Can't build minimal buildset for libbsd on IMXRT
dufault at hda.com dufault at hda.com
Fri Jun 11 13:36:06 UTC 2021
> On Jun 11, 2021, at 09:22 , Christian Mauderer <oss at c-mauderer.de> wrote:
> Yes, right. But if I didn't miss one, they should be all called only if INET6 is defined (in rtemsbsd/include/rtems/bsd/local/opt_inet6.h). In the minimal buildset that shouldn't be the case.
> Do you have a previously installed libbsd in your prefix that might mess with the build?
I *do* have a previously installed libbsd in my prefix. I don't understand the workflow properly.
I figured that if I did "./waf distclean" in rtems-libbsd between switching build sets the build woiuld bootstrap properly but evidently not.
Do you need to use multiple prefixes to support multiple build sets?  I wanted to try the minimal one first before installing.
Peter
Peter Dufault
HD Associates, Inc.      Software and System Engineering
This email is delivered through the public internet using protocols subject to interception and tampering.
Type: application/pgp-signature
Desc: Message signed with OpenPGP
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210611/4bd76741/attachment.bin>
