[PATCH rtems-libbsd 7/7] kern: Add kernel trace support (KTR)
Wed Jul 28 07:40:08 UTC 2021
On 28/7/21 4:57 pm, Sebastian Huber wrote:
> On 28/07/2021 08:53, Chris Johns wrote:
>> On 28/7/21 4:27 pm, Sebastian Huber wrote:
>>> On 27/07/2021 10:58,chrisj at rtems.org  wrote:
>>>> diff --git a/rtemsbsd/rtems/rtems-kernel-thread.c
>>>> b/rtemsbsd/rtems/rtems-kernel-thread.c
>>>> index 3e1e44b9..49ec6df7 100644
>>>> --- a/rtemsbsd/rtems/rtems-kernel-thread.c
>>>> +++ b/rtemsbsd/rtems/rtems-kernel-thread.c
>>>> @@ -260,6 +260,9 @@ rtems_bsd_thread_start(struct thread **td_ptr, void
>>>> (*func)(void *), void *arg,
>>>>            BSD_ASSERT(td != NULL);
>>>>              _Thread_Set_name(thread, name);
>>>> +#ifdef KTR
>>>> +        strlcpy(td->td_name, name, sizeof(td->td_name));
>>>> +#endif
>>> Do we really need this copy and the td_name member?
>> I found it useful with the KTR output to have the thread. KTR is a
>> developer/development aid and a good addition to libbsd.
> We already have a name in the Thread_Control:
> the_thread->Join_queue.Queue.name;
> See also _Thread_Get_name().
The `td_name` field is only present when the KTR is defined. I simply reused the
decl present in `struct thread` rather than optimise what could be done and
possibly create further issues. If the name field was present all the time I
would agree a pointer to the TCB would be preferred but that adds a pointer to
the thread struct which is currently not there.
