GSOC POSIX Compliance: Stuck trying to build Newlib
Matthew Joyce mfjoyce2004 at gmail.com
Wed Jun 16 15:57:18 UTC 2021
Hi Dr. Joel,
I tried that in newlib/libc and there were at least no errors.
(Nothing leading me to believe it was successful either!)
However I still got the same error when I sudo make install.
(sparc-rtems-ranlib: command not found) (among others!)
Thanks again!
Sincerely,
Matt
On Wed, Jun 16, 2021 at 3:06 PM Joel Sherrill <joel at rtems.org> wrote:
> Does adding --no-recursive and running it only from the directory you touched a build system file in help?
> It is regenerating a lot you don't want to touch anyway.
> --joel
> On Wed, Jun 16, 2021, 5:32 AM Matthew Joyce <mfjoyce2004 at gmail.com> wrote:
>> Hi Eshan,
>> Thanks very much for your follow up! Ok, I see now that if I go into
>> development/newlib/newlib-cygwin/newlib and run autoreconf -fvi with
>> the v2.69 using the PATH that Dr. Joel just showed, it starts to run.
>> It always eventually exits with an error though. (please see attached
>> .txt). I hope you can read that...I used the command "script" to
>> output everything to a text file.
>> Do you have any idea where I might be going wrong?
>> Thank you!
>> Sincerely,
>> Matt
>> On Tue, Jun 15, 2021 at 8:23 PM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
>> > Hi matt
>> > It would work if run inside newlib instead of newlib-cygwin
>> > run command inside of ../newlib-cygwin/newlib
>> > instead of ../newlib-cygwin
>> > On Tue, Jun 15, 2021 at 10:59 PM Matthew Joyce <mfjoyce2004 at gmail.com> wrote:
>> >> Ah, ok will do! Thank you for the tip.
>> >> On Tue, Jun 15, 2021 at 7:17 PM Gedare Bloom <gedare at rtems.org> wrote:
>> >> > Just a note, it's more efficient to capture your terminal dump into a
>> >> > text file and attach that, rather than put a screenshot up.
>> >> > On Tue, Jun 15, 2021 at 11:14 AM Matthew Joyce <mfjoyce2004 at gmail.com> wrote:
>> >> > > Hi Gentlemen,
>> >> > > Thanks very much for your quick replies!
>> >> > > I just tried both, but perhaps I'm misinterpreting your suggestions.
>> >> > > (Could you please see the attached commands / errors!)
>> >> > > Eshan,
>> >> > > I did see that link, but it wasn't clear to me what the solution was...Sorry!
>> >> > > Sincerely,
>> >> > > Matt
>> >> > > On Tue, Jun 15, 2021 at 6:52 PM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
>> >> > > > Hi Matt,
>> >> > > > Try running the command with autoconf version 2.69 that's shipped with RTEMS in the rtems bin
>> >> > > > That works as well.
>> >> > > > Also From a quick google search this is what I found : https://superuser.com/questions/617872/cant-locate-autom4te-channeldefs-pm-in-inc-when-it-definitely-is-there
>> >> > > > On Tue, Jun 15, 2021 at 9:12 PM Matthew Joyce <mfjoyce2004 at gmail.com> wrote:
>> >> > > >> Hello Dr. Joel and Eshan,
>> >> > > >> I have a patch ready to send to Newlib for the sig function prototypes
>> >> > > >> and STR2SIG_MAX.
>> >> > > >> But to do that, I think I need to have Newlib built, which I must
>> >> > > >> still be doing wrong. The error that I am getting is attached below.
>> >> > > >> I’ve been trying to follow the steps here:
>> >> > > >> https://medium.com/my-gsoc-2019-journey/apply-newlib-patch-to-rtems-source-builder-6873b0fb31b8
>> >> > > >> and https://medium.com/my-gsoc-2019-journey/build-newlib-for-sparc-and-arm-architecture-6b3287d4c6f2
>> >> > > >> I even had rebuilt everything from scratch to see if that would help,
>> >> > > >> but I still get the same error. Maybe I cloned the newlib source into
>> >> > > >> the wrong directory?
>> >> > > >> I was hoping to get the patch off to Newlib for review as a first step
>> >> > > >> while I work on writing the actual methods. When you get a moment,
>> >> > > >> could you please advise? Thank you very much!
>> >> > > >> Sincerely,
>> >> > > >> Matt
>> >> > > _______________________________________________
>> >> > > devel mailing list
>> >> > > devel at rtems.org
>> >> > > http://lists.rtems.org/mailman/listinfo/devel
