[PATCH rtems 2/2] cpu/armv7m: Fix initialization of MPU regions
Gedare Bloom
gedare at rtems.org
Fri Jun 4 17:41:13 UTC 2021
ok
On Fri, Jun 4, 2021 at 1:47 AM Christian Mauderer
<christian.mauderer at embedded-brains.de> wrote:
> The write to RBAR didn't have the valid flag set. Therefore the write to
> RASR had an influence on the previously set region. That means for
> example that if Region 0 had been enabled but 1 should be disabled due
> to a size of 0, the previous code would have disabled region 0 instead.
> This patch fixes that behaviour.
> Close #4450
> cpukit/score/cpu/arm/include/rtems/score/armv7m.h | 2 +-
> 1 file changed, 1 insertion(+), 1 deletion(-)
> diff --git a/cpukit/score/cpu/arm/include/rtems/score/armv7m.h b/cpukit/score/cpu/arm/include/rtems/score/armv7m.h
> index a5eaaef418..1803c8d8ca 100644
> --- a/cpukit/score/cpu/arm/include/rtems/score/armv7m.h
> +++ b/cpukit/score/cpu/arm/include/rtems/score/armv7m.h
> @@ -660,7 +660,7 @@ static inline void _ARMV7M_MPU_Set_region(
> rbar = (uintptr_t) begin | region | ARMV7M_MPU_RBAR_VALID;
> rasr |= _ARMV7M_MPU_Get_region_size(size);
> } else {
> - rbar = region;
> + rbar = ARMV7M_MPU_RBAR_VALID | region;
> rasr = 0;
> 2.26.2
> devel mailing list
> devel at rtems.org
