[PATCH rtems-libbsd 3/4] nexus-devices: Include CDC Ethernet for Beagle
Christian MAUDERER
christian.mauderer at embedded-brains.de
Wed Jul 28 06:45:49 UTC 2021
Hello Husni,
Am 27.07.21 um 22:37 schrieb Ahamed Husni:
> Hello Christian,
> On Wed, Jul 28, 2021 at 12:34 AM Christian Mauderer <oss at c-mauderer.de
> <mailto:oss at c-mauderer.de>> wrote:
> Hello Husni,
> On 27/07/2021 17:04, Ahamed Husni wrote:
> > On Fri, Jul 16, 2021 at 1:25 AM Christian Mauderer
> <oss at c-mauderer.de <mailto:oss at c-mauderer.de>
> > <mailto:oss at c-mauderer.de <mailto:oss at c-mauderer.de>>> wrote:
> > On 06/07/2021 19:00, Husni Faiz wrote:
> > > Configure bus for CDC Ethernet
> > > Include CDC Ethernet in Beagle BSP
> > > Signed-off-by: Husni Faiz <ahamedhusni73 at gmail.com
> <mailto:ahamedhusni73 at gmail.com>
> <mailto:ahamedhusni73 at gmail.com>>>
> > > rtemsbsd/include/bsp/nexus-devices.h | 5 +++++
> > > rtemsbsd/include/machine/rtems-bsd-nexus-bus.h | 17
> > > 2 files changed, 22 insertions(+)
> > > diff --git a/rtemsbsd/include/bsp/nexus-devices.h
> > b/rtemsbsd/include/bsp/nexus-devices.h
> > > index e6487470..6a35632e 100644
> > > --- a/rtemsbsd/include/bsp/nexus-devices.h
> > > +++ b/rtemsbsd/include/bsp/nexus-devices.h
> > > @@ -83,6 +83,11 @@ SYSINIT_REFERENCE(rtwn_rtl8188eufw);
> > > RTEMS_BSD_DRIVER_USB;
> > > RTEMS_BSD_DRIVER_USB_MASS;
> > > +#ifdef RTEMS_BSD_MODULE_DEV_USB_TEMPLATE
> > > +RTEMS_BSD_DRIVER_USB_TEMPLATE;
> > > +RTEMS_BSD_DRIVER_CDCE;
> > > +#endif
> > Same like in patch 2: Shouldn't there be an include for
> > rtems/bsd/modules.h somewhere?
> > I checked the nexus-devices.h and it already has the modules.h
> included.
> Sorry. Might have missed that that include in nexus-devices.h. But For
> patch 2 it is still necessary, isn't it?
> I manually removed the RTEMS_BSD_MODULE_DEV_USB_TEMPLATE
> from the modules.h file and rebuilt the libbsd and looked for the
> symbols to
> see if they are included. The symbols weren't there as expected.
> So I thought that the rtems/bsd/modules.h is included in the
> usb_devices.c indirectly.
> I couldn't track down where it came from. So I might be wrong.
> Shall I include the rtems/bsd/modules.h the PATCH V2?
Possible that it is included indirectly somewhere. But I wouldn't say
that this is reliable. If it is used in some other header and someone
changes something there, modules.h might isn't necessary for that header
any more. In that case it might is removed and that indirect include
might suddenly doesn't work any more.
So yes: If you use the defines from modules.h, please include the
modules.h directly.
> > > #elif defined(LIBBSP_ARM_LPC32XX_BSP_H)
> > > #include <bsp/irq.h>
> > > diff --git a/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
> > b/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
> > > index 50a43873..84f561f5 100644
> > > --- a/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
> > > +++ b/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
> > > @@ -282,6 +282,15 @@ extern "C" {
> > > SYSINIT_DRIVER_REFERENCE(umass, uhub)
> > > #endif /* RTEMS_BSD_DRIVER_USB_MASS */
> > > + * USB Template base driver.
> > > +#if !defined(RTEMS_BSD_DRIVER_USB_TEMPLATE)
> > > + #define RTEMS_BSD_DRIVER_USB_TEMPLATE \
> > > + SYSINIT_REFERENCE(usb_temp_init); \
> > > + SYSINIT_DRIVER_REFERENCE(usb_template, usb)
> > > +#endif /* RTEMS_BSD_DRIVER_USB_TEMPLATE */
> > > * USB SAF1761 host controller driver.
> > > @@ -490,6 +499,14 @@ extern "C" {
> > > SYSINIT_DRIVER_REFERENCE(re, pci);
> > > #endif /* RTEMS_BSD_DRIVER_PCI_RE */
> > > + * CDC Ethernet Driver.
> > > +#if !defined(RTEMS_BSD_DRIVER_CDCE)
> > > + #define RTEMS_BSD_DRIVER_CDCE \
> > > + SYSINIT_DRIVER_REFERENCE(cdce, uhub);
> > > +#endif /* RTEMS_BSD_DRIVER_FEC */
> > > ** MMI Physical Layer Support.
> devel mailing list
> devel at rtems.org
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
