[PATCH v1] bsps/riscv: Give enough time for clock driver initialization
Gedare Bloom
gedare at rtems.org
Mon Jun 7 17:00:06 UTC 2021
On Mon, Jun 7, 2021 at 9:47 AM Jan Sommer <jan.sommer at dlr.de> wrote:
> - Clock driver initialization for secondary cores had to take less than
> one tick
> - If tick time is small (i.e. <= 1ms) setting up all cores could take
> too long and a fatal error is thrown.
> - Give at least 10 ms time for clock initialization to avoid this error
Is there a reason to pick 10?
I assume this blocks/idles the system until the interval elapses, so
it would be good to minimize waste (subject to Joel's noted rant about
premature optimization).
> bsps/riscv/riscv/clock/clockdrv.c | 8 +++++++-
> 1 file changed, 7 insertions(+), 1 deletion(-)
> diff --git a/bsps/riscv/riscv/clock/clockdrv.c b/bsps/riscv/riscv/clock/clockdrv.c
> index 3afe86576f..102137aeab 100644
> --- a/bsps/riscv/riscv/clock/clockdrv.c
> +++ b/bsps/riscv/riscv/clock/clockdrv.c
> @@ -211,7 +211,13 @@ static void riscv_clock_initialize(void)
> tc->interval = interval;
> cmpval = riscv_clock_read_mtime(&clint->mtime);
> - cmpval += interval;
> + * For very short intervals the time of 1 tick is not enough to
> + * set up the timer on all cores in SMP systems.
> + * Give the CPU at least 10 ms.
> + interval = (10000 / us_per_tick) * interval;
> + cmpval += interval;
> riscv_clock_clint_init(clint, cmpval, 0);
> riscv_clock_secondary_initialization(clint, cmpval, interval);
> 2.17.1
> devel mailing list
> devel at rtems.org
