[PATCH 2/4] Update test smpstrongapa01
Richi Dubey richidubey at gmail.com
Wed Jun 9 07:39:49 UTC 2021
 testsuites/smptests/smpstrongapa01/init.c | 72 ++++++++++++++---------
 1 file changed, 43 insertions(+), 29 deletions(-)
diff --git a/testsuites/smptests/smpstrongapa01/init.c b/testsuites/smptests/smpstrongapa01/init.c
index bf8bc05231..e7abacd519 100644
--- a/testsuites/smptests/smpstrongapa01/init.c
+++ b/testsuites/smptests/smpstrongapa01/init.c
@@ -1,4 +1,5 @@
+ * Copyright (c) 2020 Richi Dubey ( richidubey at gmail.com )
  * Copyright (c) 2016, 2017 embedded brains GmbH.  All rights reserved.
  *  embedded brains GmbH
@@ -16,23 +17,28 @@
 #include "config.h"
 #endif
-#include "tmacros.h"
+#include <tmacros.h>
 const char rtems_test_name[] = "SMPSTRONGAPA 1";
-#define CPU_COUNT 4
+#define CPU_COUNT 2
-#define TASK_COUNT (3 * CPU_COUNT)
+#define TASK_COUNT 3
 #define P(i) (UINT32_C(2) + i)
 #define ALL ((UINT32_C(1) << CPU_COUNT) - 1)
-#define IDLE UINT8_C(255)
+#define A(cpu0, cpu1) ( (cpu1 << 1) | cpu0 )
-#define NAME rtems_build_name('S', 'A', 'P', 'A')
+typedef enum {
+  T0,
+  T1,
+  T2,
+  IDLE
+} task_index;
 typedef struct {
   enum {
@@ -43,7 +49,7 @@ typedef struct {
     KIND_UNBLOCK
   } kind;
-  size_t index;
+  task_index index;
   struct {
     rtems_task_priority priority;
@@ -65,54 +71,59 @@ typedef struct {
     KIND_RESET, \
     0, \
     { 0 }, \
-    { IDLE, IDLE, IDLE, IDLE } \
+    { IDLE, IDLE} \
-#define SET_PRIORITY(index, prio, cpu0, cpu1, cpu2, cpu3) \
+#define SET_PRIORITY(index, prio, cpu0, cpu1) \
     KIND_SET_PRIORITY, \
     index, \
     { .priority = prio }, \
-    { cpu0, cpu1, cpu2, cpu3 } \
+    { cpu0, cpu1} \
-#define SET_AFFINITY(index, aff, cpu0, cpu1, cpu2, cpu3) \
+#define SET_AFFINITY(index, aff, cpu0, cpu1) \
     KIND_SET_AFFINITY, \
     index, \
     { .cpu_set = aff }, \
+    { cpu0, cpu1 } \
-#define BLOCK(index, cpu0, cpu1, cpu2, cpu3) \
+#define BLOCK(index, cpu0, cpu1) \
     KIND_BLOCK, \
     index, \
     { 0 }, \
+    { cpu0, cpu1 } \
-#define UNBLOCK(index, cpu0, cpu1, cpu2, cpu3) \
+#define UNBLOCK(index, cpu0, cpu1) \
     KIND_UNBLOCK, \
     index, \
     { 0 }, \
+    { cpu0, cpu1} \
 static const test_action test_actions[] = {
   RESET,
-  UNBLOCK(      0,           0, IDLE, IDLE, IDLE),
-  UNBLOCK(      1,           0,    1, IDLE, IDLE),
-  UNBLOCK(      2,           0,    1,    2, IDLE),
-  UNBLOCK(      3,           0,    1,    2,    3),
-  UNBLOCK(      5,           0,    1,    2,    3),
-  SET_PRIORITY( 3,  P(4),    0,    1,    2,    3),
-  SET_PRIORITY( 5,  P(3),    0,    1,    2,    5),
-  BLOCK(        5,           0,    1,    2,    3),
-  SET_AFFINITY( 5,   ALL,    0,    1,    2,    3),
-  RESET,
+  UNBLOCK(      T0,		T0, IDLE),
+  UNBLOCK(      T1,		T0,    T1),
+  UNBLOCK(      T2,		T0,    T1),
+  SET_PRIORITY( T0,  P(0),	T0,    T1),
+   * Introduce Task 2 intially with lowest priority to imitate late arrival
+  SET_PRIORITY( T2,  P(4),	T0,    T1),
+  SET_PRIORITY( T1,  P(3),	T0,    T1),
+  SET_AFFINITY( T0,   ALL,	T0,    T1),
+  SET_AFFINITY( T1,   A(0, 1),	T0,    T1),
+  SET_AFFINITY( T2,   A(1, 0),	T0,    T1),
+   * Show that higher priority task gets dislodged from its processor
+  SET_PRIORITY( T2,   P(2),	T2,    T0),
   RESET
@@ -182,7 +193,7 @@ static void check_cpu_allocations(test_context *ctx, const test_action *action)
   size_t i;
   for (i = 0; i < CPU_COUNT; ++i) {
-    size_t e;
+    task_index e;
     const Per_CPU_Control *c;
     const Thread_Control *h;
@@ -279,7 +290,7 @@ static void test(void)
   for (i = 0; i < TASK_COUNT; ++i) {
     sc = rtems_task_create(
-      NAME,
+      rtems_build_name(' ', ' ', 'T', '0' + i),
       P(i),
       RTEMS_MINIMUM_STACK_SIZE,
       RTEMS_DEFAULT_MODES,
@@ -292,7 +303,10 @@ static void test(void)
     rtems_test_assert(sc == RTEMS_SUCCESSFUL);
-  sc = rtems_timer_create(NAME, &ctx->timer_id);
+  sc = rtems_timer_create(
+    rtems_build_name('A', 'C', 'T', 'N'),
+    &ctx->timer_id
   sc = rtems_timer_fire_after(ctx->timer_id, 1, timer, ctx);
2.17.1
