[PATCH v2 2/2] i386: Remove unneeded include header files
Jan Sommer jan.sommer at dlr.de
Mon Jun 7 08:52:49 UTC 2021
 .../sys/i386/include/machine/intr_machdep.h   |    6 -
 rtemsbsd/include/x86/bus.h                    | 1109 ----------------
 rtemsbsd/include/x86/specialreg.h             | 1143 -----------------
 3 files changed, 2258 deletions(-)
 delete mode 100644 freebsd/sys/i386/include/machine/intr_machdep.h
 delete mode 100644 rtemsbsd/include/x86/bus.h
 delete mode 100644 rtemsbsd/include/x86/specialreg.h
diff --git a/freebsd/sys/i386/include/machine/intr_machdep.h b/freebsd/sys/i386/include/machine/intr_machdep.h
deleted file mode 100644
index a0b28387..00000000
--- a/freebsd/sys/i386/include/machine/intr_machdep.h
+++ /dev/null
@@ -1,6 +0,0 @@
- * This file is in the public domain.
-/* $FreeBSD$ */
-#include <x86/intr_machdep.h>
diff --git a/rtemsbsd/include/x86/bus.h b/rtemsbsd/include/x86/bus.h
index 2427ae51..00000000
--- a/rtemsbsd/include/x86/bus.h
+++ /dev/null
@@ -1,1109 +0,0 @@
- * SPDX-License-Identifier: BSD-3-Clause AND BSD-2-Clause-NetBSDE
- * Copyright (c) KATO Takenori, 1999.
- * All rights reserved.  Unpublished rights reserved under the copyright
- * laws of Japan.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * 1. Redistributions of source code must retain the above copyright
- *    notice, this list of conditions and the following disclaimer as
- *    the first lines of this file unmodified.
- * 2. Redistributions in binary form must reproduce the above copyright
- *    notice, this list of conditions and the following disclaimer in the
- *    documentation and/or other materials provided with the distribution.
- * 3. The name of the author may not be used to endorse or promote products
- *    derived from this software without specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR
- * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
- * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
- * IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
- * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
- * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
- * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
- * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
- * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
- * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
- * $FreeBSD$
-/*	$NetBSD: bus.h,v 1.12 1997/10/01 08:25:15 fvdl Exp $	*/
- * Copyright (c) 1996, 1997 The NetBSD Foundation, Inc.
- * This code is derived from software contributed to The NetBSD Foundation
- * by Jason R. Thorpe of the Numerical Aerospace Simulation Facility,
- * NASA Ames Research Center.
- * are met:
- *    notice, this list of conditions and the following disclaimer.
- * THIS SOFTWARE IS PROVIDED BY THE NETBSD FOUNDATION, INC. AND CONTRIBUTORS
- * ``AS IS'' AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
- * TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
- * PURPOSE ARE DISCLAIMED.  IN NO EVENT SHALL THE FOUNDATION OR CONTRIBUTORS
- * BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
- * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
- * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
- * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
- * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
- * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
- * POSSIBILITY OF SUCH DAMAGE.
- * Copyright (c) 1996 Charles M. Hannum.  All rights reserved.
- * Copyright (c) 1996 Christopher G. Demetriou.  All rights reserved.
- * are met:
- * 3. All advertising materials mentioning features or use of this software
- *    must display the following acknowledgement:
- *      This product includes software developed by Christopher G. Demetriou
- *	for the NetBSD Project.
- * 4. The name of the author may not be used to endorse or promote products
-#ifndef _X86_BUS_H_
-#define _X86_BUS_H_
-#include <machine/_bus.h>
-#include <machine/cpufunc.h>
-#ifndef __GNUCLIKE_ASM
-#error "no assembler code for your compiler"
-#endif
- * Values for the x86 bus space tag, not to be used directly by MI code.
-#define	X86_BUS_SPACE_IO	0	/* space is i/o space */
-#define	X86_BUS_SPACE_MEM	1	/* space is mem space */
-#define BUS_SPACE_MAXSIZE_24BIT	0xFFFFFF
-#define BUS_SPACE_MAXSIZE_32BIT 0xFFFFFFFF
-#if defined(__amd64__)
-#define BUS_SPACE_MAXSIZE	0xFFFFFFFFFFFFFFFFULL
-#else
-#endif
-#define BUS_SPACE_MAXADDR_24BIT	0xFFFFFF
-#define BUS_SPACE_MAXADDR_32BIT 0xFFFFFFFF
-#if defined(__amd64__) || defined(PAE)
-#define BUS_SPACE_MAXADDR_48BIT	0xFFFFFFFFFFFFULL
-#define BUS_SPACE_MAXADDR	0xFFFFFFFFFFFFFFFFULL
-#else
-#endif
-#define BUS_SPACE_INVALID_DATA	(~0)
-#define BUS_SPACE_UNRESTRICTED	(~0)
- * Map a region of device bus space into CPU virtual address space.
-int bus_space_map(bus_space_tag_t tag, bus_addr_t addr, bus_size_t size,
-    int flags, bus_space_handle_t *bshp);
- * Unmap a region of device bus space.
-void bus_space_unmap(bus_space_tag_t tag, bus_space_handle_t bsh,
-    bus_size_t size);
- * Get a new handle for a subregion of an already-mapped area of bus space.
-static __inline int bus_space_subregion(bus_space_tag_t t,
-					bus_space_handle_t bsh,
-					bus_size_t offset, bus_size_t size,
-					bus_space_handle_t *nbshp);
-bus_space_subregion(bus_space_tag_t t __unused, bus_space_handle_t bsh,
-		    bus_size_t offset, bus_size_t size __unused,
-	*nbshp = bsh + offset;
-	return (0);
- * Allocate a region of memory that is accessible to devices in bus space.
-int	bus_space_alloc(bus_space_tag_t t, bus_addr_t rstart,
-			bus_addr_t rend, bus_size_t size, bus_size_t align,
-			bus_size_t boundary, int flags, bus_addr_t *addrp,
-			bus_space_handle_t *bshp);
- * Free a region of bus space accessible memory.
-static __inline void bus_space_free(bus_space_tag_t t, bus_space_handle_t bsh,
-				    bus_size_t size);
-bus_space_free(bus_space_tag_t t __unused, bus_space_handle_t bsh __unused,
-	       bus_size_t size __unused)
- * Read a 1, 2, 4, or 8 byte quantity from bus space
- * described by tag/handle/offset.
-static __inline u_int8_t bus_space_read_1(bus_space_tag_t tag,
-					  bus_space_handle_t handle,
-					  bus_size_t offset);
-static __inline u_int16_t bus_space_read_2(bus_space_tag_t tag,
-static __inline u_int32_t bus_space_read_4(bus_space_tag_t tag,
-#ifdef __amd64__
-static __inline uint64_t bus_space_read_8(bus_space_tag_t tag,
-#endif
-bus_space_read_1(bus_space_tag_t tag, bus_space_handle_t handle,
-	if (tag == X86_BUS_SPACE_IO)
-		return (inb(handle + offset));
-	return (*(volatile u_int8_t *)(handle + offset));
-bus_space_read_2(bus_space_tag_t tag, bus_space_handle_t handle,
-		return (inw(handle + offset));
-	return (*(volatile u_int16_t *)(handle + offset));
-bus_space_read_4(bus_space_tag_t tag, bus_space_handle_t handle,
-		return (inl(handle + offset));
-	return (*(volatile u_int32_t *)(handle + offset));
-#ifdef __amd64__
-bus_space_read_8(bus_space_tag_t tag, bus_space_handle_t handle,
-	if (tag == X86_BUS_SPACE_IO) /* No 8 byte IO space access on x86 */
-		return (BUS_SPACE_INVALID_DATA);
-	return (*(volatile uint64_t *)(handle + offset));
-#endif
- * Read `count' 1, 2, 4, or 8 byte quantities from bus space
- * described by tag/handle/offset and copy into buffer provided.
-static __inline void bus_space_read_multi_1(bus_space_tag_t tag,
-					    bus_size_t offset, u_int8_t *addr,
-					    size_t count);
-static __inline void bus_space_read_multi_2(bus_space_tag_t tag,
-					    bus_size_t offset, u_int16_t *addr,
-					    size_t count);
-static __inline void bus_space_read_multi_4(bus_space_tag_t tag,
-					    bus_size_t offset, u_int32_t *addr,
-					    size_t count);
-bus_space_read_multi_1(bus_space_tag_t tag, bus_space_handle_t bsh,
-		       bus_size_t offset, u_int8_t *addr, size_t count)
-		insb(bsh + offset, addr, count);
-	else {
-#ifdef __GNUCLIKE_ASM
-		__asm __volatile("				\n\
-			cld					\n\
-		1:	movb (%2),%%al				\n\
-			stosb					\n\
-			loop 1b"				:
-		    "=D" (addr), "=c" (count)			:
-		    "r" (bsh + offset), "0" (addr), "1" (count)	:
-		    "%eax", "memory");
-#endif
-bus_space_read_multi_2(bus_space_tag_t tag, bus_space_handle_t bsh,
-		       bus_size_t offset, u_int16_t *addr, size_t count)
-		insw(bsh + offset, addr, count);
-	else {
-			cld					\n\
-		1:	movw (%2),%%ax				\n\
-			stosw					\n\
-			loop 1b"				:
-#endif
-bus_space_read_multi_4(bus_space_tag_t tag, bus_space_handle_t bsh,
-		       bus_size_t offset, u_int32_t *addr, size_t count)
-		insl(bsh + offset, addr, count);
-	else {
-			cld					\n\
-		1:	movl (%2),%%eax				\n\
-			stosl					\n\
-			loop 1b"				:
-#endif
-#if 0	/* Cause a link error for bus_space_read_multi_8 */
-#define	bus_space_read_multi_8	!!! bus_space_read_multi_8 unimplemented !!!
-#endif
- * described by tag/handle and starting at `offset' and copy into
- * buffer provided.
-static __inline void bus_space_read_region_1(bus_space_tag_t tag,
-					     size_t count);
-static __inline void bus_space_read_region_2(bus_space_tag_t tag,
-					     size_t count);
-static __inline void bus_space_read_region_4(bus_space_tag_t tag,
-					     size_t count);
-bus_space_read_region_1(bus_space_tag_t tag, bus_space_handle_t bsh,
-	if (tag == X86_BUS_SPACE_IO) {
-		int _port_ = bsh + offset;
-			cld					\n\
-		1:	inb %w2,%%al				\n\
-			stosb					\n\
-			incl %2					\n\
-			loop 1b"				:
-		    "=D" (addr), "=c" (count), "=d" (_port_)	:
-		    "0" (addr), "1" (count), "2" (_port_)	:
-		    "%eax", "memory", "cc");
-#endif
-	} else {
-		bus_space_handle_t _port_ = bsh + offset;
-			cld					\n\
-			repne					\n\
-			movsb"					:
-		    "=D" (addr), "=c" (count), "=S" (_port_)	:
-		    "memory", "cc");
-#endif
-bus_space_read_region_2(bus_space_tag_t tag, bus_space_handle_t bsh,
-			cld					\n\
-		1:	inw %w2,%%ax				\n\
-			stosw					\n\
-			addl $2,%2				\n\
-			loop 1b"				:
-#endif
-	} else {
-			cld					\n\
-			repne					\n\
-			movsw"					:
-		    "memory", "cc");
-#endif
-bus_space_read_region_4(bus_space_tag_t tag, bus_space_handle_t bsh,
-			cld					\n\
-		1:	inl %w2,%%eax				\n\
-			stosl					\n\
-			addl $4,%2				\n\
-			loop 1b"				:
-#endif
-	} else {
-			cld					\n\
-			repne					\n\
-			movsl"					:
-		    "memory", "cc");
-#endif
-#if 0	/* Cause a link error for bus_space_read_region_8 */
-#define	bus_space_read_region_8	!!! bus_space_read_region_8 unimplemented !!!
-#endif
- * Write the 1, 2, 4, or 8 byte value `value' to bus space
-static __inline void bus_space_write_1(bus_space_tag_t tag,
-				       bus_size_t offset, u_int8_t value);
-static __inline void bus_space_write_2(bus_space_tag_t tag,
-				       bus_size_t offset, u_int16_t value);
-static __inline void bus_space_write_4(bus_space_tag_t tag,
-				       bus_size_t offset, u_int32_t value);
-#ifdef __amd64__
-static __inline void bus_space_write_8(bus_space_tag_t tag,
-				       bus_size_t offset, uint64_t value);
-#endif
-bus_space_write_1(bus_space_tag_t tag, bus_space_handle_t bsh,
-		outb(bsh + offset, value);
-	else
-		*(volatile u_int8_t *)(bsh + offset) = value;
-bus_space_write_2(bus_space_tag_t tag, bus_space_handle_t bsh,
-		outw(bsh + offset, value);
-	else
-		*(volatile u_int16_t *)(bsh + offset) = value;
-bus_space_write_4(bus_space_tag_t tag, bus_space_handle_t bsh,
-		outl(bsh + offset, value);
-	else
-		*(volatile u_int32_t *)(bsh + offset) = value;
-#ifdef __amd64__
-bus_space_write_8(bus_space_tag_t tag, bus_space_handle_t bsh,
-		return;
-	else
-		*(volatile uint64_t *)(bsh + offset) = value;
-#endif
- * Write `count' 1, 2, 4, or 8 byte quantities from the buffer
- * provided to bus space described by tag/handle/offset.
-static __inline void bus_space_write_multi_1(bus_space_tag_t tag,
-					     const u_int8_t *addr,
-					     size_t count);
-static __inline void bus_space_write_multi_2(bus_space_tag_t tag,
-					     const u_int16_t *addr,
-					     size_t count);
-static __inline void bus_space_write_multi_4(bus_space_tag_t tag,
-					     const u_int32_t *addr,
-					     size_t count);
-bus_space_write_multi_1(bus_space_tag_t tag, bus_space_handle_t bsh,
-			bus_size_t offset, const u_int8_t *addr, size_t count)
-		outsb(bsh + offset, addr, count);
-	else {
-			cld					\n\
-		1:	lodsb					\n\
-			movb %%al,(%2)				\n\
-			loop 1b"				:
-		    "=S" (addr), "=c" (count)			:
-#endif
-bus_space_write_multi_2(bus_space_tag_t tag, bus_space_handle_t bsh,
-			bus_size_t offset, const u_int16_t *addr, size_t count)
-		outsw(bsh + offset, addr, count);
-	else {
-			cld					\n\
-		1:	lodsw					\n\
-			movw %%ax,(%2)				\n\
-			loop 1b"				:
-#endif
-bus_space_write_multi_4(bus_space_tag_t tag, bus_space_handle_t bsh,
-			bus_size_t offset, const u_int32_t *addr, size_t count)
-		outsl(bsh + offset, addr, count);
-	else {
-			cld					\n\
-		1:	lodsl					\n\
-			movl %%eax,(%2)				\n\
-			loop 1b"				:
-#endif
-#if 0	/* Cause a link error for bus_space_write_multi_8 */
-#define	bus_space_write_multi_8(t, h, o, a, c)				\
-			!!! bus_space_write_multi_8 unimplemented !!!
-#endif
- * Write `count' 1, 2, 4, or 8 byte quantities from the buffer provided
- * to bus space described by tag/handle starting at `offset'.
-static __inline void bus_space_write_region_1(bus_space_tag_t tag,
-					      size_t count);
-static __inline void bus_space_write_region_2(bus_space_tag_t tag,
-					      size_t count);
-static __inline void bus_space_write_region_4(bus_space_tag_t tag,
-					      size_t count);
-bus_space_write_region_1(bus_space_tag_t tag, bus_space_handle_t bsh,
-			cld					\n\
-		1:	lodsb					\n\
-			outb %%al,%w0				\n\
-			incl %0					\n\
-			loop 1b"				:
-		    "=d" (_port_), "=S" (addr), "=c" (count)	:
-		    "0" (_port_), "1" (addr), "2" (count)	:
-#endif
-	} else {
-			cld					\n\
-			repne					\n\
-			movsb"					:
-		    "=D" (_port_), "=S" (addr), "=c" (count)	:
-		    "memory", "cc");
-#endif
-bus_space_write_region_2(bus_space_tag_t tag, bus_space_handle_t bsh,
-			cld					\n\
-		1:	lodsw					\n\
-			outw %%ax,%w0				\n\
-			addl $2,%0				\n\
-			loop 1b"				:
-#endif
-	} else {
-			cld					\n\
-			repne					\n\
-			movsw"					:
-		    "memory", "cc");
-#endif
-bus_space_write_region_4(bus_space_tag_t tag, bus_space_handle_t bsh,
-			cld					\n\
-		1:	lodsl					\n\
-			outl %%eax,%w0				\n\
-			addl $4,%0				\n\
-			loop 1b"				:
-#endif
-	} else {
-			cld					\n\
-			repne					\n\
-			movsl"					:
-		    "memory", "cc");
-#endif
-#if 0	/* Cause a link error for bus_space_write_region_8 */
-#define	bus_space_write_region_8					\
-			!!! bus_space_write_region_8 unimplemented !!!
-#endif
- * Write the 1, 2, 4, or 8 byte value `val' to bus space described
- * by tag/handle/offset `count' times.
-static __inline void bus_space_set_multi_1(bus_space_tag_t tag,
-					   u_int8_t value, size_t count);
-static __inline void bus_space_set_multi_2(bus_space_tag_t tag,
-					   u_int16_t value, size_t count);
-static __inline void bus_space_set_multi_4(bus_space_tag_t tag,
-					   u_int32_t value, size_t count);
-bus_space_set_multi_1(bus_space_tag_t tag, bus_space_handle_t bsh,
-		      bus_size_t offset, u_int8_t value, size_t count)
-	bus_space_handle_t addr = bsh + offset;
-		while (count--)
-			outb(addr, value);
-	else
-		while (count--)
-			*(volatile u_int8_t *)(addr) = value;
-bus_space_set_multi_2(bus_space_tag_t tag, bus_space_handle_t bsh,
-		     bus_size_t offset, u_int16_t value, size_t count)
-		while (count--)
-			outw(addr, value);
-	else
-		while (count--)
-			*(volatile u_int16_t *)(addr) = value;
-bus_space_set_multi_4(bus_space_tag_t tag, bus_space_handle_t bsh,
-		      bus_size_t offset, u_int32_t value, size_t count)
-		while (count--)
-			outl(addr, value);
-	else
-		while (count--)
-			*(volatile u_int32_t *)(addr) = value;
-#if 0	/* Cause a link error for bus_space_set_multi_8 */
-#define	bus_space_set_multi_8 !!! bus_space_set_multi_8 unimplemented !!!
-#endif
- * Write `count' 1, 2, 4, or 8 byte value `val' to bus space described
- * by tag/handle starting at `offset'.
-static __inline void bus_space_set_region_1(bus_space_tag_t tag,
-					    size_t count);
-static __inline void bus_space_set_region_2(bus_space_tag_t tag,
-					    size_t count);
-static __inline void bus_space_set_region_4(bus_space_tag_t tag,
-					    size_t count);
-bus_space_set_region_1(bus_space_tag_t tag, bus_space_handle_t bsh,
-		for (; count != 0; count--, addr++)
-	else
-bus_space_set_region_2(bus_space_tag_t tag, bus_space_handle_t bsh,
-		for (; count != 0; count--, addr += 2)
-	else
-bus_space_set_region_4(bus_space_tag_t tag, bus_space_handle_t bsh,
-		for (; count != 0; count--, addr += 4)
-	else
-#if 0	/* Cause a link error for bus_space_set_region_8 */
-#define	bus_space_set_region_8	!!! bus_space_set_region_8 unimplemented !!!
-#endif
- * Copy `count' 1, 2, 4, or 8 byte values from bus space starting
- * at tag/bsh1/off1 to bus space starting at tag/bsh2/off2.
-static __inline void bus_space_copy_region_1(bus_space_tag_t tag,
-					     bus_space_handle_t bsh1,
-					     bus_size_t off1,
-					     bus_space_handle_t bsh2,
-					     bus_size_t off2, size_t count);
-static __inline void bus_space_copy_region_2(bus_space_tag_t tag,
-					     bus_size_t off1,
-static __inline void bus_space_copy_region_4(bus_space_tag_t tag,
-					     bus_size_t off1,
-bus_space_copy_region_1(bus_space_tag_t tag, bus_space_handle_t bsh1,
-			bus_size_t off1, bus_space_handle_t bsh2,
-	bus_space_handle_t addr1 = bsh1 + off1;
-	bus_space_handle_t addr2 = bsh2 + off2;
-		if (addr1 >= addr2) {
-			/* src after dest: copy forward */
-			for (; count != 0; count--, addr1++, addr2++)
-				outb(addr2, inb(addr1));
-		} else {
-			/* dest after src: copy backwards */
-			for (addr1 += (count - 1), addr2 += (count - 1);
-			    count != 0; count--, addr1--, addr2--)
-	} else {
-				*(volatile u_int8_t *)(addr2) =
-				    *(volatile u_int8_t *)(addr1);
-		} else {
-bus_space_copy_region_2(bus_space_tag_t tag, bus_space_handle_t bsh1,
-			for (; count != 0; count--, addr1 += 2, addr2 += 2)
-				outw(addr2, inw(addr1));
-		} else {
-			for (addr1 += 2 * (count - 1), addr2 += 2 * (count - 1);
-			    count != 0; count--, addr1 -= 2, addr2 -= 2)
-	} else {
-				*(volatile u_int16_t *)(addr2) =
-				    *(volatile u_int16_t *)(addr1);
-		} else {
-bus_space_copy_region_4(bus_space_tag_t tag, bus_space_handle_t bsh1,
-			for (; count != 0; count--, addr1 += 4, addr2 += 4)
-				outl(addr2, inl(addr1));
-		} else {
-			for (addr1 += 4 * (count - 1), addr2 += 4 * (count - 1);
-			    count != 0; count--, addr1 -= 4, addr2 -= 4)
-	} else {
-				*(volatile u_int32_t *)(addr2) =
-				    *(volatile u_int32_t *)(addr1);
-		} else {
-#if 0	/* Cause a link error for bus_space_copy_8 */
-#define	bus_space_copy_region_8	!!! bus_space_copy_region_8 unimplemented !!!
-#endif
- * Bus read/write barrier methods.
- *	void bus_space_barrier(bus_space_tag_t tag, bus_space_handle_t bsh,
- *			       bus_size_t offset, bus_size_t len, int flags);
- * Note that BUS_SPACE_BARRIER_WRITE doesn't do anything other than
- * prevent reordering by the compiler; all Intel x86 processors currently
- * retire operations outside the CPU in program order.
-#define	BUS_SPACE_BARRIER_READ	0x01		/* force read barrier */
-#define	BUS_SPACE_BARRIER_WRITE	0x02		/* force write barrier */
-bus_space_barrier(bus_space_tag_t tag __unused, bus_space_handle_t bsh __unused,
-		  bus_size_t offset __unused, bus_size_t len __unused, int flags)
-	if (flags & BUS_SPACE_BARRIER_READ)
-#ifdef __amd64__
-		__asm __volatile("lock; addl $0,0(%%rsp)" : : : "memory");
-#else
-		__asm __volatile("lock; addl $0,0(%%esp)" : : : "memory");
-#endif
-	else
-		__compiler_membar();
-#endif
-#ifdef BUS_SPACE_NO_LEGACY
-#undef inb
-#undef outb
-#define inb(a) compiler_error
-#define inw(a) compiler_error
-#define inl(a) compiler_error
-#define outb(a, b) compiler_error
-#define outw(a, b) compiler_error
-#define outl(a, b) compiler_error
-#endif
-#include <machine/bus_dma.h>
- * Stream accesses are the same as normal accesses on x86; there are no
- * supported bus systems with an endianess different from the host one.
-#define	bus_space_read_stream_1(t, h, o)	bus_space_read_1((t), (h), (o))
-#define	bus_space_read_stream_2(t, h, o)	bus_space_read_2((t), (h), (o))
-#define	bus_space_read_stream_4(t, h, o)	bus_space_read_4((t), (h), (o))
-#define	bus_space_read_multi_stream_1(t, h, o, a, c) \
-	bus_space_read_multi_1((t), (h), (o), (a), (c))
-#define	bus_space_read_multi_stream_2(t, h, o, a, c) \
-	bus_space_read_multi_2((t), (h), (o), (a), (c))
-#define	bus_space_read_multi_stream_4(t, h, o, a, c) \
-	bus_space_read_multi_4((t), (h), (o), (a), (c))
-#define	bus_space_write_stream_1(t, h, o, v) \
-	bus_space_write_1((t), (h), (o), (v))
-#define	bus_space_write_stream_2(t, h, o, v) \
-	bus_space_write_2((t), (h), (o), (v))
-#define	bus_space_write_stream_4(t, h, o, v) \
-	bus_space_write_4((t), (h), (o), (v))
-#define	bus_space_write_multi_stream_1(t, h, o, a, c) \
-	bus_space_write_multi_1((t), (h), (o), (a), (c))
-#define	bus_space_write_multi_stream_2(t, h, o, a, c) \
-	bus_space_write_multi_2((t), (h), (o), (a), (c))
-#define	bus_space_write_multi_stream_4(t, h, o, a, c) \
-	bus_space_write_multi_4((t), (h), (o), (a), (c))
-#define	bus_space_set_multi_stream_1(t, h, o, v, c) \
-	bus_space_set_multi_1((t), (h), (o), (v), (c))
-#define	bus_space_set_multi_stream_2(t, h, o, v, c) \
-	bus_space_set_multi_2((t), (h), (o), (v), (c))
-#define	bus_space_set_multi_stream_4(t, h, o, v, c) \
-	bus_space_set_multi_4((t), (h), (o), (v), (c))
-#define	bus_space_read_region_stream_1(t, h, o, a, c) \
-	bus_space_read_region_1((t), (h), (o), (a), (c))
-#define	bus_space_read_region_stream_2(t, h, o, a, c) \
-	bus_space_read_region_2((t), (h), (o), (a), (c))
-#define	bus_space_read_region_stream_4(t, h, o, a, c) \
-	bus_space_read_region_4((t), (h), (o), (a), (c))
-#define	bus_space_write_region_stream_1(t, h, o, a, c) \
-	bus_space_write_region_1((t), (h), (o), (a), (c))
-#define	bus_space_write_region_stream_2(t, h, o, a, c) \
-	bus_space_write_region_2((t), (h), (o), (a), (c))
-#define	bus_space_write_region_stream_4(t, h, o, a, c) \
-	bus_space_write_region_4((t), (h), (o), (a), (c))
-#define	bus_space_set_region_stream_1(t, h, o, v, c) \
-	bus_space_set_region_1((t), (h), (o), (v), (c))
-#define	bus_space_set_region_stream_2(t, h, o, v, c) \
-	bus_space_set_region_2((t), (h), (o), (v), (c))
-#define	bus_space_set_region_stream_4(t, h, o, v, c) \
-	bus_space_set_region_4((t), (h), (o), (v), (c))
-#define	bus_space_copy_region_stream_1(t, h1, o1, h2, o2, c) \
-	bus_space_copy_region_1((t), (h1), (o1), (h2), (o2), (c))
-#define	bus_space_copy_region_stream_2(t, h1, o1, h2, o2, c) \
-	bus_space_copy_region_2((t), (h1), (o1), (h2), (o2), (c))
-#define	bus_space_copy_region_stream_4(t, h1, o1, h2, o2, c) \
-	bus_space_copy_region_4((t), (h1), (o1), (h2), (o2), (c))
-#endif /* _X86_BUS_H_ */
diff --git a/rtemsbsd/include/x86/specialreg.h b/rtemsbsd/include/x86/specialreg.h
index f528bad5..00000000
--- a/rtemsbsd/include/x86/specialreg.h
+++ /dev/null
@@ -1,1143 +0,0 @@
- * Copyright (c) 1991 The Regents of the University of California.
- * are met:
- * 3. Neither the name of the University nor the names of its contributors
- *    may be used to endorse or promote products derived from this software
- *    without specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
- * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- * ARE DISCLAIMED.  IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
- * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
- * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
- * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
- * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
- * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
- * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
- * SUCH DAMAGE.
- * $FreeBSD$
-#ifndef _MACHINE_SPECIALREG_H_
-#define	_MACHINE_SPECIALREG_H_
- * Bits in 386 special registers:
-#define	CR0_PE	0x00000001	/* Protected mode Enable */
-#define	CR0_MP	0x00000002	/* "Math" (fpu) Present */
-#define	CR0_EM	0x00000004	/* EMulate FPU instructions. (trap ESC only) */
-#define	CR0_TS	0x00000008	/* Task Switched (if MP, trap ESC and WAIT) */
-#define	CR0_PG	0x80000000	/* PaGing enable */
- * Bits in 486 special registers:
-#define	CR0_NE	0x00000020	/* Numeric Error enable (EX16 vs IRQ13) */
-#define	CR0_WP	0x00010000	/* Write Protect (honor page protect in
-							   all modes) */
-#define	CR0_AM	0x00040000	/* Alignment Mask (set to enable AC flag) */
-#define	CR0_NW  0x20000000	/* Not Write-through */
-#define	CR0_CD  0x40000000	/* Cache Disable */
-#define	CR3_PCID_SAVE 0x8000000000000000
-#define	CR3_PCID_MASK 0xfff
- * Bits in PPro special registers
-#define	CR4_VME	0x00000001	/* Virtual 8086 mode extensions */
-#define	CR4_PVI	0x00000002	/* Protected-mode virtual interrupts */
-#define	CR4_TSD	0x00000004	/* Time stamp disable */
-#define	CR4_DE	0x00000008	/* Debugging extensions */
-#define	CR4_PSE	0x00000010	/* Page size extensions */
-#define	CR4_PAE	0x00000020	/* Physical address extension */
-#define	CR4_MCE	0x00000040	/* Machine check enable */
-#define	CR4_PGE	0x00000080	/* Page global enable */
-#define	CR4_PCE	0x00000100	/* Performance monitoring counter enable */
-#define	CR4_FXSR 0x00000200	/* Fast FPU save/restore used by OS */
-#define	CR4_XMM	0x00000400	/* enable SIMD/MMX2 to use except 16 */
-#define	CR4_VMXE 0x00002000	/* enable VMX operation (Intel-specific) */
-#define	CR4_FSGSBASE 0x00010000	/* Enable FS/GS BASE accessing instructions */
-#define	CR4_PCIDE 0x00020000	/* Enable Context ID */
-#define	CR4_XSAVE 0x00040000	/* XSETBV/XGETBV */
-#define	CR4_SMEP 0x00100000	/* Supervisor-Mode Execution Prevention */
-#define	CR4_SMAP 0x00200000	/* Supervisor-Mode Access Prevention */
-#define	CR4_PKE	0x00400000	/* Protection Keys Enable */
- * Bits in AMD64 special registers.  EFER is 64 bits wide.
-#define	EFER_SCE 0x000000001	/* System Call Extensions (R/W) */
-#define	EFER_LME 0x000000100	/* Long mode enable (R/W) */
-#define	EFER_LMA 0x000000400	/* Long mode active (R) */
-#define	EFER_NXE 0x000000800	/* PTE No-Execute bit enable (R/W) */
-#define	EFER_SVM 0x000001000	/* SVM enable bit for AMD, reserved for Intel */
-#define	EFER_LMSLE 0x000002000	/* Long Mode Segment Limit Enable */
-#define	EFER_FFXSR 0x000004000	/* Fast FXSAVE/FSRSTOR */
-#define	EFER_TCE   0x000008000	/* Translation Cache Extension */
- * Intel Extended Features registers
-#define	XCR0	0		/* XFEATURE_ENABLED_MASK register */
-#define	XFEATURE_ENABLED_X87		0x00000001
-#define	XFEATURE_ENABLED_SSE		0x00000002
-#define	XFEATURE_ENABLED_YMM_HI128	0x00000004
-#define	XFEATURE_ENABLED_AVX		XFEATURE_ENABLED_YMM_HI128
-#define	XFEATURE_ENABLED_BNDREGS	0x00000008
-#define	XFEATURE_ENABLED_BNDCSR		0x00000010
-#define	XFEATURE_ENABLED_OPMASK		0x00000020
-#define	XFEATURE_ENABLED_ZMM_HI256	0x00000040
-#define	XFEATURE_ENABLED_HI16_ZMM	0x00000080
-#define	XFEATURE_AVX					\
-    (XFEATURE_ENABLED_X87 | XFEATURE_ENABLED_SSE | XFEATURE_ENABLED_AVX)
-#define	XFEATURE_AVX512						\
-    (XFEATURE_ENABLED_OPMASK | XFEATURE_ENABLED_ZMM_HI256 |	\
-    XFEATURE_ENABLED_HI16_ZMM)
-#define	XFEATURE_MPX					\
-    (XFEATURE_ENABLED_BNDREGS | XFEATURE_ENABLED_BNDCSR)
- * CPUID instruction features register
-#define	CPUID_FPU	0x00000001
-#define	CPUID_VME	0x00000002
-#define	CPUID_DE	0x00000004
-#define	CPUID_PSE	0x00000008
-#define	CPUID_TSC	0x00000010
-#define	CPUID_MSR	0x00000020
-#define	CPUID_PAE	0x00000040
-#define	CPUID_MCE	0x00000080
-#define	CPUID_CX8	0x00000100
-#define	CPUID_APIC	0x00000200
-#define	CPUID_B10	0x00000400
-#define	CPUID_SEP	0x00000800
-#define	CPUID_MTRR	0x00001000
-#define	CPUID_PGE	0x00002000
-#define	CPUID_MCA	0x00004000
-#define	CPUID_CMOV	0x00008000
-#define	CPUID_PAT	0x00010000
-#define	CPUID_PSE36	0x00020000
-#define	CPUID_PSN	0x00040000
-#define	CPUID_CLFSH	0x00080000
-#define	CPUID_B20	0x00100000
-#define	CPUID_DS	0x00200000
-#define	CPUID_ACPI	0x00400000
-#define	CPUID_MMX	0x00800000
-#define	CPUID_FXSR	0x01000000
-#define	CPUID_SSE	0x02000000
-#define	CPUID_XMM	0x02000000
-#define	CPUID_SSE2	0x04000000
-#define	CPUID_SS	0x08000000
-#define	CPUID_HTT	0x10000000
-#define	CPUID_TM	0x20000000
-#define	CPUID_IA64	0x40000000
-#define	CPUID_PBE	0x80000000
-#define	CPUID2_SSE3	0x00000001
-#define	CPUID2_PCLMULQDQ 0x00000002
-#define	CPUID2_DTES64	0x00000004
-#define	CPUID2_MON	0x00000008
-#define	CPUID2_DS_CPL	0x00000010
-#define	CPUID2_VMX	0x00000020
-#define	CPUID2_SMX	0x00000040
-#define	CPUID2_EST	0x00000080
-#define	CPUID2_TM2	0x00000100
-#define	CPUID2_SSSE3	0x00000200
-#define	CPUID2_CNXTID	0x00000400
-#define	CPUID2_SDBG	0x00000800
-#define	CPUID2_FMA	0x00001000
-#define	CPUID2_CX16	0x00002000
-#define	CPUID2_XTPR	0x00004000
-#define	CPUID2_PDCM	0x00008000
-#define	CPUID2_PCID	0x00020000
-#define	CPUID2_DCA	0x00040000
-#define	CPUID2_SSE41	0x00080000
-#define	CPUID2_SSE42	0x00100000
-#define	CPUID2_X2APIC	0x00200000
-#define	CPUID2_MOVBE	0x00400000
-#define	CPUID2_POPCNT	0x00800000
-#define	CPUID2_TSCDLT	0x01000000
-#define	CPUID2_AESNI	0x02000000
-#define	CPUID2_XSAVE	0x04000000
-#define	CPUID2_OSXSAVE	0x08000000
-#define	CPUID2_AVX	0x10000000
-#define	CPUID2_F16C	0x20000000
-#define	CPUID2_RDRAND	0x40000000
-#define	CPUID2_HV	0x80000000
- * Important bits in the Thermal and Power Management flags
- * CPUID.6 EAX and ECX.
-#define	CPUTPM1_SENSOR	0x00000001
-#define	CPUTPM1_TURBO	0x00000002
-#define	CPUTPM1_ARAT	0x00000004
-#define	CPUTPM1_HWP	0x00000080
-#define	CPUTPM1_HWP_NOTIFICATION	0x00000100
-#define	CPUTPM1_HWP_ACTIVITY_WINDOW	0x00000200
-#define	CPUTPM1_HWP_PERF_PREF	0x00000400
-#define	CPUTPM1_HWP_PKG	0x00000800
-#define	CPUTPM1_HWP_FLEXIBLE	0x00020000
-#define	CPUTPM2_EFFREQ	0x00000001
-/* Intel Processor Trace CPUID. */
-/* Leaf 0 ebx. */
-#define	CPUPT_CR3		(1 << 0)	/* CR3 Filtering Support */
-#define	CPUPT_PSB		(1 << 1)	/* Configurable PSB and Cycle-Accurate Mode Supported */
-#define	CPUPT_IPF		(1 << 2)	/* IP Filtering and TraceStop supported */
-#define	CPUPT_MTC		(1 << 3)	/* MTC Supported */
-#define	CPUPT_PRW		(1 << 4)	/* PTWRITE Supported */
-#define	CPUPT_PWR		(1 << 5)	/* Power Event Trace Supported */
-/* Leaf 0 ecx. */
-#define	CPUPT_TOPA		(1 << 0)	/* ToPA Output Supported */
-#define	CPUPT_TOPA_MULTI	(1 << 1)	/* ToPA Tables Allow Multiple Output Entries */
-#define	CPUPT_SINGLE		(1 << 2)	/* Single-Range Output Supported */
-#define	CPUPT_TT_OUT		(1 << 3)	/* Output to Trace Transport Subsystem Supported */
-#define	CPUPT_LINEAR_IP		(1 << 31)	/* IP Payloads are Linear IP, otherwise IP is effective */
-/* Leaf 1 eax. */
-#define	CPUPT_NADDR_S		0	/* Number of Address Ranges */
-#define	CPUPT_NADDR_M		(0x7 << CPUPT_NADDR_S)
-#define	CPUPT_MTC_BITMAP_S	16	/* Bitmap of supported MTC Period Encodings */
-#define	CPUPT_MTC_BITMAP_M	(0xffff << CPUPT_MTC_BITMAP_S)
-/* Leaf 1 ebx. */
-#define	CPUPT_CT_BITMAP_S	0	/* Bitmap of supported Cycle Threshold values */
-#define	CPUPT_CT_BITMAP_M	(0xffff << CPUPT_CT_BITMAP_S)
-#define	CPUPT_PFE_BITMAP_S	16	/* Bitmap of supported Configurable PSB Frequency encoding */
-#define	CPUPT_PFE_BITMAP_M	(0xffff << CPUPT_PFE_BITMAP_S)
- * Important bits in the AMD extended cpuid flags
-#define	AMDID_SYSCALL	0x00000800
-#define	AMDID_MP	0x00080000
-#define	AMDID_NX	0x00100000
-#define	AMDID_EXT_MMX	0x00400000
-#define	AMDID_FFXSR	0x02000000
-#define	AMDID_PAGE1GB	0x04000000
-#define	AMDID_RDTSCP	0x08000000
-#define	AMDID_LM	0x20000000
-#define	AMDID_EXT_3DNOW	0x40000000
-#define	AMDID_3DNOW	0x80000000
-#define	AMDID2_LAHF	0x00000001
-#define	AMDID2_CMP	0x00000002
-#define	AMDID2_SVM	0x00000004
-#define	AMDID2_EXT_APIC	0x00000008
-#define	AMDID2_CR8	0x00000010
-#define	AMDID2_ABM	0x00000020
-#define	AMDID2_SSE4A	0x00000040
-#define	AMDID2_MAS	0x00000080
-#define	AMDID2_PREFETCH	0x00000100
-#define	AMDID2_OSVW	0x00000200
-#define	AMDID2_IBS	0x00000400
-#define	AMDID2_XOP	0x00000800
-#define	AMDID2_SKINIT	0x00001000
-#define	AMDID2_WDT	0x00002000
-#define	AMDID2_LWP	0x00008000
-#define	AMDID2_FMA4	0x00010000
-#define	AMDID2_TCE	0x00020000
-#define	AMDID2_NODE_ID	0x00080000
-#define	AMDID2_TBM	0x00200000
-#define	AMDID2_TOPOLOGY	0x00400000
-#define	AMDID2_PCXC	0x00800000
-#define	AMDID2_PNXC	0x01000000
-#define	AMDID2_DBE	0x04000000
-#define	AMDID2_PTSC	0x08000000
-#define	AMDID2_PTSCEL2I	0x10000000
-#define	AMDID2_MWAITX	0x20000000
- * CPUID instruction 1 eax info
-#define	CPUID_STEPPING		0x0000000f
-#define	CPUID_MODEL		0x000000f0
-#define	CPUID_FAMILY		0x00000f00
-#define	CPUID_EXT_MODEL		0x000f0000
-#define	CPUID_EXT_FAMILY	0x0ff00000
-#ifdef __i386__
-#define	CPUID_TO_MODEL(id) \
-    ((((id) & CPUID_MODEL) >> 4) | \
-    ((((id) & CPUID_FAMILY) >= 0x600) ? \
-    (((id) & CPUID_EXT_MODEL) >> 12) : 0))
-#define	CPUID_TO_FAMILY(id) \
-    ((((id) & CPUID_FAMILY) >> 8) + \
-    ((((id) & CPUID_FAMILY) == 0xf00) ? \
-    (((id) & CPUID_EXT_FAMILY) >> 20) : 0))
-#else
-    (((id) & CPUID_EXT_MODEL) >> 12))
-    (((id) & CPUID_EXT_FAMILY) >> 20))
-#endif
- * CPUID instruction 1 ebx info
-#define	CPUID_BRAND_INDEX	0x000000ff
-#define	CPUID_CLFUSH_SIZE	0x0000ff00
-#define	CPUID_HTT_CORES		0x00ff0000
-#define	CPUID_LOCAL_APIC_ID	0xff000000
- * CPUID instruction 5 info
-#define	CPUID5_MON_MIN_SIZE	0x0000ffff	/* eax */
-#define	CPUID5_MON_MAX_SIZE	0x0000ffff	/* ebx */
-#define	CPUID5_MON_MWAIT_EXT	0x00000001	/* ecx */
-#define	CPUID5_MWAIT_INTRBREAK	0x00000002	/* ecx */
- * MWAIT cpu power states.  Lower 4 bits are sub-states.
-#define	MWAIT_C0	0xf0
-#define	MWAIT_C1	0x00
-#define	MWAIT_C2	0x10
-#define	MWAIT_C3	0x20
-#define	MWAIT_C4	0x30
- * MWAIT extensions.
-/* Interrupt breaks MWAIT even when masked. */
-#define	MWAIT_INTRBREAK		0x00000001
- * CPUID instruction 6 ecx info
-#define	CPUID_PERF_STAT		0x00000001
-#define	CPUID_PERF_BIAS		0x00000008
- * CPUID instruction 0xb ebx info.
-#define	CPUID_TYPE_INVAL	0
-#define	CPUID_TYPE_SMT		1
-#define	CPUID_TYPE_CORE		2
- * CPUID instruction 0xd Processor Extended State Enumeration Sub-leaf 1
-#define	CPUID_EXTSTATE_XSAVEOPT	0x00000001
-#define	CPUID_EXTSTATE_XSAVEC	0x00000002
-#define	CPUID_EXTSTATE_XINUSE	0x00000004
-#define	CPUID_EXTSTATE_XSAVES	0x00000008
- * AMD extended function 8000_0007h ebx info
-#define	AMDRAS_MCA_OF_RECOV	0x00000001
-#define	AMDRAS_SUCCOR		0x00000002
-#define	AMDRAS_HW_ASSERT	0x00000004
-#define	AMDRAS_SCALABLE_MCA	0x00000008
-#define	AMDRAS_PFEH_SUPPORT	0x00000010
- * AMD extended function 8000_0007h edx info
-#define	AMDPM_TS		0x00000001
-#define	AMDPM_FID		0x00000002
-#define	AMDPM_VID		0x00000004
-#define	AMDPM_TTP		0x00000008
-#define	AMDPM_TM		0x00000010
-#define	AMDPM_STC		0x00000020
-#define	AMDPM_100MHZ_STEPS	0x00000040
-#define	AMDPM_HW_PSTATE		0x00000080
-#define	AMDPM_TSC_INVARIANT	0x00000100
-#define	AMDPM_CPB		0x00000200
- * AMD extended function 8000_0008h ebx info (amd_extended_feature_extensions)
-#define	AMDFEID_CLZERO		0x00000001
-#define	AMDFEID_IRPERF		0x00000002
-#define	AMDFEID_XSAVEERPTR	0x00000004
-#define	AMDFEID_IBPB		0x00001000
-#define	AMDFEID_IBRS		0x00004000
-#define	AMDFEID_STIBP		0x00008000
-/* The below are only defined if the corresponding base feature above exists. */
-#define	AMDFEID_IBRS_ALWAYSON	0x00010000
-#define	AMDFEID_STIBP_ALWAYSON	0x00020000
-#define	AMDFEID_PREFER_IBRS	0x00040000
-#define	AMDFEID_SSBD		0x01000000
-/* SSBD via MSRC001_011F instead of MSR 0x48: */
-#define	AMDFEID_VIRT_SSBD	0x02000000
-#define	AMDFEID_SSB_NO		0x04000000
- * AMD extended function 8000_0008h ecx info
-#define	AMDID_CMP_CORES		0x000000ff
-#define	AMDID_COREID_SIZE	0x0000f000
-#define	AMDID_COREID_SIZE_SHIFT	12
- * CPUID instruction 7 Structured Extended Features, leaf 0 ebx info
-#define	CPUID_STDEXT_FSGSBASE	0x00000001
-#define	CPUID_STDEXT_TSC_ADJUST	0x00000002
-#define	CPUID_STDEXT_SGX	0x00000004
-#define	CPUID_STDEXT_BMI1	0x00000008
-#define	CPUID_STDEXT_HLE	0x00000010
-#define	CPUID_STDEXT_AVX2	0x00000020
-#define	CPUID_STDEXT_FDP_EXC	0x00000040
-#define	CPUID_STDEXT_SMEP	0x00000080
-#define	CPUID_STDEXT_BMI2	0x00000100
-#define	CPUID_STDEXT_ERMS	0x00000200
-#define	CPUID_STDEXT_INVPCID	0x00000400
-#define	CPUID_STDEXT_RTM	0x00000800
-#define	CPUID_STDEXT_PQM	0x00001000
-#define	CPUID_STDEXT_NFPUSG	0x00002000
-#define	CPUID_STDEXT_MPX	0x00004000
-#define	CPUID_STDEXT_PQE	0x00008000
-#define	CPUID_STDEXT_AVX512F	0x00010000
-#define	CPUID_STDEXT_AVX512DQ	0x00020000
-#define	CPUID_STDEXT_RDSEED	0x00040000
-#define	CPUID_STDEXT_ADX	0x00080000
-#define	CPUID_STDEXT_SMAP	0x00100000
-#define	CPUID_STDEXT_AVX512IFMA	0x00200000
-#define	CPUID_STDEXT_PCOMMIT	0x00400000
-#define	CPUID_STDEXT_CLFLUSHOPT	0x00800000
-#define	CPUID_STDEXT_CLWB	0x01000000
-#define	CPUID_STDEXT_PROCTRACE	0x02000000
-#define	CPUID_STDEXT_AVX512PF	0x04000000
-#define	CPUID_STDEXT_AVX512ER	0x08000000
-#define	CPUID_STDEXT_AVX512CD	0x10000000
-#define	CPUID_STDEXT_SHA	0x20000000
-#define	CPUID_STDEXT_AVX512BW	0x40000000
-#define	CPUID_STDEXT_AVX512VL	0x80000000
- * CPUID instruction 7 Structured Extended Features, leaf 0 ecx info
-#define	CPUID_STDEXT2_PREFETCHWT1 	0x00000001
-#define	CPUID_STDEXT2_AVX512VBMI	0x00000002
-#define	CPUID_STDEXT2_UMIP		0x00000004
-#define	CPUID_STDEXT2_PKU		0x00000008
-#define	CPUID_STDEXT2_OSPKE		0x00000010
-#define	CPUID_STDEXT2_WAITPKG		0x00000020
-#define	CPUID_STDEXT2_AVX512VBMI2	0x00000040
-#define	CPUID_STDEXT2_GFNI		0x00000100
-#define	CPUID_STDEXT2_VAES		0x00000200
-#define	CPUID_STDEXT2_VPCLMULQDQ	0x00000400
-#define	CPUID_STDEXT2_AVX512VNNI	0x00000800
-#define	CPUID_STDEXT2_AVX512BITALG	0x00001000
-#define	CPUID_STDEXT2_AVX512VPOPCNTDQ	0x00004000
-#define	CPUID_STDEXT2_RDPID		0x00400000
-#define	CPUID_STDEXT2_CLDEMOTE		0x02000000
-#define	CPUID_STDEXT2_MOVDIRI		0x08000000
-#define	CPUID_STDEXT2_MOVDIRI64B	0x10000000
-#define	CPUID_STDEXT2_ENQCMD		0x20000000
-#define	CPUID_STDEXT2_SGXLC		0x40000000
- * CPUID instruction 7 Structured Extended Features, leaf 0 edx info
-#define	CPUID_STDEXT3_AVX5124VNNIW	0x00000004
-#define	CPUID_STDEXT3_AVX5124FMAPS	0x00000008
-#define	CPUID_STDEXT3_AVX512VP2INTERSECT	0x00000100
-#define	CPUID_STDEXT3_MD_CLEAR		0x00000400
-#define	CPUID_STDEXT3_TSXFA		0x00002000
-#define	CPUID_STDEXT3_PCONFIG		0x00040000
-#define	CPUID_STDEXT3_IBPB		0x04000000
-#define	CPUID_STDEXT3_STIBP		0x08000000
-#define	CPUID_STDEXT3_L1D_FLUSH		0x10000000
-#define	CPUID_STDEXT3_ARCH_CAP		0x20000000
-#define	CPUID_STDEXT3_CORE_CAP		0x40000000
-#define	CPUID_STDEXT3_SSBD		0x80000000
-/* MSR IA32_ARCH_CAP(ABILITIES) bits */
-#define	IA32_ARCH_CAP_RDCL_NO	0x00000001
-#define	IA32_ARCH_CAP_IBRS_ALL	0x00000002
-#define	IA32_ARCH_CAP_RSBA	0x00000004
-#define	IA32_ARCH_CAP_SKIP_L1DFL_VMENTRY	0x00000008
-#define	IA32_ARCH_CAP_SSB_NO	0x00000010
-#define	IA32_ARCH_CAP_MDS_NO	0x00000020
- * CPUID manufacturers identifiers
-#define	AMD_VENDOR_ID		"AuthenticAMD"
-#define	CENTAUR_VENDOR_ID	"CentaurHauls"
-#define	CYRIX_VENDOR_ID		"CyrixInstead"
-#define	INTEL_VENDOR_ID		"GenuineIntel"
-#define	NEXGEN_VENDOR_ID	"NexGenDriven"
-#define	NSC_VENDOR_ID		"Geode by NSC"
-#define	RISE_VENDOR_ID		"RiseRiseRise"
-#define	SIS_VENDOR_ID		"SiS SiS SiS "
-#define	TRANSMETA_VENDOR_ID	"GenuineTMx86"
-#define	UMC_VENDOR_ID		"UMC UMC UMC "
- * Model-specific registers for the i386 family
-#define	MSR_P5_MC_ADDR		0x000
-#define	MSR_P5_MC_TYPE		0x001
-#define	MSR_TSC			0x010
-#define	MSR_P5_CESR		0x011
-#define	MSR_P5_CTR0		0x012
-#define	MSR_P5_CTR1		0x013
-#define	MSR_IA32_PLATFORM_ID	0x017
-#define	MSR_APICBASE		0x01b
-#define	MSR_EBL_CR_POWERON	0x02a
-#define	MSR_TEST_CTL		0x033
-#define	MSR_IA32_FEATURE_CONTROL 0x03a
-#define	MSR_IA32_SPEC_CTRL	0x048
-#define	MSR_IA32_PRED_CMD	0x049
-#define	MSR_BIOS_UPDT_TRIG	0x079
-#define	MSR_BBL_CR_D0		0x088
-#define	MSR_BBL_CR_D1		0x089
-#define	MSR_BBL_CR_D2		0x08a
-#define	MSR_BIOS_SIGN		0x08b
-#define	MSR_PERFCTR0		0x0c1
-#define	MSR_PERFCTR1		0x0c2
-#define	MSR_PLATFORM_INFO	0x0ce
-#define	MSR_MPERF		0x0e7
-#define	MSR_APERF		0x0e8
-#define	MSR_IA32_EXT_CONFIG	0x0ee	/* Undocumented. Core Solo/Duo only */
-#define	MSR_MTRRcap		0x0fe
-#define	MSR_IA32_ARCH_CAP	0x10a
-#define	MSR_IA32_FLUSH_CMD	0x10b
-#define	MSR_TSX_FORCE_ABORT	0x10f
-#define	MSR_BBL_CR_ADDR		0x116
-#define	MSR_BBL_CR_DECC		0x118
-#define	MSR_BBL_CR_CTL		0x119
-#define	MSR_BBL_CR_TRIG		0x11a
-#define	MSR_BBL_CR_BUSY		0x11b
-#define	MSR_BBL_CR_CTL3		0x11e
-#define	MSR_SYSENTER_CS_MSR	0x174
-#define	MSR_SYSENTER_ESP_MSR	0x175
-#define	MSR_SYSENTER_EIP_MSR	0x176
-#define	MSR_MCG_CAP		0x179
-#define	MSR_MCG_STATUS		0x17a
-#define	MSR_MCG_CTL		0x17b
-#define	MSR_EVNTSEL0		0x186
-#define	MSR_EVNTSEL1		0x187
-#define	MSR_THERM_CONTROL	0x19a
-#define	MSR_THERM_INTERRUPT	0x19b
-#define	MSR_THERM_STATUS	0x19c
-#define	MSR_IA32_MISC_ENABLE	0x1a0
-#define	MSR_IA32_TEMPERATURE_TARGET	0x1a2
-#define	MSR_TURBO_RATIO_LIMIT	0x1ad
-#define	MSR_TURBO_RATIO_LIMIT1	0x1ae
-#define	MSR_DEBUGCTLMSR		0x1d9
-#define	MSR_LASTBRANCHFROMIP	0x1db
-#define	MSR_LASTBRANCHTOIP	0x1dc
-#define	MSR_LASTINTFROMIP	0x1dd
-#define	MSR_LASTINTTOIP		0x1de
-#define	MSR_ROB_CR_BKUPTMPDR6	0x1e0
-#define	MSR_MTRRVarBase		0x200
-#define	MSR_MTRR64kBase		0x250
-#define	MSR_MTRR16kBase		0x258
-#define	MSR_MTRR4kBase		0x268
-#define	MSR_PAT			0x277
-#define	MSR_MC0_CTL2		0x280
-#define	MSR_MTRRdefType		0x2ff
-#define	MSR_MC0_CTL		0x400
-#define	MSR_MC0_STATUS		0x401
-#define	MSR_MC0_ADDR		0x402
-#define	MSR_MC0_MISC		0x403
-#define	MSR_MC1_CTL		0x404
-#define	MSR_MC1_STATUS		0x405
-#define	MSR_MC1_ADDR		0x406
-#define	MSR_MC1_MISC		0x407
-#define	MSR_MC2_CTL		0x408
-#define	MSR_MC2_STATUS		0x409
-#define	MSR_MC2_ADDR		0x40a
-#define	MSR_MC2_MISC		0x40b
-#define	MSR_MC3_CTL		0x40c
-#define	MSR_MC3_STATUS		0x40d
-#define	MSR_MC3_ADDR		0x40e
-#define	MSR_MC3_MISC		0x40f
-#define	MSR_MC4_CTL		0x410
-#define	MSR_MC4_STATUS		0x411
-#define	MSR_MC4_ADDR		0x412
-#define	MSR_MC4_MISC		0x413
-#define	MSR_RAPL_POWER_UNIT	0x606
-#define	MSR_PKG_ENERGY_STATUS	0x611
-#define	MSR_DRAM_ENERGY_STATUS	0x619
-#define	MSR_PP0_ENERGY_STATUS	0x639
-#define	MSR_PP1_ENERGY_STATUS	0x641
-#define	MSR_PPERF		0x64e
-#define	MSR_TSC_DEADLINE	0x6e0	/* Writes are not serializing */
-#define	MSR_IA32_PM_ENABLE	0x770
-#define	MSR_IA32_HWP_CAPABILITIES	0x771
-#define	MSR_IA32_HWP_REQUEST_PKG	0x772
-#define	MSR_IA32_HWP_INTERRUPT		0x773
-#define	MSR_IA32_HWP_REQUEST	0x774
-#define	MSR_IA32_HWP_STATUS	0x777
- * VMX MSRs
-#define	MSR_VMX_BASIC		0x480
-#define	MSR_VMX_PINBASED_CTLS	0x481
-#define	MSR_VMX_PROCBASED_CTLS	0x482
-#define	MSR_VMX_EXIT_CTLS	0x483
-#define	MSR_VMX_ENTRY_CTLS	0x484
-#define	MSR_VMX_CR0_FIXED0	0x486
-#define	MSR_VMX_CR0_FIXED1	0x487
-#define	MSR_VMX_CR4_FIXED0	0x488
-#define	MSR_VMX_CR4_FIXED1	0x489
-#define	MSR_VMX_PROCBASED_CTLS2	0x48b
-#define	MSR_VMX_EPT_VPID_CAP	0x48c
-#define	MSR_VMX_TRUE_PINBASED_CTLS	0x48d
-#define	MSR_VMX_TRUE_PROCBASED_CTLS	0x48e
-#define	MSR_VMX_TRUE_EXIT_CTLS	0x48f
-#define	MSR_VMX_TRUE_ENTRY_CTLS	0x490
- * X2APIC MSRs.
- * Writes are not serializing.
-#define	MSR_APIC_000		0x800
-#define	MSR_APIC_ID		0x802
-#define	MSR_APIC_VERSION	0x803
-#define	MSR_APIC_TPR		0x808
-#define	MSR_APIC_EOI		0x80b
-#define	MSR_APIC_LDR		0x80d
-#define	MSR_APIC_SVR		0x80f
-#define	MSR_APIC_ISR0		0x810
-#define	MSR_APIC_ISR1		0x811
-#define	MSR_APIC_ISR2		0x812
-#define	MSR_APIC_ISR3		0x813
-#define	MSR_APIC_ISR4		0x814
-#define	MSR_APIC_ISR5		0x815
-#define	MSR_APIC_ISR6		0x816
-#define	MSR_APIC_ISR7		0x817
-#define	MSR_APIC_TMR0		0x818
-#define	MSR_APIC_IRR0		0x820
-#define	MSR_APIC_ESR		0x828
-#define	MSR_APIC_LVT_CMCI	0x82F
-#define	MSR_APIC_ICR		0x830
-#define	MSR_APIC_LVT_TIMER	0x832
-#define	MSR_APIC_LVT_THERMAL	0x833
-#define	MSR_APIC_LVT_PCINT	0x834
-#define	MSR_APIC_LVT_LINT0	0x835
-#define	MSR_APIC_LVT_LINT1	0x836
-#define	MSR_APIC_LVT_ERROR	0x837
-#define	MSR_APIC_ICR_TIMER	0x838
-#define	MSR_APIC_CCR_TIMER	0x839
-#define	MSR_APIC_DCR_TIMER	0x83e
-#define	MSR_APIC_SELF_IPI	0x83f
-#define	MSR_IA32_XSS		0xda0
- * Intel Processor Trace (PT) MSRs.
-#define	MSR_IA32_RTIT_OUTPUT_BASE	0x560	/* Trace Output Base Register (R/W) */
-#define	MSR_IA32_RTIT_OUTPUT_MASK_PTRS	0x561	/* Trace Output Mask Pointers Register (R/W) */
-#define	MSR_IA32_RTIT_CTL		0x570	/* Trace Control Register (R/W) */
-#define	 RTIT_CTL_TRACEEN	(1 << 0)
-#define	 RTIT_CTL_CYCEN		(1 << 1)
-#define	 RTIT_CTL_OS		(1 << 2)
-#define	 RTIT_CTL_USER		(1 << 3)
-#define	 RTIT_CTL_PWREVTEN	(1 << 4)
-#define	 RTIT_CTL_FUPONPTW	(1 << 5)
-#define	 RTIT_CTL_FABRICEN	(1 << 6)
-#define	 RTIT_CTL_CR3FILTER	(1 << 7)
-#define	 RTIT_CTL_TOPA		(1 << 8)
-#define	 RTIT_CTL_MTCEN		(1 << 9)
-#define	 RTIT_CTL_TSCEN		(1 << 10)
-#define	 RTIT_CTL_DISRETC	(1 << 11)
-#define	 RTIT_CTL_PTWEN		(1 << 12)
-#define	 RTIT_CTL_BRANCHEN	(1 << 13)
-#define	 RTIT_CTL_MTC_FREQ_S	14
-#define	 RTIT_CTL_MTC_FREQ(n)	((n) << RTIT_CTL_MTC_FREQ_S)
-#define	 RTIT_CTL_MTC_FREQ_M	(0xf << RTIT_CTL_MTC_FREQ_S)
-#define	 RTIT_CTL_CYC_THRESH_S	19
-#define	 RTIT_CTL_CYC_THRESH_M	(0xf << RTIT_CTL_CYC_THRESH_S)
-#define	 RTIT_CTL_PSB_FREQ_S	24
-#define	 RTIT_CTL_PSB_FREQ_M	(0xf << RTIT_CTL_PSB_FREQ_S)
-#define	 RTIT_CTL_ADDR_CFG_S(n) (32 + (n) * 4)
-#define	 RTIT_CTL_ADDR0_CFG_S	32
-#define	 RTIT_CTL_ADDR0_CFG_M	(0xfULL << RTIT_CTL_ADDR0_CFG_S)
-#define	 RTIT_CTL_ADDR1_CFG_S	36
-#define	 RTIT_CTL_ADDR1_CFG_M	(0xfULL << RTIT_CTL_ADDR1_CFG_S)
-#define	 RTIT_CTL_ADDR2_CFG_S	40
-#define	 RTIT_CTL_ADDR2_CFG_M	(0xfULL << RTIT_CTL_ADDR2_CFG_S)
-#define	 RTIT_CTL_ADDR3_CFG_S	44
-#define	 RTIT_CTL_ADDR3_CFG_M	(0xfULL << RTIT_CTL_ADDR3_CFG_S)
-#define	MSR_IA32_RTIT_STATUS		0x571	/* Tracing Status Register (R/W) */
-#define	 RTIT_STATUS_FILTEREN	(1 << 0)
-#define	 RTIT_STATUS_CONTEXTEN	(1 << 1)
-#define	 RTIT_STATUS_TRIGGEREN	(1 << 2)
-#define	 RTIT_STATUS_ERROR	(1 << 4)
-#define	 RTIT_STATUS_STOPPED	(1 << 5)
-#define	 RTIT_STATUS_PACKETBYTECNT_S	32
-#define	 RTIT_STATUS_PACKETBYTECNT_M	(0x1ffffULL << RTIT_STATUS_PACKETBYTECNT_S)
-#define	MSR_IA32_RTIT_CR3_MATCH		0x572	/* Trace Filter CR3 Match Register (R/W) */
-#define	MSR_IA32_RTIT_ADDR_A(n)		(0x580 + (n) * 2)
-#define	MSR_IA32_RTIT_ADDR_B(n)		(0x581 + (n) * 2)
-#define	MSR_IA32_RTIT_ADDR0_A		0x580	/* Region 0 Start Address (R/W) */
-#define	MSR_IA32_RTIT_ADDR0_B		0x581	/* Region 0 End Address (R/W) */
-#define	MSR_IA32_RTIT_ADDR1_A		0x582	/* Region 1 Start Address (R/W) */
-#define	MSR_IA32_RTIT_ADDR1_B		0x583	/* Region 1 End Address (R/W) */
-#define	MSR_IA32_RTIT_ADDR2_A		0x584	/* Region 2 Start Address (R/W) */
-#define	MSR_IA32_RTIT_ADDR2_B		0x585	/* Region 2 End Address (R/W) */
-#define	MSR_IA32_RTIT_ADDR3_A		0x586	/* Region 3 Start Address (R/W) */
-#define	MSR_IA32_RTIT_ADDR3_B		0x587	/* Region 3 End Address (R/W) */
-/* Intel Processor Trace Table of Physical Addresses (ToPA). */
-#define	TOPA_SIZE_S	6
-#define	TOPA_SIZE_M	(0xf << TOPA_SIZE_S)
-#define	TOPA_SIZE_4K	(0 << TOPA_SIZE_S)
-#define	TOPA_SIZE_8K	(1 << TOPA_SIZE_S)
-#define	TOPA_SIZE_16K	(2 << TOPA_SIZE_S)
-#define	TOPA_SIZE_32K	(3 << TOPA_SIZE_S)
-#define	TOPA_SIZE_64K	(4 << TOPA_SIZE_S)
-#define	TOPA_SIZE_128K	(5 << TOPA_SIZE_S)
-#define	TOPA_SIZE_256K	(6 << TOPA_SIZE_S)
-#define	TOPA_SIZE_512K	(7 << TOPA_SIZE_S)
-#define	TOPA_SIZE_1M	(8 << TOPA_SIZE_S)
-#define	TOPA_SIZE_2M	(9 << TOPA_SIZE_S)
-#define	TOPA_SIZE_4M	(10 << TOPA_SIZE_S)
-#define	TOPA_SIZE_8M	(11 << TOPA_SIZE_S)
-#define	TOPA_SIZE_16M	(12 << TOPA_SIZE_S)
-#define	TOPA_SIZE_32M	(13 << TOPA_SIZE_S)
-#define	TOPA_SIZE_64M	(14 << TOPA_SIZE_S)
-#define	TOPA_SIZE_128M	(15 << TOPA_SIZE_S)
-#define	TOPA_STOP	(1 << 4)
-#define	TOPA_INT	(1 << 2)
-#define	TOPA_END	(1 << 0)
- * Constants related to MSR's.
-#define	APICBASE_RESERVED	0x000002ff
-#define	APICBASE_BSP		0x00000100
-#define	APICBASE_X2APIC		0x00000400
-#define	APICBASE_ENABLED	0x00000800
-#define	APICBASE_ADDRESS	0xfffff000
-/* MSR_IA32_FEATURE_CONTROL related */
-#define	IA32_FEATURE_CONTROL_LOCK	0x01	/* lock bit */
-#define	IA32_FEATURE_CONTROL_SMX_EN	0x02	/* enable VMX inside SMX */
-#define	IA32_FEATURE_CONTROL_VMX_EN	0x04	/* enable VMX outside SMX */
-/* MSR IA32_MISC_ENABLE */
-#define	IA32_MISC_EN_FASTSTR	0x0000000000000001ULL
-#define	IA32_MISC_EN_ATCCE	0x0000000000000008ULL
-#define	IA32_MISC_EN_PERFMON	0x0000000000000080ULL
-#define	IA32_MISC_EN_PEBSU	0x0000000000001000ULL
-#define	IA32_MISC_EN_ESSTE	0x0000000000010000ULL
-#define	IA32_MISC_EN_MONE	0x0000000000040000ULL
-#define	IA32_MISC_EN_LIMCPUID	0x0000000000400000ULL
-#define	IA32_MISC_EN_xTPRD	0x0000000000800000ULL
-#define	IA32_MISC_EN_XDD	0x0000000400000000ULL
- * IA32_SPEC_CTRL and IA32_PRED_CMD MSRs are described in the Intel'
- * document 336996-001 Speculative Execution Side Channel Mitigations.
- * AMD uses the same MSRs and bit definitions, as described in 111006-B
- * "Indirect Branch Control Extension" and 124441 "Speculative Store Bypass
- * Disable."
-/* MSR IA32_SPEC_CTRL */
-#define	IA32_SPEC_CTRL_IBRS	0x00000001
-#define	IA32_SPEC_CTRL_STIBP	0x00000002
-#define	IA32_SPEC_CTRL_SSBD	0x00000004
-/* MSR IA32_PRED_CMD */
-#define	IA32_PRED_CMD_IBPB_BARRIER	0x0000000000000001ULL
-/* MSR IA32_FLUSH_CMD */
-#define	IA32_FLUSH_CMD_L1D	0x00000001
-/* MSR IA32_HWP_CAPABILITIES */
-#define	IA32_HWP_CAPABILITIES_HIGHEST_PERFORMANCE(x)	(((x) >> 0) & 0xff)
-#define	IA32_HWP_CAPABILITIES_GUARANTEED_PERFORMANCE(x)	(((x) >> 8) & 0xff)
-#define	IA32_HWP_CAPABILITIES_EFFICIENT_PERFORMANCE(x)	(((x) >> 16) & 0xff)
-#define	IA32_HWP_CAPABILITIES_LOWEST_PERFORMANCE(x)	(((x) >> 24) & 0xff)
-/* MSR IA32_HWP_REQUEST */
-#define	IA32_HWP_REQUEST_MINIMUM_VALID			(1ULL << 63)
-#define	IA32_HWP_REQUEST_MAXIMUM_VALID			(1ULL << 62)
-#define	IA32_HWP_REQUEST_DESIRED_VALID			(1ULL << 61)
-#define	IA32_HWP_REQUEST_EPP_VALID 			(1ULL << 60)
-#define	IA32_HWP_REQUEST_ACTIVITY_WINDOW_VALID		(1ULL << 59)
-#define	IA32_HWP_REQUEST_PACKAGE_CONTROL		(1ULL << 42)
-#define	IA32_HWP_ACTIVITY_WINDOW			(0x3ffULL << 32)
-#define	IA32_HWP_REQUEST_ENERGY_PERFORMANCE_PREFERENCE	(0xffULL << 24)
-#define	IA32_HWP_DESIRED_PERFORMANCE			(0xffULL << 16)
-#define	IA32_HWP_REQUEST_MAXIMUM_PERFORMANCE		(0xffULL << 8)
-#define	IA32_HWP_MINIMUM_PERFORMANCE			(0xffULL << 0)
- * PAT modes.
-#define	PAT_UNCACHEABLE		0x00
-#define	PAT_WRITE_COMBINING	0x01
-#define	PAT_WRITE_THROUGH	0x04
-#define	PAT_WRITE_PROTECTED	0x05
-#define	PAT_WRITE_BACK		0x06
-#define	PAT_UNCACHED		0x07
-#define	PAT_VALUE(i, m)		((long long)(m) << (8 * (i)))
-#define	PAT_MASK(i)		PAT_VALUE(i, 0xff)
- * Constants related to MTRRs
-#define	MTRR_UNCACHEABLE	0x00
-#define	MTRR_WRITE_COMBINING	0x01
-#define	MTRR_WRITE_THROUGH	0x04
-#define	MTRR_WRITE_PROTECTED	0x05
-#define	MTRR_WRITE_BACK		0x06
-#define	MTRR_N64K		8	/* numbers of fixed-size entries */
-#define	MTRR_N16K		16
-#define	MTRR_N4K		64
-#define	MTRR_CAP_WC		0x0000000000000400
-#define	MTRR_CAP_FIXED		0x0000000000000100
-#define	MTRR_CAP_VCNT		0x00000000000000ff
-#define	MTRR_DEF_ENABLE		0x0000000000000800
-#define	MTRR_DEF_FIXED_ENABLE	0x0000000000000400
-#define	MTRR_DEF_TYPE		0x00000000000000ff
-#define	MTRR_PHYSBASE_PHYSBASE	0x000ffffffffff000
-#define	MTRR_PHYSBASE_TYPE	0x00000000000000ff
-#define	MTRR_PHYSMASK_PHYSMASK	0x000ffffffffff000
-#define	MTRR_PHYSMASK_VALID	0x0000000000000800
- * Cyrix configuration registers, accessible as IO ports.
-#define	CCR0			0xc0	/* Configuration control register 0 */
-#define	CCR0_NC0		0x01	/* First 64K of each 1M memory region is
-								   non-cacheable */
-#define	CCR0_NC1		0x02	/* 640K-1M region is non-cacheable */
-#define	CCR0_A20M		0x04	/* Enables A20M# input pin */
-#define	CCR0_KEN		0x08	/* Enables KEN# input pin */
-#define	CCR0_FLUSH		0x10	/* Enables FLUSH# input pin */
-#define	CCR0_BARB		0x20	/* Flushes internal cache when entering hold
-								   state */
-#define	CCR0_CO			0x40	/* Cache org: 1=direct mapped, 0=2x set
-								   assoc */
-#define	CCR0_SUSPEND	0x80	/* Enables SUSP# and SUSPA# pins */
-#define	CCR1			0xc1	/* Configuration control register 1 */
-#define	CCR1_RPL		0x01	/* Enables RPLSET and RPLVAL# pins */
-#define	CCR1_SMI		0x02	/* Enables SMM pins */
-#define	CCR1_SMAC		0x04	/* System management memory access */
-#define	CCR1_MMAC		0x08	/* Main memory access */
-#define	CCR1_NO_LOCK	0x10	/* Negate LOCK# */
-#define	CCR1_SM3		0x80	/* SMM address space address region 3 */
-#define	CCR2			0xc2
-#define	CCR2_WB			0x02	/* Enables WB cache interface pins */
-#define	CCR2_SADS		0x02	/* Slow ADS */
-#define	CCR2_LOCK_NW	0x04	/* LOCK NW Bit */
-#define	CCR2_SUSP_HLT	0x08	/* Suspend on HALT */
-#define	CCR2_WT1		0x10	/* WT region 1 */
-#define	CCR2_WPR1		0x10	/* Write-protect region 1 */
-#define	CCR2_BARB		0x20	/* Flushes write-back cache when entering
-								   hold state. */
-#define	CCR2_BWRT		0x40	/* Enables burst write cycles */
-#define	CCR2_USE_SUSP	0x80	/* Enables suspend pins */
-#define	CCR3			0xc3
-#define	CCR3_SMILOCK	0x01	/* SMM register lock */
-#define	CCR3_NMI		0x02	/* Enables NMI during SMM */
-#define	CCR3_LINBRST	0x04	/* Linear address burst cycles */
-#define	CCR3_SMMMODE	0x08	/* SMM Mode */
-#define	CCR3_MAPEN0		0x10	/* Enables Map0 */
-#define	CCR3_MAPEN1		0x20	/* Enables Map1 */
-#define	CCR3_MAPEN2		0x40	/* Enables Map2 */
-#define	CCR3_MAPEN3		0x80	/* Enables Map3 */
-#define	CCR4			0xe8
-#define	CCR4_IOMASK		0x07
-#define	CCR4_MEM		0x08	/* Enables momory bypassing */
-#define	CCR4_DTE		0x10	/* Enables directory table entry cache */
-#define	CCR4_FASTFPE	0x20	/* Fast FPU exception */
-#define	CCR4_CPUID		0x80	/* Enables CPUID instruction */
-#define	CCR5			0xe9
-#define	CCR5_WT_ALLOC	0x01	/* Write-through allocate */
-#define	CCR5_SLOP		0x02	/* LOOP instruction slowed down */
-#define	CCR5_LBR1		0x10	/* Local bus region 1 */
-#define	CCR5_ARREN		0x20	/* Enables ARR region */
-#define	CCR6			0xea
-#define	CCR7			0xeb
-/* Performance Control Register (5x86 only). */
-#define	PCR0			0x20
-#define	PCR0_RSTK		0x01	/* Enables return stack */
-#define	PCR0_BTB		0x02	/* Enables branch target buffer */
-#define	PCR0_LOOP		0x04	/* Enables loop */
-#define	PCR0_AIS		0x08	/* Enables all instrcutions stalled to
-								   serialize pipe. */
-#define	PCR0_MLR		0x10	/* Enables reordering of misaligned loads */
-#define	PCR0_BTBRT		0x40	/* Enables BTB test register. */
-#define	PCR0_LSSER		0x80	/* Disable reorder */
-/* Device Identification Registers */
-#define	DIR0			0xfe
-#define	DIR1			0xff
- * Machine Check register constants.
-#define	MCG_CAP_COUNT		0x000000ff
-#define	MCG_CAP_CTL_P		0x00000100
-#define	MCG_CAP_EXT_P		0x00000200
-#define	MCG_CAP_CMCI_P		0x00000400
-#define	MCG_CAP_TES_P		0x00000800
-#define	MCG_CAP_EXT_CNT		0x00ff0000
-#define	MCG_CAP_SER_P		0x01000000
-#define	MCG_STATUS_RIPV		0x00000001
-#define	MCG_STATUS_EIPV		0x00000002
-#define	MCG_STATUS_MCIP		0x00000004
-#define	MCG_CTL_ENABLE		0xffffffffffffffff
-#define	MCG_CTL_DISABLE		0x0000000000000000
-#define	MSR_MC_CTL(x)		(MSR_MC0_CTL + (x) * 4)
-#define	MSR_MC_STATUS(x)	(MSR_MC0_STATUS + (x) * 4)
-#define	MSR_MC_ADDR(x)		(MSR_MC0_ADDR + (x) * 4)
-#define	MSR_MC_MISC(x)		(MSR_MC0_MISC + (x) * 4)
-#define	MSR_MC_CTL2(x)		(MSR_MC0_CTL2 + (x))	/* If MCG_CAP_CMCI_P */
-#define	MC_STATUS_MCA_ERROR	0x000000000000ffff
-#define	MC_STATUS_MODEL_ERROR	0x00000000ffff0000
-#define	MC_STATUS_OTHER_INFO	0x01ffffff00000000
-#define	MC_STATUS_COR_COUNT	0x001fffc000000000	/* If MCG_CAP_CMCI_P */
-#define	MC_STATUS_TES_STATUS	0x0060000000000000	/* If MCG_CAP_TES_P */
-#define	MC_STATUS_AR		0x0080000000000000	/* If MCG_CAP_TES_P */
-#define	MC_STATUS_S		0x0100000000000000	/* If MCG_CAP_TES_P */
-#define	MC_STATUS_PCC		0x0200000000000000
-#define	MC_STATUS_ADDRV		0x0400000000000000
-#define	MC_STATUS_MISCV		0x0800000000000000
-#define	MC_STATUS_EN		0x1000000000000000
-#define	MC_STATUS_UC		0x2000000000000000
-#define	MC_STATUS_OVER		0x4000000000000000
-#define	MC_STATUS_VAL		0x8000000000000000
-#define	MC_MISC_RA_LSB		0x000000000000003f	/* If MCG_CAP_SER_P */
-#define	MC_MISC_ADDRESS_MODE	0x00000000000001c0	/* If MCG_CAP_SER_P */
-#define	MC_CTL2_THRESHOLD	0x0000000000007fff
-#define	MC_CTL2_CMCI_EN		0x0000000040000000
-#define	MC_AMDNB_BANK		4
-#define	MC_MISC_AMD_VAL		0x8000000000000000	/* Counter presence valid */
-#define	MC_MISC_AMD_CNTP	0x4000000000000000	/* Counter present */
-#define	MC_MISC_AMD_LOCK	0x2000000000000000	/* Register locked */
-#define	MC_MISC_AMD_INTP	0x1000000000000000	/* Int. type can generate interrupts */
-#define	MC_MISC_AMD_LVT_MASK	0x00f0000000000000	/* Extended LVT offset */
-#define	MC_MISC_AMD_LVT_SHIFT	52
-#define	MC_MISC_AMD_CNTEN	0x0008000000000000	/* Counter enabled */
-#define	MC_MISC_AMD_INT_MASK	0x0006000000000000	/* Interrupt type */
-#define	MC_MISC_AMD_INT_LVT	0x0002000000000000	/* Interrupt via Extended LVT */
-#define	MC_MISC_AMD_INT_SMI	0x0004000000000000	/* SMI */
-#define	MC_MISC_AMD_OVERFLOW	0x0001000000000000	/* Counter overflow */
-#define	MC_MISC_AMD_CNT_MASK	0x00000fff00000000	/* Counter value */
-#define	MC_MISC_AMD_CNT_SHIFT	32
-#define	MC_MISC_AMD_CNT_MAX	0xfff
-#define	MC_MISC_AMD_PTR_MASK	0x00000000ff000000	/* Pointer to additional registers */
-#define	MC_MISC_AMD_PTR_SHIFT	24
-/* AMD Scalable MCA */
-#define MSR_SMCA_MC0_CTL          0xc0002000
-#define MSR_SMCA_MC0_STATUS       0xc0002001
-#define MSR_SMCA_MC0_ADDR         0xc0002002
-#define MSR_SMCA_MC0_MISC0        0xc0002003
-#define MSR_SMCA_MC_CTL(x)       (MSR_SMCA_MC0_CTL + 0x10 * (x))
-#define MSR_SMCA_MC_STATUS(x)    (MSR_SMCA_MC0_STATUS + 0x10 * (x))
-#define MSR_SMCA_MC_ADDR(x)      (MSR_SMCA_MC0_ADDR + 0x10 * (x))
-#define MSR_SMCA_MC_MISC(x)      (MSR_SMCA_MC0_MISC0 + 0x10 * (x))
- * The following four 3-byte registers control the non-cacheable regions.
- * These registers must be written as three separate bytes.
- * NCRx+0: A31-A24 of starting address
- * NCRx+1: A23-A16 of starting address
- * NCRx+2: A15-A12 of starting address | NCR_SIZE_xx.
- * The non-cacheable region's starting address must be aligned to the
- * size indicated by the NCR_SIZE_xx field.
-#define	NCR1	0xc4
-#define	NCR2	0xc7
-#define	NCR3	0xca
-#define	NCR4	0xcd
-#define	NCR_SIZE_0K	0
-#define	NCR_SIZE_4K	1
-#define	NCR_SIZE_8K	2
-#define	NCR_SIZE_16K	3
-#define	NCR_SIZE_32K	4
-#define	NCR_SIZE_64K	5
-#define	NCR_SIZE_128K	6
-#define	NCR_SIZE_256K	7
-#define	NCR_SIZE_512K	8
-#define	NCR_SIZE_1M	9
-#define	NCR_SIZE_2M	10
-#define	NCR_SIZE_4M	11
-#define	NCR_SIZE_8M	12
-#define	NCR_SIZE_16M	13
-#define	NCR_SIZE_32M	14
-#define	NCR_SIZE_4G	15
- * The address region registers are used to specify the location and
- * size for the eight address regions.
- * ARRx + 0: A31-A24 of start address
- * ARRx + 1: A23-A16 of start address
- * ARRx + 2: A15-A12 of start address | ARR_SIZE_xx
-#define	ARR0	0xc4
-#define	ARR1	0xc7
-#define	ARR2	0xca
-#define	ARR3	0xcd
-#define	ARR4	0xd0
-#define	ARR5	0xd3
-#define	ARR6	0xd6
-#define	ARR7	0xd9
-#define	ARR_SIZE_0K		0
-#define	ARR_SIZE_4K		1
-#define	ARR_SIZE_8K		2
-#define	ARR_SIZE_16K	3
-#define	ARR_SIZE_32K	4
-#define	ARR_SIZE_64K	5
-#define	ARR_SIZE_128K	6
-#define	ARR_SIZE_256K	7
-#define	ARR_SIZE_512K	8
-#define	ARR_SIZE_1M		9
-#define	ARR_SIZE_2M		10
-#define	ARR_SIZE_4M		11
-#define	ARR_SIZE_8M		12
-#define	ARR_SIZE_16M	13
-#define	ARR_SIZE_32M	14
-#define	ARR_SIZE_4G		15
- * The region control registers specify the attributes associated with
- * the ARRx addres regions.
-#define	RCR0	0xdc
-#define	RCR1	0xdd
-#define	RCR2	0xde
-#define	RCR3	0xdf
-#define	RCR4	0xe0
-#define	RCR5	0xe1
-#define	RCR6	0xe2
-#define	RCR7	0xe3
-#define	RCR_RCD	0x01	/* Disables caching for ARRx (x = 0-6). */
-#define	RCR_RCE	0x01	/* Enables caching for ARR7. */
-#define	RCR_WWO	0x02	/* Weak write ordering. */
-#define	RCR_WL	0x04	/* Weak locking. */
-#define	RCR_WG	0x08	/* Write gathering. */
-#define	RCR_WT	0x10	/* Write-through. */
-#define	RCR_NLB	0x20	/* LBA# pin is not asserted. */
-/* AMD Write Allocate Top-Of-Memory and Control Register */
-#define	AMD_WT_ALLOC_TME	0x40000	/* top-of-memory enable */
-#define	AMD_WT_ALLOC_PRE	0x20000	/* programmable range enable */
-#define	AMD_WT_ALLOC_FRE	0x10000	/* fixed (A0000-FFFFF) range enable */
-/* AMD64 MSR's */
-#define	MSR_EFER	0xc0000080	/* extended features */
-#define	MSR_STAR	0xc0000081	/* legacy mode SYSCALL target/cs/ss */
-#define	MSR_LSTAR	0xc0000082	/* long mode SYSCALL target rip */
-#define	MSR_CSTAR	0xc0000083	/* compat mode SYSCALL target rip */
-#define	MSR_SF_MASK	0xc0000084	/* syscall flags mask */
-#define	MSR_FSBASE	0xc0000100	/* base address of the %fs "segment" */
-#define	MSR_GSBASE	0xc0000101	/* base address of the %gs "segment" */
-#define	MSR_KGSBASE	0xc0000102	/* base address of the kernel %gs */
-#define	MSR_TSC_AUX	0xc0000103
-#define	MSR_PERFEVSEL0	0xc0010000
-#define	MSR_PERFEVSEL1	0xc0010001
-#define	MSR_PERFEVSEL2	0xc0010002
-#define	MSR_PERFEVSEL3	0xc0010003
-#define	MSR_K7_PERFCTR0	0xc0010004
-#define	MSR_K7_PERFCTR1	0xc0010005
-#define	MSR_K7_PERFCTR2	0xc0010006
-#define	MSR_K7_PERFCTR3	0xc0010007
-#define	MSR_SYSCFG	0xc0010010
-#define	MSR_HWCR	0xc0010015
-#define	MSR_IORRBASE0	0xc0010016
-#define	MSR_IORRMASK0	0xc0010017
-#define	MSR_IORRBASE1	0xc0010018
-#define	MSR_IORRMASK1	0xc0010019
-#define	MSR_TOP_MEM	0xc001001a	/* boundary for ram below 4G */
-#define	MSR_TOP_MEM2	0xc001001d	/* boundary for ram above 4G */
-#define	MSR_NB_CFG1	0xc001001f	/* NB configuration 1 */
-#define	MSR_K8_UCODE_UPDATE 0xc0010020	/* update microcode */
-#define	MSR_MC0_CTL_MASK 0xc0010044
-#define	MSR_P_STATE_LIMIT 0xc0010061	/* P-state Current Limit Register */
-#define	MSR_P_STATE_CONTROL 0xc0010062	/* P-state Control Register */
-#define	MSR_P_STATE_STATUS 0xc0010063	/* P-state Status Register */
-#define	MSR_P_STATE_CONFIG(n) (0xc0010064 + (n)) /* P-state Config */
-#define	MSR_SMM_ADDR	0xc0010112	/* SMM TSEG base address */
-#define	MSR_SMM_MASK	0xc0010113	/* SMM TSEG address mask */
-#define	MSR_VM_CR	0xc0010114	/* SVM: feature control */
-#define	MSR_VM_HSAVE_PA 0xc0010117	/* SVM: host save area address */
-#define	MSR_AMD_CPUID07	0xc0011002	/* CPUID 07 %ebx override */
-#define	MSR_EXTFEATURES	0xc0011005	/* Extended CPUID Features override */
-#define	MSR_LS_CFG	0xc0011020
-#define	MSR_IC_CFG	0xc0011021	/* Instruction Cache Configuration */
-/* MSR_VM_CR related */
-#define	VM_CR_SVMDIS		0x10	/* SVM: disabled by BIOS */
-/* VIA ACE crypto featureset: for via_feature_rng */
-#define	VIA_HAS_RNG		1	/* cpu has RNG */
-/* VIA ACE crypto featureset: for via_feature_xcrypt */
-#define	VIA_HAS_AES		1	/* cpu has AES */
-#define	VIA_HAS_SHA		2	/* cpu has SHA1 & SHA256 */
-#define	VIA_HAS_MM		4	/* cpu has RSA instructions */
-#define	VIA_HAS_AESCTR		8	/* cpu has AES-CTR instructions */
-/* Centaur Extended Feature flags */
-#define	VIA_CPUID_HAS_RNG	0x000004
-#define	VIA_CPUID_DO_RNG	0x000008
-#define	VIA_CPUID_HAS_ACE	0x000040
-#define	VIA_CPUID_DO_ACE	0x000080
-#define	VIA_CPUID_HAS_ACE2	0x000100
-#define	VIA_CPUID_DO_ACE2	0x000200
-#define	VIA_CPUID_HAS_PHE	0x000400
-#define	VIA_CPUID_DO_PHE	0x000800
-#define	VIA_CPUID_HAS_PMM	0x001000
-#define	VIA_CPUID_DO_PMM	0x002000
-/* VIA ACE xcrypt-* instruction context control options */
-#define	VIA_CRYPT_CWLO_ROUND_M		0x0000000f
-#define	VIA_CRYPT_CWLO_ALG_M		0x00000070
-#define	VIA_CRYPT_CWLO_ALG_AES		0x00000000
-#define	VIA_CRYPT_CWLO_KEYGEN_M		0x00000080
-#define	VIA_CRYPT_CWLO_KEYGEN_HW	0x00000000
-#define	VIA_CRYPT_CWLO_KEYGEN_SW	0x00000080
-#define	VIA_CRYPT_CWLO_NORMAL		0x00000000
-#define	VIA_CRYPT_CWLO_INTERMEDIATE	0x00000100
-#define	VIA_CRYPT_CWLO_ENCRYPT		0x00000000
-#define	VIA_CRYPT_CWLO_DECRYPT		0x00000200
-#define	VIA_CRYPT_CWLO_KEY128		0x0000000a	/* 128bit, 10 rds */
-#define	VIA_CRYPT_CWLO_KEY192		0x0000040c	/* 192bit, 12 rds */
-#define	VIA_CRYPT_CWLO_KEY256		0x0000080e	/* 256bit, 15 rds */
-#endif /* !_MACHINE_SPECIALREG_H_ */
2.17.1
