[PATCH rtems-libbsd v2 3/4] rtemsbsd: Made TTCP command build for RTEMS
Tue Jun 15 18:03:42 UTC 2021
On Tue, Jun 15, 2021 at 10:25 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Fri, Jun 11, 2021 at 11:19 AM Stephen Clark
> <stephen.clark at oarcorp.com> wrote:
> > Updated ttcp.c to build for RTEMS 6, in addition to the machines
> > it originally built for. Also fixed ttcp.c to close network sockets
> > after completion. Defined a shell command for TTCP in
> > rtems-bsd-shell-ttcp.c. Added TTCP to the list of RTEMS network
> > commands in netcmds-config.h. Added declaration of the TTCP shell
> > command to rtems-bsd-commands.h. Modified libbsd.py to make waf
> > build TTCP and its shell command.
> >  libbsd.py                                     |   2 +
> >  rtemsbsd/include/machine/rtems-bsd-commands.h |   2 +
> >  rtemsbsd/include/rtems/netcmds-config.h       |   2 +
> >  rtemsbsd/rtems/rtems-bsd-shell-ttcp.c         |  39 +++
> >  rtemsbsd/ttcp/README                          |  11 +-
> >  rtemsbsd/ttcp/ttcp.c                          | 266 ++++++++++++++----
> >  6 files changed, 262 insertions(+), 60 deletions(-)
> >  create mode 100644 rtemsbsd/rtems/rtems-bsd-shell-ttcp.c
> > diff --git a/libbsd.py b/libbsd.py
> > index b367d94e..2badfdee 100644
> > --- a/libbsd.py
> > +++ b/libbsd.py
> > @@ -269,6 +269,7 @@ class rtems(builder.Module):
> >                  'rtems/rtems-bsd-shell-tcpdump.c',
> >                  'rtems/rtems-bsd-shell-vmstat.c',
> >                  'rtems/rtems-bsd-shell-wlanstats.c',
> > +                'rtems/rtems-bsd-shell-ttcp.c',
> >                  'rtems/rtems-kvm.c',
> >                  'rtems/rtems-program.c',
> >                  'rtems/rtems-program-socket.c',
> > @@ -292,6 +293,7 @@ class rtems(builder.Module):
> >                  'pppd/upap.c',
> >                  'pppd/utils.c',
> >                  'telnetd/telnetd-service.c',
> > +                'ttcp/ttcp.c',
> >              mm.generator['source']()
> > diff --git a/rtemsbsd/include/machine/rtems-bsd-commands.h
> b/rtemsbsd/include/machine/rtems-bsd-commands.h
> > index d314471f..d82c274c 100644
> > --- a/rtemsbsd/include/machine/rtems-bsd-commands.h
> > +++ b/rtemsbsd/include/machine/rtems-bsd-commands.h
> > @@ -84,6 +84,8 @@ int rtems_bsd_command_setkey(int argc, char **argv);
> >  int rtems_bsd_command_openssl(int argc, char **argv);
> > +int rtems_shell_main_ttcp(int argc, char **argv);
> >  __END_DECLS
> >  #endif /* _RTEMS_BSD_MACHINE_RTEMS_BSD_COMMANDS_H_ */
> > diff --git a/rtemsbsd/include/rtems/netcmds-config.h
> b/rtemsbsd/include/rtems/netcmds-config.h
> > index bc493af4..c1d56eb3 100644
> > --- a/rtemsbsd/include/rtems/netcmds-config.h
> > +++ b/rtemsbsd/include/rtems/netcmds-config.h
> > @@ -29,6 +29,8 @@ extern rtems_shell_cmd_t rtems_shell_PFCTL_Command;
> >  extern rtems_shell_cmd_t rtems_shell_PING_Command;
> >  extern rtems_shell_cmd_t rtems_shell_PING6_Command;
> > +extern rtems_shell_cmd_t rtems_shell_TTCP_Command;
> >  extern rtems_shell_cmd_t rtems_shell_IFCONFIG_Command;
> >  extern rtems_shell_cmd_t rtems_shell_IFMCSTAT_Command;
> > diff --git a/rtemsbsd/rtems/rtems-bsd-shell-ttcp.c
> b/rtemsbsd/rtems/rtems-bsd-shell-ttcp.c
> > new file mode 100644
> > index 00000000..babaa011
> > --- /dev/null
> > +++ b/rtemsbsd/rtems/rtems-bsd-shell-ttcp.c
> > @@ -0,0 +1,39 @@
> > +/* SPDX-License-Identifier: BSD-2-Clause */
> > + * COPYRIGHT (c) 2021. On-Line Applications Research Corporation (OAR).
> > + * All rights reserved.
> > + * Redistribution and use in source and binary forms, with or without
> > + * modification, are permitted provided that the following conditions
> > + * are met:
> > + * 1. Redistributions of source code must retain the above copyright
> > + *    notice, this list of conditions and the following disclaimer.
> > + * 2. Redistributions in binary form must reproduce the above copyright
> > + *    notice, this list of conditions and the following disclaimer in
> the
> > + *    documentation and/or other materials provided with the
> distribution.
> > + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS''
> AND
> > + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> > + * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE
> LIABLE
> > + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> CONSEQUENTIAL
> > + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE
> GOODS
> > + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
> > + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
> STRICT
> > + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN
> ANY WAY
> > + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
> OF
> > + * SUCH DAMAGE.
> > +#include <rtems/netcmds-config.h>
> > +#include <machine/rtems-bsd-commands.h>
> > +rtems_shell_cmd_t rtems_shell_TTCP_Command = {
> > +  "ttcp",                                           /* name */
> > +  "ttcp -h                     # to get help",      /* usage */
> > +  "net",                                            /* topic */
> > +  rtems_shell_main_ttcp,                            /* command */
> > +  NULL,                                             /* alias */
> > +  NULL                                              /* next */
> > diff --git a/rtemsbsd/ttcp/README b/rtemsbsd/ttcp/README
> > index 215ddacc..8a9bf017 100644
> > --- a/rtemsbsd/ttcp/README
> > +++ b/rtemsbsd/ttcp/README
> > @@ -7,14 +7,9 @@ but please do leave the credit notices in the source
> and man page intact.
> >  Contents of this directory:
> > -ttcp.c          Source that runs on IRIX 3.3.x and 4.0.x systems
> > -                and BSD-based systems.  This version also uses getopt(3)
> > -                and has 2 new options: -f and -T.
> > -ttcp.c-brl      Original source from BRL.
> > -ttcp.1          Manual page (describes ttcp.c options, which are a
> > -                superset of the other version).
> > +ttcp.c          Source that runs on IRIX 3.3.x and 4.0.x systems,
> > +                BSD-based systems, and RTEMS.  This version also
> > +                uses getopt(3) and has 2 new options: -f and -T.
> >  How to get TCP performance numbers:
> > diff --git a/rtemsbsd/ttcp/ttcp.c b/rtemsbsd/ttcp/ttcp.c
> > index dc62c64b..46e0f3fc 100644
> > --- a/rtemsbsd/ttcp/ttcp.c
> > +++ b/rtemsbsd/ttcp/ttcp.c
> > @@ -74,48 +74,95 @@ struct rusage {
> >  #include <sys/resource.h>
> >  #endif
> > -struct sockaddr_in sinme;
> > -struct sockaddr_in sinhim;
> > -struct sockaddr_in frominet;
> > +#if defined(__rtems__)
> > +#define __need_getopt_newlib
> > +#include <getopt.h>
> > +#include <rtems/shell.h>
> > +#endif
> > +static struct sockaddr_in sinme;
> > +static struct sockaddr_in sinhim;
> > +static struct sockaddr_in frominet;
> Are some of these changes in line with an upstream copy? Are you
> trying to use the __rtems__ guards to demark the RTEMS-specific
> changes from the upstream copy?
> Usually we would prefer to have all the upstream code added, and then
> add the __rtems__parts, and then add the code to the build system.
> Would that be possible and the right thing to do in this case also?
> >  /* these make it easier to avoid warnings */
> > -struct sockaddr *sinhim_p = (struct sockaddr *) &sinhim;
> > -struct sockaddr *sinme_p = (struct sockaddr *) &sinme;
> > -struct sockaddr *frominet_p = (struct sockaddr *) &frominet;
> > -int domain;
> > -socklen_t fromlen;
> > -int fd;                                /* fd of network socket */
> > -int buflen = 8 * 1024;         /* length of buffer */
> > -char *buf;                     /* ptr to dynamic buffer */
> > -int nbuf = 2 * 1024;           /* number of buffers to send in sinkmode
> > -int bufoffset = 0;             /* align buffer to this */
> > -int bufalign = 16*1024;                /* modulo this */
> > -int udp = 0;                   /* 0 = tcp, !0 = udp */
> > -int options = 0;               /* socket options */
> > -int one = 1;                    /* for 4.3 BSD style setsockopt() */
> > -short port = 5001;             /* TCP port number */
> > -char *host;                    /* ptr to name of host */
> > -int trans;                     /* 0=receive, !0=transmit mode */
> > -int sinkmode = 0;              /* 0=normal I/O, !0=sink/source mode */
> > -int verbose = 0;               /* 0=print basic info, 1=print cpu rate,
> proc
> > +static struct sockaddr *sinhim_p = (struct sockaddr *) &sinhim;
> > +static struct sockaddr *sinme_p = (struct sockaddr *) &sinme;
> > +static struct sockaddr *frominet_p = (struct sockaddr *) &frominet;
> > +static int domain;
> > +static socklen_t fromlen;
> > +static int fd;                         /* fd of network socket */
> > +static int buflen = 8 * 1024;          /* length of buffer */
> > +static char *buf;                      /* ptr to dynamic buffer */
> > +static char *alloc_buf;                        /* ptr to beginning of
> memory allocated for buf */
> > +static int nbuf = 2 * 1024;            /* number of buffers to send in
> sinkmode */
> > +static int bufoffset = 0;              /* align buffer to this */
> > +static int bufalign = 16*1024;         /* modulo this */
> > +static int udp = 0;                    /* 0 = tcp, !0 = udp */
> > +static int options = 0;                /* socket options */
> > +static int one = 1;                    /* for 4.3 BSD style
> setsockopt() */
> > +static short port = 5001;              /* TCP port number */
> > +static char *host;                     /* ptr to name of host */
> > +static int trans;                      /* 0=receive, !0=transmit mode */
> > +static int sinkmode = 0;               /* 0=normal I/O, !0=sink/source
> mode */
> > +static int verbose = 0;                /* 0=print basic info, 1=print
> cpu rate, proc
> >                                  * resource usage. */
> > -int nodelay = 0;               /* set TCP_NODELAY socket option */
> > -int b_flag = 0;                        /* use mread() */
> > -int sockbufsize = 0;           /* socket buffer size to use */
> > -char fmt = 'K';                        /* output format: k = kilobits,
> K = kilobytes,
> > +static int nodelay = 0;                /* set TCP_NODELAY socket option
> > +static int b_flag = 0;                 /* use mread() */
> > +static int sockbufsize = 0;            /* socket buffer size to use */
> > +static char fmt = 'K';                 /* output format: k = kilobits,
> K = kilobytes,
> >                                  *  m = megabits, M = megabytes,
> >                                  *  g = gigabits, G = gigabytes */
> > -int touchdata = 0;             /* access data after reading */
> > -long milliseconds = 0;          /* delay in milliseconds */
> > +static int touchdata = 0;              /* access data after reading */
> > +static long milliseconds = 0;          /* delay in milliseconds */
> > -struct hostent *addr;
> > -extern int errno;
> > -extern int optind;
> > -extern char *optarg;
> > +static struct hostent *addr;
> > +static void initialize_vars(void)
> > +       memset(&sinme, 0, sizeof(sinme));
> > +       memset(&sinhim, 0, sizeof(sinhim));
> > +       memset(&frominet, 0, sizeof(frominet));
> > +       /* these make it easier to avoid warnings */
> > +       sinhim_p = (struct sockaddr *) &sinhim;
> > +       sinme_p = (struct sockaddr *) &sinme;
> > +       frominet_p = (struct sockaddr *) &frominet;
> > +       domain = 0;
> > +       fromlen = 0;
> > +       fd = 0;                         /* fd of network socket */
> > +       buflen = 8 * 1024;              /* length of buffer */
> > +       buf = NULL;                     /* ptr to dynamic buffer */
> > +       alloc_buf = NULL; /* ptr to beginning of memory allocated for
> buf */
> > +       nbuf = 2 * 1024;                /* number of buffers to send in
> sinkmode */
> > +       bufoffset = 0;          /* align buffer to this */
> > +       bufalign = 16*1024;             /* modulo this */
> > +       udp = 0;                        /* 0 = tcp, !0 = udp */
> > +       options = 0;            /* socket options */
> > +       one = 1;                        /* for 4.3 BSD style
> setsockopt() */
> > +       port = 5001;            /* TCP port number */
> > +       host = NULL;                    /* ptr to name of host */
> > +       trans = 0;                      /* 0=receive, !0=transmit mode */
> > +       sinkmode = 0;           /* 0=normal I/O, !0=sink/source mode */
> > +       verbose = 0;            /* 0=print basic info, 1=print cpu rate,
> proc
> > +       nodelay = 0;            /* set TCP_NODELAY socket option */
> > +       b_flag = 0;                     /* use mread() */
> > +       sockbufsize = 0;                /* socket buffer size to use */
> > +       fmt = 'K';                      /* output format: k = kilobits,
> K = kilobytes,
> > +       touchdata = 0;          /* access data after reading */
> > +       milliseconds = 0;                       /* delay in milliseconds
> > +       addr = NULL;
> >  char Usage[] = "\
> >  Usage: ttcp -t [-options] host [ < in ]\n\
> > @@ -173,16 +220,34 @@ void millisleep(long msec)
> >    nanosleep( &req, NULL );
> >  #endif
> Avoid making own changes outside of the __rtems__ guards if you're
> trying to preserve compatibility with the upstream. Please read
> contributing.md.
This one is a weird case. To run the ttcp benchmark, you must have two
systems running it. One is the Tx and the other is the Rx. This usually
means you are running TTCP on your RTEMS target and on your development
system. Some of these are needed to be clean on the native build. Other
parts are specific to RTEMS.
As you can tell from the date on the code it is quite old and it is
questionable
if there is a maintained upstream.for this implementation. In answering
this,
I found https://en.wikipedia.org/wiki/Ttcp which points to nuttcp.net and
that
appears to be maintained since there was a release last year. But that's
GPLv2
so we won't be using that.
We need some changes to make it clean natively and some to make it work
on RTEMS. And I don't think there is really an active upstream for this.
This
was a new port based on newer ways of doing things in RTEMS. What
do you think is best?
It occurred to me as I typed this that perhaps the native version should
be built as part of rtems-tools instead of assuming the end user would
compile this source by hand from libbsd. But then we would be duplicating
the file.
Not a good solution all around. I suspect we really cloned and owned.
--joel
> > +#if (defined (__rtems__))
> > +int rtems_shell_main_ttcp(argc,argv)
> > +#else
> >  int main(argc,argv)
> > +#endif
> >  int argc;
> >  char **argv;
> > +       initialize_vars();
> >         unsigned long addr_tmp;
> >         int c;
> >         if (argc < 2) goto usage;
> > +#ifdef __rtems__
> > +       struct getopt_data getopt_reent;
> > +#define optarg getopt_reent.optarg
> > +#define optind getopt_reent.optind
> > +#define opterr getopt.reent.opterr
> > +#define optopt getopt.reent.optopt
> > +       memset(&getopt_reent, 0, sizeof(getopt_data));
> > +       while ((c = getopt_r(argc, argv,
> > +                                       "drstuvBDTb:f:l:m:n:p:A:O:",
> > +                                       &getopt_reent)) != -1) {
> > +#else
> >         while ((c = getopt(argc, argv, "drstuvBDTb:f:l:m:n:p:A:O:")) !=
> -1) {
> > +#endif
> >                 switch (c) {
> >                 case 'B':
> > @@ -270,8 +335,12 @@ char **argv;
> >                         sinhim.sin_addr.s_addr = inet_addr(host);
> >  #endif
> >                 } else {
> > -                       if ((addr=gethostbyname(host)) == NULL)
> > +                       if ((addr=gethostbyname(host)) == NULL)  {
> >                                 err("bad hostname");
> > +#ifdef __rtems__
> > +                               return 1;
> > +#endif
> I believe the proper way to do this is
> #ifdef __rtems__
> #endif /* __rtems__ */
> #ifdef __rtems__
>                                return 1;
> or
> #ifdef __rtems__
>                                return 1;
> #else /* __rtems__ */
> >                         sinhim.sin_family = addr->h_addrtype;
> >                         bcopy(addr->h_addr,(char*)&addr_tmp,
> addr->h_length);
> >  #if defined(cray)
> > @@ -292,8 +361,13 @@ char **argv;
> >             buflen = 5;         /* send more than the sentinel size */
> > -       if ( (buf = (char *)malloc(buflen+bufalign)) == (char *)NULL)
> > +       if ( (buf = (char *)malloc(buflen+bufalign)) == (char *)NULL)  {
> >                 err("malloc");
> > +#ifdef __rtems__
> > +               return 1;
> > +#endif
> > +       alloc_buf = buf;
> >         if (bufalign != 0)
> >                 buf +=(bufalign - ((int)buf % bufalign) + bufoffset) %
> bufalign;
> > @@ -313,24 +387,40 @@ char **argv;
> >             fprintf(stdout, "  %s\n", udp?"udp":"tcp");
> > -       if ((fd = socket(AF_INET, udp?SOCK_DGRAM:SOCK_STREAM, 0)) < 0)
> > +       if ((fd = socket(AF_INET, udp?SOCK_DGRAM:SOCK_STREAM, 0)) < 0)  {
> >                 err("socket");
> > +#ifdef __rtems__
> > +               return 1;
> > +#endif
> >         mes("socket");
> > -       if (bind(fd, sinme_p, sizeof(sinme)) < 0)
> > +       if (bind(fd, sinme_p, sizeof(sinme)) < 0)  {
> >                 err("bind");
> > +#ifdef __rtems__
> > +               return 1;
> > +#endif
> >  #if defined(SO_SNDBUF) || defined(SO_RCVBUF)
> >         if (sockbufsize) {
> >             if (trans) {
> >                 if (setsockopt(fd, SOL_SOCKET, SO_SNDBUF, &sockbufsize,
> > -                   sizeof sockbufsize) < 0)
> > +                   sizeof sockbufsize) < 0)  {
> >                         err("setsockopt: sndbuf");
> > +#ifdef __rtems__
> > +                       return 1;
> > +#endif
> >                 mes("sndbuf");
> >             } else {
> >                 if (setsockopt(fd, SOL_SOCKET, SO_RCVBUF, &sockbufsize,
> >                         err("setsockopt: rcvbuf");
> > +#ifdef __rtems__
> > +                       return 1;
> > +#endif
> >                 mes("rcvbuf");
> > @@ -344,24 +434,36 @@ char **argv;
> >                 /* We are the client if transmitting */
> >                 if (options)  {
> >  #if defined(BSD42)
> > -                       if( setsockopt(fd, SOL_SOCKET, options, 0, 0) <
> 0)
> > +                       if( setsockopt(fd, SOL_SOCKET, options, 0, 0) <
> 0)  {
> >  #else /* BSD43 */
> > -                       if( setsockopt(fd, SOL_SOCKET, options, &one,
> sizeof(one)) < 0)
> > +                       if( setsockopt(fd, SOL_SOCKET, options, &one,
> sizeof(one)) < 0)  {
> >  #endif
> >                                 err("setsockopt");
> > +#ifdef __rtems__
> > +                               return 1;
> > +#endif
> >  #ifdef TCP_NODELAY
> >                 if (nodelay) {
> >                         struct protoent *p;
> >                         p = getprotobyname("tcp");
> >                         if( p && setsockopt(fd, p->p_proto, TCP_NODELAY,
> > -                           &one, sizeof(one)) < 0)
> > +                           &one, sizeof(one)) < 0)  {
> >                                 err("setsockopt: nodelay");
> > +#ifdef __rtems__
> > +                               return 1;
> > +#endif
> >                         mes("nodelay");
> >  #endif
> > -               if(connect(fd, sinhim_p, sizeof(sinhim) ) < 0)
> > +               if(connect(fd, sinhim_p, sizeof(sinhim) ) < 0)  {
> >                         err("connect");
> > +#ifdef __rtems__
> > +                       return 1;
> > +#endif
> >                 mes("connect");
> >             } else {
> >                 /* otherwise, we are the server and
> > @@ -374,21 +476,41 @@ char **argv;
> >  #endif
> >                 if(options)  {
> >  #if defined(BSD42)
> 0)
> 0)  {
> >  #else /* BSD43 */
> sizeof(one)) < 0)
> sizeof(one)) < 0)  {
> >  #endif
> >                                 err("setsockopt");
> > +#ifdef __rtems__
> > +                               return 1;
> > +#endif
> >                 fromlen = sizeof(frominet);
> >                 domain = AF_INET;
> > -               if((fd=accept(fd, frominet_p, &fromlen) ) < 0)
> > +               int fd_list = fd;
> > +               if((fd=accept(fd_list, frominet_p, &fromlen) ) < 0)  {
> >                         err("accept");
> > +#ifdef __rtems__
> > +                       return 1;
> > +#endif
> > +               if(close(fd_list) < 0)  {
> > +                       err("close");
> > +#ifdef __rtems__
> > +                       return 1;
> > +#endif
> >                 { struct sockaddr_in peer;
> >                   socklen_t peerlen = sizeof(peer);
> >                   if (getpeername(fd, (struct sockaddr *) &peer,
> >                                 &peerlen) < 0) {
> >                         err("getpeername");
> > +#ifdef __rtems__
> > +                       return 1;
> > +#endif
> >                   fprintf(stderr,"ttcp-r: accept from %s\n",
> >                         inet_ntoa(peer.sin_addr));
> > @@ -438,7 +560,12 @@ char **argv;
> >                                 nbytes += cnt;
> > -       if(errno) err("IO");
> > +       if(errno)  {
> > +               err("IO");
> > +#ifdef __rtems__
> > +               return 1;
> > +#endif
> >         (void)read_timer(stats,sizeof(stats));
> >         if(udp&&trans)  {
> >                 (void)Nwrite( fd, buf, 4 ); /* rcvr end */
> > @@ -446,6 +573,14 @@ char **argv;
> > +       if(close(fd) < 0)  {
> > +               err("close");
> > +#ifdef __rtems__
> > +               return 1;
> > +#endif
> >         if( cput <= 0.0 )  cput = 0.001;
> >         if( realt <= 0.0 )  realt = 0.001;
> >         fprintf(stdout,
> > @@ -471,22 +606,41 @@ char **argv;
> >                 trans?"-t":"-r",
> >                 buf);
> > +       free(alloc_buf);
> > +#ifdef __rtems__
> > +       return 0;
> > +#else
> >         exit(0);
> > +#endif
> >  usage:
> >         fprintf(stderr,Usage);
> > +       free(alloc_buf);
> > +#ifdef __rtems__
> > +       return 1;
> > +#else
> >         exit(1);
> > -       return 0;
> > +       return 1;
> > +#endif
> >  void
> > -err(s)
> > +err(s)
> >  char *s;
> >         fprintf(stderr,"ttcp%s: ", trans?"-t":"-r");
> >         perror(s);
> >         fprintf(stderr,"errno=%d\n",errno);
> > +       free(alloc_buf);
> > +       if (fd != 0)
> > +               close(fd);
> > +#ifdef __rtems__
> > +       return;
> > +#else
> >         exit(1);
> > +#endif
> >  void
> > @@ -540,7 +694,9 @@ double b;
> >  static struct  timeval time0;  /* Time at which timing started */
> >  static struct  rusage ru0;     /* Resource utilization at the start */
> > +#ifndef __rtems__
> >  static void prusage();
> > +#endif
> >  static void tvadd();
> >  static void tvsub();
> >  static void psecs();
> > @@ -601,7 +757,11 @@ int len;
> >         getrusage(RUSAGE_SELF, &ru1);
> >         gettimeofday(&timedol, (struct timezone *)0);
> > +#ifndef __rtems__
> >         prusage(&ru0, &ru1, &timedol, &time0, line);
> > +#else
> > +       line[0] = '\0';
> > +#endif
> >         (void)strncpy( str, line, len );
> >         /* Get real time */
> > @@ -617,6 +777,7 @@ int len;
> >         return( cput );
> > +#ifndef __rtems__
> >  static void
> >  prusage(r0, r1, e, b, outp)
> >         register struct rusage *r0, *r1;
> > @@ -731,6 +892,7 @@ prusage(r0, r1, e, b, outp)
> >         *outp = '\0';
> > +#endif
> >  static void
> >  tvadd(tsum, t0, t1)
> > 2.27.0
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210615/24592257/attachment-0001.html>
