[PATCH] rtems: Generate <rtems/bspIo.h>
Joel Sherrill
joel at rtems.org
Fri Jul 30 13:55:27 UTC 2021
On Fri, Jul 30, 2021, 8:33 AM Sebastian Huber <
> On 30/07/2021 15:25, Joel Sherrill wrote:
> > On Fri, Jul 30, 2021 at 1:52 AM Sebastian Huber
> > <sebastian.huber at embedded-brains.de> wrote:
> >> On 30/07/2021 00:54, Chris Johns wrote:
> >>> On 29/7/21 10:59 pm, Sebastian Huber wrote:
> >>>> On 29/07/2021 14:51, Sebastian Huber wrote:
> >>>>> Change license to BSD-2-Clause according to file histories and
> >>>>> documentation re-licensing agreement.
> >>>>> Place the group into the I/O Manager group. Add all source files to
> the
> >>>>> group.
> >>>>> Update #3899.
> >>>>> Update #3993.
> > Should the specification include what format specifiers are supported?
> Those
> > would seem to be API contracts/requirements.
> What we have currently is this:
> .. rubric:: PARAMETERS:
> ``fmt``
> This parameter is a printf()-style format string.
> .. rubric:: CONSTRAINTS:
> The following constraints apply to this directive:
> * The directive may be called from within any runtime context.
> * The directive will not cause the calling task to be preempted.
> * Formatting of floating point numbers is not supported.
> Doing a detailed documentation of the supported format specifiers would
> be a bit of work.
I wasn't thinking of heavy detail. Just a list of which specifiers are
supported and maybe some general missing format options. Beyond that see
printf for details.
I was thinking you would need a requirement for a specifier that is
supported. Otherwise you don't have traceability to the entire source code.
Trying to focus on general description of what was present for the missing
the requirements are positive, not negative.
--joel
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210730/f691cc16/attachment.html>
