[PATCH v2] Update Strong APA Scheduler
Richi Dubey
richidubey at gmail.com
Thu Jun 10 08:49:32 UTC 2021
This change allows for the migration of higher priority tasks on the
arrival of a lower priority task limited by affinity constraints.
cpukit/include/rtems/scheduler.h | 10 +-
.../include/rtems/score/schedulerstrongapa.h | 166 ++-
cpukit/score/src/schedulerstrongapa.c | 964 ++++++++++++++----
3 files changed, 905 insertions(+), 235 deletions(-)
diff --git a/cpukit/include/rtems/scheduler.h b/cpukit/include/rtems/scheduler.h
index 955a83cfb4..76d84fd787 100644
--- a/cpukit/include/rtems/scheduler.h
+++ b/cpukit/include/rtems/scheduler.h
@@ -251,22 +251,24 @@
#ifdef CONFIGURE_SCHEDULER_STRONG_APA
#include <rtems/score/schedulerstrongapa.h>
+ #ifndef CONFIGURE_MAXIMUM_PROCESSORS
+ #error "CONFIGURE_MAXIMUM_PROCESSORS must be defined to configure the Strong APA scheduler"
+ #endif
#define SCHEDULER_STRONG_APA_CONTEXT_NAME( name ) \
SCHEDULER_CONTEXT_NAME( strong_APA_ ## name )
#define RTEMS_SCHEDULER_STRONG_APA( name, prio_count ) \
static struct { \
Scheduler_strong_APA_Context Base; \
- Chain_Control Ready[ ( prio_count ) ]; \
+ Scheduler_strong_APA_CPU CPU[ CONFIGURE_MAXIMUM_PROCESSORS ]; \
} SCHEDULER_STRONG_APA_CONTEXT_NAME( name )
#define RTEMS_SCHEDULER_TABLE_STRONG_APA( name, obj_name ) \
&SCHEDULER_STRONG_APA_CONTEXT_NAME( name ).Base.Base.Base, \
SCHEDULER_STRONG_APA_ENTRY_POINTS, \
- RTEMS_ARRAY_SIZE( \
- SCHEDULER_STRONG_APA_CONTEXT_NAME( name ).Ready \
- ) - 1, \
+ SCHEDULER_STRONG_APA_MAXIMUM_PRIORITY, \
( obj_name ) \
SCHEDULER_CONTROL_IS_NON_PREEMPT_MODE_SUPPORTED( false ) \
diff --git a/cpukit/include/rtems/score/schedulerstrongapa.h b/cpukit/include/rtems/score/schedulerstrongapa.h
index 530eadc279..3d2a3f1f39 100644
--- a/cpukit/include/rtems/score/schedulerstrongapa.h
+++ b/cpukit/include/rtems/score/schedulerstrongapa.h
@@ -8,30 +8,50 @@
- * Copyright (c) 2013, 2018 embedded brains GmbH. All rights reserved.
+ * SPDX-License-Identifier: BSD-2-Clause
- * embedded brains GmbH
- * Dornierstr. 4
- * 82178 Puchheim
- * Germany
- * <rtems at embedded-brains.de>
+ * Copyright (C) 2020 Richi Dubey
+ * Copyright (c) 2013, 2018 embedded brains GmbH
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#ifndef _RTEMS_SCORE_SCHEDULERSTRONGAPA_H
#define _RTEMS_SCORE_SCHEDULERSTRONGAPA_H
-#include <rtems/score/schedulerpriority.h>
#include <rtems/score/schedulersmp.h>
#ifdef __cplusplus
extern "C" {
#endif /* __cplusplus */
+/* Forward Declaration of Per_CPU_Control */
+struct Per_CPU_Control;
+typedef struct Per_CPU_Control Per_CPU_Control;
+#define STRONG_SCHEDULER_NODE_OF_CHAIN( node ) \
+ RTEMS_CONTAINER_OF( node, Scheduler_strong_APA_Node, Ready_node )
* @defgroup RTEMSScoreSchedulerStrongAPA Strong APA Scheduler
@@ -39,42 +59,95 @@ extern "C" {
* @brief This group contains the Strong APA Scheduler implementation.
- * This is an implementation of the global fixed priority scheduler (G-FP). It
- * uses one ready chain per priority to ensure constant time insert operations.
- * The scheduled chain uses linear insert operations and has at most processor
- * count entries. Since the processor and priority count are constants all
- * scheduler operations complete in a bounded execution time.
- * The the_thread preempt mode will be ignored.
+ * This is an implementation of the Strong APA scheduler defined by
+ * Cerqueira et al. in Linux's Processor Affinity API, Refined:
+ * Shifting Real-Time Tasks Towards Higher Schedulability.
+ * The scheduled and ready nodes are accessed via the
+ * Scheduler_strong_APA_Context::Ready which helps in backtracking when a
+ * node which is executing on a CPU gets blocked. New node is allocated to
+ * the cpu by checking all the executing nodes in the affinity set of the
+ * node and the subsequent nodes executing on the processors in its
+ * affinity set.
- * @brief Scheduler context specialization for Strong APA
- * schedulers.
+ * @brief Scheduler node specialization for Strong APA schedulers.
typedef struct {
- Scheduler_SMP_Context Base;
- Priority_bit_map_Control Bit_map;
- Chain_Control Ready[ RTEMS_ZERO_LENGTH_ARRAY ];
-} Scheduler_strong_APA_Context;
+ * @brief SMP scheduler node.
+ Scheduler_SMP_Node Base;
+ * @brief Chain node for Scheduler_strong_APA_Context::Ready.
+ Chain_Node Ready_node;
+ * @brief CPU that this node would preempt in the backtracking part of
+ * _Scheduler_strong_APA_Get_highest_ready and
+ * _Scheduler_strong_APA_Do_Enqueue.
+ Per_CPU_Control *cpu_to_preempt;
+ * @brief The associated affinity set of this node.
+ Processor_mask Affinity;
+} Scheduler_strong_APA_Node;
- * @brief Scheduler node specialization for Strong APA
- * schedulers.
+ * @brief CPU related variables and a CPU_Control to implement BFS.
typedef struct {
- * @brief SMP scheduler node.
+ * @brief CPU in a queue.
- Scheduler_SMP_Node Base;
+ Per_CPU_Control *cpu;
- * @brief The associated ready queue of this node.
+ * @brief The node that would preempt this CPU.
- Scheduler_priority_Ready_queue Ready_queue;
-} Scheduler_strong_APA_Node;
+ Scheduler_Node *preempting_node;
+ * @brief Whether or not this cpu has been added to the queue
+ * (visited in BFS).
+ bool visited;
+ * @brief The node currently executing on this cpu.
+ Scheduler_Node *executing;
+} Scheduler_strong_APA_CPU;
+ * @brief Scheduler context and node definition for Strong APA scheduler.
+typedef struct {
+ * @brief @see Scheduler_SMP_Context.
+ Scheduler_SMP_Context Base;
+ * @brief Chain of all the ready and scheduled nodes present in
+ * the Strong APA scheduler.
+ Chain_Control Ready;
+ * @brief Stores cpu-specific variables.
+ Scheduler_strong_APA_CPU CPU[ RTEMS_ZERO_LENGTH_ARRAY ];
+} Scheduler_strong_APA_Context;
+#define SCHEDULER_STRONG_APA_MAXIMUM_PRIORITY 255
* @brief Entry points for the Strong APA Scheduler.
@@ -101,8 +174,8 @@ typedef struct {
_Scheduler_default_Release_job, \
_Scheduler_default_Cancel_job, \
_Scheduler_default_Tick, \
- _Scheduler_SMP_Start_idle \
- SCHEDULER_OPERATION_DEFAULT_GET_SET_AFFINITY \
+ _Scheduler_strong_APA_Start_idle, \
+ _Scheduler_strong_APA_Set_affinity \
@@ -169,7 +242,7 @@ void _Scheduler_strong_APA_Update_priority(
* @brief Asks for help.
- * @param scheduler The scheduler control instance.
+ * @param scheduler The scheduler control instance.
* @param the_thread The thread that asks for help.
* @param node The node of @a the_thread.
@@ -247,6 +320,33 @@ void _Scheduler_strong_APA_Yield(
Scheduler_Node *node
+ * @brief Starts an idle thread.
+ * @param scheduler The scheduler instance.
+ * @param[in, out] the_thread An idle thread.
+ * @param cpu The cpu for the operation.
+void _Scheduler_strong_APA_Start_idle(
+ const Scheduler_Control *scheduler,
+ Thread_Control *idle,
+ struct Per_CPU_Control *cpu
+ * @brief Sets the affinity .
+ * @param the_thread The thread to yield.
+ * @param[in, out] node The node of @a the_thread.
+Status_Control _Scheduler_strong_APA_Set_affinity(
+ Thread_Control *thread,
+ Scheduler_Node *node_base,
+ const Processor_mask *affinity
#ifdef __cplusplus
diff --git a/cpukit/score/src/schedulerstrongapa.c b/cpukit/score/src/schedulerstrongapa.c
index dcfb55601a..dbfce03d5b 100644
--- a/cpukit/score/src/schedulerstrongapa.c
+++ b/cpukit/score/src/schedulerstrongapa.c
@@ -3,29 +3,35 @@
* @ingroup RTEMSScoreSchedulerStrongAPA
- * @brief This source file contains the implementation of
- * _Scheduler_strong_APA_Add_processor(),
- * _Scheduler_strong_APA_Ask_for_help(), _Scheduler_strong_APA_Block(),
- * _Scheduler_strong_APA_Initialize(),
- * _Scheduler_strong_APA_Node_initialize(),
- * _Scheduler_strong_APA_Reconsider_help_request(),
- * _Scheduler_strong_APA_Remove_processor(), _Scheduler_strong_APA_Unblock(),
- * _Scheduler_strong_APA_Update_priority(),
- * _Scheduler_strong_APA_Withdraw_node(), and _Scheduler_strong_APA_Yield().
+ * @brief Strong APA Scheduler Implementation
- * Copyright (c) 2013, 2016 embedded brains GmbH. All rights reserved.
- * Dornierstr. 4
- * 82178 Puchheim
- * Germany
+ * Copyright (c) 2013, 2016 embedded brains GmbH
+ * are met:
#ifdef HAVE_CONFIG_H
@@ -33,68 +39,217 @@
#endif
-#include <rtems/score/schedulerpriorityimpl.h>
#include <rtems/score/schedulersmpimpl.h>
+#include <rtems/score/assert.h>
-static Scheduler_strong_APA_Context *_Scheduler_strong_APA_Get_self(
- Scheduler_Context *context
+static inline Scheduler_strong_APA_Context *
+_Scheduler_strong_APA_Get_context( const Scheduler_Control *scheduler )
+ return (Scheduler_strong_APA_Context *) _Scheduler_Get_context( scheduler );
+_Scheduler_strong_APA_Get_self( Scheduler_Context *context )
return (Scheduler_strong_APA_Context *) context;
-static Scheduler_strong_APA_Node *
+static inline Scheduler_strong_APA_Node *
_Scheduler_strong_APA_Node_downcast( Scheduler_Node *node )
return (Scheduler_strong_APA_Node *) node;
-static void _Scheduler_strong_APA_Move_from_scheduled_to_ready(
+static inline void _Scheduler_strong_APA_Do_update(
Scheduler_Context *context,
- Scheduler_Node *scheduled_to_ready
+ Scheduler_Node *node,
+ Priority_Control new_priority
- Scheduler_strong_APA_Context *self =
- _Scheduler_strong_APA_Get_self( context );
- Scheduler_strong_APA_Node *node =
- _Scheduler_strong_APA_Node_downcast( scheduled_to_ready );
- _Chain_Extract_unprotected( &node->Base.Base.Node.Chain );
- _Scheduler_priority_Ready_queue_enqueue_first(
- &node->Base.Base.Node.Chain,
- &node->Ready_queue,
- &self->Bit_map
+ Scheduler_SMP_Node *smp_node;
+ (void) context;
+ smp_node = _Scheduler_SMP_Node_downcast( node );
+ _Scheduler_SMP_Node_update_priority( smp_node, new_priority );
-static void _Scheduler_strong_APA_Move_from_ready_to_scheduled(
- Scheduler_Context *context,
- Scheduler_Node *ready_to_scheduled
+ * Returns true if the Strong APA scheduler has ready nodes
+ * available for scheduling.
+static inline bool _Scheduler_strong_APA_Has_ready(
+ Scheduler_Context *context
Scheduler_strong_APA_Context *self;
+ const Chain_Node *tail;
+ Chain_Node *next;
Scheduler_strong_APA_Node *node;
- Priority_Control insert_priority;
self = _Scheduler_strong_APA_Get_self( context );
- node = _Scheduler_strong_APA_Node_downcast( ready_to_scheduled );
+ tail = _Chain_Immutable_tail( &self->Ready );
+ next = _Chain_First( &self->Ready );
- _Scheduler_priority_Ready_queue_extract(
- &self->Bit_map
+ while ( next != tail ) {
+ node = (Scheduler_strong_APA_Node *)STRONG_SCHEDULER_NODE_OF_CHAIN( next );
+ if (
+ _Scheduler_SMP_Node_state( &node->Base.Base ) ==
+ SCHEDULER_SMP_NODE_READY
+ return true;
+ next = _Chain_Next( next );
+ return false;
+static inline void _Scheduler_strong_APA_Set_scheduled(
+ Scheduler_strong_APA_Context *self,
+ Scheduler_Node *executing,
+ const Per_CPU_Control *cpu
+ self->CPU[ _Per_CPU_Get_index( cpu ) ].executing = executing;
+static inline Scheduler_Node *_Scheduler_strong_APA_Get_scheduled(
+ const Scheduler_strong_APA_Context *self,
+ return self->CPU[ _Per_CPU_Get_index( cpu ) ].executing;
+static inline void _Scheduler_strong_APA_Allocate_processor(
+ Scheduler_Context *context,
+ Scheduler_Node *scheduled_base,
+ Scheduler_Node *victim_base,
+ Per_CPU_Control *victim_cpu
+ Scheduler_strong_APA_Node *scheduled;
+ Scheduler_strong_APA_Context *self;
+ (void) victim_base;
+ scheduled = _Scheduler_strong_APA_Node_downcast( scheduled_base );
+ self = _Scheduler_strong_APA_Get_self( context );
+ _Scheduler_strong_APA_Set_scheduled( self, scheduled_base, victim_cpu );
+ _Scheduler_SMP_Allocate_processor_exact(
+ context,
+ &( scheduled->Base.Base ),
+ NULL,
+ victim_cpu
- insert_priority = _Scheduler_SMP_Node_priority( &node->Base.Base );
+ * Finds and returns the highest ready node present by accessing the
+ * _Strong_APA_Context->CPU with front and rear values.
+static inline Scheduler_Node * _Scheduler_strong_APA_Find_highest_ready(
+ uint32_t front,
+ uint32_t rear
+ Scheduler_Node *highest_ready;
+ Scheduler_strong_APA_CPU *CPU;
+ Chain_Node *next;
+ Scheduler_strong_APA_Node *node;
+ Priority_Control min_priority_num;
+ Priority_Control curr_priority;
+ Per_CPU_Control *assigned_cpu;
+ Scheduler_SMP_Node_state curr_state;
+ Per_CPU_Control *curr_CPU;
+ CPU = self->CPU;
+ * When the first task accessed has nothing to compare its priority against.
+ * So, it is the task with the highest priority witnessed so far.
+ min_priority_num = UINT64_MAX;
+ while ( front <= rear ) {
+ curr_CPU = CPU[ front++ ].cpu;
+ node = (Scheduler_strong_APA_Node*) STRONG_SCHEDULER_NODE_OF_CHAIN( next );
+ * Check if the curr_CPU is in the affinity set of the node.
+ if (
+ _Processor_mask_Is_set( &node->Affinity, _Per_CPU_Get_index( curr_CPU ) )
+ curr_state = _Scheduler_SMP_Node_state( &node->Base.Base );
+ if ( curr_state == SCHEDULER_SMP_NODE_SCHEDULED ) {
+ assigned_cpu = _Thread_Get_CPU( node->Base.Base.user );
+ if ( CPU[ _Per_CPU_Get_index( assigned_cpu ) ].visited == false ) {
+ CPU[ ++rear ].cpu = assigned_cpu;
+ CPU[ _Per_CPU_Get_index( assigned_cpu ) ].visited = true;
+ * The curr CPU of the queue invoked this node to add its CPU
+ * that it is executing on to the queue. So this node might get
+ * preempted because of the invoker curr_CPU and this curr_CPU
+ * is the CPU that node should preempt in case this node
+ * gets preempted.
+ node->cpu_to_preempt = curr_CPU;
+ } else if ( curr_state == SCHEDULER_SMP_NODE_READY ) {
+ curr_priority = _Scheduler_Node_get_priority( &node->Base.Base );
+ curr_priority = SCHEDULER_PRIORITY_PURIFY( curr_priority );
+ if (
+ min_priority_num == UINT64_MAX ||
+ curr_priority < min_priority_num
+ min_priority_num = curr_priority;
+ highest_ready = &node->Base.Base;
+ * In case curr_CPU is filter_CPU, we need to store the
+ * cpu_to_preempt value so that we go back to SMP_*
+ * function, rather than preempting the node ourselves.
+ return highest_ready;
+static inline void _Scheduler_strong_APA_Move_from_ready_to_scheduled(
+ Scheduler_Node *ready_to_scheduled
+ Priority_Control insert_priority;
+ insert_priority = _Scheduler_SMP_Node_priority( ready_to_scheduled );
insert_priority = SCHEDULER_PRIORITY_APPEND( insert_priority );
- _Chain_Insert_ordered_unprotected(
- &self->Base.Scheduled,
- &insert_priority,
- _Scheduler_SMP_Priority_less_equal
+ _Scheduler_SMP_Insert_scheduled(
+ context,
+ ready_to_scheduled,
+ insert_priority
-static void _Scheduler_strong_APA_Insert_ready(
+static inline void _Scheduler_strong_APA_Insert_ready(
@@ -106,228 +261,563 @@ static void _Scheduler_strong_APA_Insert_ready(
node = _Scheduler_strong_APA_Node_downcast( node_base );
- if ( SCHEDULER_PRIORITY_IS_APPEND( insert_priority ) ) {
- _Scheduler_priority_Ready_queue_enqueue(
- &self->Bit_map
- } else {
- &self->Bit_map
+ if( _Chain_Is_node_off_chain( &node->Ready_node ) ) {
+ _Chain_Append_unprotected( &self->Ready, &node->Ready_node );
+ } else {
+ _Chain_Extract_unprotected( &node->Ready_node );
+ _Chain_Set_off_chain( &node->Ready_node );
-static void _Scheduler_strong_APA_Extract_from_ready(
+static inline void _Scheduler_strong_APA_Move_from_scheduled_to_ready(
- Scheduler_Node *the_thread
+ Scheduler_Node *scheduled_to_ready
- _Scheduler_strong_APA_Node_downcast( the_thread );
- &self->Bit_map
+ if( !_Chain_Is_node_off_chain( &scheduled_to_ready->Node.Chain ) ) {
+ _Scheduler_SMP_Extract_from_scheduled( context, scheduled_to_ready );
+ insert_priority = _Scheduler_SMP_Node_priority( scheduled_to_ready );
+ _Scheduler_strong_APA_Insert_ready(
+ context,
+ scheduled_to_ready,
+ insert_priority
-static void _Scheduler_strong_APA_Do_update(
+ * Implement the BFS Algorithm for task departure to get the highest ready task
+ * for a particular CPU, returns the highest ready Scheduler_Node
+ * Scheduler_Node filter here points to the victim node that is blocked
+ * resulting which this function is called.
+static inline Scheduler_Node *_Scheduler_strong_APA_Get_highest_ready(
- Scheduler_Node *node_to_update,
- Priority_Control new_priority
+ Scheduler_Node *filter
- _Scheduler_strong_APA_Node_downcast( node_to_update );
- _Scheduler_SMP_Node_update_priority( &node->Base, new_priority );
- _Scheduler_priority_Ready_queue_update(
- SCHEDULER_PRIORITY_UNMAP( new_priority ),
- &self->Bit_map,
- &self->Ready[ 0 ]
+ Per_CPU_Control *filter_cpu;
+ Scheduler_Node *curr_node;
+ Scheduler_Node *next_node;
+ uint32_t front;
+ uint32_t rear;
+ uint32_t cpu_max;
+ uint32_t cpu_index;
+ * Denotes front and rear of the queue
+ front = 0;
+ rear = -1;
+ filter_cpu = _Thread_Get_CPU( filter->user );
+ CPU = self->CPU;
+ cpu_max = _SMP_Get_processor_maximum();
+ for ( cpu_index = 0 ; cpu_index < cpu_max ; ++cpu_index ) {
+ CPU[ cpu_index ].visited = false;
+ CPU[ ++rear ].cpu = filter_cpu;
+ CPU[ _Per_CPU_Get_index( filter_cpu ) ].visited = true;
+ highest_ready = _Scheduler_strong_APA_Find_highest_ready(
+ self,
+ front,
+ rear
+ if ( highest_ready != filter ) {
+ * Backtrack on the path from
+ * filter_cpu to highest_ready, shifting along every task.
+ node = _Scheduler_strong_APA_Node_downcast( highest_ready );
+ * Highest ready is not just directly reachable from the victim cpu
+ * So there is need for task shifting.
+ while ( node->cpu_to_preempt != filter_cpu ) {
+ curr_node = &node->Base.Base;
+ next_node = _Scheduler_strong_APA_Get_scheduled(
+ self,
+ (void) _Scheduler_SMP_Preempt(
+ context,
+ curr_node,
+ next_node,
+ _Scheduler_strong_APA_Allocate_processor
+ if ( curr_node == highest_ready ) {
+ _Scheduler_strong_APA_Move_from_ready_to_scheduled( context, curr_node );
+ node = _Scheduler_strong_APA_Node_downcast( next_node );
+ * To save the last node so that the caller SMP_* function
+ * can do the allocation
+ highest_ready = curr_node;
+ _Scheduler_strong_APA_Move_from_scheduled_to_ready( context, curr_node );
-_Scheduler_strong_APA_Get_context( const Scheduler_Control *scheduler )
+ * Checks the lowest scheduled directly reachable task
+static inline Scheduler_Node *_Scheduler_strong_APA_Get_lowest_scheduled(
+ Scheduler_Node *filter_base
- return (Scheduler_strong_APA_Context *) _Scheduler_Get_context( scheduler );
+ uint32_t cpu_max;
+ Scheduler_Node *lowest_scheduled = NULL;
+ Priority_Control max_priority_num;
+ Scheduler_strong_APA_Node *filter_strong_node;
+ max_priority_num = 0; /* Max (Lowest) priority encountered so far */
+ filter_strong_node = _Scheduler_strong_APA_Node_downcast( filter_base );
+ /* lowest_scheduled is NULL if affinity of a node is 0 */
+ _Assert( !_Processor_mask_Is_zero( &filter_strong_node->Affinity ) );
+ /* Checks if the CPU is in the affinity set of filter_strong_node */
+ if ( _Processor_mask_Is_set( &filter_strong_node->Affinity, cpu_index ) ) {
+ Per_CPU_Control *cpu = _Per_CPU_Get_by_index( cpu_index );
+ if ( _Per_CPU_Is_processor_online( cpu ) ) {
+ curr_node = _Scheduler_strong_APA_Get_scheduled( self, cpu );
+ curr_priority = _Scheduler_Node_get_priority( curr_node );
+ if ( curr_priority > max_priority_num ) {
+ lowest_scheduled = curr_node;
+ max_priority_num = curr_priority;
+ _Assert( lowest_scheduled != NULL );
+ return lowest_scheduled;
-void _Scheduler_strong_APA_Initialize( const Scheduler_Control *scheduler )
+static inline void _Scheduler_strong_APA_Extract_from_scheduled(
+ Scheduler_Node *node_to_extract
- _Scheduler_strong_APA_Get_context( scheduler );
- _Scheduler_SMP_Initialize( &self->Base );
- _Priority_bit_map_Initialize( &self->Bit_map );
- _Scheduler_priority_Ready_queue_initialize(
- &self->Ready[ 0 ],
- scheduler->maximum_priority
+ node = _Scheduler_strong_APA_Node_downcast( node_to_extract );
+ _Scheduler_SMP_Extract_from_scheduled( &self->Base.Base, &node->Base.Base );
+ /* Not removing it from Ready since the node could go in the READY state */
-void _Scheduler_strong_APA_Node_initialize(
- const Scheduler_Control *scheduler,
- Scheduler_Node *node,
- Thread_Control *the_thread,
- Priority_Control priority
+static inline void _Scheduler_strong_APA_Extract_from_ready(
- Scheduler_Context *context;
- Scheduler_strong_APA_Context *self;
- Scheduler_strong_APA_Node *the_node;
- the_node = _Scheduler_strong_APA_Node_downcast( node );
- _Scheduler_SMP_Node_initialize(
- scheduler,
- &the_node->Base,
- the_thread,
- priority
+ if( !_Chain_Is_node_off_chain( &node->Ready_node ) ) {
- context = _Scheduler_Get_context( scheduler );
- self = _Scheduler_strong_APA_Get_self( context );
- &the_node->Ready_queue,
- SCHEDULER_PRIORITY_UNMAP( priority ),
- &self->Bit_map,
- &self->Ready[ 0 ]
-static bool _Scheduler_strong_APA_Has_ready( Scheduler_Context *context )
+static inline Scheduler_Node* _Scheduler_strong_APA_Get_lowest_reachable(
+ uint32_t front,
+ uint32_t rear,
+ Per_CPU_Control **cpu_to_preempt
+ Scheduler_Node *lowest_reachable;
+ uint32_t cpu_max;
+ Thread_Control *curr_thread;
+ Scheduler_strong_APA_Node *curr_strong_node;
+ /* Max (Lowest) priority encountered so far */
+ CPU = self->CPU;
+ curr_CPU = CPU[ front ].cpu;
+ front = front + 1;
+ curr_node = _Scheduler_strong_APA_Get_scheduled( self, curr_CPU );
+ curr_thread = curr_node->user;
+ curr_strong_node = _Scheduler_strong_APA_Node_downcast( curr_node );
+ lowest_reachable = curr_node;
+ *cpu_to_preempt = curr_CPU;
+ if ( !curr_thread->is_idle ) {
+ if ( _Processor_mask_Is_set( &curr_strong_node->Affinity, cpu_index ) ) {
+ /* Checks if the thread_CPU is in the affinity set of the node */
+ if (
+ _Per_CPU_Is_processor_online( cpu ) &&
+ CPU[ cpu_index ].visited == false )
+ rear = rear + 1;
+ CPU[ rear ].cpu = cpu;
+ CPU[ cpu_index ].visited = true;
+ CPU[ cpu_index ].preempting_node = curr_node;
- return !_Priority_bit_map_Is_empty( &self->Bit_map );
+ return lowest_reachable;
-static Scheduler_Node *_Scheduler_strong_APA_Get_highest_ready(
+static inline bool _Scheduler_strong_APA_Do_enqueue(
+ Scheduler_Node *lowest_reachable,
+ Priority_Control insert_priority,
+ bool needs_help;
+ Priority_Control node_priority;
+ Priority_Control lowest_priority;
+ /* The first node that gets removed from the cpu */
+ Scheduler_Node *first_node;
- (void) node;
- return (Scheduler_Node *) _Scheduler_priority_Ready_queue_first(
- &self->Bit_map,
- &self->Ready[ 0 ]
+ CPU = self->CPU;
+ node_priority = _Scheduler_Node_get_priority( node );
+ node_priority = SCHEDULER_PRIORITY_PURIFY( node_priority );
+ if( lowest_reachable == NULL ) {
+ * This means the affinity set of the newly arrived node
+ * is empty.
+ lowest_priority = UINT64_MAX;
+ } else {
+ lowest_priority = _Scheduler_Node_get_priority( lowest_reachable );
+ lowest_priority = SCHEDULER_PRIORITY_PURIFY( lowest_priority );
+ if ( lowest_priority > node_priority ) {
+ * _Thread_Get_CPU(lowest_reachable->user) to lowest_reachable, shifting
+ * along every task
+ curr_node = CPU[ _Per_CPU_Get_index( cpu_to_preempt ) ].preempting_node;
+ curr_strong_node->cpu_to_preempt = cpu_to_preempt;
+ /* Save which cpu to preempt in cpu_to_preempt value of the node */
+ while ( curr_node != node ) {
+ curr_CPU = _Thread_Get_CPU( curr_node->user );
+ curr_node = CPU[ _Per_CPU_Get_index( curr_CPU ) ].preempting_node;
+ curr_strong_node->cpu_to_preempt = curr_CPU;
+ curr_CPU = curr_strong_node->cpu_to_preempt;
+ next_node = _Scheduler_strong_APA_Get_scheduled( self, curr_CPU );
+ node_priority = _Scheduler_Node_get_priority( curr_node );
+ _Scheduler_SMP_Enqueue_to_scheduled(
+ context,
+ curr_node,
+ node_priority,
+ next_node,
+ _Scheduler_SMP_Insert_scheduled,
+ _Scheduler_strong_APA_Move_from_scheduled_to_ready,
+ curr_node = next_node;
+ first_node = curr_node;
+ while ( curr_node != lowest_reachable ) {
+ /* curr_node preempts the next_node; */
+ _Scheduler_SMP_Preempt(
+ context,
+ curr_node,
+ next_node,
+ if(curr_node == first_node) {
+ _Scheduler_strong_APA_Move_from_ready_to_scheduled(context, first_node);
+ _Scheduler_strong_APA_Move_from_scheduled_to_ready( context, lowest_reachable );
+ needs_help = false;
+ } else {
+ needs_help = true;
+ /* Add it to Ready chain since it is now either scheduled or just ready. */
+ _Scheduler_strong_APA_Insert_ready( context,node, insert_priority );
+ return needs_help;
-void _Scheduler_strong_APA_Block(
+ * BFS Algorithm for task arrival
+ * Enqueue node either in the scheduled chain or in the ready chain.
+ * node is the newly arrived node and is currently not scheduled.
+static inline bool _Scheduler_strong_APA_Enqueue(
- Scheduler_Context *context = _Scheduler_Get_context( scheduler );
+ uint32_t cpu_max;
+ Scheduler_strong_APA_Node *strong_node;
- _Scheduler_SMP_Block(
+ /* Denotes front and rear of the queue */
+ uint32_t front;
+ uint32_t rear;
+ front = 0;
+ rear = -1;
+ strong_node = _Scheduler_strong_APA_Node_downcast( node );
+ CPU = self->CPU;
+ if ( _Processor_mask_Is_set( &strong_node->Affinity, cpu_index ) ) {
+ rear = rear + 1;
+ CPU[ cpu_index ].preempting_node = node;
+ lowest_reachable = _Scheduler_strong_APA_Get_lowest_reachable(
+ self,
+ front,
+ rear,
+ &cpu_to_preempt
+ return _Scheduler_strong_APA_Do_enqueue(
+ context,
+ lowest_reachable,
+ node,
+ insert_priority,
+ cpu_to_preempt
+static inline bool _Scheduler_strong_APA_Enqueue_scheduled(
+ return _Scheduler_SMP_Enqueue_scheduled(
context,
- the_thread,
node,
- _Scheduler_SMP_Extract_from_scheduled,
+ insert_priority,
+ _Scheduler_SMP_Priority_less_equal,
_Scheduler_strong_APA_Extract_from_ready,
_Scheduler_strong_APA_Get_highest_ready,
+ _Scheduler_strong_APA_Insert_ready,
_Scheduler_strong_APA_Move_from_ready_to_scheduled,
- _Scheduler_SMP_Allocate_processor_exact
-static bool _Scheduler_strong_APA_Enqueue(
+static inline bool _Scheduler_strong_APA_Do_ask_for_help(
+ Thread_Control *the_thread,
- return _Scheduler_SMP_Enqueue(
+ return _Scheduler_SMP_Ask_for_help(
context,
+ the_thread,
node,
- insert_priority,
- _Scheduler_SMP_Get_lowest_scheduled,
+ _Scheduler_strong_APA_Get_lowest_scheduled,
-static bool _Scheduler_strong_APA_Enqueue_scheduled(
+static inline void _Scheduler_strong_APA_Do_set_affinity(
+ void *arg
- return _Scheduler_SMP_Enqueue_scheduled(
+ node = _Scheduler_strong_APA_Node_downcast( node_base );
+ node->Affinity = *( (const Processor_mask *) arg );
+void _Scheduler_strong_APA_Initialize( const Scheduler_Control *scheduler )
+ Scheduler_strong_APA_Context *self =
+ _Scheduler_strong_APA_Get_context( scheduler );
+ _Scheduler_SMP_Initialize( &self->Base );
+ _Chain_Initialize_empty( &self->Ready );
+void _Scheduler_strong_APA_Yield(
+ Scheduler_Context *context = _Scheduler_Get_context( scheduler );
+ _Scheduler_SMP_Yield(
context,
+ thread,
node,
- insert_priority,
- _Scheduler_SMP_Priority_less_equal,
- _Scheduler_strong_APA_Get_highest_ready,
- _Scheduler_strong_APA_Insert_ready,
- _Scheduler_SMP_Insert_scheduled,
- _Scheduler_strong_APA_Move_from_ready_to_scheduled,
+ _Scheduler_strong_APA_Enqueue,
+ _Scheduler_strong_APA_Enqueue_scheduled
-void _Scheduler_strong_APA_Unblock(
+void _Scheduler_strong_APA_Block(
- _Scheduler_SMP_Unblock(
+ * Needed in case the node is scheduled node, since _SMP_Block only extracts
+ * from the SMP scheduled chain and from the Strong APA Ready_chain
+ * when the node is ready. But the Strong APA Ready_chain stores both
+ * ready and scheduled nodes.
+ _Scheduler_strong_APA_Extract_from_ready(context, node);
+ _Scheduler_SMP_Block(
context,
- the_thread,
+ thread,
node,
- _Scheduler_strong_APA_Do_update,
- _Scheduler_strong_APA_Enqueue
+ _Scheduler_strong_APA_Extract_from_scheduled,
+ _Scheduler_strong_APA_Extract_from_ready,
+ _Scheduler_strong_APA_Get_highest_ready,
+ _Scheduler_strong_APA_Move_from_ready_to_scheduled,
-static bool _Scheduler_strong_APA_Do_ask_for_help(
+void _Scheduler_strong_APA_Unblock(
- return _Scheduler_SMP_Ask_for_help(
+ _Scheduler_SMP_Unblock(
context,
- the_thread,
+ thread,
node,
- _Scheduler_strong_APA_Move_from_scheduled_to_ready,
- _Scheduler_SMP_Allocate_processor_lazy
+ _Scheduler_strong_APA_Do_update,
@@ -335,7 +825,7 @@ void _Scheduler_strong_APA_Update_priority(
_Scheduler_SMP_Update_priority(
context,
- the_thread,
+ thread,
node,
@@ -353,7 +843,11 @@ bool _Scheduler_strong_APA_Ask_for_help(
- return _Scheduler_strong_APA_Do_ask_for_help( context, the_thread, node );
+ return _Scheduler_strong_APA_Do_ask_for_help(
+ context,
+ the_thread,
+ node
void _Scheduler_strong_APA_Reconsider_help_request(
@@ -389,10 +883,22 @@ void _Scheduler_strong_APA_Withdraw_node(
+static inline void _Scheduler_strong_APA_Register_idle(
+ Scheduler_Node *idle_base,
+ _Scheduler_strong_APA_Set_scheduled( self, idle_base, cpu );
void _Scheduler_strong_APA_Add_processor(
@@ -405,7 +911,25 @@ void _Scheduler_strong_APA_Add_processor(
idle,
_Scheduler_strong_APA_Has_ready,
_Scheduler_strong_APA_Enqueue_scheduled,
- _Scheduler_SMP_Do_nothing_register_idle
+ _Scheduler_strong_APA_Register_idle
+ Scheduler_Context *context;
+ context = _Scheduler_Get_context( scheduler );
+ _Scheduler_SMP_Do_start_idle(
+ context,
+ idle,
+ cpu,
@@ -424,20 +948,64 @@ Thread_Control *_Scheduler_strong_APA_Remove_processor(
-void _Scheduler_strong_APA_Yield(
+void _Scheduler_strong_APA_Node_initialize(
+ Priority_Control priority
- _Scheduler_SMP_Yield(
- context,
- the_thread,
- node,
- _Scheduler_strong_APA_Extract_from_ready,
- _Scheduler_strong_APA_Enqueue,
- _Scheduler_strong_APA_Enqueue_scheduled
+ _Scheduler_SMP_Node_initialize( scheduler, smp_node, the_thread, priority );
+ _Processor_mask_Assign(
+ &strong_node->Affinity,
+ _SMP_Get_online_processors()
+ Processor_mask local_affinity;
+ _Processor_mask_And( &local_affinity, &context->Processors, affinity );
+ if ( _Processor_mask_Is_zero( &local_affinity ) ) {
+ return STATUS_INVALID_NUMBER;
+ if ( _Processor_mask_Is_equal( &node->Affinity, affinity ) )
+ return STATUS_SUCCESSFUL; /* Nothing to do. Return true. */
+ _Processor_mask_Assign( &node->Affinity, &local_affinity );
+ _Scheduler_SMP_Set_affinity(
+ context,
+ thread,
+ node_base,
+ &local_affinity,
+ _Scheduler_strong_APA_Do_set_affinity,
2.17.1
