[PATCH] rtems: Generate <rtems/bspIo.h>
Fri Jul 30 15:32:53 UTC 2021
On Fri, Jul 30, 2021, 9:24 AM Sebastian Huber <
> On 30/07/2021 15:55, Joel Sherrill wrote:
> > On Fri, Jul 30, 2021, 8:33 AM Sebastian Huber
> > <sebastian.huber at embedded-brains.de
> > <mailto:sebastian.huber at embedded-brains.de>> wrote:
> >     On 30/07/2021 15:25, Joel Sherrill wrote:
> >      > On Fri, Jul 30, 2021 at 1:52 AM Sebastian Huber
> >      >> On 30/07/2021 00:54, Chris Johns wrote:
> >      >>> On 29/7/21 10:59 pm, Sebastian Huber wrote:
> >      >>>> On 29/07/2021 14:51, Sebastian Huber wrote:
> >      >>>>> Change license to BSD-2-Clause according to file histories and
> >      >>>>> documentation re-licensing agreement.
> >      >>>>> Place the group into the I/O Manager group.  Add all source
> >     files to the
> >      >>>>> group.
> >      >>>>> Update #3899.
> >      >>>>> Update #3993.
> >      > Should the specification include what format specifiers are
> >     supported? Those
> >      > would seem to be API contracts/requirements.
> >     What we have currently is this:
> >     .. rubric:: PARAMETERS:
> >     ``fmt``
> >           This parameter is a printf()-style format string.
> >     .. rubric:: CONSTRAINTS:
> >     The following constraints apply to this directive:
> >     * The directive may be called from within any runtime context.
> >     * The directive will not cause the calling task to be preempted.
> >     * Formatting of floating point numbers is not supported.
> >     Doing a detailed documentation of the supported format specifiers
> would
> >     be a bit of work.
> > I wasn't thinking of heavy detail. Just a list of which specifiers are
> > supported and maybe some general missing format options. Beyond that see
> > printf for details.
> > I was thinking you would need a requirement for a specifier that is
> > supported. Otherwise you don't have traceability to the entire source
> code.
> > Trying to focus on general description of what was present for the
> > missing the requirements are positive, not negative.
> For the space profile I only need rtems_putc(), rtems_put_char(), and
> getchark(). The _IO_Vprintf() belongs to the test code.
Ok.  Feel free.to.movr forward.
And fwiw that method is the most uncovered code in the score. It doesn't
have good test coverage.
--joel
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210730/f512a3cc/attachment.html>
