POSIX Issue 8 Draft and _POSIX_VERSION
Joel Sherrill
joel at rtems.org
Tue Jun 1 19:42:21 UTC 2021
Hi
Over in RTEMS, we have a GSoC student looking at adding the new methods
called out in the draft Issue 8. The first step would be adding prototypes
for these. I assume these would be guarded by _POSIX_VERSION with the
appropriate value. If all this much is correct, then the stumbling block
is...
Unfortunately, the actual value for _POSIX_VERSION is 20yymmL.in the
current draft. Any suggestions on what to set it if we submit patches
before the standard is finalized?
Thanks.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210601/0f97cb80/attachment.html>
