[PATCH 5/5] bsps/sparc: Simplify memory initialization
Jiri Gaisler
jiri at gaisler.se
Tue Jun 8 18:18:19 UTC 2021
On 6/8/21 4:14 PM, Sebastian Huber wrote:
> On 08/06/2021 16:03, Gedare Bloom wrote:
>> I guess at
>> some time, loading initialized data from the ROM was needed, but now
>> it is not?
> I asked about this some time ago. I think these days the RTEMS application is always loaded by a boot loader (GRMON). If the data copy is really necessary, then an application can still add this step as a very early system initialization step, since boot_card() and the system initialization loop doesn't use global data (only read-only and BSS data). However, the SMP startup would still not work in this case. A boot loader is a better place to load the sections.
The code is an artifact from the old erc32 days, when we would boot and execute from ROM and the .data had to be copied over to RAM. With leon1/2/3, this is not used anymore as a boot loader is made from the RAM image using a custom tool (mkprom).
Jiri.
