doubt about 'bool is_executing'
Thu Jul 29 06:56:42 UTC 2021
On 28/07/2021 21:54, Gedare Bloom wrote:
> Hello all,
> In most (all?) the SMP ports, we have in the CPU Context Control:
>    bool is_executing;
Yes, all SMP ports need this. It is used to implement a TTAS lock in the
context switch:
https://docs.rtems.org/branches/master/c-user/symmetric_multiprocessing_services.html#thread-dispatch-details
> This variable often is accessed through assembly language (i.e.,
> during the context switch), using something like
> ARCH_CONTEXT_CONTROL_IS_EXECUTING_OFFSET. Unfortunately, the 'bool'
> type is not standard, or rather its size is implementation-defined.  I
> think it is generally an 8-bit value though for us. I see that the
> riscv port uses explicitly a uint32_t so that's nice.
> I think we should replace 'bool' with uint8_t in the other ports that
> are using byte-size accesses from assembly, just to be well-defined.
> Most likely, this doesn't actually affect anything and I'm just a
> little paranoid.
Is the bool size and alignment not defined by the ABI? We don't have to
use this type, we could also use an uint32_t or whatever. The convention
is that a zero value is false, everything else is true.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
