Error when trying to build llvm
Joel Sherrill
joel at rtems.org
Fri Jul 30 19:57:27 UTC 2021
On Fri, Jul 30, 2021 at 1:32 PM Ida Delphine <idadelm at gmail.com> wrote:
> Just installed swig and now met with another error. Can't find what is really wrong.
> RTEMS Source Builder - Set Builder, 6 (c938bd7cbe16)
> Build Set: 6/rtems-llvm
> Build Set: devel/swig.bset
> Build Set: devel/autotools-internal.bset
> config: devel/autoconf-2.69-1.cfg
> package: autoconf-2.69-x86_64-linux-gnu-1
> building: autoconf-2.69-x86_64-linux-gnu-1
> sizes: autoconf-2.69-x86_64-linux-gnu-1: 7.493MB (installed: 0.000B)
> cleaning: autoconf-2.69-x86_64-linux-gnu-1
> config: devel/automake-1.12.6-1.cfg
> package: automake-1.12.6-x86_64-linux-gnu-1
> building: automake-1.12.6-x86_64-linux-gnu-1
> sizes: automake-1.12.6-x86_64-linux-gnu-1: 8.085MB (installed: 0.000B)
> cleaning: automake-1.12.6-x86_64-linux-gnu-1
> config: devel/libtool-2.4.2-1.cfg
> package: libtool-2.4.2-x86_64-linux-gnu-1
> building: libtool-2.4.2-x86_64-linux-gnu-1
> sizes: libtool-2.4.2-x86_64-linux-gnu-1: 12.775MB (installed: 0.000B)
> cleaning: libtool-2.4.2-x86_64-linux-gnu-1
> Build Sizes: usage: 12.775MB total: 79.327MB (sources: 79.308MB, patches: 19.412KB, installed 0.000B)
> Build Set: Time 0:00:17.154758
> config: devel/swig-4.0.1.cfg
> package: swig-4.0.1-x86_64-linux-gnu-1
> building: swig-4.0.1-x86_64-linux-gnu-1
> sizes: swig-4.0.1-x86_64-linux-gnu-1: 106.899MB (installed: 0.000B)
> cleaning: swig-4.0.1-x86_64-linux-gnu-1
> Build Set: Time 0:01:27.065144
> config: tools/rtems-llvm-8.0.1.cfg
> package: rtems-llvm-8.0.1-x86_64-linux-gnu-1
> building: rtems-llvm-8.0.1-x86_64-linux-gnu-1
> error: building rtems-llvm-8.0.1-x86_64-linux-gnu-1
> Build FAILED
> See error report: rsb-report-rtems-llvm-8.0.1-x86_64-linux-gnu-1.txt
> Build Set: Time 0:04:53.632167
> Build FAILED
> The error report: https://pastebin.com/nFYzqWqY
I don't see any compiler errors. I see warnings and if they built with -Werror,
then it would fail.
I think there is a way to force a cmake build to show the command invoked. This
has lots of details:
https://stackoverflow.com/questions/2670121/using-cmake-with-gnu-make-how-can-i-see-the-exact-commands
I think you can manually go down into the build directory which is left
after the build failure, and type "make VERBOSE=1" >ida.log 2>&1"
Then the file ida.log should show all the commands.
The URL above shows how to do it via cmake. But in this case, I think
going into the RSB build/ directory and doing the make by hand will
give us the next bit of into -- does it compile with -Werror.
> On Fri, Jul 30, 2021 at 2:24 PM Joel Sherrill <joel at rtems.org> wrote:
>> On Fri, Jul 30, 2021 at 12:46 AM Ida Delphine <idadelm at gmail.com> wrote:
>> > Hello everyone,
>> > I have been trying to build llvm using the command
>> > ../source-builder/sb-set-builder --prefix=$HOME/development/rtems/6 6/rtems-llvm
>> > Here's the error report
>> > https://pastebin.com/vAXgwXMW
>> It would have been helpful to have put the error lines in the email
>> and a link to the full log.
>> -- Could NOT find libedit (missing: libedit_INCLUDE_DIRS libedit_LIBRARIES)
>> -- Could NOT find Doxygen (missing: DOXYGEN_EXECUTABLE)
>> CMake Error at /usr/share/cmake-3.16/Modules/FindPackageHandleStandardArgs.cmake:146
>> (message):
>> Could NOT find SWIG (missing: SWIG_EXECUTABLE SWIG_DIR)
>> Call Stack (most recent call first):
>> /usr/share/cmake-3.16/Modules/FindPackageHandleStandardArgs.cmake:393
>> (_FPHSA_FAILURE_MESSAGE)
>> /usr/share/cmake-3.16/Modules/FindSWIG.cmake:64
>> (FIND_PACKAGE_HANDLE_STANDARD_ARGS)
>> tools/lldb/scripts/CMakeLists.txt:18 (find_package)
>> > Please what am I missing?
>> Based on google results and other people having the same issue, you may not
>> have swig installed. It is something to install with npm from what I
>> see. Other people
>> have it but need to set some variables to let cmake know where it is.
>> Hopefully installing it will help. Chris should comment on this from
>> an RSB perspective.
>> --joel
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
