[PATCH v2] covoar: Store address-to-line info outside of DWARF
Alex White alex.white at oarcorp.com
Mon Jun 7 12:00:36 UTC 2021
On Wed, Jun 2, 2021 at 7:37 PM Chris Johns <chrisj at rtems.org> wrote:
> Looking good with a single comment below ...
> On 3/6/21 6:08 am, Alex White wrote:
> > This adds the AddressToLineMapper class and supporting classes to
> > assume responsibility of tracking address-to-line information.
> > This allows the DWARF library to properly cleanup all of its resources
> > and leads to significant memory savings.
> > Closes #4383
> >  rtemstoolkit/rld-dwarf.cpp           |   5 +
> >  rtemstoolkit/rld-dwarf.h             |   5 +
> >  tester/covoar/AddressToLineMapper.cc | 104 +++++++++++++
> >  tester/covoar/AddressToLineMapper.h  | 211 +++++++++++++++++++++++++++
> >  tester/covoar/ExecutableInfo.cc      |  73 +++++----
> >  tester/covoar/ExecutableInfo.h       |  11 +-
> >  tester/covoar/wscript                |   1 +
> >  7 files changed, 368 insertions(+), 42 deletions(-)
> >  create mode 100644 tester/covoar/AddressToLineMapper.cc
> >  create mode 100644 tester/covoar/AddressToLineMapper.h
> > diff --git a/rtemstoolkit/rld-dwarf.cpp b/rtemstoolkit/rld-dwarf.cpp
> > index 2fce0e4..1eae50c 100644
> > --- a/rtemstoolkit/rld-dwarf.cpp
> > +++ b/rtemstoolkit/rld-dwarf.cpp
> > @@ -1893,6 +1893,11 @@ namespace rld
> >        return false;
> > +    const addresses& compilation_unit::get_addresses () const
> > +      return addr_lines_;
> >      functions&
> >      compilation_unit::get_functions ()
> > diff --git a/rtemstoolkit/rld-dwarf.h b/rtemstoolkit/rld-dwarf.h
> > index 1210813..eadb50d 100644
> > --- a/rtemstoolkit/rld-dwarf.h
> > +++ b/rtemstoolkit/rld-dwarf.h
> > @@ -707,6 +707,11 @@ namespace rld
> >        unsigned int pc_high () const;
> > +       * The addresses associated with this compilation unit.
> > +      const addresses& get_addresses () const;
> >         * Get the source and line for an address. If the address does not match
> >         * false is returned the file is set to 'unknown' and the line is set to
> > diff --git a/tester/covoar/AddressToLineMapper.cc b/tester/covoar/AddressToLineMapper.cc
> > new file mode 100644
> > index 0000000..c305e3b
> > --- /dev/null
> > +++ b/tester/covoar/AddressToLineMapper.cc
> > @@ -0,0 +1,104 @@
> > +/*! @file AddressToLineMapper.cc
> > + *  @brief AddressToLineMapper Implementation
> > + *  This file contains the implementation of the functionality
> > + *  of the AddressToLineMapper class.
> > +#include "AddressToLineMapper.h"
> > +namespace Coverage {
> > +  uint64_t SourceLine::location() const
> > +    return address;
> > +  bool SourceLine::is_an_end_sequence() const
> > +    return is_end_sequence;
> > +  const std::string& SourceLine::path() const
> > +    return path_;
> > +  int SourceLine::line() const
> > +    return line_num;
> > +  void AddressLineRange::addSourceLine(const rld::dwarf::address& address)
> > +    auto insertResult = sourcePaths.insert(address.path());
> > +    sourceLines.emplace_back(
> > +      SourceLine (
> > +        address.location(),
> > +        *insertResult.first,
> > +        address.line(),
> > +        address.is_an_end_sequence()
> > +  const SourceLine& AddressLineRange::getSourceLine(uint32_t address) const
> > +    if (address < lowAddress || address > highAddress) {
> > +      throw SourceNotFoundError(std::to_string(address));
> > +    const SourceLine* last_line = nullptr;
> > +    for (const auto &line : sourceLines) {
> > +      if (address <= line.location())
> > +        if (address == line.location())
> > +          last_line = &line;
> > +        break;
> > +    if (last_line == nullptr) {
> > +    return *last_line;
> How often is this function being called? If it is a hot spot are there other
> ways to search for the address? I suppose it depends on the number of lines in
> the vector.
According to a quick gprof run, this function is being called a decent amount, somewhere around 1.5 million times for a full ARM coverage run.
But it only takes up a very small amount (less than 0.02%) of cumulative execution time so I don't believe it is an issue.
Alex
> If the sourcesLines vector was sorted can this loop be replaced with some form
> of std::upper_bound? That is ...
>  auto last_line =
>     std::upper_bound(sourceLines.begin(),
>                      sourceLines.end(),
>                      address,
>                      [&address](const SourceLine& sl) {
>                        return address < sl.location();
> [ not sure if the code I posted would work and if I got the lamda right :) ]
> Just wondering.
> Chris
> > +  void AddressToLineMapper::getSource(
> > +    uint32_t address,
> > +    std::string& sourceFile,
> > +    int& sourceLine
> > +  ) const {
> > +    const SourceLine default_sourceline = SourceLine();
> > +    const SourceLine* match = &default_sourceline;
> > +    for (const auto &range : addressLineRanges) {
> > +      try {
> > +        const SourceLine& potential_match = range.getSourceLine(address);
> > +        if (match->is_an_end_sequence() || !potential_match.is_an_end_sequence()) {
> > +          match = &potential_match;
> > +      } catch (const AddressLineRange::SourceNotFoundError&) {}
> > +    sourceFile = match->path();
> > +    sourceLine = match->line();
> > +  AddressLineRange& AddressToLineMapper::makeRange(
> > +    uint32_t low,
> > +    uint32_t high
> > +    addressLineRanges.emplace_back(
> > +      AddressLineRange(low, high)
> > +    return addressLineRanges.back();
> > diff --git a/tester/covoar/AddressToLineMapper.h b/tester/covoar/AddressToLineMapper.h
> > index 0000000..e6ab4a8
> > --- /dev/null
> > +++ b/tester/covoar/AddressToLineMapper.h
> > @@ -0,0 +1,211 @@
> > +/*! @file AddressToLineMapper.h
> > + *  @brief AddressToLineMapper Specification
> > + *  This file contains the specification of the AddressToLineMapper class.
> > +#ifndef __ADDRESS_TO_LINE_MAPPER_H__
> > +#define __ADDRESS_TO_LINE_MAPPER_H__
> > +#include <cstdint>
> > +#include <set>
> > +#include <string>
> > +#include <vector>
> > +#include <rld-dwarf.h>
> > +  /*! @class SourceLine
> > +   *  This class stores source information for a specific address.
> > +  class SourceLine {
> > +  public:
> > +    SourceLine()
> > +    : address(0),
> > +      path_("unknown"),
> > +      line_num(-1),
> > +      is_end_sequence(true)
> > +    SourceLine(
> > +      uint64_t addr,
> > +      const std::string& src,
> > +      int line,
> > +      bool end_sequence
> > +    ) : address(addr),
> > +        path_(src),
> > +        line_num(line),
> > +        is_end_sequence(end_sequence)
> > +     *  This method gets the address of this source information.
> > +     *  @return Returns the address of this source information
> > +    uint64_t location() const;
> > +     *  This method gets a value indicating whether this address represents an
> > +     *  end sequence.
> > +     *  @return Returns whether this address represents an end sequence or not
> > +    bool is_an_end_sequence() const;
> > +     *  This method gets the source file path of this address.
> > +     *  @return Returns the source file path of this address
> > +    const std::string& path() const;
> > +     *  This method gets the source line number of this address.
> > +     *  @return Returns the source line number of this address
> > +    int line() const;
> > +  private:
> > +     *  The address of this source information.
> > +    uint64_t address;
> > +     *  An iterator pointing to the location in the set that contains the
> > +     *  source file path of the address.
> > +    const std::string& path_;
> > +     *  The source line number of the address.
> > +    int line_num;
> > +     *  Whether the address represents an end sequence or not.
> > +    bool is_end_sequence;
> > +  typedef std::vector<SourceLine> SourceLines;
> > +  typedef std::set<std::string> SourcePaths;
> > +  /*! @class AddressLineRange
> > +   *  This class stores source information for an address range.
> > +  class AddressLineRange {
> > +  public:
> > +    class SourceNotFoundError : public std::runtime_error {
> > +      /* Use the base class constructors. */
> > +      using std::runtime_error::runtime_error;
> > +    AddressLineRange(
> > +      uint32_t low,
> > +      uint32_t high
> > +    ) : lowAddress(low), highAddress(high)
> > +     *  This method adds source and line information for a specified address.
> > +     *  @param[in] address specifies the DWARF address information
> > +    void addSourceLine(const rld::dwarf::address& address);
> > +     *  This method gets the source file name and line number for a given
> > +     *  address.
> > +     *  @param[in] address specifies the address to look up
> > +     *  @return Returns the source information for the specified address.
> > +    const SourceLine& getSourceLine(uint32_t address) const;
> > +  private:
> > +     *  The low address for this range.
> > +    uint32_t lowAddress;
> > +     *  The high address for this range.
> > +    uint32_t highAddress;
> > +     *  The source information for addresses in this range.
> > +    SourceLines sourceLines;
> > +     *  The set of source file names for this range.
> > +    SourcePaths sourcePaths;
> > +  typedef std::vector<AddressLineRange> AddressLineRanges;
> > +  /*! @class AddressToLineMapper
> > +   *  This class provides address-to-line capabilities.
> > +  class AddressToLineMapper {
> > +  public:
> > +     *  address.
> > +     *  @param[out] sourceFile specifies the name of the source file
> > +     *  @param[out] sourceLine specifies the line number in the source file
> > +    void getSource(
> > +      uint32_t address,
> > +      int& sourceLine
> > +    ) const;
> > +     *  This method creates a new range with the specified addresses.
> > +     *  @param[in] low specifies the low address of the range
> > +     *  @param[in] high specifies the high address of the range
> > +     *  @return Returns a reference to the newly created range
> > +    AddressLineRange& makeRange(uint32_t low, uint32_t high);
> > +  private:
> > +     *  The address and line information ranges.
> > +    AddressLineRanges addressLineRanges;
> > +#endif
> > diff --git a/tester/covoar/ExecutableInfo.cc b/tester/covoar/ExecutableInfo.cc
> > index 861e60d..a6184e7 100644
> > --- a/tester/covoar/ExecutableInfo.cc
> > +++ b/tester/covoar/ExecutableInfo.cc
> > @@ -40,61 +40,60 @@ namespace Coverage {
> >      executable.begin();
> >      executable.load_symbols(symbols);
> > +    rld::dwarf::file debug;
> >      debug.begin(executable.elf());
> >      debug.load_debug();
> >      debug.load_functions();
> > -    try {
> > -      for (auto& cu : debug.get_cus()) {
> > -        for (auto& func : cu.get_functions()) {
> > -          if (!func.has_machine_code()) {
> > -            continue;
> > +    for (auto& cu : debug.get_cus()) {
> > +      AddressLineRange& range = mapper.makeRange(cu.pc_low(), cu.pc_high());
> > +      // Does not filter on desired symbols under the assumption that the test
> > +      // code and any support code is small relative to what is being tested.
> > +      for (const auto &address : cu.get_addresses()) {
> > +        range.addSourceLine(address);
> > -          if (!SymbolsToAnalyze->isDesired(func.name())) {
> > -            continue;
> > +      for (auto& func : cu.get_functions()) {
> > +        if (!func.has_machine_code()) {
> > +          continue;
> > +        if (!SymbolsToAnalyze->isDesired(func.name())) {
> > +          continue;
> > +        if (func.is_inlined()) {
> > +          if (func.is_external()) {
> > +            // Flag it
> > +            std::cerr << "Function is both external and inlined: "
> > +                      << func.name() << std::endl;
> > -          if (func.is_inlined()) {
> > -            if (func.is_external()) {
> > -              // Flag it
> > -              std::cerr << "Function is both external and inlined: "
> > -                        << func.name() << std::endl;
> > -            if (func.has_entry_pc()) {
> > -              continue;
> > -            // If the low PC address is zero, the symbol does not appear in
> > -            // this executable.
> > -            if (func.pc_low() == 0) {
> > -              continue;
> > +          if (func.has_entry_pc()) {
> > +            continue;
> > -          // We can't process a zero size function.
> > -          if (func.pc_high() == 0) {
> > +          // If the low PC address is zero, the symbol does not appear in
> > +          // this executable.
> > +          if (func.pc_low() == 0) {
> >              continue;
> > -          createCoverageMap (cu.name(), func.name(),
> > -                              func.pc_low(), func.pc_high() - 1);
> > +        // We can't process a zero size function.
> > +        if (func.pc_high() == 0) {
> > +          continue;
> > +        createCoverageMap (cu.name(), func.name(),
> > +                            func.pc_low(), func.pc_high() - 1);
> > -    } catch (...) {
> > -      debug.end();
> > -      throw;
> > -    // Can't cleanup handles until the destructor because the information is
> > -    // referenced elsewhere. NOTE: This could cause problems from too many open
> > -    // file descriptors.
> >    ExecutableInfo::~ExecutableInfo()
> > -    debug.end();
> >    void ExecutableInfo::dumpCoverageMaps( void ) {
> > @@ -197,7 +196,7 @@ namespace Coverage {
> >      std::string file;
> >      int         lno;
> > -    debug.get_source (address, file, lno);
> > +    mapper.getSource (address, file, lno);
> >      std::ostringstream ss;
> >      ss << file << ':' << lno;
> >      line = ss.str ();
> > diff --git a/tester/covoar/ExecutableInfo.h b/tester/covoar/ExecutableInfo.h
> > index 5d5a595..dfc71aa 100644
> > --- a/tester/covoar/ExecutableInfo.h
> > +++ b/tester/covoar/ExecutableInfo.h
> > @@ -15,6 +15,7 @@
> >  #include <rld-files.h>
> >  #include <rld-symbols.h>
> >  #include "CoverageMapBase.h"
> >  #include "SymbolTable.h"
> > @@ -157,11 +158,6 @@ namespace Coverage {
> > -     *  The DWARF data to the ELF executable.
> > -    rld::dwarf::file debug;
> >       *  The executable's file name.
> > @@ -172,6 +168,11 @@ namespace Coverage {
> >      rld::symbols::table symbols;
> > +     *  The address-to-line mapper for this executable.
> > +    AddressToLineMapper mapper;
> >       *  This map associates a symbol with its coverage map.
> > diff --git a/tester/covoar/wscript b/tester/covoar/wscript
> > index 82599b0..a928b1b 100644
> > --- a/tester/covoar/wscript
> > +++ b/tester/covoar/wscript
> > @@ -83,6 +83,7 @@ def build(bld):
> >      bld.stlib(target = 'ccovoar',
> >                source = ['app_common.cc',
> > +                        'AddressToLineMapper.cc',
> >                          'CoverageFactory.cc',
> >                          'CoverageMap.cc',
> >                          'CoverageMapBase.cc',
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210607/c9127379/attachment-0001.html>
