[PATCH v2] Update Strong APA Scheduler
Thu Jun 10 13:50:15 UTC 2021
We'll need the entire patch set resent for commit, but you can work
through the scheduler addition first if you like, and then resend the
tests as their own patch set.
On Thu, Jun 10, 2021 at 7:20 AM Sebastian Huber
> On 10/06/2021 10:49, Richi Dubey wrote:
> > +/* Forward Declaration of Per_CPU_Control */
> > +struct Per_CPU_Control;
> > +typedef struct Per_CPU_Control Per_CPU_Control;
> Please remove the typedef.
> > +#define STRONG_SCHEDULER_NODE_OF_CHAIN( node ) \
> > +  RTEMS_CONTAINER_OF( node, Scheduler_strong_APA_Node, Ready_node )
> Please move this define to an implementation header/source file.
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
> _________Richi Dubey <richidubey at gmail.com>______________________________________
> devel mailing list
> devel at rtems.org
