[PATCH 1/7] grlib: Customizable allocation in ambapp_scan()
Thu Jun 10 13:24:00 UTC 2021
Make the memory allocations in ambapp_scan() customizable via the new struct
ambapp_context parameter which generalizes the memory copy handler.
 bsps/include/grlib/ambapp.h     | 27 ++++++++++++++--------
 bsps/shared/grlib/amba/ambapp.c | 41 ++++++++++++++++++++-------------
 2 files changed, 42 insertions(+), 26 deletions(-)
diff --git a/bsps/include/grlib/ambapp.h b/bsps/include/grlib/ambapp.h
index 3c3d3e9e3e..12911a6a3d 100644
--- a/bsps/include/grlib/ambapp.h
+++ b/bsps/include/grlib/ambapp.h
@@ -15,6 +15,15 @@
 #ifndef __AMBAPP_H__
 #define __AMBAPP_H__
+#include <stddef.h>
+/* Include VENDOR and DEVICE definitions */
+#include "ambapp_ids.h"
+#ifdef __cplusplus
+extern "C" {
+#endif
  * @defgroup amba AMBA
@@ -25,13 +34,6 @@
-/* Include VENDOR and DEVICE definitions */
-#include "ambapp_ids.h"
-#ifdef __cplusplus
-extern "C" {
-#endif
 /* Max supported AHB buses */
 #define AHB_BUS_MAX 6
@@ -181,6 +183,11 @@ typedef void *(*ambapp_memcpy_t)(
 	struct ambapp_bus *abus	/* Optional AMBA Bus pointer */
+struct ambapp_context {
+  ambapp_memcpy_t memfunc;
+  void *(*alloc)(size_t);
 /* Scan a AMBA Plug & Play bus and create all device structures describing the
  * the devices. The devices will form a tree, where every node describes one
  * interface. The resulting tree is placed in the location pointed to by root.
@@ -188,16 +195,16 @@ typedef void *(*ambapp_memcpy_t)(
  * Since it the tree is located in RAM it is easier to work with AMBA buses
  * that is located over PCI and SpaceWire etc.
+ * \param abus     Resulting device node tree root is stored here.
  * \param ioarea   The IO-AREA where Plug & Play information can be found.
- * \param parent   Used internally when recursing down a bridge. Set to NULL.
+ * \param ctx      The scan context.  May be NULL.
  * \param mmaps    Is used to perform address translation if needed.
- * \param root     Resulting device node tree root is stored here.
 extern int ambapp_scan(
 	struct ambapp_bus *abus,
 	unsigned int ioarea,
-	ambapp_memcpy_t memfunc,
+	const struct ambapp_context *ctx,
 	struct ambapp_mmap *mmaps
diff --git a/bsps/shared/grlib/amba/ambapp.c b/bsps/shared/grlib/amba/ambapp.c
index e87c86a586..62e16a9f62 100644
--- a/bsps/shared/grlib/amba/ambapp.c
+++ b/bsps/shared/grlib/amba/ambapp.c
@@ -23,7 +23,8 @@
 #define AMBA_APB_SLAVES 16
 /* Allocate one AMBA device */
-static struct ambapp_dev *ambapp_alloc_dev_struct(int dev_type)
+static struct ambapp_dev *
+ambapp_alloc_dev_struct(const struct ambapp_context *ctx, int dev_type)
   struct ambapp_dev *dev;
   size_t size = sizeof(*dev);
@@ -32,9 +33,11 @@ static struct ambapp_dev *ambapp_alloc_dev_struct(int dev_type)
     size += sizeof(struct ambapp_apb_info);
   else
     size += sizeof(struct ambapp_ahb_info); /* AHB */
-  dev = grlib_calloc(1, size);
-  if (dev != NULL)
+  dev = (*ctx->alloc)(size);
+  if (dev != NULL) {
+    dev = memset(dev, 0, size);
     dev->dev_type = dev_type;
   return dev;
@@ -145,7 +148,7 @@ static int ambapp_add_ahbbus(
 static int ambapp_scan2(
   struct ambapp_dev *parent,
   struct ambapp_dev **root
@@ -176,12 +179,12 @@ static int ambapp_scan2(
   /* AHB MASTERS */
   ahb = (struct ambapp_pnp_ahb *) (ioarea | AMBA_CONF_AREA);
   for (i = 0; i < maxloops; i++, ahb++) {
-    memfunc(&ahb_buf, ahb, sizeof(struct ambapp_pnp_ahb), abus);
+    (*ctx->memfunc)(&ahb_buf, ahb, sizeof(struct ambapp_pnp_ahb), abus);
     if (ahb_buf.id == 0)
       continue;
     /* An AHB device present here */
-    dev = ambapp_alloc_dev_struct(DEV_AHB_MST);
+    dev = ambapp_alloc_dev_struct(ctx, DEV_AHB_MST);
     if (!dev)
       return -1;
@@ -200,12 +203,12 @@ static int ambapp_scan2(
     (ioarea | AMBA_CONF_AREA | AMBA_AHB_SLAVE_CONF_AREA);
       continue;
-    dev = ambapp_alloc_dev_struct(DEV_AHB_SLV);
+    dev = ambapp_alloc_dev_struct(ctx, DEV_AHB_SLV);
     if (!dev)
       return -1;
@@ -235,7 +238,7 @@ static int ambapp_scan2(
         bridge_adr = ambapp_addr_from(abus->mmaps,
               ahb_info->custom[1]);
         /* Scan next bus if not already scanned */
-        if (ambapp_scan2(abus, bridge_adr, memfunc, dev,
+        if (ambapp_scan2(abus, bridge_adr, ctx, dev,
             &dev->children))
           return -1;
@@ -251,11 +254,11 @@ static int ambapp_scan2(
       apb = (struct ambapp_pnp_apb *)
         (apbbase | AMBA_CONF_AREA);
       for (j=0; j<AMBA_APB_SLAVES; j++, apb++) {
-        memfunc(&apb_buf, apb, sizeof(*apb), abus);
+        (*ctx->memfunc)(&apb_buf, apb, sizeof(*apb), abus);
         if (apb_buf.id == 0)
           continue;
-        apbdev = ambapp_alloc_dev_struct(DEV_APB_SLV);
+        apbdev = ambapp_alloc_dev_struct(ctx, DEV_APB_SLV);
         if (!apbdev)
           return -1;
@@ -279,22 +282,28 @@ static int ambapp_scan2(
   return 0;
+static const struct ambapp_context default_ctx = {
+  .memfunc = (ambapp_memcpy_t)memcpy,
+  .alloc = rtems_malloc
 /* Build AMBA Plug & Play device graph */
 int ambapp_scan(
   memset(abus, 0, sizeof(*abus));
   abus->mmaps = mmaps;
-  /* Default to memcpy() */
-  if (!memfunc)
-    memfunc = (ambapp_memcpy_t)memcpy;
+  if (ctx == NULL) {
+    ctx = &default_ctx;
-  return ambapp_scan2(abus, ioarea, memfunc, NULL, &abus->root);
+  return ambapp_scan2(abus, ioarea, ctx, NULL, &abus->root);
 /* Match search options againt device */
2.26.2
