[libbsd] EPOCH(9): Fix epoch call and drain
Sebastian Huber
Fri Jun 11 06:46:18 UTC 2021
Since the epoch call callbacks may lock/unlock a mutex the callbacks must be
called from within thread context with thread dispatching enabled. Use thread
pinning to ensure that the calling thread stays on the right processor. Use
the interrupt server to ensure the thread context for the epoch drain.
rtemsbsd/rtems/rtems-kernel-epoch.c | 39 ++++++++++++++++++++++++++---
1 file changed, 35 insertions(+), 4 deletions(-)
diff --git a/rtemsbsd/rtems/rtems-kernel-epoch.c b/rtemsbsd/rtems/rtems-kernel-epoch.c
index 0c070bd8..642b5854 100644
--- a/rtemsbsd/rtems/rtems-kernel-epoch.c
+++ b/rtemsbsd/rtems/rtems-kernel-epoch.c
@@ -349,15 +349,29 @@ epoch_call(epoch_t epoch, epoch_context_t ctx,
void (*callback) (epoch_context_t))
Per_CPU_Control *cpu_self;
- struct epoch_record *er;
struct epoch_pcpu *epcpu;
+ struct epoch_record *er;
+#ifdef RTEMS_SMP
+ ISR_Level level;
+ Thread_Control *executing;
+ _ISR_Local_disable(level);
+ cpu_self = _Per_CPU_Get();
+ executing = _Per_CPU_Get_executing(cpu_self);
+ _Thread_Pin(executing);
+ _ISR_Local_enable(level);
+#endif
- cpu_self = _Thread_Dispatch_disable();
epcpu = PER_CPU_DATA_GET(cpu_self, struct epoch_pcpu, epoch);
epcpu->cb_count += 1;
er = EPOCH_GET_RECORD(cpu_self, epoch);
ck_epoch_call(&er->er_record, ctx, callback);
+#ifdef RTEMS_SMP
+ cpu_self = _Thread_Dispatch_disable();
+ _Thread_Unpin(executing, cpu_self);
_Thread_Dispatch_enable(cpu_self);
+#endif
#ifdef INVARIANTS
@@ -411,7 +425,7 @@ epoch_call_drain_cb(void *arg)
epoch = arg;
- cpu = _Per_CPU_Get();
+ cpu = _Per_CPU_Get_snapshot();
er = EPOCH_GET_RECORD(cpu, epoch);
epoch_call(epoch, &er->er_drain_ctx, epoch_drain_cb);
@@ -425,6 +439,7 @@ epoch_drain_callbacks(epoch_t epoch)
uint32_t cpu_max;
rtems_id id;
rtems_status_code sc;
+ rtems_interrupt_server_request req[CPU_MAXIMUM_PROCESSORS];
#else
#endif
@@ -433,6 +448,7 @@ epoch_drain_callbacks(epoch_t epoch)
mtx_lock(&epoch->e_drain_mtx);
#ifdef RTEMS_SMP
+ memset(&req, 0, sizeof(req));
cpu_max = rtems_scheduler_get_processor_maximum();
for (cpu_index = 0; cpu_index <= cpu_max; ++cpu_index) {
@@ -445,8 +461,15 @@ epoch_drain_callbacks(epoch_t epoch)
sc = rtems_scheduler_ident_by_processor(cpu_index, &id);
if (sc == RTEMS_SUCCESSFUL) {
- _SMP_Unicast_action(cpu_index, epoch_call_drain_cb,
+ sc = rtems_interrupt_server_request_initialize(
+ cpu_index, &req[cpu_index], epoch_call_drain_cb,
epoch);
+ if (sc == RTEMS_SUCCESSFUL) {
+ rtems_interrupt_server_request_submit(
+ &req[cpu_index]);
+ } else {
+ panic("no interrupt server for epoch drain");
#else
@@ -461,4 +484,12 @@ epoch_drain_callbacks(epoch_t epoch)
mtx_unlock(&epoch->e_drain_mtx);
sx_xunlock(&epoch->e_drain_sx);
+#ifdef RTEMS_SMP
+ for (cpu_index = 0; cpu_index <= cpu_max; ++cpu_index) {
+ if (req[cpu_index].action.handler != NULL) {
+ rtems_interrupt_server_request_destroy(&req[cpu_index]);
+#endif
2.26.2
