[PATCH] libcsupport: Fix TOCTOU in getchark()
Joel Sherrill
joel at rtems.org
Wed Jul 28 16:27:25 UTC 2021
On Wed, Jul 28, 2021 at 11:23 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Wed, Jul 28, 2021 at 9:13 AM Joel Sherrill <joel at rtems.org> wrote:
> > Is this a Coverity issue? Does it have a CID?
> > I remembered TOCTOU as an acronym analysis reports used
> > but had to look up the meaning. I don't know what to do so someone
> > else would not have to look it up beyond explaining it in the long comment.
> > It is missing what was checked and used that flagged the issue. That should
> > definitely be added in the long comment.
> The TOCTOU here is that a global variable is checked and then used,
> and someone could modify it in between. The solution here is to copy
> the global into a local variable before checking and using, so this is
> better. (I can't comment whether it's from a CID, just my analysis
> here.)
The commit message should explain that.
I don't see a CID for this one in the reports but someone should check
that. I don't like their web interface and might have missed something.
> > On Wed, Jul 28, 2021 at 9:50 AM Sebastian Huber
> > <sebastian.huber at embedded-brains.de> wrote:
> > > Fix format, add Doxygen comments, and reduce includes.
> > > cpukit/libcsupport/src/getchark.c | 21 +++++++++++++--------
> > > 1 file changed, 13 insertions(+), 8 deletions(-)
> > > diff --git a/cpukit/libcsupport/src/getchark.c b/cpukit/libcsupport/src/getchark.c
> > > index 5a9afbda7a..cfe9c022d6 100644
> > > --- a/cpukit/libcsupport/src/getchark.c
> > > +++ b/cpukit/libcsupport/src/getchark.c
> > > @@ -1,8 +1,9 @@
> > > - * @file
> > > + * @file
> > > - * @brief Get Character from Stdin
> > > - * @ingroup libcsupport
> > > + * @ingroup BSPIO
> > > + * @brief This source file contains the implementation of getchark().
> > > @@ -18,13 +19,17 @@
> > > #include "config.h"
> > > #endif
> > > -#include <rtems.h>
> > > #include <rtems/bspIo.h>
> > > -int getchark(void)
> > > +int getchark( void )
> > > - if ( BSP_poll_char )
> > > - return (*BSP_poll_char)();
> > > + BSP_polling_getchar_function_type poll_char;
> > > + poll_char = BSP_poll_char;
> > > + if ( poll_char == NULL ) {
> > > + return -1;
> > > - return -1;
> > > + return ( *poll_char )();
> > > 2.26.2
> > > _______________________________________________
> > > devel mailing list
> > > devel at rtems.org
> > > http://lists.rtems.org/mailman/listinfo/devel
> > devel mailing list
> > devel at rtems.org
