[PATCH rtems-libbsd 3/7] sys/kern: Add lockmgr support
Gedare Bloom
gedare at rtems.org
Wed Jul 28 23:42:33 UTC 2021
On Wed, Jul 28, 2021 at 5:05 PM Chris Johns <chrisj at rtems.org> wrote:
> On 29/7/21 12:03 am, Gedare Bloom wrote:
> > On Tue, Jul 27, 2021 at 2:59 AM <chrisj at rtems.org> wrote:
> >> From: Chris Johns <chrisj at rtems.org>
> >> struct lock_object {
> >> -#ifndef __rtems__
> >> const char *lo_name; /* Individual lock name. */
> >> u_int lo_flags;
> >> u_int lo_data; /* General class specific data. */
> >> +#ifndef __rtems__
> >> struct witness *lo_witness; /* Data for witness. */
> >> -#else /* __rtems__ */
> >> - unsigned int lo_flags;
> >> +#endif /* __rtems__ */
> >> +#ifdef __rtems__
> > Can use
> > instead of endif+ifdef
> I will see how this ends up after looking at the fields Sebastian wants removed.
> >> +static void
> >> +lock_lockmgr(struct lock_object *lock, uintptr_t how)
> >> + panic("lockmgr locks do not support sleep interlocking");
> >> +static uintptr_t
> >> +unlock_lockmgr(struct lock_object *lock)
> > Should there be different messages for the two cases here?
> Sure. Either case means something is being used by new ported code and these
> calls need to be looked into.
> >> +static struct thread *
> >> +lockmgr_xholder(const struct lock *lk)
> >> + uintptr_t x;
> >> + x = lk->lk_lock;
> >> + if ((x & LK_SHARE))
> >> + return NULL;
> >> + return rtems_bsd_get_thread(lk->lock_object.lo_mtx.queue.Queue.owner);
> >> +static void
> >> +lockmgr_exit(u_int flags, struct lock_object *ilk, int wakeup_swapper)
> > any good reason to use ilk instead of lk as elsewhere?
> None. I copy the decl from FreeBSD ...
> freebsd/sys/kern/kern_lock.c:lockmgr_exit(u_int flags, struct lock_object *ilk,
> int wakeup_swapper)
> >> +static int
> >> +lockmgr_slock_hard(struct lock *lk, u_int flags, struct lock_object *ilk,
> >> + const char *file, int line)
> >> + uintptr_t x;
> >> + int error = 0;
> >> + lockmgr_trace("slock", 'I', lk);
> >> + rtems_bsd_mutex_lock(&lk->lock_object);
> >> + x = lk->lk_lock;
> >> + atomic_store_rel_ptr(&lk->lk_lock, x + LK_ONE_SHARER);
> >> + if (rtems_bsd_mutex_recursed(&lk->lock_object))
> >> + lk->lk_recurse++;
> >> + else
> >> + lk->lk_recurse = 0;
> >> + lockmgr_trace("slock", 'O', lk);
> >> + LOCK_LOG_LOCK("SLOCK", &lk->lock_object, 0, lk->lk_recurse, file, line);
> >> + lockmgr_exit(flags, ilk, 0);
> >> + return error;
> > this is always 0 (successful)?
> Yeap.
> >> +static int
> >> +lockmgr_upgrade(struct lock *lk, u_int flags, struct lock_object *ilk,
> >> + uintptr_t x, v;
> >> + int error = 0;
> >> + LOCK_LOG_LOCK("XUPGRADE", &lk->lock_object, 0, 0, file, line);
> >> + lockmgr_trace("xupgrade", 'I', lk);
> >> + v = lk->lk_lock;
> >> + x = v & ~LK_SHARE;
> >> + atomic_store_rel_ptr(&lk->lk_lock, x);
> > I think this function is to upgrade a shared (waiters/spinner) lock to
> > non-shared (spinner) lock? I'm not confident about correctness here.
> > It looks to me like there can be a race condition if multiple waiters
> > attempt to upgrade in parallel. It works by a preemption after the
> > first waiter loads `v = lk->lk_lock` and then another waiter loads
> > `v`. Actually, there doesn't seem to be anything that prevents two
> > separate calls to upgrade the lock by different waiters in sequence
> > either. I could be wrong (of course).
> We do not support shared locks and we do not share specific paths through locks
> so while the code may request a shared lock it is not shared.
ok that is helpful.
> You could be correct and I welcome you reviewing the code in the FB kernel this
> is based on.
I took a quick look. the FB kernel uses spinning and
atomic_fcmpset_ptr instead, which I think exactly addresses this
problem.
> >> +int
> >> +lockstatus(const struct lock *lk)
> >> + uintptr_t v, x;
> >> + int ret;
> >> + ret = LK_SHARED;
> >> + x = lk->lk_lock;
> >> + if ((x & LK_SHARE) == 0) {
> >> + v = rtems_bsd_mutex_owned(RTEMS_DECONST(struct lock_object*, &lk->lock_object));
> >> + if (v)
> >> + ret = LK_EXCLUSIVE;
> >> + else
> >> + ret = LK_EXCLOTHER;
> >> + } else if (x == LK_UNLOCKED) {
> >> + ret = 0;
> > there's no else {} here, is it possible that (x & LK_SHARE) != 0, and
> > (x != LK_UNLOCKED)? If so, ret may be returned without initialization?
> > Maybe just initialize ret = 0.
> Yes and thanks.
> Chris
