[PATCH] fsnofs01/init.c: Check for ENOENT from utime().
Tue Jun 8 18:16:49 UTC 2021
The addition of the entire *utime*() family of functions resulted
in this call returning ENOENT not ENXIO. This is better aligned
with the POSIX definition of the methods.
 testsuites/fstests/fsnofs01/init.c | 9 ++++++---
 1 file changed, 6 insertions(+), 3 deletions(-)
diff --git a/testsuites/fstests/fsnofs01/init.c b/testsuites/fstests/fsnofs01/init.c
index 6260697..659ee44 100644
--- a/testsuites/fstests/fsnofs01/init.c
+++ b/testsuites/fstests/fsnofs01/init.c
@@ -187,7 +187,6 @@ static void test_path_ops(void)
   char buf [32];
   ssize_t n = 0;
   const char *path = "/";
-  const struct utimbuf times;
   errno = 0;
   rv = open(path, O_RDONLY);
@@ -294,10 +293,14 @@ static void test_path_ops(void)
   rtems_test_assert(rv == -1);
   rtems_test_assert(errno == ENXIO);
+   * Pass in NULL so the new access and modification time are interpreted
+   * as being the current time. Otherwise, the value has to be validated.
   errno = 0;
-  rv = utime(path, &times);
+  rv = utime(path, NULL);
-  rtems_test_assert(errno == ENXIO);
+  rtems_test_assert(errno == ENOENT);
 static void test_user_env(void)
1.8.3.1
