[PATCH] score: Add PER_CPU_DATA_NEED_INITIALIZATION()
Sebastian Huber
Thu Jun 10 08:06:22 UTC 2021
Make the initialization of the per-CPU data optional.
cpukit/Makefile.am | 1 +
cpukit/include/rtems/score/percpudata.h | 14 ++++
cpukit/sapi/src/exinit.c | 13 ----
cpukit/score/src/percpudata.c | 94 ++++++++++++++++++++++++
cpukit/score/src/smp.c | 42 -----------
spec/build/cpukit/librtemscpu.yml | 1 +
testsuites/smptests/smpfatal09/init.c | 2 +
testsuites/sptests/sppercpudata01/init.c | 2 +
8 files changed, 114 insertions(+), 55 deletions(-)
create mode 100644 cpukit/score/src/percpudata.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 2782d58d93..78e33b683b 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -840,6 +840,7 @@ librtemscpu_a_SOURCES += score/src/coremsgwkspace.c
librtemscpu_a_SOURCES += score/src/coremutexseize.c
librtemscpu_a_SOURCES += score/src/percpu.c
librtemscpu_a_SOURCES += score/src/percpuasm.c
+librtemscpu_a_SOURCES += score/src/percpudata.c
librtemscpu_a_SOURCES += score/src/corerwlock.c
librtemscpu_a_SOURCES += score/src/corerwlockobtainread.c
librtemscpu_a_SOURCES += score/src/corerwlockobtainwrite.c
diff --git a/cpukit/include/rtems/score/percpudata.h b/cpukit/include/rtems/score/percpudata.h
index cae73a62b0..da454fd7bf 100644
--- a/cpukit/include/rtems/score/percpudata.h
+++ b/cpukit/include/rtems/score/percpudata.h
@@ -50,6 +50,20 @@ extern "C" {
RTEMS_LINKER_RWSET_DECLARE( _Per_CPU_Data, char );
+ * @brief Translation units which define per-CPU items shall call this macro
+ * exactly once at file scope.
+#ifdef RTEMS_SMP
+#define PER_CPU_DATA_NEED_INITIALIZATION() \
+ static const char * const _Per_CPU_Data_reference \
+ RTEMS_SECTION( ".rtemsroset.reference" ) RTEMS_USED = \
+ RTEMS_LINKER_SET_BEGIN( _Per_CPU_Data )
+#else
+ RTEMS_LINKER_RWSET_DECLARE( _Per_CPU_Data, char )
+#endif
* @brief Declares a per-CPU item of the specified type.
diff --git a/cpukit/sapi/src/exinit.c b/cpukit/sapi/src/exinit.c
index 9015a369a2..c98ed08f10 100644
--- a/cpukit/sapi/src/exinit.c
+++ b/cpukit/sapi/src/exinit.c
@@ -32,7 +32,6 @@
#include <rtems/score/heap.h>
#include <rtems/score/interr.h>
#include <rtems/score/isr.h>
-#include <rtems/score/percpudata.h>
#include <rtems/score/priority.h>
#include <rtems/score/smpimpl.h>
@@ -58,18 +57,6 @@ _Objects_Information_table[ OBJECTS_APIS_LAST + 1 ] = {
&_POSIX_Objects[ 0 ]
-RTEMS_LINKER_RWSET(
- _Per_CPU_Data,
-#if defined(RTEMS_SMP)
- * In SMP configurations, prevent false cache line sharing of per-processor
- * data with a proper alignment.
- RTEMS_ALIGNED( CPU_CACHE_LINE_BYTES )
-#endif
- char
static void rtems_initialize_data_structures(void)
diff --git a/cpukit/score/src/percpudata.c b/cpukit/score/src/percpudata.c
new file mode 100644
index 0000000000..091c6f0126
--- /dev/null
+++ b/cpukit/score/src/percpudata.c
@@ -0,0 +1,94 @@
+ * @file
+ * @ingroup RTEMSScorePerCPUData
+ * @brief This source file contains the per-CPU data linker set and its system
+ * initialization handler.
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2019, 2021 embedded brains GmbH
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#include <rtems/score/percpudata.h>
+#include <rtems/score/interr.h>
+#include <rtems/score/memory.h>
+#include <rtems/config.h>
+#include <rtems/sysinit.h>
+#include <string.h>
+RTEMS_LINKER_RWSET(
+ _Per_CPU_Data,
+#if defined(RTEMS_SMP)
+ * In SMP configurations, prevent false cache line sharing of per-processor
+ * data with a proper alignment.
+ RTEMS_ALIGNED( CPU_CACHE_LINE_BYTES )
+#endif
+ char
+static void _Per_CPU_Data_initialize( void )
+ uintptr_t size;
+ size = RTEMS_LINKER_SET_SIZE( _Per_CPU_Data );
+ if ( size > 0 ) {
+ const Memory_Information *mem;
+ Per_CPU_Control *cpu;
+ uint32_t cpu_index;
+ uint32_t cpu_max;
+ mem = _Memory_Get();
+ cpu = _Per_CPU_Get_by_index( 0 );
+ cpu->data = RTEMS_LINKER_SET_BEGIN( _Per_CPU_Data );
+ cpu_max = rtems_configuration_get_maximum_processors();
+ for ( cpu_index = 1 ; cpu_index < cpu_max ; ++cpu_index ) {
+ cpu = _Per_CPU_Get_by_index( cpu_index );
+ cpu->data = _Memory_Allocate( mem, size, CPU_CACHE_LINE_BYTES );
+ if( cpu->data == NULL ) {
+ _Internal_error( INTERNAL_ERROR_NO_MEMORY_FOR_PER_CPU_DATA );
+ memcpy( cpu->data, RTEMS_LINKER_SET_BEGIN( _Per_CPU_Data ), size);
+RTEMS_SYSINIT_ITEM(
+ _Per_CPU_Data_initialize,
+ RTEMS_SYSINIT_PER_CPU_DATA,
+ RTEMS_SYSINIT_ORDER_MIDDLE
+#endif
diff --git a/cpukit/score/src/smp.c b/cpukit/score/src/smp.c
index 2a3405c6ef..0488464da0 100644
--- a/cpukit/score/src/smp.c
+++ b/cpukit/score/src/smp.c
@@ -27,14 +27,9 @@
-#include <rtems/score/memory.h>
-#include <rtems/sysinit.h>
-#include <string.h>
#if CPU_USE_DEFERRED_FP_SWITCH == TRUE
#error "deferred FP switch not implemented for SMP"
@@ -264,40 +259,3 @@ void _SMP_Send_message_multicast(
-static void _Per_CPU_Data_initialize( void )
- uintptr_t size;
- size = RTEMS_LINKER_SET_SIZE( _Per_CPU_Data );
- if ( size > 0 ) {
- const Memory_Information *mem;
- Per_CPU_Control *cpu;
- uint32_t cpu_index;
- uint32_t cpu_max;
- mem = _Memory_Get();
- cpu = _Per_CPU_Get_by_index( 0 );
- cpu->data = RTEMS_LINKER_SET_BEGIN( _Per_CPU_Data );
- cpu_max = rtems_configuration_get_maximum_processors();
- for ( cpu_index = 1 ; cpu_index < cpu_max ; ++cpu_index ) {
- cpu = _Per_CPU_Get_by_index( cpu_index );
- cpu->data = _Memory_Allocate( mem, size, CPU_CACHE_LINE_BYTES );
- if( cpu->data == NULL ) {
- _Internal_error( INTERNAL_ERROR_NO_MEMORY_FOR_PER_CPU_DATA );
- memcpy( cpu->data, RTEMS_LINKER_SET_BEGIN( _Per_CPU_Data ), size);
-RTEMS_SYSINIT_ITEM(
- _Per_CPU_Data_initialize,
- RTEMS_SYSINIT_PER_CPU_DATA,
- RTEMS_SYSINIT_ORDER_MIDDLE
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index 810ba66352..e3f328ec5f 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -1454,6 +1454,7 @@ source:
- cpukit/score/src/once.c
- cpukit/score/src/percpu.c
- cpukit/score/src/percpuasm.c
+- cpukit/score/src/percpudata.c
- cpukit/score/src/pheapallocate.c
- cpukit/score/src/pheapextend.c
- cpukit/score/src/pheapfree.c
diff --git a/testsuites/smptests/smpfatal09/init.c b/testsuites/smptests/smpfatal09/init.c
index e67ed0a56a..dfdd11d84c 100644
--- a/testsuites/smptests/smpfatal09/init.c
+++ b/testsuites/smptests/smpfatal09/init.c
@@ -36,6 +36,8 @@
#include <tmacros.h>
+PER_CPU_DATA_NEED_INITIALIZATION();
static PER_CPU_DATA_ITEM(int, i) = 123;
const char rtems_test_name[] = "SMPFATAL 9";
diff --git a/testsuites/sptests/sppercpudata01/init.c b/testsuites/sptests/sppercpudata01/init.c
index 3d105ee61f..fbdf4c50ad 100644
--- a/testsuites/sptests/sppercpudata01/init.c
+++ b/testsuites/sptests/sppercpudata01/init.c
@@ -25,6 +25,8 @@
const char rtems_test_name[] = "SPPERCPUDATA 1";
static RTEMS_ALIGNED(CPU_HEAP_ALIGNMENT)
PER_CPU_DATA_ITEM(unsigned char, c) = 1;
2.26.2
