _bsd_rman_fini
+#define rman_first_free_region _bsd_rman_first_free_region
+#define rman_get_bushandle _bsd_rman_get_bushandle
+#define rman_get_bustag _bsd_rman_get_bustag
+#define rman_get_device _bsd_rman_get_device
+#define rman_get_end _bsd_rman_get_end
+#define rman_get_flags _bsd_rman_get_flags
+#define rman_get_irq_cookie _bsd_rman_get_irq_cookie
+#define rman_get_mapping _bsd_rman_get_mapping
+#define rman_get_rid _bsd_rman_get_rid
+#define rman_get_size _bsd_rman_get_size
+#define rman_get_start _bsd_rman_get_start
+#define rman_get_virtual _bsd_rman_get_virtual
+#define rman_head _bsd_rman_head
+#define rman_init _bsd_rman_init
+#define rman_init_from_resource _bsd_rman_init_from_resource
+#define rman_is_region_manager _bsd_rman_is_region_manager
+#define rman_last_free_region _bsd_rman_last_free_region
+#define rman_make_alignment_flags _bsd_rman_make_alignment_flags
+#define rman_manage_region _bsd_rman_manage_region
+#define rman_release_resource _bsd_rman_release_resource
+#define rman_reserve_resource _bsd_rman_reserve_resource
+#define rman_reserve_resource_bound _bsd_rman_reserve_resource_bound
+#define rman_set_bushandle _bsd_rman_set_bushandle
+#define rman_set_bustag _bsd_rman_set_bustag
+#define rman_set_device _bsd_rman_set_device
+#define rman_set_end _bsd_rman_set_end
+#define rman_set_irq_cookie _bsd_rman_set_irq_cookie
+#define rman_set_mapping _bsd_rman_set_mapping
+#define rman_set_rid _bsd_rman_set_rid
+#define rman_set_start _bsd_rman_set_start
+#define rman_set_virtual _bsd_rman_set_virtual
+#define rn4_mpath_inithead _bsd_rn4_mpath_inithead
+#define rn6_mpath_inithead _bsd_rn6_mpath_inithead
+#define rn_addroute _bsd_rn_addroute
+#define rn_delete _bsd_rn_delete
+#define rn_detachhead _bsd_rn_detachhead
+#define rn_inithead _bsd_rn_inithead
+#define rn_inithead_internal _bsd_rn_inithead_internal
+#define rn_lookup _bsd_rn_lookup
+#define rn_match _bsd_rn_match
+#define rn_mpath_capable _bsd_rn_mpath_capable
+#define rn_mpath_count _bsd_rn_mpath_count
+#define rn_mpath_next _bsd_rn_mpath_next
+#define rn_refines _bsd_rn_refines
+#define rn_walktree _bsd_rn_walktree
+#define rn_walktree_from _bsd_rn_walktree_from
+#define root_bus _bsd_root_bus
+#define root_bus_configure _bsd_root_bus_configure
+#define root_devclass _bsd_root_devclass
+#define route6_input _bsd_route6_input
+#define rsvp_input _bsd_rsvp_input
+#define rsvp_input_p _bsd_rsvp_input_p
+#define rsvp_on _bsd_rsvp_on
+#define rt3070_freqs _bsd_rt3070_freqs
+#define rt6_flush _bsd_rt6_flush
+#define rt_add_addr_allfibs _bsd_rt_add_addr_allfibs
+#define rt_addrmsg _bsd_rt_addrmsg
+#define rt_flushifroutes _bsd_rt_flushifroutes
+#define rt_flushifroutes_af _bsd_rt_flushifroutes_af
+#define rt_foreach_fib_walk _bsd_rt_foreach_fib_walk
+#define rt_foreach_fib_walk_del _bsd_rt_foreach_fib_walk_del
+#define rt_getifa_fib _bsd_rt_getifa_fib
+#define rt_ieee80211msg _bsd_rt_ieee80211msg
+#define rt_ifannouncemsg _bsd_rt_ifannouncemsg
+#define rt_ifmsg _bsd_rt_ifmsg
+#define rt_maskedcopy _bsd_rt_maskedcopy
+#define rt_missmsg _bsd_rt_missmsg
+#define rt_missmsg_fib _bsd_rt_missmsg_fib
+#define rt_mpath_capable _bsd_rt_mpath_capable
+#define rt_mpath_conflict _bsd_rt_mpath_conflict
+#define rt_mpath_deldup _bsd_rt_mpath_deldup
+#define rt_mpath_matchgate _bsd_rt_mpath_matchgate
+#define rt_mpath_select _bsd_rt_mpath_select
+#define rt_newaddrmsg _bsd_rt_newaddrmsg
+#define rt_newaddrmsg_fib _bsd_rt_newaddrmsg_fib
+#define rt_newmaddrmsg _bsd_rt_newmaddrmsg
+#define rt_numfibs _bsd_rt_numfibs
+#define rt_routemsg _bsd_rt_routemsg
+#define rt_setgate _bsd_rt_setgate
+#define rt_table_destroy _bsd_rt_table_destroy
+#define rt_table_init _bsd_rt_table_init
+#define rt_tables _bsd_rt_tables
+#define rt_tables_get_gen _bsd_rt_tables_get_gen
+#define rt_tables_get_rnh _bsd_rt_tables_get_rnh
+#define rt_updatemtu _bsd_rt_updatemtu
+#define rtalloc1 _bsd_rtalloc1
+#define rtalloc1_fib _bsd_rtalloc1_fib
+#define rtalloc_ign_fib _bsd_rtalloc_ign_fib
+#define rtalloc_mpath_fib _bsd_rtalloc_mpath_fib
+#define rtfree _bsd_rtfree
+#define rtinit _bsd_rtinit
+#define rtioctl_fib _bsd_rtioctl_fib
+#define rto_logging _bsd_rto_logging
+#define rtredirect_fib _bsd_rtredirect_fib
+#define rtrequest1_fib _bsd_rtrequest1_fib
+#define rtrequest_fib _bsd_rtrequest_fib
+#define rtsock_addrmsg _bsd_rtsock_addrmsg
+#define rtsock_mtx _bsd_rtsock_mtx
+#define rtsock_routemsg _bsd_rtsock_routemsg
+#define rtstat _bsd_rtstat
+#define rttrash _bsd_rttrash
+#define rtwn_adhoc_recv_mgmt _bsd_rtwn_adhoc_recv_mgmt
+#define rtwn_attach _bsd_rtwn_attach
+#define rtwn_bulk_rx_callback _bsd_rtwn_bulk_rx_callback
+#define rtwn_bulk_tx_callback _bsd_rtwn_bulk_tx_callback
+#define rtwn_calib_to _bsd_rtwn_calib_to
+#define rtwn_cmd_sleepable _bsd_rtwn_cmd_sleepable
+#define rtwn_cmdq_destroy _bsd_rtwn_cmdq_destroy
+#define rtwn_cmdq_init _bsd_rtwn_cmdq_init
+#define rtwn_detach _bsd_rtwn_detach
+#define rtwn_drain_mbufq _bsd_rtwn_drain_mbufq
+#define rtwn_efuse_read_next _bsd_rtwn_efuse_read_next
+#define rtwn_get_rates _bsd_rtwn_get_rates
+#define rtwn_init_cam _bsd_rtwn_init_cam
+#define rtwn_init_seccfg _bsd_rtwn_init_seccfg
+#define rtwn_init_static_keys _bsd_rtwn_init_static_keys
+#define rtwn_key_alloc _bsd_rtwn_key_alloc
+#define rtwn_key_delete _bsd_rtwn_key_delete
+#define rtwn_key_set _bsd_rtwn_key_set
+#define rtwn_load_firmware _bsd_rtwn_load_firmware
+#define rtwn_pci_delay _bsd_rtwn_pci_delay
+#define rtwn_pci_dma_map_addr _bsd_rtwn_pci_dma_map_addr
+#define rtwn_pci_intr _bsd_rtwn_pci_intr
+#define rtwn_pci_read_1 _bsd_rtwn_pci_read_1
+#define rtwn_pci_read_2 _bsd_rtwn_pci_read_2
+#define rtwn_pci_read_4 _bsd_rtwn_pci_read_4
+#define rtwn_pci_setup_rx_desc _bsd_rtwn_pci_setup_rx_desc
+#define rtwn_pci_tx_start _bsd_rtwn_pci_tx_start
+#define rtwn_pci_write_1 _bsd_rtwn_pci_write_1
+#define rtwn_pci_write_2 _bsd_rtwn_pci_write_2
+#define rtwn_pci_write_4 _bsd_rtwn_pci_write_4
+#define rtwn_raw_xmit _bsd_rtwn_raw_xmit
+#define rtwn_read_rom _bsd_rtwn_read_rom
+#define rtwn_resume _bsd_rtwn_resume
+#define rtwn_rx_common _bsd_rtwn_rx_common
+#define rtwn_rxfilter_init _bsd_rtwn_rxfilter_init
+#define rtwn_rxfilter_set _bsd_rtwn_rxfilter_set
+#define rtwn_rxfilter_update _bsd_rtwn_rxfilter_update
+#define rtwn_set_basicrates _bsd_rtwn_set_basicrates
+#define rtwn_set_multi _bsd_rtwn_set_multi
+#define rtwn_set_promisc _bsd_rtwn_set_promisc
+#define rtwn_set_rx_bssid_all _bsd_rtwn_set_rx_bssid_all
+#define rtwn_setup_beacon _bsd_rtwn_setup_beacon
+#define rtwn_start _bsd_rtwn_start
+#define rtwn_suspend _bsd_rtwn_suspend
+#define rtwn_switch_bcnq _bsd_rtwn_switch_bcnq
+#define rtwn_sysctlattach _bsd_rtwn_sysctlattach
+#define rtwn_transmit _bsd_rtwn_transmit
+#define rtwn_tx_beacon_check _bsd_rtwn_tx_beacon_check
+#define rtwn_tx_beacon_csa _bsd_rtwn_tx_beacon_csa
+#define rtwn_update_beacon _bsd_rtwn_update_beacon
+#define rtwn_usb_delay _bsd_rtwn_usb_delay
+#define rtwn_usb_get_qmap _bsd_rtwn_usb_get_qmap
+#define rtwn_usb_read_1 _bsd_rtwn_usb_read_1
+#define rtwn_usb_read_2 _bsd_rtwn_usb_read_2
+#define rtwn_usb_read_4 _bsd_rtwn_usb_read_4
+#define rtwn_usb_setup_endpoints _bsd_rtwn_usb_setup_endpoints
+#define rtwn_usb_tx_start _bsd_rtwn_usb_tx_start
+#define rtwn_usb_write_1 _bsd_rtwn_usb_write_1
+#define rtwn_usb_write_2 _bsd_rtwn_usb_write_2
+#define rtwn_usb_write_4 _bsd_rtwn_usb_write_4
+#define rtwn_usb_write_region_1 _bsd_rtwn_usb_write_region_1
+#define run_debug _bsd_run_debug
+#define rw_destroy _bsd_rw_destroy
+#define rw_init_flags _bsd_rw_init_flags
+#define rw_sysinit _bsd_rw_sysinit
+#define rw_wowned _bsd_rw_wowned
+#define sa6_any _bsd_sa6_any
+#define sa6_checkzone _bsd_sa6_checkzone
+#define sa6_checkzone_ifp _bsd_sa6_checkzone_ifp
+#define sa6_embedscope _bsd_sa6_embedscope
+#define sa6_recoverscope _bsd_sa6_recoverscope
+#define sack_array _bsd_sack_array
+#define sack_hole_zone _bsd_sack_hole_zone
+#define saf1761_otg_filter_interrupt _bsd_saf1761_otg_filter_interrupt
+#define saf1761_otg_init _bsd_saf1761_otg_init
+#define saf1761_otg_interrupt _bsd_saf1761_otg_interrupt
+#define saf1761_otg_uninit _bsd_saf1761_otg_uninit
+#define sb_max _bsd_sb_max
+#define sb_max_adj _bsd_sb_max_adj
+#define sballoc _bsd_sballoc
+#define sbappend _bsd_sbappend
+#define sbappend_locked _bsd_sbappend_locked
+#define sbappendaddr _bsd_sbappendaddr
+#define sbappendaddr_locked _bsd_sbappendaddr_locked
+#define sbappendaddr_nospacecheck_locked _bsd_sbappendaddr_nospacecheck_locked
+#define sbappendcontrol _bsd_sbappendcontrol
+#define sbappendcontrol_locked _bsd_sbappendcontrol_locked
+#define sbappendrecord _bsd_sbappendrecord
+#define sbappendrecord_locked _bsd_sbappendrecord_locked
+#define sbappendstream _bsd_sbappendstream
+#define sbappendstream_locked _bsd_sbappendstream_locked
+#define sbcompress _bsd_sbcompress
+#define sbcreatecontrol _bsd_sbcreatecontrol
+#define sbcut_locked _bsd_sbcut_locked
+#define sbdestroy _bsd_sbdestroy
+#define sbdrop _bsd_sbdrop
+#define sbdrop_locked _bsd_sbdrop_locked
+#define sbdroprecord _bsd_sbdroprecord
+#define sbdroprecord_locked _bsd_sbdroprecord_locked
+#define sbflush _bsd_sbflush
+#define sbflush_locked _bsd_sbflush_locked
+#define sbfree _bsd_sbfree
+#define sblock _bsd_sblock
+#define sbready _bsd_sbready
+#define sbrelease _bsd_sbrelease
+#define sbrelease_internal _bsd_sbrelease_internal
+#define sbrelease_locked _bsd_sbrelease_locked
+#define sbreserve_locked _bsd_sbreserve_locked
+#define sbsetopt _bsd_sbsetopt
+#define sbsndmbuf _bsd_sbsndmbuf
+#define sbsndptr _bsd_sbsndptr
+#define sbsndptr_adv _bsd_sbsndptr_adv
+#define sbsndptr_noadv _bsd_sbsndptr_noadv
+#define sbt_tickthreshold _bsd_sbt_tickthreshold
+#define sbt_timethreshold _bsd_sbt_timethreshold
+#define sbtoxsockbuf _bsd_sbtoxsockbuf
+#define sbuf_bcat _bsd_sbuf_bcat
+#define sbuf_bcopyin _bsd_sbuf_bcopyin
+#define sbuf_bcpy _bsd_sbuf_bcpy
+#define sbuf_cat _bsd_sbuf_cat
+#define sbuf_clear _bsd_sbuf_clear
+#define sbuf_clear_flags _bsd_sbuf_clear_flags
+#define sbuf_copyin _bsd_sbuf_copyin
+#define sbuf_count_drain _bsd_sbuf_count_drain
+#define sbuf_cpy _bsd_sbuf_cpy
+#define sbuf_data _bsd_sbuf_data
+#define sbuf_delete _bsd_sbuf_delete
+#define sbuf_done _bsd_sbuf_done
+#define sbuf_end_section _bsd_sbuf_end_section
+#define sbuf_error _bsd_sbuf_error
+#define sbuf_finish _bsd_sbuf_finish
+#define sbuf_get_flags _bsd_sbuf_get_flags
+#define sbuf_hexdump _bsd_sbuf_hexdump
+#define sbuf_len _bsd_sbuf_len
+#define sbuf_new _bsd_sbuf_new
+#define sbuf_new_for_sysctl _bsd_sbuf_new_for_sysctl
+#define sbuf_nl_terminate _bsd_sbuf_nl_terminate
+#define sbuf_printf _bsd_sbuf_printf
+#define sbuf_printf_drain _bsd_sbuf_printf_drain
+#define sbuf_printf_uuid _bsd_sbuf_printf_uuid
+#define sbuf_putbuf _bsd_sbuf_putbuf
+#define sbuf_putc _bsd_sbuf_putc
+#define sbuf_set_drain _bsd_sbuf_set_drain
+#define sbuf_set_flags _bsd_sbuf_set_flags
+#define sbuf_setpos _bsd_sbuf_setpos
+#define sbuf_start_section _bsd_sbuf_start_section
+#define sbuf_trim _bsd_sbuf_trim
+#define sbuf_uionew _bsd_sbuf_uionew
+#define sbuf_vprintf _bsd_sbuf_vprintf
+#define sbunlock _bsd_sbunlock
+#define sbwait _bsd_sbwait
+#define scope6_addr2default _bsd_scope6_addr2default
+#define scope6_get_default _bsd_scope6_get_default
+#define scope6_ifattach _bsd_scope6_ifattach
+#define scope6_ifdetach _bsd_scope6_ifdetach
+#define scope6_init _bsd_scope6_init
+#define scope6_ioctl _bsd_scope6_ioctl
+#define scope6_setdefault _bsd_scope6_setdefault
+#define scsi_attrib_ascii_sbuf _bsd_scsi_attrib_ascii_sbuf
+#define scsi_attrib_hexdump_sbuf _bsd_scsi_attrib_hexdump_sbuf
+#define scsi_attrib_int_sbuf _bsd_scsi_attrib_int_sbuf
+#define scsi_attrib_prefix_sbuf _bsd_scsi_attrib_prefix_sbuf
+#define scsi_attrib_sbuf _bsd_scsi_attrib_sbuf
+#define scsi_attrib_text_sbuf _bsd_scsi_attrib_text_sbuf
+#define scsi_attrib_value_sbuf _bsd_scsi_attrib_value_sbuf
+#define scsi_attrib_vendser_sbuf _bsd_scsi_attrib_vendser_sbuf
+#define scsi_attrib_volcoh_sbuf _bsd_scsi_attrib_volcoh_sbuf
+#define scsi_devid_is_lun_eui64 _bsd_scsi_devid_is_lun_eui64
+#define scsi_devid_is_lun_md5 _bsd_scsi_devid_is_lun_md5
+#define scsi_devid_is_lun_naa _bsd_scsi_devid_is_lun_naa
+#define scsi_devid_is_lun_name _bsd_scsi_devid_is_lun_name
+#define scsi_devid_is_lun_t10 _bsd_scsi_devid_is_lun_t10
+#define scsi_devid_is_lun_uuid _bsd_scsi_devid_is_lun_uuid
+#define scsi_devid_is_naa_ieee_reg _bsd_scsi_devid_is_naa_ieee_reg
+#define scsi_devid_is_port_naa _bsd_scsi_devid_is_port_naa
+#define scsi_devid_is_sas_target _bsd_scsi_devid_is_sas_target
+#define scsi_extract_sense_len _bsd_scsi_extract_sense_len
+#define scsi_find_attrib_entry _bsd_scsi_find_attrib_entry
+#define scsi_get_attrib_entry _bsd_scsi_get_attrib_entry
+#define scsi_get_devid _bsd_scsi_get_devid
+#define scsi_get_devid_desc _bsd_scsi_get_devid_desc
+#define scsi_get_nv _bsd_scsi_get_nv
+#define scsi_get_sense_key _bsd_scsi_get_sense_key
+#define scsi_inquiry _bsd_scsi_inquiry
+#define scsi_log_select _bsd_scsi_log_select
+#define scsi_log_sense _bsd_scsi_log_sense
+#define scsi_mam_attr_table _bsd_scsi_mam_attr_table
+#define scsi_mode_select _bsd_scsi_mode_select
+#define scsi_mode_select_len _bsd_scsi_mode_select_len
+#define scsi_mode_sense _bsd_scsi_mode_sense
+#define scsi_mode_sense_len _bsd_scsi_mode_sense_len
+#define scsi_mode_sense_subpage _bsd_scsi_mode_sense_subpage
+#define scsi_nv_to_str _bsd_scsi_nv_to_str
+#define scsi_parse_transportid _bsd_scsi_parse_transportid
+#define scsi_parse_transportid_64bit _bsd_scsi_parse_transportid_64bit
+#define scsi_parse_transportid_iscsi _bsd_scsi_parse_transportid_iscsi
+#define scsi_parse_transportid_rdma _bsd_scsi_parse_transportid_rdma
+#define scsi_parse_transportid_sop _bsd_scsi_parse_transportid_sop
+#define scsi_parse_transportid_spi _bsd_scsi_parse_transportid_spi
+#define scsi_prevent _bsd_scsi_prevent
+#define scsi_print_inquiry _bsd_scsi_print_inquiry
+#define scsi_print_inquiry_sbuf _bsd_scsi_print_inquiry_sbuf
+#define scsi_print_inquiry_short _bsd_scsi_print_inquiry_short
+#define scsi_print_inquiry_short_sbuf _bsd_scsi_print_inquiry_short_sbuf
+#define scsi_proto_map _bsd_scsi_proto_map
+#define scsi_read_capacity _bsd_scsi_read_capacity
+#define scsi_read_write _bsd_scsi_read_write
+#define scsi_request_sense _bsd_scsi_request_sense
+#define scsi_set_sense_data _bsd_scsi_set_sense_data
+#define scsi_set_sense_data_len _bsd_scsi_set_sense_data_len
+#define scsi_set_sense_data_va _bsd_scsi_set_sense_data_va
+#define scsi_test_unit_ready _bsd_scsi_test_unit_ready
+#define scsi_transportid_sbuf _bsd_scsi_transportid_sbuf
+#define scsi_write_same _bsd_scsi_write_same
+#define sctp6_ctlinput _bsd_sctp6_ctlinput
+#define sctp6_input _bsd_sctp6_input
+#define sctp6_input_with_port _bsd_sctp6_input_with_port
+#define sctp6_notify _bsd_sctp6_notify
+#define sctp6_usrreqs _bsd_sctp6_usrreqs
+#define sctp_CheckTimers _bsd_sctp_CheckTimers
+#define sctp_abort_an_association _bsd_sctp_abort_an_association
+#define sctp_abort_association _bsd_sctp_abort_association
+#define sctp_abort_notification _bsd_sctp_abort_notification
+#define sctp_accept _bsd_sctp_accept
+#define sctp_add_addr_to_vrf _bsd_sctp_add_addr_to_vrf
+#define sctp_add_addresses_to_i_ia _bsd_sctp_add_addresses_to_i_ia
+#define sctp_add_auth_chunk _bsd_sctp_add_auth_chunk
+#define sctp_add_local_addr_ep _bsd_sctp_add_local_addr_ep
+#define sctp_add_local_addr_restricted _bsd_sctp_add_local_addr_restricted
+#define sctp_add_or_del_interfaces _bsd_sctp_add_or_del_interfaces
+#define sctp_add_pad_tombuf _bsd_sctp_add_pad_tombuf
+#define sctp_add_remote_addr _bsd_sctp_add_remote_addr
+#define sctp_add_stream_reset_result _bsd_sctp_add_stream_reset_result
+#define sctp_add_stream_reset_result_tsn _bsd_sctp_add_stream_reset_result_tsn
+#define sctp_add_substate _bsd_sctp_add_substate
+#define sctp_add_to_readq _bsd_sctp_add_to_readq
+#define sctp_add_vtag_to_timewait _bsd_sctp_add_vtag_to_timewait
+#define sctp_addr_change _bsd_sctp_addr_change
+#define sctp_addr_mgmt_ep_sa _bsd_sctp_addr_mgmt_ep_sa
+#define sctp_alloc_authinfo _bsd_sctp_alloc_authinfo
+#define sctp_alloc_chunklist _bsd_sctp_alloc_chunklist
+#define sctp_alloc_hmaclist _bsd_sctp_alloc_hmaclist
+#define sctp_alloc_key _bsd_sctp_alloc_key
+#define sctp_alloc_sharedkey _bsd_sctp_alloc_sharedkey
+#define sctp_allocate_vrf _bsd_sctp_allocate_vrf
+#define sctp_aloc_assoc _bsd_sctp_aloc_assoc
+#define sctp_arethere_unrecognized_parameters _bsd_sctp_arethere_unrecognized_parameters
+#define sctp_asconf_cleanup _bsd_sctp_asconf_cleanup
+#define sctp_asconf_iterator_end _bsd_sctp_asconf_iterator_end
+#define sctp_asconf_iterator_ep _bsd_sctp_asconf_iterator_ep
+#define sctp_asconf_iterator_stcb _bsd_sctp_asconf_iterator_stcb
+#define sctp_asconf_send_nat_state_update _bsd_sctp_asconf_send_nat_state_update
+#define sctp_asconf_timer _bsd_sctp_asconf_timer
+#define sctp_assoc_immediate_retrans _bsd_sctp_assoc_immediate_retrans
+#define sctp_audit_retranmission_queue _bsd_sctp_audit_retranmission_queue
+#define sctp_auth_add_chunk _bsd_sctp_auth_add_chunk
+#define sctp_auth_add_hmacid _bsd_sctp_auth_add_hmacid
+#define sctp_auth_delete_chunk _bsd_sctp_auth_delete_chunk
+#define sctp_auth_get_chklist_size _bsd_sctp_auth_get_chklist_size
+#define sctp_auth_get_cookie_params _bsd_sctp_auth_get_cookie_params
+#define sctp_auth_is_supported_hmac _bsd_sctp_auth_is_supported_hmac
+#define sctp_auth_key_acquire _bsd_sctp_auth_key_acquire
+#define sctp_auth_key_release _bsd_sctp_auth_key_release
+#define sctp_auth_setactivekey _bsd_sctp_auth_setactivekey
+#define sctp_auth_setactivekey_ep _bsd_sctp_auth_setactivekey_ep
+#define sctp_autoclose_timer _bsd_sctp_autoclose_timer
+#define sctp_bindx_add_address _bsd_sctp_bindx_add_address
+#define sctp_bindx_delete_address _bsd_sctp_bindx_delete_address
+#define sctp_build_ctl_nchunk _bsd_sctp_build_ctl_nchunk
+#define sctp_build_readq_entry _bsd_sctp_build_readq_entry
+#define sctp_calc_rwnd _bsd_sctp_calc_rwnd
+#define sctp_calculate_cksum _bsd_sctp_calculate_cksum
+#define sctp_calculate_len _bsd_sctp_calculate_len
+#define sctp_calculate_rto _bsd_sctp_calculate_rto
+#define sctp_can_peel_off _bsd_sctp_can_peel_off
+#define sctp_cc_functions _bsd_sctp_cc_functions
+#define sctp_check_address_list _bsd_sctp_check_address_list
+#define sctp_chunk_output _bsd_sctp_chunk_output
+#define sctp_clean_up_stream _bsd_sctp_clean_up_stream
+#define sctp_clear_cachedkeys _bsd_sctp_clear_cachedkeys
+#define sctp_clear_cachedkeys_ep _bsd_sctp_clear_cachedkeys_ep
+#define sctp_clear_chunklist _bsd_sctp_clear_chunklist
+#define sctp_close _bsd_sctp_close
+#define sctp_cmpaddr _bsd_sctp_cmpaddr
+#define sctp_common_input_processing _bsd_sctp_common_input_processing
+#define sctp_compose_asconf _bsd_sctp_compose_asconf
+#define sctp_compute_hashkey _bsd_sctp_compute_hashkey
+#define sctp_compute_hmac _bsd_sctp_compute_hmac
+#define sctp_compute_hmac_m _bsd_sctp_compute_hmac_m
+#define sctp_connectx_helper_add _bsd_sctp_connectx_helper_add
+#define sctp_connectx_helper_find _bsd_sctp_connectx_helper_find
+#define sctp_cookie_timer _bsd_sctp_cookie_timer
+#define sctp_copy_chunklist _bsd_sctp_copy_chunklist
+#define sctp_copy_hmaclist _bsd_sctp_copy_hmaclist
+#define sctp_copy_skeylist _bsd_sctp_copy_skeylist
+#define sctp_ctlinput _bsd_sctp_ctlinput
+#define sctp_ctloutput _bsd_sctp_ctloutput
+#define sctp_deact_sharedkey _bsd_sctp_deact_sharedkey
+#define sctp_deact_sharedkey_ep _bsd_sctp_deact_sharedkey_ep
+#define sctp_default_supported_hmaclist _bsd_sctp_default_supported_hmaclist
+#define sctp_del_addr_from_vrf _bsd_sctp_del_addr_from_vrf
+#define sctp_del_local_addr_ep _bsd_sctp_del_local_addr_ep
+#define sctp_del_local_addr_restricted _bsd_sctp_del_local_addr_restricted
+#define sctp_del_remote_addr _bsd_sctp_del_remote_addr
+#define sctp_delete_from_timewait _bsd_sctp_delete_from_timewait
+#define sctp_delete_prim_timer _bsd_sctp_delete_prim_timer
+#define sctp_delete_sharedkey _bsd_sctp_delete_sharedkey
+#define sctp_delete_sharedkey_ep _bsd_sctp_delete_sharedkey_ep
+#define sctp_destination_is_reachable _bsd_sctp_destination_is_reachable
+#define sctp_disconnect _bsd_sctp_disconnect
+#define sctp_do_peeloff _bsd_sctp_do_peeloff
+#define sctp_drain _bsd_sctp_drain
+#define sctp_dynamic_set_primary _bsd_sctp_dynamic_set_primary
+#define sctp_expand_mapping_array _bsd_sctp_expand_mapping_array
+#define sctp_express_handle_sack _bsd_sctp_express_handle_sack
+#define sctp_fill_hmac_digest_m _bsd_sctp_fill_hmac_digest_m
+#define sctp_fill_pcbinfo _bsd_sctp_fill_pcbinfo
+#define sctp_fill_random_store _bsd_sctp_fill_random_store
+#define sctp_fill_stat_log _bsd_sctp_fill_stat_log
+#define sctp_find_alternate_net _bsd_sctp_find_alternate_net
+#define sctp_find_ifa_by_addr _bsd_sctp_find_ifa_by_addr
+#define sctp_find_ifa_in_ep _bsd_sctp_find_ifa_in_ep
+#define sctp_find_ifn _bsd_sctp_find_ifn
+#define sctp_find_sharedkey _bsd_sctp_find_sharedkey
+#define sctp_find_stream_reset _bsd_sctp_find_stream_reset
+#define sctp_find_vrf _bsd_sctp_find_vrf
+#define sctp_findasoc_ep_asocid_locked _bsd_sctp_findasoc_ep_asocid_locked
+#define sctp_findassociation_addr _bsd_sctp_findassociation_addr
+#define sctp_findassociation_addr_sa _bsd_sctp_findassociation_addr_sa
+#define sctp_findassociation_ep_addr _bsd_sctp_findassociation_ep_addr
+#define sctp_findassociation_ep_asconf _bsd_sctp_findassociation_ep_asconf
+#define sctp_findassociation_ep_asocid _bsd_sctp_findassociation_ep_asocid
+#define sctp_findnet _bsd_sctp_findnet
+#define sctp_fix_ecn_echo _bsd_sctp_fix_ecn_echo
+#define sctp_flush _bsd_sctp_flush
+#define sctp_free_assoc _bsd_sctp_free_assoc
+#define sctp_free_authinfo _bsd_sctp_free_authinfo
+#define sctp_free_chunklist _bsd_sctp_free_chunklist
+#define sctp_free_hmaclist _bsd_sctp_free_hmaclist
+#define sctp_free_ifa _bsd_sctp_free_ifa
+#define sctp_free_ifn _bsd_sctp_free_ifn
+#define sctp_free_key _bsd_sctp_free_key
+#define sctp_free_sharedkey _bsd_sctp_free_sharedkey
+#define sctp_free_vrf _bsd_sctp_free_vrf
+#define sctp_gather_internal_ifa_flags _bsd_sctp_gather_internal_ifa_flags
+#define sctp_generate_cause _bsd_sctp_generate_cause
+#define sctp_generate_no_user_data_cause _bsd_sctp_generate_no_user_data_cause
+#define sctp_generate_random_key _bsd_sctp_generate_random_key
+#define sctp_get_auth_chunk_len _bsd_sctp_get_auth_chunk_len
+#define sctp_get_frag_point _bsd_sctp_get_frag_point
+#define sctp_get_hmac_digest_len _bsd_sctp_get_hmac_digest_len
+#define sctp_get_ifa_hash_val _bsd_sctp_get_ifa_hash_val
+#define sctp_get_mbuf_for_msg _bsd_sctp_get_mbuf_for_msg
+#define sctp_get_next_mtu _bsd_sctp_get_next_mtu
+#define sctp_get_next_param _bsd_sctp_get_next_param
+#define sctp_get_prev_mtu _bsd_sctp_get_prev_mtu
+#define sctp_handle_asconf _bsd_sctp_handle_asconf
+#define sctp_handle_asconf_ack _bsd_sctp_handle_asconf_ack
+#define sctp_handle_auth _bsd_sctp_handle_auth
+#define sctp_handle_forward_tsn _bsd_sctp_handle_forward_tsn
+#define sctp_handle_ootb _bsd_sctp_handle_ootb
+#define sctp_handle_sack _bsd_sctp_handle_sack
+#define sctp_hc_get_mtu _bsd_sctp_hc_get_mtu
+#define sctp_hc_set_mtu _bsd_sctp_hc_set_mtu
+#define sctp_heartbeat_timer _bsd_sctp_heartbeat_timer
+#define sctp_hmac _bsd_sctp_hmac
+#define sctp_hmac_m _bsd_sctp_hmac_m
+#define sctp_ingetaddr _bsd_sctp_ingetaddr
+#define sctp_init _bsd_sctp_init
+#define sctp_init_asoc _bsd_sctp_init_asoc
+#define sctp_init_sysctls _bsd_sctp_init_sysctls
+#define sctp_init_vrf_list _bsd_sctp_init_vrf_list
+#define sctp_initialize_auth_params _bsd_sctp_initialize_auth_params
+#define sctp_initiate_iterator _bsd_sctp_initiate_iterator
+#define sctp_inpcb_alloc _bsd_sctp_inpcb_alloc
+#define sctp_inpcb_bind _bsd_sctp_inpcb_bind
+#define sctp_inpcb_free _bsd_sctp_inpcb_free
+#define sctp_input _bsd_sctp_input
+#define sctp_input_with_port _bsd_sctp_input_with_port
+#define sctp_insert_sharedkey _bsd_sctp_insert_sharedkey
+#define sctp_is_addr_in_ep _bsd_sctp_is_addr_in_ep
+#define sctp_is_addr_pending _bsd_sctp_is_addr_pending
+#define sctp_is_addr_restricted _bsd_sctp_is_addr_restricted
+#define sctp_is_address_in_scope _bsd_sctp_is_address_in_scope
+#define sctp_is_address_on_local_host _bsd_sctp_is_address_on_local_host
+#define sctp_is_in_timewait _bsd_sctp_is_in_timewait
+#define sctp_is_same_scope _bsd_sctp_is_same_scope
+#define sctp_is_there_an_abort_here _bsd_sctp_is_there_an_abort_here
+#define sctp_is_there_unsent_data _bsd_sctp_is_there_unsent_data
+#define sctp_is_vtag_good _bsd_sctp_is_vtag_good
+#define sctp_it_ctl _bsd_sctp_it_ctl
+#define sctp_iterator_worker _bsd_sctp_iterator_worker
+#define sctp_listen _bsd_sctp_listen
+#define sctp_load_addresses_from_init _bsd_sctp_load_addresses_from_init
+#define sctp_local_addr_count _bsd_sctp_local_addr_count
+#define sctp_log_block _bsd_sctp_log_block
+#define sctp_log_closing _bsd_sctp_log_closing
+#define sctp_log_cwnd _bsd_sctp_log_cwnd
+#define sctp_log_fr _bsd_sctp_log_fr
+#define sctp_log_lock _bsd_sctp_log_lock
+#define sctp_log_map _bsd_sctp_log_map
+#define sctp_log_maxburst _bsd_sctp_log_maxburst
+#define sctp_log_nagle_event _bsd_sctp_log_nagle_event
+#define sctp_log_rwnd _bsd_sctp_log_rwnd
+#define sctp_log_rwnd_set _bsd_sctp_log_rwnd_set
+#define sctp_log_sack _bsd_sctp_log_sack
+#define sctp_log_strm_del _bsd_sctp_log_strm_del
+#define sctp_log_strm_del_alt _bsd_sctp_log_strm_del_alt
+#define sctp_lower_sosend _bsd_sctp_lower_sosend
+#define sctp_m_getptr _bsd_sctp_m_getptr
+#define sctp_map_assoc_state _bsd_sctp_map_assoc_state
+#define sctp_mark_ifa_addr_down _bsd_sctp_mark_ifa_addr_down
+#define sctp_mark_ifa_addr_up _bsd_sctp_mark_ifa_addr_up
+#define sctp_min_mtu _bsd_sctp_min_mtu
+#define sctp_misc_ints _bsd_sctp_misc_ints
+#define sctp_move_chunks_from_net _bsd_sctp_move_chunks_from_net
+#define sctp_move_pcb_and_assoc _bsd_sctp_move_pcb_and_assoc
+#define sctp_mtu_size_reset _bsd_sctp_mtu_size_reset
+#define sctp_negotiate_hmacid _bsd_sctp_negotiate_hmacid
+#define sctp_net_immediate_retrans _bsd_sctp_net_immediate_retrans
+#define sctp_notify _bsd_sctp_notify
+#define sctp_notify_authentication _bsd_sctp_notify_authentication
+#define sctp_notify_stream_reset_add _bsd_sctp_notify_stream_reset_add
+#define sctp_notify_stream_reset_tsn _bsd_sctp_notify_stream_reset_tsn
+#define sctp_output _bsd_sctp_output
+#define sctp_over_udp_start _bsd_sctp_over_udp_start
+#define sctp_over_udp_stop _bsd_sctp_over_udp_stop
+#define sctp_pack_auth_chunks _bsd_sctp_pack_auth_chunks
+#define sctp_pad_lastmbuf _bsd_sctp_pad_lastmbuf
+#define sctp_pathmtu_adjustment _bsd_sctp_pathmtu_adjustment
+#define sctp_pathmtu_timer _bsd_sctp_pathmtu_timer
+#define sctp_pcb_findep _bsd_sctp_pcb_findep
+#define sctp_pcb_finish _bsd_sctp_pcb_finish
+#define sctp_pcb_init _bsd_sctp_pcb_init
+#define sctp_peeraddr _bsd_sctp_peeraddr
+#define sctp_print_address _bsd_sctp_print_address
+#define sctp_print_key _bsd_sctp_print_key
+#define sctp_print_mapping_array _bsd_sctp_print_mapping_array
+#define sctp_process_data _bsd_sctp_process_data
+#define sctp_pull_off_control_to_new_inp _bsd_sctp_pull_off_control_to_new_inp
+#define sctp_queue_op_err _bsd_sctp_queue_op_err
+#define sctp_recover_scope _bsd_sctp_recover_scope
+#define sctp_release_pr_sctp_chunk _bsd_sctp_release_pr_sctp_chunk
+#define sctp_remove_net _bsd_sctp_remove_net
+#define sctp_report_all_outbound _bsd_sctp_report_all_outbound
+#define sctp_reset_in_stream _bsd_sctp_reset_in_stream
+#define sctp_sack_check _bsd_sctp_sack_check
+#define sctp_sblog _bsd_sctp_sblog
+#define sctp_select_a_tag _bsd_sctp_select_a_tag
+#define sctp_select_initial_TSN _bsd_sctp_select_initial_TSN
+#define sctp_send_abort _bsd_sctp_send_abort
+#define sctp_send_abort_tcb _bsd_sctp_send_abort_tcb
+#define sctp_send_asconf _bsd_sctp_send_asconf
+#define sctp_send_asconf_ack _bsd_sctp_send_asconf_ack
+#define sctp_send_cookie_ack _bsd_sctp_send_cookie_ack
+#define sctp_send_cookie_echo _bsd_sctp_send_cookie_echo
+#define sctp_send_cwr _bsd_sctp_send_cwr
+#define sctp_send_deferred_reset_response _bsd_sctp_send_deferred_reset_response
+#define sctp_send_ecn_echo _bsd_sctp_send_ecn_echo
+#define sctp_send_hb _bsd_sctp_send_hb
+#define sctp_send_heartbeat_ack _bsd_sctp_send_heartbeat_ack
+#define sctp_send_initiate _bsd_sctp_send_initiate
+#define sctp_send_initiate_ack _bsd_sctp_send_initiate_ack
+#define sctp_send_operr_to _bsd_sctp_send_operr_to
+#define sctp_send_packet_dropped _bsd_sctp_send_packet_dropped
+#define sctp_send_sack _bsd_sctp_send_sack
+#define sctp_send_shutdown _bsd_sctp_send_shutdown
+#define sctp_send_shutdown_ack _bsd_sctp_send_shutdown_ack
+#define sctp_send_shutdown_complete _bsd_sctp_send_shutdown_complete
+#define sctp_send_shutdown_complete2 _bsd_sctp_send_shutdown_complete2
+#define sctp_send_str_reset_req _bsd_sctp_send_str_reset_req
+#define sctp_send_stream_reset_out_if_possible _bsd_sctp_send_stream_reset_out_if_possible
+#define sctp_sendm _bsd_sctp_sendm
+#define sctp_serialize_auth_chunks _bsd_sctp_serialize_auth_chunks
+#define sctp_serialize_hmaclist _bsd_sctp_serialize_hmaclist
+#define sctp_set_key _bsd_sctp_set_key
+#define sctp_set_primary_addr _bsd_sctp_set_primary_addr
+#define sctp_set_primary_ip_address_sa _bsd_sctp_set_primary_ip_address_sa
+#define sctp_set_rwnd _bsd_sctp_set_rwnd
+#define sctp_set_state _bsd_sctp_set_state
+#define sctp_show_key _bsd_sctp_show_key
+#define sctp_shutdown _bsd_sctp_shutdown
+#define sctp_shutdown_timer _bsd_sctp_shutdown_timer
+#define sctp_shutdownack_timer _bsd_sctp_shutdownack_timer
+#define sctp_slide_mapping_arrays _bsd_sctp_slide_mapping_arrays
+#define sctp_soreceive _bsd_sctp_soreceive
+#define sctp_sorecvmsg _bsd_sctp_sorecvmsg
+#define sctp_sosend _bsd_sctp_sosend
+#define sctp_source_address_selection _bsd_sctp_source_address_selection
+#define sctp_startup_iterator _bsd_sctp_startup_iterator
+#define sctp_stop_timers_for_shutdown _bsd_sctp_stop_timers_for_shutdown
+#define sctp_strreset_timer _bsd_sctp_strreset_timer
+#define sctp_swap_inpcb_for_listen _bsd_sctp_swap_inpcb_for_listen
+#define sctp_t1init_timer _bsd_sctp_t1init_timer
+#define sctp_t3rxt_timer _bsd_sctp_t3rxt_timer
+#define sctp_timeout_handler _bsd_sctp_timeout_handler
+#define sctp_timer_start _bsd_sctp_timer_start
+#define sctp_timer_stop _bsd_sctp_timer_stop
+#define sctp_toss_old_asconf _bsd_sctp_toss_old_asconf
+#define sctp_toss_old_cookies _bsd_sctp_toss_old_cookies
+#define sctp_try_advance_peer_ack_point _bsd_sctp_try_advance_peer_ack_point
+#define sctp_ulp_notify _bsd_sctp_ulp_notify
+#define sctp_unpack_auth_chunks _bsd_sctp_unpack_auth_chunks
+#define sctp_update_acked _bsd_sctp_update_acked
+#define sctp_update_ifn_mtu _bsd_sctp_update_ifn_mtu
+#define sctp_usrreqs _bsd_sctp_usrreqs
+#define sctp_v4src_match_nexthop _bsd_sctp_v4src_match_nexthop
+#define sctp_v6src_match_nexthop _bsd_sctp_v6src_match_nexthop
+#define sctp_validate_init_auth_params _bsd_sctp_validate_init_auth_params
+#define sctp_verify_hmac_param _bsd_sctp_verify_hmac_param
+#define sctp_wakeup_iterator _bsd_sctp_wakeup_iterator
+#define sctp_wakeup_log _bsd_sctp_wakeup_log
+#define sctp_wakeup_the_read_socket _bsd_sctp_wakeup_the_read_socket
+#define sdhci_cleanup_slot _bsd_sdhci_cleanup_slot
+#define sdhci_fdt_gpio_get_present _bsd_sdhci_fdt_gpio_get_present
+#define sdhci_fdt_gpio_get_readonly _bsd_sdhci_fdt_gpio_get_readonly
+#define sdhci_fdt_gpio_setup _bsd_sdhci_fdt_gpio_setup
+#define sdhci_fdt_gpio_teardown _bsd_sdhci_fdt_gpio_teardown
+#define sdhci_finish_data _bsd_sdhci_finish_data
+#define sdhci_generic_acquire_host _bsd_sdhci_generic_acquire_host
+#define sdhci_generic_get_card_present _bsd_sdhci_generic_get_card_present
+#define sdhci_generic_get_ro _bsd_sdhci_generic_get_ro
+#define sdhci_generic_intr _bsd_sdhci_generic_intr
+#define sdhci_generic_min_freq _bsd_sdhci_generic_min_freq
+#define sdhci_generic_read_ivar _bsd_sdhci_generic_read_ivar
+#define sdhci_generic_release_host _bsd_sdhci_generic_release_host
+#define sdhci_generic_request _bsd_sdhci_generic_request
+#define sdhci_generic_resume _bsd_sdhci_generic_resume
+#define sdhci_generic_retune _bsd_sdhci_generic_retune
+#define sdhci_generic_set_uhs_timing _bsd_sdhci_generic_set_uhs_timing
+#define sdhci_generic_suspend _bsd_sdhci_generic_suspend
+#define sdhci_generic_switch_vccq _bsd_sdhci_generic_switch_vccq
+#define sdhci_generic_tune _bsd_sdhci_generic_tune
+#define sdhci_generic_update_ios _bsd_sdhci_generic_update_ios
+#define sdhci_generic_write_ivar _bsd_sdhci_generic_write_ivar
+#define sdhci_handle_card_present _bsd_sdhci_handle_card_present
+#define sdhci_init_slot _bsd_sdhci_init_slot
+#define sdhci_quirk_clear _bsd_sdhci_quirk_clear
+#define sdhci_quirk_set _bsd_sdhci_quirk_set
+#define sdhci_start_slot _bsd_sdhci_start_slot
+#define seldrain _bsd_seldrain
+#define selrecord _bsd_selrecord
+#define seltdfini _bsd_seltdfini
+#define selwakeup _bsd_selwakeup
+#define selwakeuppri _bsd_selwakeuppri
+#define send_forward_tsn _bsd_send_forward_tsn
+#define send_sendso_input_hook _bsd_send_sendso_input_hook
+#define sha1_init _bsd_sha1_init
+#define sha1_loop _bsd_sha1_loop
+#define sha1_pad _bsd_sha1_pad
+#define sha1_result _bsd_sha1_result
+#define simplebus_add_device _bsd_simplebus_add_device
+#define simplebus_driver _bsd_simplebus_driver
+#define simplebus_fill_ranges _bsd_simplebus_fill_ranges
+#define simplebus_init _bsd_simplebus_init
+#define simplebus_setup_dinfo _bsd_simplebus_setup_dinfo
+#define skipjack_backwards _bsd_skipjack_backwards
+#define skipjack_forwards _bsd_skipjack_forwards
+#define sl_compress_init _bsd_sl_compress_init
+#define sl_compress_tcp _bsd_sl_compress_tcp
+#define sl_uncompress_tcp _bsd_sl_uncompress_tcp
+#define sl_uncompress_tcp_core _bsd_sl_uncompress_tcp_core
+#define sleepq_add _bsd_sleepq_add
+#define sleepq_alloc _bsd_sleepq_alloc
+#define sleepq_broadcast _bsd_sleepq_broadcast
+#define sleepq_chains_remove_matching _bsd_sleepq_chains_remove_matching
+#define sleepq_free _bsd_sleepq_free
+#define sleepq_lock _bsd_sleepq_lock
+#define sleepq_lookup _bsd_sleepq_lookup
+#define sleepq_release _bsd_sleepq_release
+#define sleepq_remove _bsd_sleepq_remove
+#define sleepq_remove_matching _bsd_sleepq_remove_matching
+#define sleepq_set_timeout_sbt _bsd_sleepq_set_timeout_sbt
+#define sleepq_signal _bsd_sleepq_signal
+#define sleepq_sleepcnt _bsd_sleepq_sleepcnt
+#define sleepq_timedwait _bsd_sleepq_timedwait
+#define sleepq_type _bsd_sleepq_type
+#define sleepq_wait _bsd_sleepq_wait
+#define smc_attach _bsd_smc_attach
+#define smc_detach _bsd_smc_detach
+#define smc_devclass _bsd_smc_devclass
+#define smc_miibus_readreg _bsd_smc_miibus_readreg
+#define smc_miibus_statchg _bsd_smc_miibus_statchg
+#define smc_miibus_writereg _bsd_smc_miibus_writereg
+#define smc_probe _bsd_smc_probe
+#define snprintf _bsd_snprintf
+#define snprintf_uuid _bsd_snprintf_uuid
+#define so_error_get _bsd_so_error_get
+#define so_error_set _bsd_so_error_set
+#define so_gencnt _bsd_so_gencnt
+#define so_linger_get _bsd_so_linger_get
+#define so_linger_set _bsd_so_linger_set
+#define so_lock _bsd_so_lock
+#define so_options_get _bsd_so_options_get
+#define so_options_set _bsd_so_options_set
+#define so_protosw_get _bsd_so_protosw_get
+#define so_protosw_set _bsd_so_protosw_set
+#define so_setsockopt _bsd_so_setsockopt
+#define so_sockbuf_rcv _bsd_so_sockbuf_rcv
+#define so_sockbuf_snd _bsd_so_sockbuf_snd
+#define so_sorwakeup _bsd_so_sorwakeup
+#define so_sorwakeup_locked _bsd_so_sorwakeup_locked
+#define so_sotoinpcb _bsd_so_sotoinpcb
+#define so_sototcpcb _bsd_so_sototcpcb
+#define so_sowwakeup _bsd_so_sowwakeup
+#define so_sowwakeup_locked _bsd_so_sowwakeup_locked
+#define so_state_get _bsd_so_state_get
+#define so_state_set _bsd_so_state_set
+#define so_unlock _bsd_so_unlock
+#define soabort _bsd_soabort
+#define soaccept _bsd_soaccept
+#define sobind _bsd_sobind
+#define sobindat _bsd_sobindat
+#define socantrcvmore _bsd_socantrcvmore
+#define socantrcvmore_locked _bsd_socantrcvmore_locked
+#define socantsendmore _bsd_socantsendmore
+#define socantsendmore_locked _bsd_socantsendmore_locked
+#define socketops _bsd_socketops
+#define soclose _bsd_soclose
+#define soconnect _bsd_soconnect
+#define soconnect2 _bsd_soconnect2
+#define soconnectat _bsd_soconnectat
+#define socreate _bsd_socreate
+#define sodisconnect _bsd_sodisconnect
+#define sodium_memzero _bsd_sodium_memzero
+#define sodtor_set _bsd_sodtor_set
+#define sodupsockaddr _bsd_sodupsockaddr
+#define sofree _bsd_sofree
+#define sogetopt _bsd_sogetopt
+#define sohasoutofband _bsd_sohasoutofband
+#define soisconnected _bsd_soisconnected
+#define soisconnecting _bsd_soisconnecting
+#define soisdisconnected _bsd_soisdisconnected
+#define soisdisconnecting _bsd_soisdisconnecting
+#define solisten _bsd_solisten
+#define solisten_dequeue _bsd_solisten_dequeue
+#define solisten_proto _bsd_solisten_proto
+#define solisten_proto_check _bsd_solisten_proto_check
+#define solisten_upcall_set _bsd_solisten_upcall_set
+#define solisten_wakeup _bsd_solisten_wakeup
+#define sonewconn _bsd_sonewconn
+#define soo_close _bsd_soo_close
+#define soo_ioctl _bsd_soo_ioctl
+#define soo_poll _bsd_soo_poll
+#define soo_read _bsd_soo_read
+#define soo_write _bsd_soo_write
+#define soopt_getm _bsd_soopt_getm
+#define soopt_mcopyin _bsd_soopt_mcopyin
+#define soopt_mcopyout _bsd_soopt_mcopyout
+#define sooptcopyin _bsd_sooptcopyin
+#define sooptcopyout _bsd_sooptcopyout
+#define sopoll _bsd_sopoll
+#define sopoll_generic _bsd_sopoll_generic
+#define soreceive _bsd_soreceive
+#define soreceive_dgram _bsd_soreceive_dgram
+#define soreceive_generic _bsd_soreceive_generic
+#define soreserve _bsd_soreserve
+#define sorflush _bsd_sorflush
+#define sort_modes _bsd_sort_modes
+#define sosend _bsd_sosend
+#define sosend_dgram _bsd_sosend_dgram
+#define sosend_generic _bsd_sosend_generic
+#define sosetopt _bsd_sosetopt
+#define soshutdown _bsd_soshutdown
+#define sotoxsocket _bsd_sotoxsocket
+#define soupcall_clear _bsd_soupcall_clear
+#define soupcall_set _bsd_soupcall_set
+#define sowakeup _bsd_sowakeup
+#define sppp_attach _bsd_sppp_attach
+#define sppp_dequeue _bsd_sppp_dequeue
+#define sppp_detach _bsd_sppp_detach
+#define sppp_flush _bsd_sppp_flush
+#define sppp_fr_header _bsd_sppp_fr_header
+#define sppp_fr_input _bsd_sppp_fr_input
+#define sppp_fr_keepalive _bsd_sppp_fr_keepalive
+#define sppp_get_ip_addrs _bsd_sppp_get_ip_addrs
+#define sppp_input _bsd_sppp_input
+#define sppp_ioctl _bsd_sppp_ioctl
+#define sppp_isempty _bsd_sppp_isempty
+#define sppp_pick _bsd_sppp_pick
+#define sprintf _bsd_sprintf
+#define subkey_table_gen _bsd_subkey_table_gen
+#define swi_add _bsd_swi_add
+#define swi_sched _bsd_swi_sched
+#define sx_destroy _bsd_sx_destroy
+#define sx_downgrade_int _bsd_sx_downgrade_int
+#define sx_init_flags _bsd_sx_init_flags
+#define sx_sysinit _bsd_sx_sysinit
+#define sx_try_slock_int _bsd_sx_try_slock_int
+#define sx_try_upgrade_int _bsd_sx_try_upgrade_int
+#define sx_xlocked _bsd_sx_xlocked
+#define syncache_add _bsd_syncache_add
+#define syncache_badack _bsd_syncache_badack
+#define syncache_chkrst _bsd_syncache_chkrst
+#define syncache_expand _bsd_syncache_expand
+#define syncache_init _bsd_syncache_init
+#define syncache_pcblist _bsd_syncache_pcblist
+#define syncache_unreach _bsd_syncache_unreach
+#define sysctl___debug _bsd_sysctl___debug
+#define sysctl___dev _bsd_sysctl___dev
+#define sysctl___hw _bsd_sysctl___hw
+#define sysctl___hw_bus _bsd_sysctl___hw_bus
+#define sysctl___hw_fdt _bsd_sysctl___hw_fdt
+#define sysctl___hw_nvme _bsd_sysctl___hw_nvme
+#define sysctl___hw_pci _bsd_sysctl___hw_pci
+#define sysctl___hw_sdhci _bsd_sysctl___hw_sdhci
+#define sysctl___hw_usb _bsd_sysctl___hw_usb
+#define sysctl___hw_usb_rsu _bsd_sysctl___hw_usb_rsu
+#define sysctl___hw_usb_smsc _bsd_sysctl___hw_usb_smsc
+#define sysctl___hw_zynq _bsd_sysctl___hw_zynq
+#define sysctl___kern _bsd_sysctl___kern
+#define sysctl___kern_cam _bsd_sysctl___kern_cam
+#define sysctl___kern_evdev _bsd_sysctl___kern_evdev
+#define sysctl___kern_evdev_input _bsd_sysctl___kern_evdev_input
+#define sysctl___kern_features _bsd_sysctl___kern_features
+#define sysctl___kern_ipc _bsd_sysctl___kern_ipc
+#define sysctl___net _bsd_sysctl___net
+#define sysctl___net_accf _bsd_sysctl___net_accf
+#define sysctl___net_bpf _bsd_sysctl___net_bpf
+#define sysctl___net_bpf_jitter _bsd_sysctl___net_bpf_jitter
+#define sysctl___net_inet _bsd_sysctl___net_inet
+#define sysctl___net_inet6 _bsd_sysctl___net_inet6
+#define sysctl___net_inet6_icmp6 _bsd_sysctl___net_inet6_icmp6
+#define sysctl___net_inet6_ip6 _bsd_sysctl___net_inet6_ip6
+#define sysctl___net_inet6_ipsec6 _bsd_sysctl___net_inet6_ipsec6
+#define sysctl___net_inet6_mld _bsd_sysctl___net_inet6_mld
+#define sysctl___net_inet6_tcp6 _bsd_sysctl___net_inet6_tcp6
+#define sysctl___net_inet6_udp6 _bsd_sysctl___net_inet6_udp6
+#define sysctl___net_inet_accf _bsd_sysctl___net_inet_accf
+#define sysctl___net_inet_ah _bsd_sysctl___net_inet_ah
+#define sysctl___net_inet_carp _bsd_sysctl___net_inet_carp
+#define sysctl___net_inet_esp _bsd_sysctl___net_inet_esp
+#define sysctl___net_inet_icmp _bsd_sysctl___net_inet_icmp
+#define sysctl___net_inet_igmp _bsd_sysctl___net_inet_igmp
+#define sysctl___net_inet_ip _bsd_sysctl___net_inet_ip
+#define sysctl___net_inet_ip_alias _bsd_sysctl___net_inet_ip_alias
+#define sysctl___net_inet_ipcomp _bsd_sysctl___net_inet_ipcomp
+#define sysctl___net_inet_ipip _bsd_sysctl___net_inet_ipip
+#define sysctl___net_inet_ipsec _bsd_sysctl___net_inet_ipsec
+#define sysctl___net_inet_pim _bsd_sysctl___net_inet_pim
+#define sysctl___net_inet_raw _bsd_sysctl___net_inet_raw
+#define sysctl___net_inet_tcp _bsd_sysctl___net_inet_tcp
+#define sysctl___net_inet_tcp_cc _bsd_sysctl___net_inet_tcp_cc
+#define sysctl___net_inet_tcp_cc_newreno _bsd_sysctl___net_inet_tcp_cc_newreno
+#define sysctl___net_inet_tcp_lro _bsd_sysctl___net_inet_tcp_lro
+#define sysctl___net_inet_tcp_sack _bsd_sysctl___net_inet_tcp_sack
+#define sysctl___net_inet_udp _bsd_sysctl___net_inet_udp
+#define sysctl___net_key _bsd_sysctl___net_key
+#define sysctl___net_link _bsd_sysctl___net_link
+#define sysctl___net_link_ether _bsd_sysctl___net_link_ether
+#define sysctl___net_link_generic _bsd_sysctl___net_link_generic
+#define sysctl___net_link_lagg _bsd_sysctl___net_link_lagg
+#define sysctl___net_link_lagg_lacp _bsd_sysctl___net_link_lagg_lacp
+#define sysctl___net_pf _bsd_sysctl___net_pf
+#define sysctl___net_pfsync _bsd_sysctl___net_pfsync
+#define sysctl___net_wlan _bsd_sysctl___net_wlan
+#define sysctl___security _bsd_sysctl___security
+#define sysctl___sysctl _bsd_sysctl___sysctl
+#define sysctl___vm _bsd_sysctl___vm
+#define sysctl__children _bsd_sysctl__children
+#define sysctl_add_oid _bsd_sysctl_add_oid
+#define sysctl_chg_accept_global_ootb_addip _bsd_sysctl_chg_accept_global_ootb_addip
+#define sysctl_chg_chunk_proc_limit _bsd_sysctl_chg_chunk_proc_limit
+#define sysctl_chg_error_on_ootb _bsd_sysctl_chg_error_on_ootb
+#define sysctl_chg_hashtable_size _bsd_sysctl_chg_hashtable_size
+#define sysctl_chg_initialising_chunk_proc_limit _bsd_sysctl_chg_initialising_chunk_proc_limit
+#define sysctl_chg_loglevel _bsd_sysctl_chg_loglevel
+#define sysctl_chg_param_proc_limit _bsd_sysctl_chg_param_proc_limit
+#define sysctl_chg_timer _bsd_sysctl_chg_timer
+#define sysctl_chg_track_global_addresses _bsd_sysctl_chg_track_global_addresses
+#define sysctl_ctx_entry_add _bsd_sysctl_ctx_entry_add
+#define sysctl_ctx_entry_del _bsd_sysctl_ctx_entry_del
+#define sysctl_ctx_entry_find _bsd_sysctl_ctx_entry_find
+#define sysctl_ctx_free _bsd_sysctl_ctx_free
+#define sysctl_ctx_init _bsd_sysctl_ctx_init
+#define sysctl_enable_oid _bsd_sysctl_enable_oid
+#define sysctl_find_oid _bsd_sysctl_find_oid
+#define sysctl_handle_16 _bsd_sysctl_handle_16
+#define sysctl_handle_32 _bsd_sysctl_handle_32
+#define sysctl_handle_64 _bsd_sysctl_handle_64
+#define sysctl_handle_8 _bsd_sysctl_handle_8
+#define sysctl_handle_bool _bsd_sysctl_handle_bool
+#define sysctl_handle_counter_u64 _bsd_sysctl_handle_counter_u64
+#define sysctl_handle_counter_u64_array _bsd_sysctl_handle_counter_u64_array
+#define sysctl_handle_int _bsd_sysctl_handle_int
+#define sysctl_handle_long _bsd_sysctl_handle_long
+#define sysctl_handle_opaque _bsd_sysctl_handle_opaque
+#define sysctl_handle_string _bsd_sysctl_handle_string
+#define sysctl_handle_uma_zone_cur _bsd_sysctl_handle_uma_zone_cur
+#define sysctl_handle_uma_zone_max _bsd_sysctl_handle_uma_zone_max
+#define sysctl_move_oid _bsd_sysctl_move_oid
+#define sysctl_msec_to_sbintime _bsd_sysctl_msec_to_sbintime
+#define sysctl_msec_to_ticks _bsd_sysctl_msec_to_ticks
+#define sysctl_register_disabled_oid _bsd_sysctl_register_disabled_oid
+#define sysctl_register_oid _bsd_sysctl_register_oid
+#define sysctl_remove_name _bsd_sysctl_remove_name
+#define sysctl_remove_oid _bsd_sysctl_remove_oid
+#define sysctl_rename_oid _bsd_sysctl_rename_oid
+#define sysctl_sec_to_timeval _bsd_sysctl_sec_to_timeval
+#define sysctl_unregister_oid _bsd_sysctl_unregister_oid
+#define sysctl_usec_to_sbintime _bsd_sysctl_usec_to_sbintime
+#define sysctl_wire_old_buffer _bsd_sysctl_wire_old_buffer
+#define sysctl_wlock _bsd_sysctl_wlock
+#define sysctl_wunlock _bsd_sysctl_wunlock
+#define system_base_info _bsd_system_base_info
+#define t_functions _bsd_t_functions
+#define t_functions_inited _bsd_t_functions_inited
+#define taskqgroup_adjust _bsd_taskqgroup_adjust
+#define taskqgroup_attach _bsd_taskqgroup_attach
+#define taskqgroup_attach_cpu _bsd_taskqgroup_attach_cpu
+#define taskqgroup_config_gtask_deinit _bsd_taskqgroup_config_gtask_deinit
+#define taskqgroup_config_gtask_init _bsd_taskqgroup_config_gtask_init
+#define taskqgroup_create _bsd_taskqgroup_create
+#define taskqgroup_destroy _bsd_taskqgroup_destroy
+#define taskqgroup_detach _bsd_taskqgroup_detach
+#define tbr_dequeue_ptr _bsd_tbr_dequeue_ptr
+#define tbr_set _bsd_tbr_set
+#define tc_precexp _bsd_tc_precexp
+#define tc_tick_bt _bsd_tc_tick_bt
+#define tc_tick_sbt _bsd_tc_tick_sbt
+#define tcb _bsd_tcb
+#define tcbinfo _bsd_tcbinfo
+#define tcp6_ctlinput _bsd_tcp6_ctlinput
+#define tcp6_input _bsd_tcp6_input
+#define tcp6_usrreqs _bsd_tcp6_usrreqs
+#define tcp_abc_l_var _bsd_tcp_abc_l_var
+#define tcp_addoptions _bsd_tcp_addoptions
+#define tcp_always_keepalive _bsd_tcp_always_keepalive
+#define tcp_autorcvbuf _bsd_tcp_autorcvbuf
+#define tcp_autorcvbuf_inc _bsd_tcp_autorcvbuf_inc
+#define tcp_autorcvbuf_max _bsd_tcp_autorcvbuf_max
+#define tcp_autosndbuf_inc _bsd_tcp_autosndbuf_inc
+#define tcp_autosndbuf_max _bsd_tcp_autosndbuf_max
+#define tcp_backoff _bsd_tcp_backoff
+#define tcp_ccalgounload _bsd_tcp_ccalgounload
+#define tcp_clean_dsack_blocks _bsd_tcp_clean_dsack_blocks
+#define tcp_clean_sackreport _bsd_tcp_clean_sackreport
+#define tcp_close _bsd_tcp_close
+#define tcp_compute_initwnd _bsd_tcp_compute_initwnd
+#define tcp_compute_pipe _bsd_tcp_compute_pipe
+#define tcp_ctlinput _bsd_tcp_ctlinput
+#define tcp_ctloutput _bsd_tcp_ctloutput
+#define tcp_debug_mtx _bsd_tcp_debug_mtx
+#define tcp_default_ctloutput _bsd_tcp_default_ctloutput
+#define tcp_delack_enabled _bsd_tcp_delack_enabled
+#define tcp_delacktime _bsd_tcp_delacktime
+#define tcp_discardcb _bsd_tcp_discardcb
+#define tcp_do_autorcvbuf _bsd_tcp_do_autorcvbuf
+#define tcp_do_autosndbuf _bsd_tcp_do_autosndbuf
+#define tcp_do_ecn _bsd_tcp_do_ecn
+#define tcp_do_rfc1323 _bsd_tcp_do_rfc1323
+#define tcp_do_rfc3042 _bsd_tcp_do_rfc3042
+#define tcp_do_rfc3390 _bsd_tcp_do_rfc3390
+#define tcp_do_rfc3465 _bsd_tcp_do_rfc3465
+#define tcp_do_rfc6675_pipe _bsd_tcp_do_rfc6675_pipe
+#define tcp_do_sack _bsd_tcp_do_sack
+#define tcp_do_segment _bsd_tcp_do_segment
+#define tcp_do_tso _bsd_tcp_do_tso
+#define tcp_dooptions _bsd_tcp_dooptions
+#define tcp_drain _bsd_tcp_drain
+#define tcp_drop _bsd_tcp_drop
+#define tcp_drop_syn_sent _bsd_tcp_drop_syn_sent
+#define tcp_dropwithreset _bsd_tcp_dropwithreset
+#define tcp_ecn_maxretries _bsd_tcp_ecn_maxretries
+#define tcp_fast_finwait2_recycle _bsd_tcp_fast_finwait2_recycle
+#define tcp_fini _bsd_tcp_fini
+#define tcp_finwait2_timeout _bsd_tcp_finwait2_timeout
+#define tcp_free_sackholes _bsd_tcp_free_sackholes
+#define tcp_function_lock _bsd_tcp_function_lock
+#define tcp_hc_get _bsd_tcp_hc_get
+#define tcp_hc_getmtu _bsd_tcp_hc_getmtu
+#define tcp_hc_init _bsd_tcp_hc_init
+#define tcp_hc_update _bsd_tcp_hc_update
+#define tcp_hc_updatemtu _bsd_tcp_hc_updatemtu
+#define tcp_init _bsd_tcp_init
+#define tcp_initcwnd_segments _bsd_tcp_initcwnd_segments
+#define tcp_inp_lro_compressed _bsd_tcp_inp_lro_compressed
+#define tcp_inp_lro_direct_queue _bsd_tcp_inp_lro_direct_queue
+#define tcp_inp_lro_locks_taken _bsd_tcp_inp_lro_locks_taken
+#define tcp_inp_lro_sack_wake _bsd_tcp_inp_lro_sack_wake
+#define tcp_inp_lro_single_push _bsd_tcp_inp_lro_single_push
+#define tcp_inp_lro_wokeup_queue _bsd_tcp_inp_lro_wokeup_queue
+#define tcp_inpinfo_lock_del _bsd_tcp_inpinfo_lock_del
+#define tcp_inptoxtp _bsd_tcp_inptoxtp
+#define tcp_input _bsd_tcp_input
+#define tcp_insecure_rst _bsd_tcp_insecure_rst
+#define tcp_insecure_syn _bsd_tcp_insecure_syn
+#define tcp_ipsec_support _bsd_tcp_ipsec_support
+#define tcp_keepcnt _bsd_tcp_keepcnt
+#define tcp_keepidle _bsd_tcp_keepidle
+#define tcp_keepinit _bsd_tcp_keepinit
+#define tcp_keepintvl _bsd_tcp_keepintvl
+#define tcp_log_addrs _bsd_tcp_log_addrs
+#define tcp_log_in_vain _bsd_tcp_log_in_vain
+#define tcp_log_vain _bsd_tcp_log_vain
+#define tcp_lro_dereg_mbufq _bsd_tcp_lro_dereg_mbufq
+#define tcp_lro_flush _bsd_tcp_lro_flush
+#define tcp_lro_flush_all _bsd_tcp_lro_flush_all
+#define tcp_lro_flush_inactive _bsd_tcp_lro_flush_inactive
+#define tcp_lro_free _bsd_tcp_lro_free
+#define tcp_lro_init _bsd_tcp_lro_init
+#define tcp_lro_init_args _bsd_tcp_lro_init_args
+#define tcp_lro_queue_mbuf _bsd_tcp_lro_queue_mbuf
+#define tcp_lro_reg_mbufq _bsd_tcp_lro_reg_mbufq
+#define tcp_lro_rx _bsd_tcp_lro_rx
+#define tcp_m_copym _bsd_tcp_m_copym
+#define tcp_maxmtu _bsd_tcp_maxmtu
+#define tcp_maxmtu6 _bsd_tcp_maxmtu6
+#define tcp_maxpersistidle _bsd_tcp_maxpersistidle
+#define tcp_maxseg _bsd_tcp_maxseg
+#define tcp_minmss _bsd_tcp_minmss
+#define tcp_msl _bsd_tcp_msl
+#define tcp_mss _bsd_tcp_mss
+#define tcp_mss_update _bsd_tcp_mss_update
+#define tcp_mssdflt _bsd_tcp_mssdflt
+#define tcp_mssopt _bsd_tcp_mssopt
+#define tcp_new_isn _bsd_tcp_new_isn
+#define tcp_new_ts_offset _bsd_tcp_new_ts_offset
+#define tcp_newreno_partial_ack _bsd_tcp_newreno_partial_ack
+#define tcp_newtcpcb _bsd_tcp_newtcpcb
+#define tcp_offload_connect _bsd_tcp_offload_connect
+#define tcp_offload_ctloutput _bsd_tcp_offload_ctloutput
+#define tcp_offload_detach _bsd_tcp_offload_detach
+#define tcp_offload_input _bsd_tcp_offload_input
+#define tcp_offload_output _bsd_tcp_offload_output
+#define tcp_offload_rcvd _bsd_tcp_offload_rcvd
+#define tcp_offload_tcp_info _bsd_tcp_offload_tcp_info
+#define tcp_output _bsd_tcp_output
+#define tcp_persmax _bsd_tcp_persmax
+#define tcp_persmin _bsd_tcp_persmin
+#define tcp_pmtud_blackhole_detect _bsd_tcp_pmtud_blackhole_detect
+#define tcp_pmtud_blackhole_mss _bsd_tcp_pmtud_blackhole_mss
+#define tcp_pulloutofband _bsd_tcp_pulloutofband
+#define tcp_reass _bsd_tcp_reass
+#define tcp_reass_flush _bsd_tcp_reass_flush
+#define tcp_reass_global_init _bsd_tcp_reass_global_init
+#define tcp_recvspace _bsd_tcp_recvspace
+#define tcp_respond _bsd_tcp_respond
+#define tcp_rexmit_drop_options _bsd_tcp_rexmit_drop_options
+#define tcp_rexmit_initial _bsd_tcp_rexmit_initial
+#define tcp_rexmit_min _bsd_tcp_rexmit_min
+#define tcp_rexmit_slop _bsd_tcp_rexmit_slop
+#define tcp_sack_adjust _bsd_tcp_sack_adjust
+#define tcp_sack_doack _bsd_tcp_sack_doack
+#define tcp_sack_globalholes _bsd_tcp_sack_globalholes
+#define tcp_sack_globalmaxholes _bsd_tcp_sack_globalmaxholes
+#define tcp_sack_maxholes _bsd_tcp_sack_maxholes
+#define tcp_sack_output _bsd_tcp_sack_output
+#define tcp_sack_partialack _bsd_tcp_sack_partialack
+#define tcp_sc_rst_sock_fail _bsd_tcp_sc_rst_sock_fail
+#define tcp_sendbuf_auto_lowat _bsd_tcp_sendbuf_auto_lowat
+#define tcp_sendspace _bsd_tcp_sendspace
+#define tcp_setpersist _bsd_tcp_setpersist
+#define tcp_slowtimo _bsd_tcp_slowtimo
+#define tcp_sndbuf_autoscale _bsd_tcp_sndbuf_autoscale
+#define tcp_state_change _bsd_tcp_state_change
+#define tcp_switch_back_to_default _bsd_tcp_switch_back_to_default
+#define tcp_timer_2msl _bsd_tcp_timer_2msl
+#define tcp_timer_activate _bsd_tcp_timer_activate
+#define tcp_timer_active _bsd_tcp_timer_active
+#define tcp_timer_delack _bsd_tcp_timer_delack
+#define tcp_timer_discard _bsd_tcp_timer_discard
+#define tcp_timer_keep _bsd_tcp_timer_keep
+#define tcp_timer_persist _bsd_tcp_timer_persist
+#define tcp_timer_rexmt _bsd_tcp_timer_rexmt
+#define tcp_timer_stop _bsd_tcp_timer_stop
+#define tcp_timer_suspend _bsd_tcp_timer_suspend
+#define tcp_timers_unsuspend _bsd_tcp_timers_unsuspend
+#define tcp_totbackoff _bsd_tcp_totbackoff
+#define tcp_trace _bsd_tcp_trace
+#define tcp_ts_offset_per_conn _bsd_tcp_ts_offset_per_conn
+#define tcp_tw_2msl_scan _bsd_tcp_tw_2msl_scan
+#define tcp_tw_init _bsd_tcp_tw_init
+#define tcp_tw_zone_change _bsd_tcp_tw_zone_change
+#define tcp_twcheck _bsd_tcp_twcheck
+#define tcp_twclose _bsd_tcp_twclose
+#define tcp_twstart _bsd_tcp_twstart
+#define tcp_update_dsack_list _bsd_tcp_update_dsack_list
+#define tcp_update_sack_list _bsd_tcp_update_sack_list
+#define tcp_use_hostcache _bsd_tcp_use_hostcache
+#define tcp_usrreqs _bsd_tcp_usrreqs
+#define tcp_v6mssdflt _bsd_tcp_v6mssdflt
+#define tcp_v6pmtud_blackhole_mss _bsd_tcp_v6pmtud_blackhole_mss
+#define tcp_xmit_timer _bsd_tcp_xmit_timer
+#define tcpip_fillheaders _bsd_tcpip_fillheaders
+#define tcpip_maketemplate _bsd_tcpip_maketemplate
+#define tcprexmtthresh _bsd_tcprexmtthresh
+#define tcps_states _bsd_tcps_states
+#define tcpstat _bsd_tcpstat
+#define ti_am335x_clk_devmap _bsd_ti_am335x_clk_devmap
+#define ti_am335x_pinmux_dev _bsd_ti_am335x_pinmux_dev
+#define ti_hwmods _bsd_ti_hwmods
+#define ti_hwmods_contains _bsd_ti_hwmods_contains
+#define ti_hwmods_get_clock _bsd_ti_hwmods_get_clock
+#define ti_hwmods_get_unit _bsd_ti_hwmods_get_unit
+#define ti_pinmux_padconf_get _bsd_ti_pinmux_padconf_get
+#define ti_pinmux_padconf_get_gpiomode _bsd_ti_pinmux_padconf_get_gpiomode
+#define ti_pinmux_padconf_set _bsd_ti_pinmux_padconf_set
+#define ti_pinmux_padconf_set_gpiomode _bsd_ti_pinmux_padconf_set_gpiomode
+#define ti_prcm_clk_disable _bsd_ti_prcm_clk_disable
+#define ti_prcm_clk_enable _bsd_ti_prcm_clk_enable
+#define ti_prcm_clk_get_source_freq _bsd_ti_prcm_clk_get_source_freq
+#define ti_prcm_clk_set_source _bsd_ti_prcm_clk_set_source
+#define ti_prcm_clk_set_source_freq _bsd_ti_prcm_clk_set_source_freq
+#define ti_prcm_clk_valid _bsd_ti_prcm_clk_valid
+#define ti_scm_reg_read_4 _bsd_ti_scm_reg_read_4
+#define ti_scm_reg_write_4 _bsd_ti_scm_reg_write_4
+#define tick _bsd_tick
+#define tick_sbt _bsd_tick_sbt
+#define ticket_altqs_active _bsd_ticket_altqs_active
+#define ticket_altqs_inactive _bsd_ticket_altqs_inactive
+#define ticket_pabuf _bsd_ticket_pabuf
+#define timeout _bsd_timeout
+#define timevaladd _bsd_timevaladd
+#define timevalsub _bsd_timevalsub
+#define trash_ctor _bsd_trash_ctor
+#define trash_dtor _bsd_trash_dtor
+#define trash_fini _bsd_trash_fini
+#define trash_init _bsd_trash_init
+#define tsec_attach _bsd_tsec_attach
+#define tsec_detach _bsd_tsec_detach
+#define tsec_devclass _bsd_tsec_devclass
+#define tsec_error_intr _bsd_tsec_error_intr
+#define tsec_get_hwaddr _bsd_tsec_get_hwaddr
+#define tsec_miibus_readreg _bsd_tsec_miibus_readreg
+#define tsec_miibus_statchg _bsd_tsec_miibus_statchg
+#define tsec_miibus_writereg _bsd_tsec_miibus_writereg
+#define tsec_phy_mtx _bsd_tsec_phy_mtx
+#define tsec_receive_intr _bsd_tsec_receive_intr
+#define tsec_resume _bsd_tsec_resume
+#define tsec_shutdown _bsd_tsec_shutdown
+#define tsec_suspend _bsd_tsec_suspend
+#define tsec_transmit_intr _bsd_tsec_transmit_intr
+#define tty_alloc _bsd_tty_alloc
+#define tty_alloc_mutex _bsd_tty_alloc_mutex
+#define tty_checkoutq _bsd_tty_checkoutq
+#define tty_flush _bsd_tty_flush
+#define tty_hiwat_in_block _bsd_tty_hiwat_in_block
+#define tty_hiwat_in_unblock _bsd_tty_hiwat_in_unblock
+#define tty_init_console _bsd_tty_init_console
+#define tty_ioctl _bsd_tty_ioctl
+#define tty_makedevf _bsd_tty_makedevf
+#define tty_putchar _bsd_tty_putchar
+#define tty_putstrn _bsd_tty_putstrn
+#define tty_rel_gone _bsd_tty_rel_gone
+#define tty_rel_pgrp _bsd_tty_rel_pgrp
+#define tty_rel_sess _bsd_tty_rel_sess
+#define tty_set_winsize _bsd_tty_set_winsize
+#define tty_signal_pgrp _bsd_tty_signal_pgrp
+#define tty_signal_sessleader _bsd_tty_signal_sessleader
+#define tty_timedwait _bsd_tty_timedwait
+#define tty_wait _bsd_tty_wait
+#define tty_wait_background _bsd_tty_wait_background
+#define tty_wakeup _bsd_tty_wakeup
+#define ttydisc_close _bsd_ttydisc_close
+#define ttydisc_getc _bsd_ttydisc_getc
+#define ttydisc_getc_poll _bsd_ttydisc_getc_poll
+#define ttydisc_getc_uio _bsd_ttydisc_getc_uio
+#define ttydisc_modem _bsd_ttydisc_modem
+#define ttydisc_open _bsd_ttydisc_open
+#define ttydisc_optimize _bsd_ttydisc_optimize
+#define ttydisc_read _bsd_ttydisc_read
+#define ttydisc_rint _bsd_ttydisc_rint
+#define ttydisc_rint_bypass _bsd_ttydisc_rint_bypass
+#define ttydisc_rint_done _bsd_ttydisc_rint_done
+#define ttydisc_rint_poll _bsd_ttydisc_rint_poll
+#define ttydisc_rint_simple _bsd_ttydisc_rint_simple
+#define ttydisc_write _bsd_ttydisc_write
+#define ttyinq_canonicalize _bsd_ttyinq_canonicalize
+#define ttyinq_findchar _bsd_ttyinq_findchar
+#define ttyinq_flush _bsd_ttyinq_flush
+#define ttyinq_free _bsd_ttyinq_free
+#define ttyinq_line_iterate_from_linestart _bsd_ttyinq_line_iterate_from_linestart
+#define ttyinq_line_iterate_from_reprintpos _bsd_ttyinq_line_iterate_from_reprintpos
+#define ttyinq_peekchar _bsd_ttyinq_peekchar
+#define ttyinq_read_uio _bsd_ttyinq_read_uio
+#define ttyinq_reprintpos_reset _bsd_ttyinq_reprintpos_reset
+#define ttyinq_reprintpos_set _bsd_ttyinq_reprintpos_set
+#define ttyinq_setsize _bsd_ttyinq_setsize
+#define ttyinq_unputchar _bsd_ttyinq_unputchar
+#define ttyinq_write _bsd_ttyinq_write
+#define ttyinq_write_nofrag _bsd_ttyinq_write_nofrag
+#define ttyoutq_flush _bsd_ttyoutq_flush
+#define ttyoutq_free _bsd_ttyoutq_free
+#define ttyoutq_read _bsd_ttyoutq_read
+#define ttyoutq_read_uio _bsd_ttyoutq_read_uio
+#define ttyoutq_setsize _bsd_ttyoutq_setsize
+#define ttyoutq_write _bsd_ttyoutq_write
+#define ttyoutq_write_nofrag _bsd_ttyoutq_write_nofrag
+#define tvtohz _bsd_tvtohz
+#define ucom_attach _bsd_ucom_attach
+#define ucom_cfg_is_gone _bsd_ucom_cfg_is_gone
+#define ucom_cnops _bsd_ucom_cnops
+#define ucom_detach _bsd_ucom_detach
+#define ucom_drain _bsd_ucom_drain
+#define ucom_drain_all _bsd_ucom_drain_all
+#define ucom_get_data _bsd_ucom_get_data
+#define ucom_put_data _bsd_ucom_put_data
+#define ucom_ref _bsd_ucom_ref
+#define ucom_set_pnpinfo_usb _bsd_ucom_set_pnpinfo_usb
+#define ucom_set_usb_mode _bsd_ucom_set_usb_mode
+#define ucom_status_change _bsd_ucom_status_change
+#define ucom_unref _bsd_ucom_unref
+#define udb _bsd_udb
+#define udbinfo _bsd_udbinfo
+#define udp6_ctlinput _bsd_udp6_ctlinput
+#define udp6_input _bsd_udp6_input
+#define udp6_usrreqs _bsd_udp6_usrreqs
+#define udp_blackhole _bsd_udp_blackhole
+#define udp_cksum _bsd_udp_cksum
+#define udp_ctlinput _bsd_udp_ctlinput
+#define udp_ctloutput _bsd_udp_ctloutput
+#define udp_discardcb _bsd_udp_discardcb
+#define udp_init _bsd_udp_init
+#define udp_input _bsd_udp_input
+#define udp_ipsec_adjust_cksum _bsd_udp_ipsec_adjust_cksum
+#define udp_ipsec_input _bsd_udp_ipsec_input
+#define udp_ipsec_output _bsd_udp_ipsec_output
+#define udp_ipsec_pcbctl _bsd_udp_ipsec_pcbctl
+#define udp_log_in_vain _bsd_udp_log_in_vain
+#define udp_newudpcb _bsd_udp_newudpcb
+#define udp_notify _bsd_udp_notify
+#define udp_recvspace _bsd_udp_recvspace
+#define udp_sendspace _bsd_udp_sendspace
+#define udp_set_kernel_tunneling _bsd_udp_set_kernel_tunneling
+#define udp_shutdown _bsd_udp_shutdown
+#define udp_usrreqs _bsd_udp_usrreqs
+#define udplite6_ctlinput _bsd_udplite6_ctlinput
+#define udplite_ctlinput _bsd_udplite_ctlinput
+#define udplite_init _bsd_udplite_init
+#define udpstat _bsd_udpstat
+#define uether_getifp _bsd_uether_getifp
+#define uether_getmii _bsd_uether_getmii
+#define uether_getsc _bsd_uether_getsc
+#define uether_ifattach _bsd_uether_ifattach
+#define uether_ifattach_wait _bsd_uether_ifattach_wait
+#define uether_ifdetach _bsd_uether_ifdetach
+#define uether_ifmedia_upd _bsd_uether_ifmedia_upd
+#define uether_init _bsd_uether_init
+#define uether_ioctl _bsd_uether_ioctl
+#define uether_is_gone _bsd_uether_is_gone
+#define uether_newbuf _bsd_uether_newbuf
+#define uether_pause _bsd_uether_pause
+#define uether_rxbuf _bsd_uether_rxbuf
+#define uether_rxflush _bsd_uether_rxflush
+#define uether_rxmbuf _bsd_uether_rxmbuf
+#define uether_start _bsd_uether_start
+#define ugen_do_request _bsd_ugen_do_request
+#define uhub_attach _bsd_uhub_attach
+#define uhub_child_location_string _bsd_uhub_child_location_string
+#define uhub_count_active_host_ports _bsd_uhub_count_active_host_ports
+#define uhub_detach _bsd_uhub_detach
+#define uhub_driver _bsd_uhub_driver
+#define uhub_explore_handle_re_enumerate _bsd_uhub_explore_handle_re_enumerate
+#define uhub_find_iface_index _bsd_uhub_find_iface_index
+#define uhub_probe _bsd_uhub_probe
+#define uhub_query_info _bsd_uhub_query_info
+#define uhub_root_intr _bsd_uhub_root_intr
+#define uhub_tt_buffer_reset_async_locked _bsd_uhub_tt_buffer_reset_async_locked
+#define uiomove _bsd_uiomove
+#define uiomove_nofault _bsd_uiomove_nofault
+#define ukphy_status _bsd_ukphy_status
+#define ulitecb _bsd_ulitecb
+#define ulitecbinfo _bsd_ulitecbinfo
+#define uma_align_cache _bsd_uma_align_cache
+#define uma_avail _bsd_uma_avail
+#define uma_limit _bsd_uma_limit
+#define uma_print_stats _bsd_uma_print_stats
+#define uma_print_zone _bsd_uma_print_zone
+#define uma_reclaim _bsd_uma_reclaim
+#define uma_reclaim_wakeup _bsd_uma_reclaim_wakeup
+#define uma_reclaim_worker _bsd_uma_reclaim_worker
+#define uma_set_align _bsd_uma_set_align
+#define uma_set_limit _bsd_uma_set_limit
+#define uma_size _bsd_uma_size
+#define uma_startup _bsd_uma_startup
+#define uma_zalloc_arg _bsd_uma_zalloc_arg
+#define uma_zalloc_domain _bsd_uma_zalloc_domain
+#define uma_zalloc_pcpu_arg _bsd_uma_zalloc_pcpu_arg
+#define uma_zcache_create _bsd_uma_zcache_create
+#define uma_zcreate _bsd_uma_zcreate
+#define uma_zdestroy _bsd_uma_zdestroy
+#define uma_zfree_arg _bsd_uma_zfree_arg
+#define uma_zfree_domain _bsd_uma_zfree_domain
+#define uma_zfree_pcpu_arg _bsd_uma_zfree_pcpu_arg
+#define uma_zone_exhausted _bsd_uma_zone_exhausted
+#define uma_zone_exhausted_nolock _bsd_uma_zone_exhausted_nolock
+#define uma_zone_get_cur _bsd_uma_zone_get_cur
+#define uma_zone_get_max _bsd_uma_zone_get_max
+#define uma_zone_reclaim _bsd_uma_zone_reclaim
+#define uma_zone_reserve _bsd_uma_zone_reserve
+#define uma_zone_set_allocf _bsd_uma_zone_set_allocf
+#define uma_zone_set_fini _bsd_uma_zone_set_fini
+#define uma_zone_set_freef _bsd_uma_zone_set_freef
+#define uma_zone_set_init _bsd_uma_zone_set_init
+#define uma_zone_set_max _bsd_uma_zone_set_max
+#define uma_zone_set_maxaction _bsd_uma_zone_set_maxaction
+#define uma_zone_set_maxcache _bsd_uma_zone_set_maxcache
+#define uma_zone_set_warning _bsd_uma_zone_set_warning
+#define uma_zone_set_zfini _bsd_uma_zone_set_zfini
+#define uma_zone_set_zinit _bsd_uma_zone_set_zinit
+#define uma_zsecond_create _bsd_uma_zsecond_create
+#define uma_zwait _bsd_uma_zwait
+#define unp_copy_peercred _bsd_unp_copy_peercred
+#define untimeout _bsd_untimeout
+#define usb_alloc_device _bsd_usb_alloc_device
+#define usb_alloc_mbufs _bsd_usb_alloc_mbufs
+#define usb_alloc_symlink _bsd_usb_alloc_symlink
+#define usb_bdma_done_event _bsd_usb_bdma_done_event
+#define usb_bdma_post_sync _bsd_usb_bdma_post_sync
+#define usb_bdma_pre_sync _bsd_usb_bdma_pre_sync
+#define usb_bdma_work_loop _bsd_usb_bdma_work_loop
+#define usb_bus_mem_alloc_all _bsd_usb_bus_mem_alloc_all
+#define usb_bus_mem_flush_all _bsd_usb_bus_mem_flush_all
+#define usb_bus_mem_free_all _bsd_usb_bus_mem_free_all
+#define usb_bus_port_get_device _bsd_usb_bus_port_get_device
+#define usb_bus_port_set_device _bsd_usb_bus_port_set_device
+#define usb_bus_power_update _bsd_usb_bus_power_update
+#define usb_bus_powerd _bsd_usb_bus_powerd
+#define usb_bus_reset_async_locked _bsd_usb_bus_reset_async_locked
+#define usb_bus_unload _bsd_usb_bus_unload
+#define usb_command_wrapper _bsd_usb_command_wrapper
+#define usb_debug _bsd_usb_debug
+#define usb_desc_foreach _bsd_usb_desc_foreach
+#define usb_destroy_dev _bsd_usb_destroy_dev
+#define usb_destroy_dev_sync _bsd_usb_destroy_dev_sync
+#define usb_detach_device _bsd_usb_detach_device
+#define usb_devclass_ptr _bsd_usb_devclass_ptr
+#define usb_devinfo _bsd_usb_devinfo
+#define usb_devsw _bsd_usb_devsw
+#define usb_dma_delay_done_cb _bsd_usb_dma_delay_done_cb
+#define usb_dma_tag_find _bsd_usb_dma_tag_find
+#define usb_dma_tag_setup _bsd_usb_dma_tag_setup
+#define usb_dma_tag_unsetup _bsd_usb_dma_tag_unsetup
+#define usb_do_clear_stall_callback _bsd_usb_do_clear_stall_callback
+#define usb_dump_device _bsd_usb_dump_device
+#define usb_dump_endpoint _bsd_usb_dump_endpoint
+#define usb_dump_iface _bsd_usb_dump_iface
+#define usb_dump_queue _bsd_usb_dump_queue
+#define usb_dump_xfer _bsd_usb_dump_xfer
+#define usb_dymo_eject _bsd_usb_dymo_eject
+#define usb_ed_comp_foreach _bsd_usb_ed_comp_foreach
+#define usb_edesc_foreach _bsd_usb_edesc_foreach
+#define usb_endpoint_foreach _bsd_usb_endpoint_foreach
+#define usb_extra_power_up_time _bsd_usb_extra_power_up_time
+#define usb_fifo_alloc_buffer _bsd_usb_fifo_alloc_buffer
+#define usb_fifo_attach _bsd_usb_fifo_attach
+#define usb_fifo_detach _bsd_usb_fifo_detach
+#define usb_fifo_free _bsd_usb_fifo_free
+#define usb_fifo_free_buffer _bsd_usb_fifo_free_buffer
+#define usb_fifo_get_data _bsd_usb_fifo_get_data
+#define usb_fifo_get_data_buffer _bsd_usb_fifo_get_data_buffer
+#define usb_fifo_get_data_error _bsd_usb_fifo_get_data_error
+#define usb_fifo_get_data_linear _bsd_usb_fifo_get_data_linear
+#define usb_fifo_put_bytes_max _bsd_usb_fifo_put_bytes_max
+#define usb_fifo_put_data _bsd_usb_fifo_put_data
+#define usb_fifo_put_data_buffer _bsd_usb_fifo_put_data_buffer
+#define usb_fifo_put_data_error _bsd_usb_fifo_put_data_error
+#define usb_fifo_put_data_linear _bsd_usb_fifo_put_data_linear
+#define usb_fifo_reset _bsd_usb_fifo_reset
+#define usb_fifo_set_close_zlp _bsd_usb_fifo_set_close_zlp
+#define usb_fifo_set_write_defrag _bsd_usb_fifo_set_write_defrag
+#define usb_fifo_signal _bsd_usb_fifo_signal
+#define usb_fifo_softc _bsd_usb_fifo_softc
+#define usb_fifo_wait _bsd_usb_fifo_wait
+#define usb_fifo_wakeup _bsd_usb_fifo_wakeup
+#define usb_free_device _bsd_usb_free_device
+#define usb_free_symlink _bsd_usb_free_symlink
+#define usb_get_device_state _bsd_usb_get_device_state
+#define usb_get_manufacturer _bsd_usb_get_manufacturer
+#define usb_get_product _bsd_usb_get_product
+#define usb_get_serial _bsd_usb_get_serial
+#define usb_handle_request_callback _bsd_usb_handle_request_callback
+#define usb_hs_bandwidth_alloc _bsd_usb_hs_bandwidth_alloc
+#define usb_hs_bandwidth_free _bsd_usb_hs_bandwidth_free
+#define usb_idesc_foreach _bsd_usb_idesc_foreach
+#define usb_iface_is_cdrom _bsd_usb_iface_is_cdrom
+#define usb_isoc_time_expand _bsd_usb_isoc_time_expand
+#define usb_make_dev _bsd_usb_make_dev
+#define usb_make_str_desc _bsd_usb_make_str_desc
+#define usb_msc_auto_quirk _bsd_usb_msc_auto_quirk
+#define usb_msc_eject _bsd_usb_msc_eject
+#define usb_msc_read_10 _bsd_usb_msc_read_10
+#define usb_msc_read_capacity _bsd_usb_msc_read_capacity
+#define usb_msc_write_10 _bsd_usb_msc_write_10
+#define usb_needs_explore _bsd_usb_needs_explore
+#define usb_needs_explore_all _bsd_usb_needs_explore_all
+#define usb_pause_mtx _bsd_usb_pause_mtx
+#define usb_pc_alloc_mem _bsd_usb_pc_alloc_mem
+#define usb_pc_buffer_is_aligned _bsd_usb_pc_buffer_is_aligned
+#define usb_pc_cpu_flush _bsd_usb_pc_cpu_flush
+#define usb_pc_cpu_invalidate _bsd_usb_pc_cpu_invalidate
+#define usb_pc_dmamap_create _bsd_usb_pc_dmamap_create
+#define usb_pc_dmamap_destroy _bsd_usb_pc_dmamap_destroy
+#define usb_pc_free_mem _bsd_usb_pc_free_mem
+#define usb_pc_load_mem _bsd_usb_pc_load_mem
+#define usb_peer_can_wakeup _bsd_usb_peer_can_wakeup
+#define usb_port_powerup_delay _bsd_usb_port_powerup_delay
+#define usb_port_reset_delay _bsd_usb_port_reset_delay
+#define usb_port_reset_recovery _bsd_usb_port_reset_recovery
+#define usb_port_resume_delay _bsd_usb_port_resume_delay
+#define usb_port_root_reset_delay _bsd_usb_port_root_reset_delay
+#define usb_printbcd _bsd_usb_printbcd
+#define usb_probe_and_attach _bsd_usb_probe_and_attach
+#define usb_proc_create _bsd_usb_proc_create
+#define usb_proc_drain _bsd_usb_proc_drain
+#define usb_proc_explore_lock _bsd_usb_proc_explore_lock
+#define usb_proc_explore_msignal _bsd_usb_proc_explore_msignal
+#define usb_proc_explore_mwait _bsd_usb_proc_explore_mwait
+#define usb_proc_explore_unlock _bsd_usb_proc_explore_unlock
+#define usb_proc_free _bsd_usb_proc_free
+#define usb_proc_is_called_from _bsd_usb_proc_is_called_from
+#define usb_proc_is_gone _bsd_usb_proc_is_gone
+#define usb_proc_msignal _bsd_usb_proc_msignal
+#define usb_proc_mwait _bsd_usb_proc_mwait
+#define usb_proc_rewakeup _bsd_usb_proc_rewakeup
+#define usb_quirk_ioctl_p _bsd_usb_quirk_ioctl_p
+#define usb_quirk_unload _bsd_usb_quirk_unload
+#define usb_read_symlink _bsd_usb_read_symlink
+#define usb_ref_lock _bsd_usb_ref_lock
+#define usb_reset_iface_endpoints _bsd_usb_reset_iface_endpoints
+#define usb_resume_delay _bsd_usb_resume_delay
+#define usb_resume_recovery _bsd_usb_resume_recovery
+#define usb_resume_wait _bsd_usb_resume_wait
+#define usb_set_address_settle _bsd_usb_set_address_settle
+#define usb_set_device_state _bsd_usb_set_device_state
+#define usb_statestr _bsd_usb_statestr
+#define usb_string_lang_en _bsd_usb_string_lang_en
+#define usb_suspend_resume _bsd_usb_suspend_resume
+#define usb_temp_get_desc_p _bsd_usb_temp_get_desc_p
+#define usb_temp_setup_by_index_p _bsd_usb_temp_setup_by_index_p
+#define usb_temp_unload _bsd_usb_temp_unload
+#define usb_temp_unsetup_p _bsd_usb_temp_unsetup_p
+#define usb_template _bsd_usb_template
+#define usb_test_quirk _bsd_usb_test_quirk
+#define usb_test_quirk_p _bsd_usb_test_quirk_p
+#define usb_trim_spaces _bsd_usb_trim_spaces
+#define usb_ugen_methods _bsd_usb_ugen_methods
+#define usbd_add_dynamic_quirk _bsd_usbd_add_dynamic_quirk
+#define usbd_alloc_config_desc _bsd_usbd_alloc_config_desc
+#define usbd_clear_data_toggle _bsd_usbd_clear_data_toggle
+#define usbd_clear_stall_callback _bsd_usbd_clear_stall_callback
+#define usbd_clear_stall_locked _bsd_usbd_clear_stall_locked
+#define usbd_copy_in _bsd_usbd_copy_in
+#define usbd_copy_out _bsd_usbd_copy_out
+#define usbd_ctrl_lock _bsd_usbd_ctrl_lock
+#define usbd_ctrl_transfer_setup _bsd_usbd_ctrl_transfer_setup
+#define usbd_ctrl_unlock _bsd_usbd_ctrl_unlock
+#define usbd_device_attached _bsd_usbd_device_attached
+#define usbd_do_request_callback _bsd_usbd_do_request_callback
+#define usbd_do_request_flags _bsd_usbd_do_request_flags
+#define usbd_do_request_proc _bsd_usbd_do_request_proc
+#define usbd_dummy_timeout _bsd_usbd_dummy_timeout
+#define usbd_enum_is_locked _bsd_usbd_enum_is_locked
+#define usbd_enum_lock _bsd_usbd_enum_lock
+#define usbd_enum_lock_sig _bsd_usbd_enum_lock_sig
+#define usbd_enum_unlock _bsd_usbd_enum_unlock
+#define usbd_errstr _bsd_usbd_errstr
+#define usbd_filter_power_mode _bsd_usbd_filter_power_mode
+#define usbd_find_descriptor _bsd_usbd_find_descriptor
+#define usbd_frame_zero _bsd_usbd_frame_zero
+#define usbd_free_config_desc _bsd_usbd_free_config_desc
+#define usbd_fs_isoc_schedule_alloc_slot _bsd_usbd_fs_isoc_schedule_alloc_slot
+#define usbd_get_bus_index _bsd_usbd_get_bus_index
+#define usbd_get_config_descriptor _bsd_usbd_get_config_descriptor
+#define usbd_get_device_descriptor _bsd_usbd_get_device_descriptor
+#define usbd_get_device_index _bsd_usbd_get_device_index
+#define usbd_get_dma_delay _bsd_usbd_get_dma_delay
+#define usbd_get_endpoint _bsd_usbd_get_endpoint
+#define usbd_get_endpoint_mode _bsd_usbd_get_endpoint_mode
+#define usbd_get_ep_by_addr _bsd_usbd_get_ep_by_addr
+#define usbd_get_iface _bsd_usbd_get_iface
+#define usbd_get_interface_altindex _bsd_usbd_get_interface_altindex
+#define usbd_get_interface_descriptor _bsd_usbd_get_interface_descriptor
+#define usbd_get_isoc_fps _bsd_usbd_get_isoc_fps
+#define usbd_get_mode _bsd_usbd_get_mode
+#define usbd_get_no_alts _bsd_usbd_get_no_alts
+#define usbd_get_no_descriptors _bsd_usbd_get_no_descriptors
+#define usbd_get_page _bsd_usbd_get_page
+#define usbd_get_speed _bsd_usbd_get_speed
+#define usbd_in_polling_mode _bsd_usbd_in_polling_mode
+#define usbd_interface_count _bsd_usbd_interface_count
+#define usbd_lookup_id_by_info _bsd_usbd_lookup_id_by_info
+#define usbd_lookup_id_by_uaa _bsd_usbd_lookup_id_by_uaa
+#define usbd_m_copy_in _bsd_usbd_m_copy_in
+#define usbd_pipe_enter _bsd_usbd_pipe_enter
+#define usbd_pipe_start _bsd_usbd_pipe_start
+#define usbd_req_clear_device_feature _bsd_usbd_req_clear_device_feature
+#define usbd_req_clear_hub_feature _bsd_usbd_req_clear_hub_feature
+#define usbd_req_clear_port_feature _bsd_usbd_req_clear_port_feature
+#define usbd_req_clear_tt_buffer _bsd_usbd_req_clear_tt_buffer
+#define usbd_req_get_alt_interface_no _bsd_usbd_req_get_alt_interface_no
+#define usbd_req_get_config _bsd_usbd_req_get_config
+#define usbd_req_get_config_desc _bsd_usbd_req_get_config_desc
+#define usbd_req_get_config_desc_full _bsd_usbd_req_get_config_desc_full
+#define usbd_req_get_desc _bsd_usbd_req_get_desc
+#define usbd_req_get_descriptor_ptr _bsd_usbd_req_get_descriptor_ptr
+#define usbd_req_get_device_desc _bsd_usbd_req_get_device_desc
+#define usbd_req_get_device_status _bsd_usbd_req_get_device_status
+#define usbd_req_get_hid_desc _bsd_usbd_req_get_hid_desc
+#define usbd_req_get_hub_descriptor _bsd_usbd_req_get_hub_descriptor
+#define usbd_req_get_hub_status _bsd_usbd_req_get_hub_status
+#define usbd_req_get_port_status _bsd_usbd_req_get_port_status
+#define usbd_req_get_report _bsd_usbd_req_get_report
+#define usbd_req_get_report_descriptor _bsd_usbd_req_get_report_descriptor
+#define usbd_req_get_ss_hub_descriptor _bsd_usbd_req_get_ss_hub_descriptor
+#define usbd_req_get_string_any _bsd_usbd_req_get_string_any
+#define usbd_req_get_string_desc _bsd_usbd_req_get_string_desc
+#define usbd_req_re_enumerate _bsd_usbd_req_re_enumerate
+#define usbd_req_reset_port _bsd_usbd_req_reset_port
+#define usbd_req_reset_tt _bsd_usbd_req_reset_tt
+#define usbd_req_set_address _bsd_usbd_req_set_address
+#define usbd_req_set_alt_interface_no _bsd_usbd_req_set_alt_interface_no
+#define usbd_req_set_config _bsd_usbd_req_set_config
+#define usbd_req_set_device_feature _bsd_usbd_req_set_device_feature
+#define usbd_req_set_hub_depth _bsd_usbd_req_set_hub_depth
+#define usbd_req_set_hub_feature _bsd_usbd_req_set_hub_feature
+#define usbd_req_set_hub_u1_timeout _bsd_usbd_req_set_hub_u1_timeout
+#define usbd_req_set_hub_u2_timeout _bsd_usbd_req_set_hub_u2_timeout
+#define usbd_req_set_idle _bsd_usbd_req_set_idle
+#define usbd_req_set_lpm_info _bsd_usbd_req_set_lpm_info
+#define usbd_req_set_port_feature _bsd_usbd_req_set_port_feature
+#define usbd_req_set_port_link_state _bsd_usbd_req_set_port_link_state
+#define usbd_req_set_protocol _bsd_usbd_req_set_protocol
+#define usbd_req_set_report _bsd_usbd_req_set_report
+#define usbd_req_warm_reset_port _bsd_usbd_req_warm_reset_port
+#define usbd_set_alt_interface_index _bsd_usbd_set_alt_interface_index
+#define usbd_set_config_index _bsd_usbd_set_config_index
+#define usbd_set_endpoint_mode _bsd_usbd_set_endpoint_mode
+#define usbd_set_endpoint_stall _bsd_usbd_set_endpoint_stall
+#define usbd_set_parent_iface _bsd_usbd_set_parent_iface
+#define usbd_set_pnpinfo _bsd_usbd_set_pnpinfo
+#define usbd_set_power_mode _bsd_usbd_set_power_mode
+#define usbd_setup_device_desc _bsd_usbd_setup_device_desc
+#define usbd_sr_lock _bsd_usbd_sr_lock
+#define usbd_sr_unlock _bsd_usbd_sr_unlock
+#define usbd_start_re_enumerate _bsd_usbd_start_re_enumerate
+#define usbd_start_set_config _bsd_usbd_start_set_config
+#define usbd_transfer_clear_stall _bsd_usbd_transfer_clear_stall
+#define usbd_transfer_dequeue _bsd_usbd_transfer_dequeue
+#define usbd_transfer_done _bsd_usbd_transfer_done
+#define usbd_transfer_drain _bsd_usbd_transfer_drain
+#define usbd_transfer_enqueue _bsd_usbd_transfer_enqueue
+#define usbd_transfer_pending _bsd_usbd_transfer_pending
+#define usbd_transfer_poll _bsd_usbd_transfer_poll
+#define usbd_transfer_power_ref _bsd_usbd_transfer_power_ref
+#define usbd_transfer_setup _bsd_usbd_transfer_setup
+#define usbd_transfer_setup_sub _bsd_usbd_transfer_setup_sub
+#define usbd_transfer_setup_sub_malloc _bsd_usbd_transfer_setup_sub_malloc
+#define usbd_transfer_start _bsd_usbd_transfer_start
+#define usbd_transfer_stop _bsd_usbd_transfer_stop
+#define usbd_transfer_submit _bsd_usbd_transfer_submit
+#define usbd_transfer_timeout_ms _bsd_usbd_transfer_timeout_ms
+#define usbd_transfer_unsetup _bsd_usbd_transfer_unsetup
+#define usbd_xfer_clr_flag _bsd_usbd_xfer_clr_flag
+#define usbd_xfer_frame_data _bsd_usbd_xfer_frame_data
+#define usbd_xfer_frame_len _bsd_usbd_xfer_frame_len
+#define usbd_xfer_get_fps_shift _bsd_usbd_xfer_get_fps_shift
+#define usbd_xfer_get_frame _bsd_usbd_xfer_get_frame
+#define usbd_xfer_get_frame_buffer _bsd_usbd_xfer_get_frame_buffer
+#define usbd_xfer_get_priv _bsd_usbd_xfer_get_priv
+#define usbd_xfer_get_timestamp _bsd_usbd_xfer_get_timestamp
+#define usbd_xfer_is_stalled _bsd_usbd_xfer_is_stalled
+#define usbd_xfer_max_framelen _bsd_usbd_xfer_max_framelen
+#define usbd_xfer_max_frames _bsd_usbd_xfer_max_frames
+#define usbd_xfer_max_len _bsd_usbd_xfer_max_len
+#define usbd_xfer_maxp_was_clamped _bsd_usbd_xfer_maxp_was_clamped
+#define usbd_xfer_old_frame_length _bsd_usbd_xfer_old_frame_length
+#define usbd_xfer_set_flag _bsd_usbd_xfer_set_flag
+#define usbd_xfer_set_frame_data _bsd_usbd_xfer_set_frame_data
+#define usbd_xfer_set_frame_len _bsd_usbd_xfer_set_frame_len
+#define usbd_xfer_set_frame_offset _bsd_usbd_xfer_set_frame_offset
+#define usbd_xfer_set_frames _bsd_usbd_xfer_set_frames
+#define usbd_xfer_set_interval _bsd_usbd_xfer_set_interval
+#define usbd_xfer_set_priv _bsd_usbd_xfer_set_priv
+#define usbd_xfer_set_stall _bsd_usbd_xfer_set_stall
+#define usbd_xfer_set_timeout _bsd_usbd_xfer_set_timeout
+#define usbd_xfer_softc _bsd_usbd_xfer_softc
+#define usbd_xfer_state _bsd_usbd_xfer_state
+#define usbd_xfer_status _bsd_usbd_xfer_status
+#define usbss_driver _bsd_usbss_driver
+#define uuid_ether_add _bsd_uuid_ether_add
+#define uuid_ether_del _bsd_uuid_ether_del
+#define uuidcmp _bsd_uuidcmp
+#define vesagtf_mode _bsd_vesagtf_mode
+#define vesagtf_mode_params _bsd_vesagtf_mode_params
+#define vht80_chan_ranges _bsd_vht80_chan_ranges
+#define vid_allocate _bsd_vid_allocate
+#define vid_configure _bsd_vid_configure
+#define vid_find_adapter _bsd_vid_find_adapter
+#define vid_get_adapter _bsd_vid_get_adapter
+#define vid_get_switch _bsd_vid_get_switch
+#define vid_init_struct _bsd_vid_init_struct
+#define vid_register _bsd_vid_register
+#define vid_release _bsd_vid_release
+#define vid_unregister _bsd_vid_unregister
+#define videomode_count _bsd_videomode_count
+#define videomode_list _bsd_videomode_list
+#define vidsw _bsd_vidsw
+#define vlan_cookie_p _bsd_vlan_cookie_p
+#define vlan_devat_p _bsd_vlan_devat_p
+#define vlan_input_p _bsd_vlan_input_p
+#define vlan_link_state_p _bsd_vlan_link_state_p
+#define vlan_mtag_pcp _bsd_vlan_mtag_pcp
+#define vlan_pcp_p _bsd_vlan_pcp_p
+#define vlan_setcookie_p _bsd_vlan_setcookie_p
+#define vlan_tag_p _bsd_vlan_tag_p
+#define vlan_trunk_cap_p _bsd_vlan_trunk_cap_p
+#define vlan_trunkdev_p _bsd_vlan_trunkdev_p
+#define vlog _bsd_vlog
+#define vnet_if_clone_init _bsd_vnet_if_clone_init
+#define vprintf _bsd_vprintf
+#define vsnprintf _bsd_vsnprintf
+#define vsnrprintf _bsd_vsnrprintf
+#define vsprintf _bsd_vsprintf
+#define wakeup _bsd_wakeup
+#define wakeup_any _bsd_wakeup_any
+#define wakeup_one _bsd_wakeup_one
+#define window_deflate _bsd_window_deflate
+#define window_inflate _bsd_window_inflate
+#define write_dsfield _bsd_write_dsfield
+#define xform_ah_authsize _bsd_xform_ah_authsize
+#define xform_attach _bsd_xform_attach
+#define xform_detach _bsd_xform_detach
+#define xform_init _bsd_xform_init
+#define xpt_bus_deregister _bsd_xpt_bus_deregister
+#define xpt_bus_register _bsd_xpt_bus_register
+#define xpt_done _bsd_xpt_done
+#define z_alloc _bsd_z_alloc
+#define z_free _bsd_z_free
+#define zd1211_firmware _bsd_zd1211_firmware
+#define zd1211b_firmware _bsd_zd1211b_firmware
+#define zone_clust _bsd_zone_clust
+#define zone_drain _bsd_zone_drain
+#define zone_extpgs _bsd_zone_extpgs
+#define zone_jumbo16 _bsd_zone_jumbo16
+#define zone_jumbo9 _bsd_zone_jumbo9
+#define zone_jumbop _bsd_zone_jumbop
+#define zone_mbuf _bsd_zone_mbuf
+#define zone_pack _bsd_zone_pack
+#define zy7_pl_fclk_disable _bsd_zy7_pl_fclk_disable
+#define zy7_pl_fclk_enable _bsd_zy7_pl_fclk_enable
+#define zy7_pl_fclk_enabled _bsd_zy7_pl_fclk_enabled
+#define zy7_pl_fclk_get_freq _bsd_zy7_pl_fclk_get_freq
+#define zy7_pl_fclk_get_source _bsd_zy7_pl_fclk_get_source
+#define zy7_pl_fclk_set_freq _bsd_zy7_pl_fclk_set_freq
+#define zy7_pl_fclk_set_source _bsd_zy7_pl_fclk_set_source
+#define zy7_pl_level_shifters_disable _bsd_zy7_pl_level_shifters_disable
+#define zy7_pl_level_shifters_enable _bsd_zy7_pl_level_shifters_enable
+#define zy7_pl_level_shifters_enabled _bsd_zy7_pl_level_shifters_enabled
+#define zy7_slcr_postload_pl _bsd_zy7_slcr_postload_pl
2.24.1
