[PATCH rtems 2/2] bsps/imxrt: Simplify linkcmds and make it flexible
Chris Johns
chrisj at rtems.org
Tue Jun 8 10:05:17 UTC 2021
On 8/6/21 7:08 pm, Christian Mauderer wrote:
> Hello Chris,
> On 08/06/2021 05:07, Chris Johns wrote:
>> On 7/6/21 6:40 pm, Christian Mauderer wrote:> I think the Options don't need
>> documentation changes because the options in the
>>> waf based build system are now documented directly in the yaml files and printed
>>> if you generate the default config.
>> Hmm I am not sure I agree with the premise the YAML is the documentation. The
>> user manual exists for this purpose and user wanting to explore RTEMS would look
>> there rather than cloning the repo, running commands etc.
> The alternative would be to duplicate documentation of the BSP options in the
> user manual. And (manual) duplication is always a bad idea if you ask me. Or
> move the description from the yaml to the documentation entirely which means
> that you need to pick the correct version of the documentation for the sources.
> It also means that you have to look up the meaning of each option in the right
> version of the manual instead of in the default config.
At the moment users need to work too hard to find it. Maybe manual changes can
be added if someone wants to added them until a better solution is provided. I
think it is better that blocking changes until it is.
> I think the only reasonable option (with the current structure) would be to
> somehow automatically generate that documentation part. For example by creating
> the default BSP config.ini for each BSP and adding it to the user manual. But
> that has to be an automatic process. Otherwise it will be out of date right from
> the beginning.
.... or something else. I don't think we need to solve the problem here and now
as we do not have enough support in rtems.git to handle it.
I do not want to depend on rtems-central at this point in time. It needs to
mature, it needs to exist for a while and be supported before we can integrate it.
>> I accept the current defaults etc work flow is a good place to start for the waf
>> conversion project but we need to do a lot more to make accessing the YAML
>> easier. The wscript contains the only rtems.git repo means to read the YAML and
>> the pickled data and that limits how we can change and evolve this.
> We could merge documentation and code again. From my point of view that would
> make it simpler to add documentation for new features right when they are
> implemented and there would be always the right version for a source commit. I
> don't really know the reason why it was split up in 2015 / 2016 so we would have
> to look that up before discussing further into that direction. Additionally it
> would need discussion how and where (for example) network stacks would be
> documented.
It was split because it did not work as it did not handle the whole project so
please lets not be distracted revisiting old problems.
