[PATCH 5/5] bsps/sparc: Simplify memory initialization
Tue Jun 8 09:20:51 UTC 2021
Directly initialize the memory in the start sequence defined by start.S
instead of using a system initialization handler.  This avoids using the
global variable rdb_start which used a memory location which was shared
with _ERC32_MEC_Timer_Control_Mirror.  This change makes it possible to
use _Memory_Allocate() even before the system initialization is started.
Change license to BSD-2-Clause according to file history and
re-licensing agreement.
Update #3053.
 bsps/sparc/shared/start/bspgetworkarea.c | 59 ++++++++++++++----------
 bsps/sparc/shared/start/start.S          | 14 ++----
 2 files changed, 39 insertions(+), 34 deletions(-)
diff --git a/bsps/sparc/shared/start/bspgetworkarea.c b/bsps/sparc/shared/start/bspgetworkarea.c
index 3fbeb824f2..6ceda38c07 100644
--- a/bsps/sparc/shared/start/bspgetworkarea.c
+++ b/bsps/sparc/shared/start/bspgetworkarea.c
@@ -1,44 +1,55 @@
+ * @file
+ * @ingroup RTEMSScoreMemory
+ * @brief This source file contains an implementation of _Memory_Get().
- *  This set of routines are the BSP specific initialization
- *  support routines.
+ * SPDX-License-Identifier: BSD-2-Clause
- *  COPYRIGHT (c) 1989-2008.
- *  On-Line Applications Research Corporation (OAR).
+ * Copyright (C) 2019, 2021 embedded brains GmbH
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * are met:
 #include <bsp.h>
-#include <bsp/bootcard.h>
-#include <rtems/sysinit.h>
+#include <rtems/score/memory.h>
-/* Tells us where to put the workspace in case remote debugger is present.  */
-extern uintptr_t rdb_start;
+/* This function is called only by the start sequence defined in start.S */
+void _SPARC_Memory_initialize( void *end_of_usable_ram );
 static Memory_Area _Memory_Areas[ 1 ];
 static const Memory_Information _Memory_Information =
   MEMORY_INFORMATION_INITIALIZER( _Memory_Areas );
-static void bsp_memory_initialize( void )
-  void      *begin;
-  uintptr_t  size;
-  begin = &end;
-  size = rdb_start - (uintptr_t)begin;
-  _Memory_Initialize_by_size( &_Memory_Areas[ 0 ], begin, size );
+  _Memory_Initialize( &_Memory_Areas[ 0 ], &end, end_of_usable_ram );
-RTEMS_SYSINIT_ITEM(
-  bsp_memory_initialize,
-  RTEMS_SYSINIT_MEMORY,
-  RTEMS_SYSINIT_ORDER_MIDDLE
 const Memory_Information *_Memory_Get( void )
   return &_Memory_Information;
diff --git a/bsps/sparc/shared/start/start.S b/bsps/sparc/shared/start/start.S
index 807e5d1ca3..8a5830ae03 100644
--- a/bsps/sparc/shared/start/start.S
+++ b/bsps/sparc/shared/start/start.S
@@ -178,16 +178,10 @@ SYM(trap_table):
    MEC timer control register mirror is so we can stop the timers
    from an external debugger. It is needed because the control
    register is write-only. Trap 0x7C cannot occure in ERC32...
-   We also use this location to store the last location of the
-   usable RAM in order not to overwrite the remote debugger with
-   the RTEMS work-space area.
-	.global SYM(_ERC32_MEC_Timer_Control_Mirror), SYM(rdb_start), SYM(CLOCK_SPEED)
+	.global SYM(_ERC32_MEC_Timer_Control_Mirror), SYM(CLOCK_SPEED)
-SYM(rdb_start):
 SYM(_ERC32_MEC_Timer_Control_Mirror):
   BAD_TRAP; BAD_TRAP;                           ! 7C - 7D undefined
@@ -320,9 +314,6 @@ SYM(hard_reset):
 	st	%l7, [%l0]
 #endif
-	set	SYM(rdb_start), %g5	! End of RAM
-	st	%o0, [%g5]
         /* clear the bss */
         sethi %hi(__bss_start), %g2     ! g2 = start of bss
@@ -338,6 +329,9 @@ SYM(hard_reset):
         bleu,a .Lzerobss
         nop
+        call    SYM(_SPARC_Memory_initialize)
+         nop ! o0 = end of usable RAM provided by the initial stack pointer
         call    SYM(boot_card)          ! does not return
          mov    %g0, %i0                ! command line
2.26.2
