Running SPARC/LEON3 in TSIM-LEON3 simulator
Đức Anh dauto98 at gmail.com
Wed Jun 9 16:39:13 UTC 2021
Hi all,
I am trying to run my RTEMS application in the TSIM-LEON3 simulator. It
works fine with RTEMS version 6 (master branch) but it is not when I build
with RTEMS version 5.1 (branch 5). The reason why I revert back to version
5 because I want to use the SMP feature of RTEMS, and I haven't seen a way
to enable it through waf in version 6.
The problem is when I start tsim with rtems 5 application, it immediately
exits the program, with status 0. The code in the Init task is not even
executed.
So actually I have 2 questions:
- Is there a way to enable SMP for SPARC/LEON3 in RTEMS 6?
- have anyone use RTEMS with TSIM-LEON3 simulator before, have you succeed
in running it?
Best regards,
Duc Anh
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210609/3296a6a5/attachment-0001.html>
